  4. Test Adapter NSPanel-lovelace-ui v1.x.x
    6.5k
1.3k Beiträge 36 Kommentatoren 310.9k Aufrufe 36 Beobachtet
  • W welli
    @tt-tom
    Hier mal ein Auszug wo vorher alles das selbe ist für NSpanel 1+2 dann hat NSpanel 1 ein problem.
    2026-05-30 20:21:15.015 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~3806625,6°C~~63488~Leistung~15.45 kWh~侀~65222~Solar 11KW~3.15 kWh~侀~2016~Solar 800W~30.4 W~~64800~Sonne~21:33~~64512~Wind~2,6m/s~~64512~Böen~4,6m/s~~65535~Windr.~SSW~~65093~Feuchte~50%~~65222~UV~1,110?10~~31~Wasser~10?11~~2016~Zeichpumpe~10?12~~65504~UV-Licht~10?13~~35921~Teischspill~00?14~~35921~Luftpumpe~0"} to panel.
    2026-05-30 20:21:15.483 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
    2026-05-30 20:21:15.707 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
    2026-05-30 20:21:15.857 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~3806625,6°C~~63488~Leistung~15.45 kWh~侀~65222~Solar 11KW~3.15 kWh~侀~2016~Solar 800W~3.15 kWh~~64800~Sonne~21:33~~64512~Wind~2,6m/s~~64512~Böen~4,6m/s~~65535~Windr.~SSW~~65093~Feuchte~50%~~65222~UV~1,110?10~~31~Wasser~10?11~~2016~Zeichpumpe~10?12~~65504~UV-Licht~10?13~~35921~Teischspill~00?14~~35921~Luftpumpe~0"} to panel.
    2026-05-30 20:21:20.024 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~3806625,6°C~~63488~Leistung~15.45 kWh~侀~65222~Solar 11KW~3.15 kWh~侀~2016~Solar 800W~3.15 kWh~~64800~Sonne~21:33~~64512~Wind~2,6m/s~~64512~Böen~4,6m/s~~65535~Windr.~SSW~~65093~Feuchte~50%~~65222~UV~1,110?10~~31~Wasser~10?11~~2016~Zeichpumpe~10?12~~65504~UV-Licht~10?13~~35921~Teischspill~00?14~~35921~Luftpumpe~0"} to panel.
    2026-05-30 20:21:20.399 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
    2026-05-30 20:21:20.624 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
    2026-05-30 20:21:20.824 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~3806625,6°C~~63488~Leistung~2694.18 W~侀~65222~Solar 11KW~29.6 W~侀~2016~Solar 800W~29.6 W~~64800~Sonne~21:33~~64512~Wind~2,6m/s~~64512~Böen~4,6m/s~~65535~Windr.~SSW~~65093~Feuchte~50%~~65222~UV~1,110?10~~31~Wasser~10?11~~2016~Zeichpumpe~10?12~~65504~UV-Licht~10?13~~35921~Teischspill~00?14~~35921~Luftpumpe~0"} to panel.
    2026-05-30 20:21:23.019 - debug: nspanel-lovelace-ui.0 (20751) [#scr] [NSPanel_1] Switch page to invisible!
    2026-05-30 20:21:23.019 - warn: nspanel-lovelace-ui.0 (20751) [NSPanel_1] is offline!
    2026-05-30 20:21:23.219 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"pageType~pageStartup","opt":{"retain":true}} to panel.
    2026-05-30 20:21:24.633 - debug: nspanel-lovelace-ui.0 (20751) [mqttServer] Client "NSPanel_1-7E1E20" login successful (user="seRPHbcwAkkSRlb").
    2026-05-30 20:21:25.014 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~3806625,6°C~~63488~Leistung~15.45 kWh~侀~65222~Solar 11KW~29.6 W~侀~2016~Solar 800W~29.6 W~~64800~Sonne~21:33~~64512~Wind~2,6m/s~~64512~Böen~4,6m/s~~65535~Windr.~SSW~~65093~Feuchte~50%~~65222~UV~1,110?10~~31~Wasser~10?11~~2016~Zeichpumpe~10?12~~65504~UV-Licht~10?13~~35921~Teischspill~00?14~~35921~Luftpumpe~0"} to panel.
