  4. Fehlermeldung bei Update Adapters
    6.3k
27 Beiträge 4 Kommentatoren 1.3k Aufrufe 2 Beobachtet
    @Ro75
    Doch, das ist okay. Jedenfalls solange keine verwaisten INODES gelöscht wurden.
    Die Suche nach diesen Orphans läuft wohl mittlerweile bei jedem x-ten Bootvorgang mal mit.
    Ro75R Offline
    Ro75R Offline
    Ro75
    @Thomas-Braun sagte:
    Das wusste ich bisher nicht. Danke für die Info.
    Ro75.
    • A Alero
      @Thomas-Braun
      iob diag:
      ```bash
      Script v.2026-06-01
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.12.63+deb13-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
         Firmware Date: Tue 2014-04-01
          Firmware Age: 12y 2month 1w 4d
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64bit
      System was installed 90 days ago (on 2026-03-13).
      Systemuptime and Load:
       12:09:23 up 1 min,  1 user,  load average: 1.07, 0.45, 0.17
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2026-06-12 12:09:23 CEST
                 Universal time: Fri 2026-06-12 10:09:23 UTC
                       RTC time: Fri 2026-06-12 10:09:23
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      juergen
      HOME=/home/juergen
      GROUPS=juergen cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        Not found
      Desktop:
      Session:                tty
      Boot Target:            multi-user.target
      *** MEMORY ***
      Mem:            8.3G        3.3G        4.7G        4.5M        497M        5.0G
      Swap:           5.5G          0B        5.5G
      Total:           13G        3.3G         10G
      Active iob-Instances:   17
               7947 M total memory
               3186 M used memory
               2927 M active memory
                234 M inactive memory
               4524 M free memory
                 57 M buffer memory
                417 M swap cache
               5237 M total swap
                  0 M used swap
               5237 M free swap
      top - 12:09:23 up 1 min,  1 user,  load average: 1.07, 0.45, 0.17
      Tasks: 165 total,   5 running, 160 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 25.5 us,  4.3 sy,  0.0 ni, 68.1 id,  0.0 wa,  0.0 hi,  2.1 si,  0.0 st
      MiB Mem :   7947.3 total,   4523.7 free,   3187.2 used,    474.5 buff/cache
      MiB Swap:   5238.0 total,   5238.0 free,      0.0 used.   4760.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  496K  795M   1% /run
      /dev/sda1      ext4       93G  5.8G   83G   7% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     3.9G  3.9M  3.9G   1% /tmp
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1000
      Messages concerning filesystems in dmesg:
      [Fri Jun 12 12:07:42 2026] EXT4-fs (sda1): orphan cleanup on readonly fs
      [Fri Jun 12 12:07:42 2026] EXT4-fs (sda1): mounted filesystem ad7cb7c3-87c0-4151-8142-0f5900745d4e ro with ordered data mode. Quota mode: none.
      [Fri Jun 12 12:07:43 2026] EXT4-fs (sda1): re-mounted ad7cb7c3-87c0-4151-8142-0f5900745d4e r/w.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      617M    /var/
      296M    /var/cache
      288M    /var/cache/apt
      198M    /var/cache/apt/archives
      174M    /var/lib
      Archived and active journals take up 11.8M in the file system.
      /opt/iobroker/backups:
      16M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      784M    /opt/iobroker/iobroker-data/
      587M    /opt/iobroker/iobroker-data/files
      128M    /opt/iobroker/iobroker-data/backup-objects
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      59M     /opt/iobroker/iobroker-data/files/vis
      30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
      29M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      12M     /opt/iobroker/iobroker-data/files/vis.0/kuddel_08_20/vis-views.json
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.3
      /usr/bin/node           v22.22.3
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.3-1nodesource1
        Candidate: 22.22.3-1nodesource1
        Version table:
       *** 22.22.3-1nodesource1 1001
           22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main amd64 Packages
              500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.1.2, hostname: iobroker      , alive, uptime: 108)
      Core adapters versions
      js-controller:  7.1.2
      admin:          7.8.23
      javascript:     9.0.18
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://security.debian.org/debian-security trixie-security InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Get:5 https://repos.influxdata.com/debian stable InRelease [6922 B]
      Fetched 6922 B in 0s (17.8 kB/s)
      Reading package lists...
      Pending systemupdates: 0
      ============= Mark until here for C&P =============
      iob diag has finished.
      @Alero sagte:
      Der Adapter ist aber jetzt auch aktuell:
      Adapter "ws" : 4.1.0 , installed 4.1.0
      Bleibt noch das Ding mit CIFS und noserverino.
      Schiebt dein Backitup-Adapter seine Dateien zufällig auf ein per SMB/CIFS angebundenes FritzNAS?
      Das ist nämlich ein bekanntes Ding, hier muss die Option 'noserverino' aktiv sein.
        @Alero sagte:
        Setz den user juergen in die Gruppe adm:
        sudo usermod -aG adm juergen
        Dann die Kiste einmal sauber neustarten.
        Und nimm die persönlichen Daten aus dem letzten Teil raus.
        Im diag werden keine Fehler angezeigt:
        Kann aber auch ein Fehler im Code an der Stelle sein.
        Kopier jetzt nochmal die Ausgabe von
        iob update && iob upgrade
        hier rein.
        Ich hoffe, ich hab alles!
        Ist am Handy nicht ganz so einfach
          @Alero sagte:
          hier rein.
          Alero
          @Thomas-Braun
          juergen@iobroker:~$ sudo usermod -aG juergen adm
          [sudo] password for juergen:
          usermod: user 'adm' does not exist
            @Alero sagte:
            Alero
            @Thomas-Braun
            Hi, ja Backup wird auf mein nas geschrieben
              Alero
              @Homoran
              wie mache ich das?
              • A Alero
                @Thomas-Braun
                @Alero
                Hatte aus der Erinnerung geschrieben.
                So müsste es aber passen:
                • A Alero
                  @Thomas-Braun
                  @Alero sagte:
                  Ein FritzNAS?
                  Setz aber mal die Option 'noserverino' in den Einstellungen des Backitup-Adapters.
                  A 2 Antworten Letzte Antwort
                    @Alero sagte:
                    Ein FritzNAS?
                    Alero
                    @Thomas-Braun
                    nein synology
                    • A Alero
                      @Thomas-Braun
                      nein synology
                      @Alero
                      Setz trotzem mal 'noserverino'.
                        @Alero sagte:
                        Ein FritzNAS?
                        Alero
                        schrieb am zuletzt editiert von Alero
                        @Thomas-Braun
                        wofür ist die Einstellung noserverino?
                        gesetzt
                        • A Alero
                          @Thomas-Braun
                          gesetzt
                          @Alero
                          Siehe die Meldung aus deinem Bildchen.
                          Wenn es Text wäre könnte ich das jetzt kopieren...
                            @Alero
                            Alero
                            hat gepasst.
                            Alle Adapter ließen sich jetzt installieren.
                            war jetzt noch was offen?
                              Alero
                              danke für eure Hilfe
                              • A Alero
                                hat gepasst.
                                @Alero sagte:
                                Schau dir einen aktuellen Lauf (nach einem sauberen Neustart der Kiste) von
                                iob diag
                                an.
                                  Alero
                                  Mache ich
