  4. Alexa Shopping List mit Bring synchronisieren
187 Beiträge 32 Kommentatoren 60.6k Aufrufe 31 Beobachtet
  • E elron
    @MartyBr sagte in Alexa Shopping List mit Bring synchronisieren:
    @elron
    Kannst du bitte auf das originale Script verlinken? Ich finde es hier leider nicht.
    Danke für die Anpassung.
    Hi Martin,
    hier bzw. auch im Threadverlauf.
    MartyBr
    #171
    @elron
    Der Link funktioniert leider nicht (zumindest bei mir). Ich habe das Script von @sil4s genommen.
    Vielen Dank
    Martin
    Homematic und Homematic IP
    E 1 Antwort Letzte Antwort
    • M MartyBr
      @elron
      Vielen Dank
      elron
      #172
      @elron
      Vielen Dank
      Okay, komisch, hier nochmal der gesamte Code inkl. der aktuellen Änderung:
       * GENERIC INFO:
       *      Created by Daniel Drießen @ DDProductions
       *      Date of creation:   17.07.2024
       *      Version:            0.1.0.0
       * DESCRIPTION:
       *      This script synchronizes the shopping lists of 'Alexa' and 'Bring'.
       *      It monitors changes in both shopping lists and ensures that they stay updated with each other.
       *      The script uses events to detect changes in the shopping lists of both 'Alexa' and 'Bring'.
       *      When changes are detected, it initiates a synchronization to reconcile any discrepancies between the lists.
       *      The synchronization process involves comparing the items on both lists and updating each list to reflect the combined items from both sources.
       * DEPENDENCIES:
       *      - Alexa2 adapter
       *      - Bring adapter
       * LIMITATIONS:
       *      Due to the nature of the 'Bring' adapter (which does not store an 'added' or 'updated' timestamp for items on the shopping list), a 'real' synchronization is not possible
       *      because there is no way to detect the order of changes to the shopping lists of 'Alexa' and 'Bring'.
       * TODO & FUTURE GOALS:
       *      - Add better error handling.
       *      - Move functions 'getItemsOnAlexaShoppingList' & 'getItemsOnBringShoppingList' into classes 'AlexaShoppingList' & 'BringShoppingList'.
       *      - Move functions 'addItemToShoppingList', 'removeItemFromShoppingList' into classes 'AlexaShoppingList' & 'BringShoppingList'.
       *      - Enhance the synchronization logic to minimize potential syncing errors and improve reliability given the above limitations.
       *      - Maybe add a sync schedule for periodic syncing.
       * CHANGELOG:
       *      18.07.2024 - Initial version completed.
      export default this;
      +        SCRIPT SETUP        +
      /*---------- OBJECT-ID CONSTANTS ------------------------------------------------------------------------------------------------*/
      const objectID_alexa_shoppingList_folder = 'alexa2.0.Lists.SHOP';
      const objectID_alexa_shoppingList_addItem = 'alexa2.0.Lists.SHOP.#New';
      const objectID_bring_shoppingList_sentenceString = 'bring.0.xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx.enumSentence';
      const objectID_bring_shoppingList_addItem = 'bring.0.xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx.saveItem';
      const objectID_bring_shoppingList_removeItem = 'bring.0.xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx.removeItem';
      +                                                               START OF SCRIPT LOGIC        +
      var initComplete = false;
      var syncingInProgress = false;
      var resyncRequests = [];
      startScriptLogic();
      async function startScriptLogic() {
          try {
              await init();
              initComplete = true;
          } catch (error) {
              console.error(error.message);
              console.debug(`SCRIPT WILL TERMINATE NOW!`);
              await this.stopScriptAsync();
      /*---------- INIT ---------------------------------------------------------------------------------------------------------------*/
      async function init(): Promise <void> {
          console.info(`Script initialization...`);
          await synchronizeShoppingLists('init', false);
          console.info(`Script initialization completed successfully!`);
          await checkForResyncRequests();
      /*---------- TRIGGER ------------------------------------------------------------------------------------------------------------*/
      // Alexa
      on({ id: [].concat([objectID_alexa_shoppingList_folder + '.json']), change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        let oldValue = obj.oldState.val;
        console.debug(`'Alexa' shopping list changed!`);
        if (initComplete && !syncingInProgress) {
            await synchronizeShoppingLists('alexa', false);
        } else {
            resyncRequests.push('alexa');
      // Bring
      on({ id: [].concat([objectID_bring_shoppingList_sentenceString]), change: 'ne' }, async (obj) => {
        console.debug(`'Bring' shopping list changed!`);
            await synchronizeShoppingLists('bring', false);
        } else {
            resyncRequests.push('bring');
      /*---------- SYNC ---------------------------------------------------------------------------------------------------------------*/
      async function synchronizeShoppingLists(syncInitiator:string, isResync:boolean) {
          console.info(`Sync started`);
          console.debug(`Sync initiator: '${capitalizeFirstLetter(syncInitiator)}'`);
          console.debug(`Sync is a resync: '${isResync}'`);
          syncingInProgress = true;
          var itemsOnAlexaShoppingList = await getItemsOnAlexaShoppingList();
          var itemsOnBringShoppingList = await getItemsOnBringShoppingList();
          console.debug(`Items on "Alexa" shopping list (${itemsOnAlexaShoppingList.length}): ${itemsOnAlexaShoppingList.map(item => item.value)}`);
          console.debug(`Items on "Bring" shopping list (${itemsOnBringShoppingList.length}): ${itemsOnBringShoppingList.map(item => item.value)}`);
          if (syncInitiator.toLowerCase() === 'init') {
              // If sync initiator is "init"
              // create a combined item list and add each item missing on each list to each list.
              // Create combined shopping list
              var itemsOnCombinedShoppingList = [];
              for (const itemOnAlexaShoppingList of itemsOnAlexaShoppingList) {
                  if (!await ShoppingListUtils.checkIfShoppingListArrayContainsShoppingListItem(itemsOnCombinedShoppingList, itemOnAlexaShoppingList)) {
                      itemsOnCombinedShoppingList.push(itemOnAlexaShoppingList);
              for (const itemOnBringShoppingList of itemsOnBringShoppingList) {
                  if (!await ShoppingListUtils.checkIfShoppingListArrayContainsShoppingListItem(itemsOnCombinedShoppingList, itemOnBringShoppingList)) {
                      itemsOnCombinedShoppingList.push(itemOnBringShoppingList);
              //console.debug(`Items on "Combined" shopping list: ${itemsOnCombinedShoppingList.map(item => item.value)}`);
              // Add each missing item on each list to each list
              var itemsToAddToAlexaShoppingList = [];
              var itemsToAddToBringShoppingList = [];
              for (const itemOnCombinedShoppingList of itemsOnCombinedShoppingList) {
                  if (!await ShoppingListUtils.checkIfShoppingListArrayContainsShoppingListItem(itemsOnAlexaShoppingList, itemOnCombinedShoppingList)) {
                      itemsToAddToAlexaShoppingList.push(itemOnCombinedShoppingList);
                  if (!await ShoppingListUtils.checkIfShoppingListArrayContainsShoppingListItem(itemsOnBringShoppingList, itemOnCombinedShoppingList)) {
                      itemsToAddToBringShoppingList.push(itemOnCombinedShoppingList);
              if (itemsToAddToAlexaShoppingList.length > 0) {
                  console.debug(`Items to add to "Alexa" shopping list (${itemsToAddToAlexaShoppingList.length}): ${itemsToAddToAlexaShoppingList.map(item => item.value)}`);
              if (itemsToAddToBringShoppingList.length > 0) {
                  console.debug(`Items to add to "Bring" shopping list (${itemsToAddToBringShoppingList.length}): ${itemsToAddToBringShoppingList.map(item => item.value)}`);
              for (const itemToAddToAlexaShoppingList of itemsToAddToAlexaShoppingList) {
                  await AlexaShoppingListItem.addItemToShoppingList(itemToAddToAlexaShoppingList);
              for (const itemToAddToBringShoppingList of itemsToAddToBringShoppingList) {
                  await BringShoppingListItem.addItemToShoppingList(itemToAddToBringShoppingList);
          } else if (syncInitiator.toLowerCase() === 'alexa') {
              // If sync initiator is "alexa"
              // add each item from the alexa shopping list that is missing on the bring shopping list to the bring shopping list.
              // Then remove each item from the bring shopping list that is not on the alexa shopping list.
              // Add each item from the alexa shopping list that is missing on the bring shopping list to the bring shopping list.
                  if (!await ShoppingListUtils.checkIfShoppingListArrayContainsShoppingListItem(itemsOnBringShoppingList, itemOnAlexaShoppingList)) {
                      itemsToAddToBringShoppingList.push(itemOnAlexaShoppingList);
              // Get an update of the bring shopping list
              // Remove each item from the bring shopping list that is not on the alexa shopping list.
              var itemsToRemoveFromBringShoppingList = [];
                  if (!await ShoppingListUtils.checkIfShoppingListArrayContainsShoppingListItem(itemsOnAlexaShoppingList, itemOnBringShoppingList)) {
                      itemsToRemoveFromBringShoppingList.push(itemOnBringShoppingList);
              if (itemsToRemoveFromBringShoppingList.length > 0) {
                  console.debug(`Items to remove from "Bring" shopping list (${itemsToRemoveFromBringShoppingList.length}): ${itemsToRemoveFromBringShoppingList.map(item => item.value)}`);
              for (const itemToRemoveFromBringShoppingList of itemsToRemoveFromBringShoppingList) {
                  await BringShoppingListItem.removeItemFromShoppingList(itemToRemoveFromBringShoppingList);
          } else if (syncInitiator.toLowerCase() === 'bring') {
              // If sync initiator is "bring"
              // add each item from the bring shopping list that is missing on the alexa shopping list to the alexa shopping list.
              // Then remove each item from the alexa shopping list that is not on the bring shopping list.
