  3. Entwicklung
  4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
    1.0k
lgtv
861 Beiträge 113 Kommentatoren 397.0k Aufrufe 69 Beobachtet
  • PlasmachefP Offline
    PlasmachefP Offline
    Plasmachef
    #89
    Hallo SchuetzeSchulz,
    und danke für die schnelle Antwort.
    "LiveTV" Modus ist klar … hab ihn aber extra nochmal aktiviert.
    Hier das gezogene Log:
    lgtv.0	2018-02-01 18:49:30.445	debug	Polling OnlineStatus
    lgtv.0	2018-02-01 18:49:30.432	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:49:30.403	debug	Polling channel
    lgtv.0	2018-02-01 18:48:30.409	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:48:30.405	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:48:30.404	debug	Polling Input
    lgtv.0	2018-02-01 18:48:30.403	debug	Polling OnlineStatus
    lgtv.0	2018-02-01 18:48:30.397	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:48:30.395	debug	Polling channel
    lgtv.0	2018-02-01 18:48:28.674	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:48:28.671	debug	Sending switch to channel 4 command to WebOS TV: 192.168.1.138
    lgtv.0	2018-02-01 18:48:11.773	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:48:11.771	debug	Switching to LiveTV on WebOS TV: 192.168.1.138
    lgtv.0	2018-02-01 18:48:11.771	debug	Sending launch command livetv to WebOS TV: 192.168.1.138
    lgtv.0	2018-02-01 18:47:30.407	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:47:30.400	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:47:30.397	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:47:30.396	debug	Polling Input
    lgtv.0	2018-02-01 18:47:30.393	debug	Polling OnlineStatus
    lgtv.0	2018-02-01 18:47:30.391	debug	Polling channel
    lgtv.0	2018-02-01 18:46:41.112	debug	Connecting to WebOS TV: ws://192.168.1.138:3000
    lgtv.0	2018-02-01 18:46:41.099	debug	Sending switch to channel 4 command to WebOS TV: 192.168.1.138
    lgtv.0	2018-02-01 18:46:30.378	info	Ready. Configured WebOS TV IP: 192.168.1.138
    lgtv.0	2018-02-01 18:46:30.370	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.lgtv, node: v6.12.3
    lgtv.0	2018-02-01 18:46:30.318	debug	statesDB connected
    lgtv.0	2018-02-01 18:46:30.244	debug	objectDB connected
    Danke für drüberschaun!
    Grüße und schönen Abend :-)
      SchuetzeSchulz
      #90
      Hmm, der Adapter macht was es soll und wirft keinen Fehler aus:
      Verstehe ich nicht. Bei mir geht es wie gesagt wunderbar.
      Können andere mit dem Adapter hier diese Funktion mal austesten???
      Könnte jetzt höchstens sein, dass Dein TV das - warum auch immer - nicht unterstützt???
        PlasmachefP Offline
        Plasmachef
        #91
        da ich leider von Technik bzw. Programmierung nicht viel Ahnung habe, kann ich nur versuchen dich mit Infos zu versorgen :-(
        Hier gibt es Infos zu dem verwendeten Protokoll:
        http://developer.lgappstv.com/TV_HELP/i … ations.htm
        Hier eine Java Lösung:
        http://book2s.com/java/src/package/com/ … rvice.html
        Und hier weitere Infos/Kommandos
        https://www.npmjs.com/package/lgtv2
        Vielleicht findest du ja bei Gelegenheit mal Zeit drüber zu schauen um die Abweichungen zu entdecken.
        An dieser Stelle schon mal herzlichen Dank dafür!
