  4. Was bedeutet das ? rpi-resize-swap-file.
    6.4k
27 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • Michael SchmittM Michael Schmitt
    mir ist diese Meldung bei einem iob diag aufgefallen. Was bedeutet das und was ist zu tun ?
      UNIT                         LOAD   ACTIVE SUB    DESCRIPTION
    * rpi-resize-swap-file.service loaded failed failed rpi-resize-var-swap-service - resize swapfile
    iob diag
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberry
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     15:07:25 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-04-13 15:07:25 CEST
               Universal time: Mon 2026-04-13 13:07:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marvman67
    HOME=/home/marvman67
    GROUPS=marvman67 adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/marvman67
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.6G        795M        8.9M        712M        1.4G
    Swap:           2.1G        4.2M        2.1G
    Total:          6.1G        2.6G        2.9G
    Active iob-Instances:   20
             3795 M total memory
             2452 M used memory
             1513 M active memory
             1309 M inactive memory
              758 M free memory
               56 M buffer memory
              622 M swap cache
             2047 M total swap
                4 M used swap
             2043 M free swap
    top - 15:07:26 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
    Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  2.3 sy,  0.0 ni, 97.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.7 total,    758.5 free,   2452.8 used,    679.9 buff/cache
    MiB Swap:   2048.0 total,   2044.0 free,      4.0 used.   1342.9 avail Mem
    *** FAILED SERVICES ***
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.3M  750M   2% /run
    /dev/sda2      ext4      229G  7.1G  213G   4% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.9G  2.9M  1.9G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
    tmpfs          tmpfs     380M   12K  380M   1% /run/user/1000
    [Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Sun Apr 12 11:49:00 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    231M    /var/cache
    225M    /var/cache/apt
    187M    /var/lib
    145M    /var/lib/apt/lists
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    173M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    342M    /opt/iobroker/iobroker-data/
    181M    /opt/iobroker/iobroker-data/files
    116M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_13-49_objects.jsonl.gz
    4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_11-49_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2706986-if00
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 98290)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : Raspberry                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Raspberry                                -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspberry                                -  enabled
    + system.adapter.deconz.0                 : deconz                : Raspberry                                -  enabled, port: 80
      system.adapter.devices.0                : devices               : Raspberry                                - disabled
    + system.adapter.email.0                  : email                 : Raspberry                                -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspberry                                -  enabled
    + system.adapter.history.0                : history               : Raspberry                                -  enabled
      system.adapter.ical.0                   : ical                  : Raspberry                                -  enabled
      system.adapter.iot.0                    : iot                   : Raspberry                                - disabled
    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
    + system.adapter.matter.0                 : matter                : Raspberry                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspberry                                -  enabled
    + system.adapter.simple-api.0             : simple-api            : Raspberry                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : Raspberry                                -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
    + system.adapter.telegram.0               : telegram              : Raspberry                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Raspberry                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
    + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "deconz"       : 1.7.4    , installed 1.7.4
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.6    , installed 1.0.0
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        5969
    States:         4431
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://phoscon.de/apt/deconz generic InRelease
    Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       6655       632/deCONZ
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       5895       632/deCONZ
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4211       1/init
    tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       11463      1697/io.socketio.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8540       1216/sshd: /usr/sbi
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6144       1203/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6139       1203/iobroker.js-co
    tcp6       0      0 :::111                  :::*                    LISTEN      0          901        1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8542       1216/sshd: /usr/sbi
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9906       1685/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12294      1725/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8038       1283/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9052       1291/io.admin.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11479      1665/io.matter.0
    udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       7125       1559/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4945       628/avahi-daemon: r
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       11478      1665/io.matter.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15004      2525/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6676       632/deCONZ
    udp        0      0 0.0.0.0:34805           0.0.0.0:*                           101        4947       628/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2652       1/init
    udp6       0      0 :::5353                 :::*                                1001       11482      1665/io.matter.0
    udp6       0      0 :::5353                 :::*                                101        4946       628/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1001       11477      1665/io.matter.0
    udp6       0      0 :::1900                 :::*                                1001       15007      2525/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       15006      2525/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       15005      2525/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          2653       1/init
    udp6       0      0 :::57875                :::*                                101        4948       628/avahi-daemon: r
    udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6109       704/NetworkManager
    2026-04-13 09:30:00.066  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 58968
    2026-04-13 09:30:09.853  - info: host.Raspberry instance system.adapter.ical.0 having pid 58968 terminated with code 0 (NO_ERROR)
    2026-04-13 10:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 61569
    2026-04-13 10:30:09.776  - info: host.Raspberry instance system.adapter.ical.0 having pid 61569 terminated with code 0 (NO_ERROR)
    2026-04-13 11:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 64157
    2026-04-13 11:30:09.934  - info: host.Raspberry instance system.adapter.ical.0 having pid 64157 terminated with code 0 (NO_ERROR)
    2026-04-13 11:49:35.045  - info: admin.0 (1283) Adapter rating updated
    2026-04-13 11:49:42.144  - info: admin.1 (1291) Adapter rating updated
    2026-04-13 12:30:00.116  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 66781
    2026-04-13 12:30:09.734  - info: host.Raspberry instance system.adapter.ical.0 having pid 66781 terminated with code 0 (NO_ERROR)
    2026-04-13 12:55:43.589  - info: javascript.0 (1382) script.js.common.Anwesendheitscheck.Marvin_PC_AN_AUS_Wlan: telegram[Michael]: 12:55 Uhr. PC von Marvin wurde ausgeschalten.
