  4. Einschätzung zu Systemstand
    6.3k
25 Beiträge 3 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • W Würfel
    lasse gerade den Restore laufen und einige Adapter findet er nicht.
    Wie bekomme ich die nachträglich rein?
    Manuell installieren und dann noch einmal Restore laufen lassen?
    host.RasPiIobroker
    2026-05-10 21:33:58.227	warn	startInstance cannot find adapter "worx@3.3.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:33:43.289	warn	startInstance cannot find adapter "unifi@0.7.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:33:38.646	warn	startInstance cannot find adapter "unifi-protect@1.0.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:33:25.234	warn	startInstance cannot find adapter "unifi-protect@1.0.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:32:52.305	warn	startInstance cannot find adapter "tuya@3.17.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:32:39.163	warn	startInstance cannot find adapter "tr-064@4.3.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:32:26.960	warn	startInstance cannot find adapter "sprinklecontrol@1.0.5". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:32:14.608	warn	startInstance cannot find adapter "solarmanpv@0.7.3". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:58.360	warn	startInstance cannot find adapter "shelly@10.6.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:56.311	error	iobroker npm-install: host.RasPiIobroker Cannot install iobroker.rpi2@3.0.2: 1
    host.RasPiIobroker
    2026-05-10 21:31:56.309	error	iobroker npm-install: npm error code 1npm error path /opt/iobroker/node_modules/iobroker.rpi2npm error command failednpm error command sh -c bash ./preinstall-check.shnpm error Checking package: libgpiod-dev >= 2.2npm error libgpiod-dev is not installednpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-10T19_31_51_321Z-debug-0.log
    host.RasPiIobroker
    2026-05-10 21:31:47.347	warn	startInstance cannot find adapter "rpi2@2.4.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:35.520	warn	startInstance cannot find adapter "melcloud@3.0.4". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:22.237	warn	startInstance cannot find adapter "ical@1.20.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:17.629	warn	startInstance cannot find adapter "hm-rpc@3.0.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:13.088	warn	startInstance cannot find adapter "hm-rpc@3.0.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:31:08.463	warn	startInstance cannot find adapter "hm-rpc@3.0.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:30:52.974	warn	startInstance cannot find adapter "hm-rpc@3.0.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:30:40.582	warn	startInstance cannot find adapter "hm-rega@5.1.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:30:29.085	warn	startInstance cannot find adapter "feiertage@1.4.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:30:13.192	warn	startInstance cannot find adapter "cloud@6.0.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:29:57.891	warn	startInstance cannot find adapter "alexa2@3.27.4". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:29:46.368	warn	startInstance cannot find adapter "whatsapp-cmb@0.3.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:29:41.629	warn	startInstance cannot find adapter "vis-icontwo". Try to install it... 2 attempt
    host.RasPiIobroker
    2026-05-10 21:29:18.189	warn	startInstance cannot find adapter "telegram@4.1.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:28:55.689	warn	startInstance cannot find adapter "roborock@0.7.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:28:41.365	warn	startInstance cannot find adapter "residents@1.1.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:28:23.706	warn	startInstance cannot find adapter "javascript@9.2.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:28:11.668	warn	startInstance cannot find adapter "influxdb@4.0.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:28:01.232	warn	startInstance cannot find adapter "history@4.0.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:27:48.876	warn	startInstance cannot find adapter "vis-2-widgets-radar-trap@2.3.3". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:27:31.021	warn	startInstance cannot find adapter "icons-ultimate-png@1.0.1". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:27:20.596	warn	startInstance cannot find adapter "icons-smarthome@1.0.0". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:24:41.513	warn	startInstance cannot find adapter "icons-open-icon-library-png@0.1.2". Try to install it... 1 attempt
    host.RasPiIobroker
    2026-05-10 21:24:24.000	warn	startInstance cannot find adapter "icons-mfd-svg@1.2.0". Try to install it... 1 attempt
    @Würfel sagte:
    Zumindest für den rpi2 fehlt dir das Paket libgpiod-dev:
    Mit deinen Meldungen kann man nichts anfangen ohne zu wissen an welcher Stelle beim Restore und auf welcher Basis die erscheinen. Im Zuge des Restores können das aber ganz normale Meldungen sein. Abwarten.
    • W Offline
      W Offline
      Würfel
      schrieb am zuletzt editiert von Würfel
      Ist das auch noch normal?`
      host.RasPiIobroker
      2026-05-10 21:53:45.470	error	Cannot download and install adapter "rpi2@2.4.0". To retry it disable/enable the adapter or restart host. Also check the error messages in the log!
