  4. Was bedeutet das ? rpi-resize-swap-file.
    2.5k
    2.8k
27 Beiträge 3 Kommentatoren 807 Aufrufe 2 Beobachtet
  • Michael SchmittM Online
    Michael Schmitt
    mir ist diese Meldung bei einem iob diag aufgefallen. Was bedeutet das und was ist zu tun ?
      UNIT                         LOAD   ACTIVE SUB    DESCRIPTION
    * rpi-resize-swap-file.service loaded failed failed rpi-resize-var-swap-service - resize swapfile
    iob diag
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Raspberry
           Icon name: computer
              Kernel: Linux 6.12.75+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     15:07:25 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2026-04-13 15:07:25 CEST
               Universal time: Mon 2026-04-13 13:07:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marvman67
    HOME=/home/marvman67
    GROUPS=marvman67 adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/marvman67
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.6G        795M        8.9M        712M        1.4G
    Swap:           2.1G        4.2M        2.1G
    Total:          6.1G        2.6G        2.9G
    Active iob-Instances:   20
             3795 M total memory
             2452 M used memory
             1513 M active memory
             1309 M inactive memory
              758 M free memory
               56 M buffer memory
              622 M swap cache
             2047 M total swap
                4 M used swap
             2043 M free swap
    top - 15:07:26 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
    Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  2.3 sy,  0.0 ni, 97.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.7 total,    758.5 free,   2452.8 used,    679.9 buff/cache
    MiB Swap:   2048.0 total,   2044.0 free,      4.0 used.   1342.9 avail Mem
    *** FAILED SERVICES ***
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  9.3M  750M   2% /run
    /dev/sda2      ext4      229G  7.1G  213G   4% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     1.9G  2.9M  1.9G   1% /tmp
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
    tmpfs          tmpfs     380M   12K  380M   1% /run/user/1000
    [Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Sun Apr 12 11:49:00 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.5G    /var/
    231M    /var/cache
    225M    /var/cache/apt
    187M    /var/lib
    145M    /var/lib/apt/lists
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    173M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    342M    /opt/iobroker/iobroker-data/
    181M    /opt/iobroker/iobroker-data/files
    116M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    43M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
    4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_13-49_objects.jsonl.gz
    4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_11-49_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2706986-if00
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 98290)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.1                  : admin                 : Raspberry                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Raspberry                                -  enabled
    + system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
    + system.adapter.cloud.0                  : cloud                 : Raspberry                                -  enabled
    + system.adapter.deconz.0                 : deconz                : Raspberry                                -  enabled, port: 80
      system.adapter.devices.0                : devices               : Raspberry                                - disabled
    + system.adapter.email.0                  : email                 : Raspberry                                -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : Raspberry                                -  enabled
    + system.adapter.history.0                : history               : Raspberry                                -  enabled
      system.adapter.ical.0                   : ical                  : Raspberry                                -  enabled
      system.adapter.iot.0                    : iot                   : Raspberry                                - disabled
    + system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
    + system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
    + system.adapter.matter.0                 : matter                : Raspberry                                -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : Raspberry                                -  enabled
    + system.adapter.simple-api.0             : simple-api            : Raspberry                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : Raspberry                                -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
    + system.adapter.telegram.0               : telegram              : Raspberry                                -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : Raspberry                                -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
    + system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name            │ url                                                     │ auto upgrade │
    │ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "deconz"       : 1.7.4    , installed 1.7.4
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "history"      : 4.0.0    , installed 4.0.0
    Adapter    "ical"         : 1.19.7   , installed 1.19.7
    Adapter    "iot"          : 5.0.12   , installed 5.0.12
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "matter"       : 0.5.6    , installed 1.0.0
    Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "web"          : 8.0.0    , installed 8.0.0
    Adapter    "ws"           : 4.0.0    , installed 4.0.0
    Objects and States
    Objects:        5969
    States:         4431
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://phoscon.de/apt/deconz generic InRelease
    Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       6655       632/deCONZ
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       5895       632/deCONZ
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4211       1/init
    tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       11463      1697/io.socketio.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8540       1216/sshd: /usr/sbi
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6144       1203/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6139       1203/iobroker.js-co