              // Add each item from the bring shopping list that is missing on the alexa shopping list to the alexa shopping list.
                      itemsToAddToAlexaShoppingList.push(itemOnBringShoppingList);
              // Get an update of the alexa shopping list
              // Remove each item from the alexa shopping list that is not on the bring shopping list.
              var itemsToRemoveFromAlexaShoppingList = [];
                      itemsToRemoveFromAlexaShoppingList.push(itemOnAlexaShoppingList);
              if (itemsToRemoveFromAlexaShoppingList.length > 0) {
                  console.debug(`Items to remove from "Alexa" shopping list (${itemsToRemoveFromAlexaShoppingList.length}): ${itemsToRemoveFromAlexaShoppingList.map(item => item.value)}`);
              for (const itemToRemoveFromAlexaShoppingList of itemsToRemoveFromAlexaShoppingList) {
                  await AlexaShoppingListItem.removeItemFromShoppingList(itemToRemoveFromAlexaShoppingList);
          console.info(`Sync completed!`);
      async function checkForResyncRequests() {
          if (resyncRequests.length > 0) {
              // Get the first resync request.
              var firstResyncRequest = resyncRequests[0];
              // Remove the first resync request from the array.
              resyncRequests.shift();
              // Remove all values from the array that match the firstResyncRequest value
              resyncRequests = resyncRequests.filter(request => request !== firstResyncRequest);
              // Perform resync
              await synchronizeShoppingLists(firstResyncRequest, true);
      /*---------- GET SHOPPING LIST ITEMS --------------------------------------------------------------------------------------------*/
      // Alexa
      async function getItemsOnAlexaShoppingList(): Promise <Array<AlexaShoppingListItem>> {
          var alexaShoppingListItems = [];
          var completedAlexaShoppingListItemsToRemove = [];
          var jsonShoppingListString = await getStateAsync(objectID_alexa_shoppingList_folder + '.json');
          var jsonShoppingList = JSON.parse(jsonShoppingListString.val);
          jsonShoppingList.forEach((item, index) => {
              var item_id = item.id;
              var item_listID = item.listId;
              var item_customerID = item.customerId;
              var item_shoppingListItem = item.shoppingListItem;
              var item_value = item.value;
              var item_completed = item.completed;
              var item_version = item.version;
              var item_createdDateTime = item.createdDateTime;
              var item_updatedDateTime = item.updatedDateTime;
              var item_idOfFolderObject = objectID_alexa_shoppingList_folder + '.items.' + item.id;
              var item_idOfDeleteDatapoint = objectID_alexa_shoppingList_folder + '.items.' + item.id + '.#delete';
              console.debug(`item_id: ${item_id}`);
              console.debug(`item_listID: ${item_listID}`);
              console.debug(`item_customerID: ${item_customerID}`);
              console.debug(`item_shoppingListItem: ${item_shoppingListItem}`);
              console.debug(`item_value: ${item_value}`);
              console.debug(`item_completed: ${item_completed}`);
              console.debug(`item_version: ${item_version}`);
              console.debug(`item_createdDateTime: ${item_createdDateTime}`);
              console.debug(`item_updatedDateTime: ${item_updatedDateTime}`);
              console.debug(`item_idOfFolderObject: ${item_idOfFolderObject}`);
              console.debug(`item_idOfDeleteDatapoint: ${item_idOfDeleteDatapoint}`);
              try {
                  const newAlexaShoppingListItem = new AlexaShoppingListItem(
                      item_id,
                      item_listID,
                      item_customerID,
                      item_shoppingListItem,
                      item_value,
                      item_completed,
                      item_version,
                      item_createdDateTime,
                      item_updatedDateTime,
                      item_idOfFolderObject,
                      item_idOfDeleteDatapoint);
                      if (!newAlexaShoppingListItem.completed) {
                          alexaShoppingListItems.push(newAlexaShoppingListItem);
                      } else {
                          completedAlexaShoppingListItemsToRemove.push(newAlexaShoppingListItem);
                  } catch (error) {
                      console.error(`Error while creating Alexa Shopping-List Item Object! -  Original Error: ${error.message}`);
          if (completedAlexaShoppingListItemsToRemove.length > 0) {
              for (const completedAlexaShoppingListItemToRemove of completedAlexaShoppingListItemsToRemove) {
                  await AlexaShoppingListItem.removeItemFromShoppingList(completedAlexaShoppingListItemToRemove);
          // Sort the array of alexa shopping list items (case insensitive sorting)
          alexaShoppingListItems.sort((a, b) => a.value.toLowerCase().localeCompare(b.value.toLowerCase()));
          return alexaShoppingListItems;
      // Bring
      async function getItemsOnBringShoppingList(): Promise <Array<BringShoppingListItem>> {
          var bringShoppingListItems = [];
          try {
              var humanReadableShoppingListObject = await getStateAsync(objectID_bring_shoppingList_sentenceString);
              var humanReadableShoppingList = humanReadableShoppingListObject.val;
              if (humanReadableShoppingList !== null && humanReadableShoppingList !== '' && humanReadableShoppingList.length > 0) {
                  humanReadableShoppingList = replaceAllOccurrencesOfASubstringWithinAString(humanReadableShoppingList, ' und ', ', ');
                  humanReadableShoppingList = replaceAllOccurrencesOfASubstringWithinAString(humanReadableShoppingList, ', ', ';');
                  const bringShoppingListItemStrings = splitStringIntoArray(humanReadableShoppingList, ';');
                  for (const bringShoppingListItemString of bringShoppingListItemStrings) {
                      try {
                          const newBringShoppingListItem = new BringShoppingListItem(bringShoppingListItemString);
                          bringShoppingListItems.push(newBringShoppingListItem);
                      } catch (error) {
                          continue;
          } catch (error) {
              console.error(`Error while getting Bring Shopping-List Items! - Original Error: ${error.message}`);
          bringShoppingListItems.sort((a, b) => a.value.toLowerCase().localeCompare(b.value.toLowerCase()));
          return bringShoppingListItems;
      +        CLASSES        +
      class AlexaShoppingListItem {
          public id: string;
          public listID: string;
          public customerID: string;
          public shoppingListItem: boolean;
          public value: string;
          public completed: boolean;
          public version: number;
          public createdDateTime: number;
          public updatedDateTime: number;
          public idOfFolderObject: string;
          public idOfDeleteDatapoint: string;
          constructor(
              listID:string,
              customerID:string,
              shoppingListItem:boolean,
              value:string,
              completed:boolean,
              version:number,
              createdDateTime:number,
              updatedDateTime:number,
              idOfFolderObject:string,
              idOfDeleteDatapoint:string) {
                  this.id = id;
                  this.listID = listID;
                  this.customerID = customerID;
                  this.shoppingListItem = shoppingListItem;
                  this.value = value;
                  this.completed = completed;
                  this.version = version;
                  this.createdDateTime = createdDateTime;
                  this.updatedDateTime = updatedDateTime;
                  this.idOfFolderObject = idOfFolderObject;
                  this.idOfDeleteDatapoint = idOfDeleteDatapoint;
           * Adds an item to the Alexa shopping list.
           * @param item - The item to save to the Alexa shopping list. Must be either an instance of 'AlexaShoppingListItem' or 'BringShoppingListItem'.
           * @return Promise<boolean> - True if the function completed running its code.
          static async addItemToShoppingList(item:AlexaShoppingListItem | BringShoppingListItem): Promise <boolean> {
              // Parameter validation
              if (!(item instanceof AlexaShoppingListItem || item instanceof BringShoppingListItem)) {
                  throw new Error("Invalid parameter: Parameter 'item' must be an instance of 'AlexaShoppingListItem' or 'BringShoppingListItem'!");
              await setStateAsync(objectID_alexa_shoppingList_addItem, capitalizeFirstLetter(item.value), false);
              return true;
           * Removes an item from the Alexa shopping list.
           * @param item - The item to remove from the Alexa shopping list. Must be an instance of 'AlexaShoppingListItem'.
           static async removeItemFromShoppingList(item:AlexaShoppingListItem): Promise <boolean> {
              if (!(item instanceof AlexaShoppingListItem)) {
                  throw new Error("Invalid parameter: Parameter 'item' must be an instance of 'AlexaShoppingListItem'!");
              await setStateAsync(item.idOfDeleteDatapoint, true, false);
              return true;
      class BringShoppingListItem {
          constructor(value:string) {
              this.value = value;
           * Adds an item to the Bring shopping list.
           * @param item - The item to save to the Bring shopping list. Must be either an instance of 'AlexaShoppingListItem' or 'BringShoppingListItem'.
              await setStateAsync(objectID_bring_shoppingList_addItem, capitalizeFirstLetter(item.value), false);
              return true;
           * Removes an item from the Bring shopping list.
           * @param item - The item to remove from the Bring shopping list. Must be an instance of 'BringShoppingListItem'.
           static async removeItemFromShoppingList(item:BringShoppingListItem): Promise <boolean> {
              if (!(item instanceof BringShoppingListItem)) {
                  throw new Error("Invalid parameter: Parameter 'item' must be an instance of 'BringShoppingListItem'!");
              await setStateAsync(objectID_bring_shoppingList_removeItem, item.value, false);
              return true;
      class ShoppingListUtils {
           * Checks if a given shopping list array contains a specific shopping list item.
           * Herefore it compares all items in the given shopping list array with the given shopping list item
           * (either an 'AlexaShoppingListItem' or a 'BringShoppingListItem')
           * in a case-insensitive way.
           * @param shoppingListArray - Array of AlexaShoppingListItem or BringShoppingListItem objects to check within.
           * @param shoppingListItem - The shopping list item to find in the array.