      host.RasPiIobroker
      2026-05-10 21:53:43.429	error	iobroker npm-install: host.RasPiIobroker Cannot install iobroker.rpi2@2.4.0: 1
      host.RasPiIobroker
      2026-05-10 21:53:43.428	error	iobroker npm-install: npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioInput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:14:17: error: expected primary-expression before ‘line’npm error 14 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:19:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~npm error | gpiod::linenpm error In file included from /usr/include/gpiodcxx/chip.hpp:21,npm error from /usr/include/gpiod.hpp:27,npm error from ../cpp/opengpio.cpp:3:npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:19:58: error: ‘DIRECTION_INPUT’ is not a member of ‘gpiod::line_request’npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:28:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:30:22: error: ‘line’ is not capturednpm error 30 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:28:66: note: the lambda has no capture-defaultnpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:34:52: error: ‘line’ is not capturednpm error 34 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:33:67: note: the lambda has no capture-defaultnpm error 33 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioOutput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:49:17: error: expected primary-expression before ‘line’npm error 49 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:54:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:54:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:63:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:66:9: error: ‘line’ is not capturednpm error 66 | line.set_value(value); });npm error | ^~~~npm error ../cpp/opengpio.cpp:63:66: note: the lambda has no capture-defaultnpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:69:52: error: ‘line’ is not capturednpm error 69 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:68:67: note: the lambda has no capture-defaultnpm error 68 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:81:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 81 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:92:17: error: expected primary-expression before ‘line’npm error 92 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:100:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:100:58: error: ‘EVENT_BOTH_EDGES’ is not a member of ‘gpiod::line_request’npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:109:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:111:22: error: ‘line’ is not capturednpm error 111 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:109:66: note: the lambda has no capture-defaultnpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:115:11: error: ‘struct WatchContext’ has no member named ‘line’npm error 115 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:127:25: error: expected primary-expression before ‘line’npm error 127 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:131:33: error: ‘line’ is not capturednpm error 131 | bool hasEvent = line.event_wait(chrono::milliseconds(1));npm error | ^~~~npm error ../cpp/opengpio.cpp:124:10: note: the lambda has no capture-defaultnpm error 124 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp:134:28: error: ‘line_event’ is not a member of ‘gpiod’; did you mean ‘info_event’?npm error 134 | gpiod::line_event event = line.event_read();npm error | ^~~~~~~~~~npm error | info_eventnpm error ../cpp/opengpio.cpp:135:34: error: ‘event’ was not declared in this scope; did you mean ‘servent’?npm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~npm error | serventnpm error ../cpp/opengpio.cpp:135:61: error: ‘gpiod::line_event’ has not been declarednpm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~~~~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:147:19: error: ‘struct WatchContext’ has no member named ‘line’npm error 147 | data->line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:168:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 168 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioPwm(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:196:17: error: expected primary-expression before ‘line’npm error 196 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:201:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:201:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:213:11: error: ‘struct PwmContext’ has no member named ‘line’npm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:213:18: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 213 | data->line = line;npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:224:25: error: expected primary-expression before ‘line’npm error 224 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:264:17: error: ‘line’ is not capturednpm error 264 | line.set_value(true);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:278:17: error: ‘line’ is not capturednpm error 278 | line.set_value(false);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:327:25: error: expected primary-expression before ‘line’npm error 327 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:328:13: error: ‘line’ is not capturednpm error 328 | line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp:324:10: note: the lambda has no capture-defaultnpm error 324 | [](uv_work_t *req, int status)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)npm error gyp ERR! System Linux 6.12.75+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v22.22.2npm error gyp ERR! node-gyp -v v11.5.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-10T19_53_23_585Z-debug-0.log
      host.RasPiIobroker
      2026-05-10 21:53:17.435	error	iobroker npm-install: host.RasPiIobroker Cannot install iobroker.rpi2@2.4.0: 1
      host.RasPiIobroker
      2026-05-10 21:53:17.433	error	iobroker npm-install: npm error code 1npm error path /opt/iobroker/node_modules/opengpionpm error command failednpm error command sh -c node-gyp rebuildnpm error make: Entering directory '/opt/iobroker/node_modules/opengpio/build'npm error CXX(target) Release/obj.target/opengpio/cpp/opengpio.onpm error make: Leaving directory '/opt/iobroker/node_modules/opengpio/build'npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioInput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:14:17: error: expected primary-expression before ‘line’npm error 14 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:19:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~npm error | gpiod::linenpm error In file included from /usr/include/gpiodcxx/chip.hpp:21,npm error from /usr/include/gpiod.hpp:27,npm error from ../cpp/opengpio.cpp:3:npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:19:58: error: ‘DIRECTION_INPUT’ is not a member of ‘gpiod::line_request’npm error 19 | line.request({resourceName, gpiod::line_request::DIRECTION_INPUT, 0});npm error | ^~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:28:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:30:22: error: ‘line’ is not capturednpm error 30 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:28:66: note: the lambda has no capture-defaultnpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:34:52: error: ‘line’ is not capturednpm error 34 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:33:67: note: the lambda has no capture-defaultnpm error 33 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:28:62: note: ‘<typeprefixerror>line’ declared herenpm error 28 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioOutput(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:49:17: error: expected primary-expression before ‘line’npm error 49 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:54:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:54:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 54 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:63:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:66:9: error: ‘line’ is not capturednpm error 66 | line.set_value(value); });npm error | ^~~~npm error ../cpp/opengpio.cpp:63:66: note: the lambda has no capture-defaultnpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:69:52: error: ‘line’ is not capturednpm error 69 | { line.release(); });npm error | ^~~~npm error ../cpp/opengpio.cpp:68:67: note: the lambda has no capture-defaultnpm error 68 | Napi::Function cleanup = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:63:62: note: ‘<typeprefixerror>line’ declared herenpm error 63 | Napi::Function setter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:81:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 81 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:92:17: error: expected primary-expression before ‘line’npm error 92 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:100:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:100:58: error: ‘EVENT_BOTH_EDGES’ is not a member of ‘gpiod::line_request’npm error 100 | line.request({resourceName, gpiod::line_request::EVENT_BOTH_EDGES, 0}, 0);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:109:62: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:111:22: error: ‘line’ is not capturednpm error 111 | bool value = line.get_value();npm error | ^~~~npm error ../cpp/opengpio.cpp:109:66: note: the lambda has no capture-defaultnpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioWatch(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:115:11: error: ‘struct WatchContext’ has no member named ‘line’npm error 115 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:127:25: error: expected primary-expression before ‘line’npm error 127 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:131:33: error: ‘line’ is not capturednpm error 131 | bool hasEvent = line.event_wait(chrono::milliseconds(1));npm error | ^~~~npm error ../cpp/opengpio.cpp:124:10: note: the lambda has no capture-defaultnpm error 124 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:109:62: note: ‘<typeprefixerror>line’ declared herenpm error 109 | Napi::Function getter = Napi::Function::New(info.Env(), [line](const Napi::CallbackInfo &info)npm error | ^~~~npm error ../cpp/opengpio.cpp:134:28: error: ‘line_event’ is not a member of ‘gpiod’; did you mean ‘info_event’?npm error 134 | gpiod::line_event event = line.event_read();npm error | ^~~~~~~~~~npm error | info_eventnpm error ../cpp/opengpio.cpp:135:34: error: ‘event’ was not declared in this scope; did you mean ‘servent’?npm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~npm error | serventnpm error ../cpp/opengpio.cpp:135:61: error: ‘gpiod::line_event’ has not been declarednpm error 135 | bool value = event.event_type == gpiod::line_event::RISING_EDGE ? true : false;npm error | ^~~~~~~~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:147:19: error: ‘struct WatchContext’ has no member named ‘line’npm error 147 | data->line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp: At global scope:npm error ../cpp/opengpio.cpp:168:12: error: ‘line’ in namespace ‘gpiod’ does not name a typenpm error 168 | gpiod::line line;npm error | ^~~~npm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In function ‘Napi::Array GpioPwm(const Napi::CallbackInfo&)’:npm error ../cpp/opengpio.cpp:196:17: error: expected primary-expression before ‘line’npm error 196 | gpiod::line line = chip.get_line(lineNumber);npm error | ^~~~npm error ../cpp/opengpio.cpp:201:9: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp:201:58: error: ‘DIRECTION_OUTPUT’ is not a member of ‘gpiod::line_request’npm error 201 | line.request({resourceName, gpiod::line_request::DIRECTION_OUTPUT, 0}, 1);npm error | ^~~~~~~~~~~~~~~~npm error ../cpp/opengpio.cpp:213:11: error: ‘struct PwmContext’ has no member named ‘line’npm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:213:18: error: ‘line’ was not declared in this scope; did you mean ‘gpiod::line’?npm error 213 | data->line = line;npm error | ^~~~npm error | gpiod::linenpm error /usr/include/gpiodcxx/line.hpp:24:11: note: ‘gpiod::line’ declared herenpm error 24 | namespace line {npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:224:25: error: expected primary-expression before ‘line’npm error 224 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:264:17: error: ‘line’ is not capturednpm error 264 | line.set_value(true);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp:278:17: error: ‘line’ is not capturednpm error 278 | line.set_value(false);npm error | ^~~~npm error ../cpp/opengpio.cpp:221:10: note: the lambda has no capture-defaultnpm error 221 | [](uv_work_t *req)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error ../cpp/opengpio.cpp: In lambda function:npm error ../cpp/opengpio.cpp:327:25: error: expected primary-expression before ‘line’npm error 327 | gpiod::line line = data->line;npm error | ^~~~npm error ../cpp/opengpio.cpp:328:13: error: ‘line’ is not capturednpm error 328 | line.release();npm error | ^~~~npm error ../cpp/opengpio.cpp:324:10: note: the lambda has no capture-defaultnpm error 324 | [](uv_work_t *req, int status)npm error | ^npm error ../cpp/opengpio.cpp:213:18: note: ‘<typeprefixerror>line’ declared herenpm error 213 | data->line = line;npm error | ^~~~npm error make: *** [opengpio.target.mk:108: Release/obj.target/opengpio/cpp/opengpio.o] Error 1npm error gyp ERR! build error npm error gyp ERR! stack Error: `make` failed with exit code: 2npm error gyp ERR! stack at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:219:23)npm error gyp ERR! System Linux 6.12.75+rpt-rpi-v8npm error gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/opengpionpm error gyp ERR! node -v v22.22.2npm error gyp ERR! node-gyp -v v11.5.0npm error gyp ERR! not oknpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-10T19_52_54_932Z-debug-0.log
      host.RasPiIobroker
      2026-05-10 21:52:49.002	error	iobroker npm-install: host.RasPiIobroker Cannot install iobroker.rpi2@3.0.2: 1
      host.RasPiIobroker
      2026-05-10 21:52:49.001	error	iobroker npm-install: npm error code 1npm error path /opt/iobroker/node_modules/iobroker.rpi2npm error command failednpm error command sh -c bash ./preinstall-check.shnpm error Checking package: libgpiod-dev >= 2.2npm error libgpiod-dev is not installednpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-05-10T19_52_36_693Z-debug-0.log
      host.RasPiIobroker
      2026-05-10 21:38:44.002	error	iobroker npm-install: host.RasPiIobroker Unknown packet name info. Please install packages from outside the repository using "iobroker url <url-or-package>"!adapter "info" cannot be installed: Unknown packet name info. Please install packages from outside the repository using "iobroker url <url-or-package>"!