    2026-05-30 20:21:25.350 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1] Receive message:{"type":"event","method":"startup","id":"61","action":"eu","opt":"5.1.1"}
    2026-05-30 20:21:25.350 - info: nspanel-lovelace-ui.0 (20751) [NSPanel_1] is online!
    2026-05-30 20:21:25.351 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/tempOffset","payload":"0"} to panel.
    2026-05-30 20:21:25.362 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/STATUS0","payload":""} to panel.
    2026-05-30 20:21:25.373 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/POWER1","payload":""} to panel.
    2026-05-30 20:21:25.385 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/POWER2","payload":""} to panel.
    2026-05-30 20:21:25.397 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/GetDriverVersion","payload":""} to panel.
    2026-05-30 20:21:25.411 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
    2026-05-30 20:21:25.421 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/Rule3","payload":"ON CustomSend DO RuleTimer3 140 ENDON ON Rules#Timer=3 DO CustomSend pageType~pageStartup ENDON"} to panel.
    2026-05-30 20:21:25.476 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/Rule3","payload":"1"} to panel.
    2026-05-30 20:21:25.598 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1] set color to RGB {"r":255,"g":255,"b":255} -> 65535
    2026-05-30 20:21:25.598 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"dimmode~15~59~0~65535"} to panel.
    2026-05-30 20:21:25.598 - debug: nspanel-lovelace-ui.0 (20751) [main] [NSPanel_1] Switch page to visible!
    2026-05-30 20:21:25.635 - debug: nspanel-lovelace-ui.0 (20751) [mqttServer] Client NSPanel_1-7E1E20 connected.
    2026-05-30 20:21:25.679 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
    2026-05-30 20:21:25.732 - debug: nspanel-lovelace-ui.0 (20751) [main] Register last send type 44_17_93_7E_1E_20-cardGrid block for 200ms
    2026-05-30 20:21:25.779 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1] Set screeensaver timeout to 15s.
    2026-05-30 20:21:25.780 - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_1] Set screeensaver timeout to 2s.
    2026-05-30 20:21:25.823 - info: nspanel-lovelace-ui.0 (20751) [NSPanel_1] Panel startup finished!
    TT-Tom
    #1215
    @welli du musst Logs immer in Codetags </> packen sonst kann das keiner lesen
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    W 1 Antwort Letzte Antwort
    • T Nicht stören
      T Nicht stören
      ticaki
      #1216
      @homoran wärst du so nett :)
      Spenden
        Snigga
        #1217
        Hallo Zusammen,
        kann ich zu dem Punkt .cmd.screenSaver.infoIcon eigentlich auch irgendwo die Farbe einstellen ist aktuell immer Gelb und ich möchte gerne hier die verschiedenen Müllarten einblenden so 1 -2 Tage vorher. Geht das?
        • T Nicht stören
          T Nicht stören
          ticaki
          #1218
          Die Farbe ist fest im HMI vergeben, das kann ich nicht ändern. Ich hab kaum ahnung von dem HMI zeugs
          Spenden
            Snigga
            #1219
            Danke für die Antwort
            • T TT-Tom
              W Offline
              W Offline
              welli
              #1220
              @TT-Tom
              Hoffe mal das es so richtig ist
              2026-05-30 20:21:15.015  - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~38066~~25,6°C~~~~63488~Leistung~15.45 kWh~~~侀~65222~Solar 11KW~3.15 kWh~~~侀~2016~Solar 800W~30.4 W~~~~64800~Sonne~21:33~~~~64512~Wind~2,6m/s~~~~64512~Böen~4,6m/s~~~~65535~Windr.~SSW~~~~65093~Feuchte~50%~~~~65222~UV~1,11~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
              2026-05-30 20:21:15.857  - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~38066~~25,6°C~~~~63488~Leistung~15.45 kWh~~~侀~65222~Solar 11KW~3.15 kWh~~~侀~2016~Solar 800W~3.15 kWh~~~~64800~Sonne~21:33~~~~64512~Wind~2,6m/s~~~~64512~Böen~4,6m/s~~~~65535~Windr.~SSW~~~~65093~Feuchte~50%~~~~65222~UV~1,11~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
              2026-05-30 20:21:20.024  - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~38066~~25,6°C~~~~63488~Leistung~15.45 kWh~~~侀~65222~Solar 11KW~3.15 kWh~~~侀~2016~Solar 800W~3.15 kWh~~~~64800~Sonne~21:33~~~~64512~Wind~2,6m/s~~~~64512~Böen~4,6m/s~~~~65535~Windr.~SSW~~~~65093~Feuchte~50%~~~~65222~UV~1,11~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
              2026-05-30 20:21:20.824  - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~38066~~25,6°C~~~~63488~Leistung~2694.18 W~~~侀~65222~Solar 11KW~29.6 W~~~侀~2016~Solar 800W~29.6 W~~~~64800~Sonne~21:33~~~~64512~Wind~2,6m/s~~~~64512~Böen~4,6m/s~~~~65535~Windr.~SSW~~~~65093~Feuchte~50%~~~~65222~UV~1,11~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
              2026-05-30 20:21:25.014  - debug: nspanel-lovelace-ui.0 (20751) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~38066~~25,6°C~~~~63488~Leistung~15.45 kWh~~~侀~65222~Solar 11KW~29.6 W~~~侀~2016~Solar 800W~29.6 W~~~~64800~Sonne~21:33~~~~64512~Wind~2,6m/s~~~~64512~Böen~4,6m/s~~~~65535~Windr.~SSW~~~~65093~Feuchte~50%~~~~65222~UV~1,11~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
              • W Offline
                W Offline
                welli
                #1221
                @TT-Tom
                Habe mir eine Popup Page eingebaut.
                Diese meldet auch , aber nach einer gewissen Zeit starten die NSpanels neu und die Seite verschwindet bevor mann Sie bestätigen kann.
                Ist dies normal?
                Hier noch die info die ich bekomme.
                2026-06-03 10:59:21.165 info [NSPanel_1] Panel startup finished!
                2026-06-03 10:59:21.120 info [NSPanel_2] Panel startup finished!
                • T Nicht stören
                  T Nicht stören
                  ticaki
                  #1222
                  nein es ist nicht normal das ein panel häufig neustartet - das passiert bei schlechtem wlan oder einem adapter bug - aktuell sieht es nach schlechtem wlan aus (weil das nicht meine schuld wäre) aber einen bug oder Einrichtungsfehler will ich nicht ausschließen.
                  Dein log auszug ist zu kurz - man bräuchte schon mindestens 2-3 x offline drin
                  Spenden
                  • T ticaki
                    W Offline