    tcp6       0      0 :::111                  :::*                    LISTEN      0          901        1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8542       1216/sshd: /usr/sbi
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9906       1685/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12294      1725/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8038       1283/io.admin.0
    tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9052       1291/io.admin.1
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11479      1665/io.matter.0
    udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       7125       1559/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4945       628/avahi-daemon: r
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       11478      1665/io.matter.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15004      2525/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6676       632/deCONZ
    udp        0      0 0.0.0.0:34805           0.0.0.0:*                           101        4947       628/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2652       1/init
    udp6       0      0 :::5353                 :::*                                1001       11482      1665/io.matter.0
    udp6       0      0 :::5353                 :::*                                101        4946       628/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1001       11477      1665/io.matter.0
    udp6       0      0 :::1900                 :::*                                1001       15007      2525/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       15006      2525/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       15005      2525/io.deconz.0
    udp6       0      0 :::111                  :::*                                0          2653       1/init
    udp6       0      0 :::57875                :::*                                101        4948       628/avahi-daemon: r
    udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6109       704/NetworkManager
    2026-04-13 09:30:00.066  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 58968
    2026-04-13 09:30:09.853  - info: host.Raspberry instance system.adapter.ical.0 having pid 58968 terminated with code 0 (NO_ERROR)
    2026-04-13 10:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 61569
    2026-04-13 10:30:09.776  - info: host.Raspberry instance system.adapter.ical.0 having pid 61569 terminated with code 0 (NO_ERROR)
    2026-04-13 11:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 64157
    2026-04-13 11:30:09.934  - info: host.Raspberry instance system.adapter.ical.0 having pid 64157 terminated with code 0 (NO_ERROR)
    2026-04-13 11:49:35.045  - info: admin.0 (1283) Adapter rating updated
    2026-04-13 11:49:42.144  - info: admin.1 (1291) Adapter rating updated
    2026-04-13 12:30:00.116  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 66781
    2026-04-13 12:30:09.734  - info: host.Raspberry instance system.adapter.ical.0 having pid 66781 terminated with code 0 (NO_ERROR)
    2026-04-13 12:55:43.589  - info: javascript.0 (1382) script.js.common.Anwesendheitscheck.Marvin_PC_AN_AUS_Wlan: telegram[Michael]: 12:55 Uhr. PC von Marvin wurde ausgeschalten.
    2026-04-13 13:00:22.692  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
    2026-04-13 13:00:27.064  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
    2026-04-13 13:03:00.018  - info: javascript.0 (1382) script.js.common.Wichtig.24Std_Sensor_Zeitstempel_nicht_aktualisiert: telegram[Michael]: 24 Stunden keine Änderung bei Wohnzimmer_Lichtschalter, SZ_TV_Schalter_Steckdose, Bad Spiegel, Rauchmelder_Schlafzimmer, Rauchmelder_Flur, Rauchmelder_WZ, CO_Sensor_Küche, . Eventuell ist die Batterie leer?
    2026-04-13 13:30:00.061  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 69380
    2026-04-13 13:30:09.633  - info: host.Raspberry instance system.adapter.ical.0 having pid 69380 terminated with code 0 (NO_ERROR)
    2026-04-13 13:59:09.505  - info: admin.0 (1283) Request actual repository...
    2026-04-13 13:59:10.563  - info: host.Raspberry Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2026-04-13 13:59:21.691  - info: admin.0 (1283) Repository received successfully.
    2026-04-13 14:30:00.043  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 71972
    2026-04-13 14:30:10.418  - warn: ical.0 (71972) get state error: Connection is closed.
    2026-04-13 14:30:10.503  - info: host.Raspberry instance system.adapter.ical.0 having pid 71972 terminated with code 0 (NO_ERROR)
    2026-04-13 14:39:38.092  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
    2026-04-13 14:39:44.177  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
    2026-04-13 14:51:30.503  - info: admin.0 (1283) ==> Connected system.user.admin from ::ffff:192.168.178.29
    Gruß Michael
    • Michael SchmittM Michael Schmitt
      iob diag
      Script v.2026-01-31
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      marvman67
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               3795 M total memory
               2452 M used memory
                758 M free memory
                 56 M buffer memory
                622 M swap cache
               2047 M total swap
                  4 M used swap
               2043 M free swap
      *** FILESYSTEM ***
      /var:
      2.5G    /var/
      231M    /var/cache
      225M    /var/cache/apt
      187M    /var/lib
      USB-Devices by-id:
      /usr/bin/npm            10.9.7
      /usr/bin/npx            10.9.7
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.22
      javascript:     9.0.18
      Adapter State
      + instance is alive
      Objects and States
      Objects:        5969
      States:         4431
      Gruß Michael
      @Michael-Schmitt
      Schau mal per
      systemctl status rpi-resize-swap-file.service
      nach den Details.
      Und spiel die vier Updates ein.
        Michael Schmitt
        schrieb am zuletzt editiert von Michael Schmitt
        marvman67@Raspberry:~ $ systemctl status rpi-resize-swap-file.service
        × rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile
             Loaded: loaded (/usr/lib/systemd/system/rpi-resize-swap-file.service; static)
             Active: failed (Result: exit-code) since Mon 2026-04-13 15:19:52 CEST; 15min ago
         Invocation: d34a236a8065464db386823236ca32ea
            Process: 75463 ExecStart=/usr/lib/rpi-swap/bin/rpi-resize-swap-file (code=exited, status=1/FAILURE)
           Main PID: 75463 (code=exited, status=1/FAILURE)
                CPU: 210ms
        Apr 13 15:19:52 Raspberry systemd[1]: Starting rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile...
