  4. Remko Wärmepumpe ModBus-Anbindung
19 Beiträge 2 Kommentatoren 887 Aufrufe 1 Beobachtet
  • L Offline
    luas
    was steht im debug log?
    Invalid data holdingRegisters/0: {"_address":"10010","name":"temp_set","description":"","unit":"","type":"","len":"","factor":1,"offset":0,"formula":"","role":"level","room":"","poll":"","wp":"","cw":"","isScale":"","address":-29991,"deviceId":1,"fullId":"modbus.8.0"}
    Invalid object: {"type":"state","common":{"name":"","role":"level","type":"number","read":false,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":-29991,"deviceId":1,"type":"","len":"","offset":0,"factor":1,"poll":""}}
    Auf der zweiten Einstellungsseite habe ich nichts verändert.
    das heisst? was steht da?
    wie ist die Geräte ID?
    Soweit ich sehe "1". Das ist laut Doku der Default, und so hatte ich auch mit QModBus Erfolg.
    wie ist der Register-offset?
    Da bin ich überfragt. Wo könnte ich das herausfinden?
    • L luas
      @luas sagte in Remko Wärmepumpe ModBus-Anbindung:
      "address":-29991
      das hatte ich befürchtet!
      nimm mal da den Haken raus!
      • L Offline
        luas
        Immer noch Fehler, aber anders:
        • L luas
          @luas bitte keine Bildchen!
          Logs alst Text in code-tags posten
          • L Offline
            luas
            Verzeihung. So:
            modbus.8 2026-03-14 22:09:55.122	debug	[DevID_1] Poll start ---------------------
            modbus.8 2026-03-14 22:09:55.121	info	Connected to slave
            modbus.8 2026-03-14 22:09:50.002	debug	connect to serial /dev/ttyUSB0 with 9600
            modbus.8 2026-03-14 22:09:49.917	info	Can not execute task add for ID undefined: Parameter "id" needs to be of type "string" but type "undefined" has been passed
            modbus.8 2026-03-14 22:09:49.864	debug	Add undefined: {"type":"state","common":{"name":"","role":"level","type":"number","read":false,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":-29991,"deviceId":1,"type":"","len":"","offset":0,"factor":1,"poll":""}}
            modbus.8 2026-03-14 22:09:49.864	error	Invalid object: {"type":"state","common":{"name":"","role":"level","type":"number","read":false,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":-29991,"deviceId":1,"type":"","len":"","offset":0,"factor":1,"poll":""}}
            modbus.8 2026-03-14 22:09:49.863	error	Invalid data holdingRegisters/0: {"_address":-29991,"name":"temp_set","description":"","unit":"","type":"","len":"","factor":1,"offset":0,"formula":"","role":"level","room":"","poll":"","wp":"","cw":"","isScale":"","address":-29991,"deviceId":1,"fullId":"modbus.8.0"}
            modbus.8 2026-03-14 22:09:49.863	debug	Initialize Objects for holdingRegs: [{"_address":-29991,"name":"temp_set","description":"","unit":"","type":"","len":"","factor":1,"offset":0,"formula":"","role":"level","room":"","poll":"","wp":"","cw":"","isScale":"","address":-29991,"deviceId":1}]
            modbus.8 2026-03-14 22:09:49.863	debug	Initialize Objects for inputRegs: []
            modbus.8 2026-03-14 22:09:49.863	debug	Initialize Objects for coils: []
            modbus.8 2026-03-14 22:09:49.863	debug	Initialize Objects for disInputs: []
            modbus.8 2026-03-14 22:09:49.741	info	starting. Version 7.0.6 in /opt/iobroker/node_modules/iobroker.modbus, node: v22.22.0, js-controller: 7.0.7
            modbus.8 2026-03-14 22:09:49.582	debug	Plugin sentry Initialize Plugin (enabled=true)
            • L luas
              Verzeihung. So:
              welcher Register steht denn jetzt in der Registerkonfiguration???
              • L Offline
                luas
                Oh, da stand plötzlich -29991. Ich habe erneut 10100 eingetragen, jetzt ist der Eintrag im Objektbaum erschienen. Juhu!
                Allerdings noch mit Wert "0" - "substitute initial value"
                Im Log jetzt keine Störungsmeldungen mehr. Vielleicht nur noch eine Frage des Datentyps?
                • L luas
                  Vielleicht
                  • Haken bei Abfrage fehlt!
                  • falscher offset
                    • nimm mal einen niedriger oder einen höher
                  • falsches Register
                    • warum jetzt 10100? bisher 10010!
                  • falscher USB-Port
                    • sinnvoll immer den /dev/serial/by-id zu nehmen
                  • falscher Faktor
                  • oder anderer Fehler
                  und ja!
