  3. Entwicklung
  4. Daten aus Fronius Solarweb auslesen
636 Beiträge 60 Kommentatoren 287.6k Aufrufe 50 Beobachtet
    Andi.T 0
    #624
    Hallo @jb_sullivan danke für den Tipp, musste erst noch darauf kommen, den Experten Modus einzuschalten um das Objekt zu finden. Bin gespannt.
      TimoWald
      #625
      Bei mir kommt aktuel noch folgende Meldung. Die objecte unter javascript/0/ werden bei mir nicht angelegt.
      2026-01-10 17:11:15.117 - info: admin.0 (302) ==> Connected system.user.admin from ::ffff:192.168.9.50
      2026-01-10 17:11:18.317 - info: javascript.0 (29439) script.js.common.Solarweb: Stopping script
      2026-01-10 17:11:18.330 - info: javascript.0 (29439) script.js.common.Solarweb: start JavaScript (Blockly)
      2026-01-10 17:11:18.334 - error: javascript.0 (29439) script.js.common.Solarweb: Error: ReferenceError: URL is not defined
      2026-01-10 17:11:18.334 - error: javascript.0 (29439) script.js.common.Solarweb: at Login (script.js.common.Solarweb:9:9)
      2026-01-10 17:11:18.334 - error: javascript.0 (29439) script.js.common.Solarweb: at Aggrdata_Zeitplan (script.js.common.Solarweb:995:9)
      2026-01-10 17:11:18.334 - error: javascript.0 (29439) script.js.common.Solarweb: at script.js.common.Solarweb:1041:7
      2026-01-10 17:11:18.334 - error: javascript.0 (29439) script.js.common.Solarweb: at script.js.common.Solarweb:1050:3
      2026-01-10 17:11:18.334 - error: javascript.0 (29439) script.js.common.Solarweb: at Script.runInContext (node:vm:149:12)
      2026-01-10 17:11:19.248 - info: admin.0 (302) <== Disconnect system.user.admin from ::ffff:192.168.9.50 javascript
      2026-01-10 17:11:19.474 - info: myuplink.0 (666) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.52" has to be type "number" but received type "string"
      2026-01-10 17:11:19.519 - info: myuplink.0 (666) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.58" has to be type "number" but received type "string"
      2026-01-10 17:11:19.602 - info: myuplink.0 (666) State value to set for "myuplink.0.852667d2-3708-4ad8-93f5-7c1db0d06d23.hp24-r-20250320-04-d1-6e-d9-4f-3f.Text_not_found_id_fw_ait-V3_lang_de_.40011" has to be type "number" but received type "string"
      • JB_SullivanJ JB_Sullivan
        Weiß jemand, ob Fronius etwas bei den auslesbaren Datenpunkten verändert hat?
        Ich bekomme seit dieser Woche nämlich keine Summenwerte für die aktuelle Woche und die Vorwoche mehr (siehe SUMME)
        Im Script gibt es ebenfalls eine Fehlermeldung:
        javascript.0	16:01:15.261	info
        Stopping script
        javascript.0	16:01:15.412	info
        javascript.0	16:01:17.625	warn
        Solarweb Current Day konnte nicht abgefragt werden
        javascript.0	16:01:19.516	warn
        Solarweb Current Month konnte nicht abgefragt werden
        javascript.0	16:01:21.515	warn
        Solarweb Current Year konnte nicht abgefragt werden
        javascript.0	16:01:23.516	warn
        Solarweb Total konnte nicht abgefragt werden
        javascript.0	16:01:23.584	info
        Solarweb Token erstellt
        javascript.0	16:01:25.639	info
        registered 8 subscriptions, 9 schedules, 0 messages, 0 logs and 0 file subscriptions
        javascript.0	16:02:01.296	info
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #626
        @JB_Sullivan sagte in Daten aus Fronius Solarweb auslesen:
        Hallo
        Funktioniert es bei dir wieder?
