  4. Update / Upgrade-einen Adapter nicht automatisch updaten
    6.4k
37 Beiträge 4 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • R Rushmed
    Sehr gerne, auch hier wieder mit der Bitte um Rückmeldung falls Probleme sichtbar sind die diese Angelegenheit nicht betreffen.
    WLED hab' ich wieder down gegraded.
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Smartazamba
           Icon name: computer
              Kernel: Linux 6.12.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     22:53:31 up 4 days,  4:06,  2 users,  load average: 2.23, 2.28, 2.29
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-02-17 22:53:31 CET
               Universal time: Tue 2026-02-17 21:53:31 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.2G        5.3G        252M        137M        2.9G        2.9G
    Swap:           2.1G        544M        1.6G
    Total:           10G        5.9G        1.9G
    Active iob-Instances:   39
             7819 M total memory
             5095 M used memory
             3213 M active memory
             3812 M inactive memory
              240 M free memory
              129 M buffer memory
             2679 M swap cache
             2047 M total swap
              519 M used swap
             1528 M free swap
    top - 22:53:32 up 4 days,  4:06,  2 users,  load average: 2.23, 2.28, 2.29
    Tasks: 256 total,   1 running, 255 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 57.8 us,  6.7 sy,  0.0 ni, 35.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7819.7 total,    239.5 free,   5096.2 used,   2809.3 buff/cache
    MiB Swap:   2048.0 total,   1528.6 free,    519.4 used.   2723.5 avail Mem
    *** FAILED SERVICES ***
      UNIT              LOAD   ACTIVE SUB    DESCRIPTION
    * logrotate.service loaded failed failed Rotate log files
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    df: /media/HDD3@NAS: Host is down
    /dev/root      ext4      110G   25G   83G  23% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  195M  1.4G  13% /run
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     3.9G  6.8M  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/sda1      vfat      253M   49M  204M  20% /boot/firmware
    /dev/sdc       ext4      5.5T  2.8T  2.5T  53% /media/HDD2
    /dev/sdb1      ext4      4.6T  2.8T  1.6T  65% /media/HDD1
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
    tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
    [Fri Feb 13 18:46:55 2026] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
    [Fri Feb 13 18:46:55 2026] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Fri Feb 13 18:47:00 2026] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w.
    [Fri Feb 13 18:47:03 2026] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
    [Fri Feb 13 18:47:03 2026] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
    [Mon Feb 16 03:32:14 2026] EXT4-fs (loop0): recovery complete
    [Mon Feb 16 03:32:14 2026] EXT4-fs (loop0): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w with ordered data mode. Quota mode: none.
    [Mon Feb 16 03:32:14 2026] EXT4-fs (loop0): unmounting filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a.
    [Mon Feb 16 03:37:12 2026] EXT4-fs (loop0): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w with ordered data mode. Quota mode: none.
    [Mon Feb 16 03:37:19 2026] EXT4-fs (loop0): unmounting filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a.
    Show mounted filesystems:
    TARGET            SOURCE     FSTYPE OPTIONS
    /                 /dev/sda2  ext4   rw,noatime
    |-/boot/firmware  /dev/sda1  vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    |-/media/HDD2     /dev/sdc   ext4   rw,nosuid,nodev,noexec,relatime
    |-/media/HDD3@NAS //NAS/HDD3 cifs   rw,relatime,vers=3.1.1,cache=strict,upcall_target=app,username=pi,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.17,file_mode=0755,dir_mode=0755,soft,nounix,serverino,mapposix,reparse=nfs,rsize=4194304,wsize=4194304,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    `-/media/HDD1     /dev/sdb1  ext4   rw,nosuid,nodev,noexec,relatime
    /var:
    4.5G    /var/
    975M    /var/log
    786M    /var/cache
    770M    /var/cache/apt
    637M    /var/cache/apt/archives
    Archived and active journals take up 200.5M in the file system.