                    W Offline
                    welli
                    #1223
                    @ticaki
                    HIer mal ne log, dauert +/- 8 min bis die Panels neu starten
                    2026-06-03 11:04:20.016 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1243.13 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:20.018 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1243.13 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:20.392 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:20.474 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:20.663 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:20.700 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:20.861 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1243.13 W~~~侀~65222~Solar 11KW~-1.6 W~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:20.893 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1243.13 W~~~侀~65222~Solar 11KW~-1.6 W~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:22.189 - info: admin.0 (905) ==> Connected system.user.admin from ::ffff:192.168.178.53
                    2026-06-03 11:04:25.012 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~-1.6 W~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:25.014 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:25.369 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:25.438 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:25.641 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:25.758 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:25.796 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:25.968 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:30.017 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:30.060 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1230.55 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:30.371 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:30.433 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:30.650 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:30.702 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:30.853 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1230.55 W~~~侀~65222~Solar 11KW~-1.6 W~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:30.905 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1230.55 W~~~侀~65222~Solar 11KW~-1.6 W~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:35.014 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~-1.6 W~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:35.016 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~-1.6 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:35.389 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:35.426 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:35.599 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:35.659 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:35.796 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:35.854 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:40.017 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:40.019 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:40.372 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:40.441 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:40.613 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:40.641 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:40.790 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1230.55 W~~~侀~65222~Solar 11KW~0 W~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:40.864 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~1230.55 W~~~侀~65222~Solar 11KW~0 W~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:44.256 - info: javascript.0 (1104) script.js.common.NSPANEL_Abfall_Info_Weiterleiten1: Stopping script
                    2026-06-03 11:04:44.261 - info: javascript.0 (1104) script.js.common.NSPANEL_Abfall_Info_Weiterleiten1: start JavaScript (Blockly)
                    2026-06-03 11:04:44.274 - info: javascript.0 (1104) script.js.common.NSPANEL_Abfall_Info_Weiterleiten1: registered 0 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
                    2026-06-03 11:04:45.011 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 W~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:45.012 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:45.368 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:45.435 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:45.608 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:45.637 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:45.783 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:45.838 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:46.475 - info: admin.0 (905) <== Disconnect system.user.admin from ::ffff:192.168.178.53 javascript
                    2026-06-03 11:04:50.017 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3021.36 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:50.019 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3021.36 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:50.414 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:50.443 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:50.630 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:50.717 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:50.831 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3021.36 W~~~侀~65222~Solar 11KW~0 W~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:50.916 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3021.36 W~~~侀~65222~Solar 11KW~0 W~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:55.013 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 W~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:55.014 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:55.384 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:55.397 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:04:55.659 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:55.669 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:04:55.873 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:04:55.915 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~4.89 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:05:00.010 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:05"} to panel.
