  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.4k
3.8k Beiträge 462 Kommentatoren 2.2m Aufrufe 410 Beobachtet
  • Holger EtzelH Holger Etzel
    @Thomas-Braun
    Danke, das war es. Manchmal ist man einfach blind 👍
    #3303
    @Holger-Etzel
    Und wie schaut das Ding sonst aus?
    Poste mal die komplette Ausgabe von
    iob diag
    • S swagner
      @tombox ich verwende nur den SoC und dieser Wert wird abgerufen, ich habe jetzt kein Debug eingeschaltet aber das log sieht immer so aus.
      2026-05-13 04:36:24.244 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
      2026-05-13 04:36:24.245 - info: vw-connect.0 (1518338) MQTT: Not authorized - stopping reconnect. Will retry on next token refresh.
      2026-05-13 04:36:24.245 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 04:48:25.238 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 04:48:25.479 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 04:48:25.557 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"ttings.targetStateOfChargeInPercent.json"
      2026-05-13 05:18:25.181 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 05:18:25.428 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 05:18:25.484 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"
      2026-05-13 05:30:23.838 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
      2026-05-13 05:30:23.838 - info: vw-connect.0 (1518338) MQTT: Not authorized - stopping reconnect. Will retry on next token refresh.
      2026-05-13 05:30:23.838 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 05:48:25.138 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 05:48:25.336 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 05:48:25.396 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"
      2026-05-13 06:18:25.492 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 06:18:25.824 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 06:18:25.922 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"
      2026-05-13 06:24:23.828 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
      2026-05-13 06:24:23.828 - info: vw-connect.0 (1518338) MQTT: Not authorized - stopping reconnect. Will retry on next token refresh.
      2026-05-13 06:24:23.828 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 06:48:24.859 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 06:48:25.795 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 06:48:25.860 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"
      2026-05-13 07:18:24.040 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Not authorized
      2026-05-13 07:18:24.040 - info: vw-connect.0 (1518338) MQTT: Not authorized - stopping reconnect. Will retry on next token refresh.
      2026-05-13 07:18:24.041 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 07:18:25.260 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 07:18:25.571 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 07:18:25.651 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"
      2026-05-13 07:48:26.037 - info: vw-connect.0 (1518338) Server not available. For endpoint charging/settings Please try again later:"Internal server error"
      2026-05-13 07:48:26.322 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/locations Please try again later:"Internal server error"
      2026-05-13 07:48:26.412 - info: vw-connect.0 (1518338) Server not available. For endpoint fueling/sessions/latest Please try again later:"Internal server error"
      swagner
      #3304
      Jetzt hat sich das log verändert, zusätzlich zu den vorhandenen Meldungen oben habe jetzt auch Banned Meldungen.
      2026-05-13 09:06:43.849 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Banned
      2026-05-13 09:06:43.849 - error: vw-connect.0 (1518338) MQTT Offline
      2026-05-13 09:06:43.849 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 09:07:43.851 - info: vw-connect.0 (1518338) MQTT Reconnecting with refreshed token
      2026-05-13 09:07:44.078 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Banned
      2026-05-13 09:07:44.078 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 09:08:44.079 - info: vw-connect.0 (1518338) MQTT Reconnecting with refreshed token
      2026-05-13 09:08:44.325 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Banned
      2026-05-13 19:10:32.128 - info: vw-connect.0 (1518338) MQTT Reconnecting with refreshed token
      2026-05-13 19:10:32.448 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Banned
      2026-05-13 19:10:32.448 - info: vw-connect.0 (1518338) MQTT Connection closed
      2026-05-13 19:11:32.453 - error: vw-connect.0 (1518338) MQTT: Reconnect count exceeded. Stop MQTT
      2026-05-13 19:11:32.724 - error: vw-connect.0 (1518338) MQTT Error: ErrorWithReasonCode: Connection refused: Banned
      2026-05-13 19:11:32.724 - info: vw-connect.0 (1518338) MQTT Connection closed
        Hallo, ich bekomme den Adapter nicht installiert, wo finde ich die aktuelle Version, bzw. wie installiere ich den Adapter?
