  4. Adapter läuft nicht mehr
    6.0k
23 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
    mattle1957
    Mache ich dann später noch! Nochmals vielen Dank für die hervorragende Unterstützung!
    • M mattle1957
      Das iob diag sieht jetzt folgendermaßen aus:
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: martinpi
             Icon name: computer
                Kernel: Linux 6.12.47+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       08:18:51 up 17:29,  1 user,  load average: 2.77, 3.34, 1.77
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Fri 2026-01-30 08:18:51 CET
                 Universal time: Fri 2026-01-30 07:18:51 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/pi
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Mem:            8.2G        1.9G        3.0G         12M        3.4G        6.3G
      Swap:           2.1G          0B        2.1G
      Total:           10G        1.9G        5.1G
      Active iob-Instances:   22
               7819 M total memory
               1822 M used memory
               1757 M active memory
               2819 M inactive memory
               2850 M free memory
                188 M buffer memory
               3070 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      top - 08:18:52 up 17:29,  1 user,  load average: 2.77, 3.34, 1.77
      Tasks: 213 total,   3 running, 210 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 60.4 us,  9.4 sy,  0.0 ni, 28.3 id,  0.0 wa,  0.0 hi,  1.9 si,  0.0 st
      MiB Mem :   7819.7 total,   2887.9 free,   1784.8 used,   3258.7 buff/cache
      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   6034.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     1.6G  9.3M  1.6G   1% /run
      /dev/sda2      ext4      9.8G  6.2G  3.3G  66% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     3.9G  2.8M  3.9G   1% /tmp
      /dev/sda1      vfat      510M   74M  437M  15% /boot/firmware
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
      tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
      [Thu Jan 29 14:48:58 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=D8:3A:DD:37:EA:4C vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=100683d9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Thu Jan 29 14:49:05 2026] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Thu Jan 29 14:49:05 2026] EXT4-fs (sda2): mounted filesystem 21724cc6-e5a3-48a1-8643-7917dba3a9fb ro with ordered data mode. Quota mode: none.
      [Thu Jan 29 14:49:09 2026] EXT4-fs (sda2): re-mounted 21724cc6-e5a3-48a1-8643-7917dba3a9fb r/w.
      Show mounted filesystems:
      TARGET   SOURCE    FSTYPE OPTIONS
      /        /dev/sda2 ext4   rw,noatime
      `-/boot/firmware
               /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iochars
      /var:
      2.5G    /var/
      237M    /var/cache
      231M    /var/cache/apt
      177M    /var/lib
      145M    /var/lib/apt
      Archived and active journals take up 8M in the file system.
      /opt/iobroker/backups:
      8.9M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      219M    /opt/iobroker/iobroker-data/
      171M    /opt/iobroker/iobroker-data/files
      47M     /opt/iobroker/iobroker-data/files/admin.admin
      46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
      7.2M    /opt/iobroker/iobroker-data/files/ham.admin/static/js/main.8080bc0b.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D200ZYDG-if00-port0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.0
      /usr/bin/node           v22.22.0
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      /usr/bin/corepack       0.34.0
      nodejs:
        Installed: 22.22.0-1nodesource1
        Candidate: 22.22.0-1nodesource1
        Version table:
       *** 22.22.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      martinpi            martinpi (version: 7.0.7, hostname: martinpi      , alive, uptime: 183)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.22
      javascript:     9.0.11
      nodejs modules from github:     0
      Adapter State
      + system.adapter.accuweather.0            : accuweather           : martinpi                                 -  enabled
      + system.adapter.admin.0                  : admin                 : martinpi                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alpha-ess.0              : alpha-ess             : martinpi                                 -  enabled
      + system.adapter.backitup.0               : backitup              : martinpi                                 -  enabled
        system.adapter.bmw.0                    : bmw                   : martinpi                                 - disabled
      + system.adapter.device-reminder.0        : device-reminder       : martinpi                                 -  enabled
      + system.adapter.discovery.0              : discovery             : martinpi                                 -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: martinpi                                 -  enabled
      + system.adapter.fiat.0                   : fiat                  : martinpi                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : martinpi                                 -  enabled
      + system.adapter.go-e.0                   : go-e                  : martinpi                                 -  enabled
        system.adapter.habpanel.0               : habpanel              : martinpi                                 - disabled
        system.adapter.ham.0                    : ham                   : martinpi                                 -  enabled
        system.adapter.ham.1                    : ham                   : martinpi                                 -  enabled
      + system.adapter.history.0                : history               : martinpi                                 -  enabled
      + system.adapter.homepilot.0              : homepilot             : martinpi                                 -  enabled
      + system.adapter.javascript.0             : javascript            : martinpi                                 -  enabled
        system.adapter.modbus.0                 : modbus                : martinpi                                 - disabled
        system.adapter.modbus.1                 : modbus                : martinpi                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : martinpi                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : martinpi                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.2                   : mqtt                  : martinpi                                 - disabled, port: 9000, bind: 0.0.0.0
