  4. Was bedeutet das ? rpi-resize-swap-file.
    6.4k
27 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • Michael SchmittM Offline
    Michael Schmitt
    erledigt, Fehler immer noch vorhanden
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberry
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:28:45 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-04-13 16:28:45 CEST
               Universal time: Mon 2026-04-13 14:28:45 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marvman67
    HOME=/home/marvman67
    GROUPS=marvman67 adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/marvman67
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.2G        1.3G         10M        560M        1.8G
    Swap:           2.1G          0B        2.1G
    Total:          6.1G        2.2G        3.5G
    Active iob-Instances:   20
             3795 M total memory
             2085 M used memory
             2146 M active memory
              225 M inactive memory
             1262 M free memory
               54 M buffer memory
              479 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 16:28:46 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
    Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.8 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.7 total,   1261.7 free,   2085.7 used,    535.0 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1710.0 avail Mem
    *** FAILED SERVICES ***
      UNIT                         LOAD   ACTIVE SUB    DESCRIPTION
    * rpi-resize-swap-file.service loaded failed failed rpi-resize-var-swap-service - resize swapfile
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.3M  750M   2% /run
    /dev/sda2      ext4      229G  7.1G  213G   4% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.9G  648K  1.9G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
    tmpfs          tmpfs     380M   12K  380M   1% /run/user/1000
    [Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Mon Apr 13 16:17:38 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    231M    /var/cache
    225M    /var/cache/apt
    187M    /var/lib
    145M    /var/lib/apt/lists
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    173M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    341M    /opt/iobroker/iobroker-data/
    181M    /opt/iobroker/iobroker-data/files
    116M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    44M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_15-49_objects.jsonl.gz
    4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_13-49_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2706986-if00
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 668)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : Raspberry                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Raspberry                                -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspberry                                -  enabled
    + system.adapter.deconz.0                 : deconz                : Raspberry                                -  enabled, port: 80
      system.adapter.devices.0                : devices               : Raspberry                                - disabled
    + system.adapter.email.0                  : email                 : Raspberry                                -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspberry                                -  enabled
    + system.adapter.history.0                : history               : Raspberry                                -  enabled
      system.adapter.ical.0                   : ical                  : Raspberry                                -  enabled
      system.adapter.iot.0                    : iot                   : Raspberry                                - disabled
    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
    + system.adapter.matter.0                 : matter                : Raspberry                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspberry                                -  enabled
    + system.adapter.simple-api.0             : simple-api            : Raspberry                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : Raspberry                                -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
    + system.adapter.telegram.0               : telegram              : Raspberry                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Raspberry                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
    + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "deconz"       : 1.7.4    , installed 1.7.4
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.6    , installed 1.0.0
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        5969
    States:         4496
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://phoscon.de/apt/deconz generic InRelease
    Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       2016       630/deCONZ
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2279       1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8467       1212/sshd: /usr/sbi
    tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       10155      1689/io.socketio.0
    tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       9364       630/deCONZ
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6816       1200/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7607       1200/iobroker.js-co
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1217       1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8469       1212/sshd: /usr/sbi
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6930       1280/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10514      1717/io.web.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10485      1673/io.simple-api.
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9786       1288/io.admin.1
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4614       1/init
    udp        0      0 0.0.0.0:45527           0.0.0.0:*                           101        1876       626/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10541      1657/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10176      1657/io.matter.0
    udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10093      1572/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        1874       626/avahi-daemon: r
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       10175      1657/io.matter.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11887      2053/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       9386       630/deCONZ
    udp6       0      0 :::111                  :::*                                0          2280       1/init
    udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          8508       702/NetworkManager
    udp6       0      0 :::5353                 :::*                                1001       10542      1657/io.matter.0
    udp6       0      0 :::5353                 :::*                                1001       10179      1657/io.matter.0
    udp6       0      0 :::5353                 :::*                                101        1875       626/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1001       10174      1657/io.matter.0
    udp6       0      0 :::40645                :::*                                101        1877       626/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       11890      2053/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       11889      2053/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       11888      2053/io.deconz.0
      Michael Schmitt
      marvman67@Raspberry:~ $ systemctl status rpi-resize-swap-file.service
      × rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile
           Loaded: loaded (/usr/lib/systemd/system/rpi-resize-swap-file.service; static)
           Active: failed (Result: exit-code) since Mon 2026-04-13 16:28:45 CEST; 5min ago
       Invocation: ace4635917fb4b07abbc341357411796
          Process: 2356 ExecStart=/usr/lib/rpi-swap/bin/rpi-resize-swap-file (code=exited, status=1/FAILURE)
         Main PID: 2356 (code=exited, status=1/FAILURE)
              CPU: 219ms
      Apr 13 16:28:45 Raspberry systemd[1]: Starting rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile...
      Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: swaplabel: no device specified
      Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: Try 'swaplabel --help' for more information.
      Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2380]: mkswap: error: /var/swap is mounted; will not make swapspace
      Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Main process exited, code=exited, status=1/FAILURE
      Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Failed with result 'exit-code'.
      Apr 13 16:28:45 Raspberry systemd[1]: Failed to start rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile.
        Michael Schmitt
        schrieb am zuletzt editiert von Michael Schmitt
        ich hab nun folgendes gemacht.
        sudo nano /etc/rpi/swap.conf
        und dort das eingetragen
        FixedSizeMiB=2048
        dann
        sudo swapoff /var/swap
        sudo systemctl restart rpi-swap.service
        ceck mit swapon --show
        NAME TYPE SIZE USED PRIO
        /var/swap file 2G 0B -2
        so wie ich im Internet gelesen habe kontrolliert das "rpi-resize-swap-file.service" nur ob die swap Größe richtig ist und das ist sie ja nun.
        Dmit nun die Fehlermeldung nicht mehr kommt habe ich den Dienst deaktiviert.
        sudo systemctl mask rpi-resize-swap-file.service
        systemctl status var-swap.swap
        marvman67@Raspberry:~ $ systemctl status var-swap.swap
        ● var-swap.swap - /var/swap
             Loaded: loaded (/etc/fstab; generated)
             Active: active since Mon 2026-04-13 17:07:09 CEST; 27min ago
         Invocation: 4e3dc8887e5c4b70b12060987cb2294e
               What: /var/swap
               Docs: man:fstab(5)
                     man:systemd-fstab-generator(8)
              Tasks: 0 (limit: 3924)
                CPU: 33ms
             CGroup: /system.slice/var-swap.swap
        Apr 13 17:07:09 Raspberry systemd[1]: Activating swap var-swap.swap - /var/swap...
        Apr 13 17:07:09 Raspberry systemd[1]: Activated swap var-swap.swap - /var/swap.
        aktuelles iob diag nach reboot
        ```bash
        Script v.2026-01-31
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
         17:36:16 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
        CPU threads: 4
        Current issues:
                       Local time: Mon 2026-04-13 17:36:17 CEST
                   Universal time: Mon 2026-04-13 15:36:17 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        marvman67
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            4.0G        2.3G        944M         12M        853M        1.7G
        Swap:           2.1G          0B        2.1G
        Total:          6.1G        2.3G        3.1G
                 3795 M total memory
                 2179 M used memory
                 2139 M active memory
                  544 M inactive memory
                  901 M free memory
                   76 M buffer memory
                  737 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        top - 17:36:17 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
        Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  4.4 us,  0.0 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.7 total,    901.0 free,   2179.5 used,    814.0 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1616.2 avail Mem
        0 loaded units listed.
        *** FILESYSTEM ***
        tmpfs          tmpfs     1.9G  2.9M  1.9G   1% /tmp
        [Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
        [Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
        [Mon Apr 13 17:07:27 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
        /var:
        2.5G    /var/
        231M    /var/cache
        225M    /var/cache/apt
        187M    /var/lib
        349M    /opt/iobroker/iobroker-data/
        46M     /opt/iobroker/iobroker-data/objects.jsonl
        6.5M    /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 1718)
        admin:          7.7.22
        javascript:     9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects:        5969
        States:         4431
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8398       1093/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8403       1093/iobroker.js-co
        tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7319       589/deCONZ
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4221       1/init
        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6036       589/deCONZ
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9381       1105/sshd: /usr/sbi
        tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       8917       1532/io.socketio.0
        tcp6       0      0 :::111                  :::*                    LISTEN      0          302        1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          9383       1105/sshd: /usr/sbi
        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9670       1159/io.admin.1
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6879       1151/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8945       1572/io.web.0
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10403      1520/io.simple-api.
