  4. Modbus Adapter received answer for wrong ID 2, expected 1
    6.4k
20 Beiträge 7 Kommentatoren 621 Aufrufe 6 Beobachtet
  • HF_SPSlerH Offline
    HF_SPSlerH Offline
    HF_SPSler
    ich habe heute den Modbus Adapter auf 7.0.6 geupdatet und ihn anschließend mit der debugausgabe gestartet. Dabei ist mir aufgefallen, dass beim Polling der Slaves zwar die Daten ordnungsgemäß abgeholt werden jedoch der Eintrag "received answer for wrong ID 2, expected 1" für fast jeden Slave mit in das log geschrieben wird.
    modbus.4 	2026-02-13 18:23:29.903	debug	[DevID_30/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:29.902	debug	received answer for wrong ID 30, expected 1
    modbus.4	2026-02-13 18:23:29.880	debug	[DevID_30/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:29.880	debug	[DevID_30] Poll start ---------------------
    modbus.4	2026-02-13 18:23:29.103	debug	[DevID_24/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:29.102	debug	received answer for wrong ID 24, expected 1
    modbus.4	2026-02-13 18:23:29.079	debug	[DevID_24/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:29.078	debug	[DevID_24] Poll start ---------------------
    modbus.4	2026-02-13 18:23:28.303	debug	[DevID_23/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:28.303	debug	received answer for wrong ID 23, expected 1
    modbus.4	2026-02-13 18:23:28.281	debug	[DevID_23/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:28.281	debug	[DevID_23] Poll start ---------------------
    modbus.4	2026-02-13 18:23:27.504	debug	[DevID_22/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:27.503	debug	received answer for wrong ID 22, expected 1
    modbus.4	2026-02-13 18:23:27.482	debug	[DevID_22/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:27.481	debug	[DevID_22] Poll start ---------------------
    modbus.4	2026-02-13 18:23:26.704	debug	[DevID_21/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:26.704	debug	received answer for wrong ID 21, expected 1
    modbus.4	2026-02-13 18:23:26.682	debug	[DevID_21/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:26.681	debug	[DevID_21] Poll start ---------------------
    modbus.4	2026-02-13 18:23:25.905	debug	[DevID_20/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:25.904	debug	received answer for wrong ID 20, expected 1
    modbus.4	2026-02-13 18:23:25.820	debug	[DevID_20/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:25.819	debug	[DevID_20] Poll start ---------------------
    modbus.4	2026-02-13 18:23:25.042	debug	[DevID_3/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:25.041	debug	received answer for wrong ID 3, expected 1
    modbus.4	2026-02-13 18:23:25.020	debug	[DevID_3/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:25.019	debug	[DevID_3] Poll start ---------------------
    modbus.4	2026-02-13 18:23:24.242	debug	[DevID_2/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:24.241	debug	received answer for wrong ID 2, expected 1
    modbus.4	2026-02-13 18:23:24.217	debug	[DevID_2/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:24.216	debug	[DevID_2] Poll start ---------------------
    modbus.4	2026-02-13 18:23:23.441	debug	[DevID_1/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:23.411	debug	[DevID_1/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:23.410	debug	[DevID_1] Poll start ---------------------
    modbus.4	2026-02-13 18:23:19.635	debug	[DevID_30/inputRegs] Poll address 0 DONE
    modbus.4	2026-02-13 18:23:19.634	debug	received answer for wrong ID 30, expected 1
    modbus.4	2026-02-13 18:23:19.611	debug	[DevID_30/inputRegs] Poll address 0 - 6 registers
    modbus.4	2026-02-13 18:23:19.611	debug	[DevID_30] Poll start ---------------------
    Verwendet wird Iobroker auf einem Raspi4 8GB. Der Adapter läuft in mehreren Instanzen um zum Einen via Modbus-TCP die Victron PV Anlage auszulesen und via Modbus-RTU 9 Slaves auszulesen die in verschiedenen Räumen Klimadaten aufnehmen.