    2026-04-13 13:00:22.692  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
    2026-04-13 13:00:27.064  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
    2026-04-13 13:03:00.018  - info: javascript.0 (1382) script.js.common.Wichtig.24Std_Sensor_Zeitstempel_nicht_aktualisiert: telegram[Michael]: 24 Stunden keine Änderung bei Wohnzimmer_Lichtschalter, SZ_TV_Schalter_Steckdose, Bad Spiegel, Rauchmelder_Schlafzimmer, Rauchmelder_Flur, Rauchmelder_WZ, CO_Sensor_Küche, . Eventuell ist die Batterie leer?
    2026-04-13 13:30:00.061  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 69380
    2026-04-13 13:30:09.633  - info: host.Raspberry instance system.adapter.ical.0 having pid 69380 terminated with code 0 (NO_ERROR)
    2026-04-13 13:59:09.505  - info: admin.0 (1283) Request actual repository...
    2026-04-13 13:59:10.563  - info: host.Raspberry Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2026-04-13 13:59:21.691  - info: admin.0 (1283) Repository received successfully.
    2026-04-13 14:30:00.043  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 71972
    2026-04-13 14:30:10.418  - warn: ical.0 (71972) get state error: Connection is closed.
    2026-04-13 14:30:10.503  - info: host.Raspberry instance system.adapter.ical.0 having pid 71972 terminated with code 0 (NO_ERROR)
    2026-04-13 14:39:38.092  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
    2026-04-13 14:39:44.177  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
    2026-04-13 14:51:30.503  - info: admin.0 (1283) ==> Connected system.user.admin from ::ffff:192.168.178.29
    Gruß Michael
    @Michael-Schmitt
    Schau mal per
    systemctl status rpi-resize-swap-file.service
    nach den Details.
    Und spiel die vier Updates ein.
    • Michael SchmittM Offline
      Michael Schmitt
      schrieb am zuletzt editiert von Michael Schmitt
      marvman67@Raspberry:~ $ systemctl status rpi-resize-swap-file.service
      × rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile
           Loaded: loaded (/usr/lib/systemd/system/rpi-resize-swap-file.service; static)
           Active: failed (Result: exit-code) since Mon 2026-04-13 15:19:52 CEST; 15min ago
       Invocation: d34a236a8065464db386823236ca32ea
          Process: 75463 ExecStart=/usr/lib/rpi-swap/bin/rpi-resize-swap-file (code=exited, status=1/FAILURE)
         Main PID: 75463 (code=exited, status=1/FAILURE)
              CPU: 210ms
      Apr 13 15:19:52 Raspberry systemd[1]: Starting rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile...
      Apr 13 15:19:52 Raspberry rpi-resize-swap-file[75502]: swaplabel: no device specified
      Apr 13 15:19:52 Raspberry rpi-resize-swap-file[75502]: Try 'swaplabel --help' for more information.
      Apr 13 15:19:52 Raspberry rpi-resize-swap-file[75503]: mkswap: error: /var/swap is mounted; will not make swapspace
      Apr 13 15:19:52 Raspberry systemd[1]: rpi-resize-swap-file.service: Main process exited, code=exited, status=1/FAILURE
      Apr 13 15:19:52 Raspberry systemd[1]: rpi-resize-swap-file.service: Failed with result 'exit-code'.