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1442       1/init
        udp        0      0 0.0.0.0:57509           0.0.0.0:*                           101        6249       585/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8953       1508/io.matter.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8056       1508/io.matter.0
        udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10337      1419/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6247       585/avahi-daemon: r
        udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       8055       1508/io.matter.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10729      1781/io.deconz.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7333       589/deCONZ
        udp6       0      0 :::111                  :::*                                0          1443       1/init
        udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6802       780/NetworkManager
        udp6       0      0 :::38101                :::*                                101        6250       585/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                1001       8954       1508/io.matter.0
        udp6       0      0 :::5353                 :::*                                1001       8059       1508/io.matter.0
        udp6       0      0 :::5353                 :::*                                101        6248       585/avahi-daemon: r
        udp6       0      0 :::5540                 :::*                                1001       8054       1508/io.matter.0
        udp6       0      0 :::1900                 :::*                                1001       10732      1781/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       10731      1781/io.deconz.0
        udp6       0      0 :::1900                 :::*                                1001       10730      1781/io.deconz.0
        2026-04-13 17:13:05.053  - info: host.Raspberry stopInstance system.adapter.deconz.0 (force=false, process=true)
        2026-04-13 17:13:05.061  - info: deconz.0 (1371) Got terminate signal TERMINATE_YOURSELF
        2026-04-13 17:13:05.071  - info: deconz.0 (1371) cleaned everything up...
        2026-04-13 17:13:05.072  - info: deconz.0 (1371) terminating
        2026-04-13 17:13:05.073  - info: deconz.0 (1371) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2026-04-13 17:13:05.176  - info: host.Raspberry stopInstance system.adapter.deconz.0 send kill signal
        2026-04-13 17:13:05.577  - info: deconz.0 (1371) terminating
        2026-04-13 17:13:05.792  - info: host.Raspberry instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2026-04-13 17:13:09.725  - info: host.Raspberry instance system.adapter.deconz.0 in version "1.7.4" started with pid 1781
        2026-04-13 17:13:12.430  - info: deconz.0 (1781) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v22.22.2, js-controller: 7.0.7
        2026-04-13 17:13:12.588  - info: deconz.0 (1781) deConz Version: 2.32.5; API version: 1.16.0
        2026-04-13 17:13:34.462  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.29
        2026-04-13 17:13:35.843  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
        Wert: false
        Adapter NICHT erreichbar
        2026-04-13 17:13:36.889  - info: javascript.0 (1257) script.js.common.Wichtig.Sensor_erreichbar: telegram[Michael]: Kanal ID: deconz.0.Sensors.146
        Name: Bewegungsmelder Flur 4 Tür SZ reachable
        Wert: true
        Sensor ist wieder erreichbar
        2026-04-13 17:13:57.519  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
        Wert: true
        Adapter ist wieder erreichbar
        2026-04-13 17:20:12.613  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.29 iqontrol.0
        2026-04-13 17:30:00.083  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 3169
        2026-04-13 17:30:09.714  - info: host.Raspberry instance system.adapter.ical.0 having pid 3169 terminated with code 0 (NO_ERROR)
        ich hoffe ich hab nicht mehr zerstört, als in Ordnung gebracht :)
        • Michael SchmittM Michael Schmitt
          FixedSizeMiB=2048
          dann
                 What: /var/swap
                 Docs: man:fstab(5)
                  CPU: 33ms
          ```bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          marvman67
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   3795 M total memory
                   2179 M used memory
                    901 M free memory
                     76 M buffer memory
                    737 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          2.5G    /var/
          231M    /var/cache
          225M    /var/cache/apt
          187M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5969
          States:         4431
          Wert: false
          Wert: true
          Wert: true
          @Michael-Schmitt
          Hattest du da in der Vergangenheit selber schon was umgestellt?