        Viele Grüße
        P.S.: mach dir aber bitte wegen mir keinen Stress …
          SchuetzeSchulz
          #92
          Grundlage meines Adapters ist <url url="https://www.npmjs.com/package/lgtv2">[](</s>https://www.npmjs.com/package/lgtv2<br/>
          [https://www.npmjs.com/package/lgtv2](</s>https://www.npmjs.com/package/lgtv2<br/>
          )</url>
          Demzufolge muss es eigentlich funktionieren. Bisher bist Du leider auch der Einzige wo es nicht funktioniert :(
          Hast Du sonst mal versucht, den Adapter zu deinstallieren und komplett neu zu installieren und einzurichten?
          AN ALLE ANDERE: Könnt Ihr bei Euch das Verhalten mal versuchen zu reproduzieren?
            PlasmachefP Offline
            Plasmachef
            #93
            so…
            Instanz gelöscht
            Adapter gelöscht
            Raspi rebootet
            Adapter über "Katze" installiert
            Instanz angelegt
            Instanz IP eingetragen
            TV eingeschaltet
            TV auf liveTV geschaltet
            Kanal 7 aktuell am laufen
            Objekt "channel" von Hand geändert (auf 4)
            TV unverändert
            Objekt "channel" aktualisiert sich (nach ein paar Sekunden) auf 7 zurück
            war leider nix :-(
              SchuetzeSchulz
              #94
              Hmm, dann habe ich leider keine Idee :(
              Müssen wir mal auf die anderen warten, ob bei denen das Problem auch auftritt.
              • R Offline
                rh1212
                #95
                @SchuetzeSchulz:
                Müssen wir mal auf die anderen warten, ob bei denen das Problem auch auftritt. `
                Hallo!
                danke für Deine Arbeit.
                Bei mir funktionier diese funktion auch nicht, also ich wenn die 3 schreibe, dann passiert nichts.
                Andere frage, ist das möglich andere Apps alleine hinzufügen die ich auf mein TV habe? oder funktioniert nur mit diese Apps?
                Danke!
                  SchuetzeSchulz
                  #96
                  Könnten die, bei denen das Umschalten des Kanals nicht funktioniert mir mal bitte das verwendete TV-Modell nennen?
                  • R Offline
                    rh1212
                    #97
                    @SchuetzeSchulz:
                    Könnten die, bei denen das Umschalten des Kanals nicht funktioniert mir mal bitte das verwendete TV-Modell nennen? `
                    LG 55LF652V
                      SchuetzeSchulz
                      #98
                      Und bitte mal die eingesetzte WebOS Version direkt aus dem Einstellungsmenü des Fernsehers.
                      Ich habe da so eine Vermutung…
                      • R Offline
                        rh1212
                        #99
                        @SchuetzeSchulz:
                        Ich habe da so eine Vermutung… `
                        2.2.0-15505 (beehive-biscayne)
                          SchuetzeSchulz
                          #100
                          Ist das wirklich die "WebOS Version"?
                          Falls ja, dann haben wir hier einen Unterschied zu meinem (und ein Update wird mir nicht angeboten):
                            SchuetzeSchulz
                            #101
                            Wie im Github bereits geschrieben scheint das ein WebOS 2.0 Probem zu sein?!
                            Bei meinem mit WebOS 1 geht das.
                            Leider finde ich auch keine Doku zu WebOS 2.0, sonst könnte ich mal nachschauen was sich an dem Befehl geändert hat.
                            Kann mir noch jemand die WebOS Version nennen, bei dem es nicht funktioniert um meine Vermutung evtl. zu bestätigen?
                              PlasmachefP Offline
                              Plasmachef
                              #102
                              danke, dass du am Ball bleibst mit meinem / unserem Problem.
                              Hier auch meine Info:
                              Grüße und schönes WE wünsche ich!
                                SchuetzeSchulz
                                #103
                                OK,
                                das bestätigt leider meine Theorie das es ein WebOS 2.0 Problem ist.
                                Leider kann ich mangels WebOS 2.0 Gerät nicht herausfinden, wie WebOS 2.0 angesteuert werden muss um den Kanal zu wechseln :(
                                Ich finde da dummerweise auch keinerlei Kommando in der WebOS 2.0 SDK Dokumentation.
