  4. sourceanalytix -Fehler keine Rücksetzung der Werte
    6.4k
sourceanalytixfehlerproblem
49 Beiträge 7 Kommentatoren 2.5k Aufrufe 5 Beobachtet
  • Q quinti
    Hallo @zsmmn,
    habe beim sourceanalytix Adapter seit eingen Wochen das Porblem, dass Montags die Tageseswerte nicht zurück gesetzt werden.
    Es schein ein Problem mit den Wochenwerten zu sein.
    Log:
    sourceanalytix.1	2026-04-13 00:00:00.750	error	Error: DB closed
    sourceanalytix.1	2026-04-13 00:00:00.617	error	Error: DB closed
    sourceanalytix.1	2026-04-13 00:00:00.617	warn	get state error: Connection is closed.
    sourceanalytix.1	2026-04-13 00:00:00.616	warn	Could not perform strict object check of state sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.meterReadings.currentWeek.03_Wednesday: DB closed
    sourceanalytix.1	2026-04-13 00:00:00.475	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.03_Wednesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.472	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.03_Wednesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.416	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.02_Tuesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.372	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.02_Tuesday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.298	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.01_Monday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.255	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.01_Monday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.203	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.currentWeek.07_Sunday" has no existing object, this might lead to an error in future versions
    sourceanalytix.1	2026-04-13 00:00:00.137	warn	State "sourceanalytix.1.javascript__0__Variabeln__Zähler_Klima400V_ENERGY_TOTAL.currentYear.costs.previousWeek.07_Sunday" has no existing object, this might lead to an error in future versions
    habe letzten Montag den State der im log auftauchte gelöscht. Diese Woche ist jetzt aber ein anderer Wert betroffen.
    Ro75R Offline
    Ro75R Offline
    Ro75
    @quinti sagte:
    Was ist denn damit?
    Zu wenig Speicher? Datenträger voll? beschädigt?
    iob diag?
    Ro75.
    • Q quinti
      ich nutze den Adapter seit Jahren, hatte nie Probleme und auch bewusst nicht am System geändert. Grundeinstellung vom iobroker habe ich glaube ich noch nie geändert.
      Seit ein paar Wochen habe ich Montags, dass die Tageswerte nicht zurück gesetzt werden, also die states mit currentYear.consumed.01_currentDay hinten.
      Beim Wechsel Monat auf Dienstag wurden dann die Berechnungen immer normal durchgeführt.
      Heute dann zum ersten Mal der Fall das 2 Tage nach Gang nicht funktioniert.
      Die previousDay Werte werden nicht dabei geschrieben, siehe screenshots von gerade 14.04.2026. Heute noch der Wert vom Wechsel Samstag/Sonntag.
      Ich werde mal die beteilgten Adapter auf loglevel info stellen über MItternacht, also
      -sourceanalytix
      -sql (ist als Standard im iobroker hinterlegt)
      -javascript
      crunchipC Offline
      crunchipC Offline
      @quinti sagte:
      ich würde eher mal darauf achten ob Werte übertragen werden zu dem Zeitraum Mitternacht, denn wenn kein Wert reinkommt, wird auch nicht weitergezählt.
      also würde ich eher da mal ansetzen
      @quinti sagte:
      • Q Offline
        Q Offline
        quinti
        hatte ich vergessen anzuhängen :)
        • Q quinti
          crunchipC Offline
          crunchipC Offline
          @quinti ist Instanz 1 eigentlich bewusst beabsichtigt? oder laufen da sogar 2 Instanzen?
          • Q Offline
            Q Offline
            quinti
            ja, da laufen 2 instanzen. Instanz 1 aktiv. Instanz 0 ist nur noch da, weil da ein paar historische Werte drin sind, die ich gerne aufbewahren möchte.
            • Q Offline
              Q Offline
              quinti
              iob diagiob diag.txt
              bash
              Script v.2026-01-31
              *** BASE SYSTEM ***
               Static hostname: iobroker
                     Icon name: computer-container
                       Chassis: container ☐
                Virtualization: lxc
                        Kernel: Linux 6.8.4-3-pve
                  Architecture: x86-64
              OS is similar to:
              model name      : Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz
              Docker          : false
              Virtualization  : lxc
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
               19:05:54 up 2 min,  2 users,  load average: 1.00, 1.24, 1.33
              CPU threads: 3
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'bookworm'!