        Bekomme folgende Meldung:
        $ iobroker url https://github.com/TA2k/ioBroker.vw-connect --host raspberry --debug
        install TA2k/ioBroker.vw-connect#e4b105b65dc2dcc6bc97d5f4e72e044697afcdf7
        NPM version: 10.8.2Installing TA2k/ioBroker.vw-connect#e4b105b65dc2dcc6bc97d5f4e72e044697afcdf7... (System call)
        npm error code EBADENGINE
        npm error engine Unsupported engine
        npm error engine Not compatible with your version of node/npm: iobroker.vw-connect@0.8.3npm error notsup Not compatible with your version of node/npm: iobroker.vw-connect@0.8.3npm error notsup Required: {"node":">=22.12.0"}npm error notsup Actual: {"npm":"10.8.2","node":"v20.19.4"}
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-13T14_11_16_007Z-debug-0.log
        npm error code EBADENGINEnpm error engine Unsupported enginenpm error engine Not compatible with your version of node/npm: iobroker.vw-connect@0.8.3npm error notsup Not compatible with your version of node/npm: iobroker.vw-connect@0.8.3npm error notsup Required: {"node":">=22.12.0"}npm error notsup Actual: {"npm":"10.8.2","node":"v20.19.4"}npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-13T14_11_16_007Z-debug-0.log
        host.raspberry Cannot install TA2k/ioBroker.vw-connect#e4b105b65dc2dcc6bc97d5f4e72e044697afcdf7: 1
        ERROR: Process exited with code 25
        Holger
        arteckA Offline
        arteckA Offline
        arteck
        #3305
        @Holger-Etzel
        beispiel anhand Zigbee adapter
        https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
        du musst diese URL nehmen https://github.com/TA2k/ioBroker.vw-connect
        • S swagner
          R Online
          R Online
          RaBe52
          schrieb am zuletzt editiert von RaBe52
          #3306
          @swagner
          me to, die gleichen Meldungen, aber SoC funktioniert.
          ioBroker unter Proxmox auf HP Z4 G4 (Terramaster unter Proxmox als Backup),
          backitpup, Drag-indicator, Ebus, Energiefluss erweitert, Enphase, Fritzdect, Ham, Kecontact, Midea, mqtt, Proxmox, REST API, Shelly, Signal-cmb, smoothed, Sonoff, Telegram, text2command, TR-064, Tuya, Vaillant, VW connect, Wamo, ...
            swagner
            #3307
            ich habe jetzt 0.8.4 installiert (disable SKODA mqtt), ich bekomme die SoC Werte, alles andere habe ich nicht getestet. Ich vergleiche die SoC Werte von diesem Adapter mit den SoC Werten die ich über ODB2 auslese und bin wieder im grünen Status.
            Ich lese VWConnect Adapter SoC und ODB2 SoC aus und sobald einer davon für 60min kein update mehr liefert, wenn das Auto geladen wird, dann wird der Wert Gelb in VIS angezeigt
            • S swagner
              stevie77
              #3308
              @swagner Kurze Zwischenfrage: Ist das hier gerade eigentlich ein spezielles Skoda-Problem oder ein MQTT-Problem? Weil ich mich ein bisschen wundere, dass meine Instanz seit Wochen den SoC für nen VW ID.7 ohne Probleme bekommt...
              Updaten kann ich nämlich seit längerer Zeit nicht mehr, weil meine Docker-Installation von ioBroker auf nem Raspi 4 mit nem älteren Betriebssystem läuft und Node.js 22 nicht mehr installierbar zu sein scheint (ich hänge auf Version 20 fest, arbeite aber an nem Raspi 5 mit aktuellem OS). Momentan funktioniert die SoC-Abfrage aber eben glücklicherweise noch...