                    2026-06-03 11:05:00.011 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:05"} to panel.
                    2026-06-03 11:05:00.020 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] state triggerd 44_17_93_7E_1E_20/cmd/popupNotificationCustom
                    2026-06-03 11:05:00.020 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] update notification id 1
                    2026-06-03 11:05:00.020 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] notification id 1 is first in queue, updating view
                    2026-06-03 11:05:00.022 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] state triggerd E0_E2_E6_0B_8C_D4/cmd/popupNotificationCustom
                    2026-06-03 11:05:00.022 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] update notification id 1
                    2026-06-03 11:05:00.022 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] notification id 1 is first in queue, updating view
                    2026-06-03 11:05:00.220 - debug: nspanel-lovelace-ui.0 (2910) [#scr] [NSPanel_1] Switch page to invisible!
                    2026-06-03 11:05:00.220 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] [NSPanel_1] Switch page to visible!
                    2026-06-03 11:05:00.220 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] Register last send type 44_17_93_7E_1E_20-popupNotify block for 200ms
                    2026-06-03 11:05:00.220 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"pageType~popupNotify"} to panel.
                    2026-06-03 11:05:00.221 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] update notification page!
                    2026-06-03 11:05:00.223 - debug: nspanel-lovelace-ui.0 (2910) [#scr] [NSPanel_2] Switch page to invisible!
                    2026-06-03 11:05:00.223 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] [NSPanel_2] Switch page to visible!
                    2026-06-03 11:05:00.224 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] Register last send type E0_E2_E6_0B_8C_D4-popupNotify block for 200ms
                    2026-06-03 11:05:00.224 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"pageType~popupNotify"} to panel.
                    2026-06-03 11:05:00.224 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] update notification page!
                    2026-06-03 11:05:00.420 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"entityUpdateDetail~8~!!! Abfall !!!~65535~~~~~OK~65535~Heute wird Varolux abgeholt ~65535~0~1~~"} to panel.
                    2026-06-03 11:05:00.425 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"entityUpdateDetail~8~!!! Abfall !!!~65535~~~~~OK~65535~Heute wird Varolux abgeholt ~65535~0~1~~"} to panel.
                    2026-06-03 11:06:00.009 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/STATUS0","payload":""} to panel.
                    2026-06-03 11:06:00.009 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/STATUS0","payload":""} to panel.
                    2026-06-03 11:06:00.023 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:06"} to panel.
                    2026-06-03 11:06:00.023 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:06"} to panel.
                    2026-06-03 11:08:00.012 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:08"} to panel.
                    2026-06-03 11:08:00.013 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:08"} to panel.
                    2026-06-03 11:09:00.010 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:09"} to panel.
                    2026-06-03 11:09:00.011 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:09"} to panel.
                    2026-06-03 11:10:00.011 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:10"} to panel.
                    2026-06-03 11:10:00.012 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:10"} to panel.
                    2026-06-03 11:11:00.009 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/STATUS0","payload":""} to panel.
                    2026-06-03 11:11:00.010 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/STATUS0","payload":""} to panel.
                    2026-06-03 11:11:00.022 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:11"} to panel.
                    2026-06-03 11:11:00.022 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:11"} to panel.
