<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Was bedeutet das ? rpi-resize-swap-file.]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
mir ist diese Meldung bei einem iob diag aufgefallen. Was bedeutet das und was ist zu tun ?</p>
<pre><code>  UNIT                         LOAD   ACTIVE SUB    DESCRIPTION
* rpi-resize-swap-file.service loaded failed failed rpi-resize-var-swap-service - resize swapfile
</code></pre>
<p dir="auto">iob diag</p>
<pre><code class="language-bash">Script v.2026-01-31
*** BASE SYSTEM ***
Operating System: Debian GNU/Linux 13 (trixie)
 Static hostname: Raspberry
       Icon name: computer
          Kernel: Linux 6.12.75+rpt-rpi-v8
    Architecture: arm64
OS is similar to:
Model           : Raspberry Pi 4 Model B Rev 1.2
Docker          : false
Virtualization  : none
Kernel          : aarch64
Userland        : 64 bit
Systemuptime and Load:
 15:07:25 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
CPU threads: 4
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'trixie'!
*** RASPBERRY THROTTLING ***
Current issues:
Previously detected issues:
*** TIME AND TIMEZONES ***
               Local time: Mon 2026-04-13 15:07:25 CEST
           Universal time: Mon 2026-04-13 13:07:25 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
marvman67
HOME=/home/marvman67
GROUPS=marvman67 adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
iobroker
HOME=/home/iobroker
SUDO_HOME=/home/marvman67
*** DISPLAY-SERVER SETUP ***
Display-Server:         false
Unit display-manager.service could not be found.
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:            4.0G        2.6G        795M        8.9M        712M        1.4G
Swap:           2.1G        4.2M        2.1G
Total:          6.1G        2.6G        2.9G
Active iob-Instances:   20
         3795 M total memory
         2452 M used memory
         1513 M active memory
         1309 M inactive memory
          758 M free memory
           56 M buffer memory
          622 M swap cache
         2047 M total swap
            4 M used swap
         2043 M free swap
top - 15:07:26 up 1 day,  3:18,  2 users,  load average: 0.60, 0.33, 0.30
Tasks: 205 total,   2 running, 203 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.0 us,  2.3 sy,  0.0 ni, 97.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3795.7 total,    758.5 free,   2452.8 used,    679.9 buff/cache
MiB Swap:   2048.0 total,   2044.0 free,      4.0 used.   1342.9 avail Mem
*** FAILED SERVICES ***
Legend: LOAD   -&gt; Reflects whether the unit definition was properly loaded.
        ACTIVE -&gt; The high-level unit activation state, i.e. generalization of SUB.
        SUB    -&gt; The low-level unit activation state, values depend on unit type.
1 loaded units listed.
*** DMESG CRITICAL ERRORS ***
No critical errors detected
*** FILESYSTEM ***
udev           devtmpfs  1.6G     0  1.6G   0% /dev
tmpfs          tmpfs     760M  9.3M  750M   2% /run
/dev/sda2      ext4      229G  7.1G  213G   4% /
tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
tmpfs          tmpfs     1.9G  2.9M  1.9G   1% /tmp
/dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
tmpfs          tmpfs     380M   12K  380M   1% /run/user/1000
[Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
[Sun Apr 12 11:48:57 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
[Sun Apr 12 11:49:00 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
Show mounted filesystems:
TARGET           SOURCE    FSTYPE OPTIONS
/                /dev/sda2 ext4   rw,noatime
`-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
/var:
2.5G    /var/
231M    /var/cache
225M    /var/cache/apt
187M    /var/lib
145M    /var/lib/apt/lists
Archived and active journals take up 8M in the file system.
/opt/iobroker/backups:
173M    /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
342M    /opt/iobroker/iobroker-data/
181M    /opt/iobroker/iobroker-data/files
116M    /opt/iobroker/iobroker-data/backup-objects
47M     /opt/iobroker/iobroker-data/files/admin.admin
46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
43M     /opt/iobroker/iobroker-data/objects.jsonl
19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
8.2M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BDfRPp5J.js
4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_13-49_objects.jsonl.gz
4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_11-49_objects.jsonl.gz
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
please always prefer the links 'by-id':
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2706986-if00
No nvbackup.json found.
*** NodeJS-Installation ***
/usr/bin/nodejs         v22.22.2
/usr/bin/node           v22.22.2
/usr/bin/npm            10.9.7
/usr/bin/npx            10.9.7
✓ Node.js installation is correct
nodejs:
  Installed: 22.22.2-1nodesource1
  Candidate: 22.22.2-1nodesource1
  Version table:
 *** 22.22.2-1nodesource1 1001
        500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
        100 /var/lib/dpkg/status
     22.22.1-1nodesource1 1001
     22.22.0-1nodesource1 1001
     22.21.0-1nodesource1 1001
     22.20.0-1nodesource1 1001
     22.19.0-1nodesource1 1001
     22.18.0-1nodesource1 1001
     22.17.1-1nodesource1 1001
     22.17.0-1nodesource1 1001
     22.16.0-1nodesource1 1001
     22.15.1-1nodesource1 1001
     22.15.0-1nodesource1 1001
     22.14.0-1nodesource1 1001
     22.13.1-1nodesource1 1001
     22.13.0-1nodesource1 1001
     22.12.0-1nodesource1 1001
     22.11.0-1nodesource1 1001
     22.10.0-1nodesource1 1001
     22.9.0-1nodesource1 1001
     22.8.0-1nodesource1 1001
     22.7.0-1nodesource1 1001
     22.6.0-1nodesource1 1001
     22.5.1-1nodesource1 1001
     22.5.0-1nodesource1 1001
     22.4.1-1nodesource1 1001
     22.4.0-1nodesource1 1001
     22.3.0-1nodesource1 1001
     22.2.0-1nodesource1 1001
     22.1.0-1nodesource1 1001
     22.0.0-1nodesource1 1001
     20.19.2+dfsg-1+deb13u2 500
        500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
     20.19.2+dfsg-1 500
        500 http://deb.debian.org/debian trixie/main arm64 Packages
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 98290)
Core adapters versions
js-controller:  7.0.7
admin:          7.7.22
javascript:     9.0.18
nodejs modules from github:     0
Adapter State
+ system.adapter.admin.0                  : admin                 : Raspberry                                -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
+ system.adapter.admin.1                  : admin                 : Raspberry                                -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
+ system.adapter.alexa2.0                 : alexa2                : Raspberry                                -  enabled
+ system.adapter.backitup.0               : backitup              : Raspberry                                -  enabled
+ system.adapter.cloud.0                  : cloud                 : Raspberry                                -  enabled
+ system.adapter.deconz.0                 : deconz                : Raspberry                                -  enabled, port: 80
  system.adapter.devices.0                : devices               : Raspberry                                - disabled
+ system.adapter.email.0                  : email                 : Raspberry                                -  enabled
+ system.adapter.fritzdect.0              : fritzdect             : Raspberry                                -  enabled