          Denn die Voreinstellung für ein frisches Debian 13 'Trixie' ist
          536MB:
          *** MEMORY ***
          Mem:            8.2G        4.4G        2.8G         11M        1.1G        3.8G
          Swap:           536M          0B        536M
          Total:          8.7G        4.4G        3.3G
          Active iob-Instances:   37
                   7819 M total memory
                   4201 M used memory
                   4218 M active memory
                    631 M inactive memory
                   2673 M free memory
                    105 M buffer memory
                    948 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          Und auf meinem System gibt es den Service auch erst gar nicht:
          echad@chet:~ $  systemctl status rpi-resize-swap-file.service
          Unit rpi-resize-swap-file.service could not be found.
          echad@chet:~ $
            Michael Schmitt
            Ich hatte mal die swappiness auf 40 gesetzt aber mehr nicht und wenn ich mich recht erinnere dann aber nochmal komplett neu aufgesetzt und wieder nur swappines auf 40.
              @Michael-Schmitt
              Irgendwas ist jedenfalls auf deiner Kiste grundsätzlich anders als auf meiner...
                Michael Schmitt
                ich werd das jetzt mal so lassen und beobachten, wenn es Probleme gibt mach ich einfach alles neu ;)
                  Michael Schmitt
                  so ich hab jetzt alles neu gemacht und hab immer noch 2,1gb swap keine Ahnung warum. Kann das an meiner SSD (240gb) liegen ? Von swap hab ich die Finger komplett gelassen.
                  Das einzigste was nicht geht, der RPI2 Adapter lies sich nicht wiederherstellen (v3.0.2) Auch nach einem deinstallieren bekomme ich den nicht wieder.
                  host.Raspberry
                  	2026-04-15 16:48:36.071	info	iobroker exit 25
                  host.Raspberry
                  	2026-04-15 16:48:34.955	error	iobroker host.Raspberry Cannot install iobroker.rpi2@3.0.2: 1
                  host.Raspberry
                  	2026-04-15 16:48:34.953	error	iobroker npm error code 1npm error path /opt/iobroker/node_modules/iobroker.rpi2npm error command failednpm error command sh -c bash ./preinstall-check.shnpm error Checking package: libgpiod-dev >= 2.2npm error libgpiod-dev is not installednpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-15T14_48_28_153Z-debug-0.log
                  host.Raspberry
                  	2026-04-15 16:48:27.944	info	iobroker Installing iobroker.rpi2@3.0.2... (System call)
                  host.Raspberry
                  	2026-04-15 16:48:27.943	info	iobroker NPM version: 10.9.7
                  host.Raspberry
                  	2026-04-15 16:48:24.047	info	iobroker add rpi2 --host Raspberry
                  hier ein iob diag
                  ```bash
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                   16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
                  CPU threads: 4
                  Current issues:
                                 Local time: Wed 2026-04-15 16:42:58 CEST
                             Universal time: Wed 2026-04-15 14:42:58 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  marvman67
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Mem:            4.0G        2.0G        1.1G         12M        909M        1.9G
                  Swap:           2.1G          0B        2.1G
                  Total:          6.1G        2.0G        3.3G
                  Active iob-Instances:   18
                           3795 M total memory
                           1947 M used memory
                           1907 M active memory
                            534 M inactive memory
                           1080 M free memory
                             96 M buffer memory
                            770 M swap cache
                           2047 M total swap
                              0 M used swap
                           2047 M free swap
                  top - 16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
                  Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  1.9 us,  3.7 sy,  0.0 ni, 92.6 id,  1.9 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3795.7 total,   1079.0 free,   1947.7 used,    867.8 buff/cache
                  MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1848.0 avail Mem
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     760M  9.1M  751M   2% /run
                  /dev/sda2      ext4      220G  6.6G  204G   4% /
                  /dev/sda1      vfat      505M   74M  432M  15% /boot/firmware
                  tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
                  [Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                  [Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): mounted filesystem 687fa5d6-7e12-409f-8631-6b47ecc831af ro with ordered data mode. Quota mode: none.
                  [Wed Apr 15 16:23:09 2026] EXT4-fs (sda2): re-mounted 687fa5d6-7e12-409f-8631-6b47ecc831af r/w.