              *** TIME AND TIMEZONES ***
                             Local time: Tue 2026-04-14 19:05:54 CEST
                         Universal time: Tue 2026-04-14 17:05:54 UTC
                               RTC time: n/a
                            NTP service: n/a
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              hermann
              HOME=/home/hermann
              GROUPS=hermann adm dialout sudo plugdev users iobroker
              js-controller is not running
              *** DISPLAY-SERVER SETUP ***
              Display-Server:         false
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            8.6G         56M        8.1G        139K        409M        8.5G
              Swap:           8.6G          0B        8.6G
              Total:           17G         56M         16G
              Active iob-Instances:   1
                       8192 M total memory
                         54 M used memory
                        206 M active memory
                        207 M inactive memory
                       7747 M free memory
                          0 M buffer memory
                        390 M swap cache
                       8191 M total swap
                          0 M used swap
                       8191 M free swap
              top - 19:05:54 up 2 min,  2 users,  load average: 1.00, 1.24, 1.33
              Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8192.0 total,   7745.6 free,     55.6 used,    391.0 buff/cache
              MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   8136.4 avail Mem
              *** FAILED SERVICES ***
                UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
              * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
              * iobroker.service     loaded failed failed ioBroker Server
              2 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              dmesg: read kernel buffer failed: Operation not permitted
              No critical errors detected
              *** FILESYSTEM ***
              /dev/loop2     ext4       24G   10G   13G  45% /
              none           tmpfs     492K  4.0K  488K   1% /dev
              udev           devtmpfs   32G     0   32G   0% /dev/tty
              tmpfs          tmpfs      32G     0   32G   0% /dev/shm
              tmpfs          tmpfs      13G  132K   13G   1% /run
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     6.3G     0  6.3G   0% /run/user/1000
              Show mounted filesystems:
              TARGET SOURCE     FSTYPE OPTIONS
              /      /dev/loop2 ext4   rw,relatime
              /var:
              605M    /var/
              282M    /var/log/journal/bb1a573610aa48a7948bbf161935960d
              282M    /var/log
              231M    /var/lib
              Archived and active journals take up 281.1M in the file system.
              /opt/iobroker/backups:
              507M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              769M    /opt/iobroker/iobroker-data/
              558M    /opt/iobroker/iobroker-data/files
              217M    /opt/iobroker/iobroker-data/files/vis-2
              141M    /opt/iobroker/iobroker-data/files/vis-2/assets
              135M    /opt/iobroker/iobroker-data/backup-objects
              43M     /opt/iobroker/iobroker-data/objects.jsonl
              34M     /opt/iobroker/iobroker-data/states.jsonl
              34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-DqJdyjgH.js.map
              34M     /opt/iobroker/iobroker-data/files/vis-2/assets/index-CrLrNq4s.js.map
              20M     /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
              USB-Devices by-id:
              USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
              please always prefer the links 'by-id':
              No Devices found 'by-id'
              No nvbackup.json found.
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v24.5.0
              /usr/bin/node           v24.5.0
              /usr/bin/npm            11.5.1
              /usr/bin/npx            11.5.1
              ✓ Node.js installation is correct
              nodejs:
                Installed: 24.5.0-1nodesource1
                Candidate: 24.14.1-1nodesource1
                Version table:
                   24.14.1-1nodesource1 600
                      500 https://deb.nodesource.com/node_24.x nodistro/main amd64 Packages
                   24.14.0-1nodesource1 600
                   24.13.1-1nodesource1 600
                   24.13.0-1nodesource1 600
                   24.12.0-1nodesource1 600
                   24.11.1-1nodesource1 600
                   24.11.0-1nodesource1 600
                   24.10.0-1nodesource1 600
                   24.9.0-1nodesource1 600
                   24.8.0-1nodesource1 600
                   24.7.0-1nodesource1 600
                   24.6.0-1nodesource1 600
               *** 24.5.0-1nodesource1 600
                   24.4.1-1nodesource1 600
                   24.4.0-1nodesource1 600
                   24.3.0-1nodesource1 600
                   24.1.0-1nodesource1 600
                   24.0.2-1nodesource1 600
                   24.0.1-1nodesource1 600
                   24.0.0-1nodesource1 600
                   18.20.4+dfsg-1~deb12u1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                      500 http://security.debian.org bookworm-security/main amd64 Packages
              No problems detected
              Errors in npm tree: 0
              The current Node.js version (v24.5.0) is vulnerable to the following CVEs:
              CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
              This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
              Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
              CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
              CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
              CVE-2025-59464(medium): A memory leak in Node.js’s OpenSSL integration occurs when converting `X.509` certificate fields to UTF-8 without freeing the allocated buffer. When applications call `socket.getPeerCertificate(true)`, each certificate field leaks memory, allowing remote clients to trigger steady memory growth through repeated TLS connections. Over time this can lead to resource exhaustion and denial of service.
              CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
              server.on('secureConnection', socket => {
              socket.on('error', err => {
              console.log(err)
              CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
              CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves `SNICallback` invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
              When an `SNICallback` throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
              * This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including **20.x, 22.x, 24.x, and 25.x**, on any TLS server where `SNICallback` may throw on unexpected `servername` input.
              Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
              CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught `TypeError` when a request is received with a header named `__proto__` and the application accesses `req.headersDistinct`.
              When this occurs, `dest["__proto__"]` resolves to `Object.prototype` rather than `undefined`, causing `.push()` to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by `error` event listeners, meaning it cannot be handled without wrapping every `req.headersDistinct` access in a `try/catch`.
              * This vulnerability affects all Node.js HTTP servers on **20.x, 22.x, 24.x, and v25.x**
              CVE-2026-21712(medium): A flaw in Node.js URL processing causes an assertion failure in native code when `url.format()` is called with a malformed internationalized domain name (IDN) containing invalid characters, crashing the Node.js process.
              * This vulnerability affects **24.x and 25.x**.
              Patched versions: ^24.14.1 || ^25.8.2
              CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
              Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
              This vulnerability affects **20.x, 22.x, 24.x, and 25.x**.
              CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
              This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
              CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves `fs.realpathSync.native()` without the required read permission checks, while all comparable filesystem functions correctly enforce them.
              As a result, code running under `--permission` with restricted `--allow-fs-read` can still use `fs.realpathSync.native()` to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
              This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-read` is intentionally restricted.
              CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves `FileHandle.chmod()` and `FileHandle.chown()` in the promises API without the required permission checks, while their callback-based equivalents (`fs.fchmod()`, `fs.fchown()`) were correctly patched.
              As a result, code running under `--permission` with restricted `--allow-fs-write` can still use promise-based `FileHandle` methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
              This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-write` is intentionally restricted.
              CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
              The most common trigger is any endpoint that calls `JSON.parse()` on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
              *** ioBroker-Installation ***
              ioBroker Status
              iobroker is not running on this host.