                  Den Typ musst du angeben.
                  L 1 Antwort Letzte Antwort
                    Vielleicht
                    • falscher offset
                    • falsches Register
                    • falscher USB-Port
                    • falscher Faktor
                    und ja!
                    luas
                    falsches Register
                    Mist, ja.
                    Ich sehe /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_BG02Q6FL-if00-port0
                    Aber wie würde ich das eintragen? Auf der Verbindungsseite ist es nur ein Drop-Down-Feld
                    Und für die übrigen Fragen scheint mir das ein guter Moment, um noch mal beim Support nachzuhaken. Danke soweit, ich melde mich, wenn es etwas Neues gibt!
                    • L luas
                      falsches Register
                      Mist, ja.
                      ohne benutzerdefiniert?
                      nöö!
                      was kommt jetzt mit dem richtigen Register und angehakter Checkbox Abfrage?
                      • L Offline
                        luas
                        Ja. Aber passt. Funktioniert erst mal.
                        nöö! was kommt jetzt mit dem richtigen Register und angehakter Checkbox Abfrage?
                        Die Mischung macht's. Der Support schreibt:
                        "unsere Geräte verwenden standardmäßig 16-Bit-Modbus-Register mit Big-Endian-Byte-Reihenfolge (MSB first).
                        Daher sollte der Wert als Unsigned 16-Bit Integer (Big-Endian) interpretiert werden. Da laut Registertabelle keine negativen Werte vorkommen, ist dies der passende Datentyp. Alternativ kann auch Signed 16-Bit (Big-Endian) funktionieren."
                        Mit Unsigned 16-Bit (Big-Endian) (und "Abfrage"-Checkbox?) haut es tatsächlich hin, Juhu!
                        Es geht aber gleich wieder schief, wenn ich versuche, Register 10000 abzufragen:
                        modbus.8 2026-03-17 19:01:15.315	info	Disconnected from slave
                        modbus.8 2026-03-17 19:01:14.315	warn	[DevID_1/holdingRegs] Block 10000-10010: {}
                        modbus.8 2026-03-17 19:01:14.315	error	Request timed out.
                        modbus.8 2026-03-17 19:01:14.314	warn	Error: undefined
                        modbus.8 2026-03-17 19:01:09.524	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
                        modbus.8 2026-03-17 19:01:09.524	error	Error response for FCx3: Illegal Data Address
                        modbus.8 2026-03-17 19:01:09.313	debug	[DevID_1/holdingRegs] Poll address 10000 - 11 registers
                        Wie kommt IOBroker auf die Idee, einen ganzen Registerblock 1000-10010 abzufragen?
                        Immerhin kann ich Register 10000 auf "1" setzen und das Gerät schaltet sich daraufhin ein! Ganz auf dem Holzweg sind wir also nicht.
                        • L luas
                          das hätte ich jetzt auch empfohlen.
                          was passiert denn mit signed?
                          gibt es keine Register mit negativen Werten?
                          • L luas
                            gibt es diese 11 Register?
                            Möglicherweise kann dein Gerät nicht mit nicht vergebenen Adressen umgehen.
                            Stell mal die Anzahl gleichzeitig abgerufener Register runter (oder direkt auf 1)
                            • L Offline
                              luas
                              schrieb am zuletzt editiert von luas
                              Genau, so steht es in der Antwort vom Support.
                              Eben nicht, der Support schrieb ja auch, dass das ungewöhnlich sei, aber so sei es nun mal.
                              Wo finde ich das? Die maximale Leseanforderungslänge?
                              • L luas
                                Wo finde ich das
                                siehe oben
                                • L Offline
                                  luas
                                  Es klappt, es klappt!
                                  Eine (vielleicht vorerst letzte) Frage: wenn ich richtig verstehe, sind die Register 11000, 11001, 11004 und 13000 binärkodiert.
                                  General_status=3 würde also bedeuten: binär 00000011, also "thermo_on" und "alarm". "thermo_on" ist plausibel, "alarm" nicht, dann müsste ja 11001 oder 11004 ungleich null sein.
                                  Unabhängig davon: was ist der eleganteste Weg, diese einzelnen Bits herauszuführen? Ich glaube, ich habe das an anderer Stelle per JavaScript gemacht...
                                  • L Offline
                                    luas
                                    Gut, dass ich noch mal gefragt habe. Der Support schreibt:
                                    "Bit 0 steht für Gerät ein/aus (0 = aus / 1 =ein). Das ist leider in unserer Tabelle nicht aufgeführt und kann schonmal Fragen aufwerfen."
                                    Dezimal "3" steht also für "Gerät eingeschaltet" und "Gerät heizt oder kühlt".
