  4. Adapter läuft nicht mehr
    6.0k
23 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • M mattle1957
    Das iob diag sieht jetzt folgendermaßen aus:
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: martinpi
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     08:18:51 up 17:29,  1 user,  load average: 2.77, 3.34, 1.77
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Fri 2026-01-30 08:18:51 CET
               Universal time: Fri 2026-01-30 07:18:51 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.2G        1.9G        3.0G         12M        3.4G        6.3G
    Swap:           2.1G          0B        2.1G
    Total:           10G        1.9G        5.1G
    Active iob-Instances:   22
             7819 M total memory
             1822 M used memory
             1757 M active memory
             2819 M inactive memory
             2850 M free memory
              188 M buffer memory
             3070 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 08:18:52 up 17:29,  1 user,  load average: 2.77, 3.34, 1.77
    Tasks: 213 total,   3 running, 210 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 60.4 us,  9.4 sy,  0.0 ni, 28.3 id,  0.0 wa,  0.0 hi,  1.9 si,  0.0 st
    MiB Mem :   7819.7 total,   2887.9 free,   1784.8 used,   3258.7 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6034.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
    /dev/sda2      ext4      9.8G  6.2G  3.3G  66% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     3.9G  2.8M  3.9G   1% /tmp
    /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
    tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
    [Thu Jan 29 14:48:58 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:37:EA:4C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=100683d9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Thu Jan 29 14:49:05 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
    [Thu Jan 29 14:49:05 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
    [Thu Jan 29 14:49:09 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
    Show mounted filesystems:
    TARGET   SOURCE    FSTYPE OPTIONS
    /        /dev/sda2 ext4   rw,noatime
    `-/boot/firmware
             /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iochars
    /var:
    2.5G    /var/
    237M    /var/cache
    231M    /var/cache/apt
    177M    /var/lib
    145M    /var/lib/apt
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    8.9M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    219M    /opt/iobroker/iobroker-data/
    171M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    25M     /opt/iobroker/iobroker-data/objects.jsonl
    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
    USB-Devices by-id:
    /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D200ZYDG-if00-port0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    martinpi            martinpi (version: 7.0.7, hostname: martinpi      , alive, uptime: 183)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
    + system.adapter.accuweather.0            : accuweather           : martinpi                                 -  enabled
    + system.adapter.admin.0                  : admin                 : martinpi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alpha-ess.0              : alpha-ess             : martinpi                                 -  enabled
    + system.adapter.backitup.0               : backitup              : martinpi                                 -  enabled
      system.adapter.bmw.0                    : bmw                   : martinpi                                 - disabled
    + system.adapter.device-reminder.0        : device-reminder       : martinpi                                 -  enabled
    + system.adapter.discovery.0              : discovery             : martinpi                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: martinpi                                 -  enabled
    + system.adapter.fiat.0                   : fiat                  : martinpi                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : martinpi                                 -  enabled
    + system.adapter.go-e.0                   : go-e                  : martinpi                                 -  enabled
      system.adapter.habpanel.0               : habpanel              : martinpi                                 - disabled
      system.adapter.ham.0                    : ham                   : martinpi                                 -  enabled
      system.adapter.ham.1                    : ham                   : martinpi                                 -  enabled
    + system.adapter.history.0                : history               : martinpi                                 -  enabled
    + system.adapter.homepilot.0              : homepilot             : martinpi                                 -  enabled
    + system.adapter.javascript.0             : javascript            : martinpi                                 -  enabled
      system.adapter.modbus.0                 : modbus                : martinpi                                 - disabled
      system.adapter.modbus.1                 : modbus                : martinpi                                 - disabled
    + system.adapter.mqtt.0                   : mqtt                  : martinpi                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.1                   : mqtt                  : martinpi                                 -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.mqtt.2                   : mqtt                  : martinpi                                 - disabled, port: 9000, bind: 0.0.0.0
    + system.adapter.philips-air.0            : philips-air           : martinpi                                 -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : martinpi                                 -  enabled
      system.adapter.radar2.0                 : radar2                : martinpi                                 - disabled
    + system.adapter.smartmeter.0             : smartmeter            : martinpi                                 -  enabled
    + system.adapter.sonoff.0                 : sonoff                : martinpi                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.tuya.0                   : tuya                  : martinpi                                 -  enabled
      system.adapter.viessmannapi.0           : viessmannapi          : martinpi                                 - disabled
    + system.adapter.web.0                    : web                   : martinpi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "bmw"          : 4.3.2    , installed 4.3.2
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "fiat"         : 0.0.8    , installed 0.0.8
