  4. Test Adapter NSPanel-lovelace-ui v1.x.x
    6.5k
1.3k Beiträge 36 Kommentatoren 310.7k Aufrufe 36 Beobachtet
  • MichaelFM Offline
    MichaelFM Offline
    MichaelF
    #1034
    Dass hat geklappt, Danke :-)
    Musste aber auch den Adapter neu starten:
    admin.0
    2026-04-18 21:17:00.479	info	<== Disconnect system.user.admin from ::ffff:192.168.178.52 javascript
    admin.0
    nspanel-lovelace-ui.0
    2026-04-18 21:16:57.415	info	[controller] Panel NsPanelWohnzimmer removed!
    2026-04-18 21:16:57.283	warn	[NsPanelWohnzimmer] is offline!
    2026-04-18 21:16:57.283	info	[NsPanelWohnzimmer] Goint offline because delete panel!
    2026-04-18 21:16:57.282	error	[NsPanelWohnzimmer] Model missmatch! Config model is eu but panel send us-p. Check your config!
    2026-04-18 21:16:57.282	info	[NsPanelWohnzimmer] is online!
    javascript.0
    2026-04-18 21:16:56.953	info	script.js.nspanel-lovelace-ui_0.NsPanelWohnzimmer: Stopping script
    javascript.0
    2026-04-18 21:16:56.708	info	script.js.nspanel-lovelace-ui_0.NsPanelWohnzimmer: [ 'Panel for Topic: NsPanelWohnzimmer name: NsPanelWohnzimmer Script version 0.20.1 is correct!', 'done', '✅ Panel "08_D1_F9_A4_ED_44" reloaded with updated configuration.']
    2026-04-18 21:16:56.706	info	✅ Panel "08_D1_F9_A4_ED_44" reloaded with updated configuration.
    • T Nicht stören
      T Nicht stören
      ticaki
      #1035
      keine ahnung wo das hier "[NsPanelWohnzimmer] Model missmatch! Config model is eu but panel send us-p. Check your config!
      " herkommt - das sollte da nicht stehen wenns shcon mal lief
      Spenden
      • MichaelFM Offline
        MichaelFM Offline
        MichaelF
        #1036
        kann ich das aus dem alten script einfach in den neuen Kopieren ?
             **                    Screensaver Configuration                      **
            leftScreensaverEntity: [
                // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
            bottomScreensaverEntity: [
                // bottomScreensaverEntity 1
                    ScreensaverEntity: 'brightsky.0.daily.00.sunrise',
                    ScreensaverEntityFactor: 1,
                    ScreensaverEntityDecimalPlaces: 0,
                    ScreensaverEntityDateFormat: {hour: '2-digit', minute: '2-digit'}, // Description at Wiki-Pages
                    ScreensaverEntityIconOn: 'weather-sunset-up',
                    ScreensaverEntityIconOff: null,
                    ScreensaverEntityText: 'Sonne',
                    ScreensaverEntityUnitText: '%',
                    ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100}
                // bottomScreensaverEntity 2
                    ScreensaverEntity: 'sainlogic.0.weather.current.windspeed',
                    ScreensaverEntityFactor: (1000 / 3600),
                    ScreensaverEntityDecimalPlaces: 1,
                    ScreensaverEntityIconOn: 'weather-windy',
                    ScreensaverEntityText: "Wind",
                    ScreensaverEntityUnitText: 'm/s',
                    ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120}
                // bottomScreensaverEntity 3
                    ScreensaverEntity: 'sainlogic.0.weather.current.windgustspeed',
                    ScreensaverEntityIconOn: 'weather-tornado',
                    ScreensaverEntityText: 'Böen',
                // bottomScreensaverEntity 4
                    ScreensaverEntity: 'brightsky.0.current.wind_bearing_text',
                    ScreensaverEntityIconOn: 'windsock',
                    ScreensaverEntityText: 'Windr.',
                    ScreensaverEntityUnitText: '°',
                    ScreensaverEntityIconColor: White
                // bottomScreensaverEntity 5 (for Alternative and Advanced Screensaver)
                    ScreensaverEntity: 'sainlogic.0.weather.current.outdoorhumidity',
                    ScreensaverEntityIconOn: 'water-percent',
                    ScreensaverEntityText: 'Feuchte',