      • W Würfel
        host.RasPiIobroker
        host.RasPiIobroker
        host.RasPiIobroker
        host.RasPiIobroker
        host.RasPiIobroker
        host.RasPiIobroker
        host.RasPiIobroker
        host.RasPiIobroker
        @Würfel
        Zu rpi2 hatte ich doch schon was geschrieben...
        • W Offline
          W Offline
          Würfel
          Ok,
          ok kannte ich nicht heraus lesen ob es dazu gehört noch
          host.RasPiIobroker
          2026-05-10 21:53:44.468	info	iobroker npm-install: exit 25
          Das war die letzte meldung im log
          Ist Restore durch?
          • W Würfel
            Ok,
            host.RasPiIobroker
            Ist Restore durch?
            @Würfel
            Was liefert
            sudo apt update
            apt policy libgpiod-dev
            Nachinstallieren ggfls. per
            sudo apt install libgpiod-dev
            • W Offline
              W Offline
              Würfel
              iob@RasPiIobroker:~ $ sudo apt update
              [sudo] password for iob:
              Hit:1 http://deb.debian.org/debian trixie InRelease
              Hit:2 http://deb.debian.org/debian trixie-updates InRelease
              Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
              Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
              Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
              All packages are up to date.
              iob@RasPiIobroker:~ $ apt policy libgpiod-dev
              libgpiod-dev:
                Installed: 2.2.1-2+deb13u1
                Candidate: 2.2.1-2+deb13u1
                Version table:
               *** 2.2.1-2+deb13u1 500
                      500 http://deb.debian.org/debian trixie/main arm64 Packages
              iob@RasPiIobroker:~ $ sudo apt install libgpiod-dev
              libgpiod-dev is already the newest version (2.2.1-2+deb13u1).
              Summary:
                Upgrading: 0, Installing: 0, Removing: 0, Not Upgrading: 0
              • W Würfel
                host.RasPiIobroker
                host.RasPiIobroker
                host.RasPiIobroker
                host.RasPiIobroker
                host.RasPiIobroker
                host.RasPiIobroker
                host.RasPiIobroker
                host.RasPiIobroker
                @Würfel sagte:
                Bei trixie brauchst du 3.x
                  @Würfel sagte:
                  @Homoran sagte:
                  Stibimpt. Wie praktisch, dass das eh seit Monaten die vorgesehene Version ist:
                  rpi2
                  latest:	3.0.2 for 5 months
                  stable:	3.0.2 for 5 months
                  • W Offline
                    W Offline
                    Würfel
                    Ist drauf, rpi2 Version 3.0.2
                    Hab eben noch weil im Host angezeigt wurde JS von 7.0 auf 7.1 update angeklickt.
                    Nach einer Weile erschein die Startseite zum Anmelden und nun hab ich ein I mit Kreis drum wo einer im Kreis die Farbe dreht.
                    Nach einer Weile öffnete die Adminpage. Ist das I mit dem drehenden Balken ein Ladebildschirm oder was macht das System in dem Augenblick?
                    • W Würfel
                      @Würfel
                      Zeig mal die Ausgabe von
                      iob diag
                      nun. Nix klicken, ist ein Terminal-Befehl.
                      • W Offline
                        W Offline
                        Würfel
                        ```bash
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                        Operating System: Debian GNU/Linux 13 (trixie)
                         Static hostname: RasPiIobroker
                               Icon name: computer
                                  Kernel: Linux 6.12.75+rpt-rpi-v8
                            Architecture: arm64
                        OS is similar to:
                        Model           : Raspberry Pi 4 Model B Rev 1.5
                        Docker          : false
                        Virtualization  : none
                        Kernel          : aarch64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         22:58:19 up 23 min,  1 user,  load average: 0.39, 1.20, 1.76
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Debian stable version codenamed 'trixie'!
