Test Adapter NSPanel-lovelace-ui v1.x.x
kann ich das aus dem alten script einfach in den neuen Kopieren ?
/*********************************************************************** ** ** ** Screensaver Configuration ** ** ** ***********************************************************************/ leftScreensaverEntity: [ // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400 ], bottomScreensaverEntity: [ // bottomScreensaverEntity 1 { ScreensaverEntity: 'brightsky.0.daily.00.sunrise', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityDateFormat: {hour: '2-digit', minute: '2-digit'}, // Description at Wiki-Pages ScreensaverEntityIconOn: 'weather-sunset-up', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Sonne', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100} }, // bottomScreensaverEntity 2 { ScreensaverEntity: 'sainlogic.0.weather.current.windspeed', ScreensaverEntityFactor: (1000 / 3600), ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'weather-windy', ScreensaverEntityIconOff: null, ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'm/s', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} }, // bottomScreensaverEntity 3 { ScreensaverEntity: 'sainlogic.0.weather.current.windgustspeed', ScreensaverEntityFactor: (1000 / 3600), ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'weather-tornado', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Böen', ScreensaverEntityUnitText: 'm/s', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} }, // bottomScreensaverEntity 4 { ScreensaverEntity: 'brightsky.0.current.wind_bearing_text', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'windsock', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Windr.', ScreensaverEntityUnitText: '°', ScreensaverEntityIconColor: White }, // bottomScreensaverEntity 5 (for Alternative and Advanced Screensaver) { ScreensaverEntity: 'sainlogic.0.weather.current.outdoorhumidity', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'water-percent', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Feuchte', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} }, // bottomScreensaverEntity 6 (for Advanced Screensaver) { ScreensaverEntity: NSPanel_Path + 'Relay.1', ScreensaverEntityIconOn: 'coach-lamp-variant', ScreensaverEntityText: 'Street', ScreensaverEntityOnColor: Yellow, ScreensaverEntityOffColor: White, ScreensaverEntityOnText: 'Is ON', ScreensaverEntityOffText: 'Not ON' }, // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400 ], indicatorScreensaverEntity: [ // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400 ], // Status Icon mrIcon1ScreensaverEntity: { ScreensaverEntity: NSPanel_Path + 'Relay.1', ScreensaverEntityIconOn: 'ceiling-fan', ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff }, mrIcon2ScreensaverEntity: { ScreensaverEntity: NSPanel_Path + 'Relay.2', ScreensaverEntityIconOn: 'lightbulb', ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff }, // ------ DE: Ende der Screensaver Einstellungen -------------------- // ------ EN: End of screensaver settings --------------------------- -
was genau möchtest du rüber kopieren, alles was du gezeigt hast?? bitte genauer definieren.
Ich glaube ich habe es hin bekommen, was nur nicht Funktioniert ist das umschalten auf die andere Vorhersage im Bildschirmschoner.
Hatte das Display vorher gemacht.