    Jetzt würde mich natürlich mal interessieren, warum diese Meldung ins Log geschrieben wird?
    S7 1214 (Master) + Logo!8(Slave Erdgeschoss) + Logo!8 (Slave Obergeschoss) + S7 1214 (Slave Garage/Nebengebäude)
    fuzzy1955F 1 Antwort Letzte Antwort
    • HF_SPSlerH HF_SPSler
      fuzzy1955F Offline
      fuzzy1955F Offline
      fuzzy1955
      schrieb am zuletzt editiert von fuzzy1955
      @HF_SPSler sagte in Modbus Adapter received answer for wrong ID 2, expected 1:
      bei mir bringt auch das Update auf den Modbus-Adapter v7.0.6 Fehler beim Waveshare Modbus ETH 8xRelay:
      modbus.1
      2026-02-14 08:14:14.615	warn	[DevID_1] Some register types failed but continuing: 1/4 errors
      modbus.1
      2026-02-14 08:14:14.114	warn	[DevID_1/coils] Block 0-15: {}
      modbus.1
      2026-02-14 08:14:14.114	debug	Received pdu describes an error.
      modbus.1
      2026-02-14 08:14:14.107	debug	[DevID_1/coils] Poll address 0 - 16 bits
      modbus.1
      2026-02-14 08:14:14.107	debug	[DevID_1] Poll start ---------------------
      Die Relais schalten korrekt, aber im Log stehen die Fehler, obwohl ich nur das Coils-Register verwenden. Was kann die Ursache dafür sein? Vorweg danke für eure Unterstützung!
      [Nachtrag]
      Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
      Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
      Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
      Großes Danke an alle tatkräftigen Helfer im Forum!
      • WinniW Offline
        WinniW Offline
        Winni
        modbus.1
        Bei mir genauso. Ich hatte die Fehlermeldung nach dem Update auch. Nachdem das aber meine IDM AERO ALM 6-15 Wärmepumpe ist und das bisher perfekt gelaufen ist,wollte ich kein Risiko eingehen und bin nur zurück auf die 6.4.0. Damit war die Fehlermeldung wieder verschwunden. Vielleicht interessant, ich habe noch 2 weitere Instanzen laufen für SMA Wechelrichter SB4000/5000 TL-21, da kam keine Fehlermeldung.
        WinniW 1 Antwort Letzte Antwort
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          Wenn es Probleme gibt bitte ein Issue loggen.
          Support Repositoryverwaltung.
          LESEN - gute Forenbeitrage
          • WinniW Winni
            modbus.1
            WinniW Offline
            WinniW Offline
            Winni
            schrieb am zuletzt editiert von Winni
            Ich glaube ich konnte das Problem lösen. Ich hatte einen Datenpunkt unter "Diskrete Eingänge" aktiviert ohne weitere Parameter anzugeben. War wohl irgendwann aus Versehen. Die neue Version hat das bemerkt und angemeckert, der älteren war das wohl egal. Ich habe das korrigiert und jetzt läuft der Adapter wie er soll. 😀
            Edit: Ich meine das Problem dieser Fehlermeldung:
            modbus.1
            • darkbluD Offline
              darkbluD Offline
              darkblu
              schrieb am zuletzt editiert von darkblu
              Ich habe die gleiche Fehlermeldung mit ebenfalls 7.0.6:
              2026-02-14 16:56:29.082	warn	[DevID_247] Some register types failed but continuing: 1/4 errors
              wüsste aber nicht, wo etwas falsches oder fehlendes sein soll.
              Demnach müsste ich jetzt jeden Eintrag der Reihe nach aus meinen Holding Registern und Diskreten Ausgängen löschen um zu sehen, welcher der fehlerhafte ist ?
              Die Muße habe ich gerade nicht.
              Ich komme von 6.3.2, da war auch alles i.O.