        Apr 13 15:19:52 Raspberry rpi-resize-swap-file[75502]: swaplabel: no device specified
        Apr 13 15:19:52 Raspberry rpi-resize-swap-file[75502]: Try 'swaplabel --help' for more information.
        Apr 13 15:19:52 Raspberry rpi-resize-swap-file[75503]: mkswap: error: /var/swap is mounted; will not make swapspace
        Apr 13 15:19:52 Raspberry systemd[1]: rpi-resize-swap-file.service: Main process exited, code=exited, status=1/FAILURE
        Apr 13 15:19:52 Raspberry systemd[1]: rpi-resize-swap-file.service: Failed with result 'exit-code'.
        Apr 13 15:19:52 Raspberry systemd[1]: Failed to start rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile.
        schon wieder updates .... erst gestern gemacht grrrrrrrrrr
                  CPU: 210ms
          @Michael-Schmitt sagte:
          Da ist ein Firmware-Update dabei. Neustart nicht vergessen.
            Michael Schmitt
            erledigt, Fehler immer noch vorhanden
            Script v.2026-01-31
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
             16:28:45 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
            CPU threads: 4
            Current issues:
                           Local time: Mon 2026-04-13 16:28:45 CEST
                       Universal time: Mon 2026-04-13 14:28:45 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            marvman67
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Mem:            4.0G        2.2G        1.3G         10M        560M        1.8G
            Swap:           2.1G          0B        2.1G
            Total:          6.1G        2.2G        3.5G
                     3795 M total memory
                     2085 M used memory
                     2146 M active memory
                      225 M inactive memory
                     1262 M free memory
                       54 M buffer memory
                      479 M swap cache
                     2047 M total swap
                        0 M used swap
                     2047 M free swap
            top - 16:28:46 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
            Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.8 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3795.7 total,   1261.7 free,   2085.7 used,    535.0 buff/cache
            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1710.0 avail Mem
            *** FILESYSTEM ***
            tmpfs          tmpfs     1.9G  648K  1.9G   1% /tmp
            [Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
            [Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
            [Mon Apr 13 16:17:38 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
            /var:
            2.5G    /var/
            231M    /var/cache
            225M    /var/cache/apt
            187M    /var/lib
            341M    /opt/iobroker/iobroker-data/
            44M     /opt/iobroker/iobroker-data/objects.jsonl
            4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_15-49_objects.jsonl.gz
            USB-Devices by-id:
            /usr/bin/npm            10.9.7
            /usr/bin/npx            10.9.7
            nodejs:
              Version table:
                 20.19.2+dfsg-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 668)
            admin:          7.7.22
            javascript:     9.0.18
            Adapter State
            + instance is alive
            Objects and States
            Objects:        5969
            States:         4496
            Pending systemupdates: 0
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       2016       630/deCONZ
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2279       1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8467       1212/sshd: /usr/sbi
            tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       10155      1689/io.socketio.0
            tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       9364       630/deCONZ
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6816       1200/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7607       1200/iobroker.js-co
            tcp6       0      0 :::111                  :::*                    LISTEN      0          1217       1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          8469       1212/sshd: /usr/sbi
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6930       1280/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10514      1717/io.web.0
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10485      1673/io.simple-api.
            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9786       1288/io.admin.1
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4614       1/init
            udp        0      0 0.0.0.0:45527           0.0.0.0:*                           101        1876       626/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10541      1657/io.matter.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10176      1657/io.matter.0
            udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10093      1572/io.tr-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        1874       626/avahi-daemon: r
            udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       10175      1657/io.matter.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11887      2053/io.deconz.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       9386       630/deCONZ
            udp6       0      0 :::111                  :::*                                0          2280       1/init
            udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          8508       702/NetworkManager
            udp6       0      0 :::5353                 :::*                                1001       10542      1657/io.matter.0
            udp6       0      0 :::5353                 :::*                                1001       10179      1657/io.matter.0
            udp6       0      0 :::5353                 :::*                                101        1875       626/avahi-daemon: r
            udp6       0      0 :::5540                 :::*                                1001       10174      1657/io.matter.0
            udp6       0      0 :::40645                :::*                                101        1877       626/avahi-daemon: r
            udp6       0      0 :::1900                 :::*                                1001       11890      2053/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       11889      2053/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       11888      2053/io.deconz.0
              Michael Schmitt
                   Active: failed (Result: exit-code) since Mon 2026-04-13 16:28:45 CEST; 5min ago
               Invocation: ace4635917fb4b07abbc341357411796
                  Process: 2356 ExecStart=/usr/lib/rpi-swap/bin/rpi-resize-swap-file (code=exited, status=1/FAILURE)
                 Main PID: 2356 (code=exited, status=1/FAILURE)
                      CPU: 219ms
              Apr 13 16:28:45 Raspberry systemd[1]: Starting rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile...
              Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: swaplabel: no device specified
              Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: Try 'swaplabel --help' for more information.
              Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2380]: mkswap: error: /var/swap is mounted; will not make swapspace
              Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Main process exited, code=exited, status=1/FAILURE
              Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Failed with result 'exit-code'.
              Apr 13 16:28:45 Raspberry systemd[1]: Failed to start rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile.
                Michael Schmitt
                ich hab nun folgendes gemacht.
                sudo nano /etc/rpi/swap.conf
                und dort das eingetragen
                FixedSizeMiB=2048
                dann
                sudo swapoff /var/swap
                sudo systemctl restart rpi-swap.service
                ceck mit swapon --show
                NAME TYPE SIZE USED PRIO
                /var/swap file 2G 0B -2
                so wie ich im Internet gelesen habe kontrolliert das "rpi-resize-swap-file.service" nur ob die swap Größe richtig ist und das ist sie ja nun.
                Dmit nun die Fehlermeldung nicht mehr kommt habe ich den Dienst deaktiviert.
                sudo systemctl mask rpi-resize-swap-file.service
                systemctl status var-swap.swap
                marvman67@Raspberry:~ $ systemctl status var-swap.swap
                ● var-swap.swap - /var/swap
                     Loaded: loaded (/etc/fstab; generated)
                     Active: active since Mon 2026-04-13 17:07:09 CEST; 27min ago
                 Invocation: 4e3dc8887e5c4b70b12060987cb2294e
                       What: /var/swap
                       Docs: man:fstab(5)
                             man:systemd-fstab-generator(8)
                      Tasks: 0 (limit: 3924)
                        CPU: 33ms
                     CGroup: /system.slice/var-swap.swap
                Apr 13 17:07:09 Raspberry systemd[1]: Activating swap var-swap.swap - /var/swap...
                Apr 13 17:07:09 Raspberry systemd[1]: Activated swap var-swap.swap - /var/swap.
                aktuelles iob diag nach reboot
                ```bash
                Script v.2026-01-31
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 17:36:16 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
                CPU threads: 4
                Current issues:
                               Local time: Mon 2026-04-13 17:36:17 CEST
                           Universal time: Mon 2026-04-13 15:36:17 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                marvman67
                iobroker
                HOME=/home/iobroker
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:            4.0G        2.3G        944M         12M        853M        1.7G
                Swap:           2.1G          0B        2.1G
                Total:          6.1G        2.3G        3.1G
                         3795 M total memory
                         2179 M used memory
                         2139 M active memory
                          544 M inactive memory
                          901 M free memory
                           76 M buffer memory
                          737 M swap cache
                         2047 M total swap
                            0 M used swap
                         2047 M free swap
                top - 17:36:17 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
                Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
                %Cpu(s):  4.4 us,  0.0 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                MiB Mem :   3795.7 total,    901.0 free,   2179.5 used,    814.0 buff/cache
                MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1616.2 avail Mem
                0 loaded units listed.
                *** FILESYSTEM ***
                [Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                [Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
                [Mon Apr 13 17:07:27 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
                /var:
                2.5G    /var/
                231M    /var/cache
                225M    /var/cache/apt
                187M    /var/lib
                349M    /opt/iobroker/iobroker-data/
                46M     /opt/iobroker/iobroker-data/objects.jsonl
                6.5M    /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.9.7
                /usr/bin/npx            10.9.7
                nodejs:
                  Version table:
                     20.19.2+dfsg-1 500
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 1718)
                admin:          7.7.22
                javascript:     9.0.18
                Adapter State
                + instance is alive
                Objects and States
                Objects:        5969
                States:         4431
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8398       1093/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8403       1093/iobroker.js-co
                tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7319       589/deCONZ
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4221       1/init
                tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6036       589/deCONZ
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9381       1105/sshd: /usr/sbi
                tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       8917       1532/io.socketio.0
                tcp6       0      0 :::111                  :::*                    LISTEN      0          302        1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          9383       1105/sshd: /usr/sbi
                tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9670       1159/io.admin.1
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6879       1151/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8945       1572/io.web.0
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10403      1520/io.simple-api.