+ system.adapter.history.0                : history               : Raspberry                                -  enabled
  system.adapter.ical.0                   : ical                  : Raspberry                                -  enabled
  system.adapter.iot.0                    : iot                   : Raspberry                                - disabled
+ system.adapter.iqontrol.0               : iqontrol              : Raspberry                                -  enabled
+ system.adapter.javascript.0             : javascript            : Raspberry                                -  enabled
+ system.adapter.matter.0                 : matter                : Raspberry                                -  enabled
+ system.adapter.rpi2.0                   : rpi2                  : Raspberry                                -  enabled
+ system.adapter.simple-api.0             : simple-api            : Raspberry                                -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
+ system.adapter.socketio.0               : socketio              : Raspberry                                -  enabled, port: 8084, bind: 192.168.178.42, run as: admin
+ system.adapter.telegram.0               : telegram              : Raspberry                                -  enabled, port: 8443, bind: 0.0.0.0
+ system.adapter.tr-064.0                 : tr-064                : Raspberry                                -  enabled
+ system.adapter.trashschedule.0          : trashschedule         : Raspberry                                -  enabled
+ system.adapter.web.0                    : web                   : Raspberry                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
+ instance is alive
ioBroker-Repositories
│ (index) │ name            │ url                                                     │ auto upgrade │
│ 0       │ 'stable'        │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
│ 1       │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: stable
Adapter    "admin"        : 7.7.22   , installed 7.7.22
Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
Adapter    "backitup"     : 3.3.14   , installed 3.3.14
Adapter    "cloud"        : 5.0.1    , installed 5.0.1
Adapter    "deconz"       : 1.7.4    , installed 1.7.4
Adapter    "devices"      : 1.2.14   , installed 1.2.14
Adapter    "email"        : 2.0.4    , installed 2.0.4
Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
Adapter    "history"      : 4.0.0    , installed 4.0.0
Adapter    "ical"         : 1.19.7   , installed 1.19.7
Adapter    "iot"          : 5.0.12   , installed 5.0.12
Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
Adapter    "javascript"   : 9.0.18   , installed 9.0.18
Controller "js-controller": 7.0.7    , installed 7.0.7
Adapter    "matter"       : 0.5.6    , installed 1.0.0
Adapter    "rpi2"         : 3.0.2    , installed 3.0.2
Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
Adapter    "socketio"     : 7.0.8    , installed 7.0.8
Adapter    "trashschedule": 3.3.0    , installed 3.3.0
Adapter    "web"          : 8.0.0    , installed 8.0.0
Adapter    "ws"           : 4.0.0    , installed 4.0.0
Objects and States
Objects:        5969
States:         4431
Hit:1 http://deb.debian.org/debian trixie InRelease
Hit:2 http://deb.debian.org/debian trixie-updates InRelease
Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
Hit:4 http://phoscon.de/apt/deconz generic InRelease
Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
Reading package lists...
Pending systemupdates: 4
*** Listening Ports ***
tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       6655       632/deCONZ
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       5895       632/deCONZ
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4211       1/init
tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       11463      1697/io.socketio.0
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8540       1216/sshd: /usr/sbi
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6144       1203/iobroker.js-co
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6139       1203/iobroker.js-co
tcp6       0      0 :::111                  :::*                    LISTEN      0          901        1/init
tcp6       0      0 :::22                   :::*                    LISTEN      0          8542       1216/sshd: /usr/sbi
tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9906       1685/io.simple-api.
tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12294      1725/io.web.0
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       8038       1283/io.admin.0
tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9052       1291/io.admin.1
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       11479      1665/io.matter.0
udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       7125       1559/io.tr-064.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4945       628/avahi-daemon: r
udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       11478      1665/io.matter.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       15004      2525/io.deconz.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       6676       632/deCONZ
udp        0      0 0.0.0.0:34805           0.0.0.0:*                           101        4947       628/avahi-daemon: r
udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          2652       1/init
udp6       0      0 :::5353                 :::*                                1001       11482      1665/io.matter.0
udp6       0      0 :::5353                 :::*                                101        4946       628/avahi-daemon: r
udp6       0      0 :::5540                 :::*                                1001       11477      1665/io.matter.0
udp6       0      0 :::1900                 :::*                                1001       15007      2525/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       15006      2525/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       15005      2525/io.deconz.0
udp6       0      0 :::111                  :::*                                0          2653       1/init
udp6       0      0 :::57875                :::*                                101        4948       628/avahi-daemon: r
udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6109       704/NetworkManager
2026-04-13 09:30:00.066  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 58968
2026-04-13 09:30:09.853  - info: host.Raspberry instance system.adapter.ical.0 having pid 58968 terminated with code 0 (NO_ERROR)
2026-04-13 10:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 61569
2026-04-13 10:30:09.776  - info: host.Raspberry instance system.adapter.ical.0 having pid 61569 terminated with code 0 (NO_ERROR)
2026-04-13 11:30:00.073  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 64157
2026-04-13 11:30:09.934  - info: host.Raspberry instance system.adapter.ical.0 having pid 64157 terminated with code 0 (NO_ERROR)
2026-04-13 11:49:35.045  - info: admin.0 (1283) Adapter rating updated
2026-04-13 11:49:42.144  - info: admin.1 (1291) Adapter rating updated
2026-04-13 12:30:00.116  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 66781
2026-04-13 12:30:09.734  - info: host.Raspberry instance system.adapter.ical.0 having pid 66781 terminated with code 0 (NO_ERROR)
2026-04-13 12:55:43.589  - info: javascript.0 (1382) script.js.common.Anwesendheitscheck.Marvin_PC_AN_AUS_Wlan: telegram[Michael]: 12:55 Uhr. PC von Marvin wurde ausgeschalten.
