  4. sourceanalytix -Fehler keine Rücksetzung der Werte
    6.4k
sourceanalytixfehlerproblem
49 Beiträge 7 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • Q Offline
    Q Offline
    quinti
    ja, da laufen 2 instanzen. Instanz 1 aktiv. Instanz 0 ist nur noch da, weil da ein paar historische Werte drin sind, die ich gerne aufbewahren möchte.
    • Q Offline
      Q Offline
      quinti
      iob diagiob diag.txt
      bash
      Script v.2026-01-31
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.8.4-3-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:05:54 up 2 min,  2 users,  load average: 1.00, 1.24, 1.33
      CPU threads: 3
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2026-04-14 19:05:54 CEST
                 Universal time: Tue 2026-04-14 17:05:54 UTC
                       RTC time: n/a
                    NTP service: n/a
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      hermann
      HOME=/home/hermann
      GROUPS=hermann adm dialout sudo plugdev users iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.6G         56M        8.1G        139K        409M        8.5G
      Swap:           8.6G          0B        8.6G
      Total:           17G         56M         16G
      Active iob-Instances:   1
               8192 M total memory
                 54 M used memory
                206 M active memory
                207 M inactive memory
               7747 M free memory
                  0 M buffer memory
                390 M swap cache
               8191 M total swap
                  0 M used swap
               8191 M free swap
      top - 19:05:54 up 2 min,  2 users,  load average: 1.00, 1.24, 1.33
      Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8192.0 total,   7745.6 free,     55.6 used,    391.0 buff/cache
      MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   8136.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      * iobroker.service     loaded failed failed ioBroker Server
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      /dev/loop2     ext4       24G   10G   13G  45% /
      none           tmpfs     492K  4.0K  488K   1% /dev
      udev           devtmpfs   32G     0   32G   0% /dev/tty
      tmpfs          tmpfs      32G     0   32G   0% /dev/shm
      tmpfs          tmpfs      13G  132K   13G   1% /run
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
      Show mounted filesystems:
      TARGET SOURCE     FSTYPE OPTIONS
      /      /dev/loop2 ext4   rw,relatime
      /var:
      605M    /var/
      282M    /var/log/journal/bb1a573610aa48a7948bbf161935960d
      282M    /var/log
      231M    /var/lib
      Archived and active journals take up 281.1M in the file system.
      /opt/iobroker/backups:
      507M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      769M    /opt/iobroker/iobroker-data/
      558M    /opt/iobroker/iobroker-data/files
      217M    /opt/iobroker/iobroker-data/files/vis-2
      141M    /opt/iobroker/iobroker-data/files/vis-2/assets
      135M    /opt/iobroker/iobroker-data/backup-objects
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      34M     /opt/iobroker/iobroker-data/states.jsonl
      34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-DqJdyjgH.js.map
      34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-CrLrNq4s.js.map
      20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      No Devices found 'by-id'
      No nvbackup.json found.
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v24.5.0
      /usr/bin/node           v24.5.0
      /usr/bin/npm            11.5.1
      /usr/bin/npx            11.5.1
      ✓ Node.js installation is correct
      nodejs:
        Installed: 24.5.0-1nodesource1
        Candidate: 24.14.1-1nodesource1
        Version table:
           24.14.1-1nodesource1 600
              500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
           24.14.0-1nodesource1 600
           24.13.1-1nodesource1 600
           24.13.0-1nodesource1 600
           24.12.0-1nodesource1 600
           24.11.1-1nodesource1 600
           24.11.0-1nodesource1 600
           24.10.0-1nodesource1 600
           24.9.0-1nodesource1 600
           24.8.0-1nodesource1 600
           24.7.0-1nodesource1 600
           24.6.0-1nodesource1 600
       *** 24.5.0-1nodesource1 600
           24.4.1-1nodesource1 600
           24.4.0-1nodesource1 600
           24.3.0-1nodesource1 600
           24.1.0-1nodesource1 600
           24.0.2-1nodesource1 600
           24.0.1-1nodesource1 600
           24.0.0-1nodesource1 600
           18.20.4+dfsg-1~deb12u1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      The current Node.js version (v24.5.0) is vulnerable to the following CVEs:
      CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
      This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
      Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
      CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
      CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
      CVE-2025-59464(medium): A memory leak in Node.js’s OpenSSL integration occurs when converting `X.509` certificate fields to UTF-8 without freeing the allocated buffer. When applications call `socket.getPeerCertificate(true)`, each certificate field leaks memory, allowing remote clients to trigger steady memory growth through repeated TLS connections. Over time this can lead to resource exhaustion and denial of service.
      CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
      server.on('secureConnection', socket => {
      socket.on('error', err => {
      console.log(err)
      CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
      CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves `SNICallback` invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
      When an `SNICallback` throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
      * This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including **20.x, 22.x, 24.x, and 25.x**, on any TLS server where `SNICallback` may throw on unexpected `servername` input.
      Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
      CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught `TypeError` when a request is received with a header named `__proto__` and the application accesses `req.headersDistinct`.
      When this occurs, `dest["__proto__"]` resolves to `Object.prototype` rather than `undefined`, causing `.push()` to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by `error` event listeners, meaning it cannot be handled without wrapping every `req.headersDistinct` access in a `try/catch`.
      * This vulnerability affects all Node.js HTTP servers on **20.x, 22.x, 24.x, and v25.x**
      CVE-2026-21712(medium): A flaw in Node.js URL processing causes an assertion failure in native code when `url.format()` is called with a malformed internationalized domain name (IDN) containing invalid characters, crashing the Node.js process.
      * This vulnerability affects **24.x and 25.x**.
      Patched versions: ^24.14.1 || ^25.8.2
      CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
      Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
      This vulnerability affects **20.x, 22.x, 24.x, and 25.x**.
      CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
      This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
      CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves `fs.realpathSync.native()` without the required read permission checks, while all comparable filesystem functions correctly enforce them.
      As a result, code running under `--permission` with restricted `--allow-fs-read` can still use `fs.realpathSync.native()` to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
      This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-read` is intentionally restricted.
      CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves `FileHandle.chmod()` and `FileHandle.chown()` in the promises API without the required permission checks, while their callback-based equivalents (`fs.fchmod()`, `fs.fchown()`) were correctly patched.
      As a result, code running under `--permission` with restricted `--allow-fs-write` can still use promise-based `FileHandle` methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
      This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-write` is intentionally restricted.
      CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
      The most common trigger is any endpoint that calls `JSON.parse()` on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.1.0, hostname: iobroker      , alive, uptime: 17)
      Core adapters versions
      js-controller:  7.1.0
      admin:          7.8.20
      javascript:     9.1.1
      nodejs modules from github:     2
      +-- iobroker.ecovacs-deebot@1.4.16-alpha.7 (git+ssh://git@github.com/mrbungle64/ioBroker.ecovacs-deebot.git#2b8cdedde82e5f0d7057d3403e9cf45fc7a02d0c)
      +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
      Adapter State
        system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
        system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
        system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
        system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        system.adapter.gotify.0                 : gotify                : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobroker                                 - disabled
        system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
        system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
        system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
        system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
        system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
        system.adapter.renault.0                : renault               : iobroker                                 -  enabled
        system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
        system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
        system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 - disabled, port: 9000
        system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
        system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
        system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
        system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
        system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name      │ url        │ auto upgrade │
      │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
      │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
      │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
      │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
      Active repo(s): online, beta
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repositories: online, beta
      Cannot download repository hash file from "https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist-hash.json": Request failed with status code 404
      Adapter    "admin"        : 7.8.20   , installed 7.8.20
      Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 3.3.15   , installed 3.3.15
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.16-alpha.7
      Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
      Adapter    "evcc"         : 0.2.8    , installed 0.2.8
      Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "fullybrowser" : 3.1.3    , installed 3.1.3
      Adapter    "gotify"       : 0.5.0    , installed 0.5.0
      Adapter    "ical"         : 1.20.0   , installed 1.20.0
      Adapter    "iot"          : 6.0.1    , installed 6.0.1
      Adapter    "javascript"   : 9.2.0    , installed 9.1.1  [Updatable]
      Controller "js-controller": 7.1.1    , installed 7.1.0  [Updatable]
      Adapter    "knx"          : 2.0.39   , installed 2.0.39
      Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
      Adapter    "nina"         : 0.0.26   , installed 0.0.26
      Adapter    "node-red"     : 6.0.7    , installed 6.0.7
      Adapter    "nuki"         : 2.0.0    , installed 2.0.0
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "ping"         : 2.1.0    , installed 2.1.0
      Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
      Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
      Adapter    "renault"      : 0.0.22   , installed 0.0.22
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "scenes"       : 4.0.4    , installed 4.0.4
      Adapter    "shelly"       : 10.6.1   , installed 10.6.1
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "squeezeboxrpc": 1.6.4    , installed 1.6.4
      Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
      Adapter    "traccar"      : 1.1.7    , installed 1.1.6  [Updatable]