           * @returns Promise<boolean> - True if the item is found, otherwise false.
          static async checkIfShoppingListArrayContainsShoppingListItem(shoppingListArray: Array<AlexaShoppingListItem | BringShoppingListItem>, shoppingListItem: AlexaShoppingListItem | BringShoppingListItem): Promise <boolean> {
              if (!Array.isArray(shoppingListArray)) {
                  throw new Error("Invalid parameter: 'shoppingListArray' must be an array.");
              if (!(shoppingListItem instanceof AlexaShoppingListItem || shoppingListItem instanceof BringShoppingListItem)) {
                  throw new Error("Invalid parameter: 'shoppingListItem' must be an instance of 'AlexaShoppingListItem' or 'BringShoppingListItem'.");
              for (const item of shoppingListArray) {
                      throw new Error("Invalid parameter: All elements in 'shoppingListArray' must be instances of 'AlexaShoppingListItem' or 'BringShoppingListItem'.");
              // Normalize the value of the shopping list item to lower case for case-insensitive comparison
              const itemValueToCheck = shoppingListItem.value.toLowerCase();
              // Check if any item in the array matches the shopping list item value
                  if (item.value.toLowerCase() === itemValueToCheck) {
                      return true;
              return false;
      /*---------- HELPER FUNCTIONS ---------------------------------------------------------------------------------------------------*/
      function capitalizeFirstLetter(input: string): string {
          if (input.length === 0) {
              return input; // Return the empty string if input is empty
          return input.charAt(0).toUpperCase() + input.slice(1);
      function replaceAllOccurrencesOfASubstringWithinAString(originalString: string, searchValue: string, replaceValue: string): string {
          const regex = new RegExp(searchValue, 'g');
          return originalString.replace(regex, replaceValue);
      function splitStringIntoArray(input: string, delimiter: string): string[] {
          return input.split(delimiter);
      • E elron
        @elron
        Vielen Dank
         * GENERIC INFO:
         *      Version:            0.1.0.0
         * DESCRIPTION:
         * DEPENDENCIES:
         *      - Alexa2 adapter
         *      - Bring adapter
         * LIMITATIONS:
         * CHANGELOG:
        +        SCRIPT SETUP        +
        startScriptLogic();
            try {
                await init();
            } catch (error) {
        // Alexa
          } else {
        // Bring
          } else {
                // Perform resync
        // Alexa
                try {
                        item_id,
                        item_listID,
                        item_customerID,
                        item_value,
                        item_completed,
                        item_version,
                        } else {
                    } catch (error) {
        // Bring
            try {
                        try {
                        } catch (error) {
                            continue;
            } catch (error) {
        +        CLASSES        +
            public id: string;
            constructor(
                listID:string,
                customerID:string,
                value:string,
                completed:boolean,
                version:number,
                    this.id = id;
                    this.value = value;
                return true;
                return true;
                this.value = value;
                return true;
                return true;
                        return true;
                return false;
        MartyBr
        #173
        @elron
        Viele Dank. Ich habe es importiert und die Datenpunkte angepasst. Test erfolgt morgen.
        Martin
        • mcBirneM Offline
          mcBirneM Offline
          mcBirne
          schrieb am zuletzt editiert von mcBirne
          #174
          Ich habe die beiden Datenpunkte angepasst. Leider erhalte ich folgende Fehlermeldung:
          javascript.0	16:24:56.439	error
          compile failed at: script.js.Alexas.Bring_Synchronisieren2:36
          SyntaxError: Unexpected token 'export'
              at new Script (node:vm:117:7)
              at JavaScript.createVM (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:2174:25)
              at JavaScript.prepareScript (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:2472:44)
              at processTicksAndRejections (node:internal/process/task_queues:105:5)
              at JavaScript.onObjectChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:659:25)
          Hat das Problem noch jemand? Oder weiß jemand, was ich machen kann?
          grrfieldG 1 Antwort Letzte Antwort
          • mcBirneM mcBirne
            grrfieldG Offline
            grrfieldG Offline
            grrfield
            #175
            @mcBirne Es ist zwar schon einige Zeit her, aber hast Du das Skript als TypeScript eingefügt? Die Fehlermeldungen sehen nach JavaScript aus.
            mcBirneM 1 Antwort Letzte Antwort
            • HeimwehH Heimweh
              @martin_olw Ich hab es jetzt doch getestet und noch was geändert:
              Hier die Beschreibung:
              Der Skript überwacht den Datenpunkt alexa2.0.Lists.SHOP.json.
              Sobald Alexa z. B. sagt:
              „Alexa, setze vier Äpfel auf die Einkaufsliste“
              wird das als neuer Eintrag in dieser Liste erkannt.
              Zahlwort-Umwandlung:
              Aus „vier Äpfel“ wird „4 Äpfel“.
              Auch zusammengesetzte Zahlen wie „fünfzehn“ oder „dreiundzwanzig“ werden korrekt erkannt.
              Das erste Wort nach der Zahl wird großgeschrieben: z. B. „4 Äpfel“ statt „4 äpfel“.
              Todoist-Eintrag:
              Der bereinigte und umgewandelte Eintrag wird direkt über die REST-API an Todoist gesendet und dort im definierten Projekt als Aufgabe eingetragen.
              Automatisches Entfernen in Alexa:
              Nach 60 Sekunden wird der passende Alexa-Listeneintrag automatisch als „abgehakt“ markiert.
              Es muss nur die ListID und der Token eingesetzt werden.
              const axios = require('axios');
              // Todoist API-Konfiguration
              const todoistProjectId = 'XXXXXXXX'; // Deine Projekt-ID
              const todoistToken = 'XXXXXXXXXXXXXXXXXXXXXXX'; // Dein Token
              let previousList = [];
              // 1. Alexa-Änderungen überwachen
              on({ id: 'alexa2.0.Lists.SHOP.json', change: 'any' }, function (obj) {
                  try {
                      const currentList = JSON.parse(obj.state.val);
                      if (currentList && currentList.length > 0) {
                          if (previousList.length < currentList.length) {
                              const newItem = currentList.find(item =>
                                  !previousList.some(prevItem => prevItem.id === item.id)
                              if (newItem) {
                                  const umgewandelt = wordsToNumbersSmart(newItem.value);
                                  const aufgabe = capitalizeFirst(umgewandelt);
                                  addTaskToTodoist(aufgabe);
                                  // Nach 60 Sekunden Alexa-Eintrag auf "completed" setzen
                                  setTimeout(() => {
                                      const alexaList = JSON.parse(getState('alexa2.0.Lists.SHOP.json').val);
                                      const matchingItem = alexaList.find(item => {
                                          const itemText = wordsToNumbersSmart(item.value).trim().toLowerCase();
                                          return itemText === aufgabe.trim().toLowerCase();
                                      if (matchingItem) {
                                          const completeState = `alexa2.0.Lists.SHOP.items.${matchingItem.id}.completed`;
                                          setState(completeState, true);
                                      } else {
                                          console.warn(`⚠️ Kein passender Alexa-Eintrag zu "${aufgabe}" gefunden.`);
                                  }, 60 * 1000); // 60 Sekunden
                          previousList = currentList;
                  } catch (e) {
                      console.error('Fehler beim Parsen der Alexa-Liste:', e.message || e);
              // 2. Aufgaben an Todoist senden
              function addTaskToTodoist(itemValue) {
                  const todoistData = {
                      content: itemValue,
                      project_id: todoistProjectId
                  axios.post('https://api.todoist.com/rest/v2/tasks', todoistData, {
                      headers: {
                          'Content-Type': 'application/json',
                          'Authorization': `Bearer ${todoistToken}`
                  .then(() => {
                      console.log(`✅ "${itemValue}" zu Todoist hinzugefügt.`);
                  .catch(error => {
                      console.error('Fehler beim Hinzufügen zu Todoist:', error.message || error);
              // 3. Erstes Wort groß
              function capitalizeFirst(text) {
                  if (!text || typeof text !== 'string') return '';
                  return text.charAt(0).toUpperCase() + text.slice(1);
              // 4. Wörter → Zahlen (z. B. „vierzehn“ → 14)
              function wordsToNumbersSmart(text) {
                  const ones = {
                      'null': 0, 'eins': 1, 'eine': 1, 'einen': 1,
                      'zwei': 2, 'drei': 3, 'vier': 4, 'fünf': 5,
                      'sechs': 6, 'sieben': 7, 'acht': 8, 'neun': 9,
                      'zehn': 10, 'elf': 11, 'zwölf': 12, 'dreizehn': 13,
                      'vierzehn': 14, 'fünfzehn': 15, 'sechzehn': 16,
                      'siebzehn': 17, 'achtzehn': 18, 'neunzehn': 19
                  const tens = {
                      'zwanzig': 20, 'dreißig': 30, 'vierzig': 40,
                      'fünfzig': 50, 'sechzig': 60, 'siebzig': 70,
                      'achtzig': 80, 'neunzig': 90
                  const multipliers = {
                      'hundert': 100,
                      'tausend': 1000
                  const skipWords = ['und', 'oder', 'mit', 'für', 'pro'];
                  const words = text.toLowerCase().split(/\s+/);
                  const finalText = [];
                  let i = 0;
                  let capitalizeNext = 0;
                  while (i < words.length) {
                      const word = words[i];
                      if (ones[word] !== undefined) {
                          if (i + 2 < words.length && words[i + 1] === 'und' && tens[words[i + 2]]) {
                              const value = ones[word] + tens[words[i + 2]];
                              finalText.push(value.toString());
                              capitalizeNext = 2;
                              i += 3;
                              continue;
                          if (i + 1 < words.length && multipliers[words[i + 1]]) {
                              const value = ones[word] * multipliers[words[i + 1]];
                              capitalizeNext = 2;
                              i += 2;
                              continue;
                          finalText.push(ones[word].toString());
                          capitalizeNext = 2;
                          i++;
                      } else if (tens[word] !== undefined) {
                          finalText.push(tens[word].toString());
                          capitalizeNext = 2;
                          i++;
                      } else if (!isNaN(word)) {
                          finalText.push(word);
                          capitalizeNext = 2;
                          i++;
                      } else {
                          if (capitalizeNext > 0 && !skipWords.includes(word)) {
                              finalText.push(word.charAt(0).toUpperCase() + word.slice(1));
                              capitalizeNext--;
                          } else {
                          i++;
                  return finalText.join(' ');
              M Online
              M Online
              martin_olw
              #176
              Hallo @Heimweh und vielen Dank noch einmal für das Script und die Anpassungen. Lief bis vor kurzem alles ohne Probleme bei mir. Jetzt aber bekomme ich immer folgende Fehlermeldung:
              script.js.common.ToDoist.Einkaufsliste_Alexa_Todoist: Fehler beim Hinzufügen zu Todoist:
              Mehr nicht. Woran kann das liegen?