      Apr 13 15:19:52 Raspberry systemd[1]: Failed to start rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile.
      schon wieder updates .... erst gestern gemacht grrrrrrrrrr
                CPU: 210ms
        @Michael-Schmitt sagte:
        Da ist ein Firmware-Update dabei. Neustart nicht vergessen.
          Michael Schmitt
          erledigt, Fehler immer noch vorhanden
          Script v.2026-01-31
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
           16:28:45 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
          CPU threads: 4
          Current issues:
                         Local time: Mon 2026-04-13 16:28:45 CEST
                     Universal time: Mon 2026-04-13 14:28:45 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          marvman67
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:            4.0G        2.2G        1.3G         10M        560M        1.8G
          Swap:           2.1G          0B        2.1G
          Total:          6.1G        2.2G        3.5G
                   3795 M total memory
                   2085 M used memory
                   2146 M active memory
                    225 M inactive memory
                   1262 M free memory
                     54 M buffer memory
                    479 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          top - 16:28:46 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
          Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.8 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3795.7 total,   1261.7 free,   2085.7 used,    535.0 buff/cache
          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1710.0 avail Mem
          *** FILESYSTEM ***
          tmpfs          tmpfs     1.9G  648K  1.9G   1% /tmp
          [Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
          [Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
          [Mon Apr 13 16:17:38 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
          /var:
          2.5G    /var/
          231M    /var/cache
          225M    /var/cache/apt
          187M    /var/lib
          341M    /opt/iobroker/iobroker-data/
          44M     /opt/iobroker/iobroker-data/objects.jsonl
          4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_15-49_objects.jsonl.gz
          USB-Devices by-id:
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 668)
          admin:          7.7.22
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        5969
          States:         4496
          Pending systemupdates: 0
          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       2016       630/deCONZ
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2279       1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8467       1212/sshd: /usr/sbi
          tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       10155      1689/io.socketio.0
          tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       9364       630/deCONZ
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6816       1200/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7607       1200/iobroker.js-co
          tcp6       0      0 :::111                  :::*                    LISTEN      0          1217       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          8469       1212/sshd: /usr/sbi
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6930       1280/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10514      1717/io.web.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10485      1673/io.simple-api.
          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9786       1288/io.admin.1
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4614       1/init
          udp        0      0 0.0.0.0:45527           0.0.0.0:*                           101        1876       626/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10541      1657/io.matter.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10176      1657/io.matter.0
          udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10093      1572/io.tr-064.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        1874       626/avahi-daemon: r
          udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       10175      1657/io.matter.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11887      2053/io.deconz.0
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       9386       630/deCONZ
          udp6       0      0 :::111                  :::*                                0          2280       1/init
          udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          8508       702/NetworkManager
          udp6       0      0 :::5353                 :::*                                1001       10542      1657/io.matter.0
          udp6       0      0 :::5353                 :::*                                1001       10179      1657/io.matter.0
          udp6       0      0 :::5353                 :::*                                101        1875       626/avahi-daemon: r
          udp6       0      0 :::5540                 :::*                                1001       10174      1657/io.matter.0
          udp6       0      0 :::40645                :::*                                101        1877       626/avahi-daemon: r
          udp6       0      0 :::1900                 :::*                                1001       11890      2053/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       11889      2053/io.deconz.0
          udp6       0      0 :::1900                 :::*                                1001       11888      2053/io.deconz.0
            Michael Schmitt
                 Active: failed (Result: exit-code) since Mon 2026-04-13 16:28:45 CEST; 5min ago
             Invocation: ace4635917fb4b07abbc341357411796
                Process: 2356 ExecStart=/usr/lib/rpi-swap/bin/rpi-resize-swap-file (code=exited, status=1/FAILURE)
               Main PID: 2356 (code=exited, status=1/FAILURE)
                    CPU: 219ms
            Apr 13 16:28:45 Raspberry systemd[1]: Starting rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile...
            Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: swaplabel: no device specified
            Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: Try 'swaplabel --help' for more information.
            Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2380]: mkswap: error: /var/swap is mounted; will not make swapspace
            Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Main process exited, code=exited, status=1/FAILURE
            Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Failed with result 'exit-code'.
            Apr 13 16:28:45 Raspberry systemd[1]: Failed to start rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile.
              Michael Schmitt
              ich hab nun folgendes gemacht.
              sudo nano /etc/rpi/swap.conf
              und dort das eingetragen
              FixedSizeMiB=2048
              dann
              sudo swapoff /var/swap
              sudo systemctl restart rpi-swap.service
              ceck mit swapon --show
              NAME TYPE SIZE USED PRIO
              /var/swap file 2G 0B -2
              so wie ich im Internet gelesen habe kontrolliert das "rpi-resize-swap-file.service" nur ob die swap Größe richtig ist und das ist sie ja nun.