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1442       1/init
                udp        0      0 0.0.0.0:57509           0.0.0.0:*                           101        6249       585/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8953       1508/io.matter.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8056       1508/io.matter.0
                udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10337      1419/io.tr-064.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6247       585/avahi-daemon: r
                udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       8055       1508/io.matter.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10729      1781/io.deconz.0
                udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7333       589/deCONZ
                udp6       0      0 :::111                  :::*                                0          1443       1/init
                udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6802       780/NetworkManager
                udp6       0      0 :::38101                :::*                                101        6250       585/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                1001       8954       1508/io.matter.0
                udp6       0      0 :::5353                 :::*                                1001       8059       1508/io.matter.0
                udp6       0      0 :::5353                 :::*                                101        6248       585/avahi-daemon: r
                udp6       0      0 :::5540                 :::*                                1001       8054       1508/io.matter.0
                udp6       0      0 :::1900                 :::*                                1001       10732      1781/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       10731      1781/io.deconz.0
                udp6       0      0 :::1900                 :::*                                1001       10730      1781/io.deconz.0
                2026-04-13 17:13:05.053  - info: host.Raspberry stopInstance system.adapter.deconz.0 (force=false, process=true)
                2026-04-13 17:13:05.061  - info: deconz.0 (1371) Got terminate signal TERMINATE_YOURSELF
                2026-04-13 17:13:05.071  - info: deconz.0 (1371) cleaned everything up...
                2026-04-13 17:13:05.072  - info: deconz.0 (1371) terminating
                2026-04-13 17:13:05.073  - info: deconz.0 (1371) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2026-04-13 17:13:05.176  - info: host.Raspberry stopInstance system.adapter.deconz.0 send kill signal
                2026-04-13 17:13:05.577  - info: deconz.0 (1371) terminating
                2026-04-13 17:13:05.792  - info: host.Raspberry instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2026-04-13 17:13:09.725  - info: host.Raspberry instance system.adapter.deconz.0 in version "1.7.4" started with pid 1781
                2026-04-13 17:13:12.430  - info: deconz.0 (1781) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v22.22.2, js-controller: 7.0.7
                2026-04-13 17:13:12.588  - info: deconz.0 (1781) deConz Version: 2.32.5; API version: 1.16.0
                2026-04-13 17:13:34.462  - info: web.0 (1572) ==> Connected system.user.admin from ::ffff:192.168.178.29
                2026-04-13 17:13:35.843  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
                Wert: false
                Adapter NICHT erreichbar
                2026-04-13 17:13:36.889  - info: javascript.0 (1257) script.js.common.Wichtig.Sensor_erreichbar: telegram[Michael]: Kanal ID: deconz.0.Sensors.146
                Name: Bewegungsmelder Flur 4 Tür SZ reachable
                Wert: true
                Sensor ist wieder erreichbar
                2026-04-13 17:13:57.519  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
                Wert: true
                Adapter ist wieder erreichbar
                2026-04-13 17:20:12.613  - info: web.0 (1572) <== Disconnect system.user.admin from ::ffff:192.168.178.29 iqontrol.0
                2026-04-13 17:30:00.083  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 3169
                2026-04-13 17:30:09.714  - info: host.Raspberry instance system.adapter.ical.0 having pid 3169 terminated with code 0 (NO_ERROR)
                ich hoffe ich hab nicht mehr zerstört, als in Ordnung gebracht :)
                  FixedSizeMiB=2048
                  dann
                         What: /var/swap
                         Docs: man:fstab(5)
                          CPU: 33ms
                  ```bash
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : 64 bit
                  CPU threads: 4
                  Current issues:
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  marvman67
                  iobroker
                  HOME=/home/iobroker
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:           2.1G          0B        2.1G
                           3795 M total memory
                           2179 M used memory
                            901 M free memory
                             76 M buffer memory
                            737 M swap cache
                           2047 M total swap
                              0 M used swap
                           2047 M free swap
                  *** FILESYSTEM ***
                  /var:
                  2.5G    /var/
                  231M    /var/cache
                  225M    /var/cache/apt
                  187M    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            10.9.7
                  /usr/bin/npx            10.9.7
                  nodejs:
                    Version table:
                       20.19.2+dfsg-1 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.7.22
                  javascript:     9.0.18
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        5969
                  States:         4431
                  Wert: false
                  Wert: true
                  Wert: true
                  @Michael-Schmitt
                  Hattest du da in der Vergangenheit selber schon was umgestellt?