                  /var:
                  2.5G    /var/
                  231M    /var/cache
                  225M    /var/cache/apt
                  186M    /var/lib
                  146M    /var/lib/apt
                  5.8M    /opt/iobroker/backups/
                  202M    /opt/iobroker/iobroker-data/
                  180M    /opt/iobroker/iobroker-data/files
                  20M     /opt/iobroker/iobroker-data/objects.jsonl
                  8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
                  4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                  3.7M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/assets/index-DS28Nms8.js
                  USB-Devices by-id:
                  /usr/bin/npm            10.9.7
                  /usr/bin/npx            10.9.7
                  nodejs:
                    Version table:
                       20.19.2+dfsg-1 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 184)
                  admin:          7.7.22
                  javascript:     9.0.18
                  Adapter State
                    system.adapter.cloud.0                  : cloud                 : Raspberry                                - disabled
                  + instance is alive
                  Objects and States
                  Objects:        5922
                  States:         4448
                  tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       18917      2872/io.socketio.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7089       958/sshd: /usr/sbin
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5180       1/init
                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6065       625/deCONZ
                  tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7106       625/deCONZ
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17701      2536/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17696      2536/iobroker.js-co
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          7091       958/sshd: /usr/sbin
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          4095       1/init
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17867      2567/io.admin.1
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19806      2860/io.simple-api.
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18942      2900/io.web.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18547      2555/io.admin.0
                  udp        0      0 0.0.0.0:33244           0.0.0.0:*                           101        4790       619/avahi-daemon: r
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18957      2848/io.matter.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17133      2848/io.matter.0
                  udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       19780      2792/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4788       619/avahi-daemon: r
                  udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       17132      2848/io.matter.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18174      2744/io.deconz.0
                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       8239       625/deCONZ
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4241       1/init
                  udp6       0      0 fe80::ac82:ba7c:acc:546 :::*                                0          8254       693/NetworkManager
                  udp6       0      0 :::5353                 :::*                                1001       18958      2848/io.matter.0
                  udp6       0      0 :::5353                 :::*                                1001       17136      2848/io.matter.0
                  udp6       0      0 :::5353                 :::*                                101        4789       619/avahi-daemon: r
                  udp6       0      0 :::5540                 :::*                                1001       17131      2848/io.matter.0
                  udp6       0      0 :::1900                 :::*                                1001       18177      2744/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       18176      2744/io.deconz.0
                  udp6       0      0 :::1900                 :::*                                1001       18175      2744/io.deconz.0
                  udp6       0      0 :::34850                :::*                                101        4791       619/avahi-daemon: r
                  udp6       0      0 :::111                  :::*                                0          4242       1/init
                  2026-04-15 16:41:19.111  - info: matter.0 (2848) Preparing bridged device 12dac884-896a-4955-8fac-85635d860d45 "Bad Spiegel 3" for bridge
                  2026-04-15 16:41:19.269  - info: matter.0 (2848) Preparing bridged device c0f93364-0f42-4f41-90a9-cc3dce4d22c2 "Bad Spiegel 4" for bridge
                  2026-04-15 16:41:19.457  - info: matter.0 (2848) Preparing bridged device 82a95d66-641f-45ed-a070-6dd88a067ca0 "Computerzimmer Decke 1" for bridge
                  2026-04-15 16:41:19.585  - info: matter.0 (2848) Preparing bridged device 270b7502-23c8-4ab7-a490-fe11d20a48d0 "Computerzimmer Decke 2" for bridge
                  2026-04-15 16:41:19.706  - info: matter.0 (2848) Preparing bridged device 170ac091-af8a-45d2-884a-ec31345186ad "Flurlicht Telefon" for bridge
                  2026-04-15 16:41:19.853  - info: matter.0 (2848) Preparing bridged device ca7e0c6c-01ec-4025-8887-ab695a46d509 "Küche 1" for bridge
                  2026-04-15 16:41:19.970  - info: matter.0 (2848) Preparing bridged device 980e21e5-de18-457d-a0ff-8d74d0ecb22b "Küche 2" for bridge
                  2026-04-15 16:41:20.106  - info: matter.0 (2848) Preparing bridged device 1ce9fd49-2428-4b81-8262-4fffcb8ff0dc "Küche 3" for bridge