                                • Jey CeeJ Offline
                                  Jey CeeJ Offline
                                  Jey Cee
                                  #104
                                  gibt es eine Möglichkeit heraus zu finden welche App geöffnet ist und ob dort etwas Wiedergegeben wird?
                                  Ich möchte bei Wiedergabe das Licht dimmen bzw. abschalten und bei Pause oder Ende einschalten. Leider hab ich bisher keine Möglichkeit gefunden zu ermitteln ob auf dem TV etwas Wiedergegeben wird.
                                  Jey Cee
                                  Persönlicher Support
                                  Spenden -> paypal.me/J3YC33
                                    SchuetzeSchulz
                                    #105
                                    Das wiedergegeben wird geht in Apps nicht abzufragen.
                                    Ich prüfe gerade eine Möglichkeit, abzufragen welche App gerade offen ist.
                                    Hierzu mal bitte den Adapter von der GitHub URL (https://github.com/SebastianSchultz/ioBroker.lgtv) neu installieren und das Log auf Debug stellen.
                                    Nun sollten solche EInträge im Abfrageintervall kommen:
                                    lgtv.0 	2018-02-19 18:19:43.300 	debug 	LG TV, CURRENT APP JSON: {}
                                    lgtv.0 	2018-02-19 18:19:43.300 	debug 	LG TV, CURRENT APP NO JSON: [object Object]
                                    Wird da irgendwo die aktuelle App angezeigt?
                                      SchuetzeSchulz
                                      #106
                                      ich hatte da leider noch ein paar Fehler im Code :(
                                      Ich möchte mich auch hier nochmal bei Euch für Eure Geduld bedanken und mich entschuldigen das es scheinbar nicht auf allen Modellen nicht so sauber läuft wie es sollte. Ich habe hier leider nur ein Modell zum Testen :)
                                      Wenn Ihr den Adapter von der GitHub URL neu installiert, findet Ihr jetzt mit aktiviertem Debug Log folgenden Eintrag im Log:
                                      Zusätzlich wird ab sofort auch ein neuer Datenpunkt mit der aktuellen App erstellt:
                                      Der Log-Eintrag sowie der Datenpunkt werden abhängig vom in der Adapter-Konfiguration eingestellten Poll-Intervall erstellt.
                                      ACHTUNG:
                                      Für das Kanalwechsel-Problem auf WebOS 2.0 Geräten habe ich einen weiteren Debug-Log-Eintrag hinzugefügt.
                                      Könntet Ihr den bitte mal testen?
                                      Wenn Ihr den Kanal mittels Datenpunkt "channel" wechselt und der Fernseher einen Fehler zurückgibt, müsste hoffentlich im Debug-Log ein neuer Eintrag a`la
                                      Error in switching to channel ...
                                      auftauchen. Dort sollte hoffentlich eine Fehlermeldung hinter stehen.
                                        PlasmachefP Offline
                                        Plasmachef
                                        #107
                                        du musst dich wirklich nicht entschuldigen!!!
                                        Wir sind froh, dass sich jemand um den LG-Adapter kümmert.
                                        Wenn ich Zuhause bin werde ich das mal testen und Feedback geben.
                                        Bis dann …
                                          PlasmachefP Offline
                                          Plasmachef
                                          #108
                                          habs installiert.
                                          Bekomme aber weder einen neuen Datenpunkt noch ist das Log bei debug wie angezeigt.
                                          Bei manueller Eingabe der URL das gleiche Ergebnis wie über die "Katze".
                                          wurde es wieder zurückgebaut?
                                          NACHTRAG:
                                          nach ca. einer Stunde und fast dem Wahnsinn nahe, habe ich die neue Version endlich aufgespielt bekommen.
                                          Melde mich heute Abend bzgl. Ergebnissen zum Kanalwechsel