      Adapter    "tuya"         : 3.17.0   , installed 3.17.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "unifi-network": 1.4.0    , installed 1.4.0
      Adapter    "vis-2"        : 2.13.17  , installed 2.13.17
      Adapter    "vis-2-widgets-collection": 2.4.1, installed 2.4.1
      Adapter    "vis-2-widgets-inventwo": 0.6.5, installed 0.6.5
      Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
      Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
      Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 8.1.0    , installed 8.1.0
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Adapter    "worx"         : 3.3.0    , installed 3.3.0
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Objects and States
      Objects:        31715
      States:         30867
      W: https://packages.microsoft.com/ubuntu/16.04/prod/dists/xenial/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
      Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 102
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          839430941  330/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          839431662  1/init
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          839430942  330/master
      tcp6       0      0 :::111                  :::*                    LISTEN      0          839431664  1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          839433330  1/init
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839431663  1/init
      udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          839433415  168/ntpd
      udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          839433413  168/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          839433411  168/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          839433407  168/ntpd
      udp6       0      0 :::111                  :::*                                0          839431665  1/init
      udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        839433669  168/ntpd
      udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839433667  168/ntpd
      udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        839433665  168/ntpd
      udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839433663  168/ntpd
      udp6       0      0 ::1:123                 :::*                                0          839433417  168/ntpd
      udp6       0      0 :::123                  :::*                                0          839433404  168/ntpd
      2026-04-14 19:03:42.345  - warn: host.iobroker instance system.adapter.ping.0 terminated due to SIGKILL
      2026-04-14 19:03:42.359  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
      2026-04-14 19:03:42.359  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
      2026-04-14 19:03:55.082  - warn: admin.0 (343) Cannot update news: ETIMEDOUT
      2026-04-14 19:04:10.715  - error: host.iobroker Caught by controller[0]: (node:415) [DEP0176] DeprecationWarning: fs.F_OK is deprecated, use fs.constants.F_OK instead
      2026-04-14 19:04:10.718  - error: host.iobroker Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
      2026-04-14 19:04:10.718  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGTERM
      2026-04-14 19:04:11.307  - warn: admin.0 (343) get state error: Connection is closed.
      2026-04-14 19:04:11.345  - error: admin.0 (343) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2026-04-14 19:04:11.345  - error: admin.0 (343) unhandled promise rejection: Connection is closed.
      2026-04-14 19:04:11.414  - error: admin.0 (343) Error: Connection is closed.
          at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
          at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
          at StateRedisClient.pushMessage (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1215:27)
          at Admin.registerNotification (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7771:28)
          at Admin.writeUpdateInfo (/opt/iobroker/node_modules/iobroker.admin/build/src/main.ts:890:20)
      2026-04-14 19:04:11.604  - error: host.iobroker Caught by controller[0]: (node:343) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[0]: (Use `node --trace-warnings ...` to show where the warning was created)
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]: Error: Connection is closed.
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at StateRedisClient.pushMessage (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1215:27)
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Admin.registerNotification (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7771:28)
      2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Admin.writeUpdateInfo (/opt/iobroker/node_modules/iobroker.admin/build/src/main.ts:890:20)
      HomoranH crunchipC 2 Antworten Letzte Antwort
      • Ro75R Offline
        Ro75R Offline
        Ro75
        nodejs >22.x warum? Beta Repo warum?
        Ro75.
        • Q quinti
          bash
          Script v.2026-01-31
          *** BASE SYSTEM ***
            Virtualization: lxc
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 3
                           RTC time: n/a
                        NTP service: n/a
                    RTC in local TZ: no
          hermann
          HOME=/home/hermann
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           8.6G          0B        8.6G
          Total:           17G         56M         16G
                   8192 M total memory
                     54 M used memory
                    206 M active memory
                   7747 M free memory
                      0 M buffer memory
                    390 M swap cache
                   8191 M total swap
                      0 M used swap
                   8191 M free swap
          *** FILESYSTEM ***
          /var:
          605M    /var/
          282M    /var/log
          231M    /var/lib
          USB-Devices by-id:
          /usr/bin/npm            11.5.1
          /usr/bin/npx            11.5.1
          nodejs:
            Version table:
          console.log(err)
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.8.20
          javascript:     9.1.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        31715
          States:         30867
          @quinti sagte:
          Da stimmt was grundsätzlich nicht, diag würde nie lügen!
          OS zu alt
          @quinti sagte:
          Läuft iobroker gar nicht?
          @quinti sagte:
          • iobroker.service loaded failed failed ioBroker Server
          Was ist da los?
          @quinti sagte:
          Node 24 ist noch nicht für iob empfohlen
          @quinti sagte:
          Warum 2 repos gleichzeitig?
          @quinti sagte:
          A
          updaten!