Hier meine gessamte Konfig:
/*********************************************************************** ** ** ** Screensaver Configuration ** ** ** ***********************************************************************/ favoritScreensaverEntity: [], alternateScreensaverEntity: [ // only used with alternate Screensaver ], indicatorScreensaverEntity: [ // indicatorScreensaverEntity 1 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_offene_Fenster.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'window-open-variant', ScreensaverEntityIconOff: 'window-closed-variant', ScreensaverEntityText: 'Fenster', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {val_min: 0, val_max: 1}, }, // indicatorScreensaverEntity 2 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_offene_Tuer.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'door-open', ScreensaverEntityIconOff: 'door-closed', ScreensaverEntityText: 'Tür', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: {val_min: 0, val_max: 1}, }, // indicatorScreensaverEntity 3 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.NSPanel.allgemein.Status_Licht_An.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'lightbulb', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Licht', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: {val_min: 0, val_max: 1}, }, // indicatorScreensaverEntity 4 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.Türschloss.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'lock', ScreensaverEntityIconOff: 'lock-open', ScreensaverEntityText: 'Türschloss', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: {val_min: 0, val_max: 1, val_best: 1}, }, // indicatorScreensaverEntity 5 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.NSPanel.allgemein.Auto.Safety.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'car-key', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Auto', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: {val_min: 0, val_max: 1, val_best: 1}, }, ], bottomScreensaverEntity: [ // bottomScreensaverEntity 1 { type: 'script', ScreensaverEntity: 'brightsky.0.daily.00.sunrise', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityDateFormat: {hour: '2-digit', minute: '2-digit'}, // Description at Wiki-Pages ScreensaverEntityIconOn: 'weather-sunset-up', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Sonne', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: MSYellow //{'val_min': 0, 'val_max': 100}, }, // bottomScreensaverEntity 2 { type: 'script', ScreensaverEntity: 'sainlogic.0.weather.current.outdoorhumidity', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'water-percent', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Feuchte', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} }, { type: 'script', ScreensaverEntity: 'sainlogic.0.weather.current.windspeed', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'weather-windy', ScreensaverEntityIconOff: null, ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'm/s', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} }, // bottomScreensaverEntity 3 { type: 'script', ScreensaverEntity: 'sainlogic.0.weather.current.windgustspeed', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'weather-tornado', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Böen', ScreensaverEntityUnitText: 'm/s', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} }, // bottomScreensaverEntity 4 { type: 'script', ScreensaverEntity: 'brightsky.0.current.wind_bearing_text', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'windsock', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Windr.', ScreensaverEntityUnitText: '°', ScreensaverEntityIconColor: White, }, // bottomScreensaverEntity 5 (Advanced Screensaver) { type: 'script', ScreensaverEntity: 'sainlogic.0.weather.current.outdoorhumidity', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityIconOn: 'water-percent', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Feuchte', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 