              Prinzipiell funktioniert dein Skript aber:
              Updating item "bananentest" ({"id":"ad0e6a37-8dc2-4085-83d6-b282773292ac","listId":"YW16bjEuYWNjb3VudC5BRTVPSlgyRFk0UUhEVUJUNEJOWUpPUEJVSjNBLVNIT1BQSU5HX0lURU0=","value":"bananentest","customerId":"A2FTPWL63RKNMN","completed":true,"createdDateTime":1770990517898,"updatedDateTime":1770990517898,"version":1,"note":null,"index":0,"#delete":false,"listName":"SHOP"}) of the list SHOP.
              Funktioniert das bei dir noch alles?
              Danke für die ernuete Hilfe!
              VG Martin
              • N Offline
                N Offline
                no6mis
                #177
                Todoist hat die API angepasst, v2 gibt es nicht mehr.
                https://developer.todoist.com/api/v1/#tag/Tasks
                Du musst die API-URL auf https://api.todoist.com/api/v1/tasks ändern und die Projekt-IDs aktualisieren.
                • N no6mis
                  M Online
                  M Online
                  martin_olw
                  #178
                  @no6mis Ich danke dir! Genau das hat geholfen!
                  • HeimwehH Offline
                    HeimwehH Offline
                    Heimweh
                    #179
                    Sorry für meine späte Antwort - bei mir geht es auch nicht mehr. Die Projekt ID (zumindest die aus dem Browser) ist keine reine numerische Zahl mehr?
                    N 1 Antwort Letzte Antwort
                    • HeimwehH Heimweh
                      N Offline
                      N Offline
                      no6mis
                      #180
                      @Heimweh sagte in Alexa Shopping List mit Bring synchronisieren:
                      ja, die Zeichenfolge aus dem Browser (der Teil nach dem Klarnamen-) kannst du 1:1 in dein Script übernehmen.
                      • HeimwehH Offline
                        HeimwehH Offline
                        Heimweh
                        #181
                        Ich habe diese Änderung der Todoist API zum Anlass genommen den Script zu überarbeiten, da mittlerweile auch wieder die Listen in den Alexa Adapter eingelesen werden. Vielleicht kann den Script ja jemand brauchen.....
                        Alexa Shoppingliste ↔ Todoist (Projekt-Sync)
                        Dieses Script synchronisiert die Alexa Shoppingliste
                        (alexa2.0.Lists.SHOP.json) mit einem definierten Todoist-Projekt.
                        Funktionen
                        Beim Scriptstart werden alle offenen Alexa-Einträge in das Todoist-Projekt übernommen.
                        Neue Einträge in Alexa werden automatisch in Todoist angelegt.
                        Wird ein Task in Todoist erledigt, wird er in Alexa als „completed“ markiert.
                        Gelöschte oder erledigte Tasks in Todoist verschwinden damit auch aus der offenen Alexa-Liste.
                        Doppelimporte werden durch ein internes Mapping verhindert.
                        Deutsche Zahlwörter werden automatisch in Zahlen umgewandelt (z. B. „zwei Liter“ → „2 Liter“).
                        Voraussetzungen
                        ioBroker mit javascript-Adapter
                        alexa2-Adapter mit aktivierter Listenfunktion
                        Todoist API Token (REST v1)
                        axios (muss installiert sein)
                        Unterschied zur älteren Version
                        Es wird nicht mehr der Datenpunkt alexa2.0.History.summary ausgewertet.
                        Es wird direkt der vom alexa2-Adapter bereitgestellte Listen-JSON verwendet.
                        Die Synchronisation funktioniert jetzt sauber in beide Richtungen.
                        Es wird ausschließlich die aktuelle Todoist REST v1 API verwendet.
                        const axios = require("axios");
                        const TAG = "A2S-SHOP-PROD-2";
                        const ALEXA_JSON_DP = "alexa2.0.Lists.SHOP.json";
                        const ALEXA_ITEMS_ROOT = "alexa2.0.Lists.SHOP.items";
                        const TODOIST_TOKEN = "HIER_DEIN_TODOIST_TOKEN";
                        const TODOIST_BASE = "https://api.todoist.com/api/v1";
                        const TODOIST_PROJECT_ID = "HIER_DEINE_TODOIST_PROJEKT_ID";
                        const POLL_SEC = 20;
                        const MIN_TASK_AGE_MS = 5_000;
                        const STORE_ROOT = "0_userdata.0.alexaTodoistBiSync";
                        const MAP_STATE = `${STORE_ROOT}.map_shop`;
                        function headers(extra = {}) {
                          return { Authorization: `Bearer ${TODOIST_TOKEN}`, ...extra };
                        async function todoistCreateTask(content, projectId) {
                          const res = await axios.post(
                            `${TODOIST_BASE}/tasks`,
                            { content, project_id: projectId },
                            { headers: headers({ "Content-Type": "application/json" }), timeout: 15000 }
                          return res.data;
                        async function todoistGetTask(taskId) {
                          const res = await axios.get(`${TODOIST_BASE}/tasks/${taskId}`, {
                            headers: headers(),
                            timeout: 15000,
                            validateStatus: (s) => (s >= 200 && s < 300) || s === 404,
                          return res;
                        function ensureStateIfMissing(id, def, common) {
                          if (!existsState(id)) createState(id, def, common);
                        function readJsonSafe(id, fallback) {
                          const st = getState(id);
                          if (!st || st.val === null || st.val === undefined || st.val === "") return fallback;
                          try { return JSON.parse(st.val); } catch { return fallback; }
                        function writeJson(id, obj) {
                          setState(id, JSON.stringify(obj), true);
                        function parseAlexaJson(raw) {
                          if (raw === null || raw === undefined) return [];
                          const data = typeof raw === "string" ? JSON.parse(raw) : raw;
                          return Array.isArray(data) ? data : [];
                        function isCompletedAlexa(it) {
                          const v = it?.completed;
                          return v === true || v === 1 || v === "1" || v === "true";
                        function normalizeMap(map) {
                          let changed = false;
                          const now = Date.now();
                          for (const [alexaId, info] of Object.entries(map)) {
                            if (!info || typeof info !== "object") {
                              map[alexaId] = { todoistId: null, value: "", createdAt: now, alexaCompletedPushed: false };
                              changed = true;
                              continue;
                            if (info.todoistId === undefined) { info.todoistId = null; changed = true; }
                            if (info.value === undefined) { info.value = ""; changed = true; }
                            if (!info.createdAt || isNaN(Number(info.createdAt))) { info.createdAt = now; changed = true; }
                            if (info.alexaCompletedPushed === undefined) { info.alexaCompletedPushed = false; changed = true; }
                          return changed;
                        // ---- Text normalisieren (Zahlwörter) ----
                          if (!text || typeof text !== "string") return "";
                          const ones = {
                            "null": 0, "eins": 1, "eine": 1, "einen": 1, "ein": 1,
                            "zwei": 2, "drei": 3, "vier": 4, "fünf": 5,
                            "sechs": 6, "sieben": 7, "acht": 8, "neun": 9,
                            "zehn": 10, "elf": 11, "zwölf": 12, "dreizehn": 13,
                            "vierzehn": 14, "fünfzehn": 15, "sechzehn": 16,
                            "siebzehn": 17, "achtzehn": 18, "neunzehn": 19
                          const tens = {
                            "zwanzig": 20, "dreißig": 30, "dreissig": 30,
                            "vierzig": 40, "fünfzig": 50, "sechzig": 60,
                            "siebzig": 70, "achtzig": 80, "neunzig": 90
                          const multipliers = { "hundert": 100, "tausend": 1000 };
                          const skipWords = ["und", "oder", "mit", "für", "pro"];
                          const words = String(text).toLowerCase().split(/\s+/).filter(Boolean);
                          const out = [];
                          let i = 0;
                          let capNext = 0;
                            const w = words[i];
                            if (ones[w] !== undefined) {
                              if (i + 2 < words.length && words[i + 1] === "und" && tens[words[i + 2]] !== undefined) {
                                out.push(String(ones[w] + tens[words[i + 2]]));
                                capNext = 2;
                                i += 3;
                                continue;
                              if (i + 1 < words.length && multipliers[words[i + 1]] !== undefined) {
                                out.push(String(ones[w] * multipliers[words[i + 1]]));
                                capNext = 2;
                                i += 2;
                                continue;
                              out.push(String(ones[w]));
                              capNext = 2;
                              i++;
                              continue;
                            if (tens[w] !== undefined) {
                              out.push(String(tens[w]));
                              capNext = 2;
                              i++;
                              continue;
                            if (!isNaN(w)) {
                              out.push(w);
                              capNext = 2;
                              i++;
                              continue;
                            if (capNext > 0 && !skipWords.includes(w)) {
                              out.push(w.charAt(0).toUpperCase() + w.slice(1));
                              capNext--;
                            } else {
                              out.push(w);
                            i++;
                          return out.join(" ");
                        function normalizeTaskText(raw) {
                          const withNums = wordsToNumbersSmart(String(raw || "").trim());
                          return capitalizeFirst(withNums);
                        // ---- Debounce/Locks ----
                        let alexaSyncRunning = false;
                        let pollRunning = false;
                        let debounceTimer = null;
                        function triggerAlexaSyncDebounced(fullImport = false) {
                          if (debounceTimer) clearTimeout(debounceTimer);
                          debounceTimer = setTimeout(() => {
                            syncAlexaToTodoist(fullImport).catch(e => log(`[${TAG}] [Alexa→Todoist] ERROR ${e.message}`, "error"));
                          }, 800);
                        // ---- Alexa -> Todoist ----
                        async function syncAlexaToTodoist(fullImport) {