2026-04-13 13:00:22.692  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
2026-04-13 13:00:27.064  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
2026-04-13 13:03:00.018  - info: javascript.0 (1382) script.js.common.Wichtig.24Std_Sensor_Zeitstempel_nicht_aktualisiert: telegram[Michael]: 24 Stunden keine Änderung bei Wohnzimmer_Lichtschalter, SZ_TV_Schalter_Steckdose, Bad Spiegel, Rauchmelder_Schlafzimmer, Rauchmelder_Flur, Rauchmelder_WZ, CO_Sensor_Küche, . Eventuell ist die Batterie leer?
2026-04-13 13:30:00.061  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 69380
2026-04-13 13:30:09.633  - info: host.Raspberry instance system.adapter.ical.0 having pid 69380 terminated with code 0 (NO_ERROR)
2026-04-13 13:59:09.505  - info: admin.0 (1283) Request actual repository...
2026-04-13 13:59:10.563  - info: host.Raspberry Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
2026-04-13 13:59:21.691  - info: admin.0 (1283) Repository received successfully.
2026-04-13 14:30:00.043  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 71972
2026-04-13 14:30:10.418  - warn: ical.0 (71972) get state error: Connection is closed.
2026-04-13 14:30:10.503  - info: host.Raspberry instance system.adapter.ical.0 having pid 71972 terminated with code 0 (NO_ERROR)
2026-04-13 14:39:38.092  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde geöffnet.
2026-04-13 14:39:44.177  - info: javascript.0 (1382) script.js.common.Tür_Fenster_Sensoren.Fenster-Tür_geöffnet: telegram[Michael]: Wohnungstür wurde wieder geschlossen.
2026-04-13 14:51:30.503  - info: admin.0 (1283) ==&gt; Connected system.user.admin from ::ffff:192.168.178.29
</code></pre>
<p dir="auto">Gruß Michael</p>
]]></description><link>https://forum.iobroker.net/topic/84289/was-bedeutet-das-rpi-resize-swap-file.</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 11:31:53 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84289.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Apr 2026 13:14:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Thu, 16 Apr 2026 17:09:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1334964">sagte</a>:</p>
<p dir="auto">was auch immer das bedeutet</p>
</blockquote>
<p dir="auto">Das bedeutet, dass zwar zram angelegt und verwendet wird, die Auslaastung aber so gering ist, dass nicht noch der 'Notüberlauf' in Form der klassischen SWAP-Datei erfordeerlich ist. In dem Fall würdest du da zwei Geräte-Zeilen sehen.</p>
]]></description><link>https://forum.iobroker.net/post/1334980</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334980</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Thu, 16 Apr 2026 17:09:00 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Thu, 16 Apr 2026 15:46:46 GMT]]></title><description><![CDATA[<p dir="auto">was auch immer das bedeutet</p>
<pre><code>marvman67@Raspberry:~ $ zramctl
NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram0 zstd            2G   4K   64B   20K       4 [SWAP]
</code></pre>
<pre><code>marvman67@Raspberry:~ $ swapon --show
NAME       TYPE      SIZE USED PRIO
/dev/zram0 partition   2G   0B  100
</code></pre>
<p dir="auto">werd das mal so alles lassen und schauen wie es mit dem zram nun läuft</p>
]]></description><link>https://forum.iobroker.net/post/1334964</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334964</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Thu, 16 Apr 2026 15:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 18:25:29 GMT]]></title><description><![CDATA[<p dir="auto">Werde ich mir morgen mal anschauen.</p>
]]></description><link>https://forum.iobroker.net/post/1334857</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334857</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 18:25:29 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 18:18:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a></p>
<p dir="auto">rpi-swap: Newer images (Trixie) use the rpi-swap service to manage both ZRAM and a reduced-size fallback swap file.</p>
<p dir="auto">Wird also schon gemacht.</p>
<p dir="auto">Edit: Die Konfiguration steht in der</p>
<pre><code>cat /etc/rpi/swap.conf
</code></pre>
<p dir="auto">drin.<br />
Edit 2: Und mit</p>
<pre><code>zramctl
</code></pre>
<p dir="auto">kann man die Verteilung prüfen .</p>
]]></description><link>https://forum.iobroker.net/post/1334852</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334852</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 15 Apr 2026 18:18:37 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 17:37:43 GMT]]></title><description><![CDATA[<p dir="auto">Na dann liegt es mal nicht an mir, das ist schonmal beruhigend. Was ich nun so im Internet lesen konnte soll es sinnvoll sein swap trotzdem zum aktivieren. Da zram ja im Ram liegt (komprimiert) und man damit weniger Ram hat. So soll es gut sein trotzdem swap zu aktivieren. Damit der Raspi bei Lastspitzen auf die 2.1gb zugreifen kann. Ist dem so ?</p>
]]></description><link>https://forum.iobroker.net/post/1334851</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334851</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 17:37:43 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 17:31:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a></p>
<p dir="auto">Offenbar neue default-Einstellungen. Ist mir bis dato gar nicht aufgefallen, mein letzte Woche frisch aufgesetzter Testpi läuft jetzt auch so:</p>
<pre><code>*** MEMORY ***
Mem:            4.0G        751M        2.4G         12M        891M        3.2G
Swap:           2.1G          0B        2.1G
Total:          6.1G        751M        4.6G
</code></pre>
<pre><code>thomas@testpi:~ $ swapon --show
thomas@testpi:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1334850</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334850</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 15 Apr 2026 17:31:19 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 16:56:09 GMT]]></title><description><![CDATA[<p dir="auto">aber warum ist es nun nach der Neuinstallation "zram" und nicht swap</p>
]]></description><link>https://forum.iobroker.net/post/1334847</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334847</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 16:56:09 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 16:55:09 GMT]]></title><description><![CDATA[<p dir="auto">Da hatten ich wohl das hier noch im Kopf</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1334381">sagte</a>:</p>