      + system.adapter.philips-air.0            : philips-air           : martinpi                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : martinpi                                 -  enabled
        system.adapter.radar2.0                 : radar2                : martinpi                                 - disabled
      + system.adapter.smartmeter.0             : smartmeter            : martinpi                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : martinpi                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tuya.0                   : tuya                  : martinpi                                 -  enabled
        system.adapter.viessmannapi.0           : viessmannapi          : martinpi                                 - disabled
      + system.adapter.web.0                    : web                   : martinpi                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "accuweather"  : 2.1.1    , installed 2.1.1
      Adapter    "admin"        : 7.7.22   , installed 7.7.22
      Adapter    "alpha-ess"    : 3.0.1    , installed 3.0.1
      Adapter    "backitup"     : 3.3.13   , installed 3.3.13
      Adapter    "bmw"          : 4.3.2    , installed 4.3.2
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
      Adapter    "fiat"         : 0.0.8    , installed 0.0.8
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "go-e"         : 1.0.41   , installed 1.0.41
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "homepilot"    : 1.2.3    , installed 1.2.3
      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
      Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects:        8733
      States:         8061
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
      Hit:5 http://archive.raspberrypi.com/debian trixie InRelease
      Reading package lists... Done
      Pending Updates: 31
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9321       1103/sshd: /usr/sbi
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29810      1/init
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       54218      13539/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       54688      12689/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       52196      12689/iobroker.js-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          9323       1103/sshd: /usr/sbi
      tcp6       0      0 :::111                  :::*                    LISTEN      0          28302      1/init
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       54809      12725/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       57473      13852/io.web.0
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          28300      1/init
      udp        0      0 0.0.0.0:33785           0.0.0.0:*                           1001       54198      13405/io.philips-ai
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        5853       610/avahi-daemon: r
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       58372      13613/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       58373      13613/io.tuya.0
      udp        0      0 0.0.0.0:56443           0.0.0.0:*                           101        5855       610/avahi-daemon: r
      udp6       0      0 :::111                  :::*                                0          28820      1/init
      udp6       0      0 fe80::da3a:ddff:fe3:546 :::*                                0          7074       678/NetworkManager
      udp6       0      0 :::5353                 :::*                                101        5854       610/avahi-daemon: r
      udp6       0      0 :::60941                :::*                                101        5856       610/avahi-daemon: r
      2026-01-30 08:18:52.789  - info: smartmeter.0 (13465) Received 4 values, 0 updated
      2026-01-30 08:18:55.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
      2026-01-30 08:18:59.429  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
      2026-01-30 08:19:03.786  - info: smartmeter.0 (13465) Received 4 values, 0 updated
      2026-01-30 08:19:04.055  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimem" has value "1769757544038" greater than max "2147483648"
      2026-01-30 08:19:04.170  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimed" has value "1769757544169" greater than max "2147483648"
      2026-01-30 08:19:04.406  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimem" has value "1769757544399" greater than max "2147483648"
      2026-01-30 08:19:04.519  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimed" has value "1769757544518" greater than max "2147483648"
      2026-01-30 08:19:07.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
      2026-01-30 08:19:09.390  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
      2026-01-30 08:19:14.788  - info: smartmeter.0 (13465) Received 4 values, 0 updated
      2026-01-30 08:19:19.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
      2026-01-30 08:19:19.451  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
      2026-01-30 08:19:25.789  - info: smartmeter.0 (13465) Received 4 values, 0 updated
      2026-01-30 08:19:29.437  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
      2026-01-30 08:19:31.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
      2026-01-30 08:19:34.223  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimem" has value "1769757574218" greater than max "2147483648"
      2026-01-30 08:19:34.325  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300188482.energy_stats.datatimed" has value "1769757574324" greater than max "2147483648"
      2026-01-30 08:19:34.537  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimem" has value "1769757574532" greater than max "2147483648"
      2026-01-30 08:19:34.636  - warn: fritzdect.0 (13770) State value to set for "fritzdect.0.DECT_116300450036.energy_stats.datatimed" has value "1769757574636" greater than max "2147483648"
      2026-01-30 08:19:36.788  - info: smartmeter.0 (13465) Received 4 values, 0 updated
      2026-01-30 08:19:39.430  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
      2026-01-30 08:19:43.052  - warn: homepilot.0 (12903) Cannot connect to Homepilot: Error: connect EHOSTUNREACH 192.168.2.15:80
      2026-01-30 08:19:47.784  - info: smartmeter.0 (13465) Received 4 values, 0 updated
      2026-01-30 08:19:49.441  - info: device-reminder.0 (13663) State value to set for "device-reminder.0.HP Drucker.live consumption" has to be type "number" but received type "string"
      Wie lange es genau gedauert hat kann ich nicht sagen, da ich nach dem Einspielen des backups vom Rechner weggegangen bin (hat mir zu lange gedauert bis alle Adapter wieder gelaufen sind). Heute früh war alles paletti.