                          if (alexaSyncRunning) return;
                          alexaSyncRunning = true;
                          try {
                            const raw = getState(ALEXA_JSON_DP)?.val;
                            const items = parseAlexaJson(raw);
                            const map = readJsonSafe(MAP_STATE, {});
                            const changed = normalizeMap(map);
                            if (changed) writeJson(MAP_STATE, map);
                            for (const it of items) {
                              const alexaId = it?.id ? String(it.id) : null;
                              const valueRaw = it?.value ? String(it.value).trim() : "";
                              if (!alexaId || !valueRaw) continue;
                              if (isCompletedAlexa(it)) continue;
                              if (map[alexaId]?.todoistId) continue;
                              const value = normalizeTaskText(valueRaw);
                              const task = await todoistCreateTask(value, TODOIST_PROJECT_ID);
                              map[alexaId] = {
                                todoistId: String(task.id),
                                value,
                                createdAt: Date.now(),
                                alexaCompletedPushed: false,
                              log(`[${TAG}] [Alexa→Todoist] Angelegt: "${value}"`, "info");
                            if (fullImport) log(`[${TAG}] [Init] Start-Import abgeschlossen.`, "info");
                          } finally {
                        // ---- Todoist -> Alexa ----
                        async function pollTodoistAndMirror() {
                          if (pollRunning) return;
                          pollRunning = true;
                          try {
                            const entries = Object.entries(map).filter(([, info]) => info?.todoistId && !info.alexaCompletedPushed);
                            for (const [alexaId, info] of entries) {
                              const todoistId = String(info.todoistId);
                              const age = now - Number(info.createdAt || now);
                              if (age < MIN_TASK_AGE_MS) continue;
                              const res = await todoistGetTask(todoistId);
                              let markDone = false;
                              if (res.status === 404) {
                                // Task nicht mehr abrufbar -> behandeln wir als "weg/erledigt"
                                markDone = true;
                              } else if (res.status >= 200 && res.status < 300) {
                                const t = res.data || {};
                                const checked = t.checked === true;
                                const deleted = t.is_deleted === true;
                                // Wenn erledigt ODER gelöscht, dann Alexa abhaken
                                markDone = (checked || deleted);
                              } else {
                                continue;
                              if (!markDone) continue;
                              const completedDp = `${ALEXA_ITEMS_ROOT}.${alexaId}.completed`;
                              if (existsState(completedDp)) setState(completedDp, true, false);
                              info.alexaCompletedPushed = true;
                              log(`[${TAG}] [Todoist→Alexa] Abgehakt (TodoistId=${todoistId})`, "info");
                          } catch (e) {
                            const status = e.response?.status;
                            const body = e.response?.data ? JSON.stringify(e.response.data) : e.message;
                            log(`[${TAG}] [Poll] ERROR status=${status} body=${body}`, "error");
                          } finally {
                        // ---- INIT ----
                        ensureStateIfMissing(MAP_STATE, "{}", { type: "string", role: "json", read: true, write: true });
                        log(`[${TAG}] START poll=${POLL_SEC}s`, "info");
                        triggerAlexaSyncDebounced(true);
                        on({ id: ALEXA_JSON_DP, change: "any" }, () => triggerAlexaSyncDebounced(false));
                        schedule(`*/${POLL_SEC} * * * * *`, () => pollTodoistAndMirror());
                        • grrfieldG grrfield
                          mcBirneM Offline
                          mcBirneM Offline
                          mcBirne
                          #182
                          @grrfield sagte in Alexa Shopping List mit Bring synchronisieren:
                          nein, das wars, danke für den Tipp!
                            SchiefVanCleef
                            #183
                            Hallo zusammen, 🤗 nach dem ich hier viel über IO Broker in Verbindung mit Bring und der Alexa Shopping Liste gelernt habe 🤠 und immer mal wieder "tweaks" an meinem abgewandelten Script vorgenommen habe und es nun super geschmeidigt läuft, möchte ich gerne das aktuelle ALEXA BRING SCRIPT mit euch teilen und der hervorragenden Community auf diesem Weg etwas zurück geben und einfach nur DANKE 🙌 sagen.
                            Zum Script:
                            Bei der brindBaseID müsst ihr XXX wie gewohnt durch eure Bring Shopping List ID ersetzen, damit die richtige Liste befüllt wird. Ansonste alles wie immer: Alexa2.0 Adapter und bring.0 Adapter sind Voraussetzung, dass es funktioniert. Steht aber auch auskommentiert im Script.
                            //  Alexa Shopping List  <->  Bring!  Zwei-Wege-Sync
                            //  Engine: 3-Wege-Merge gegen persistierten Schatten + Zeitstempel-Konfliktlösung
                            //  Behandelt korrekt: Hinzufügen, Abhaken, Reaktivieren, Löschen (beidseitig)
                            // --- KONFIGURATION: an die eigene Installation anpassen ---
                            // Bring-Listen-ID findest du in den Objekten unter "bring.0" -> Channel deiner Liste (UUID):
                            const bringBaseId  = 'bring.0.xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx';
                            // Alexa-Einkaufsliste, bei den meisten Setups:
                            const alexa2BaseId = 'alexa2.0.Lists.SHOPPING_LIST';
                            // Voraussetzungen: Adapter "alexa2" + "bring" eingerichtet, 0_userdata.0 vorhanden.
                            // Persistenter Speicher für den Schatten (0_userdata.0 existiert in modernen ioBroker-Installs)
                            const SHADOW_STATE  = '0_userdata.0.alexaBringSync.shadow';
                            // Timing
                            const DEBOUNCE_MS   = 2000;   // warte nach der letzten Änderung, bevor synchronisiert wird
                            const LOCK_MS       = 5000;   // Beruhigungsfenster, bis async Schreibvorgänge der Adapter durch sind
                            // Bei einem echten Konflikt (beide Seiten gleichzeitig geändert, Zeitstempel uneindeutig):
                            // true  = im Zweifel "active" gewinnen lassen (nichts verlieren, was man evtl. noch braucht)
                            const CONFLICT_PREFER_ACTIVE = true;
                            // Optionaler Watchdog: warnt im Log, wenn die alexa2-Cloud-Verbindung wegbricht
                            const WATCH_ALEXA_CONNECTION = true;
                            // --- ABGELEITETE IDs ---
                            const bringListId          = bringBaseId + '.content';
                            const bringListCompletedId = bringBaseId + '.recentContent';
                            const bringAddToList       = bringBaseId + '.saveItem';            // hinzufügen / aus recent reaktivieren
                            const bringCompleteItem    = bringBaseId + '.moveToRecentContent'; // abhaken (-> recent)
                            const bringRemoveItem      = bringBaseId + '.removeItem';          // komplett entfernen (content + recent)
                            const alexaAddToList       = alexa2BaseId + '.#New';
                            const alexaListId          = alexa2BaseId + '.json';
                            // --- LAUFZEIT-ZUSTAND ---
                            let isSyncing   = false;
                            let pendingSync = false;
                            let syncTimeout = null;
                            // --- HILFSFUNKTIONEN ---
                            function cleanName(str) { return str ? String(str).trim().toLowerCase() : ''; }
                            function formatName(str) {
                                if (!str) return '';
                                str = String(str).trim();
                                return str.charAt(0).toUpperCase() + str.slice(1);
                            function loadShadow() {
                                try { const s = getState(SHADOW_STATE); return (s && s.val) ? JSON.parse(s.val) : {}; }
                                catch (e) { log('Schatten nicht lesbar, starte leer: ' + e, 'warn'); return {}; }
                            function saveShadow(sh) { setState(SHADOW_STATE, JSON.stringify(sh), true); }
                            // Konfliktlösung: jüngerer Zeitstempel gewinnt, sonst konfigurierte Vorzugsregel
                            function resolveConflict(aStatus, bStatus, aTs, bTs, displayName) {
                                let winner;
                                if (aTs > bTs)      winner = aStatus;
                                else if (bTs > aTs) winner = bStatus;
                                else                winner = CONFLICT_PREFER_ACTIVE
                                                              ? ((aStatus === 'active' || bStatus === 'active') ? 'active' : 'done')
                                                              : ((aStatus === 'done'   || bStatus === 'done')   ? 'done'   : 'active');
                                log(`[KONFLIKT] "${displayName}": Alexa=${aStatus}(${aTs}) vs Bring=${bStatus}(${bTs}) -> ${winner}`, 'warn');
                                return winner;
                            function finishLock() {
                                if (syncTimeout) clearTimeout(syncTimeout);
                                syncTimeout = setTimeout(() => {
                                    isSyncing = false;
                                    if (pendingSync) { pendingSync = false; triggerSync(); } // Nachlauf für während der Sperre Eingetroffenes
                                }, LOCK_MS);
                            // --- HAUPTLOGIK ---
                            function doSync() {
                                if (isSyncing) { pendingSync = true; return; }
                                isSyncing = true;
                                try {
                                    const aState = getState(alexaListId);
                                    const bState = getState(bringListId);
                                    const rState = getState(bringListCompletedId);
                                    if (!aState || aState.val == null || !bState || bState.val == null) { finishLock(); return; }
                                    const alexaList   = JSON.parse(aState.val);
                                    const bringActive = JSON.parse(bState.val);
                                    const bringRecent = (rState && rState.val) ? JSON.parse(rState.val) : [];