                  2026-04-15 16:41:20.233  - info: matter.0 (2848) Preparing bridged device 822a73fa-c98d-4861-ae74-ef74f322098e "Küche 4" for bridge
                  2026-04-15 16:41:20.347  - info: matter.0 (2848) Preparing bridged device 6f4b50d4-b9d6-45c2-b70e-1449fe45ff82 "Schlafzimmer Decke" for bridge
                  2026-04-15 16:41:20.484  - info: matter.0 (2848) Preparing bridged device bf9aa093-0a0f-49c4-a027-2908578847fd "Schlafzimmer Nachttischlampe" for bridge
                  2026-04-15 16:41:20.602  - info: matter.0 (2848) Preparing bridged device 71b3bc3e-2d8a-42d7-86d8-8c9caa8261ec "WZ Decke hinten" for bridge
                  2026-04-15 16:41:20.736  - info: matter.0 (2848) Preparing bridged device 70d546c5-da32-47e9-ae9a-93c5c2766f2d "WZ Decke vorne" for bridge
                  2026-04-15 16:41:20.849  - info: matter.0 (2848) Preparing bridged device a385531c-a983-4c83-827b-12924d8f1cfe "WZ Stehlampe 1" for bridge
                  2026-04-15 16:41:21.032  - info: matter.0 (2848) Preparing bridged device c93667f3-9f91-4f23-bf3b-965041c64cf5 "WZ Stehlampe 2" for bridge
                  2026-04-15 16:41:21.212  - info: matter.0 (2848) 2026-04-15 16:41:21.212 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c going online
                  2026-04-15 16:41:21.293  - info: matter.0 (2848) 2026-04-15 16:41:21.293 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c is online
                  2026-04-15 16:41:55.635  - info: alexa2.0 (2732) Using cached smart home devices list from Wed Apr 15 2026 16:25:23 GMT+0200 (Central European Summer Time)
                  2026-04-15 16:41:58.046  - info: alexa2.0 (2732) No smart home devices to query
                  2026-04-15 16:41:59.278  - info: alexa2.0 (2732) Subscribing to states...
                  2026-04-15 16:41:59.955  - info: javascript.0 (2662) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: matter.0 is connected
                  Wert: true
                  2026-04-15 16:42:01.063  - info: alexa2.0 (2732) Alexa-Push-Connection (macDms = true) established. Disable Polling
                  2026-04-15 16:42:15.838  - info: alexa2.0 (2732) Initialization Done ...
                  wie komm ich wieder zum RPI2 Adapter ?
                    host.Raspberry
                    host.Raspberry
                    host.Raspberry
                    host.Raspberry
                    host.Raspberry
                    host.Raspberry
                    hier ein iob diag
                    ```bash
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    OS is similar to:
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    marvman67
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:           2.1G          0B        2.1G
                             3795 M total memory
                             1947 M used memory
                             1080 M free memory
                               96 M buffer memory
                              770 M swap cache
                             2047 M total swap
                                0 M used swap
                             2047 M free swap
                    *** FILESYSTEM ***
                    /var:
                    2.5G    /var/
                    231M    /var/cache
                    225M    /var/cache/apt
                    186M    /var/lib
                    146M    /var/lib/apt
                    USB-Devices by-id:
                    /usr/bin/npm            10.9.7
                    /usr/bin/npx            10.9.7
                    nodejs:
                      Version table:
                         20.19.2+dfsg-1 500
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.7.22
                    javascript:     9.0.18
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        5922
                    States:         4448
                    Wert: true
                    @Michael-Schmitt sagte:
                    Mit welchen Meldungen bekommst du den denn nicht installiert?
                      Michael Schmitt
                      host.Raspberry
                      host.Raspberry
                      host.Raspberry
                      host.Raspberry
                      host.Raspberry
                      host.Raspberry
                      Edit:
                      iobroker libgpiod-dev is not installed ?????
                        host.Raspberry
                        host.Raspberry
                        host.Raspberry
                        host.Raspberry
                        host.Raspberry
                        host.Raspberry
                        Edit:
                        Also nachinstallieren:
                        sudo apt update
                        sudo apt install libgpiod-dev
                          Michael Schmitt
                          Dankeeee jetzt ist alles da.
                          Irgend eine Ahnung warum mein Swap selbst nach einer Neuinstallation so groß ist ?
                            @Michael-Schmitt
                            Nein. Könnte aber sein, dass die Größe bei aktuellen Neuinstallationen anders als bisher berechnet werden.
                              So groß oder schon so stark in Gebrauch?
                                Michael Schmitt
                                Also ich denke nicht das der stark in Gebrauch ist, so viel hab ich nicht. Nur iobroker und Deconz.
                                Was mir auch gefallen ist jetzt steht da
                                marvman67@Raspberry:~ $ swapon --show
                                /dev/zram0 partition   2G 3.3M  100
                                davor war das
                                /var/swap file 2G 5.8M -2
                                wie gesagt hab ich nur komplett Neuinstalliert und Backups drauf gemacht.