60} }, // bottomScreensaverEntity 6 (for Advanced Screensaver) // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400 // Some templates for the screensaver uncomment the lines to use them // If u use an other instance for the weather data, change the instance in the following lines // If you want to have them all, set weatherAddDefaultItems=true in the config and leave the following lines as they are! // zum nutzen der Vorlagen für den Bildschirmschoner die Zeilen auskommentieren, um sie zu verwenden // Wenn du eine andere Instanz für die Wetterdaten verwendest, ändere die Instanz in den folgenden Zeilen // Wenn du sie alle haben willst, setze weatherAddDefaultItems=true in der Konfiguration ganz oben und lass die folgenden Zeilen so wie sie sind! /* OPENWEATHERMAP // Bottom 1 - sunrise/set { type: 'template', template: 'text.openweathermap.favorit', dpInit: `/^openweathermap\\.0.+/`, modeScr: 'favorit', }, // Bottom 2 - Forecast Day 1 { type: 'template', template: 'text.openweathermap.bot2values', dpInit: `/^openweathermap\\.0.+?day0/`, modeScr: 'bottom', }, // Bottom 3 - Forecast Day 2 { type: 'template', template: 'text.openweathermap.bot2values', dpInit: `/^openweathermap\\.0.+?day1/`, modeScr: 'bottom', }, // Bottom 4 - Forecast Day 3 { type: 'template', template: 'text.openweathermap.bot2values', dpInit: `/^openweathermap\\.0.+?day2/`, modeScr: 'bottom', }, // Bottom 5 - Forecast Day 4 { type: 'template', template: 'text.openweathermap.bot2values', dpInit: `/^openweathermap\\.0.+?day3/`, modeScr: 'bottom', }, // Bottom 6 - Forecast Day 5 { type: 'template', template: 'text.openweathermap.bot2values', dpInit: `/^openweathermap\\.0.+?day4/`, modeScr: 'bottom', }, // Bottom 7 - Forecast Day 6 { type: 'template', template: 'text.openweathermap.bot2values', dpInit: `/^openweathermap\\.0.+?day5/`, modeScr: 'bottom', }, // Bottom 8 - Windgeschwindigkeit { type: 'template', template: 'text.openweathermap.windspeed', dpInit: `/^openweathermap\\.0./`, modeScr: 'bottom', }, // Bottom 9 - Böen { type: 'template', template: 'text.openweathermap.windgust', dpInit: `/^openweathermap\\.0./`, modeScr: 'bottom', }, // Bottom 10 - Windrichtung { type: 'template', template: 'text.openweathermap.winddirection', dpInit: `/^openweathermap\\.0./`, modeScr: 'bottom', }, // Bottom 11 - UV-Index { type: 'template', template: 'text.accuweather.uvindex', dpInit: `/^accuweather\\.0./`, modeScr: 'bottom', }, */ /* PIRATE-WEATHER // Bottom 1 - sunrise/set { type: 'template', template: 'text.pirate-weather.sunriseset', dpInit: `/^pirate-weather\\.0\\.weather\\.daily\\.00.+/`, modeScr: 'bottom', }, // Bottom 2 - Forecast Day 1 { type: 'template', template: 'text.pirate-weather.bot2values', dpInit: `/^pirate-weather\\.0.+?\\.daily\\.01/`, modeScr: 'bottom', }, // Bottom 3 - Forecast Day 2 { type: 'template', template: 'text.pirate-weather.bot2values', dpInit: `/^pirate-weather\\.0.+?\\.daily\\.02/`, modeScr: 'bottom', }, // Bottom 4 - Forecast Day 3 { type: 'template', template: 'text.pirate-weather.bot2values', dpInit: `/^pirate-weather\\.0.+?\\.daily\\.03/`, modeScr: 'bottom', }, // Bottom 5 - Forecast Day 4 { type: 'template', template: 'text.pirate-weather.bot2values', dpInit: `/^pirate-weather\\.0.+?\\.daily\\.04/`, modeScr: 'bottom', }, // Bottom 6 - Forecast Day 5 { type: 'template', template: 'text.pirate-weather.bot2values', dpInit: `/^pirate-weather\\.0.+?\\.daily\\.05/`, modeScr: 'bottom', }, // Bottom 7 - Forecast Day 6 { type: 'template', template: 'text.pirate-weather.bot2values', dpInit: `/^pirate-weather\\.0.+?