                                    // grobe Bring-Zeitstempel (Listenebene) nur für die Konfliktlösung
                                    const bringContentLc = bState.lc || bState.ts || 0;
                                    const bringRecentLc  = (rState && (rState.lc || rState.ts)) || 0;
                                    // --- Maps der aktuellen Zustände ---
                                    const alexaByName = {};   // active gewinnt bei Namens-Duplikaten
                                    alexaList.forEach(it => {
                                        const k = cleanName(it.value); if (!k) return;
                                        const st = it.completed ? 'done' : 'active';
                                        if (!alexaByName[k] || st === 'active') alexaByName[k] = it;
                                    const bringActiveMap = {}; bringActive.forEach(it => { const k = cleanName(it.name); if (k) bringActiveMap[k] = it; });
                                    const bringRecentMap = {}; bringRecent.forEach(it => { const k = cleanName(it.name); if (k) bringRecentMap[k] = it; });
                                    const shadow    = loadShadow();
                                    const newShadow = {};
                                    const names = new Set([
                                        ...Object.keys(alexaByName), ...Object.keys(bringActiveMap),
                                        ...Object.keys(bringRecentMap), ...Object.keys(shadow)
                                    names.forEach(name => {
                                        const aItem   = alexaByName[name];
                                        const aStatus = aItem ? (aItem.completed ? 'done' : 'active') : 'absent';
                                        const bStatus = bringActiveMap[name] ? 'active' : (bringRecentMap[name] ? 'done' : 'absent');
                                        const prev    = shadow[name] || { a: 'absent', b: 'absent', c: 'absent' };
                                        const aChanged = aStatus !== prev.a;
                                        const bChanged = bStatus !== prev.b;
                                        const displayName = (bringActiveMap[name] || bringRecentMap[name] || {}).name
                                                            || (aItem ? aItem.value : null) || prev.name || formatName(name);
                                        const aTs = aItem ? (aItem.updatedDateTime || 0) : 0;
                                        const bTs = (bStatus === 'active') ? bringContentLc : (bStatus === 'done' ? bringRecentLc : 0);
                                        // --- Zielzustand T bestimmen ---
                                        let T;
                                        if      (aChanged && !bChanged) T = aStatus;
                                        else if (bChanged && !aChanged) T = bStatus;
                                        else if (aChanged &&  bChanged) T = (aStatus === bStatus) ? aStatus
        : resolveConflict(aStatus, bStatus, aTs, bTs, displayName);
                                        else                            T = prev.c; // nichts geändert -> Kanon halten
                                        if (!T) T = (aStatus !== 'absent') ? aStatus : bStatus;
                                        // --- Alexa angleichen ---
                                        let aResult = aStatus;
                                        if (T === 'active') {
                                            if (aStatus === 'absent') { log(`[ALEXA +]          ${displayName}`); setState(alexaAddToList, displayName); aResult = 'active'; }
                                            else if (aStatus === 'done') { log(`[ALEXA reaktiv.]    ${displayName}`); setState(`${alexa2BaseId}.items.${aItem.id}.completed`, false); aResult = 'active'; }
                                        } else if (T === 'done') {
                                            if (aStatus === 'active') { log(`[ALEXA abgehakt]    ${displayName}`); setState(`${alexa2BaseId}.items.${aItem.id}.completed`, true); aResult = 'done'; }
                                            // aStatus 'absent' -> erledigtes Item lässt sich in Alexa nicht erzeugen, bleibt absent
                                        } else if (T === 'absent') {
                                            if (aStatus !== 'absent') { log(`[ALEXA gelöscht]    ${displayName}`); setState(`${alexa2BaseId}.items.${aItem.id}.#delete`, true); aResult = 'absent'; }
                                        // --- Bring angleichen ---
                                        let bResult = bStatus;
                                            if (bStatus !== 'active') { log(`[BRING +]           ${displayName}`); setState(bringAddToList, displayName); bResult = 'active'; }
                                            if (bStatus === 'active') { log(`[BRING abgehakt]    ${displayName}`); setState(bringCompleteItem, displayName); bResult = 'done'; }
                                            // bStatus 'absent' -> kann nicht als erledigt erzeugt werden, bleibt absent
                                            if (bStatus !== 'absent') { log(`[BRING gelöscht]    ${displayName}`); setState(bringRemoveItem, displayName); bResult = 'absent'; }
                                        // --- neuen Schatten schreiben (komplett verschwundene Items fallen raus) ---
                                        if (!(aResult === 'absent' && bResult === 'absent')) {
                                            newShadow[name] = { a: aResult, b: bResult, c: T, name: displayName, ts: Date.now() };
                                    saveShadow(newShadow);
                                } catch (e) {
                                    log('Fehler im Sync-Skript: ' + e, 'error');
                                finishLock();
                            // --- TRIGGER mit Debounce ---
                            function triggerSync() {
                                debounceTimer = setTimeout(doSync, DEBOUNCE_MS);
                            on({ id: bringListId,          change: 'ne' }, triggerSync);
                            on({ id: bringListCompletedId, change: 'ne' }, triggerSync);
                            on({ id: alexaListId,          change: 'ne' }, triggerSync);
                            if (WATCH_ALEXA_CONNECTION) {
                                on({ id: 'alexa2.0.info.connection', change: 'ne' }, obj => {
                                    if (obj.state.val === false) log('alexa2-Cloud-Verbindung verloren – Sync evtl. inaktiv bis zum Reconnect.', 'warn');
                            // --- START: Schatten-State sicherstellen, dann initial abgleichen ---
                            createState(SHADOW_STATE, '{}', false, { name: 'Alexa-Bring Sync Shadow', type: 'string', read: true, write: true }, () => {
                                log('Alexa <-> Bring Sync (Shadow-Merge) gestartet. Initialer Abgleich …');
                                triggerSync();
                            Das Script müsste ihr einfach als JS Script in IO Broker kopieren und starten. Der Rest funktioniert dann automatisch. WICHTIG NOCHMAL: Die Bring Base ID bzw. der Platzhalter XXX mit eurer echten Listen ID ersetzen.
                            DANKE nochmal an die gesamte Community, mit deren Hilfe dieses angepasste und für meine Zwecke hervorragend funktionierende Script entstanden ist. KUDOS an alle die ihre Scripts geteilt haben. 🤙 👏
                            • I Offline
                              I Offline
                              IOMax
                              #184
                              @schiefvancleef danke, eine Umsetzung auf Groß/Klein wäre noch super
                              • LocosL Offline
                                LocosL Offline
                                Locos
                                schrieb am zuletzt editiert von Locos
                                #185
                                Hi zusammen,
                                ich habe mir ein eigenes schlankes Skript gebaut, weil ich Alexa einfach nur als reines Spracheingabe-Mikrofon für meine Bring!-Liste nutzen will. Nach intensiven Tests im Alltag wurde der Code noch einmal überarbeitet und optimiert.
                                UPDATE (02.07.2026):
                                Was ist neu?
                                • 🚀 Multi-Item-Support (Großeinkäufe):
                                  Sagt ihr z. B. "Alexa, füge Äpfel und Bananen hinzu", zerschneidet das Skript den Satz ab sofort automatisch bei jedem "und". Es schickt getrennte Artikel an Bring! und löscht auch alle einzeln bei Alexa.
                                • 🧮 Intelligenter Mengen-Addierer:
                                  Wenn ihr schon "2 Flaschen Bier" auf der Liste habt und später "Schreibe zwei Flaschen Bier auf die Liste" sagt, liest das Skript die aktuelle Bring-Liste aus und rechnet zusammen ➔ Es landen "Bier, 4 Flaschen" in der App!
                                • 📦 Riesiges Verpackungs-Wörterbuch:
                                  Der Filter erkennt jetzt auch unzählige Haushalts-Einheiten wie Packungen, Dosen, Gläser, Rollen, Tuben, Kisten und Kartons.
                                • ⏱️ Anti-Verschluck-Garantie (Staggering):
                                  Werden mehrere Artikel gleichzeitig angesagt, schickt das Skript diese nun mit 1,5 Sekunden Abstand an den Adapter. So geht garantiert nichts mehr verloren.
                                • 🛠️ Feinschliff & Bugfixes:
                                  Das Skript reagiert nun auch auf wiederholte, identische Sätze (change: "any"), erkennt Trigger-Wörter wie "hinzu" und löscht hängende Cloud-Warteschleifen beim Skript-Neustart sauber auf.
                                Prinzip:
                                • Erkennen:
                                  Ihr sagt: "Alexa, pack drei Bananen auf die Einkaufsliste". Das Skript reagiert auf den neuen Text in eurem Alexa-Verlauf (alexa2.0.History.summary).
                                • Eintragen:
                                  Das Skript schnappt sich den Artikel, formatiert ihn und schickt ihn sofort an euren Bring!-Adapter.
                                • Löschen (Hier kommt die Alexa-Liste ins Spiel):
                                  Da Alexa den Artikel parallel natürlich trotzdem auf ihre eigene Liste setzt, wartet das Skript ein paar Sekunden, bis die Amazon-Cloud synchronisiert hat. Dann durchsucht es das JSON eurer echten Alexa-Einkaufsliste (alexa2.0.Lists.SHOP.json), sucht dort nach den "Bananen", schnappt sich die von Amazon vergebene Artikel-ID und löscht den Eintrag direkt von der Alexa-Liste.
                                • Ergebnis:
                                  Das Produkt landet perfekt in eurer Bring!-App und eure Alexa-Liste wird im Hintergrund automatisch bereinigt.
                                Funktionen:
                                • Mathematischer Zahlen-Gesamt-Parser:
                                  Macht aus gesprochenen Wörtern echte Zahlen. Die Logik basiert auf der genialen Grundidee des Users Heimweh, wurde von uns aber komplett neu aufgebaut, damit nun auch komplexe, zusammengesetzte Zahlenketten (z. B. "zwei hundert fünfzig gramm butter" ➔ 250) im selben Durchlauf fehlerfrei aufaddiert und zusammengefasst werden!