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker            iobroker (version: 7.1.0, hostname: iobroker      , alive, uptime: 17)
              Core adapters versions
              js-controller:  7.1.0
              admin:          7.8.20
              javascript:     9.1.1
              nodejs modules from github:     2
              +-- iobroker.ecovacs-deebot@1.4.16-alpha.7 (git+ssh://git@github.com/mrbungle64/ioBroker.ecovacs-deebot.git#2b8cdedde82e5f0d7057d3403e9cf45fc7a02d0c)
              +-- iobroker.klipper-moonraker@0.1.0 (git+ssh://git@github.com/DrozmotiX/ioBroker.klipper-moonraker.git#0d2851e98f7443e85ebe29d98d8d725640dd0a8a)
              Adapter State
                system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
                system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
                system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
                system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                system.adapter.gotify.0                 : gotify                : iobroker                                 -  enabled
                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                system.adapter.klipper-moonraker.0      : klipper-moonraker     : iobroker                                 - disabled
                system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
                system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
                system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
                system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
                system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 - disabled, port: 9000
                system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
                system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
                system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
                system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
              + instance is alive
              ioBroker-Repositories
              │ (index) │ name      │ url        │ auto upgrade │
              │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
              │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
              │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
              │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
              Active repo(s): online, beta
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repositories: online, beta
              Cannot download repository hash file from "https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist-hash.json": Request failed with status code 404
              Adapter    "admin"        : 7.8.20   , installed 7.8.20
              Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
              Adapter    "alias-manager": 2.1.0    , installed 2.1.0
              Adapter    "awattar"      : 1.0.6    , installed 1.0.6
              Adapter    "backitup"     : 3.3.15   , installed 3.3.15
              Adapter    "denon"        : 1.15.12  , installed 1.15.12
              Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.16-alpha.7
              Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
              Adapter    "evcc"         : 0.2.8    , installed 0.2.8
              Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
              Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
              Adapter    "fullybrowser" : 3.1.3    , installed 3.1.3
              Adapter    "gotify"       : 0.5.0    , installed 0.5.0
              Adapter    "ical"         : 1.20.0   , installed 1.20.0
              Adapter    "iot"          : 6.0.1    , installed 6.0.1
              Adapter    "javascript"   : 9.2.0    , installed 9.1.1  [Updatable]
              Controller "js-controller": 7.1.1    , installed 7.1.0  [Updatable]
              Adapter    "knx"          : 2.0.39   , installed 2.0.39
              Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
              Adapter    "nina"         : 0.0.26   , installed 0.0.26
              Adapter    "node-red"     : 6.0.7    , installed 6.0.7
              Adapter    "nuki"         : 2.0.0    , installed 2.0.0
              Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
              Adapter    "ping"         : 2.1.0    , installed 2.1.0
              Adapter    "pirate-weather": 0.8.0   , installed 0.8.0
              Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
              Adapter    "renault"      : 0.0.22   , installed 0.0.22
              Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
              Adapter    "scenes"       : 4.0.4    , installed 4.0.4
              Adapter    "shelly"       : 10.6.1   , installed 10.6.1
              Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
              Adapter    "socketio"     : 7.1.3    , installed 7.1.3
              Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
              Adapter    "sql"          : 3.0.1    , installed 3.0.1
              Adapter    "squeezeboxrpc": 1.6.4    , installed 1.6.4
              Adapter    "sureflap"     : 3.4.2    , installed 3.4.2
              Adapter    "traccar"      : 1.1.7    , installed 1.1.6  [Updatable]
              Adapter    "tuya"         : 3.17.0   , installed 3.17.0
              Adapter    "unifi"        : 0.7.0    , installed 0.7.0
              Adapter    "unifi-network": 1.4.0    , installed 1.4.0
              Adapter    "vis-2"        : 2.13.17  , installed 2.13.17
              Adapter    "vis-2-widgets-collection": 2.4.1, installed 2.4.1
              Adapter    "vis-2-widgets-inventwo": 0.6.5, installed 0.6.5
              Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
              Adapter    "vis-colorpicker": 2.1.0  , installed 2.1.0
              Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
              Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
              Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
              Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
              Adapter    "web"          : 8.1.0    , installed 8.1.0
              Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
              Adapter    "worx"         : 3.3.0    , installed 3.3.0
              Adapter    "ws"           : 4.1.0    , installed 4.1.0
              Objects and States
              Objects:        31715
              States:         30867
              W: https://packages.microsoft.com/ubuntu/16.04/prod/dists/xenial/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
              Hit:1 http://security.debian.org bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:4 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
              Hit:5 https://deb.nodesource.com/node_24.x nodistro InRelease
              Reading package lists...