                        *** RASPBERRY THROTTLING ***
                        Current issues:
                        Previously detected issues:
                        *** TIME AND TIMEZONES ***
                                       Local time: Sun 2026-05-10 22:58:20 CEST
                                   Universal time: Sun 2026-05-10 20:58:20 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        iob
                        HOME=/home/iob
                        GROUPS=iob adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
                        iobroker
                        HOME=/home/iobroker
                        SUDO_HOME=/home/iob
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server:         false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            8.2G        4.7G        2.0G         12M        1.6G        3.5G
                        Swap:           2.1G          0B        2.1G
                        Total:           10G        4.7G        4.2G
                        Active iob-Instances:   42
                                 7819 M total memory
                                 4492 M used memory
                                 4371 M active memory
                                  971 M inactive memory
                                 1929 M free memory
                                  195 M buffer memory
                                 1320 M swap cache
                                 2047 M total swap
                                    0 M used swap
                                 2047 M free swap
                        top - 22:58:20 up 23 min,  1 user,  load average: 0.39, 1.20, 1.76
                        Tasks: 235 total,   1 running, 234 sleeping,   0 stopped,   0 zombie
                        %Cpu(s): 10.2 us,  2.0 sy,  0.0 ni, 85.7 id,  2.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   7819.7 total,   1927.7 free,   4494.2 used,   1516.9 buff/cache
                        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   3325.5 avail Mem
                        *** FAILED SERVICES ***
                        0 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        udev           devtmpfs  3.6G     0  3.6G   0% /dev
                        tmpfs          tmpfs     1.6G  9.1M  1.6G   1% /run
                        /dev/sda2      ext4      110G   18G   88G  17% /
                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                        tmpfs          tmpfs     3.9G  2.6M  3.9G   1% /tmp
                        /dev/sda1      vfat      505M   65M  440M  13% /boot/firmware
                        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
                        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                        tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
                        [Sun May 10 22:35:14 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                        [Sun May 10 22:35:14 2026] EXT4-fs (sda2): mounted filesystem e634e0a4-a958-46cb-abad-862d2102573f ro with ordered data mode. Quota mode: none.
                        [Sun May 10 22:35:17 2026] EXT4-fs (sda2): re-mounted e634e0a4-a958-46cb-abad-862d2102573f r/w.
                        Show mounted filesystems:
                        TARGET           SOURCE    FSTYPE OPTIONS
                        /                /dev/sda2 ext4   rw,noatime
                        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                        /var:
                        2.5G    /var/
                        231M    /var/cache
                        226M    /var/cache/apt
                        179M    /var/lib
                        147M    /var/lib/apt
                        Archived and active journals take up 8M in the file system.
                        /opt/iobroker/backups:
                        576M    /opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        852M    /opt/iobroker/iobroker-data/
                        791M    /opt/iobroker/iobroker-data/files
                        156M    /opt/iobroker/iobroker-data/files/vis
                        148M    /opt/iobroker/iobroker-data/files/vis/widgets
                        114M    /opt/iobroker/iobroker-data/files/vis-2
                        37M     /opt/iobroker/iobroker-data/objects.jsonl
                        37M     /opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
                        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                        24M     /opt/iobroker/iobroker-data/states.jsonl
                        22M     /opt/iobroker/iobroker-data/files/residents.admin/build/index.js.map
                        USB-Devices by-id:
                        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                        please always prefer the links 'by-id':
                        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1c87ccd6d41bef11984da4d94909ffd0-if00-port0
                        *** ZigBee Settings ***
                        ✓ Your zigbee.1 COM-Port is matching 'by-id'. Very good!
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs         v22.22.2
                        /usr/bin/node           v22.22.2
                        /usr/bin/npm            10.9.7
                        /usr/bin/npx            10.9.7
                        ✓ Node.js installation is correct
                        nodejs:
                          Installed: 22.22.2-1nodesource1
                          Candidate: 22.22.2-1nodesource1
                          Version table:
                         *** 22.22.2-1nodesource1 1001
                                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                             22.22.1-1nodesource1 1001
                             22.22.0-1nodesource1 1001
                             22.21.0-1nodesource1 1001
                             22.20.0-1nodesource1 1001
                             22.19.0-1nodesource1 1001
                             22.18.0-1nodesource1 1001
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                             20.19.2+dfsg-1+deb13u2 500
                                500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
                             20.19.2+dfsg-1 500
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        RasPiIobroker       RasPiIobroker (version: 7.1.2, hostname: RasPiIobroker , alive, uptime: 954)
                        Core adapters versions
                        js-controller:  7.1.2
                        admin:          7.8.24
                        javascript:     9.2.2
                        nodejs modules from github:     1
                        +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#b9a3db457ac1a6e1ef4b7ab6edcfddc0388e4b19)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : RasPiIobroker                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          system.adapter.alexa2.0                 : alexa2                : RasPiIobroker                            - disabled
                        + system.adapter.backitup.0               : backitup              : RasPiIobroker                            -  enabled
                        + system.adapter.cloud.0                  : cloud                 : RasPiIobroker                            -  enabled
                        + system.adapter.devices.0                : devices               : RasPiIobroker                            -  enabled
                        + system.adapter.discovery.0              : discovery             : RasPiIobroker                            -  enabled
                          system.adapter.dwd.0                    : dwd                   : RasPiIobroker                            -  enabled
                        + system.adapter.echarts.0                : echarts               : RasPiIobroker                            -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: RasPiIobroker                            -  enabled