                    ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65}
                // bottomScreensaverEntity 6 (for Advanced Screensaver)
                    ScreensaverEntity: NSPanel_Path + 'Relay.1',
                    ScreensaverEntityIconOn: 'coach-lamp-variant',
                    ScreensaverEntityText: 'Street',
                    ScreensaverEntityOnColor: Yellow,
                    ScreensaverEntityOffColor: White,
                    ScreensaverEntityOnText: 'Is ON',
                    ScreensaverEntityOffText: 'Not ON'
            indicatorScreensaverEntity: [
            // Status Icon
            mrIcon1ScreensaverEntity: {
                ScreensaverEntityIconOn: 'ceiling-fan',
                ScreensaverEntityValue: null,
                ScreensaverEntityValueDecimalPlace: 0,
                ScreensaverEntityValueUnit: null,
                ScreensaverEntityOnColor: On,
                ScreensaverEntityOffColor: HMIOff
            mrIcon2ScreensaverEntity: {
                ScreensaverEntity: NSPanel_Path + 'Relay.2',
                ScreensaverEntityIconOn: 'lightbulb',
            // ------ DE: Ende der Screensaver Einstellungen --------------------
            // ------ EN: End of screensaver settings ---------------------------
        • arteckA Offline
          arteckA Offline
          arteck
          #1037
          kann ich mit https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/wiki/PageThermo2 ein whirlpool ansteuern ?
          die DP's hätte ich gerne in der Card
          werd aber mal wieder aus der Beschreibung nicht schlau..
          • T Nicht stören
            T Nicht stören
            ticaki
            #1038
            Ja,
            ne cardThermo2 ist ne cardGrid2 mit nem Thermostat.
            Da bei items (NICHT thermoItems) machste die schalter/anzeigen für filter, heater, session usw rein, wie bei einer cardGrid
            const this_Thermostat: PageType =
                    'type': 'cardThermo2',
                    'heading': 'Wohnzimmer',
                    uniqueName: 'this_Thermostat',
                    thermoItems: [
                            name2: 'Klimaanlage',
                            minValue: 16,
                            maxValue: 28,
                            stepValue: 0.1,
                    'parent': 'main',
                    'items': []
            Ich steuere damit meine Klimaanlage an, du müsstest name2 weg lassen
            Spenden
            • arteckA arteck
              TT-Tom
              #1039
              @arteck
              versuche mal das, musste nur ausbauen
              const Thermo2New: PageType = {
                      type: 'cardThermo2',
                      uniqueName:'Seitenname für interne Verwendung - Pflicht',
                      heading: 'egal wird eh nicht angezeigt',
                      thermoItems:[
                              name: 'Das hier ist die Überschrift',
                              set:'mspa.0.control.target_temperature', // Der Einstellwert der Heizung
                              thermoId1:'mspa.0.status.water_temperature', // Aktuelle Raumtemperatur (oberer Wert in der Anzeige)
                              //thermoId2:'0_userdata.0.Einzelne_Geräte.Thermostat.HUMIDITY', // Aktuelle Luftfeuchtigkeit (unterer Wert in der Anzeige)
                              //modeId:'0_userdata.0.Einzelne_Geräte.Thermostat.MODE', // Textfeld unterhalb der Werte - kein Zeichenkettendatenpunkt
                      items:[
                           {id: 'mspa.0.control.filter', icon: 'water-check'},
                           {id: 'mspa.0.control.heater', icon:'heat-wave'},
              usw. ......
              Gruß Tom
              Public Transport
              NSPanel Adapter Wiki
              • MichaelFM MichaelF
                    // Status Icon
                TT-Tom
                #1040
                @MichaelF
                was genau möchtest du rüber kopieren, alles was du gezeigt hast?? bitte genauer definieren.