              Dmit nun die Fehlermeldung nicht mehr kommt habe ich den Dienst deaktiviert.
              sudo systemctl mask rpi-resize-swap-file.service
              systemctl status var-swap.swap
              marvman67@Raspberry:~ $ systemctl status var-swap.swap
              ● var-swap.swap - /var/swap
                   Loaded: loaded (/etc/fstab; generated)
                   Active: active since Mon 2026-04-13 17:07:09 CEST; 27min ago
               Invocation: 4e3dc8887e5c4b70b12060987cb2294e
                     What: /var/swap
                     Docs: man:fstab(5)
                           man:systemd-fstab-generator(8)
                    Tasks: 0 (limit: 3924)
                      CPU: 33ms
                   CGroup: /system.slice/var-swap.swap
              Apr 13 17:07:09 Raspberry systemd[1]: Activating swap var-swap.swap - /var/swap...
              Apr 13 17:07:09 Raspberry systemd[1]: Activated swap var-swap.swap - /var/swap.
              aktuelles iob diag nach reboot
              ```bash
              Script v.2026-01-31
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
               17:36:16 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
              CPU threads: 4
              Current issues:
                             Local time: Mon 2026-04-13 17:36:17 CEST
                         Universal time: Mon 2026-04-13 15:36:17 UTC
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              marvman67
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            4.0G        2.3G        944M         12M        853M        1.7G
              Swap:           2.1G          0B        2.1G
              Total:          6.1G        2.3G        3.1G
                       3795 M total memory
                       2179 M used memory
                       2139 M active memory
                        544 M inactive memory
                        901 M free memory
                         76 M buffer memory
                        737 M swap cache
                       2047 M total swap
                          0 M used swap
                       2047 M free swap
              top - 17:36:17 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
              Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  4.4 us,  0.0 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   3795.7 total,    901.0 free,   2179.5 used,    814.0 buff/cache
              MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1616.2 avail Mem
              0 loaded units listed.
              *** FILESYSTEM ***
              [Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
              [Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
              [Mon Apr 13 17:07:27 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
              /var:
              2.5G    /var/
              231M    /var/cache
              225M    /var/cache/apt
              187M    /var/lib
              349M    /opt/iobroker/iobroker-data/
              46M     /opt/iobroker/iobroker-data/objects.jsonl
              6.5M    /opt/iobroker/iobroker-data/states.jsonl
              USB-Devices by-id:
              /usr/bin/npm            10.9.7
              /usr/bin/npx            10.9.7
              nodejs:
                Version table:
                   20.19.2+dfsg-1 500
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 1718)
              admin:          7.7.22
              javascript:     9.0.18
              Adapter State
              + instance is alive
              Objects and States
              Objects:        5969
              States:         4431
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8398       1093/iobroker.js-co
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8403       1093/iobroker.js-co
              tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7319       589/deCONZ
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4221       1/init
              tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6036       589/deCONZ
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9381       1105/sshd: /usr/sbi
              tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       8917       1532/io.socketio.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          302        1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          9383       1105/sshd: /usr/sbi
              tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9670       1159/io.admin.1
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6879       1151/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8945       1572/io.web.0
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10403      1520/io.simple-api.
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1442       1/init
              udp        0      0 0.0.0.0:57509           0.0.0.0:*                           101        6249       585/avahi-daemon: r
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8953       1508/io.matter.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8056       1508/io.matter.0
              udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10337      1419/io.tr-064.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6247       585/avahi-daemon: r
              udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       8055       1508/io.matter.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10729      1781/io.deconz.0
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7333       589/deCONZ
              udp6       0      0 :::111                  :::*                                0          1443       1/init
              udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6802       780/NetworkManager
              udp6       0      0 :::38101                :::*                                101        6250       585/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                1001       8954       1508/io.matter.0
              udp6       0      0 :::5353                 :::*                                1001       8059       1508/io.matter.0
              udp6       0      0 :::5353                 :::*                                101        6248       585/avahi-daemon: r
              udp6       0      0 :::5540                 :::*                                1001       8054       1508/io.matter.0
              udp6       0      0 :::1900                 :::*                                1001       10732      1781/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       10731      1781/io.deconz.0
              udp6       0      0 :::1900                 :::*                                1001       10730      1781/io.deconz.0
              2026-04-13 17:13:05.053  - info: host.Raspberry stopInstance system.adapter.deconz.0 (force=false, process=true)
              2026-04-13 17:13:05.061  - info: deconz.0 (1371) Got terminate signal TERMINATE_YOURSELF
              2026-04-13 17:13:05.071  - info: deconz.0 (1371) cleaned everything up...