\\.daily\\.06/`, modeScr: 'bottom', }, // Bottom 8 - Windgeschwindigkeit { type: 'template', template: 'text.pirate-weather.windspeed', dpInit: `/^pirate-weather\\.0\\.weather\\.currently./`, modeScr: 'bottom', }, // Bottom 9 - Böen { type: 'template', template: 'text.pirate-weather.windgust', dpInit: `/^pirate-weather\\.0\\.weather\\.currently./`, modeScr: 'bottom', }, // Bottom 10 - Windrichtung { type: 'template', template: 'text.pirate-weather.winddirection', dpInit: `/^pirate-weather\\.0\\.weather\\.currently./`, modeScr: 'bottom', }, // Bottom 11 - UV-Index { type: 'template', template: 'text.pirate-weather.uvindex', dpInit: `/^pirate-weather\\.0\\.weather\\.currently./`, modeScr: 'bottom', }, // hier kann man dann eine Stundenübersicht erzeugen durch anpassen der 02 bzw. 04 // die sind nicht in addDefaultWeather enthalten. { type: 'template', template: 'text.pirate-weather.hourlyweather', dpInit: `/^pirate-weather\\.0.+?\\.hourly\\.02/`, modeScr: 'bottom', }, { type: 'template', template: 'text.pirate-weather.hourlyweather', dpInit: `/^pirate-weather\\.0.+?\\.hourly\\.04/`, modeScr: 'bottom', }, */ // Bright Sky { type: 'template', template: 'text.brightsky.sunriseset', dpInit: `/^brightsky\\.0\\.daily\\.00.+/`, modeScr: 'bottom', }, // Bottom 2 - brightsky.0. Forecast Day 1 { type: 'template', template: 'text.brightsky.bot2values', dpInit: `/^brightsky\\.0\\.daily\\.01/`, modeScr: 'bottom', }, // Bottom 3 - brightsky.0. Forecast Day 2 { type: 'template', template: 'text.brightsky.bot2values', dpInit: `/^brightsky\\.0\\.daily\\.02/`, modeScr: 'bottom', }, // Bottom 4 - brightsky.0. Forecast Day 3 { type: 'template', template: 'text.brightsky.bot2values', dpInit: `/^brightsky\\.0\\.daily\\.03/`, modeScr: 'bottom', }, // Bottom 5 - brightsky.0. Forecast Day 4 { type: 'template', template: 'text.brightsky.bot2values', dpInit: `/^brightsky\\.0\\.daily\\.04/`, modeScr: 'bottom', }, // Bottom 6 - brightsky.0. Forecast Day 5 { type: 'template', template: 'text.brightsky.bot2values', dpInit: `/^brightsky\\.0\\.daily\\.05/`, modeScr: 'bottom', }, // Bottom 7 - brightsky.0. Forecast Day 6 { type: 'template', template: 'text.brightsky.bot2values', dpInit: `/^brightsky\\.0\\.daily\\.06/`, modeScr: 'bottom', }, // Bottom 8 - Windgeschwindigkeit { type: 'template', template: 'text.brightsky.windspeed', dpInit: `/^brightsky\\.0\\.current./`, modeScr: 'bottom', }, // Bottom 9 - Böen { type: 'template', template: 'text.brightsky.windgust', dpInit: `/^brightsky\\.0\\.current./`, modeScr: 'bottom', }, // Bottom 10 - Windrichtung { type: 'template', template: 'text.brightsky.winddirection', dpInit: `/^brightsky\\.0\\.current./`, modeScr: 'bottom', }, // Bottom 10 - Solar { type: 'template', template: 'text.brightsky.solar', dpInit: `/^brightsky\\.0\\.current./`, modeScr: 'bottom', }, ], leftScreensaverEntity: [ // leftScreensaverEntity 1 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.NSPanel.Flur.Sensor.ANALOG.Temperature.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'thermometer', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Temperatur', ScreensaverEntityUnitText: '°C', ScreensaverEntityIconColor: {val_min: 0, val_max: 35, val_best: 22}, }, // leftScreensaverEntity 2 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.Heizung.WärmeTagesVerbrauch.ACTUAL', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 1, ScreensaverEntityIconOn: 'counter', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Wärme', ScreensaverEntityUnitText: ' kWh', ScreensaverEntityIconColor: MSYellow, //{'val_min': 0, 'val_max': 5000} }, // leftScreensaverEntity 3 (only Advanced Screensaver) { type: 'script', ScreensaverEntity: 'alias.0.NSPanel.allgemein.Abfall.event1.INFO', ScreensaverEntityFactor: 1, ScreensaverEntityDecimalPlaces: 0, ScreensaverEntityDateFormat: {year: 'numeric', month: '2-digit', day: '2-digit'}, ScreensaverEntityIconOn: 'trash-can', ScreensaverEntityIconOff: null, ScreensaverEntityText: 'Abfall', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: '0_userdata.0.Abfallkalender.1.color', }, ], // Status Icon mrIcon1ScreensaverEntity: { type: 'script', ScreensaverEntity: 'Relay.1', ScreensaverEntityIconOn: 'ceiling-fan', ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff }, mrIcon2ScreensaverEntity: { type: 'script', ScreensaverEntity: 'Relay.2', ScreensaverEntityIconOn: 'lightbulb', ScreensaverEntityIconOff: null, ScreensaverEntityValue: null, ScreensaverEntityValueDecimalPlace: 0, ScreensaverEntityValueUnit: null, ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff }, // ------ DE: Ende der Screensaver Einstellungen -------------------- // ------ EN: End of screensaver settings ---------------------------Dimmer habe ich noch nicht hin bekommen:
Lässt sich nur ein und aus schalten hier der Alias:
Und diese Fehlermeldung ist echt nervig weil man immer den Adapter neu starten muss wenn man was am script ändert :-)
nspanel-lovelace-ui.0 2026-04-19 00:30:05.407 info [controller] Panel NsPanelWohnzimmer removed! nspanel-lovelace-ui.0 2026-04-19 00:30:05.296 warn [NsPanelWohnzimmer] is offline! nspanel-lovelace-ui.0 2026-04-19 00:30:05.295 info [NsPanelWohnzimmer] Goint offline because delete panel! nspanel-lovelace-ui.0 2026-04-19 00:30:05.295 error [NsPanelWohnzimmer] Model missmatch! Config model is eu but panel send us-p. Check your config! nspanel-lovelace-ui.0 2026-04-19 00:30:05.295 info [NsPanelWohnzimmer] is online! javascript.0 2026-04-19 00:30:04.974 info script.js.nspanel-lovelace-ui_0.NsPanelWohnzimmer: Stopping script javascript.0 2026-04-19 00:30:04.739 info script.js.nspanel-lovelace-ui_0.NsPanelWohnzimmer: [ 'Panel for Topic: NsPanelWohnzimmer name: NsPanelWohnzimmer Script version 0.20.1 is correct!', 'done', '✅ Panel "08_D1_F9_A4_ED_44" reloaded with updated configuration.' ] nspanel-lovelace-ui.0 2026-04-19 00:30:04.737 info ✅ Panel "08_D1_F9_A4_ED_44" reloaded with updated configuration. admin.0 2026-04-19 00:30:03.883 info <== Disconnect system.user.admin from ::ffff:192.168.178.52 javascript admin.0 2026-04-19 00:30:03.883 info <== Disconnect system.user.admin from ::ffff:192.168.178.52 javascript nspanel-lovelace-ui.0 2026-04-19 00:30:03.341 info [NsPanelWohnzimmer] Setting panel to offline until first message! ical.0 2026-04-19 00:30:03.238 info processing URL: Google https://calendar.google.com/calendar/ical/mferber83%40gmail.com/private-54e18925919b923d77c7864d1eaab115/basic.ics ical.0 2026-04-19 00:30:02.297 info starting. Version 1.19.7 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 nspanel-lovelace-ui.0 2026-04-19 00:30:02.280 info [controller] Panel NsPanelWohnzimmer removed! nspanel-lovelace-ui.0 2026-04-19 00:30:01.963 warn [NsPanelWohnzimmer] is offline! nspanel-lovelace-ui.0 2026-04-19 00:30:01.957 info [NsPanelWohnzimmer] Goint offline because delete panel!Anaonsten läuft das erste Panel
Dein Panel sagt es wäre ein us-p keine Ahnung wie es darauf kommt. Was ist es denn?
Dann hast du es falsch in der initialisierung eingestellt - gehte auf nspanel initialisierung stelle klicke auf dem panel auf den stift stelle rechts oben us-p ein und klicke auf nspanel aktualisierung
Ich muß ja erstmal den standardfehler abklappern - das eine mal wo ich nicht ffrage ist es falsch initialisiert :D Bug ist notiert muß mal suchen - wo der fehler entsteht.
EDIT: gefunden
0.17.5 (2026-04-18)
- (ticaki) When the panel was restarted by the script, the model was set to ‘eu’
Gibt es die Möglichkeit bei diesem Alias die Schrittgröße kleiner zu machen ?
{ id: 'alias.0.NSPanel.TemperaturWassserSpeicher', name: 'TemperaturSpeicher', useValue: true, suffixName: '°C'}, -
Funktioniert, kann vielleicht noch mal jemand bei den Dimmern unterstützen oder gehen die einfach noch nicht?
Alles geht! Was nicht bedeutet, dass wir nichts vergessen haben :)
Dimmer sollte gehen um zu helfen brauche ich die Skriptzeile und ein Bild vom alias. Ich benutze den Devicemanager nicht, bin i.d.R. schneller fertig wenn ichs per Hand mache.
ist es eine cardGrid? (fontSize)
Zum Dimmer - kein Bild von den Orginalstates sondern aus dem alias ordner :)
Kann ich bestätigen - werde mal gucken wo das was fehlt
@michaelf
Es wäre möglich das das am TFT liegt, da kann ich dann jetzt nix dran machen.Bitte gib mir zu dem dimmer ein Bild aus dem alias.0 Ordner und die konfiguration aus dem Skript dazu.