                    2026-06-03 11:13:20.735 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Receive message:{"type":"event","method":"startup","id":"61","action":"eu","opt":"5.1.1"}
                    2026-06-03 11:13:20.735 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/STATUS0","payload":""} to panel.
                    2026-06-03 11:13:20.746 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/POWER1","payload":""} to panel.
                    2026-06-03 11:13:20.757 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/POWER2","payload":""} to panel.
                    2026-06-03 11:13:20.768 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/GetDriverVersion","payload":""} to panel.
                    2026-06-03 11:13:20.779 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/Rule3","payload":"ON CustomSend DO RuleTimer3 140 ENDON ON Rules#Timer=3 DO CustomSend pageType~pageStartup ENDON"} to panel.
                    2026-06-03 11:13:20.790 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/Rule3","payload":"1"} to panel.
                    2026-06-03 11:13:20.939 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] set color to RGB {"r":255,"g":255,"b":255} -> 65535
                    2026-06-03 11:13:20.939 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"dimmode~15~80~0~65535"} to panel.
                    2026-06-03 11:13:20.939 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] [NSPanel_1] Switch page to invisible!
                    2026-06-03 11:13:20.939 - debug: nspanel-lovelace-ui.0 (2910) [main] [NSPanel_1] Switch page to visible!
                    2026-06-03 11:13:20.992 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Receive message:{"type":"event","method":"startup","id":"61","action":"eu","opt":"5.1.1"}
                    2026-06-03 11:13:20.992 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/STATUS0","payload":""} to panel.
                    2026-06-03 11:13:21.003 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/POWER1","payload":""} to panel.
                    2026-06-03 11:13:21.055 - debug: nspanel-lovelace-ui.0 (2910) [main] Register last send type 44_17_93_7E_1E_20-cardGrid block for 200ms
                    2026-06-03 11:13:21.058 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/POWER2","payload":""} to panel.
                    2026-06-03 11:13:21.068 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/GetDriverVersion","payload":""} to panel.
                    2026-06-03 11:13:21.078 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/Rule3","payload":"ON CustomSend DO RuleTimer3 140 ENDON ON Rules#Timer=3 DO CustomSend pageType~pageStartup ENDON"} to panel.
                    2026-06-03 11:13:21.089 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/Rule3","payload":"1"} to panel.
                    2026-06-03 11:13:21.097 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Set screeensaver timeout to 15s.
                    2026-06-03 11:13:21.098 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Set screeensaver timeout to 2s.
                    2026-06-03 11:13:21.098 - info: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Panel startup finished!
                    2026-06-03 11:13:21.220 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] set color to RGB {"r":255,"g":255,"b":255} -> 65535
                    2026-06-03 11:13:21.220 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"dimmode~15~80~0~65535"} to panel.
                    2026-06-03 11:13:21.220 - debug: nspanel-lovelace-ui.0 (2910) [///popupNotificationCustom] [NSPanel_2] Switch page to invisible!
                    2026-06-03 11:13:21.220 - debug: nspanel-lovelace-ui.0 (2910) [main] [NSPanel_2] Switch page to visible!
                    2026-06-03 11:13:21.221 - debug: nspanel-lovelace-ui.0 (2910) [main] Register last send type E0_E2_E6_0B_8C_D4-cardGrid block for 200ms
                    2026-06-03 11:13:21.222 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Set screeensaver timeout to 15s.
                    2026-06-03 11:13:21.224 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Set screeensaver timeout to 2s.
                    2026-06-03 11:13:21.224 - info: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Panel startup finished!
                    2026-06-03 11:13:21.231 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"pageType~cardGrid"} to panel.
                    2026-06-03 11:13:21.458 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Receive message:{"type":"event","method":"renderCurrentPage","id":"undefined","opt":""}
                    2026-06-03 11:13:21.468 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"pageType~cardGrid"} to panel.
                    2026-06-03 11:13:21.557 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"entityUpd~Garten~button~bSubPrev~~65535~~~button~bSubNext~~65535~~~switch~1?0~~35921~ Licht Garten~0~switch~1?1~~35921~Licht Pavilion~0~switch~1?2~~35921~Licht Pavilion~0~switch~1?3~~2016~Licht Pavilion~1~switch~1?4~~35921~Wasserschlauch~0~~~~~~"} to panel.