    /opt/iobroker/backups:
    1.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    449M    /opt/iobroker/iobroker-data/
    195M    /opt/iobroker/iobroker-data/backup-objects
    182M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    58M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-Rz8ETF2t.js
    12M     /opt/iobroker/iobroker-data/states.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    7.2M    /opt/iobroker/iobroker-data/backup-objects/2026-02-17_21-32_objects.jsonl.gz
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    ⚠ HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'.
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Smartazamba         Smartazamba (version: 7.1.0, hostname: Smartazamba   , alive, uptime: 156128)
    Core adapters versions
    js-controller:  7.1.0
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     2
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    +-- iobroker.proxmox@2.4.10 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.proxmox.git#0c1b29f61b4babc1bf767ae7c08699b7aef3aa22)
    Adapter State
    + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
      system.adapter.artnet.0                 : artnet                : Smartazamba                              - disabled, port: 6454
    + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
    + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
      system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
    + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
      system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
      system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
    + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
    + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
      system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
    + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
    + system.adapter.matter.0                 : matter                : Smartazamba                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
    + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
    + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
      system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
      system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
      system.adapter.proxmox.0                : proxmox               : Smartazamba                              - disabled, port: 8006
    + system.adapter.reolink.0                : reolink               : Smartazamba                              -  enabled
    + system.adapter.reolink.1                : reolink               : Smartazamba                              -  enabled
    + system.adapter.rest-api.0               : rest-api              : Smartazamba                              -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
    + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.unifi-network.0          : unifi-network         : Smartazamba                              - disabled, port: 8443
    + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
    + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wifilight.0              : wifilight             : Smartazamba                              -  enabled
    + system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              -  enabled, port: 5000
    + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Upgrade policy: minor
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.1.0
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "matter"       : 0.5.6    , installed 0.5.6
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.4.9    , installed 2.4.10
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "shuttercontrol": 2.0.11  , installed 2.0.11
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "unifi-network": 1.3.1    , installed 1.3.1
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.3    , installed 0.7.2  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        20229
    States:         19246
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian trixie InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Get:7 https://repos.influxdata.com/debian stable InRelease [6913 B]
    Fetched 6913 B in 0s (23.3 kB/s)
    Reading package lists...
    Pending systemupdates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7355       1027/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          7623       1463/smbd
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          7622       1463/smbd
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       12665413   3209133/iobroker.js
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       12664798   3209133/iobroker.js
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          9222       1280/exim4
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       12673221   3210539/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       12675287   3210477/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       12671408   3210208/io.mqtt.0
    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       22366242   1483654/nc
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          9223       1280/exim4
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        10774      1510/grafana
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        12665967   3209071/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1002       12673364   3211535/io.simple-a
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       12669156   3209217/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       12674564   3211560/io.web.0
    tcp6       0      0 :::8093                 :::*                    LISTEN      1002       12672595   3211584/io.rest-api
    tcp6       0      0 :::21                   :::*                    LISTEN      0          925        990/vsftpd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          7357       1027/sshd: /usr/sbi
    tcp6       0      0 :::139                  :::*                    LISTEN      0          7621       1463/smbd