              Pending systemupdates: 102
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          839430941  330/master
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          839431662  1/init
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          839430942  330/master
              tcp6       0      0 :::111                  :::*                    LISTEN      0          839431664  1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          839433330  1/init
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839431663  1/init
              udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          839433415  168/ntpd
              udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          839433413  168/ntpd
              udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          839433411  168/ntpd
              udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          839433407  168/ntpd
              udp6       0      0 :::111                  :::*                                0          839431665  1/init
              udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        839433669  168/ntpd
              udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839433667  168/ntpd
              udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        839433665  168/ntpd
              udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839433663  168/ntpd
              udp6       0      0 ::1:123                 :::*                                0          839433417  168/ntpd
              udp6       0      0 :::123                  :::*                                0          839433404  168/ntpd
              2026-04-14 19:03:42.345  - warn: host.iobroker instance system.adapter.ping.0 terminated due to SIGKILL
              2026-04-14 19:03:42.359  - warn: host.iobroker instance system.adapter.iot.0 terminated due to SIGKILL
              2026-04-14 19:03:42.359  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
              2026-04-14 19:03:55.082  - warn: admin.0 (343) Cannot update news: ETIMEDOUT
              2026-04-14 19:04:10.715  - error: host.iobroker Caught by controller[0]: (node:415) [DEP0176] DeprecationWarning: fs.F_OK is deprecated, use fs.constants.F_OK instead
              2026-04-14 19:04:10.718  - error: host.iobroker Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
              2026-04-14 19:04:10.718  - warn: host.iobroker instance system.adapter.javascript.0 terminated due to SIGTERM
              2026-04-14 19:04:11.307  - warn: admin.0 (343) get state error: Connection is closed.
              2026-04-14 19:04:11.345  - error: admin.0 (343) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              2026-04-14 19:04:11.345  - error: admin.0 (343) unhandled promise rejection: Connection is closed.
              2026-04-14 19:04:11.414  - error: admin.0 (343) Error: Connection is closed.
                  at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                  at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                  at StateRedisClient.pushMessage (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1215:27)
                  at Admin.registerNotification (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7771:28)
                  at Admin.writeUpdateInfo (/opt/iobroker/node_modules/iobroker.admin/build/src/main.ts:890:20)
              2026-04-14 19:04:11.604  - error: host.iobroker Caught by controller[0]: (node:343) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[0]: (Use `node --trace-warnings ...` to show where the warning was created)
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]: Error: Connection is closed.
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Redis.publish (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at StateRedisClient.pushMessage (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:1215:27)
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Admin.registerNotification (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:7771:28)
              2026-04-14 19:04:11.605  - error: host.iobroker Caught by controller[1]:     at Admin.writeUpdateInfo (/opt/iobroker/node_modules/iobroker.admin/build/src/main.ts:890:20)
              HomoranH crunchipC 2 Antworten Letzte Antwort
              • Ro75R Offline
                Ro75R Offline
                Ro75
                nodejs >22.x warum? Beta Repo warum?
                Ro75.
                • Q quinti
                  bash
                  Script v.2026-01-31
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                  CPU threads: 3
                                   RTC time: n/a
                                NTP service: n/a
                            RTC in local TZ: no
                  hermann
                  HOME=/home/hermann
                  Display-Manager:
                  Desktop:
                  Session:                tty
                  *** MEMORY ***
                  Swap:           8.6G          0B        8.6G
                  Total:           17G         56M         16G
                           8192 M total memory
                             54 M used memory
                            206 M active memory
                           7747 M free memory
                              0 M buffer memory
                            390 M swap cache
                           8191 M total swap
                              0 M used swap
                           8191 M free swap
                  *** FILESYSTEM ***
                  /var:
                  605M    /var/
                  282M    /var/log
                  231M    /var/lib
                  USB-Devices by-id:
                  /usr/bin/npm            11.5.1
                  /usr/bin/npx            11.5.1
                  nodejs:
                    Version table:
                  console.log(err)
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  admin:          7.8.20
                  javascript:     9.1.1
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        31715
                  States:         30867
                  @quinti sagte:
                  Da stimmt was grundsätzlich nicht, diag würde nie lügen!
                  OS zu alt
                  @quinti sagte:
                  Läuft iobroker gar nicht?
                  @quinti sagte:
                  • iobroker.service loaded failed failed ioBroker Server
                  Was ist da los?
                  @quinti sagte:
                  Node 24 ist noch nicht für iob empfohlen
                  @quinti sagte:
                  Warum 2 repos gleichzeitig?
                  @quinti sagte:
                  A
                  updaten!