              • S stevie77
                swagner
                #3309
                @stevie77 Ich nehme mal an das Skoda angefangen hat bestimme Funktionen für third party software abzustellen und alle anderen werden früher oder später folgen, das ist auch der Grund warum ich vor einiger Zeit angefangen habe den SoC via ODB2 abzufragen und das funktioniert auch wenn ich unterwegs bin da sich der ODB2 Adapter über WLAN mit einem 4G Router und OpenVPN im Auto in mein Netzwerk verbindet und somit auch mit dem IOBroker.
                Der 4G Router (Cudy LT300) hat €32 gekostet und €10 pro Jahr als pre-paid für die 4G SIM karte, ich frage SoC und Odometer ab.
                ODB2 ist ein MeatPi (Wican ODB C3) hat ~€45 gekostet.
                Ich benötige den SoC fürs "intelligente" laden via PV
                IOBroker läuft bei mir als Debian VirtualBox VM auf Ubuntu mit 4 anderen VMs
                • S swagner
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #3310
                  @swagner sagte:
                  das ist quack.... Skoda hat massive Server Probleme zur Zeit..
                  https://www.golem.de/news/cyberangriff-trifft-fahrzeughersteller-kundendaten-von-skoda-kompromittiert-2605-208556.html
                  also bitte keine Panik verbeiten vor allem wenns nur aus 'ich vermute' Quelle kommt
                  • arteckA arteck
                    @swagner sagte:
                    stevie77
                    #3311
                    @arteck Hmm, der Vorfall soll "ausschließlich den Web-Shop für Zubehörteile von Skoda Auto Deutschland" betreffen. Der Adapter hier verbindet sich zu einem Shop-System?
                    • R Offline
                      road_runner31
                      #3312
                      Seit einigen Tagen scheint der Zugriff auf die Cloud-Daten nicht zu funktionieren, kann das jemand bestätigen bzw. hat eine Idee?
                      • madingM Offline
                        madingM Offline
                        mading
                        #3313
                        403 = forbidden. User/ pass richtig? S-pin?
                        • R Offline
                          road_runner31
                          #3314
                          Im Adapter ist alles grün.. passt also.. ging ja bis vor Kurzem..
                          • madingM Offline
                            madingM Offline
                            mading
                            #3315
                            Dann ein Server Problem 😊
                            • madingM Offline
                              madingM Offline
                              mading
                              #3316
                              Oder Zustimmung muss über die Webseite neu erteilt werden?
                              • H Offline
                                huzzel
                                #3317
                                Bei meinem Cupra bekomme ich aktuell auch keine neuen Daten mehr. Selbe Fehlermeldung. Wollte mich dann auch der Webseite anmelden, hmm, bin wohl zu blöd, ich finde den Anmende-Button nicht mehr. Die App geht aber noch ganz normal auf.
                                Im Log steht, dass der Login successful ist.
                                Ich tippe also mal auf der Server.
                                Beim ID geht alles ganz normal
                                  manrum1
                                  schrieb am zuletzt editiert von manrum1
                                  #3318
                                  Bei Homeassistant scheint das Problem gelöst zu sein: https://github.com/WulfgarW/homeassistant-pycupra/issues/89#issuecomment-4498745226
                                  • H huzzel
                                    tombox
                                    #3319
                                    @huzzel 0.8.5 testen
                                    • arteckA Offline
                                      arteckA Offline
                                      arteck
                                      #3320
                                      sieht gut aus.. zumindest für Tavascan
                                      • R Offline
                                        road_runner31
                                        #3321
                                        Kann ich für den Formentor bestätigen! Danke!!
                                        Schönen Pfingsmontag Euch allen!
                                        • amg_666A Offline
                                          amg_666A Offline
                                          amg_666
                                          #3322
                                          Die 0.8.4 lief bei meinem Skoda Octavia stabil, die 0.8.5 sieht auch bislang gut aus