    tcp6       0      0 :::445                  :::*                    LISTEN      0          7620       1463/smbd
    udp        0      0 0.0.0.0:33906           0.0.0.0:*                           108        6275       457/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       22241897   1452644/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       12674857   3211200/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       12675390   3211200/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       12675382   3211200/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        6273       457/avahi-daemon: r
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1002       12675399   3211200/io.matter.0
    udp        0      0 0.0.0.0:55327           0.0.0.0:*                           1002       12675554   3211200/io.matter.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6364       566/dhcpcd: [networ
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          8869       1403/nmbd
    udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          8868       1403/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          8850       1403/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          8871       1403/nmbd
    udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          8870       1403/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          8851       1403/nmbd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       12673143   3210161/io.mihome-v
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       12672237   3210201/io.mihome-v
    udp6       0      0 :::546                  :::*                                0          6366       566/dhcpcd: [networ
    udp6       0      0 :::58340                :::*                                108        6276       457/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                1002       12674858   3211200/io.matter.0
    udp6       0      0 :::5353                 :::*                                1002       12675393   3211200/io.matter.0
    udp6       0      0 :::5353                 :::*                                1002       12675385   3211200/io.matter.0
    udp6       0      0 :::5353                 :::*                                108        6274       457/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1002       12675398   3211200/io.matter.0
    udp6       0      0 :::55327                :::*                                1002       12673925   3211200/io.matter.0
    2026-02-17 22:40:39.838  - info: weatherunderground.0 (1468568) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.22.0, js-controller: 7.1.0
    2026-02-17 22:40:45.183  - info: weatherunderground.0 (1468568) Terminated (NO_ERROR): Without reason
    2026-02-17 22:40:45.728  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1468568 terminated with code 0 (NO_ERROR)
    2026-02-17 22:42:58.130  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Treppenhaus Brightness von 1 auf 20 geändert. Quelle=javascript.0 Lampe_Treppenhaus_switch_State=unverändert
    2026-02-17 22:43:01.929  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Treppenhaus Brightness von 20 auf 20 geändert. Quelle=javascript.0 Lampe_Treppenhaus_switch_State=unverändert
    2026-02-17 22:43:41.980  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Arbeitsplatte Brightness von 0 auf 50 geändert. Quelle=javascript.0 Lampe_Arbeitsplatte_switch_State=true
    2026-02-17 22:44:51.922  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Treppenhaus Brightness von 20 auf 1 geändert. Quelle=javascript.0 Lampe_Treppenhaus_switch_State=unverändert
    2026-02-17 22:45:15.197  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Treppenhaus Brightness von 1 auf 20 geändert. Quelle=javascript.0 Lampe_Treppenhaus_switch_State=unverändert
    2026-02-17 22:45:23.153  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Treppenhaus Brightness von 20 auf 20 geändert. Quelle=javascript.0 Lampe_Treppenhaus_switch_State=unverändert
    2026-02-17 22:45:32.596  - info: javascript.0 (3209484) script.js.PC_und_Opple: PC-Zimmer Monitor aktiviert wegen BWM
    2026-02-17 22:45:33.050  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 1473617
    2026-02-17 22:45:39.239  - info: weatherunderground.0 (1473617) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.22.0, js-controller: 7.1.0
    2026-02-17 22:45:47.325  - info: weatherunderground.0 (1473617) Terminated (NO_ERROR): Without reason
    2026-02-17 22:45:47.874  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1473617 terminated with code 0 (NO_ERROR)
    2026-02-17 22:46:26.499  - info: admin.0 (3209217) ==> Connected system.user.admin from ::ffff:192.168.178.38
    2026-02-17 22:47:13.076  - info: javascript.0 (3209484) script.js.Lampen_Displays._Switch_Status_Synch_: Lampe Treppenhaus Brightness von 20 auf 1 geändert. Quelle=javascript.0 Lampe_Treppenhaus_switch_State=unverändert
    2026-02-17 22:50:33.066  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 1478459
    2026-02-17 22:50:40.339  - info: weatherunderground.0 (1478459) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.22.0, js-controller: 7.1.0
    2026-02-17 22:50:46.389  - info: weatherunderground.0 (1478459) Terminated (NO_ERROR): Without reason
    2026-02-17 22:50:46.936  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1478459 terminated with code 0 (NO_ERROR)
    2026-02-17 22:51:23.530  - info: admin.0 (3209217) <== Disconnect system.user.admin from ::ffff:192.168.178.38 admin
    2026-02-17 22:51:58.513  - info: shelly.0 (3210477) [MQTT] Device with client id "shellyem3-485519D6FEC7" connected from 192.168.178.167!
    2026-02-17 22:52:00.599  - info: sourceanalytix.0 (3211521) Updating SourceAnalytix configuration for : shelly.0.SHEM-3#485519D6FEC7#1.Total.ConsumedPower
    2026-02-17 22:52:01.674  - info: shelly.0 (3210477) [MQTT] Device with client id "shellyem3-485519D6FEC7" initialized.