                Gruß Tom
                Public Transport
                MichaelFM 1 Antwort Letzte Antwort
                • T TT-Tom
                  @MichaelF
                  MichaelFM Offline
                  MichaelFM Offline
                  MichaelF
                  #1041
                  @TT-Tom
                  Ich glaube ich habe es hin bekommen, was nur nicht Funktioniert ist das umschalten auf die andere Vorhersage im Bildschirmschoner.
                  Hatte das Display vorher gemacht.
                  Hier meine gessamte Konfig:
                          favoritScreensaverEntity: [],
                          alternateScreensaverEntity: [
                              // only used with alternate Screensaver
                              // indicatorScreensaverEntity 1 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_offene_Fenster.ACTUAL',
                                  ScreensaverEntityIconOn: 'window-open-variant',
                                  ScreensaverEntityIconOff: 'window-closed-variant',
                                  ScreensaverEntityText: 'Fenster',
                                  ScreensaverEntityIconColor: {val_min: 0, val_max: 1},
                              // indicatorScreensaverEntity 2 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_offene_Tuer.ACTUAL',
                                  ScreensaverEntityIconOn: 'door-open',
                                  ScreensaverEntityIconOff: 'door-closed',
                                  ScreensaverEntityText: 'Tür',
                                  ScreensaverEntityUnitText: '',
                              // indicatorScreensaverEntity 3 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_Licht_An.ACTUAL',
                                  ScreensaverEntityText: 'Licht',
                              // indicatorScreensaverEntity 4 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.Türschloss.ACTUAL',
                                  ScreensaverEntityIconOn: 'lock',
                                  ScreensaverEntityIconOff: 'lock-open',
                                  ScreensaverEntityText: 'Türschloss',
                                  ScreensaverEntityIconColor: {val_min: 0, val_max: 1, val_best: 1},
                              // indicatorScreensaverEntity 5 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.NSPanel.allgemein.Auto.Safety.ACTUAL',
                                  ScreensaverEntityIconOn: 'car-key',
                                  ScreensaverEntityText: 'Auto',
                              type: 'script',
                              ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100},
                              type: 'script',
                              type: 'script',
                              type: 'script',
                                  type: 'script',
                              ScreensaverEntityIconColor: White,
                              // bottomScreensaverEntity 5 (Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 60}
                              // Some templates for the screensaver uncomment the lines to use them
                              // If u use an other instance for the weather data, change the instance in the following lines
                              // If you want to have them all, set weatherAddDefaultItems=true in the config and leave the following lines as they are!
                              // zum nutzen der Vorlagen für den Bildschirmschoner die Zeilen auskommentieren, um sie zu verwenden
                              // Wenn du eine andere Instanz für die Wetterdaten verwendest, ändere die Instanz in den folgenden Zeilen
                              // Wenn du sie alle haben willst, setze weatherAddDefaultItems=true in der Konfiguration ganz oben und lass die folgenden Zeilen so wie sie sind!
                              OPENWEATHERMAP
                              // Bottom 1 - sunrise/set
                                  type: 'template',
                                  template: 'text.openweathermap.favorit',
                                  dpInit: `/^openweathermap\\.0.+/`,
                                  modeScr: 'favorit',
                              // Bottom 2 -  Forecast Day 1
                                  type: 'template',
                                  template: 'text.openweathermap.bot2values',
                                  dpInit: `/^openweathermap\\.0.+?day0/`,
                                  modeScr: 'bottom',
                              // Bottom 3 - Forecast Day 2
                                  type: 'template',
                                  dpInit: `/^openweathermap\\.0.+?day1/`,
                                  modeScr: 'bottom',
                              // Bottom 4 - Forecast Day 3
                                  type: 'template',
                                  dpInit: `/^openweathermap\\.0.+?day2/`,
                                  modeScr: 'bottom',
                              // Bottom 5 - Forecast Day 4
                                  type: 'template',
                                  dpInit: `/^openweathermap\\.0.+?day3/`,
                                  modeScr: 'bottom',