                                • Bruchzahlen-Erkennung:
                                  Unterstützt jetzt auch native Bruchteile wie "ein halbes Kilo" (➔ 0.5Kg) oder "ein viertel Pfund".
                                • Automatische Groß-/Kleinschreibung:
                                  Der Produktname in Bring! wird mit einem großen Anfangsbuchstaben übernommen (z. B. "frische milch" ➔ "Frische milch").
                                • Saubere Mengentrennung:
                                  Zahlen und Einheiten am Anfang werden erkannt und so an den Bring!-Adapter übergeben, dass sie in der Bring!-App perfekt getrennt im Feld specification (Menge) und name (Produkt) landen. Kein Textmatsch!
                                • Cloud-Warteschleife (Dynamic Retry):
                                  Weil die Amazon-Cloud manchmal pennt und ein paar Sekunden braucht, um das JSON im ioBroker zu aktualisieren, prüft mein Skript bis zu 5-mal alle 3 Sekunden nach, ob der Artikel da ist. Erst wenn er im JSON auftaucht, wird er per .#delete-Befehl weggebeamt.
                                • Error-Handling & Logging:
                                  Jede Texttransformation und Regex-Filterung ist einzeln per try-catch abgesichert. Sollte die Spracherkennung von Alexa mal totalen Kauderwelsch liefern, stürzt das Skript nicht mehr ab, sondern loggt den Fehler sauber und schickt den Artikel im Notfall-Fallback einfach als Rohtext an Bring!.
                                • Schont die Ressourcen:
                                  Kein permanentes JSON-Dauer-Polling im Hintergrund. Das Skript springt nur an, wenn ich auch wirklich was ansage.
                                Voraussetzungen:
                                JavaScript-Adapter, alexa2-Adapter (Listenfunktion aktiv), bring-Adapter.
                                Code (Einfach als neues JavaScript (JS) anlegen, eure eigene Bring-ID oben eintragen und fertig!):
                                 * Alexa Voice-Input to Bring! List Pushing Engine
                                 * Erkennt Sprachbefehle aus der Alexa-History, wandelt Zahlwörter um,
                                 * trennt Mengen sauber ab (z.B. "3 Erdbeeren" -> "Erdbeeren, 3" für Bring!),
                                 * teilt Aufzählungen ("und", ",") in einzelne Artikel auf,
                                 * addiert Mengen bestehender Artikel intelligent zusammen,
                                 * formatiert den Artikel und löscht ihn anschließend sofort von Alexa.
                                // --- KONFIGURATION ---
                                // ID des Datenpunkts für die Alexa History Zusammenfassung und Antworttext
                                const alexaHistorySummaryId = 'alexa2.0.History.summary';
                                const alexaHistoryAnswerId = 'alexa2.0.History.answerText';
                                // Basis-ID deiner Bring! Adapter-Instanz (HIER DEINE EIGENE ID EINTRAGEN)
                                const bringBaseId = 'bring.0.deine-bring-liste-id-hier';
                                const bringAddItemStateId = bringBaseId + '.saveItem';
                                // Pfad zur Alexa-Einkaufsliste (Basis und JSON)
                                const alexa2BaseId = 'alexa2.0.Lists.SHOP';
                                const alexaShoppingListJsonId = `${alexa2BaseId}.json`;
                                // Schalter für Debug-Ausgaben im ioBroker-Log
                                const printDebug = true;
                                // Array für laufende Timeouts (verhindert Fehler bei Skript-Neustart)
                                let activeTimeouts = [];
                                function debug(msg) {
                                    if (printDebug) {
                                        log('[Alexa->Bring Push] ' + msg);
                                // Schneidet führende Alexa-Befehlswörter ab
                                function stripPrefixes(text) {
                                    if (!text) return '';
                                    const prefixesToRemove = [
                                        /^(?:hey\s+)?alexa,\s*/i,
                                        /^(?:hey\s+)?alexa\s+/i,
                                        /^füge\s+/i, /^setz\s+/i, /^setze\s+/i, /^packe\s+/i, /^pack\s+/i,
                                        /^schreib\s+/i, /^schreibe\s+/i, /^notiere\s+/i
                                    let result = String(text).trim();
                                    let changed = true;
                                    while (changed) {
                                        let startLen = result.length;
                                        for (const prefixRegex of prefixesToRemove) {
                                            result = result.replace(prefixRegex, '').trim();
                                        changed = result.length !== startLen;
                                    return result;
                                // Prüft alte und neue Mengen und addiert sie, falls die Einheiten passen
                                function mergeQuantities(oldSpec, newSpec) {
                                    if (!oldSpec) return newSpec;
                                    if (!newSpec) return oldSpec;
                                    const regex = /^(\d+(?:[.,]\d+)?)\s*(.*)$/i;
                                    const matchOld = String(oldSpec).match(regex);
                                    const matchNew = String(newSpec).match(regex);
                                    if (matchOld && matchNew) {
                                        let numOld = parseFloat(matchOld[1].replace(',', '.'));
                                        let numNew = parseFloat(matchNew[1].replace(',', '.'));
                                        let unitOld = matchOld[2].trim().toLowerCase();
                                        let unitNew = matchNew[2].trim().toLowerCase();
                                        // Wenn die Einheiten gleich sind (oder eine fehlt), wird addiert
                                        if (unitOld === unitNew || unitOld === '' || unitNew === '') {
                                            let total = numOld + numNew;
                                            let unitToUse = matchNew[2].trim() || matchOld[2].trim();
                                            return unitToUse ? `${total} ${unitToUse}` : `${total}`;
                                        } else {
                                            // Wenn Einheiten unterschiedlich sind (z.B. "500 g" und "1 Packung"),
                                            // hängen wir sie einfach mit einem "+" zusammen
                                            return `${oldSpec} + ${newSpec}`;
                                    return newSpec; // Fallback, falls keine Zahlen gefunden wurden
                                // Zuverlässiger Parser für deutsche Zahlwörter
                                    try {
                                        let t = String(text).toLowerCase().replace(/\s+/g, ' ');
                                        const ones = {
                                            "null": 0, "eins": 1, "eine": 1, "einen": 1, "ein": 1, "milli": 1,
                                            "zwei": 2, "drei": 3, "vier": 4, "fünf": 5, "sechs": 6, "sieben": 7, "acht": 8, "neun": 9,
                                            "zehn": 10, "elf": 11, "zwölf": 12, "dreizehn": 13, "vierzehn": 14, "fünfzehn": 15,
                                            "sechzehn": 16, "siebzehn": 17, "achtzehn": 18, "neunzehn": 19
                                        const tens = {
                                            "zwanzig": 20, "dreißig": 30, "dreissig": 30, "vierzig": 40, "fünfzig": 50,
                                            "sechzig": 60, "siebzig": 70, "achtzig": 80, "neunzig": 90
                                        const skipWords = ["und"];
                                        const words = t.split(/\s+/).filter(Boolean);
                                        const out = [];
                                        let currentNumber = 0;
                                        let hasNumber = false;
                                        for (let i = 0; i < words.length; i++) {
                                            const w = words[i];
                                                currentNumber += ones[w];
                                                hasNumber = true;
                                            } else if (tens[w] !== undefined) {
                                                currentNumber += tens[w];
                                                hasNumber = true;
                                            } else if (multipliers[w] !== undefined) {
                                                if (currentNumber === 0) currentNumber = 1;
                                                currentNumber *= multipliers[w];
                                                hasNumber = true;
                                            } else if (!isNaN(Number(w))) {
                                                if (hasNumber) {
                                                    out.push(String(currentNumber));
                                                    currentNumber = 0;
                                                    hasNumber = false;
                                                out.push(w);
                                            } else if (skipWords.includes(w) && hasNumber) {
                                                continue;
                                            } else {
                                                if (hasNumber) {
                                                    currentNumber = 0;
                                                    hasNumber = false;
                                                if (out.length === 0 || !isNaN(Number(out[out.length - 1]))) {
                                                } else {
                                                    out.push(w);
                                        if (hasNumber) {
                                        let resultString = out.join(" ");
                                        // Brüche umwandeln
                                        resultString = resultString.replace(/\b(1\s+)?halbe?s?\b/gi, '0.5');
                                        resultString = resultString.replace(/\b(1\s+)?viertel\b/gi, '0.25');
                                        return resultString;
                                    } catch (err) {
                                        log(`Fehler in wordsToNumbersSmart bei Text "${text}": ${err.message}`, 'warn');
                                        return String(text);
                                // Bereinigt den Text, trennt Mengen ab und sorgt für korrekte Groß-/Kleinschreibung
                                function ListCleaner(Eintrag = '') {
                                    if (!Eintrag) return { formatted: '', product: '', quantity: '' };
                                    try {
                                        let textWithNumbers = wordsToNumbersSmart(Eintrag);
                                        if (!textWithNumbers || typeof textWithNumbers !== 'string') {
                                            textWithNumbers = String(Eintrag);
                                        textWithNumbers = textWithNumbers.trim();
                                        const quantityRegex = /^(\d+(?:[.,]\d+)?)(?:\s*(mal|x|stck|stück|l|ltr|liter|kg|kilo|g|gramm|pfund|flasche|flaschen|packung|packungen|päckchen|dose|dosen|becher|glas|gläser|rolle|rollen|tube|tuben|tafel|tafeln|kiste|kisten|karton|kartons))?\s+(.+)$/i;
                                        const match = textWithNumbers.match(quantityRegex);
                                        if (match && match[1] && match[3]) {
                                            let quantity = String(match[1]).trim();
                                            let unit = match[2] ? String(match[2]).trim().toLowerCase() : '';
                                            let product = String(match[3]).trim();
                                            if (product.length > 0) {
                                                product = product.charAt(0).toUpperCase() + product.slice(1);
                                                if (['kilo', 'kg'].includes(unit)) {
                                                    unit = 'kg';
                                                } else if (['gramm', 'g'].includes(unit)) {
                                                    unit = 'g';
                                                } else if (['liter', 'l', 'ltr'].includes(unit)) {