                  @quinti sagte:
                  Dito
                  • Q quinti
                    bash
                    Script v.2026-01-31
                    *** BASE SYSTEM ***
                      Virtualization: lxc
                    OS is similar to:
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : 64 bit
                    CPU threads: 3
                                     RTC time: n/a
                                  NTP service: n/a
                              RTC in local TZ: no
                    hermann
                    HOME=/home/hermann
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Swap:           8.6G          0B        8.6G
                    Total:           17G         56M         16G
                             8192 M total memory
                               54 M used memory
                              206 M active memory
                             7747 M free memory
                                0 M buffer memory
                              390 M swap cache
                             8191 M total swap
                                0 M used swap
                             8191 M free swap
                    *** FILESYSTEM ***
                    /var:
                    605M    /var/
                    282M    /var/log
                    231M    /var/lib
                    USB-Devices by-id:
                    /usr/bin/npm            11.5.1
                    /usr/bin/npx            11.5.1
                    nodejs:
                      Version table:
                    console.log(err)
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    admin:          7.8.20
                    javascript:     9.1.1
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        31715
                    States:         30867
                    crunchipC Offline
                    crunchipC Offline
                    @quinti da ist doch etwas mit deinem Arbeitsspeicher faul
                      @quinti sagte:
                      OS zu alt
                      @quinti sagte:
                      @quinti sagte:
                      Was ist da los?
                      @quinti sagte:
                      @quinti sagte:
                      @quinti sagte:
                      A
                      updaten!
                      @quinti sagte:
                      Dito
                      @Homoran sagte:
                      Kann ich nicht ausschließen...
                      Aber die Diagnose basiert natürlich auf Daten aus dem System.
                      basiert natürlich auf veralteten Informationen, da ja das running süstäm nie getascht wurde.
                      Wäre das auf Stand wäre auch die Diagnose richtig.
                      Insgesamt ist das Dig aber komplett inkonsistent aufgebaut. nodejs@24 auf einem ansonsten versumpften Bookworm mit iob-Beta-Quelle macht gar keinen Sinn. Wo soll es denn hingehen? Bleeding edge oder 'never tatsch irgendwas'? Beides kombiniert kann nicht gut funktionieren.
                      Und wozu solll die microsoft/xenial-Quelle gut sein? Davon ganz abgesehen, dass sie natürlich nicht mehr funktioniert.
                      • Q Offline
                        Q Offline
                        quinti
                        sry, hatte iwie im kopf das iob diag mit gestopptem iobroker laufen muss. Habs wohl verwechselt mit iob fix --> alter mann
                        Das microsoft repository ist drin da ich mal einen mssql client installiert habe.
                        Bin noch auf bookworm da iobroker in einem proxmox container läuft und proxmox noch auf 8.2.2 mit bookworm ist. Möchte im moment proxmox nicht upgraden. Ist wohl z Zt ein bug drin der grub durcheinander bringt. Hat mir letzte Woche meinen tvheadend Rechner zerschossen.
                        Hab mal updates durchgeführt.
                        hier neues diag mit gestartetem iobroker ;)
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                         20:13:47 up 16 min,  2 users,  load average: 1.74, 1.83, 1.82
                        CPU threads: 3
                        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
                                       Local time: Tue 2026-04-14 20:13:47 CEST
                                   Universal time: Tue 2026-04-14 18:13:47 UTC
                                         RTC time: n/a
                                      NTP service: n/a
                                  RTC in local TZ: no
                        hermann
                        HOME=/home/hermann
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Mem:            8.6G        4.3G        3.2G        143K        1.1G        4.3G
                        Swap:           8.6G          0B        8.6G
                        Total:           17G        4.3G         11G
                        Active iob-Instances:   39
                                 8192 M total memory
                                 4116 M used memory
                                 3929 M active memory
                                  867 M inactive memory
                                 3032 M free memory
                                    0 M buffer memory
                                 1043 M swap cache
                                 8191 M total swap
                                    0 M used swap
                                 8191 M free swap
                        top - 20:13:48 up 16 min,  2 users,  load average: 1.74, 1.83, 1.82
                        Tasks:  69 total,   1 running,  68 sleeping,   0 stopped,   0 zombie
                        MiB Mem :   8192.0 total,   3030.9 free,   4118.0 used,   1043.3 buff/cache
                        MiB Swap:   8192.0 total,   8192.0 free,      0.0 used.   4074.0 avail Mem
                        1 loaded units listed.