<p dir="auto">Swap:           2.1G        <strong>4.2M</strong>        2.1G</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/1334846</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334846</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Wed, 15 Apr 2026 16:55:09 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 16:41:24 GMT]]></title><description><![CDATA[<p dir="auto">Also ich denke nicht das der stark in Gebrauch ist, so viel hab ich nicht. Nur iobroker und Deconz.</p>
<p dir="auto">Was mir auch gefallen ist jetzt steht da</p>
/dev/zram0 partition   2G 3.3M  100
</code></pre>
<p dir="auto">davor war das</p>
/var/swap file 2G 5.8M -2
</code></pre>
<p dir="auto">wie gesagt hab ich nur komplett Neuinstalliert und Backups drauf gemacht.</p>
]]></description><link>https://forum.iobroker.net/post/1334845</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334845</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 16:41:24 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 16:07:32 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1334837">sagte</a>:</p>
<p dir="auto">Irgend eine Ahnung warum mein Swap selbst nach einer Neuinstallation so groß ist ?</p>
</blockquote>
<p dir="auto">So groß oder schon so stark in Gebrauch?</p>
]]></description><link>https://forum.iobroker.net/post/1334842</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334842</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Wed, 15 Apr 2026 16:07:32 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 15:48:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a></p>
<p dir="auto">Nein. Könnte aber sein, dass die Größe bei aktuellen Neuinstallationen anders als bisher berechnet werden.</p>
]]></description><link>https://forum.iobroker.net/post/1334839</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334839</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 15 Apr 2026 15:48:51 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 15:33:11 GMT]]></title><description><![CDATA[<p dir="auto">Dankeeee jetzt ist alles da.</p>
]]></description><link>https://forum.iobroker.net/post/1334837</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334837</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 15:33:11 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 15:27:42 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1334835">sagte</a>:</p>
<p dir="auto">libgpiod-dev is not installed</p>
</blockquote>
<p dir="auto">Also nachinstallieren:</p>
<pre><code>sudo apt update
sudo apt install libgpiod-dev
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1334836</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334836</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 15 Apr 2026 15:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 15:27:52 GMT]]></title><description><![CDATA[<pre><code>host.Raspberry
	2026-04-15 16:48:36.071	info	iobroker exit 25
host.Raspberry
	2026-04-15 16:48:34.955	error	iobroker host.Raspberry Cannot install iobroker.rpi2@3.0.2: 1
host.Raspberry
	2026-04-15 16:48:34.953	error	iobroker npm error code 1npm error path /opt/iobroker/node_modules/iobroker.rpi2npm error command failednpm error command sh -c bash ./preinstall-check.shnpm error Checking package: libgpiod-dev &gt;= 2.2npm error libgpiod-dev is not installednpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2026-04-15T14_48_28_153Z-debug-0.log
host.Raspberry
	2026-04-15 16:48:27.944	info	iobroker Installing iobroker.rpi2@3.0.2... (System call)
host.Raspberry
	2026-04-15 16:48:27.943	info	iobroker NPM version: 10.9.7
host.Raspberry
	2026-04-15 16:48:24.047	info	iobroker add rpi2 --host Raspberry
</code></pre>
<p dir="auto">Edit:<br />
iobroker libgpiod-dev is not installed  ?????</p>
]]></description><link>https://forum.iobroker.net/post/1334835</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334835</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 15:27:52 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 15:24:44 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1334832">sagte</a>:</p>
<p dir="auto">wie komm ich wieder zum RPI2 Adapter ?</p>
</blockquote>
<p dir="auto">Mit welchen Meldungen bekommst du den denn nicht installiert?</p>
]]></description><link>https://forum.iobroker.net/post/1334834</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334834</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 15 Apr 2026 15:24:44 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Wed, 15 Apr 2026 14:50:44 GMT]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
so ich hab jetzt alles neu gemacht und hab immer noch 2,1gb swap keine Ahnung warum. Kann das an meiner SSD (240gb) liegen ? Von swap hab ich die Finger komplett gelassen.<br />
Das einzigste was nicht geht, der RPI2 Adapter lies sich nicht wiederherstellen (v3.0.2) Auch nach einem deinstallieren bekomme ich den nicht wieder.</p>
host.Raspberry
host.Raspberry
host.Raspberry
host.Raspberry
host.Raspberry
</code></pre>
<p dir="auto">hier ein iob diag</p>
<pre><code>```bash
Script v.2026-01-31
*** BASE SYSTEM ***
       Icon name: computer
    Architecture: arm64
OS is similar to:
Docker          : false
Kernel          : aarch64
Userland        : 64 bit
 16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
CPU threads: 4
Current issues:
               Local time: Wed 2026-04-15 16:42:58 CEST
           Universal time: Wed 2026-04-15 14:42:58 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
marvman67
iobroker
HOME=/home/iobroker
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:            4.0G        2.0G        1.1G         12M        909M        1.9G
Swap:           2.1G          0B        2.1G
Total:          6.1G        2.0G        3.3G
Active iob-Instances:   18
         3795 M total memory
         1947 M used memory
         1907 M active memory
          534 M inactive memory
         1080 M free memory
           96 M buffer memory
          770 M swap cache
         2047 M total swap
            0 M used swap
         2047 M free swap
top - 16:42:58 up 19 min,  1 user,  load average: 1.56, 1.63, 1.04
Tasks: 215 total,   1 running, 214 sleeping,   0 stopped,   0 zombie
%Cpu(s):  1.9 us,  3.7 sy,  0.0 ni, 92.6 id,  1.9 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3795.7 total,   1079.0 free,   1947.7 used,    867.8 buff/cache
MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1848.0 avail Mem
0 loaded units listed.
*** FILESYSTEM ***
tmpfs          tmpfs     760M  9.1M  751M   2% /run
/dev/sda2      ext4      220G  6.6G  204G   4% /
/dev/sda1      vfat      505M   74M  432M  15% /boot/firmware
tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
[Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
[Wed Apr 15 16:23:06 2026] EXT4-fs (sda2): mounted filesystem 687fa5d6-7e12-409f-8631-6b47ecc831af ro with ordered data mode. Quota mode: none.