                                                    unit = 'l';
                                                } else if (['stck', 'stück'].includes(unit)) {
                                                    unit = 'Stück';
                                                } else if (['mal', 'x'].includes(unit)) {
                                                    unit = '';
                                                } else if (unit) {
                                                    unit = unit.charAt(0).toUpperCase() + unit.slice(1);
                                                let finalQuantity = unit ? `${quantity} ${unit}` : quantity;
                                                debug(`Menge erkannt: "${finalQuantity}", Produkt: "${product}" -> Formatiere für Bring als "${product}, ${finalQuantity}"`);
                                                return { formatted: `${product}, ${finalQuantity}`, product: product, quantity: finalQuantity };
                                        let normProduct = textWithNumbers.charAt(0).toUpperCase() + textWithNumbers.slice(1);
                                        return { formatted: normProduct, product: normProduct, quantity: '' };
                                    } catch (err) {
                                        log(`Fehler in ListCleaner bei Eintrag "${Eintrag}": ${err.message}`, 'error');
                                        let fallbackProduct = String(Eintrag).charAt(0).toUpperCase() + String(Eintrag).slice(1);
                                        return { formatted: fallbackProduct, product: fallbackProduct, quantity: '' };
                                // Intelligente Löschfunktion mit Cloud-Warteschleife und Multi-Match-Logik
                                function removeItemFromAlexaList(itemName, extractedProduct, attempt = 1) {
                                    const maxAttempts = 5;
                                    const retryDelay = 3000;
                                    let cleanedAlexaName = stripPrefixes(itemName);
                                    debug(`Versuche, "${cleanedAlexaName}" (Produkt-Match: "${extractedProduct}") von der Alexa-Liste zu entfernen (Versuch ${attempt}/${maxAttempts}).`);
                                    try {
                                        const listState = getState(alexaShoppingListJsonId);
                                        if (!listState || !listState.val) {
                                            debug("Alexa Einkaufslisten-JSON ist leer. Warte auf Adapter-Update...");
                                            if (attempt < maxAttempts) {
                                                let timer = setTimeout(() => removeItemFromAlexaList(itemName, extractedProduct, attempt + 1), retryDelay);
                                                activeTimeouts.push(timer);
                                            return;
                                        const shoppingList = JSON.parse(listState.val);
                                        let itemIdToDelete = null;
                                        const search1 = cleanedAlexaName.toLowerCase();
                                        const search2 = extractedProduct.toLowerCase();
                                        for (const item of shoppingList) {
                                            if (item && item.value) {
                                                const valLower = item.value.toLowerCase();
                                                if (valLower === search1 || valLower === search2 || search1.includes(valLower) || valLower.includes(search2)) {
                                                    itemIdToDelete = item.id;
                                                    cleanedAlexaName = item.value;
                                                    break;
                                        if (itemIdToDelete) {
                                            const deleteStateId = `${alexa2BaseId}.items.${itemIdToDelete}.#delete`;
                                            debug(`Artikel-ID gefunden. Sende Löschbefehl an: ${deleteStateId}`);
                                            setState(deleteStateId, true);
                                            debug(`Löschbefehl für "${cleanedAlexaName}" erfolgreich an Amazon übermittelt.`);
                                        } else {
                                                debug(`Artikel "${cleanedAlexaName}" / "${extractedProduct}" noch nicht im JSON. Cloud synchronisiert noch... Erneuter Versuch in 3 Sek.`);
                                            } else {
                                                debug(`Artikel wurde nach ${maxAttempts} Versuchen nicht im JSON gefunden.`);
                                    } catch (e) {
                                        log(`Fehler beim Entfernen des Artikels von der Alexa-Liste: ${e}`, 'error');
                                on({ id: alexaHistorySummaryId, change: "any", ack: true }, function (obj) {
                                    try {
                                        if (!obj.state || !obj.state.val || typeof obj.state.val !== 'string') return;
                                        const summaryTextFull = obj.state.val;
                                        const summaryText = summaryTextFull.toLowerCase();
                                        const alexaAnswer = getState(alexaHistoryAnswerId)?.val || 'Keine Antwort aufgezeichnet';
                                        debug(`Neuer History Summary Eintrag: "${summaryTextFull}" | Alexa Antwort: "${alexaAnswer}"`);
                                        // Trigger-Phrasen inklusive "hinzu" aus dem Forum
                                        const triggerPhrases = [' auf die einkaufsliste', ' zur einkaufsliste', ' hinzu', ' hinzufügen'];
                                        let itemFound = false;
                                        let itemNameRaw = '';
                                        for (const phrase of triggerPhrases) {
                                            const index = summaryText.lastIndexOf(phrase);
                                            if (index !== -1 && index > 0) {
                                                itemNameRaw = summaryTextFull.substring(0, index).trim();
                                                itemNameRaw = stripPrefixes(itemNameRaw);
                                                itemFound = true;
                                                break;
                                        if (itemFound && itemNameRaw) {
                                            // 1. Text bei Komma oder " und " aufteilen für Multi-Item-Support
                                            const itemsToProcess = itemNameRaw.split(/,\s*|\s+und\s+/i).filter(Boolean);
                                            debug(`Multi-Item-Erkennung: Satz wurde in ${itemsToProcess.length} Artikel geteilt.`);
                                            // 2. Jeden Artikel einzeln verarbeiten
                                            itemsToProcess.forEach((singleItemRaw, index) => {
                                                const cleanResult = ListCleaner(singleItemRaw);
                                                const cleanedItemName = cleanResult.formatted;
                                                const originalItemName = singleItemRaw.trim();
                                                if (cleanedItemName) {
                                                    // --- NEU: Bring! JSON prüfen und Mengen addieren ---
                                                    let finalItemNameToBring = cleanedItemName;
                                                    try {
                                                        const bringContentState = getState(bringBaseId + '.content');
                                                        if (bringContentState && bringContentState.val) {
                                                            let bringList = typeof bringContentState.val === 'string' ? JSON.parse(bringContentState.val) : bringContentState.val;
                                                            // Sucht, ob das Produkt schon auf der Bring!-Liste steht
                                                            let existingItem = bringList.find(i => i.name.toLowerCase() === cleanResult.product.toLowerCase());
                                                            if (existingItem && existingItem.specification) {
        let mergedSpec = mergeQuantities(existingItem.specification, cleanResult.quantity);
        finalItemNameToBring = `${cleanResult.product}, ${mergedSpec}`;
        debug(`Artikel "${cleanResult.product}" existiert bereits. Addiere Menge: "${existingItem.specification}" + "${cleanResult.quantity}" -> "${mergedSpec}"`);
                                                    } catch (e) {
                                                        debug(`Fehler beim Auslesen der bestehenden Bring-Liste: ${e.message}`);
                                                    // 3. Gestaffelte Ausführung (1.5 Sekunden Abstand pro Artikel),
                                                    // damit der Bring! Adapter sich nicht verschluckt.
                                                    let processingDelay = index * 1500;
                                                    let processTimer = setTimeout(() => {
                                                        debug(`[Artikel ${index + 1}/${itemsToProcess.length}] Roh: "${originalItemName}" -> Bring!: "${finalItemNameToBring}".`);
                                                        // Schritt 1: Zu Bring! hinzufügen (mit eventuell addierter Menge)
                                                        setState(bringAddItemStateId, finalItemNameToBring, false);
                                                        // Schritt 2: Verzögertes Löschen auf Alexa-Seite triggern
                                                        let deleteTimer = setTimeout(() => {
                                                            removeItemFromAlexaList(originalItemName, cleanResult.product);
                                                        }, 4000);
                                                        activeTimeouts.push(deleteTimer);
                                                    }, processingDelay);
                                                    activeTimeouts.push(processTimer);
                                                } else {
                                                    debug(`Artikel "${originalItemName}" ist nach Bereinigung leer. Ignoriere.`);
                                    } catch (globalErr) {
                                        log(`Unerwarteter globaler Fehler in der Hauptschleife: ${globalErr.message}`, 'error');
                                // --- CLEANUP BEIM BEENDEN ---
                                onStop(function () {
                                    activeTimeouts.forEach(timer => clearTimeout(timer));
                                    debug("Skript gestoppt. Alle laufenden Timeouts wurden sicher beendet.");
                                }, 10);
                                // --- SKRIPTSTART ---
                                debug("Skript gestartet. Multi-Item-Parser, Mengen-Addierer und erweiterte Triggerwörter aktiv.");
                                • mcBirneM Offline
                                  mcBirneM Offline
                                  mcBirne
                                  #186
                                  Super, vielen Dank! Klappt super bei mir.
                                  Aber mir ist aufgefallen, dass es nur funktioniert wenn ich sage:
                                  "packe 3 Äpfel auf die Eingaufsliste". Wenn ich sage: "füge 3 Äpel hinzu" passiert leider nichts. Alexa packt sie auf die internen Einkaufsliste aber das Skript reagiert nicht. Gibt es eine Möglichgeit auch das noch abzugreifen?
                                  Habe es gefunden.
                                  Zeile 252 sieht bei mir jetzt so aus:
                                  const triggerPhrases = [' auf die einkaufsliste', ' zur einkaufsliste',' hinzu',' hinzufügen'];
                                  Werde es weiter testen.
                                  LocosL 1 Antwort Letzte Antwort
                                  • mcBirneM mcBirne
                                    Habe es gefunden.
                                    LocosL Offline
                                    LocosL Offline
                                    Locos
                                    #187
                                    @mcBirne danke für dein Feedback. habe das Skript nochmal etwas überarbeitet. Siehe vorherigen Post.
                                    Liebe Grüße