              2026-04-13 17:13:05.072  - info: deconz.0 (1371) terminating
              2026-04-13 17:13:05.073  - info: deconz.0 (1371) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2026-04-13 17:13:05.176  - info: host.Raspberry stopInstance system.adapter.deconz.0 send kill signal
              2026-04-13 17:13:05.577  - info: deconz.0 (1371) terminating
              2026-04-13 17:13:05.792  - info: host.Raspberry instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2026-04-13 17:13:09.725  - info: host.Raspberry instance system.adapter.deconz.0 in version "1.7.4" started with pid 1781
              2026-04-13 17:13:12.430  - info: deconz.0 (1781) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v22.22.2, js-controller: 7.0.7
              2026-04-13 17:13:12.588  - info: deconz.0 (1781) deConz Version: 2.32.5; API version: 1.16.0
              2026-04-13 17:13:34.462  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.29
              2026-04-13 17:13:35.843  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
              Wert: false
              Adapter NICHT erreichbar
              2026-04-13 17:13:36.889  - info: javascript.0 (1257) script.js.common.Wichtig.Sensor_erreichbar: telegram[Michael]: Kanal ID: deconz.0.Sensors.146
              Name: Bewegungsmelder Flur 4 Tür SZ reachable
              Wert: true
              Sensor ist wieder erreichbar
              2026-04-13 17:13:57.519  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
              Wert: true
              Adapter ist wieder erreichbar
              2026-04-13 17:20:12.613  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.29 iqontrol.0
              2026-04-13 17:30:00.083  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 3169
              2026-04-13 17:30:09.714  - info: host.Raspberry instance system.adapter.ical.0 having pid 3169 terminated with code 0 (NO_ERROR)
              ich hoffe ich hab nicht mehr zerstört, als in Ordnung gebracht :)
                FixedSizeMiB=2048
                dann
                       What: /var/swap
                       Docs: man:fstab(5)
                        CPU: 33ms
                ```bash
                Script v.2026-01-31
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                marvman67
                iobroker
                HOME=/home/iobroker
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Swap:           2.1G          0B        2.1G
                         3795 M total memory
                         2179 M used memory
                          901 M free memory
                           76 M buffer memory
                          737 M swap cache
                         2047 M total swap
                            0 M used swap
                         2047 M free swap
                *** FILESYSTEM ***
                /var:
                2.5G    /var/
                231M    /var/cache
                225M    /var/cache/apt
                187M    /var/lib
                USB-Devices by-id:
                /usr/bin/npm            10.9.7
                /usr/bin/npx            10.9.7
                nodejs:
                  Version table:
                     20.19.2+dfsg-1 500
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                admin:          7.7.22
                javascript:     9.0.18
                Adapter State
                + instance is alive
                Objects and States
                Objects:        5969
                States:         4431
                Wert: false
                Wert: true
                Wert: true
                @Michael-Schmitt
                Hattest du da in der Vergangenheit selber schon was umgestellt?
                Denn die Voreinstellung für ein frisches Debian 13 'Trixie' ist
                536MB:
                *** MEMORY ***
                Mem:            8.2G        4.4G        2.8G         11M        1.1G        3.8G
                Swap:           536M          0B        536M
                Total:          8.7G        4.4G        3.3G
                Active iob-Instances:   37
                         7819 M total memory
                         4201 M used memory
                         4218 M active memory
                          631 M inactive memory
                         2673 M free memory
                          105 M buffer memory
                          948 M swap cache
                          511 M total swap
                            0 M used swap
                          511 M free swap
                Und auf meinem System gibt es den Service auch erst gar nicht:
                echad@chet:~ $  systemctl status rpi-resize-swap-file.service
                Unit rpi-resize-swap-file.service could not be found.
                echad@chet:~ $
                  Michael Schmitt
                  Ich hatte mal die swappiness auf 40 gesetzt aber mehr nicht und wenn ich mich recht erinnere dann aber nochmal komplett neu aufgesetzt und wieder nur swappines auf 40.
                    @Michael-Schmitt
                    Irgendwas ist jedenfalls auf deiner Kiste grundsätzlich anders als auf meiner...