          @quinti sagte:
          Dito
          • Q quinti
            bash
            Script v.2026-01-31
            *** BASE SYSTEM ***
              Virtualization: lxc
            OS is similar to:
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
            CPU threads: 3
                             RTC time: n/a
                          NTP service: n/a
                      RTC in local TZ: no
            hermann
            HOME=/home/hermann
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           8.6G          0B        8.6G
            Total:           17G         56M         16G
                     8192 M total memory
                       54 M used memory
                      206 M active memory
                     7747 M free memory
                        0 M buffer memory
                      390 M swap cache
                     8191 M total swap
                        0 M used swap
                     8191 M free swap
            *** FILESYSTEM ***
            /var:
            605M    /var/
            282M    /var/log
            231M    /var/lib
            USB-Devices by-id:
            /usr/bin/npm            11.5.1
            /usr/bin/npx            11.5.1
            nodejs:
              Version table:
            console.log(err)
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.8.20
            javascript:     9.1.1
            Adapter State
            + instance is alive
            Objects and States
            Objects:        31715
            States:         30867
            crunchipC Offline
            crunchipC Offline
            @quinti da ist doch etwas mit deinem Arbeitsspeicher faul
              @quinti sagte:
              OS zu alt
              @quinti sagte:
              @quinti sagte:
              Was ist da los?
              @quinti sagte:
              @quinti sagte:
              @quinti sagte:
              A
              updaten!
              @quinti sagte:
              Dito
              @Homoran sagte:
              Kann ich nicht ausschließen...
              Aber die Diagnose basiert natürlich auf Daten aus dem System.
              basiert natürlich auf veralteten Informationen, da ja das running süstäm nie getascht wurde.
              Wäre das auf Stand wäre auch die Diagnose richtig.
              Insgesamt ist das Dig aber komplett inkonsistent aufgebaut. nodejs@24 auf einem ansonsten versumpften Bookworm mit iob-Beta-Quelle macht gar keinen Sinn. Wo soll es denn hingehen? Bleeding edge oder 'never tatsch irgendwas'? Beides kombiniert kann nicht gut funktionieren.
              Und wozu solll die microsoft/xenial-Quelle gut sein? Davon ganz abgesehen, dass sie natürlich nicht mehr funktioniert.
              • Q Offline
                Q Offline
                quinti
                sry, hatte iwie im kopf das iob diag mit gestopptem iobroker laufen muss. Habs wohl verwechselt mit iob fix --> alter mann
                Das microsoft repository ist drin da ich mal einen mssql client installiert habe.
                Bin noch auf bookworm da iobroker in einem proxmox container läuft und proxmox noch auf 8.2.2 mit bookworm ist. Möchte im moment proxmox nicht upgraden. Ist wohl z Zt ein bug drin der grub durcheinander bringt. Hat mir letzte Woche meinen tvheadend Rechner zerschossen.
                Hab mal updates durchgeführt.
                hier neues diag mit gestartetem iobroker ;)
                Script v.2026-01-31
                *** BASE SYSTEM ***
                  Virtualization: lxc
                OS is similar to:
                Docker          : false
                Kernel          : x86_64
                Userland        : 64 bit
                 20:13:47 up 16 min,  2 users,  load average: 1.74, 1.83, 1.82
                CPU threads: 3
                Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                               Local time: Tue 2026-04-14 20:13:47 CEST
                           Universal time: Tue 2026-04-14 18:13:47 UTC
                                 RTC time: n/a
                              NTP service: n/a
                          RTC in local TZ: no
                hermann
                HOME=/home/hermann
                iobroker
                HOME=/home/iobroker
                GROUPS=iobroker tty dialout audio video plugdev
                Display-Manager:
                Desktop:
                Session:                tty
                *** MEMORY ***
                Mem:            8.6G        4.3G        3.2G        143K        1.1G        4.3G
                Swap:           8.6G          0B        8.6G
                Total:           17G        4.3G         11G
                Active iob-Instances:   39
                         8192 M total memory
                         4116 M used memory
                         3929 M active memory
                          867 M inactive memory
                         3032 M free memory
                            0 M buffer memory
                         1043 M swap cache
                         8191 M total swap
                            0 M used swap
                         8191 M free swap
                top - 20:13:48 up 16 min,  2 users,  load average: 1.74, 1.83, 1.82
                Tasks:  69 total,   1 running,  68 sleeping,   0 stopped,   0 zombie
                MiB Mem :   8192.0 total,   3030.9 free,   4118.0 used,   1043.3 buff/cache
                MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   4074.0 avail Mem
                1 loaded units listed.
                *** FILESYSTEM ***
                /dev/loop2     ext4       24G   11G   13G  45% /
                tmpfs          tmpfs      13G  136K   13G   1% /run
                /var:
                613M    /var/
                290M    /var/log/journal/bb1a573610aa48a7948bbf161935960d
                290M    /var/log
                231M    /var/lib
                Archived and active journals take up 289.1M in the file system.