                  Denn die Voreinstellung für ein frisches Debian 13 'Trixie' ist
                  536MB:
                  *** MEMORY ***
                  Mem:            8.2G        4.4G        2.8G         11M        1.1G        3.8G
                  Swap:           536M          0B        536M
                  Total:          8.7G        4.4G        3.3G
                  Active iob-Instances:   37
                           7819 M total memory
                           4201 M used memory
                           4218 M active memory
                            631 M inactive memory
                           2673 M free memory
                            105 M buffer memory
                            948 M swap cache
                            511 M total swap
                              0 M used swap
                            511 M free swap
                  Und auf meinem System gibt es den Service auch erst gar nicht:
                  echad@chet:~ $  systemctl status rpi-resize-swap-file.service
                  Unit rpi-resize-swap-file.service could not be found.
                  echad@chet:~ $
                    Michael Schmitt
                    Ich hatte mal die swappiness auf 40 gesetzt aber mehr nicht und wenn ich mich recht erinnere dann aber nochmal komplett neu aufgesetzt und wieder nur swappines auf 40.
                      @Michael-Schmitt
                      Irgendwas ist jedenfalls auf deiner Kiste grundsätzlich anders als auf meiner...
                        Michael Schmitt
                        ich werd das jetzt mal so lassen und beobachten, wenn es Probleme gibt mach ich einfach alles neu ;)
                          Michael Schmitt
                          so ich hab jetzt alles neu gemacht und hab immer noch 2,1gb swap keine Ahnung warum. Kann das an meiner SSD (240gb) liegen ? Von swap hab ich die Finger komplett gelassen.
                          Das einzigste was nicht geht, der RPI2 Adapter lies sich nicht wiederherstellen (v3.0.2) Auch nach einem deinstallieren bekomme ich den nicht wieder.
                          host.Raspberry
                          	2026-04-15 16:48:36.071	info	iobroker exit 25
                          host.Raspberry
                          	2026-04-15 16:48:34.955	error	iobroker host.Raspberry Cannot install iobroker.rpi2@3.0.2: 1
                          host.Raspberry
                          	2026-04-15 16:48:34.953	error	iobroker npm error code 1npm error path /opt/iobroker/node_modules/iobroker.rpi2npm error command failednpm error command sh -c bash ./preinstall-check.shnpm error Checking package: libgpiod-dev >= 2.2npm error libgpiod-dev is not installednpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-15T14_48_28_153Z-debug-0.log
                          host.Raspberry
                          	2026-04-15 16:48:27.944	info	iobroker Installing iobroker.rpi2@3.0.2... (System call)
                          host.Raspberry
                          	2026-04-15 16:48:27.943	info	iobroker NPM version: 10.9.7
                          host.Raspberry
                          	2026-04-15 16:48:24.047	info	iobroker add rpi2 --host Raspberry
                          hier ein iob diag
                          ```bash
                          Script v.2026-01-31
                          *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                          OS is similar to:
                          Docker          : false
                          Kernel          : aarch64
                          Userland        : 64 bit
                           16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
                          CPU threads: 4
                          Current issues:
                                         Local time: Wed 2026-04-15 16:42:58 CEST
                                     Universal time: Wed 2026-04-15 14:42:58 UTC
                                           RTC time: n/a
                                        NTP service: active
                                    RTC in local TZ: no
                          marvman67
                          iobroker
                          HOME=/home/iobroker
                          Display-Manager:
                          Desktop:
                          Session:                tty
                          *** MEMORY ***
                          Mem:            4.0G        2.0G        1.1G         12M        909M        1.9G
                          Swap:           2.1G          0B        2.1G
                          Total:          6.1G        2.0G        3.3G
                          Active iob-Instances:   18
                                   3795 M total memory
                                   1947 M used memory
                                   1907 M active memory
                                    534 M inactive memory
                                   1080 M free memory
                                     96 M buffer memory
                                    770 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          top - 16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
                          Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
                          %Cpu(s):  1.9 us,  3.7 sy,  0.0 ni, 92.6 id,  1.9 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   3795.7 total,   1079.0 free,   1947.7 used,    867.8 buff/cache
                          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1848.0 avail Mem
                          *** FILESYSTEM ***
                          tmpfs          tmpfs     760M  9.1M  751M   2% /run
                          /dev/sda2      ext4      220G  6.6G  204G   4% /
                          /dev/sda1      vfat      505M   74M  432M  15% /boot/firmware
                          tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
                          [Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
                          [Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): mounted filesystem 687fa5d6-7e12-409f-8631-6b47ecc831af ro with ordered data mode. Quota mode: none.
                          [Wed Apr 15 16:23:09 2026] EXT4-fs (sda2): re-mounted 687fa5d6-7e12-409f-8631-6b47ecc831af r/w.
