  4. [gelöst] iU891A-XL Instanz Wireless mbus mit Fehler
27 Beiträge 2 Kommentatoren 974 Aufrufe 2 Beobachtet
  • D DGR
    Ich habe mal die Nacht seit gestern abgewartet und das Problem ist erneut aufgetreten. So war der Stand heute früh (Haupt- und Gartenwasserzähler):
    Zeit
    error
    Nachricht
    wireless-mbus.0
    2026-03-19 08:53:55.957	error	Timeout waiting for response
    wireless-mbus.0
    2026-03-19 08:53:55.957	error	Error opening serial port /dev/ttyACM1 with baudrate 115200
    wireless-mbus.0
    2026-03-19 08:53:55.956	error	IMSTv2: Failed to init device: Timeout waiting for response
    wireless-mbus.0
    2026-03-19 08:53:52.960	error	application layer message too short, expected 84, got 32 bytes
    wireless-mbus.0
    2026-03-19 08:53:48.242	error	Serialport error: Port is not open
    Ein weiterer Restart der Instanz brachte:
    host.raspi2
    2026-03-19 09:02:07.620	error	instance system.adapter.wireless-mbus.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    wireless-mbus.0
    2026-03-19 09:02:07.068	error	Exception-Code: ERR_BUFFER_OUT_OF_BOUNDS: Attempt to access memory outside buffer bounds
    wireless-mbus.0
    2026-03-19 09:02:07.068	error	RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds at boundsError (node:internal/buffer:86:11) at Buffer.readInt32LE (node:internal/buffer:392:5) at ImstV2Receiver.parseRawMessage (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/ImstV2Receiver.js:108:46) at ImstV2Receiver.emitMessage (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/SerialDevice.js:135:36) at ImstV2Receiver.onData (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/SerialDevice.js:122:22) at SerialPort.emit (node:events:519:28) at addChunk (node:internal/streams/readable:561:12) at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) at Readable.push (node:internal/streams/readable:392:5) at /opt/iobroker/node_modules/iobroker.wireless-mbus/node_modules/@serialport/stream/dist/index.js:208:18
    wireless-mbus.0
    2026-03-19 09:02:07.067	error	unhandled promise rejection: Attempt to access memory outside buffer bounds
    wireless-mbus.0
    2026-03-19 09:02:07.067	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    wireless-mbus.0
    2026-03-19 09:02:02.348	error	Serialport error: Port is not open
    @DGR sagte in iU891A-XL Instanz Wireless mbus mit Fehler:
    stimmt der Port
    port /dev/ttyACM1
    ls /dev/serial/by-id/ sagt?
      stimmt der Port
      port /dev/ttyACM1
      DGR
      @Homoran sagte in iU891A-XL Instanz Wireless mbus mit Fehler:
      ls /dev/serial/-by-id/
      pi@raspi2:~ $ ls /dev/serial/-by-id/
      ls: Zugriff auf '/dev/serial/-by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunde
        DGR
        pi@raspi2:~ $ ls /dev/serial/by-id/
        usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00  usb-IMST_iU891A_IMS4139-if00
          DGR
          ich würde vielleicht auch wmbusmeters von github installieren und es damit versuchen, aber mir fehlt eine Installationsanleitung.
          • D DGR
            @DGR sorry mein Typo!
            hab's korrigiert.
            Dann trag doch mal statt /dev/ACM1 ein: /dev-serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00
            • D DGR
              wofür?
              Expertenmodus - Installation von Github - wmbusmeter
              aber nur für Experten!
                DGR
                pi@raspi2:~ $ ls /dev-serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00
                ls: Zugriff auf '/dev-serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00' nicht möglich: Datei oder Verzeichnis nicht gefunden
                • D DGR
                  @DGR was versuchst du da?
                    DGR
                    Was habe ich hier falsch verstanden ?
                    "Dann trag doch mal statt /dev/ACM1 ein: /dev-serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00"
                      DGR
                      es sind am Raspi 2 USB-Ports belegt. Einmal mit Conbee II und einmal mit iu891A-XL
                      • D DGR
                        das weiss ich nicht!
                        das solltest du hier eintragen
                        • D DGR
                          warum tröpfeln wichtige Informationen nur immer erst wenn man mehrfach nachfragt??
                          Also wird der wmbus im Moment gar nicht vom RasPi gesehen???
                          Abziehen
                          Einstecken
                          ls.... ausführen!
                            DGR
                            Das Kuriose ist, obwohl ich in der Zeit nichts weiter geändert habe und nur hier die Kommunikation mit den oben genannten Befehlen stattfand ist der Zustand jetzt:
                            Wie auch schon vorher sind beide USB-Ports mit der Belegung sichtbar:
                            • D DGR
                              ist das dann der mbus-Stick?
                              dann trag das entsprechend in der Instanz ein
                              mach mal ein ls -la /dev/serial/by-id/
                                DGR
                                pi@raspi2:~ $ ls -la /dev/serial/by-id/
                                insgesamt 0
                                drwxr-xr-x 2 root root 80 19. Mär 03:31 .
                                drwxr-xr-x 4 root root 80 14. Mär 14:57 ..
                                lrwxrwxrwx 1 root root 13 19. Mär 03:31 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00 -> ../../ttyACM0
                                lrwxrwxrwx 1 root root 13 18. Mär 09:04 usb-IMST_iU891A_IMS4139-if00 -> ../../ttyACM1
                                  DGR
                                  Was wmbusmeters betrifft. Hier kann ich das nicht finden. Auch nicht bei Beta.
                                  • D DGR
                                    @DGR dann den pfad des Repos im rechten Reiter eintragen.
                                    Aber wie gesagt!
                                    nur für Experten
                                    was da liegt, muss nicht lauffähig sein
                                    • D DGR
                                      insgesamt 0
                                      @DGR da fehlt das /dev/serial/by-id/ davor
                                        DGR
                                        host.raspi2
                                        2026-03-19 10:39:21.776	error	instance system.adapter.wireless-mbus.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                        wireless-mbus.0
                                        2026-03-19 10:39:21.238	error	Exception-Code: ERR_BUFFER_OUT_OF_BOUNDS: Attempt to access memory outside buffer bounds
                                        wireless-mbus.0
                                        2026-03-19 10:39:21.237	error	RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds at boundsError (node:internal/buffer:86:11) at Buffer.readUInt16LE (node:internal/buffer:245:5) at HciMessageV2.parse (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/HciMessageV2.js:131:28) at ImstV2Receiver.isTelegramMessage (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/ImstV2Receiver.js:92:13) at ImstV2Receiver.onData (/opt/iobroker/node_modules/iobroker.wireless-mbus/lib/receiver/SerialDevice.js:119:23) at SerialPort.emit (node:events:519:28) at addChunk (node:internal/streams/readable:561:12) at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) at Readable.push (node:internal/streams/readable:392:5) at /opt/iobroker/node_modules/iobroker.wireless-mbus/node_modules/@serialport/stream/dist/index.js:208:18
                                        wireless-mbus.0
                                        2026-03-19 10:39:21.237	error	unhandled promise rejection: Attempt to access memory outside buffer bounds
                                        wireless-mbus.0
                                        2026-03-19 10:39:21.236	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                        wireless-mbus.0
                                        2026-03-19 10:39:16.461	error	Serialport error: Port is not open
                                        • D DGR
                                          host.raspi2
                                          wireless-mbus.0
                                          wireless-mbus.0
                                          wireless-mbus.0
                                          wireless-mbus.0
                                          wireless-mbus.0
                                          warum auch immer