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "go-e"         : 1.0.41   , installed 1.0.41
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "homepilot"    : 1.2.3    , installed 1.2.3
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
    Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        8733
    States:         8061
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
    Reading package lists... Done
    Pending Updates: 31
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9321       1103/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29810      1/init
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       54218      13539/io.sonoff.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54688      12689/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       52196      12689/iobroker.js-c
    tcp6       0      0 :::22                   :::*                    LISTEN      0          9323       1103/sshd: /usr/sbi
    tcp6       0      0 :::111                  :::*                    LISTEN      0          28302      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54809      12725/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57473      13852/io.web.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28300      1/init
    udp        0      0 0.0.0.0:33785           0.0.0.0:*                           1001       54198      13405/io.philips-ai
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5853       610/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       58372      13613/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       58373      13613/io.tuya.0
    udp        0      0 0.0.0.0:56443           0.0.0.0:*                           101        5855       610/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          28820      1/init
    udp6       0      0 fe80::da3a:ddff:fe3:546 :::*                                0          7074       678/NetworkManager
    udp6       0      0 :::5353                 :::*                                101        5854       610/avahi-daemon: r
    udp6       0      0 :::60941                :::*                                101        5856       610/avahi-daemon: r
    2026-01-30 08:18:52.789  - info: smartmeter.0 (13465) Received 4 values, 0 updated
    2026-01-30 08:18:55.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
    2026-01-30 08:18:59.429  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
    2026-01-30 08:19:03.786  - info: smartmeter.0 (13465) Received 4 values, 0 updated
    2026-01-30 08:19:04.055  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimem" has value "1769757544038" greater than max "2147483648"
    2026-01-30 08:19:04.170  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimed" has value "1769757544169" greater than max "2147483648"
    2026-01-30 08:19:04.406  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimem" has value "1769757544399" greater than max "2147483648"
    2026-01-30 08:19:04.519  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimed" has value "1769757544518" greater than max "2147483648"
    2026-01-30 08:19:07.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
    2026-01-30 08:19:09.390  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
    2026-01-30 08:19:14.788  - info: smartmeter.0 (13465) Received 4 values, 0 updated
    2026-01-30 08:19:19.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
    2026-01-30 08:19:19.451  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
    2026-01-30 08:19:25.789  - info: smartmeter.0 (13465) Received 4 values, 0 updated
    2026-01-30 08:19:29.437  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
    2026-01-30 08:19:31.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
    2026-01-30 08:19:34.223  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimem" has value "1769757574218" greater than max "2147483648"
    2026-01-30 08:19:34.325  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimed" has value "1769757574324" greater than max "2147483648"
    2026-01-30 08:19:34.537  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimem" has value "1769757574532" greater than max "2147483648"
    2026-01-30 08:19:34.636  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimed" has value "1769757574636" greater than max "2147483648"
    2026-01-30 08:19:36.788  - info: smartmeter.0 (13465) Received 4 values, 0 updated
    2026-01-30 08:19:39.430  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
    2026-01-30 08:19:43.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
    2026-01-30 08:19:47.784  - info: smartmeter.0 (13465) Received 4 values, 0 updated
    2026-01-30 08:19:49.441  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
    Wie lange es genau gedauert hat kann ich nicht sagen, da ich nach dem Einspielen des backups vom Rechner weggegangen bin (hat mir zu lange gedauert bis alle Adapter wieder gelaufen sind). Heute früh war alles paletti.
    crunchipC Offline
    crunchipC Offline
    @mattle1957 sagte in Adapter läuft nicht mehr:
    • system.adapter.mqtt.1 : mqtt : martinpi - enabled, port: 1883, bind: 0.0.0.0
    • system.adapter.sonoff.0 : sonoff : martinpi - enabled, port: 1883, bind: 0.0.0.0
    solltest mal deine Ports überdenken, das passt so nicht
      mattle1957
      @ crunchip : die Ports passen. Nur mit diesen funktioniert es.
      • M mattle1957
        das sind zwei unterschiedliche Aussagen!
        passend sind die Ports definitiv nicht.
        Es können nicht 2 Instanzen auf dem selben Port lauschen.
        Dass es nur so "funktioniert" wird an der falschen Konfiguration der Endgeräte liegen
          mattle1957
          die Ports stehen doch in Verbindung mit der URL und die ist unterschiedlich!
          crunchipC HomoranH 2 Antworten Letzte Antwort
          • M mattle1957
            crunchipC Offline
            crunchipC Offline
            die da wäre?
            IP:Port und du hast mqtt und sonoff auf dem selben Port laufen
            • M mattle1957
              dein Raspi hat verschiedene IPs?
              • crunchipC Offline
                crunchipC Offline
                ich denke er hat noch nen externen mqtt laufen und seinen mqtt Adapter als client, is trotzdem falsch konfiguriert
                  mattle1957
                  @Homoran
                  Nein, aber die darauf laufenden Adapter greifen auf verschiedene IP's und dem zugehörigen Port zu.
                  HomoranH crunchipC 2 Antworten Letzte Antwort
                  • M mattle1957
                    @Homoran
                    nöö!
                    die Geräte greifen auf den selben Port drines Raspi zu.
                    • M mattle1957
                      @Homoran
                      crunchipC Offline
                      crunchipC Offline