        Hab auch das Problem.
        javascript.1	11:56:19.720	info	Stopping script
        javascript.0	11:56:19.908	info	Stopping script
        javascript.0	11:56:20.271	info	start JavaScript (Blockly)
        javascript.0	11:56:20.680	info	Solarweb Token erstellt
        javascript.0	11:56:22.332	warn    Solarweb Current Day konnte nicht abgefragt werden
        javascript.0	11:56:24.333	warn    Solarweb Current Month konnte nicht abgefragt werden
        javascript.0	11:56:26.331	warn    Solarweb Current Year konnte nicht abgefragt werden
        javascript.0	11:56:28.337	warn    Solarweb Total konnte nicht abgefragt werden
        javascript.0	11:56:32.399	info	Solarweb Forecast Forecast Today konnte nicht abgefragt werden - Kein Premiumaccount
        javascript.0	11:56:36.377	info	registered 8 subscriptions, 10 schedules, 0 messages, 0 logs and 0 file subscriptions
        javascript.0	11:56:36.406	info	Solarweb Forecast Forecast Tomorrow konnte nicht abgefragt werden - Kein Premiumaccount
        ° Fixer ---> iob fix
          topsurfer
          #627
          nute Solarweb seit einem Jahr und bin auch schon "immer" Pro-Kunde.
          In der App zeigt er mir auch "Premium" an (das ist ja das "Pro", oder?
          Aber seit paar Tagen meldet der Adapter (Inst. ist wohl die aktuellste Version 0.0.3):
          "Not a Pro PV System"
          Kennt jemand diese Meldung?
          Jemand nee Idee?
          Wenn ich in den Einstellungen vom Adapter ein falsches PW angebe erscheint (korrekt): Authentication failed.
          Also das Login scheint ja zu stimmen / weiterhin zu funktionieren.
            Andi.T 0
            #628
            Hallo, weiss jemand warum ich solch eine Fehlermeldung bekomme und wie ich sie abstelle?
            Die Vorhersage Daten für den Tag und den nächsten Tag sehe ich jedoch in den Objekten.
            Insgesamt sind es 3 Fehlermeldungsblöcke mit jeweils anderen Zeiten
            Die Fronius PV-ID habe ich manuell im Log gekürzt: Hier ein Block als Beispiel:
            2026-06-12 13:45:01.779 - error: fronius-solarweb.0 (4096599) https://swqapi.solarweb.com/pvsystems/f5535....*/weather/energyforecast?from=1781178286596&to=1781264681596
            2026-06-12 13:45:01.780 - error: fronius-solarweb.0 (4096599) AxiosError: Request failed with status code 404
            2026-06-12 13:45:01.780 - error: fronius-solarweb.0 (4096599) {"responseError":1002,"responseMessage":"Requested resource not found."}
            • A Andi.T 0
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #629
              @Andi.T-0 sagte:
              bei mir auch das gleiche
              • C Offline
                c1olli
                #630
                Habt ihr ein Fronius Solarweb Abo ? Wenn nein, dann würde es Sinn machen weil die Energievorhersage nur im Abo und nicht in der freien Version verfügbar ist.
                Olli
                NegaleinN A 2 Antworten Letzte Antwort
                • C c1olli
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #631
                  @c1olli sagte:
                  Ja
                  • C c1olli
                    Andi.T 0
                    schrieb am zuletzt editiert von Andi.T 0
                    #632
                    @c1olli sagte:
                    ja, so ist es. Die Tageswerte kommen auch und sind auch korrekt, aber diese Fehler halt...
                      Andi.T 0
                      #633
                      Hallo, nach einem Update des js-controller auf Version 7.2.2 sind die Fehlermeldungen im Moment weg.
                      • R Offline
                        reutli
                        #634
                        Moin,
                        habe seit einiger Tagen wieder diese "altbekannte" Fehlermeldung.
                        Habe aber keinen Schimmer wie ich die abstellen kann.
                        javascript.0
                           2026-08-14 05:32:08.060	warn	script.js.PV_Überwachung.Fronius: Solarweb Total konnte nicht abgefragt werden
                        javascript.0
                           2026-08-14 05:32:06.051	warn	script.js.PV_Überwachung.Fronius: Solarweb Current Year konnte nicht abgefragt werden
                        javascript.0
                           2026-08-14 05:32:04.057	warn	script.js.PV_Überwachung.Fronius: Solarweb Current Month konnte nicht abgefragt werden
                        javascript.0
                           2026-08-14 05:32:02.052	warn	script.js.PV_Überwachung.Fronius: Solarweb Current Day konnte nicht abgefragt werden
                        Danke schon einmal für die Hilfe!
                        iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                        *Wer freundlich ist, dem wird freundlich geholfen *
                        • nik82N Offline
                          nik82N Offline
                          nik82
                          #635
                          @reutli
                          Bei Solarweb im Internet einmal anmelden und Meldung bestätigen.
                          R 1 Antwort Letzte Antwort
                          • nik82N nik82
                            @reutli
                            reutli
                            #636
                            @nik82 sagte:
                            @reutli
                            Es kann so einfach sein! Danke für den Tipp!