    2026-02-17 22:52:02.048  - info: sourceanalytix.0 (3211521) Updating SourceAnalytix configuration for : shelly.0.SHEM-3#485519D6FEC7#1.Total.ConsumedPower
    @Rushmed
    Leg dir künftig einen user an, der nicht 'pi' heißt.
    Was ist denn mit dem logrotate los?
    • logrotate.service loaded failed failed Rotate log files
    Und das wollte ich sehen:
    Du hast da die Auto-Updates aktiv.
    Würde ich grundsätzlich nicht machen. Du gibst die Kontrolle darüber, was da wann auf dem System aktualisiert wird aus der Hand.
    Allerdings würde ich dann auch erwarten, das eigene Einstellungen dazu auf Ebene des Adapters auch zuerst ziehen. Oder das ist anders gedacht und bei global ausgestelltem Autoupdate kann man dann einzelne Adapter dennoch automatisch updaten lassen.
    Hau die 4 OS-Updates drauf.
    R 2 Antworten Letzte Antwort
      @Rushmed
      Rushmed
      @Thomas-Braun sagte in Update / Upgrade-einen Adapter nicht automatisch updaten:
      Wie geht das?
      • R Rushmed
        Wie geht das?
        @Rushmed sagte in Update / Upgrade-einen Adapter nicht automatisch updaten:
        Wie geht das?
        Mit
        sudo apt update && sudo apt full-upgrade
        Je nachdem ist dann ein Neustart (mindestens des entsprechenden Services) notwendig.
        • R Offline
          Rushmed
          erledigt
          • R Rushmed
            Da ist mein Problem wieder.
            Jetzt gibt es ein Problem mit dem WLED Adapter 0.7.3.
            https://forum.iobroker.net/topic/83910/gel%C3%B6st-wled-warnungen-nach-update-auf-0.7.3/5?_=1771363092492
            Trotzdem werde ich nach einem Downgrade auf 0.7.2 wieder automatisch hoch gezogen.
            mcm1957M Online
            mcm1957M Online
            mcm1957
            Was meinst du damit?
            WIE hast du downgegradet?
            Hast du irgendeinen Updatebefehl selbst abgesetzt? Also in der UI auf "alle Updaten" geklickt? Oder irgendwelche Befehle auf der Commandline abgesetzt? Wenn ja welche?
            An sich gibt es bei deiner Einstellung für diesen Adapetr KEIN automatisches Update außer du löst es im UI oder auf der Coammandline aus.
            EDIT:
            Da die Frage oben auftrat: Die ADAPTER-Einstellung gewinnt gegenüber der Repository Einstellung:
            https://github.com/DrozmotiX/ioBroker.wled/issues/786#issuecomment-3910467451
            Wenn also bei wled none steht sollte dieser Adapter nicht aktualisisert werden.
            Hast du eine Notification über das Update erhalten?
            Wenn nicht deutet es darauf hin, dass da gar kein automatisches Update stattgefunden hat sondern du z.B.
            'iob upgrade' eingetipselt hast. Das aktualisisert wie beschrieben ALLE Adapter. Analog gibts dazu einen Button im Admin UI - wenn du den akklickst werden auch ALLE Adapter aktualisisiert.
            Was WLED betrifft - da gibts ne neue Release im Beta Test / Latest Repo.
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • R Offline
              Rushmed
              Ich habe per GUI downgegraded.
              • mcm1957M mcm1957
                EDIT:
                @mcm1957 sagte in Update / Upgrade-einen Adapter nicht automatisch updaten:
                Vermutlich nicht. Ich gehe davon aus, das die globale Einstellung für das stable-Repo zuerst zieht.
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  Lt. Dokumentation NEIN.
                  Explizit getestet hab ichs jetzt nicht. Kann ggF ein Bug sein.
                  • mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    @rushmed
                    Stell mal die automatischen Updates für das REPO auf aus.