                    2026-06-03 11:13:21.667 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Receive message:{"type":"event","method":"renderCurrentPage","id":"undefined","opt":""}
                    2026-06-03 11:13:21.766 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"entityUpd~Garten~button~bSubPrev~~65535~~~button~bSubNext~~65535~~~switch~1?0~~35921~ Licht Garten~0~switch~1?1~~35921~Licht Pavilion~0~switch~1?2~~35921~Licht Pavilion~0~switch~1?3~~2016~Licht Pavilion~1~switch~1?4~~35921~Wasserschlauch~0~~~~~~"} to panel.
                    2026-06-03 11:13:21.867 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"timeout~15"} to panel.
                    2026-06-03 11:13:22.018 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"date~Mi., 3.06.26"} to panel.
                    2026-06-03 11:13:22.078 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"timeout~15"} to panel.
                    2026-06-03 11:13:22.210 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:13"} to panel.
                    2026-06-03 11:13:22.312 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"date~Mi., 3.06.26"} to panel.
                    2026-06-03 11:13:22.404 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"timeout~2"} to panel.
                    2026-06-03 11:13:22.513 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:13"} to panel.
                    2026-06-03 11:13:22.716 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"timeout~2"} to panel.
                    2026-06-03 11:13:23.460 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Receive message:{"type":"event","method":"sleepReached","id":"cardGrid","opt":""}
                    2026-06-03 11:13:23.460 - debug: nspanel-lovelace-ui.0 (2910) [main] [NSPanel_1] Switch page to invisible!
                    2026-06-03 11:13:23.460 - debug: nspanel-lovelace-ui.0 (2910) [#scr] [NSPanel_1] Switch page to visible!
                    2026-06-03 11:13:23.461 - debug: nspanel-lovelace-ui.0 (2910) [#scr] Register last send type 44_17_93_7E_1E_20-screensaver2 block for 200ms
                    2026-06-03 11:13:23.461 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"pageType~screensaver2"} to panel.
                    2026-06-03 11:13:23.466 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Set screeensaver timeout to 15s.
                    2026-06-03 11:13:23.649 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1] Receive message:{"type":"event","method":"renderCurrentPage","id":"undefined","opt":""}
                    2026-06-03 11:13:23.713 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Receive message:{"type":"event","method":"sleepReached","id":"cardGrid","opt":""}
                    2026-06-03 11:13:23.714 - debug: nspanel-lovelace-ui.0 (2910) [main] [NSPanel_2] Switch page to invisible!
                    2026-06-03 11:13:23.715 - debug: nspanel-lovelace-ui.0 (2910) [#scr] [NSPanel_2] Switch page to visible!
                    2026-06-03 11:13:23.716 - debug: nspanel-lovelace-ui.0 (2910) [#scr] Register last send type E0_E2_E6_0B_8C_D4-screensaver2 block for 200ms
                    2026-06-03 11:13:23.716 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"pageType~screensaver2"} to panel.
                    2026-06-03 11:13:23.718 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Set screeensaver timeout to 15s.
                    2026-06-03 11:13:23.749 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"time~11:13"} to panel.
                    2026-06-03 11:13:23.903 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3050.55 W~~~侀~65222~Solar 11KW~-1.5 W~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:23.905 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2] Receive message:{"type":"event","method":"renderCurrentPage","id":"undefined","opt":""}
                    2026-06-03 11:13:24.004 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"time~11:13"} to panel.
                    2026-06-03 11:13:24.210 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3050.55 W~~~侀~65222~Solar 11KW~-1.5 W~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:24.231 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:24.459 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:24.649 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"timeout~15"} to panel.
                    2026-06-03 11:13:24.684 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:24.910 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:25.011 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~-1.5 W~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:25.154 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"timeout~15"} to panel.
                    2026-06-03 11:13:25.347 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:25.416 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:25.691 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:25.720 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:25.887 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:25.990 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:26.295 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:30.014 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:30.015 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3008.9 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:30.453 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:30.458 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:30.724 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:30.735 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:30.923 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3008.9 W~~~侀~65222~Solar 11KW~-1.5 W~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:31.034 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3008.9 W~~~侀~65222~Solar 11KW~-1.5 W~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:35.016 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~-1.5 W~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:35.060 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~-1.5 W~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:35.363 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:35.446 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"color~6371~65535~65363~54938~65535~54938~54938~54938~54938~54938~54938~54938~54938~54938~65363~1374"} to panel.