                          /var:
                          2.5G    /var/
                          231M    /var/cache
                          225M    /var/cache/apt
                          186M    /var/lib
                          146M    /var/lib/apt
                          5.8M    /opt/iobroker/backups/
                          202M    /opt/iobroker/iobroker-data/
                          180M    /opt/iobroker/iobroker-data/files
                          20M     /opt/iobroker/iobroker-data/objects.jsonl
                          8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
                          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                          3.7M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/assets/index-DS28Nms8.js
                          USB-Devices by-id:
                          /usr/bin/npm            10.9.7
                          /usr/bin/npx            10.9.7
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 184)
                          admin:          7.7.22
                          javascript:     9.0.18
                          Adapter State
                            system.adapter.cloud.0                  : cloud                 : Raspberry                                - disabled
                          + instance is alive
                          Objects and States
                          Objects:        5922
                          States:         4448
                          tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       18917      2872/io.socketio.0
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7089       958/sshd: /usr/sbin
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5180       1/init
                          tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6065       625/deCONZ
                          tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7106       625/deCONZ
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17701      2536/iobroker.js-co
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17696      2536/iobroker.js-co
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          7091       958/sshd: /usr/sbin
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          4095       1/init
                          tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17867      2567/io.admin.1
                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19806      2860/io.simple-api.
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18942      2900/io.web.0
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18547      2555/io.admin.0
                          udp        0      0 0.0.0.0:33244           0.0.0.0:*                           101        4790       619/avahi-daemon: r
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18957      2848/io.matter.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17133      2848/io.matter.0
                          udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       19780      2792/io.tr-064.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4788       619/avahi-daemon: r
                          udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       17132      2848/io.matter.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18174      2744/io.deconz.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       8239       625/deCONZ
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4241       1/init
                          udp6       0      0 fe80::ac82:ba7c:acc:546 :::*                                0          8254       693/NetworkManager
                          udp6       0      0 :::5353                 :::*                                1001       18958      2848/io.matter.0
                          udp6       0      0 :::5353                 :::*                                1001       17136      2848/io.matter.0
                          udp6       0      0 :::5353                 :::*                                101        4789       619/avahi-daemon: r
                          udp6       0      0 :::5540                 :::*                                1001       17131      2848/io.matter.0
                          udp6       0      0 :::1900                 :::*                                1001       18177      2744/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       18176      2744/io.deconz.0
                          udp6       0      0 :::1900                 :::*                                1001       18175      2744/io.deconz.0
                          udp6       0      0 :::34850                :::*                                101        4791       619/avahi-daemon: r
                          udp6       0      0 :::111                  :::*                                0          4242       1/init
                          2026-04-15 16:41:19.111  - info: matter.0 (2848) Preparing bridged device 12dac884-896a-4955-8fac-85635d860d45 "Bad Spiegel 3" for bridge
                          2026-04-15 16:41:19.269  - info: matter.0 (2848) Preparing bridged device c0f93364-0f42-4f41-90a9-cc3dce4d22c2 "Bad Spiegel 4" for bridge
                          2026-04-15 16:41:19.457  - info: matter.0 (2848) Preparing bridged device 82a95d66-641f-45ed-a070-6dd88a067ca0 "Computerzimmer Decke 1" for bridge
                          2026-04-15 16:41:19.585  - info: matter.0 (2848) Preparing bridged device 270b7502-23c8-4ab7-a490-fe11d20a48d0 "Computerzimmer Decke 2" for bridge
                          2026-04-15 16:41:19.706  - info: matter.0 (2848) Preparing bridged device 170ac091-af8a-45d2-884a-ec31345186ad "Flurlicht Telefon" for bridge
                          2026-04-15 16:41:19.853  - info: matter.0 (2848) Preparing bridged device ca7e0c6c-01ec-4025-8887-ab695a46d509 "Küche 1" for bridge
                          2026-04-15 16:41:19.970  - info: matter.0 (2848) Preparing bridged device 980e21e5-de18-457d-a0ff-8d74d0ecb22b "Küche 2" for bridge
                          2026-04-15 16:41:20.106  - info: matter.0 (2848) Preparing bridged device 1ce9fd49-2428-4b81-8262-4fffcb8ff0dc "Küche 3" for bridge
                          2026-04-15 16:41:20.233  - info: matter.0 (2848) Preparing bridged device 822a73fa-c98d-4861-ae74-ef74f322098e "Küche 4" for bridge
                          2026-04-15 16:41:20.347  - info: matter.0 (2848) Preparing bridged device 6f4b50d4-b9d6-45c2-b70e-1449fe45ff82 "Schlafzimmer Decke" for bridge
                          2026-04-15 16:41:20.484  - info: matter.0 (2848) Preparing bridged device bf9aa093-0a0f-49c4-a027-2908578847fd "Schlafzimmer Nachttischlampe" for bridge
                          2026-04-15 16:41:20.602  - info: matter.0 (2848) Preparing bridged device 71b3bc3e-2d8a-42d7-86d8-8c9caa8261ec "WZ Decke hinten" for bridge
                          2026-04-15 16:41:20.736  - info: matter.0 (2848) Preparing bridged device 70d546c5-da32-47e9-ae9a-93c5c2766f2d "WZ Decke vorne" for bridge
                          2026-04-15 16:41:20.849  - info: matter.0 (2848) Preparing bridged device a385531c-a983-4c83-827b-12924d8f1cfe "WZ Stehlampe 1" for bridge
                          2026-04-15 16:41:21.032  - info: matter.0 (2848) Preparing bridged device c93667f3-9f91-4f23-bf3b-965041c64cf5 "WZ Stehlampe 2" for bridge
                          2026-04-15 16:41:21.212  - info: matter.0 (2848) 2026-04-15 16:41:21.212 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c going online
                          2026-04-15 16:41:21.293  - info: matter.0 (2848) 2026-04-15 16:41:21.293 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c is online
                          2026-04-15 16:41:55.635  - info: alexa2.0 (2732) Using cached smart home devices list from Wed Apr 15 2026 16:25:23 GMT+0200 (Central European Summer Time)
                          2026-04-15 16:41:58.046  - info: alexa2.0 (2732) No smart home devices to query
                          2026-04-15 16:41:59.278  - info: alexa2.0 (2732) Subscribing to states...