                742M    /opt/iobroker/iobroker-data/
                36M     /opt/iobroker/iobroker-data/objects.jsonl
                14M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/nodejs         v24.14.1
                /usr/bin/node           v24.14.1
                /usr/bin/npm            11.11.0
                /usr/bin/npx            11.11.0
                nodejs:
                  Installed: 24.14.1-1nodesource1
                  Version table:
                 *** 24.14.1-1nodesource1 600
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                iobroker            iobroker (version: 7.1.1, hostname: iobroker      , alive, uptime: 316)
                js-controller:  7.1.1
                admin:          7.8.20
                javascript:     9.2.0
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
                + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                + system.adapter.gotify.0                 : gotify                : iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                + system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
                + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                  system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                + system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
                + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                + instance is alive
                Active repo(s): beta
                Used repository: beta
                Adapter    "javascript"   : 9.2.0    , installed 9.2.0
                Controller "js-controller": 7.1.1    , installed 7.1.1
                Adapter    "traccar"      : 1.1.7    , installed 1.1.7
                Objects and States
                Objects:        31783
                States:         31368
                Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease
                Hit:5 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
                Pending systemupdates: 0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       840021606  4327/iobroker.js-co
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       840021611  4327/iobroker.js-co
                tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          839861821  333/master
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       840025688  4603/io.mqtt.0
                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       840042633  4802/io.sonoff.0
                tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       840037661  4785/io.shelly.0
                tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          839864060  1/init
                tcp6       0      0 :::51989                :::*                    LISTEN      1001       840031495  4736/io.nuki-extend
                tcp6       0      0 :::111                  :::*                    LISTEN      0          839864062  1/init
                tcp6       0      0 :::22                   :::*                    LISTEN      0          839864218  1/init
                tcp6       0      0 :::8087                 :::*                    LISTEN      1001       840056132  5058/io.simple-api.
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       840057907  5156/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       840021668  4348/io.admin.0
                tcp6       0      0 ::1:25                  :::*                    LISTEN      0          839861822  333/master
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       840042801  4851/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       840042802  4851/io.tuya.0
                udp        0      0 192.168.101.102:54278   0.0.0.0:*                           1001       840025951  4719/io.knx.0
                udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839864061  1/init
                udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          839859795  164/ntpd
                udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          839859793  164/ntpd
                udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          839859791  164/ntpd
                udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          839859787  164/ntpd
                udp6       0      0 :::111                  :::*                                0          839864063  1/init
                udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        839862059  164/ntpd
                udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839862057  164/ntpd
                udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        839862055  164/ntpd
                udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839862053  164/ntpd
                udp6       0      0 ::1:123                 :::*                                0          839859797  164/ntpd
                udp6       0      0 :::123                  :::*                                0          839859784  164/ntpd
                • Ro75R Offline
                  Ro75R Offline
                  Ro75
                  ändert nichts an der Tatsache nodejs >22 warum? Beta-Repo warum? OS läuft aus. ...
                  Ro75.
                  • Q quinti
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 3
                                     RTC time: n/a
                                  NTP service: n/a
                              RTC in local TZ: no
                    hermann
                    HOME=/home/hermann
                    iobroker
                    HOME=/home/iobroker
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:           8.6G          0B        8.6G
                    Total:           17G        4.3G         11G
                             8192 M total memory
                             4116 M used memory
                             3032 M free memory
                                0 M buffer memory
                             1043 M swap cache
                             8191 M total swap
                                0 M used swap
                             8191 M free swap
                    *** FILESYSTEM ***
                    /var:
                    613M    /var/
                    290M    /var/log
                    231M    /var/lib
                    USB-Devices by-id:
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.8.20
                    javascript:     9.2.0
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        31783
                    States:         31368
                    @quinti sagte:
                    Dann schmeiß den alten Mist da raus. xenial ist 10 Jahre alt!!!
                    • Ro75R Ro75
                      Ro75.
                      @Ro75 sagte:
                      Ro75.
                      @quinti und noch alle Updates fahren.
                      Die sind noch im bookworm offen!
                      Wir reden nicht von Trixie
                      Q 1 Antwort Letzte Antwort
                      • Ro75R Offline
                        Ro75R Offline
                        Ro75
                        @quinti und wenn du schon Beta nutzt, dann muss du auch damit rechnen, dass etwas möglicherweise nicht so funktioniert wie gewollt - hat BETA und nicht STABLE. Eventuell solltest du alles auf Stable zurück.
                        Ro75.
                          @Ro75 sagte:
                          Ro75.
                          Q Offline
                          Q Offline
                          quinti
                          @Homoran sagte:
                          @Ro75 sagte:
                          Ro75.
                          apt update/upgrade zeigt aber nichts mehr an zum updaten?
                          • Q quinti
                            @Homoran sagte:
                            @Ro75 sagte:
                            Ro75.
                            @quinti sagte:
                            Zeigen!