[Wed Apr 15 16:23:09 2026] EXT4-fs (sda2): re-mounted 687fa5d6-7e12-409f-8631-6b47ecc831af r/w.
/var:
2.5G    /var/
231M    /var/cache
225M    /var/cache/apt
186M    /var/lib
146M    /var/lib/apt
5.8M    /opt/iobroker/backups/
202M    /opt/iobroker/iobroker-data/
180M    /opt/iobroker/iobroker-data/files
20M     /opt/iobroker/iobroker-data/objects.jsonl
8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
3.7M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/assets/index-DS28Nms8.js
USB-Devices by-id:
/usr/bin/npm            10.9.7
/usr/bin/npx            10.9.7
nodejs:
  Version table:
     20.19.2+dfsg-1 500
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 184)
admin:          7.7.22
javascript:     9.0.18
Adapter State
  system.adapter.cloud.0                  : cloud                 : Raspberry                                - disabled
+ instance is alive
Objects and States
Objects:        5922
States:         4448
Pending systemupdates: 0
tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       18917      2872/io.socketio.0
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7089       958/sshd: /usr/sbin
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5180       1/init
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6065       625/deCONZ
tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7106       625/deCONZ
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17701      2536/iobroker.js-co
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17696      2536/iobroker.js-co
tcp6       0      0 :::22                   :::*                    LISTEN      0          7091       958/sshd: /usr/sbin
tcp6       0      0 :::111                  :::*                    LISTEN      0          4095       1/init
tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17867      2567/io.admin.1
tcp6       0      0 :::8087                 :::*                    LISTEN      1001       19806      2860/io.simple-api.
tcp6       0      0 :::8082                 :::*                    LISTEN      1001       18942      2900/io.web.0
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18547      2555/io.admin.0
udp        0      0 0.0.0.0:33244           0.0.0.0:*                           101        4790       619/avahi-daemon: r
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       18957      2848/io.matter.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       17133      2848/io.matter.0
udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       19780      2792/io.tr-064.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        4788       619/avahi-daemon: r
udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       17132      2848/io.matter.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       18174      2744/io.deconz.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       8239       625/deCONZ
udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4241       1/init
udp6       0      0 fe80::ac82:ba7c:acc:546 :::*                                0          8254       693/NetworkManager
udp6       0      0 :::5353                 :::*                                1001       18958      2848/io.matter.0
udp6       0      0 :::5353                 :::*                                1001       17136      2848/io.matter.0
udp6       0      0 :::5353                 :::*                                101        4789       619/avahi-daemon: r
udp6       0      0 :::5540                 :::*                                1001       17131      2848/io.matter.0
udp6       0      0 :::1900                 :::*                                1001       18177      2744/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       18176      2744/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       18175      2744/io.deconz.0
udp6       0      0 :::34850                :::*                                101        4791       619/avahi-daemon: r
udp6       0      0 :::111                  :::*                                0          4242       1/init
2026-04-15 16:41:19.111  - info: matter.0 (2848) Preparing bridged device 12dac884-896a-4955-8fac-85635d860d45 "Bad Spiegel 3" for bridge
2026-04-15 16:41:19.269  - info: matter.0 (2848) Preparing bridged device c0f93364-0f42-4f41-90a9-cc3dce4d22c2 "Bad Spiegel 4" for bridge
2026-04-15 16:41:19.457  - info: matter.0 (2848) Preparing bridged device 82a95d66-641f-45ed-a070-6dd88a067ca0 "Computerzimmer Decke 1" for bridge
2026-04-15 16:41:19.585  - info: matter.0 (2848) Preparing bridged device 270b7502-23c8-4ab7-a490-fe11d20a48d0 "Computerzimmer Decke 2" for bridge
2026-04-15 16:41:19.706  - info: matter.0 (2848) Preparing bridged device 170ac091-af8a-45d2-884a-ec31345186ad "Flurlicht Telefon" for bridge
2026-04-15 16:41:19.853  - info: matter.0 (2848) Preparing bridged device ca7e0c6c-01ec-4025-8887-ab695a46d509 "Küche 1" for bridge
2026-04-15 16:41:19.970  - info: matter.0 (2848) Preparing bridged device 980e21e5-de18-457d-a0ff-8d74d0ecb22b "Küche 2" for bridge
2026-04-15 16:41:20.106  - info: matter.0 (2848) Preparing bridged device 1ce9fd49-2428-4b81-8262-4fffcb8ff0dc "Küche 3" for bridge
2026-04-15 16:41:20.233  - info: matter.0 (2848) Preparing bridged device 822a73fa-c98d-4861-ae74-ef74f322098e "Küche 4" for bridge
2026-04-15 16:41:20.347  - info: matter.0 (2848) Preparing bridged device 6f4b50d4-b9d6-45c2-b70e-1449fe45ff82 "Schlafzimmer Decke" for bridge
2026-04-15 16:41:20.484  - info: matter.0 (2848) Preparing bridged device bf9aa093-0a0f-49c4-a027-2908578847fd "Schlafzimmer Nachttischlampe" for bridge
2026-04-15 16:41:20.602  - info: matter.0 (2848) Preparing bridged device 71b3bc3e-2d8a-42d7-86d8-8c9caa8261ec "WZ Decke hinten" for bridge
2026-04-15 16:41:20.736  - info: matter.0 (2848) Preparing bridged device 70d546c5-da32-47e9-ae9a-93c5c2766f2d "WZ Decke vorne" for bridge
2026-04-15 16:41:20.849  - info: matter.0 (2848) Preparing bridged device a385531c-a983-4c83-827b-12924d8f1cfe "WZ Stehlampe 1" for bridge
2026-04-15 16:41:21.032  - info: matter.0 (2848) Preparing bridged device c93667f3-9f91-4f23-bf3b-965041c64cf5 "WZ Stehlampe 2" for bridge
2026-04-15 16:41:21.212  - info: matter.0 (2848) 2026-04-15 16:41:21.212 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c going online
2026-04-15 16:41:21.293  - info: matter.0 (2848) 2026-04-15 16:41:21.293 NOTICE Node fe2b4fb3-d31d-4c1d-943c-afc35bb3c55c is online
2026-04-15 16:41:55.635  - info: alexa2.0 (2732) Using cached smart home devices list from Wed Apr 15 2026 16:25:23 GMT+0200 (Central European Summer Time)
2026-04-15 16:41:58.046  - info: alexa2.0 (2732) No smart home devices to query
2026-04-15 16:41:59.278  - info: alexa2.0 (2732) Subscribing to states...