                              // Bottom 6 - Forecast Day 5
                                  type: 'template',
                                  dpInit: `/^openweathermap\\.0.+?day4/`,
                                  modeScr: 'bottom',
                              // Bottom 7 -  Forecast Day 6
                                  type: 'template',
                                  dpInit: `/^openweathermap\\.0.+?day5/`,
                                  modeScr: 'bottom',
                              // Bottom 8 - Windgeschwindigkeit
                                  type: 'template',
                                  template: 'text.openweathermap.windspeed',
                                  dpInit: `/^openweathermap\\.0./`,
                                  modeScr: 'bottom',
                              // Bottom 9 - Böen
                                  type: 'template',
                                  template: 'text.openweathermap.windgust',
                                  modeScr: 'bottom',
                              // Bottom 10 - Windrichtung
                                  type: 'template',
                                  template: 'text.openweathermap.winddirection',
                                  modeScr: 'bottom',
                              // Bottom 11 - UV-Index
                                  type: 'template',
                                  template: 'text.accuweather.uvindex',
                                  dpInit: `/^accuweather\\.0./`,
                                  modeScr: 'bottom',
                              PIRATE-WEATHER
                                  type: 'template',
                                  template: 'text.pirate-weather.sunriseset',
                                  dpInit: `/^pirate-weather\\.0\\.weather\\.daily\\.00.+/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  template: 'text.pirate-weather.bot2values',
                                  dpInit: `/^pirate-weather\\.0.+?\\.daily\\.01/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  dpInit: `/^pirate-weather\\.0.+?\\.daily\\.02/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  dpInit: `/^pirate-weather\\.0.+?\\.daily\\.03/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  dpInit: `/^pirate-weather\\.0.+?\\.daily\\.04/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  dpInit: `/^pirate-weather\\.0.+?\\.daily\\.05/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  dpInit: `/^pirate-weather\\.0.+?\\.daily\\.06/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  template: 'text.pirate-weather.windspeed',
                                  dpInit: `/^pirate-weather\\.0\\.weather\\.currently./`,
                                  modeScr: 'bottom',
                              // Bottom 9 - Böen
                                  type: 'template',
                                  template: 'text.pirate-weather.windgust',
                                  modeScr: 'bottom',
                                  type: 'template',
                                  template: 'text.pirate-weather.winddirection',
                                  modeScr: 'bottom',
                                  type: 'template',
                                  template: 'text.pirate-weather.uvindex',
                                  modeScr: 'bottom',
                              // hier kann man dann eine Stundenübersicht erzeugen durch anpassen der 02 bzw. 04
                              // die sind nicht in addDefaultWeather enthalten.
                                  type: 'template',
                                  template: 'text.pirate-weather.hourlyweather',
                                  dpInit: `/^pirate-weather\\.0.+?\\.hourly\\.02/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  dpInit: `/^pirate-weather\\.0.+?\\.hourly\\.04/`,
                                  modeScr: 'bottom',
                            // Bright Sky
                                  type: 'template',
                                  template: 'text.brightsky.sunriseset',
                                  dpInit: `/^brightsky\\.0\\.daily\\.00.+/`,
                                  modeScr: 'bottom',
                              // Bottom 2 - brightsky.0. Forecast Day 1
                                  type: 'template',
                                  template: 'text.brightsky.bot2values',
                                  dpInit: `/^brightsky\\.0\\.daily\\.01/`,
                                  modeScr: 'bottom',
                              // Bottom 3 - brightsky.0. Forecast Day 2
                                  type: 'template',
                                  dpInit: `/^brightsky\\.0\\.daily\\.02/`,
                                  modeScr: 'bottom',
                              // Bottom 4 - brightsky.0. Forecast Day 3
                                  type: 'template',
                                  dpInit: `/^brightsky\\.0\\.daily\\.03/`,
                                  modeScr: 'bottom',
                              // Bottom 5 - brightsky.0. Forecast Day 4
                                  type: 'template',
                                  dpInit: `/^brightsky\\.0\\.daily\\.04/`,