                            Mit vollständiger Eingabe
                            • Q quinti
                              Script v.2026-01-31
                              *** BASE SYSTEM ***
                                Virtualization: lxc
                              OS is similar to:
                              Docker          : false
                              Kernel          : x86_64
                              Userland        : 64 bit
                              CPU threads: 3
                                               RTC time: n/a
                                            NTP service: n/a
                                        RTC in local TZ: no
                              hermann
                              HOME=/home/hermann
                              iobroker
                              HOME=/home/iobroker
                              Display-Manager:
                              Desktop:
                              Session:                tty
                              *** MEMORY ***
                              Swap:           8.6G          0B        8.6G
                              Total:           17G        4.3G         11G
                                       8192 M total memory
                                       4116 M used memory
                                       3032 M free memory
                                          0 M buffer memory
                                       1043 M swap cache
                                       8191 M total swap
                                          0 M used swap
                                       8191 M free swap
                              *** FILESYSTEM ***
                              /var:
                              613M    /var/
                              290M    /var/log
                              231M    /var/lib
                              USB-Devices by-id:
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              admin:          7.8.20
                              javascript:     9.2.0
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        31783
                              States:         31368
                              @quinti sagte:
                              Sorry, hab das letzte diag übersehen
                                @quinti sagte:
                                Zeigen!
                                Q Offline
                                Q Offline
                                quinti
                                @Homoran sagte:
                                @quinti sagte:
                                Zeigen!
                                root@iobroker:~# apt update
                                Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                Reading package lists... Done
                                All packages are up to date.
                                root@iobroker:~# apt upgrade
                                Calculating upgrade... Done
                                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                root@iobroker:~#
                                • Q quinti
                                  @Homoran sagte:
                                  @quinti sagte:
                                  Zeigen!
                                  root@iobroker:~#
                                  @quinti ok, siehe letzten Post von mir
                                  Aber wieso bist du root?
                                    Q Offline
                                    Q Offline
                                    quinti
                                    @Homoran
                                    mache sachen am system als root, sollte ich nicht?
                                    • Q quinti
                                      @Homoran
                                      @quinti sagte:
                                      sollte ich nicht?
                                      Nein. Man loggt sich nie direkt als root ein, man verwendet sudo als Zwischenschicht dafür.
                                      • Q Offline
                                        Q Offline
                                        quinti
                                        so, downgrade auf node 22 gemacht und stable repo eingestellt.
                                        Ich schau mal was heute nacht passiert...
                                        Danke schonmal!!!
                                        Script v.2026-01-31
                                        *** BASE SYSTEM ***
                                          Virtualization: lxc
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         20:37:07 up 7 min,  3 users,  load average: 1.23, 1.47, 1.54
                                        CPU threads: 3
                                                       Local time: Tue 2026-04-14 20:37:07 CEST
                                                   Universal time: Tue 2026-04-14 18:37:07 UTC
                                                         RTC time: n/a
                                                      NTP service: n/a
                                                  RTC in local TZ: no
                                        hermann
                                        HOME=/home/hermann
                                        iobroker
                                        HOME=/home/iobroker
                                        Display-Manager:
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:            8.6G        3.9G        4.0G        163K        764M        4.7G
                                        Swap:           8.6G          0B        8.6G
                                        Total:           17G        3.9G         12G
                                        Active iob-Instances:   38
                                                 8192 M total memory
                                                 3676 M used memory
                                                 3665 M active memory
                                                  559 M inactive memory
                                                 3787 M free memory
                                                    0 M buffer memory
                                                  728 M swap cache
                                                 8191 M total swap
                                                    0 M used swap
                                                 8191 M free swap
                                        top - 20:37:07 up 7 min,  3 users,  load average: 1.23, 1.47, 1.54
                                        Tasks:  75 total,   1 running,  74 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 50.0 us,  0.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   8192.0 total,   3785.8 free,   3677.5 used,    728.8 buff/cache
                                        MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   4514.5 avail Mem
                                        *** FILESYSTEM ***
                                        /dev/loop2     ext4       24G   11G   13G  46% /
                                        tmpfs          tmpfs      13G  156K   13G   1% /run
                                        tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/0
                                        /var:
                                        647M    /var/
                                        290M    /var/log