2026-04-15 16:41:59.955  - info: javascript.0 (2662) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: matter.0 is connected
Wert: true
Adapter ist wieder erreichbar
2026-04-15 16:42:01.063  - info: alexa2.0 (2732) Alexa-Push-Connection (macDms = true) established. Disable Polling
2026-04-15 16:42:15.838  - info: alexa2.0 (2732) Initialization Done ...
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1334832</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334832</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Wed, 15 Apr 2026 14:50:44 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 16:42:14 GMT]]></title><description><![CDATA[<p dir="auto">ich werd das jetzt mal so lassen und beobachten, wenn es Probleme gibt mach ich einfach alles neu ;)</p>
]]></description><link>https://forum.iobroker.net/post/1334436</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334436</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Mon, 13 Apr 2026 16:42:14 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 16:40:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a></p>
<p dir="auto">Irgendwas ist jedenfalls auf deiner Kiste grundsätzlich anders als auf meiner...</p>
]]></description><link>https://forum.iobroker.net/post/1334434</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334434</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 13 Apr 2026 16:40:03 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 16:38:31 GMT]]></title><description><![CDATA[<p dir="auto">Ich hatte mal die swappiness auf 40 gesetzt aber mehr nicht und wenn ich mich recht erinnere dann aber nochmal komplett neu aufgesetzt und wieder nur swappines auf 40.</p>
]]></description><link>https://forum.iobroker.net/post/1334433</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334433</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Mon, 13 Apr 2026 16:38:31 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 16:32:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a></p>
<p dir="auto">Hattest du da in der Vergangenheit selber schon was umgestellt?<br />
Denn die Voreinstellung für ein frisches Debian 13 'Trixie' ist</p>
<p dir="auto">536MB:</p>
Mem:            8.2G        4.4G        2.8G         11M        1.1G        3.8G
Swap:           536M          0B        536M
Total:          8.7G        4.4G        3.3G
Active iob-Instances:   37
         7819 M total memory
         4201 M used memory
         4218 M active memory
          631 M inactive memory
         2673 M free memory
          105 M buffer memory
          948 M swap cache
          511 M total swap
            0 M used swap
          511 M free swap
</code></pre>
<p dir="auto">Und auf meinem System gibt es den Service auch erst gar nicht:</p>
<pre><code>echad@chet:~ $  systemctl status rpi-resize-swap-file.service
Unit rpi-resize-swap-file.service could not be found.
echad@chet:~ $
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1334429</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334429</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 13 Apr 2026 16:32:52 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 15:40:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">ich hab nun folgendes gemacht.</p>
<p dir="auto">sudo nano /etc/rpi/swap.conf</p>
<p dir="auto">und dort das eingetragen<br />
FixedSizeMiB=2048</p>
<p dir="auto">dann<br />
sudo swapoff /var/swap<br />
sudo systemctl restart rpi-swap.service</p>
<p dir="auto">ceck mit swapon --show</p>
<p dir="auto">NAME      TYPE SIZE USED PRIO<br />
/var/swap file   2G   0B   -2</p>
<p dir="auto">so wie ich im Internet gelesen habe kontrolliert das "rpi-resize-swap-file.service" nur ob die swap Größe richtig ist und das ist  sie ja nun.</p>
<p dir="auto">Dmit nun die Fehlermeldung nicht mehr kommt habe ich den Dienst deaktiviert.<br />
sudo systemctl mask rpi-resize-swap-file.service</p>
<p dir="auto">systemctl status var-swap.swap</p>
<pre><code>marvman67@Raspberry:~ $ systemctl status var-swap.swap
● var-swap.swap - /var/swap
     Loaded: loaded (/etc/fstab; generated)
     Active: active since Mon 2026-04-13 17:07:09 CEST; 27min ago
 Invocation: 4e3dc8887e5c4b70b12060987cb2294e
       What: /var/swap
       Docs: man:fstab(5)
             man:systemd-fstab-generator(8)
      Tasks: 0 (limit: 3924)
        CPU: 33ms
     CGroup: /system.slice/var-swap.swap
Apr 13 17:07:09 Raspberry systemd[1]: Activating swap var-swap.swap - /var/swap...
Apr 13 17:07:09 Raspberry systemd[1]: Activated swap var-swap.swap - /var/swap.