                        *** FILESYSTEM ***
                        /dev/loop2     ext4       24G   11G   13G  45% /
                        tmpfs          tmpfs      13G  136K   13G   1% /run
                        /var:
                        613M    /var/
                        290M    /var/log/journal/bb1a573610aa48a7948bbf161935960d
                        290M    /var/log
                        231M    /var/lib
                        Archived and active journals take up 289.1M in the file system.
                        742M    /opt/iobroker/iobroker-data/
                        36M     /opt/iobroker/iobroker-data/objects.jsonl
                        14M     /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        /usr/bin/nodejs         v24.14.1
                        /usr/bin/node           v24.14.1
                        /usr/bin/npm            11.11.0
                        /usr/bin/npx            11.11.0
                        nodejs:
                          Installed: 24.14.1-1nodesource1
                          Version table:
                         *** 24.14.1-1nodesource1 600
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 7.1.1, hostname: iobroker      , alive, uptime: 316)
                        js-controller:  7.1.1
                        admin:          7.8.20
                        javascript:     9.2.0
                        Adapter State
                        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                        + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : iobroker                                 -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                        + system.adapter.evcc.0                   : evcc                  : iobroker                                 -  enabled, port: 7070
                        + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                        + system.adapter.gotify.0                 : gotify                : iobroker                                 -  enabled
                        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.knx.0                    : knx                   : iobroker                                 -  enabled, bind: 192.168.101.102
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                        + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
                        + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                        + system.adapter.pirate-weather.0         : pirate-weather        : iobroker                                 -  enabled
                        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                        + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                        + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
                          system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                        + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                        + system.adapter.sureflap.0               : sureflap              : iobroker                                 -  enabled
                        + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                        + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                        + system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                        + system.adapter.worx.0                   : worx                  : iobroker                                 -  enabled
                        + instance is alive
                        Active repo(s): beta
                        Used repository: beta
                        Adapter    "javascript"   : 9.2.0    , installed 9.2.0
                        Controller "js-controller": 7.1.1    , installed 7.1.1
                        Adapter    "traccar"      : 1.1.7    , installed 1.1.7
                        Objects and States
                        Objects:        31783
                        States:         31368
                        Hit:4 https://deb.nodesource.com/node_24.x nodistro InRelease
                        Hit:5 https://packages.microsoft.com/ubuntu/16.04/prod xenial InRelease
                        Pending systemupdates: 0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       840021606  4327/iobroker.js-co
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       840021611  4327/iobroker.js-co
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          839861821  333/master
                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       840025688  4603/io.mqtt.0
                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       840042633  4802/io.sonoff.0
                        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       840037661  4785/io.shelly.0
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          839864060  1/init
                        tcp6       0      0 :::51989                :::*                    LISTEN      1001       840031495  4736/io.nuki-extend
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          839864062  1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          839864218  1/init
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       840056132  5058/io.simple-api.
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       840057907  5156/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       840021668  4348/io.admin.0
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          839861822  333/master
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       840042801  4851/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       840042802  4851/io.tuya.0
                        udp        0      0 192.168.101.102:54278   0.0.0.0:*                           1001       840025951  4719/io.knx.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          839864061  1/init
                        udp        0      0 192.168.101.102:123     0.0.0.0:*                           0          839859795  164/ntpd
                        udp        0      0 192.168.0.102:123       0.0.0.0:*                           0          839859793  164/ntpd
                        udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          839859791  164/ntpd
                        udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          839859787  164/ntpd
                        udp6       0      0 :::111                  :::*                                0          839864063  1/init
                        udp6       0      0 fe80::be24:11ff:fe3:123 :::*                                106        839862059  164/ntpd
                        udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839862057  164/ntpd
                        udp6       0      0 fe80::be24:11ff:fe0:123 :::*                                106        839862055  164/ntpd
                        udp6       0      0 fd6d:f83d:ff15:0:be:123 :::*                                106        839862053  164/ntpd
                        udp6       0      0 ::1:123                 :::*                                0          839859797  164/ntpd
                        udp6       0      0 :::123                  :::*                                0          839859784  164/ntpd
                        • Ro75R Offline
                          Ro75R Offline
                          Ro75
                          ändert nichts an der Tatsache nodejs >22 warum? Beta-Repo warum? OS läuft aus. ...