              Raspi 4, 4GB für Influxdb 1.8 und Grafana
              Raspi 5, 8 GB für ioBroker
              Threadnetzwerk per Apple
              mcm1957M DolomitiD 2 Antworten Letzte Antwort
              • darkbluD darkblu
                mcm1957M Online
                mcm1957M Online
                mcm1957
                Wenn es die selbe Ursache ist war das in 6.x.x auch NICHT in Ordnung. Es wurde nur der Fehler nicht entdeckt. :-).
                Du kannst aber auch einfach nicht in log schaun. Dann ist ja weiter alles ok. :-):-)
                • WinniW Offline
                  WinniW Offline
                  Winni
                  Oder mal die Datenpunkte anschauen. Ist da einer der nicht aktualisiert ist, bzw. wo N/A drin steht?
                    HF_SPSlerH Offline
                    HF_SPSler
                    Jetzt haben sich ja einige mit hier an das Thema gehängt, die aber, so verstehe ich das, andere Probleme haben. Wie sieht es denn mit meinem Issue aus :-)
                    Da hänge ich immer noch bei:
                      hast du ein Issue suf Github erstellt?
                      dann kommt auch da die Antwort
                      Hier hab ich noch keine (fehlerhafte) Konfiguration von dir gesehen
                      • darkbluD darkblu
                        DolomitiD Offline
                        DolomitiD Offline
                        Dolomiti
                        @darkblu sagte in Modbus Adapter received answer for wrong ID 2, expected 1:
                        Ich habe auch das Problem. Die Warnungen gingen erste weg nachdem ich alle DI bis auf einen gelöscht habe.
                        Intel N100 (32GB,256GB SSD), Proxmox -> Debian 13 in VM (Master) + Debian 13 in CT (Test) + Debmatic, HM-Aktoren, Wago 750-880, Shelly, Zigbee
                        • darkbluD Offline
                          darkbluD Offline
                          darkblu
                          @dolomiti ,Was sind denn DI ? 🤔
                          • darkbluD darkblu
                            @darkblu Digital Inputs
                            • DolomitiD Offline
                              DolomitiD Offline
                              Dolomiti
                              • darkbluD Offline
                                darkbluD Offline
                                darkblu
                                Ok, Danke
                                Du hast also alle Register und/oder Coils bis auf einen gelöscht ?
                                Dann leb ich lieber erstmal mit der Fehlermeldung.
                                DolomitiD 1 Antwort Letzte Antwort
                                • darkbluD darkblu
                                  Ok, Danke
                                  DolomitiD Offline
                                  DolomitiD Offline
                                  Dolomiti
                                  @darkblu
                                  Ja, war auf meinem Testsystem zum eingrenzen des Problems. Ich bleibe erstmal auf 6.3.2 bzw. 6.4.0.
                                  Mal schauen ob ich einen Wireshark-Mitschnitt mache um das Problem zu finden.
                                  • WinniW Offline
                                    WinniW Offline
                                    Winni
                                    @darkblu @dolomiti habt ihr die Einstellung bei der 7.0.6 gesehen?
                                    Mir ist die unter der 6.x nicht aufgefallen. Probiert doch mal aus ein Häkchen zu setzen, vielleicht ist die Fehlermeldung dann weg. Wäre dann eine Lösung bis die wirkliche Ursache gefunden ist.
                                    fuzzy1955F DolomitiD 2 Antworten Letzte Antwort
                                    • WinniW Winni
                                      fuzzy1955F Offline
                                      fuzzy1955F Offline
                                      fuzzy1955
                                      @Winni sagte in Modbus Adapter received answer for wrong ID 2, expected 1:
                                      Hab ich versucht. Das hilft nichts.
                                      • WinniW Winni
                                        DolomitiD Offline
                                        DolomitiD Offline
                                        Dolomiti
                                        Hat bei mir auch nicht geholfen. V8.0.0 war bei mir die Lösung
                                        • darkbluD Offline
                                          darkbluD Offline
                                          darkblu
                                          Kann ich auch bestätigen, Version 8.0.0 brachte die Lösung.
                                          Seit dem keine Fehlermeldung mehr.