                    2026-06-03 11:13:35.663 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:35.711 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"statusUpdate~~17299~~17299~~"} to panel.
                    2026-06-03 11:13:35.913 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:35.935 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~5.33 kWh~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:40.018 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_1-SendClass] send payload: {"topic":"NSPanel_1/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3008.9 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    2026-06-03 11:13:40.019 - debug: nspanel-lovelace-ui.0 (2910) [NSPanel_2-SendClass] send payload: {"topic":"NSPanel_2/cmnd/CustomSend","payload":"weatherUpdate~~~~19017~~13,9°C~~~~63488~Leistung~3008.9 W~~~侀~65222~Solar 11KW~0 kWh~~~侀~2016~Solar 800W~0 kWh~~~~64800~Sonne~21:37~~~~64544~Wind~6,2m/s~~~~64544~Böen~9,8m/s~~~~65535~Windr.~WSW~~~~64835~Feuchte~82%~~~~65222~UV~1,29~~0?10~~31~Wasser~1~~0?11~~2016~Zeichpumpe~1~~0?12~~65504~UV-Licht~1~~0?13~~35921~Teischspill~0~~0?14~~35921~Luftpumpe~0"} to panel.
                    • T Nicht stören
                      T Nicht stören
                      ticaki
                      #1224
                      Und bitte noch die adapterversion ich schaue dann heute abend
                      Spenden
                      W 2 Antworten Letzte Antwort
                      • T ticaki
                        W Offline
                        W Offline
                        welli
                        #1225
                        @ticaki
                        v0.17.8
                        • T ticaki
                          W Offline
                          W Offline
                          welli
                          #1226
                          @ticaki
                          Mir ist auch aufgefallen das die Uhrzeit hinterher läuft auf dem Screensaver , auf den Raspberry locale Zeit ist korrekt und auf den NSpanles in der Konsole läuft die Zeit korrekt
                          • T Nicht stören
                            T Nicht stören
                            ticaki
                            #1227
                            Die AI hats so schön geschrieben deshalb kopiere ich das hier rein :)
                            ich hab mir deinen Log mal genau angeschaut – und ich glaube nicht, dass es am WLAN liegt. Es ist auch kein echter „Absturz" der Panels. Was du siehst, ist eine eingebaute Sicherheitsfunktion:
                            Der Adapter „spricht" im Normalbetrieb regelmäßig mit jedem Panel. Das Panel hat einen kleinen Wächter eingebaut: Hört es 140 Sekunden lang nichts vom Adapter, lädt es sich selbst neu (es springt auf die
                            Startseite). Das ist absichtlich so, damit ein Panel sich von selbst fängt, falls mal was klemmt.
                            In deinem Log sieht man genau das:
                            • Normal schickt der Adapter jede Minute Daten an die Panels.
                            • Zweimal hat er das nicht getan – einmal ~2 Minuten lang gar nichts.
                            • Nach genau 140 Sekunden Stille haben sich beide Panels gleichzeitig neu geladen.
                            Und genau hier ist der Punkt: beide gleichzeitig = es liegt nicht an den Panels (zwei Geräte verlieren nicht sekundengenau zusammen das WLAN), sondern daran, dass der Adapter für ~2 Minuten ausgesetzt hat.
                            In der Zeit kam von ihm einfach nichts mehr – und der Wächter hat zugeschlagen.
                            Das erklärt auch deine zweite Beobachtung mit der Uhrzeit: Die Uhr auf dem Screensaver wird vom Adapter einmal pro Minute nachgestellt. Wenn der Adapter aussetzt, läuft die angezeigte Zeit logischerweise
                            hinterher, bis er sich wieder meldet. Gleiche Ursache, nur ein anderes Symptom.