</code></pre>
<p dir="auto">aktuelles iob diag nach reboot</p>
<pre><code>```bash
Script v.2026-01-31
*** BASE SYSTEM ***
       Icon name: computer
    Architecture: arm64
OS is similar to:
Docker          : false
Kernel          : aarch64
Userland        : 64 bit
 17:36:16 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
CPU threads: 4
Current issues:
               Local time: Mon 2026-04-13 17:36:17 CEST
           Universal time: Mon 2026-04-13 15:36:17 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
marvman67
iobroker
HOME=/home/iobroker
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:            4.0G        2.3G        944M         12M        853M        1.7G
Swap:           2.1G          0B        2.1G
Total:          6.1G        2.3G        3.1G
         3795 M total memory
         2179 M used memory
         2139 M active memory
          544 M inactive memory
          901 M free memory
           76 M buffer memory
          737 M swap cache
         2047 M total swap
            0 M used swap
         2047 M free swap
top - 17:36:17 up 28 min,  1 user,  load average: 0.50, 0.31, 0.35
Tasks: 201 total,   1 running, 200 sleeping,   0 stopped,   0 zombie
%Cpu(s):  4.4 us,  0.0 sy,  0.0 ni, 95.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3795.7 total,    901.0 free,   2179.5 used,    814.0 buff/cache
MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1616.2 avail Mem
*** FILESYSTEM ***
[Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
[Mon Apr 13 17:07:24 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
[Mon Apr 13 17:07:27 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
/var:
2.5G    /var/
231M    /var/cache
225M    /var/cache/apt
187M    /var/lib
349M    /opt/iobroker/iobroker-data/
46M     /opt/iobroker/iobroker-data/objects.jsonl
6.5M    /opt/iobroker/iobroker-data/states.jsonl
4.7M    /opt/iobroker/iobroker-data/backup-objects/2026-04-13_15-49_objects.jsonl.gz
USB-Devices by-id:
/usr/bin/npm            10.9.7
/usr/bin/npx            10.9.7
nodejs:
  Version table:
     20.19.2+dfsg-1 500
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 1718)
admin:          7.7.22
javascript:     9.0.18
Adapter State
+ instance is alive
Objects and States
Objects:        5969
States:         4431
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8398       1093/iobroker.js-co
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       8403       1093/iobroker.js-co
tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       7319       589/deCONZ
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4221       1/init
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       6036       589/deCONZ
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9381       1105/sshd: /usr/sbi
tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       8917       1532/io.socketio.0
tcp6       0      0 :::111                  :::*                    LISTEN      0          302        1/init
tcp6       0      0 :::22                   :::*                    LISTEN      0          9383       1105/sshd: /usr/sbi
tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9670       1159/io.admin.1
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6879       1151/io.admin.0
tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8945       1572/io.web.0
tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10403      1520/io.simple-api.
udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1442       1/init
udp        0      0 0.0.0.0:57509           0.0.0.0:*                           101        6249       585/avahi-daemon: r
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8953       1508/io.matter.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       8056       1508/io.matter.0
udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10337      1419/io.tr-064.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6247       585/avahi-daemon: r
udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       8055       1508/io.matter.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10729      1781/io.deconz.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       7333       589/deCONZ
udp6       0      0 :::111                  :::*                                0          1443       1/init
udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          6802       780/NetworkManager
udp6       0      0 :::38101                :::*                                101        6250       585/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                1001       8954       1508/io.matter.0
udp6       0      0 :::5353                 :::*                                1001       8059       1508/io.matter.0
udp6       0      0 :::5353                 :::*                                101        6248       585/avahi-daemon: r
udp6       0      0 :::5540                 :::*                                1001       8054       1508/io.matter.0
udp6       0      0 :::1900                 :::*                                1001       10732      1781/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       10731      1781/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       10730      1781/io.deconz.0
2026-04-13 17:13:05.053  - info: host.Raspberry stopInstance system.adapter.deconz.0 (force=false, process=true)
2026-04-13 17:13:05.061  - info: deconz.0 (1371) Got terminate signal TERMINATE_YOURSELF
2026-04-13 17:13:05.071  - info: deconz.0 (1371) cleaned everything up...
2026-04-13 17:13:05.072  - info: deconz.0 (1371) terminating
2026-04-13 17:13:05.073  - info: deconz.0 (1371) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2026-04-13 17:13:05.176  - info: host.Raspberry stopInstance system.adapter.deconz.0 send kill signal
2026-04-13 17:13:05.577  - info: deconz.0 (1371) terminating
2026-04-13 17:13:05.792  - info: host.Raspberry instance system.adapter.deconz.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2026-04-13 17:13:09.725  - info: host.Raspberry instance system.adapter.deconz.0 in version "1.7.4" started with pid 1781
2026-04-13 17:13:12.430  - info: deconz.0 (1781) starting. Version 1.7.4 in /opt/iobroker/node_modules/iobroker.deconz, node: v22.22.2, js-controller: 7.0.7
2026-04-13 17:13:12.588  - info: deconz.0 (1781) deConz Version: 2.32.5; API version: 1.16.0
2026-04-13 17:13:34.462  - info: web.0 (1572) ==&gt; Connected system.user.admin from ::ffff:192.168.178.29
2026-04-13 17:13:35.843  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
Wert: false
Adapter NICHT erreichbar
2026-04-13 17:13:36.889  - info: javascript.0 (1257) script.js.common.Wichtig.Sensor_erreichbar: telegram[Michael]: Kanal ID: deconz.0.Sensors.146
Name: Bewegungsmelder Flur 4 Tür SZ reachable
Wert: true
Sensor ist wieder erreichbar
2026-04-13 17:13:57.519  - info: javascript.0 (1257) script.js.common.Wichtig.System_Adapter_wahr_falsch_TEST: telegram[Michael]: Adapter: deconz.0 is connected
Wert: true
2026-04-13 17:20:12.613  - info: web.0 (1572) &lt;== Disconnect system.user.admin from ::ffff:192.168.178.29 iqontrol.0
2026-04-13 17:30:00.083  - info: host.Raspberry instance system.adapter.ical.0 in version "1.19.7" started with pid 3169
2026-04-13 17:30:09.714  - info: host.Raspberry instance system.adapter.ical.0 having pid 3169 terminated with code 0 (NO_ERROR)
</code></pre>
<p dir="auto">ich hoffe ich hab nicht mehr zerstört, als in Ordnung gebracht :)</p>
]]></description><link>https://forum.iobroker.net/post/1334413</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334413</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Mon, 13 Apr 2026 15:40:39 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 14:34:24 GMT]]></title><description><![CDATA[<pre><code>marvman67@Raspberry:~ $ systemctl status rpi-resize-swap-file.service
× rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile
     Loaded: loaded (/usr/lib/systemd/system/rpi-resize-swap-file.service; static)
     Active: failed (Result: exit-code) since Mon 2026-04-13 16:28:45 CEST; 5min ago
 Invocation: ace4635917fb4b07abbc341357411796
    Process: 2356 ExecStart=/usr/lib/rpi-swap/bin/rpi-resize-swap-file (code=exited, status=1/FAILURE)
   Main PID: 2356 (code=exited, status=1/FAILURE)
        CPU: 219ms
Apr 13 16:28:45 Raspberry systemd[1]: Starting rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile...
Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: swaplabel: no device specified
Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2379]: Try 'swaplabel --help' for more information.