                                        230M    /var/lib
                                        782M    /opt/iobroker/iobroker-data/
                                        53M     /opt/iobroker/iobroker-data/objects.jsonl
                                        36M     /opt/iobroker/iobroker-data/states.jsonl
                                        USB-Devices by-id:
                                        /usr/bin/nodejs         v22.22.2
                                        /usr/bin/node           v22.22.2
                                        /usr/bin/npm            10.9.7
                                        /usr/bin/npx            10.9.7
                                        nodejs:
                                          Installed: 22.22.2-1nodesource1
                                          Candidate: 22.22.2-1nodesource1
                                          Version table:
                                         *** 22.22.2-1nodesource1 1001
                                             22.22.1-1nodesource1 1001
                                             22.22.0-1nodesource1 1001
                                             22.21.0-1nodesource1 1001
                                             22.20.0-1nodesource1 1001
                                             22.19.0-1nodesource1 1001
                                             22.18.0-1nodesource1 1001
                                             22.17.1-1nodesource1 1001
                                             22.17.0-1nodesource1 1001
                                             22.16.0-1nodesource1 1001
                                             22.15.1-1nodesource1 1001
                                             22.15.0-1nodesource1 1001
                                             22.14.0-1nodesource1 1001
                                             22.13.1-1nodesource1 1001
                                             22.13.0-1nodesource1 1001
                                             22.12.0-1nodesource1 1001
                                             22.11.0-1nodesource1 1001
                                             22.10.0-1nodesource1 1001
                                             22.9.0-1nodesource1 1001
                                             22.8.0-1nodesource1 1001
                                             22.7.0-1nodesource1 1001
                                             22.6.0-1nodesource1 1001
                                             22.5.1-1nodesource1 1001
                                             22.5.0-1nodesource1 1001
                                             22.4.1-1nodesource1 1001
                                             22.4.0-1nodesource1 1001
                                             22.3.0-1nodesource1 1001
                                             22.2.0-1nodesource1 1001
                                             22.1.0-1nodesource1 1001
                                             22.0.0-1nodesource1 1001
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        iobroker            iobroker (version: 7.1.1, hostname: iobroker      , alive, uptime: 452)
                                        admin:          7.8.20
                                        javascript:     9.2.0
                                        Adapter State
                                        + instance is alive
                                        Active repo(s): stable
                                        Used repository: stable
                                        Adapter    "admin"        : 7.7.22   , installed 7.8.20
                                        Adapter    "backitup"     : 3.3.14   , installed 3.3.15
                                        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.2
                                        Adapter    "evcc"         : 0.2.4    , installed 0.2.8
                                        Adapter    "fullybrowser" : 3.1.2    , installed 3.1.3
                                        Adapter    "ical"         : 1.19.7   , installed 1.20.0
                                        Adapter    "iot"          : 5.0.12   , installed 6.0.1
                                        Adapter    "javascript"   : 9.0.18   , installed 9.2.0
                                        Controller "js-controller": 7.0.7    , installed 7.1.1
                                        Adapter    "knx"          : 2.0.30   , installed 2.0.39
                                        Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
                                        Adapter    "nina"         : 0.0.25   , installed 0.0.26
                                        Adapter    "ping"         : 1.7.9    , installed 2.1.0
                                        Adapter    "socketio"     : 7.0.8    , installed 7.1.3
                                        Adapter    "squeezeboxrpc": 1.6.2    , installed 1.6.4
                                        Adapter    "traccar"      : 1.1.6    , installed 1.1.7
                                        Adapter    "tuya"         : 3.16.0   , installed 3.17.0
                                        Adapter    "unifi-network": 1.3.1    , installed 1.4.0
                                        Adapter    "vis-2"        : 2.13.8   , installed 2.13.17
                                        Adapter    "vis-2-widgets-collection": 1.8.1, installed 2.4.1
                                        Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.6.5
                                        Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.1
                                        Adapter    "web"          : 8.0.0    , installed 8.1.0
                                        Adapter    "ws"           : 4.0.0    , installed 4.1.0
                                        Objects and States
                                        Objects:        31783
                                        States:         31368
                                        Hit:2 http://security.debian.org bookworm-security InRelease
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       840312012  160/iobroker.js-con
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       840307229  160/iobroker.js-con
                                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          840311862  331/master
                                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       840328669  761/io.shelly.0
                                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       840331330  792/io.sonoff.0
                                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       840307675  579/io.mqtt.0
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          840305159  1/init
                                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       840399609  1888/io.nuki-extend
                                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          840311863  331/master
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          840305283  1/init
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          840305161  1/init
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       840312162  348/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       840332274  1487/io.web.0
                                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       840337283  1061/io.simple-api.