                                  mir ist diese Meldung bei einem iob diag aufgefallen. Was bedeutet das und was ist zu tun ?
                                  iob diag
                                  Script v.2026-01-31
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   15:07:25 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Mon 2026-04-13 15:07:25 CEST
                                             Universal time: Mon 2026-04-13 13:07:25 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  marvman67
                                  iobroker
                                  HOME=/home/iobroker
                                  Display-Manager:
                                  Desktop:
                                  Session:                tty
                                  *** MEMORY ***
                                  Mem:            4.0G        2.6G        795M        8.9M        712M        1.4G
                                  Swap:           2.1G        4.2M        2.1G
                                  Total:          6.1G        2.6G        2.9G
                                           3795 M total memory
                                           2452 M used memory
                                           1513 M active memory
                                           1309 M inactive memory
                                            758 M free memory
                                             56 M buffer memory
                                            622 M swap cache
                                           2047 M total swap
                                              4 M used swap
                                           2043 M free swap
                                  top - 15:07:26 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
                                  Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us,  2.3 sy,  0.0 ni, 97.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3795.7 total,    758.5 free,   2452.8 used,    679.9 buff/cache
                                  MiB Swap:   2048.0 total,   2044.0 free,      4.0 used.   1342.9 avail Mem
                                  *** FILESYSTEM ***
                                  [Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                                  [Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
                                  [Sun Apr 12 11:49:00 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
                                  /var:
                                  2.5G    /var/
                                  231M    /var/cache
                                  225M    /var/cache/apt
                                  187M    /var/lib
                                  342M    /opt/iobroker/iobroker-data/
                                  43M     /opt/iobroker/iobroker-data/objects.jsonl
                                  4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_11-49_objects.jsonl.gz
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.9.7
                                  /usr/bin/npx            10.9.7
                                  nodejs:
                                    Version table:
                                       20.19.2+dfsg-1 500
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 98290)
                                  admin:          7.7.22
                                  javascript:     9.0.18
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        5969
                                  States:         4431
                                  Pending systemupdates: 4
                                  tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       6655       632/deCONZ
                                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       5895       632/deCONZ
                                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4211       1/init
                                  tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       11463      1697/io.socketio.0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8540       1216/sshd: /usr/sbi
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6144       1203/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6139       1203/iobroker.js-co
                                  tcp6       0      0 :::111                  :::*                    LISTEN      0          901        1/init
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          8542       1216/sshd: /usr/sbi
                                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9906       1685/io.simple-api.
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12294      1725/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8038       1283/io.admin.0
                                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9052       1291/io.admin.1
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11479      1665/io.matter.0
                                  udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       7125       1559/io.tr-064.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4945       628/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       11478      1665/io.matter.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15004      2525/io.deconz.0
                                  udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6676       632/deCONZ
                                  udp        0      0 0.0.0.0:34805           0.0.0.0:*                           101        4947       628/avahi-daemon: r
                                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2652       1/init
                                  udp6       0      0 :::5353                 :::*                                1001       11482      1665/io.matter.0
                                  udp6       0      0 :::5353                 :::*                                101        4946       628/avahi-daemon: r
                                  udp6       0      0 :::5540                 :::*                                1001       11477      1665/io.matter.0
                                  udp6       0      0 :::1900                 :::*                                1001       15007      2525/io.deconz.0
                                  udp6       0      0 :::1900                 :::*                                1001       15006      2525/io.deconz.0
                                  udp6       0      0 :::1900                 :::*                                1001       15005      2525/io.deconz.0
                                  udp6       0      0 :::111                  :::*                                0          2653       1/init
                                  udp6       0      0 :::57875                :::*                                101        4948       628/avahi-daemon: r
                                  udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6109       704/NetworkManager
                                  2026-04-13 09:30:00.066  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 58968
                                  2026-04-13 09:30:09.853  - info: host.Raspberry instance system.adapter.ical.0 having pid 58968 terminated with code 0 (NO_ERROR)
                                  2026-04-13 10:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 61569
                                  2026-04-13 10:30:09.776  - info: host.Raspberry instance system.adapter.ical.0 having pid 61569 terminated with code 0 (NO_ERROR)
                                  2026-04-13 11:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 64157
                                  2026-04-13 11:30:09.934  - info: host.Raspberry instance system.adapter.ical.0 having pid 64157 terminated with code 0 (NO_ERROR)
                                  2026-04-13 11:49:35.045  - info: admin.0 (1283) Adapter rating updated
                                  2026-04-13 11:49:42.144  - info: admin.1 (1291) Adapter rating updated
                                  2026-04-13 12:30:00.116  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 66781
                                  2026-04-13 12:30:09.734  - info: host.Raspberry instance system.adapter.ical.0 having pid 66781 terminated with code 0 (NO_ERROR)
                                  2026-04-13 12:55:43.589  - info: javascript.0 (1382) script.js.common.Anwesendheitscheck.Marvin_PC_AN_AUS_Wlan: telegram[Michael]: 12:55 Uhr. PC von Marvin wurde ausgeschalten.