      @mattle1957 sagte in Adapter läuft nicht mehr:
      wenn du nicht gegen 08:13 irgendwas größeres am iobroker gespielt hast, ist der Pi möglicherweise an seiner Leistungsgrenze.
      Oder sieh mal im log nach was da war, das log im diag reicht nicht soweit zurück.
      Allerdings sind da innerhalb 2 Min. genug Dinge drin, die du fixen solltest
        mattle1957
        Ich muss sowieso den einen oder anderen Adapter den ich nicht mehr benötige, rausschmeissen. Dann sollte der Pi wieder passen. Sonst muss ich den mal auf einen 5er mit mehr RAM aufrüsten.
        Man installiert doch mal einfach einen Adapter und merkt später dass man ihn nicht benötigt.
        • M mattle1957
          es geht um den load average, nicht um RAM!
          die load average geht an die Grenze und sinkt anschließend auf ein deutlich niedrigeren Wert, der auch vorher existierte.
          Also ist da etwas, was nicht rund läuft.
          Natürlich kann man sich, wenn man mit platten Reifen nicht nehr so dchnell vorankommt auch rinen stärkeren Motor einbauen lassen, anstelle den Reifen aufzupumpen.
          • M mattle1957
            Script v.2025-08-09
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            SUDO_HOME=/home/pi
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           2.1G          0B        2.1G
                     7819 M total memory
                     1822 M used memory
                     2850 M free memory
                      188 M buffer memory
                     3070 M swap cache
                     2047 M total swap
                        0 M used swap
                     2047 M free swap
            *** FILESYSTEM ***
            `-/boot/firmware
            /var:
            2.5G    /var/
            237M    /var/cache
            231M    /var/cache/apt
            177M    /var/lib
            145M    /var/lib/apt
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
                 20.19.2+dfsg-1 500
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.22
            javascript:     9.0.11
            Adapter State
            + instance is alive
            Objects and States
            Objects:        8733
            States:         8061
            Pending Updates: 31
            crunchipC Offline
            crunchipC Offline
            • system.adapter.mqtt.1 : mqtt : martinpi - enabled, port: 1883, bind: 0.0.0.0
            • system.adapter.sonoff.0 : sonoff : martinpi - enabled, port: 1883, bind: 0.0.0.0
            solltest mal deine Ports überdenken, das passt so nicht
              mattle1957
              @ crunchip : die Ports passen. Nur mit diesen funktioniert es.
              • M mattle1957
                das sind zwei unterschiedliche Aussagen!
                passend sind die Ports definitiv nicht.
                Es können nicht 2 Instanzen auf dem selben Port lauschen.
                Dass es nur so "funktioniert" wird an der falschen Konfiguration der Endgeräte liegen
                  mattle1957
                  die Ports stehen doch in Verbindung mit der URL und die ist unterschiedlich!
                  crunchipC HomoranH 2 Antworten Letzte Antwort
                  • M mattle1957
                    crunchipC Offline
                    crunchipC Offline
                    die da wäre?
                    IP:Port und du hast mqtt und sonoff auf dem selben Port laufen
                    • M mattle1957
                      dein Raspi hat verschiedene IPs?
                      • crunchipC Offline
                        crunchipC Offline
                        ich denke er hat noch nen externen mqtt laufen und seinen mqtt Adapter als client, is trotzdem falsch konfiguriert
                          mattle1957
                          @Homoran
                          Nein, aber die darauf laufenden Adapter greifen auf verschiedene IP's und dem zugehörigen Port zu.
                          HomoranH crunchipC 2 Antworten Letzte Antwort
                          • M mattle1957
                            @Homoran
                            nöö!
                            die Geräte greifen auf den selben Port drines Raspi zu.
                            • M mattle1957
                              @Homoran
                              crunchipC Offline
                              crunchipC Offline