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       840328970  861/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       840328971  861/io.tuya.0
                                        udp        0      0 192.168.101.102:52906   0.0.0.0:*                           1001       840322543  695/io.knx.0
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          840305160  1/init
                                        udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          840310672  169/ntpd
                                        udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          840310670  169/ntpd
                                        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          840310668  169/ntpd
                                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          840310664  169/ntpd
                                        udp6       0      0 :::111                  :::*                                0          840305162  1/init
                                        udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        840312136  169/ntpd
                                        udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        840312133  169/ntpd
                                        udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        840312055  169/ntpd
                                        udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        840312051  169/ntpd
                                        udp6       0      0 ::1:123                 :::*                                0          840310674  169/ntpd
                                        udp6       0      0 :::123                  :::*                                0          840310661  169/ntpd
                                        2026-04-14 20:32:03.982  - info: sourceanalytix.1 (1083) Initialising (35 of 45) "sonoff.0.SONOFF_POW#07_Lueftungsanlage.ENERGY_Total"
                                        2026-04-14 20:32:04.208  - info: sourceanalytix.1 (1083) Initialization of sonoff.0.SONOFF_POW#07_Lueftungsanlage.ENERGY_Total successfully
                                        2026-04-14 20:32:04.208  - info: sourceanalytix.1 (1083) Initialising (36 of 45) "mqtt.0.solar.ac.yieldtotal"
                                        2026-04-14 20:32:04.373  - info: sourceanalytix.1 (1083) Initialization of mqtt.0.solar.ac.yieldtotal successfully
                                        2026-04-14 20:32:04.374  - info: sourceanalytix.1 (1083) Initialising (37 of 45) "0_userdata.0.PV.EV-Carport-total"
                                        2026-04-14 20:32:04.653  - info: sourceanalytix.1 (1083) Initialization of 0_userdata.0.PV.EV-Carport-total successfully
                                        2026-04-14 20:32:04.654  - info: sourceanalytix.1 (1083) Initialising (38 of 45) "shelly.0.shellypro1pm#8813bfda218c#1.Relay0.Energy"
                                        2026-04-14 20:32:05.635  - info: sourceanalytix.1 (1083) Initialization of shelly.0.shellypro1pm#8813bfda218c#1.Relay0.Energy successfully
                                        2026-04-14 20:32:05.635  - info: sourceanalytix.1 (1083) Initialising (39 of 45) "mqtt.1.evcc.loadpoints.1.chargeTotalImport"
                                        2026-04-14 20:32:05.997  - info: sourceanalytix.1 (1083) Initialization of mqtt.1.evcc.loadpoints.1.chargeTotalImport successfully
                                        2026-04-14 20:32:05.997  - info: sourceanalytix.1 (1083) Initialising (40 of 45) "sonoff.0.SP111_#04_Wischrobo.ENERGY_Total"
                                        2026-04-14 20:32:06.221  - info: sourceanalytix.1 (1083) Initialization of sonoff.0.SP111_#04_Wischrobo.ENERGY_Total successfully
                                        2026-04-14 20:32:06.221  - info: sourceanalytix.1 (1083) Initialising (41 of 45) "0_userdata.0.Energie.shellypro3em_gesamt"
                                        2026-04-14 20:32:06.609  - info: sourceanalytix.1 (1083) Initialization of 0_userdata.0.Energie.shellypro3em_gesamt successfully
                                        2026-04-14 20:32:06.609  - info: sourceanalytix.1 (1083) Initialising (42 of 45) "0_userdata.0.Energie.Stromverbrauch-Energie-gesamt"
                                        2026-04-14 20:32:06.934  - info: sourceanalytix.1 (1083) Initialization of 0_userdata.0.Energie.Stromverbrauch-Energie-gesamt successfully
                                        2026-04-14 20:32:06.935  - info: sourceanalytix.1 (1083) Initialising (43 of 45) "alias.0.Hoymiles-Batterie.MSA-280425340276.device.inv.etin"
                                        2026-04-14 20:32:07.191  - info: sourceanalytix.1 (1083) Initialization of alias.0.Hoymiles-Batterie.MSA-280425340276.device.inv.etin successfully
                                        2026-04-14 20:32:07.191  - info: sourceanalytix.1 (1083) Initialising (44 of 45) "alias.0.Hoymiles-Batterie.MSA-280425340276.device.inv.etout"
                                        2026-04-14 20:32:07.494  - info: sourceanalytix.1 (1083) Initialization of alias.0.Hoymiles-Batterie.MSA-280425340276.device.inv.etout successfully
                                        2026-04-14 20:32:07.494  - info: sourceanalytix.1 (1083) Initialising (45 of 45) "alias.0.Energiemessung.Total.Stromzähler-WP"
                                        2026-04-14 20:32:07.735  - info: sourceanalytix.1 (1083) Initialization of alias.0.Energiemessung.Total.Stromzähler-WP successfully
                                        2026-04-14 20:32:07.737  - info: sourceanalytix.1 (1083) Successfully activated SourceAnalytix for 45 of 45 states, will do my Job until you stop me!
                                        2026-04-14 20:32:22.065  - warn: energiefluss-erweitert.0 (1560) Workspace configuration is NOT password protected!
                                        2026-04-14 20:35:00.053  - info: sourceanalytix.1 (1083) Device reset detected for 0_userdata.0.PV.EV-Carport-total, feature disabled (or below threshold) processing normally)
                                        • Ro75R Offline
                                          Ro75R Offline
                                          Ro75
                                          admin: 7.8.20
                                          javascript: 9.2.0 >>> definitiv nicht stable!
                                          Ro75.