                        + system.adapter.epson_ecotank_et_2750.0  : epson_ecotank_et_2750 : RasPiIobroker                            -  enabled
                          system.adapter.fb-checkpresence.0       : fb-checkpresence      : RasPiIobroker                            - disabled
                          system.adapter.feiertage.0              : feiertage             : RasPiIobroker                            - disabled
                          system.adapter.flot.0                   : flot                  : RasPiIobroker                            - disabled
                        + system.adapter.history.0                : history               : RasPiIobroker                            -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : RasPiIobroker                            -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : RasPiIobroker                            -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : RasPiIobroker                            -  enabled, port: 0
                        + system.adapter.hm-rpc.2                 : hm-rpc                : RasPiIobroker                            -  enabled, port: 0
                          system.adapter.hm-rpc.3                 : hm-rpc                : RasPiIobroker                            - disabled, port: 0
                          system.adapter.homekit-controller.0     : homekit-controller    : RasPiIobroker                            - disabled
                          system.adapter.ical.0                   : ical                  : RasPiIobroker                            -  enabled
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: RasPiIobroker                            - disabled
                          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : RasPiIobroker                            - disabled
                          system.adapter.icons-material-png.0     : icons-material-png    : RasPiIobroker                            - disabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : RasPiIobroker                            - disabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : RasPiIobroker                            - disabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RasPiIobroker                            - disabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: RasPiIobroker                            - disabled
                          system.adapter.icons-smarthome.0        : icons-smarthome       : RasPiIobroker                            - disabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : RasPiIobroker                            - disabled
                          system.adapter.influxdb.0               : influxdb              : RasPiIobroker                            - disabled, port: 8086
                          system.adapter.info.0                   : info                  : RasPiIobroker                            - disabled
                        + system.adapter.javascript.0             : javascript            : RasPiIobroker                            -  enabled
                        + system.adapter.melcloud.0               : melcloud              : RasPiIobroker                            -  enabled
                        + system.adapter.nina.0                   : nina                  : RasPiIobroker                            -  enabled
                          system.adapter.onvif.0                  : onvif                 : RasPiIobroker                            - disabled, port: 80, 443, 7575, 8000, 8080, 8081, 8899, 9000
                          system.adapter.onvif.1                  : onvif                 : RasPiIobroker                            - disabled, port: 80, 443, 7575, 8000, 8080, 8081, 8899, 9000
                          system.adapter.onvif.2                  : onvif                 : RasPiIobroker                            - disabled, port: 80, 443, 7575, 8000, 8080, 8081, 8899, 9000
                          system.adapter.radar-trap.0             : radar-trap            : RasPiIobroker                            - disabled
                        + system.adapter.reolink.0                : reolink               : RasPiIobroker                            -  enabled
                        + system.adapter.reolink.1                : reolink               : RasPiIobroker                            -  enabled
                          system.adapter.residents.0              : residents             : RasPiIobroker                            - disabled
                          system.adapter.roborock.1               : roborock              : RasPiIobroker                            - disabled
                        + system.adapter.rpi2.0                   : rpi2                  : RasPiIobroker                            -  enabled
                        + system.adapter.shelly.0                 : shelly                : RasPiIobroker                            -  enabled, port: 1882, bind: 0.0.0.0
                          system.adapter.smartcontrol.0           : smartcontrol          : RasPiIobroker                            - disabled
                          system.adapter.smartthings.0            : smartthings           : RasPiIobroker                            - disabled
                        + system.adapter.socketio.0               : socketio              : RasPiIobroker                            -  enabled, port: 8086, bind: 192.168.178.144, run as: admin
                        + system.adapter.socketio.1               : socketio              : RasPiIobroker                            -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                          system.adapter.solarmanpv.0             : solarmanpv            : RasPiIobroker                            - disabled
                        + system.adapter.sourceanalytix.0         : sourceanalytix        : RasPiIobroker                            -  enabled
                        + system.adapter.sourceanalytix.1         : sourceanalytix        : RasPiIobroker                            -  enabled
                          system.adapter.sprinklecontrol.0        : sprinklecontrol       : RasPiIobroker                            - disabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : RasPiIobroker                            -  enabled
                        + system.adapter.telegram.0               : telegram              : RasPiIobroker                            -  enabled, port: 8443, bind: 0.0.0.0
                          system.adapter.tr-064.0                 : tr-064                : RasPiIobroker                            - disabled
                        + system.adapter.tuya.0                   : tuya                  : RasPiIobroker                            -  enabled
                        + system.adapter.unifi-protect.0          : unifi-protect         : RasPiIobroker                            -  enabled
                        + system.adapter.unifi-protect.1          : unifi-protect         : RasPiIobroker                            -  enabled
                        + system.adapter.unifi.0                  : unifi                 : RasPiIobroker                            -  enabled
                        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : RasPiIobroker                            -  enabled
                          system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: RasPiIobroker                            - disabled
                        + system.adapter.vis-2.0                  : vis-2                 : RasPiIobroker                            -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : RasPiIobroker                            - disabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : RasPiIobroker                            - disabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RasPiIobroker                            - disabled