                      Michael Schmitt
                      ich werd das jetzt mal so lassen und beobachten, wenn es Probleme gibt mach ich einfach alles neu ;)
                        Michael Schmitt
                        so ich hab jetzt alles neu gemacht und hab immer noch 2,1gb swap keine Ahnung warum. Kann das an meiner SSD (240gb) liegen ? Von swap hab ich die Finger komplett gelassen.
                        Das einzigste was nicht geht, der RPI2 Adapter lies sich nicht wiederherstellen (v3.0.2) Auch nach einem deinstallieren bekomme ich den nicht wieder.
                        host.Raspberry
                        	2026-04-15 16:48:36.071	info	iobroker exit 25
                        host.Raspberry
                        	2026-04-15 16:48:34.955	error	iobroker host.Raspberry Cannot install iobroker.rpi2@3.0.2: 1
                        host.Raspberry
                        	2026-04-15 16:48:34.953	error	iobroker npm error code 1npm error path /opt/iobroker/node_modules/iobroker.rpi2npm error command failednpm error command sh -c bash ./preinstall-check.shnpm error Checking package: libgpiod-dev >= 2.2npm error libgpiod-dev is not installednpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-15T14_48_28_153Z-debug-0.log
                        host.Raspberry
                        	2026-04-15 16:48:27.944	info	iobroker Installing iobroker.rpi2@3.0.2... (System call)
                        host.Raspberry
                        	2026-04-15 16:48:27.943	info	iobroker NPM version: 10.9.7
                        host.Raspberry
                        	2026-04-15 16:48:24.047	info	iobroker add rpi2 --host Raspberry
                        hier ein iob diag
                        ```bash
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        OS is similar to:
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : 64 bit
                         16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
                        CPU threads: 4
                        Current issues:
                                       Local time: Wed 2026-04-15 16:42:58 CEST
                                   Universal time: Wed 2026-04-15 14:42:58 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        marvman67
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            4.0G        2.0G        1.1G         12M        909M        1.9G
                        Swap:           2.1G          0B        2.1G
                        Total:          6.1G        2.0G        3.3G
                        Active iob-Instances:   18
                                 3795 M total memory
                                 1947 M used memory
                                 1907 M active memory
                                  534 M inactive memory
                                 1080 M free memory
                                   96 M buffer memory
                                  770 M swap cache
                                 2047 M total swap
                                    0 M used swap
                                 2047 M free swap
                        top - 16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
                        Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  1.9 us,  3.7 sy,  0.0 ni, 92.6 id,  1.9 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :   3795.7 total,   1079.0 free,   1947.7 used,    867.8 buff/cache
                        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1848.0 avail Mem
                        *** FILESYSTEM ***
                        tmpfs          tmpfs     760M  9.1M  751M   2% /run
                        /dev/sda2      ext4      220G  6.6G  204G   4% /
                        /dev/sda1      vfat      505M   74M  432M  15% /boot/firmware
                        tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
                        [Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                        [Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): mounted filesystem 687fa5d6-7e12-409f-8631-6b47ecc831af ro with ordered data mode. Quota mode: none.
                        [Wed Apr 15 16:23:09 2026] EXT4-fs (sda2): re-mounted 687fa5d6-7e12-409f-8631-6b47ecc831af r/w.
                        /var:
                        2.5G    /var/
                        231M    /var/cache
                        225M    /var/cache/apt
                        186M    /var/lib
                        146M    /var/lib/apt
                        5.8M    /opt/iobroker/backups/
                        202M    /opt/iobroker/iobroker-data/
                        180M    /opt/iobroker/iobroker-data/files
                        20M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
                        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                        3.7M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/assets/index-DS28Nms8.js
                        USB-Devices by-id:
                        /usr/bin/npm            10.9.7
                        /usr/bin/npx            10.9.7
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 184)
                        admin:          7.7.22
                        javascript:     9.0.18
                        Adapter State
                          system.adapter.cloud.0                  : cloud                 : Raspberry                                - disabled
                        + instance is alive
                        Objects and States
                        Objects:        5922
                        States:         4448
                        tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       18917      2872/io.socketio.0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7089       958/sshd: /usr/sbin
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5180       1/init
                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6065       625/deCONZ
                        tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7106       625/deCONZ
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17701      2536/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17696      2536/iobroker.js-co
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          7091       958/sshd: /usr/sbin
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          4095       1/init
                        tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17867      2567/io.admin.1
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19806      2860/io.simple-api.