                                  2026-04-13 13:00:22.692  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
                                  2026-04-13 13:00:27.064  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
                                  2026-04-13 13:03:00.018  - info: javascript.0 (1382) script.js.common.Wichtig.24Std_Sensor_Zeitstempel_nicht_aktualisiert: telegram[Michael]: 24 Stunden keine Änderung bei Wohnzimmer_Lichtschalter, SZ_TV_Schalter_Steckdose, Bad Spiegel, Rauchmelder_Schlafzimmer, Rauchmelder_Flur, Rauchmelder_WZ, CO_Sensor_Küche, . Eventuell ist die Batterie leer?
                                  2026-04-13 13:30:00.061  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 69380
                                  2026-04-13 13:30:09.633  - info: host.Raspberry instance system.adapter.ical.0 having pid 69380 terminated with code 0 (NO_ERROR)
                                  2026-04-13 13:59:09.505  - info: admin.0 (1283) Request actual repository...
                                  2026-04-13 13:59:10.563  - info: host.Raspberry Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                  2026-04-13 13:59:21.691  - info: admin.0 (1283) Repository received successfully.
                                  2026-04-13 14:30:00.043  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 71972
                                  2026-04-13 14:30:10.418  - warn: ical.0 (71972) get state error: Connection is closed.
                                  2026-04-13 14:30:10.503  - info: host.Raspberry instance system.adapter.ical.0 having pid 71972 terminated with code 0 (NO_ERROR)
                                  2026-04-13 14:39:38.092  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
                                  2026-04-13 14:39:44.177  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
                                  2026-04-13 14:51:30.503  - info: admin.0 (1283) ==> Connected system.user.admin from ::ffff:192.168.178.29
                                  Gruß Michael
                                  Da hatten ich wohl das hier noch im Kopf
                                    Michael Schmitt
                                    aber warum ist es nun nach der Neuinstallation "zram" und nicht swap
                                      @Michael-Schmitt
                                      Offenbar neue default-Einstellungen. Ist mir bis dato gar nicht aufgefallen, mein letzte Woche frisch aufgesetzter Testpi läuft jetzt auch so:
                                      *** MEMORY ***
                                      Mem:            4.0G        751M        2.4G         12M        891M        3.2G
                                      Swap:           2.1G          0B        2.1G
                                      Total:          6.1G        751M        4.6G
                                      thomas@testpi:~ $ swapon --show
                                      /dev/zram0 partition   2G   0B  100
                                      thomas@testpi:~ $
                                        Michael Schmitt
                                        Na dann liegt es mal nicht an mir, das ist schonmal beruhigend. Was ich nun so im Internet lesen konnte soll es sinnvoll sein swap trotzdem zum aktivieren. Da zram ja im Ram liegt (komprimiert) und man damit weniger Ram hat. So soll es gut sein trotzdem swap zu aktivieren. Damit der Raspi bei Lastspitzen auf die 2.1gb zugreifen kann. Ist dem so ?
                                          @Michael-Schmitt
                                          rpi-swap: Newer images (Trixie) use the rpi-swap service to manage both ZRAM and a reduced-size fallback swap file.
                                          Wird also schon gemacht.
                                          Edit: Die Konfiguration steht in der
                                          cat /etc/rpi/swap.conf
                                          drin.
                                          Edit 2: Und mit
                                          zramctl
                                          kann man die Verteilung prüfen .