                          system.adapter.vis-history.0            : vis-history           : RasPiIobroker                            - disabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RasPiIobroker                            - disabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : RasPiIobroker                            - disabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : RasPiIobroker                            -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RasPiIobroker                            - disabled
                          system.adapter.vis-justgage.0           : vis-justgage          : RasPiIobroker                            - disabled
                          system.adapter.vis-map.0                : vis-map               : RasPiIobroker                            - disabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : RasPiIobroker                            - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : RasPiIobroker                            - disabled
                          system.adapter.vis-metro.0              : vis-metro             : RasPiIobroker                            - disabled
                          system.adapter.vis-plumb.0              : vis-plumb             : RasPiIobroker                            - disabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : RasPiIobroker                            - disabled
                          system.adapter.vis.0                    : vis                   : RasPiIobroker                            -  enabled
                        + system.adapter.vw-connect.0             : vw-connect            : RasPiIobroker                            -  enabled
                        + system.adapter.web.0                    : web                   : RasPiIobroker                            -  enabled, port: 8082, bind: 192.168.178.144, run as: admin
                        + system.adapter.web.1                    : web                   : RasPiIobroker                            -  enabled, port: 8083, bind: 192.168.178.144, run as: admin
                          system.adapter.web.2                    : web                   : RasPiIobroker                            - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : RasPiIobroker                            -  enabled
                        + system.adapter.worx.0                   : worx                  : RasPiIobroker                            -  enabled
                        + system.adapter.ws.0                     : ws                    : RasPiIobroker                            -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
                        + system.adapter.yahka.0                  : yahka                 : RasPiIobroker                            -  enabled
                        + system.adapter.zigbee.1                 : zigbee                : RasPiIobroker                            -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1c87ccd6d41bef11984da4d94909ffd0-if00-port0
                          system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : RasPiIobroker                            - disabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): beta
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: beta
                        Adapter    "admin"        : 7.8.24   , installed 7.8.24
                        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                        Adapter    "backitup"     : 3.3.17   , installed 3.3.17
                        Adapter    "cloud"        : 6.0.1    , installed 6.0.1
                        Adapter    "devices"      : 2.0.5    , installed 2.0.5
                        Adapter    "echarts"      : 3.1.0    , installed 3.1.0
                        Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
                        Adapter    "epson_ecotank_et_2750": 1.1.0, installed 1.1.0
                        Adapter    "fb-checkpresence": 1.4.2 , installed 1.4.2
                        Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
                        Adapter    "history"      : 4.0.0    , installed 4.0.0
                        Adapter    "hm-rpc"       : 3.0.2    , installed 3.0.2
                        Adapter    "homekit-controller": 0.5.11, installed 0.5.11
                        Adapter    "ical"         : 1.20.1   , installed 1.20.1
                        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                        Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
                        Adapter    "javascript"   : 9.2.2    , installed 9.2.2
                        Controller "js-controller": 7.1.2    , installed 7.1.2
                        Adapter    "melcloud"     : 3.0.4    , installed 3.0.4
                        Adapter    "nina"         : 0.0.26   , installed 0.0.26
                        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                        Adapter    "radar-trap"   : 2.2.2    , installed 2.2.2
                        Adapter    "reolink"      : 1.4.2    , installed 1.4.2
                        Adapter    "residents"    : 1.1.1    , installed 1.1.1
                        Adapter    "roborock"     : 0.7.0    , installed 0.7.0
                        Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
                        Adapter    "shelly"       : 10.6.1   , installed 10.6.1
                        Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
                        Adapter    "smartthings"  : 0.3.0    , installed 0.3.0
                        Adapter    "socketio"     : 7.1.3    , installed 7.1.3
                        Adapter    "solarmanpv"   : 0.7.3    , installed 0.7.3
                        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                        Adapter    "sprinklecontrol": 1.0.5  , installed 1.0.5
                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                        Adapter    "tuya"         : 3.17.0   , installed 3.17.0
                        Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                        Adapter    "unifi-protect": 1.0.1    , installed 1.0.1
                        Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
                        Adapter    "vis-2"        : 2.13.19  , installed 2.13.19
                        Adapter    "vis-2-widgets-radar-trap": 2.3.3, installed 2.3.3
                        Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
                        Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
                        Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
                        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                        Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
                        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                        Adapter    "vw-connect"   : 0.8.3    , installed 0.8.1  [Updatable]
                        Adapter    "web"          : 8.1.0    , installed 8.1.0
                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                        Adapter    "worx"         : 3.3.0    , installed 3.3.0
                        Adapter    "ws"           : 4.1.0    , installed 4.1.0
                        Adapter    "yahka"        : 1.1.6    , installed 1.1.6
                        Adapter    "zigbee"       : 3.4.3    , installed 3.4.3
                        Adapter    "zigbee2mqtt"  : 3.2.1    , installed 3.2.1
                        Objects and States
                        Objects:        36090
                        States:         30856
                        Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
                        Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
                        Reading package lists...