                          Ro75.
                          • Q quinti
                            Script v.2026-01-31
                            *** BASE SYSTEM ***
                              Virtualization: lxc
                            OS is similar to:
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 3
                                             RTC time: n/a
                                          NTP service: n/a
                                      RTC in local TZ: no
                            hermann
                            HOME=/home/hermann
                            iobroker
                            HOME=/home/iobroker
                            Display-Manager:
                            Desktop:
                            Session:                tty
                            *** MEMORY ***
                            Swap:           8.6G          0B        8.6G
                            Total:           17G        4.3G         11G
                                     8192 M total memory
                                     4116 M used memory
                                     3032 M free memory
                                        0 M buffer memory
                                     1043 M swap cache
                                     8191 M total swap
                                        0 M used swap
                                     8191 M free swap
                            *** FILESYSTEM ***
                            /var:
                            613M    /var/
                            290M    /var/log
                            231M    /var/lib
                            USB-Devices by-id:
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.8.20
                            javascript:     9.2.0
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        31783
                            States:         31368
                            @quinti sagte:
                            Dann schmeiß den alten Mist da raus. xenial ist 10 Jahre alt!!!
                            • Ro75R Ro75
                              Ro75.
                              @Ro75 sagte:
                              Ro75.
                              @quinti und noch alle Updates fahren.
                              Die sind noch im bookworm offen!
                              Wir reden nicht von Trixie
                              Q 1 Antwort Letzte Antwort
                              • Ro75R Offline
                                Ro75R Offline
                                Ro75
                                @quinti und wenn du schon Beta nutzt, dann muss du auch damit rechnen, dass etwas möglicherweise nicht so funktioniert wie gewollt - hat BETA und nicht STABLE. Eventuell solltest du alles auf Stable zurück.
                                Ro75.
                                  @Ro75 sagte:
                                  Ro75.
                                  Q Offline
                                  Q Offline
                                  quinti
                                  @Homoran sagte:
                                  @Ro75 sagte:
                                  Ro75.
                                  apt update/upgrade zeigt aber nichts mehr an zum updaten?
                                  • Q quinti
                                    @Homoran sagte:
                                    @Ro75 sagte:
                                    Ro75.
                                    @quinti sagte:
                                    Zeigen!
                                    Mit vollständiger Eingabe
                                    • Q quinti
                                      Script v.2026-01-31
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      CPU threads: 3
                                                       RTC time: n/a
                                                    NTP service: n/a
                                                RTC in local TZ: no
                                      hermann
                                      HOME=/home/hermann
                                      iobroker
                                      HOME=/home/iobroker
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Swap:           8.6G          0B        8.6G
                                      Total:           17G        4.3G         11G
                                               8192 M total memory
                                               4116 M used memory
                                               3032 M free memory
                                                  0 M buffer memory
                                               1043 M swap cache
                                               8191 M total swap
                                                  0 M used swap
                                               8191 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      613M    /var/
                                      290M    /var/log
                                      231M    /var/lib
                                      USB-Devices by-id:
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.8.20
                                      javascript:     9.2.0
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        31783
                                      States:         31368
                                      @quinti sagte:
                                      Sorry, hab das letzte diag übersehen
                                        @quinti sagte:
                                        Zeigen!
                                        Q Offline
                                        Q Offline
                                        quinti
                                        @Homoran sagte:
                                        @quinti sagte:
                                        Zeigen!
                                        root@iobroker:~# apt update
                                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                                        Reading package lists... Done
                                        All packages are up to date.
                                        root@iobroker:~# apt upgrade
                                        Calculating upgrade... Done
                                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                        root@iobroker:~#
                                        • Q quinti
                                          @Homoran sagte:
                                          @quinti sagte:
                                          Zeigen!
                                          root@iobroker:~#
                                          @quinti ok, siehe letzten Post von mir
                                          Aber wieso bist du root?