                            Die Frage ist also: Warum setzt der Adapter bei dir alle paar Minuten für so lange aus? Das ist meistens kein Adapter-Fehler, sondern dein ioBroker-Rechner ist in dem Moment überlastet. Kannst du mir dazu bitte ein paar Sachen rausfinden:
                            1. Welcher Raspberry Pi ist das (Pi 3 / Pi 4 / wie viel RAM)?
                            2. Läuft auf der Kiste viel anderes (viele Adapter, History/InfluxDB, Backups zur vollen Stunde …)?
                            3. Schau dir in ioBroker mal die Werte unter System → Host an, besonders CPU-Auslastung, freier Speicher (RAM/Swap) und – wenn vorhanden – den „Event Loop Lag". Idealerweise beobachtest du die genau dann,
                              wenn die Panels neu starten.
                            Ich vermute stark, dass genau zu diesen Zeitpunkten die CPU/der Speicher am Anschlag ist und ioBroker für ein-zwei Minuten „einfriert".
                            Parallel schaue ich mir auf meiner Seite an, ob ich den Wächter etwas toleranter machen kann, damit ein kurzer Hänger nicht gleich zum Neustart führt – aber die eigentliche Ursache liegt vermutlich in der Auslastung deines Systems.
                            Spenden
                            • T ticaki
                              W Offline
                              W Offline
                              welli
                              #1228
                              @ticaki
                              Der Raspberry 5 mit 8GB läuft 3-5% mit 32% Ram.
                              Habe mal pings auf mein WIFI gemacht und erschreckende Beobachtung gemacht.
                              Von links nacht rechts : IObroker , NAS , Fritzbox , NSpanel_1
                              Wo ran könnte dis liegen?
                              • T Nicht stören
                                T Nicht stören
                                ticaki
                                #1229
                                Dafür solltest du einen eigenen Topic öffnen, hier gibt es leute die sich damit besser auskennen. Aber das ist schon etwas ernstes - vielleicht kanal optimieren, zigbee auf dem falschen kana.l
                                Spenden
                                • T ticaki
                                  W Offline
                                  W Offline
                                  welli
                                  #1230
                                  @ticaki
                                  Habe mein Wlan heute mal geprüft , und neu eingestellt, heute habe ich bei dem IObroker und NAS sowie Fritzbox nur noch 1-2ms .
                                  Aber bei den Nspanels bleit die ping Antwort variable von 2-200ms bis zur Zeitüberschreitung , obschon das NSPanel_1 3 Meter vom Repeater weg ist , kann es nicht sein dass im NSpanel intern es zu dies verschiedenen Verzögerungen kommt?
                                  • T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    #1231
                                    das ist ein normaler tasmota der funkt nur auf 2.4ghz kann sein das das bei dir überlaufen ist oder sich mit zigbee beißt - das wird eher nicht am adapter oder nspanel liegen (hw defekt mal aussen vor gelassen)
                                    Spenden
                                    • T ticaki
                                      W Offline
                                      W Offline
                                      welli
                                      #1232
                                      @ticaki
                                      Danke noch für deinen support.
                                      Leider habe ich noch mit der Uhrzeit Probleme , die läuft hinterher , denke mal , habe vor kurzen auf Node.js: v22.22.3 ge-updated.
                                      Kann dies nicht das Problem sein?
                                      Zigbee habe ich nicht , also dann ein Überlauf.
                                      • W welli
                                        @ticaki
                                        T Nicht stören
                                        T Nicht stören
                                        ticaki
                                        #1233
                                        @welli
                                        Die Uhrzeit ist simpel - die kommt vom adapter und wenn die nachricht vom adapter verloren geht, hängt die Uhrzeit - nach 2:30 geht das panel dann in den "waiting for data". Ich bin wegen dem uhrzeit problem schon mal zu spät gekommen.
                                        Das hauptproblem ist, dass tasmota kein 1 und 2 bei MQTT anbieten (weiß die option nicht mehr auswendig) das ist immer fire and forget. Ich hab das im adapter etwas abgefangen, aber wenns panel die nachricht nicht bekommt kann ich da auch nix machen.
                                        hab ein ähnliches Problem gerade mit einem pi 3b der verliert laufend das wlan - keine ahnung wieso.
                                        Spenden
                                        • H Online
                                          H Online
                                          holgerwolf
                                          #1234
                                          Ich habe gesehen, dass es eine Möglichkeit gibt, die Abfahrtstabelle und die Verbindungen aus dem public-transport Adapter aufs NS Panel zu bekommen.
                                          Hat da jemand ne Beschreibung/Anleitung zu?