                                  modeScr: 'bottom',
                              // Bottom 6 - brightsky.0. Forecast Day 5
                                  type: 'template',
                                  dpInit: `/^brightsky\\.0\\.daily\\.05/`,
                                  modeScr: 'bottom',
                              // Bottom 7 - brightsky.0. Forecast Day 6
                                  type: 'template',
                                  dpInit: `/^brightsky\\.0\\.daily\\.06/`,
                                  modeScr: 'bottom',
                                  type: 'template',
                                  template: 'text.brightsky.windspeed',
                                  dpInit: `/^brightsky\\.0\\.current./`,
                                  modeScr: 'bottom',
                              // Bottom 9 - Böen
                                  type: 'template',
                                  template: 'text.brightsky.windgust',
                                  modeScr: 'bottom',
                                  type: 'template',
                                  template: 'text.brightsky.winddirection',
                                  modeScr: 'bottom',
                              // Bottom 10 - Solar
                                  type: 'template',
                                  template: 'text.brightsky.solar',
                                  modeScr: 'bottom',
                              // leftScreensaverEntity 1 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.NSPanel.Flur.Sensor.ANALOG.Temperature.ACTUAL',
                                  ScreensaverEntityIconOn: 'thermometer',
                                  ScreensaverEntityText: 'Temperatur',
                                  ScreensaverEntityUnitText: '°C',
                                  ScreensaverEntityIconColor: {val_min: 0, val_max: 35, val_best: 22},
                              // leftScreensaverEntity 2 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.Heizung.WärmeTagesVerbrauch.ACTUAL',
                                  ScreensaverEntityIconOn: 'counter',
                                  ScreensaverEntityText: 'Wärme',
                                  ScreensaverEntityUnitText: ' kWh',
                                  ScreensaverEntityIconColor: MSYellow, //{'val_min': 0, 'val_max': 5000}
                              // leftScreensaverEntity 3 (only Advanced Screensaver)
                                  type: 'script',
                                  ScreensaverEntity: 'alias.0.NSPanel.allgemein.Abfall.event1.INFO',
                                  ScreensaverEntityDateFormat: {year: 'numeric', month: '2-digit', day: '2-digit'},
                                  ScreensaverEntityIconOn: 'trash-can',
                                  ScreensaverEntityText: 'Abfall',
                                  ScreensaverEntityIconColor: '0_userdata.0.Abfallkalender.1.color',
                          // Status Icon
                              type: 'script',
                              ScreensaverEntity: 'Relay.1',
                              type: 'script',
                              ScreensaverEntity: 'Relay.2',
                  Dimmer habe ich noch nicht hin bekommen:
                  Lässt sich nur ein und aus schalten hier der Alias:
                  Und diese Fehlermeldung ist echt nervig weil man immer den Adapter neu starten muss wenn man was am script ändert :-)
                  2026-04-19 00:30:05.407	info	[controller] Panel NsPanelWohnzimmer removed!
                  2026-04-19 00:30:05.296	warn	[NsPanelWohnzimmer] is offline!
                  2026-04-19 00:30:05.295	info	[NsPanelWohnzimmer] Goint offline because delete panel!
                  2026-04-19 00:30:05.295	error	[NsPanelWohnzimmer] Model missmatch! Config model is eu but panel send us-p. Check your config!
                  2026-04-19 00:30:05.295	info	[NsPanelWohnzimmer] is online!
                  javascript.0
                  2026-04-19 00:30:04.974	info	script.js.nspanel-lovelace-ui_0.NsPanelWohnzimmer: Stopping script
                  javascript.0
                  2026-04-19 00:30:04.739	info	script.js.nspanel-lovelace-ui_0.NsPanelWohnzimmer: [ 'Panel for Topic: NsPanelWohnzimmer name: NsPanelWohnzimmer Script version 0.20.1 is correct!', 'done', '✅ Panel "08_D1_F9_A4_ED_44" reloaded with updated configuration.' ]
                  2026-04-19 00:30:04.737	info	✅ Panel "08_D1_F9_A4_ED_44" reloaded with updated configuration.
                  admin.0
                  2026-04-19 00:30:03.883	info	<== Disconnect system.user.admin from ::ffff:192.168.178.52 javascript
                  admin.0
                  2026-04-19 00:30:03.341	info	[NsPanelWohnzimmer] Setting panel to offline until first message!
                  ical.0
                  2026-04-19 00:30:03.238	info	processing URL: Google https://calendar.google.com/calendar/ical/mferber83%40gmail.com/private-54e18925919b923d77c7864d1eaab115/basic.ics
                  ical.0
                  2026-04-19 00:30:02.297	info	starting. Version 1.19.7 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
                  2026-04-19 00:30:02.280	info	[controller] Panel NsPanelWohnzimmer removed!