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18942      2900/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18547      2555/io.admin.0
                        udp        0      0 0.0.0.0:33244           0.0.0.0:*                           101        4790       619/avahi-daemon: r
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18957      2848/io.matter.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17133      2848/io.matter.0
                        udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       19780      2792/io.tr-064.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4788       619/avahi-daemon: r
                        udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       17132      2848/io.matter.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18174      2744/io.deconz.0
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       8239       625/deCONZ
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4241       1/init
                        udp6       0      0 fe80::ac82:ba7c:acc:546 :::*                                0          8254       693/NetworkManager
                        udp6       0      0 :::5353                 :::*                                1001       18958      2848/io.matter.0
                        udp6       0      0 :::5353                 :::*                                1001       17136      2848/io.matter.0
                        udp6       0      0 :::5353                 :::*                                101        4789       619/avahi-daemon: r
                        udp6       0      0 :::5540                 :::*                                1001       17131      2848/io.matter.0
                        udp6       0      0 :::1900                 :::*                                1001       18177      2744/io.deconz.0
                        udp6       0      0 :::1900                 :::*                                1001       18176      2744/io.deconz.0
                        udp6       0      0 :::1900                 :::*                                1001       18175      2744/io.deconz.0
                        udp6       0      0 :::34850                :::*                                101        4791       619/avahi-daemon: r
                        udp6       0      0 :::111                  :::*                                0          4242       1/init
                        2026-04-15 16:41:19.111  - info: matter.0 (2848) Preparing bridged device 12dac884-896a-4955-8fac-85635d860d45 "Bad Spiegel 3" for bridge
                        2026-04-15 16:41:19.269  - info: matter.0 (2848) Preparing bridged device c0f93364-0f42-4f41-90a9-cc3dce4d22c2 "Bad Spiegel 4" for bridge
                        2026-04-15 16:41:19.457  - info: matter.0 (2848) Preparing bridged device 82a95d66-641f-45ed-a070-6dd88a067ca0 "Computerzimmer Decke 1" for bridge
                        2026-04-15 16:41:19.585  - info: matter.0 (2848) Preparing bridged device 270b7502-23c8-4ab7-a490-fe11d20a48d0 "Computerzimmer Decke 2" for bridge
                        2026-04-15 16:41:19.706  - info: matter.0 (2848) Preparing bridged device 170ac091-af8a-45d2-884a-ec31345186ad "Flurlicht Telefon" for bridge
                        2026-04-15 16:41:19.853  - info: matter.0 (2848) Preparing bridged device ca7e0c6c-01ec-4025-8887-ab695a46d509 "Küche 1" for bridge
                        2026-04-15 16:41:19.970  - info: matter.0 (2848) Preparing bridged device 980e21e5-de18-457d-a0ff-8d74d0ecb22b "Küche 2" for bridge
                        2026-04-15 16:41:20.106  - info: matter.0 (2848) Preparing bridged device 1ce9fd49-2428-4b81-8262-4fffcb8ff0dc "Küche 3" for bridge
                        2026-04-15 16:41:20.233  - info: matter.0 (2848) Preparing bridged device 822a73fa-c98d-4861-ae74-ef74f322098e "Küche 4" for bridge
                        2026-04-15 16:41:20.347  - info: matter.0 (2848) Preparing bridged device 6f4b50d4-b9d6-45c2-b70e-1449fe45ff82 "Schlafzimmer Decke" for bridge
                        2026-04-15 16:41:20.484  - info: matter.0 (2848) Preparing bridged device bf9aa093-0a0f-49c4-a027-2908578847fd "Schlafzimmer Nachttischlampe" for bridge
                        2026-04-15 16:41:20.602  - info: matter.0 (2848) Preparing bridged device 71b3bc3e-2d8a-42d7-86d8-8c9caa8261ec "WZ Decke hinten" for bridge
                        2026-04-15 16:41:20.736  - info: matter.0 (2848) Preparing bridged device 70d546c5-da32-47e9-ae9a-93c5c2766f2d "WZ Decke vorne" for bridge
                        2026-04-15 16:41:20.849  - info: matter.0 (2848) Preparing bridged device a385531c-a983-4c83-827b-12924d8f1cfe "WZ Stehlampe 1" for bridge
                        2026-04-15 16:41:21.032  - info: matter.0 (2848) Preparing bridged device c93667f3-9f91-4f23-bf3b-965041c64cf5 "WZ Stehlampe 2" for bridge
                        2026-04-15 16:41:21.212  - info: matter.0 (2848) 2026-04-15 16:41:21.212 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c going online
                        2026-04-15 16:41:21.293  - info: matter.0 (2848) 2026-04-15 16:41:21.293 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c is online
                        2026-04-15 16:41:55.635  - info: alexa2.0 (2732) Using cached smart home devices list from Wed Apr 15 2026 16:25:23 GMT+0200 (Central European Summer Time)
                        2026-04-15 16:41:58.046  - info: alexa2.0 (2732) No smart home devices to query
                        2026-04-15 16:41:59.278  - info: alexa2.0 (2732) Subscribing to states...