                    Irgendwas könnte da faul sein, weil lt. Doku gibts ein Fallback auf die Repoeinstellung wenn beim Adapter nichts eingestellt ist. Nur kann man beim Adapter nicht "nichts" einstellen. An sich sollte es da "kein Updaten" und "use Default" geben - oder so was. Muss ich mal checken (oder checken lassen).
                      @Rushmed
                      Rushmed
                      Wie kann ich dem nachgehen?
                      Unter Hosts habe ich inzwischen dashier gefunden:
                      Mal sehen ob das Update heute wieder passiert.
                      • mcm1957M Online
                        mcm1957M Online
                        mcm1957
                        Wie schon geschrieben:
                        Schalte das automatische Aktualisiseren ggF in den Repositoryeinstellungen aus.
                        • R Rushmed
                          systemctl status logrotate.service
                          anschauen.
                          • R Offline
                            Rushmed
                            Ich habe eine neue Vermutung.
                            Wenn ich diesen Dialog mit ""Bestätigen und Schließen" quittiere wird das automatische Update ausgeführt.
                            Gestern habe ich den nicht bestätigt und das automatische Update blieb aus.
                            Heute hab' ich bestatigt und es wurde wieder aktualisiert.
                            Die Aktualisierung erfolgt dabei immer gegen 19:50 Uhr.
                            Zm Thema logrotate:
                            pi@Smartazamba:~ $ systemctl status logrotate.service
                            × logrotate.service - Rotate log files
                                 Loaded: loaded (/usr/lib/systemd/system/logrotate.service; static)
                                 Active: failed (Result: exit-code) since Thu 2026-02-19 00:04:47 CET; 19h ago
                             Invocation: bd4e4ea76e674357a496e798384a85c5
                            TriggeredBy: ● logrotate.timer
                                   Docs: man:logrotate(8)
                                         man:logrotate.conf(5)
                                Process: 2943945 ExecStart=/usr/sbin/logrotate /etc/logrotate.conf (code=exited, status=1/FAILURE)
                               Main PID: 2943945 (code=exited, status=1/FAILURE)
                                    CPU: 82ms
                            Feb 19 00:04:47 Smartazamba systemd[1]: Starting logrotate.service - Rotate log files...
                            Feb 19 00:04:47 Smartazamba logrotate[2943945]: warning: Potentially dangerous mode on influxdb: 0664
                            Feb 19 00:04:47 Smartazamba logrotate[2943945]: error: Ignoring influxdb because it is writable by group or others.
                            Feb 19 00:04:47 Smartazamba logrotate[2943945]: error: found error in file influxdb, skipping
                            Feb 19 00:04:47 Smartazamba systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
                            Feb 19 00:04:47 Smartazamba systemd[1]: logrotate.service: Failed with result 'exit-code'.
                            Feb 19 00:04:47 Smartazamba systemd[1]: Failed to start logrotate.service - Rotate log files.
                            • R Rushmed
                              Zm Thema logrotate:
                                      CPU: 82ms
                              @Rushmed
                              Da sind offenbar falsche Rechte auf der influxdb gesetzt.
                              Hast du denn nun das globale Auto-Update aus?
                              • R Offline
                                Rushmed
                                Das globale Autoupdate ist an.
                                Wo kann ich die korrekten Rechte für influxdb finden und muss ich die für /etc/influxdb setzen?
                                • R Rushmed
                                  Das solltest du doch aus schalten.
                                  Zu influx und wie da die Userverwaltung funktioniert und welche Rechte da im einzelnen die richtigen sind kann ich dir nichts sagen, ich verwende das nicht.
                                  R 1 Antwort Letzte Antwort
                                    Rushmed
                                    MIr ist schon klar wie ich alle Autoupdates verhindern kann aber ich versuche hier beim Debuggen eines möglichen Fehlers zu helfen.
                                    • R Rushmed
                                      @Rushmed
                                      Dann schau in die Logs.
                                      • R Offline
                                        Rushmed
                                        Bzgl. logrotate.
                                        Ich hab die Bude mal neu gestertet und jetzt läuft der Service.
                                        Danke für deine DIAG Prügung!