                          2026-04-15 16:41:59.955  - info: javascript.0 (2662) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: matter.0 is connected
                          Wert: true
                          2026-04-15 16:42:01.063  - info: alexa2.0 (2732) Alexa-Push-Connection (macDms = true) established. Disable Polling
                          2026-04-15 16:42:15.838  - info: alexa2.0 (2732) Initialization Done ...
                          wie komm ich wieder zum RPI2 Adapter ?
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            host.Raspberry
                            hier ein iob diag
                            ```bash
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                            CPU threads: 4
                            Current issues:
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            marvman67
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           2.1G          0B        2.1G
                                     3795 M total memory
                                     1947 M used memory
                                     1080 M free memory
                                       96 M buffer memory
                                      770 M swap cache
                                     2047 M total swap
                                        0 M used swap
                                     2047 M free swap
                            *** FILESYSTEM ***
                            /var:
                            2.5G    /var/
                            231M    /var/cache
                            225M    /var/cache/apt
                            186M    /var/lib
                            146M    /var/lib/apt
                            USB-Devices by-id:
                            /usr/bin/npm            10.9.7
                            /usr/bin/npx            10.9.7
                            nodejs:
                              Version table:
                                 20.19.2+dfsg-1 500
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.7.22
                            javascript:     9.0.18
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        5922
                            States:         4448
                            Wert: true
                            Mit welchen Meldungen bekommst du den denn nicht installiert?
                              Michael Schmitt
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              host.Raspberry
                              Edit:
                              iobroker libgpiod-dev is not installed ?????
                                host.Raspberry
                                host.Raspberry
                                host.Raspberry
                                host.Raspberry
                                host.Raspberry
                                host.Raspberry
                                Edit:
                                Also nachinstallieren:
                                sudo apt update
                                sudo apt install libgpiod-dev
                                  Michael Schmitt
                                  Dankeeee jetzt ist alles da.
                                  Irgend eine Ahnung warum mein Swap selbst nach einer Neuinstallation so groß ist ?
                                    @Michael-Schmitt
                                    Nein. Könnte aber sein, dass die Größe bei aktuellen Neuinstallationen anders als bisher berechnet werden.
                                      So groß oder schon so stark in Gebrauch?
                                        Michael Schmitt
                                        Also ich denke nicht das der stark in Gebrauch ist, so viel hab ich nicht. Nur iobroker und Deconz.
                                        Was mir auch gefallen ist jetzt steht da
                                        marvman67@Raspberry:~ $ swapon --show
                                        /dev/zram0 partition   2G 3.3M  100
                                        davor war das
                                        /var/swap file 2G 5.8M -2
                                        wie gesagt hab ich nur komplett Neuinstalliert und Backups drauf gemacht.
                                          iob diag
                                          Script v.2026-01-31
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                          Current issues:
                                                           RTC time: n/a
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          marvman67
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                                   3795 M total memory
                                                   2452 M used memory
                                                    758 M free memory
                                                     56 M buffer memory
                                                    622 M swap cache
                                                   2047 M total swap
                                                      4 M used swap
                                                   2043 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          2.5G    /var/
                                          231M    /var/cache
                                          225M    /var/cache/apt
                                          187M    /var/lib
                                          USB-Devices by-id:
                                          /usr/bin/npm            10.9.7
                                          /usr/bin/npx            10.9.7
                                          nodejs:
                                            Version table:
                                               20.19.2+dfsg-1 500
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.7.22
                                          javascript:     9.0.18
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        5969
                                          States:         4431
                                          Gruß Michael
                                          Da hatten ich wohl das hier noch im Kopf
                                          83.2k