Apr 13 16:28:45 Raspberry rpi-resize-swap-file[2380]: mkswap: error: /var/swap is mounted; will not make swapspace
Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Main process exited, code=exited, status=1/FAILURE
Apr 13 16:28:45 Raspberry systemd[1]: rpi-resize-swap-file.service: Failed with result 'exit-code'.
Apr 13 16:28:45 Raspberry systemd[1]: Failed to start rpi-resize-swap-file.service - rpi-resize-var-swap-service - resize swapfile.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/1334398</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334398</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Mon, 13 Apr 2026 14:34:24 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 14:32:53 GMT]]></title><description><![CDATA[<p dir="auto">erledigt, Fehler immer noch vorhanden</p>
*** BASE SYSTEM ***
       Icon name: computer
    Architecture: arm64
OS is similar to:
Docker          : false
Kernel          : aarch64
Userland        : 64 bit
 16:28:45 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
CPU threads: 4
Current issues:
               Local time: Mon 2026-04-13 16:28:45 CEST
           Universal time: Mon 2026-04-13 14:28:45 UTC
                 RTC time: n/a
              NTP service: active
          RTC in local TZ: no
marvman67
iobroker
HOME=/home/iobroker
Display-Manager:
Desktop:
Session:                tty
*** MEMORY ***
Mem:            4.0G        2.2G        1.3G         10M        560M        1.8G
Swap:           2.1G          0B        2.1G
Total:          6.1G        2.2G        3.5G
         3795 M total memory
         2085 M used memory
         2146 M active memory
          225 M inactive memory
         1262 M free memory
           54 M buffer memory
          479 M swap cache
         2047 M total swap
            0 M used swap
         2047 M free swap
top - 16:28:46 up 11 min,  1 user,  load average: 0.43, 0.67, 0.57
Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
%Cpu(s):  0.0 us,  2.1 sy,  0.0 ni, 95.8 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
MiB Mem :   3795.7 total,   1261.7 free,   2085.7 used,    535.0 buff/cache
MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   1710.0 avail Mem
*** FILESYSTEM ***
tmpfs          tmpfs     1.9G  648K  1.9G   1% /tmp
[Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
[Mon Apr 13 16:17:35 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
[Mon Apr 13 16:17:38 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
/var:
2.5G    /var/
231M    /var/cache
225M    /var/cache/apt
187M    /var/lib
341M    /opt/iobroker/iobroker-data/
44M     /opt/iobroker/iobroker-data/objects.jsonl
USB-Devices by-id:
/usr/bin/npm            10.9.7
/usr/bin/npx            10.9.7
nodejs:
  Version table:
     20.19.2+dfsg-1 500
ioBroker Status
Objects type: jsonl
States  type: jsonl
Hosts:
Raspberry           Raspberry (version: 7.0.7, hostname: Raspberry     , alive, uptime: 668)
admin:          7.7.22
javascript:     9.0.18
Adapter State
+ instance is alive
Objects and States
Objects:        5969
States:         4496
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       2016       630/deCONZ
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2279       1/init
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8467       1212/sshd: /usr/sbi
tcp        0      0 192.168.178.42:8084     0.0.0.0:*               LISTEN      1001       10155      1689/io.socketio.0
tcp        0      0 0.0.0.0:441             0.0.0.0:*               LISTEN      1000       9364       630/deCONZ
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6816       1200/iobroker.js-co
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       7607       1200/iobroker.js-co
tcp6       0      0 :::111                  :::*                    LISTEN      0          1217       1/init
tcp6       0      0 :::22                   :::*                    LISTEN      0          8469       1212/sshd: /usr/sbi
tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6930       1280/io.admin.0
tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10514      1717/io.web.0
tcp6       0      0 :::8087                 :::*                    LISTEN      1001       10485      1673/io.simple-api.
tcp6       0      0 :::8088                 :::*                    LISTEN      1001       9786       1288/io.admin.1
udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4614       1/init
udp        0      0 0.0.0.0:45527           0.0.0.0:*                           101        1876       626/avahi-daemon: r
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10541      1657/io.matter.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10176      1657/io.matter.0
udp        0      0 192.168.178.42:5353     0.0.0.0:*                           1001       10093      1572/io.tr-064.0
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        1874       626/avahi-daemon: r
udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1001       10175      1657/io.matter.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       11887      2053/io.deconz.0
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       9386       630/deCONZ
udp6       0      0 :::111                  :::*                                0          2280       1/init
udp6       0      0 fe80::e65f:1ff:fe05:546 :::*                                0          8508       702/NetworkManager
udp6       0      0 :::5353                 :::*                                1001       10542      1657/io.matter.0
udp6       0      0 :::5353                 :::*                                1001       10179      1657/io.matter.0
udp6       0      0 :::5353                 :::*                                101        1875       626/avahi-daemon: r
udp6       0      0 :::5540                 :::*                                1001       10174      1657/io.matter.0
udp6       0      0 :::40645                :::*                                101        1877       626/avahi-daemon: r
udp6       0      0 :::1900                 :::*                                1001       11890      2053/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       11889      2053/io.deconz.0
udp6       0      0 :::1900                 :::*                                1001       11888      2053/io.deconz.0
</code></pre>
<pre><code></code></pre>
]]></description><link>https://forum.iobroker.net/post/1334397</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334397</guid><dc:creator><![CDATA[Michael Schmitt]]></dc:creator><pubDate>Mon, 13 Apr 2026 14:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to Was bedeutet das ? rpi-resize-swap-file. on Mon, 13 Apr 2026 14:29:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/michael-schmitt" aria-label="Profile: Michael-Schmitt">@<bdi>Michael-Schmitt</bdi></a> <a href="/post/1334383">sagte</a>:</p>
<p dir="auto">schon wieder updates</p>
</blockquote>
<p dir="auto">Da ist ein Firmware-Update dabei. Neustart nicht vergessen.</p>
]]></description><link>https://forum.iobroker.net/post/1334396</link><guid isPermaLink="true">https://forum.iobroker.net/post/1334396</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 13 Apr 2026 14:29:00 GMT</pubDate></item></channel></rss>