                        2026-04-15 16:41:59.955  - info: javascript.0 (2662) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: matter.0 is connected
                        Wert: true
                        2026-04-15 16:42:01.063  - info: alexa2.0 (2732) Alexa-Push-Connection (macDms = true) established. Disable Polling
                        2026-04-15 16:42:15.838  - info: alexa2.0 (2732) Initialization Done ...
                        wie komm ich wieder zum RPI2 Adapter ?
                          host.Raspberry
                          host.Raspberry
                          host.Raspberry
                          host.Raspberry
                          host.Raspberry
                          host.Raspberry
                          hier ein iob diag
                          ```bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                          CPU threads: 4
                          Current issues:
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          marvman67
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Swap:           2.1G          0B        2.1G
                                   3795 M total memory
                                   1947 M used memory
                                   1080 M free memory
                                     96 M buffer memory
                                    770 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          *** FILESYSTEM ***
                          /var:
                          2.5G    /var/
                          231M    /var/cache
                          225M    /var/cache/apt
                          186M    /var/lib
                          146M    /var/lib/apt
                          USB-Devices by-id:
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin:          7.7.22
                          javascript:     9.0.18
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects:        5922
                          States:         4448
                          Wert: true
                          Mit welchen Meldungen bekommst du den denn nicht installiert?
                            Michael Schmitt
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            Edit:
                            iobroker libgpiod-dev is not installed ?????
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              Edit:
                              Also nachinstallieren:
                              sudo apt update
                              sudo apt install libgpiod-dev
                                Michael Schmitt
                                Dankeeee jetzt ist alles da.
                                Irgend eine Ahnung warum mein Swap selbst nach einer Neuinstallation so groß ist ?
                                  @Michael-Schmitt
                                  Nein. Könnte aber sein, dass die Größe bei aktuellen Neuinstallationen anders als bisher berechnet werden.
                                    So groß oder schon so stark in Gebrauch?
                                      Michael Schmitt
                                      Also ich denke nicht das der stark in Gebrauch ist, so viel hab ich nicht. Nur iobroker und Deconz.
                                      Was mir auch gefallen ist jetzt steht da
                                      marvman67@Raspberry:~ $ swapon --show
                                      /dev/zram0 partition   2G 3.3M  100
                                      davor war das
                                      /var/swap file 2G 5.8M -2
                                      wie gesagt hab ich nur komplett Neuinstalliert und Backups drauf gemacht.
                                        iob diag
                                        Script v.2026-01-31
                                        *** BASE SYSTEM ***
                                               Icon name: computer
                                            Architecture: arm64
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : aarch64
                                        Userland        : 64 bit
                                        CPU threads: 4
                                        Current issues:
                                                         RTC time: n/a
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        marvman67
                                        iobroker
                                        HOME=/home/iobroker
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                                 3795 M total memory
                                                 2452 M used memory
                                                  758 M free memory
                                                   56 M buffer memory
                                                  622 M swap cache
                                                 2047 M total swap
                                                    4 M used swap
                                                 2043 M free swap
                                        *** FILESYSTEM ***
                                        /var:
                                        2.5G    /var/
                                        231M    /var/cache
                                        225M    /var/cache/apt
                                        187M    /var/lib
                                        USB-Devices by-id:
                                        /usr/bin/npm            10.9.7
                                        /usr/bin/npx            10.9.7
                                        nodejs:
                                          Version table:
                                             20.19.2+dfsg-1 500
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        admin:          7.7.22
                                        javascript:     9.0.18
                                        Adapter State
                                        + instance is alive
                                        Objects and States
                                        Objects:        5969
                                        States:         4431
                                        Gruß Michael
                                        Da hatten ich wohl das hier noch im Kopf
                                          Michael Schmitt
                                          aber warum ist es nun nach der Neuinstallation "zram" und nicht swap