                        Pending systemupdates: 0
                        *** Listening Ports ***
                        tcp        0      0 192.168.178.144:8082    0.0.0.0:*               LISTEN      1001       19985      3704/io.web.0
                        tcp        0      0 192.168.178.144:8083    0.0.0.0:*               LISTEN      1001       22167      3721/io.web.1
                        tcp        0      0 192.168.178.144:8086    0.0.0.0:*               LISTEN      1001       21039      3512/io.socketio.0
                        tcp        0      0 0.0.0.0:43923           0.0.0.0:*               LISTEN      1001       18821      3214/io.yahka.0
                        tcp        0      0 192.168.178.144:2001    0.0.0.0:*               LISTEN      1001       17988      3021/io.hm-rpc.0
                        tcp        0      0 192.168.178.144:2010    0.0.0.0:*               LISTEN      1001       18088      3068/io.hm-rpc.2
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16901      2851/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15249      2851/iobroker.js-co
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          265        1/init
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9325       860/sshd: /usr/sbin
                        tcp        0      0 192.168.178.144:8701    0.0.0.0:*               LISTEN      1001       16223      3034/io.hm-rpc.1
                        tcp6       0      0 :::8085                 :::*                    LISTEN      1001       22531      3737/io.ws.0
                        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       19879      3524/io.socketio.1
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17822      2879/io.admin.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          1206       1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          9335       860/sshd: /usr/sbin
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5511       1/init
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        1911       645/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18874      3117/io.shelly.0
                        udp        0      0 0.0.0.0:39001           0.0.0.0:*                           101        1913       645/avahi-daemon: r
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       19043      3125/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       19044      3125/io.tuya.0
                        udp6       0      0 :::111                  :::*                                0          5512       1/init
                        udp6       0      0 fe80::3474:42d7:a07:546 :::*                                0          8348       699/NetworkManager
                        udp6       0      0 :::5353                 :::*                                101        1912       645/avahi-daemon: r
                        udp6       0      0 :::59000                :::*                                101        1914       645/avahi-daemon: r
                        2026-05-10 22:55:28.844  - info: dwd.0 (4317) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2026-05-10 22:55:29.393  - info: host.RasPiIobroker instance system.adapter.dwd.0 having pid 4317 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2026-05-10 22:55:48.086  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:55:48.310  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:55:50.902  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Connect locally to device
                        2026-05-10 22:55:50.902  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg Init with IP=192.168.178.194, Key=d5R&$cSpUI/[yvX#, Version=3.3
                        2026-05-10 22:55:53.974  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:56:17.046  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:56:51.382  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:56:54.156  - info: tuya.0 (3125) bfacf54b96372f497255jg: Connect locally to device
                        2026-05-10 22:56:54.156  - info: tuya.0 (3125) bfacf54b96372f497255jg Init with IP=192.168.178.53, Key=gd/V|.sWrld+{7Bp, Version=3.3
                        2026-05-10 22:56:57.239  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:57:00.118  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:57:20.310  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:58:03.190  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:58:03.382  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:58:05.959  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Connect locally to device
                        2026-05-10 22:58:05.960  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg Init with IP=192.168.178.194, Key=d5R&$cSpUI/[yvX#, Version=3.3
                        2026-05-10 22:58:09.014  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:58:32.086  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.194:6668
                        2026-05-10 22:59:06.463  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:59:10.969  - info: tuya.0 (3125) bfacf54b96372f497255jg: Connect locally to device
                        2026-05-10 22:59:10.974  - info: tuya.0 (3125) bfacf54b96372f497255jg Init with IP=192.168.178.53, Key=gd/V|.sWrld+{7Bp, Version=3.3
                        2026-05-10 22:59:14.038  - info: tuya.0 (3125) bfacf54b96372f497255jg: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.53:6668
                        2026-05-10 22:59:15.163  - info: tuya.0 (3125) bf883cc2b4e69f7ed901gg: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.194:6668
                        iob diag has finished.
                        • W Würfel
                          ```bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          iob
                          HOME=/home/iob
                          iobroker
                          HOME=/home/iobroker
                          SUDO_HOME=/home/iob
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           2.1G          0B        2.1G
                                   7819 M total memory
                                   4492 M used memory
                                   1929 M free memory
                                    195 M buffer memory
                                   1320 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.5G    /var/
                          231M    /var/cache
                          226M    /var/cache/apt
                          179M    /var/lib
                          147M    /var/lib/apt
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.8.24
                          javascript:     9.2.2
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        36090
                          States:         30856
                          @Würfel
                          Da fehlt der Anfang.
                          • W Offline
                            W Offline
                            Würfel
                            Oh Sorry. Sollte nun komplett sein.
                            • W Würfel
                              @Würfel
                              Das schaut soweit i. O. aus.
                              Ich würde wohl statt des Beta/Latest-Reppo da stable verwenden.
                              W 1 Antwort Letzte Antwort
                                @Würfel
                                W Offline
                                W Offline
                                Würfel
                                @Thomas-Braun Kann ich das einfach in den Basiseinstellungen anklicken und speichern oder mache ich mir da eine neue Baustelle auf?
                                Upgrade automatisch?
                                • W Würfel
                                  @Würfel
                                  Die Quellen kannst du in den Einstellungen ändern.
                                  Von automatischen Upgrades lasse ich die Finger, ich sehe gerne kommen, was da aktualisiert wird.
                                  • W Offline
                                    W Offline
                                    Würfel
                                    Ok Danke