                  2026-04-19 00:30:01.963	warn	[NsPanelWohnzimmer] is offline!
                  2026-04-19 00:30:01.957	info	[NsPanelWohnzimmer] Goint offline because delete panel!
                  Anaonsten läuft das erste Panel 😀
                  • T Nicht stören
                    T Nicht stören
                    ticaki
                    #1042
                    Dein Panel sagt es wäre ein us-p keine Ahnung wie es darauf kommt. Was ist es denn?
                    Spenden
                    • T ticaki
                      MichaelFM Offline
                      MichaelFM Offline
                      MichaelF
                      schrieb am zuletzt editiert von MichaelF
                      #1043
                      @ticaki Ein US im Hochformat
                      • MichaelFM Offline
                        MichaelFM Offline
                        MichaelF
                        #1044
                        Gibt es die Möglichkeit bei diesem Alias die Schrittgröße kleiner zu machen ?
                        { id: 'alias.0.NSPanel.TemperaturWassserSpeicher', name: 'TemperaturSpeicher', useValue: true, suffixName: '°C'},
                        • T Nicht stören
                          T Nicht stören
                          ticaki
                          #1045
                          Dann hast du es falsch in der initialisierung eingestellt - gehte auf nspanel initialisierung stelle klicke auf dem panel auf den stift stelle rechts oben us-p ein und klicke auf nspanel aktualisierung
                          Spenden
                          • T ticaki
                            MichaelFM Offline
                            MichaelFM Offline
                            MichaelF
                            #1046
                            @ticaki
                            hab ich schon zwei mal gemacht:
                            Immer die gleiche Fehlermeldung.
                            Wenn es hier auch falsch eingestellt wäre passt auch die Ansicht nicht, hatte ich am Anfang :-)
                            • T Nicht stören
                              T Nicht stören
                              ticaki
                              #1047
                              Ich muß ja erstmal den standardfehler abklappern - das eine mal wo ich nicht ffrage ist es falsch initialisiert :D Bug ist notiert muß mal suchen - wo der fehler entsteht.
                              EDIT: gefunden
                              Spenden
                              • T Nicht stören
                                T Nicht stören
                                ticaki
                                #1048
                                0.17.5 (2026-04-18)
                                • (ticaki) When the panel was restarted by the script, the model was set to ‘eu’
                                Spenden
                                • MichaelFM Offline
                                  MichaelFM Offline
                                  MichaelF
                                  #1049
                                  Funktioniert, kann vielleicht noch mal jemand bei den Dimmern unterstützen oder gehen die einfach noch nicht?
                                    T Nicht stören
                                    T Nicht stören
                                    ticaki
                                    #1050
                                    @MichaelF sagte:
                                    fontSize: 0-5
                                    Spenden
                                      T Nicht stören
                                      T Nicht stören
                                      ticaki
                                      #1051
                                      @MichaelF sagte:
                                      Alles geht! Was nicht bedeutet, dass wir nichts vergessen haben :)
                                      Dimmer sollte gehen um zu helfen brauche ich die Skriptzeile und ein Bild vom alias. Ich benutze den Devicemanager nicht, bin i.d.R. schneller fertig wenn ichs per Hand mache.
                                      Spenden
                                      • T ticaki
                                        @MichaelF sagte:
                                        fontSize: 0-5
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        #1052
                                        @ticaki
                                        Ich glaub das war es :-)
                                          @ticaki
                                          MichaelFM Offline
                                          MichaelFM Offline
                                          MichaelF
                                          #1053
                                          Leider doch nicht da ändert sich leider nichts egal ob 1 oder 5
                                          { id: 'alias.0.NSPanel.TemperaturWassserSpeicher', name: 'TemperaturSpeicher', useValue: true, suffixName: '°C', fontSize: 0 },
