  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Zigbee Adapter zeigt bei Sonoff Plug keine Energiewerte
    6.4k
71 Beiträge 12 Kommentatoren 5.5k Aufrufe 12 Beobachtet
  • nograxN Online
    nograxN Online
    nograx
    Moin, ich habe auch 2 dieser Plugs im Einsatz. Bei mir werden auch keine Leistungsdaten angezeigt, bzw. die Werte stehen immer auf 0. Adapterversion ist die 3.3.4. im Debug des Devices steht folgendes:
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I04 (712c) value generated '0' from device a4c138082522ffff for 'Active power'
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I03 (712c) message received '{"power":0}' from device a4c138082522ffff type 'S60ZBTPF'
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I02.8c (712c) candidates: [{},{},{"power":0},{},{},{},{},{}] => payload {"power":0}
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I02.7b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I02.8a (712c) converter 8 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I02.6b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.864	warn	ELEVATED:I02.7a (712c) converter 7 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.5b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.6a (712c) converter 6 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.4b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.5a (712c) converter 5 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.3b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.4a (712c) converter 4 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.2b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:{"power":0}
    zigbee.0
    2026-01-29 08:01:18.863	warn	ELEVATED:I02.3a (712c) converter 3 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.862	warn	ELEVATED:I02.1b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.862	warn	ELEVATED:I02.2a (712c) converter 2 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.862	warn	ELEVATED:I02.0b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
    zigbee.0
    2026-01-29 08:01:18.861	warn	ELEVATED:I02.1a (712c) converter 1 : Cluster customClusterEwelink
    zigbee.0
    2026-01-29 08:01:18.861	warn	ELEVATED:I02 (712c) 8 converters available for 'S60ZBTPF' 'a4c138082522ffff' with cluster 'customClusterEwelink' and type 'attributeReport'
    zigbee.0
    2026-01-29 08:01:18.860	warn	ELEVATED:I04 (712c) value generated '51' from device a4c138082522ffff for 'Link quality'
    zigbee.0
    2026-01-29 08:01:18.764	warn	ELEVATED:I01 (712c) Zigbee Event of Type attributeReport from device 0xa4c138082522ffff, incoming event: {"type":"attributeReport","data":{"acCurrentPowerValue":72879},"linkquality":51,"groupID":0,"cluster":"customClusterEwelink","meta":{"rawData":{"type":"Buffer","data":[24,6,10,6,112,35,175,28,1,0]},"zclTransactionSequenceNumber":6,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      Bitte die Steckdose über die Oberfläche neu konfigurieren. Das sieht sehr danach aus das bestimmte Faktoren die zur Umrechnung benötigt sind im Konverter nicht vorhanden sind - diese werden üblicherweise bei der Konfiguration des Gerätes gesetzt / bestimmt.
      Ansonsten deutet das Verhalten auf ein Problem im Converter hin:
      zigbee.0 2026-01-29 08:01:18.863	warn	ELEVATED:I02.2b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:{"power":0}
      Daraus ist zu ersehen das der Konverter basierend auf der Meldung des Gerätes den Wert 0 zurück liefert. Das ist demnach ein Thema für die zigbee-herdsman-converters - da kann der Zigbee Adapter wenig bis nichts tun.
      Ich kann dem ohne Zugang auf entsprechende Geräte mit dem Debugger nicht weiter nachgehen.
      A.
      Nachtrag: Ist das lesen und Anpassen der Ausgaben zur Lesbarkeit wirklich so schwer ? Hier mal ein (3 Zeiliger) Ausdruck des Logs oben - mit minimalen Anpassungen damit man das besser lesen kann.
      zigbee.0 2026-01-29 08:01:18.862	warn	ELEVATED:I02.1b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
      zigbee.0 2026-01-29 08:01:18.862	warn	ELEVATED:I02.2a (712c) converter 2 : Cluster customClusterEwelink
      zigbee.0 2026-01-29 08:01:18.862	warn	ELEVATED:I02.0b (712c) data: {"acCurrentPowerValue":72879} options: {} meta:{"deviceIEEE":"0xa4c138082522ffff","logger":"StatesController","state":{"state":""}} result:undefined
      zigbee.0 2026-01-29 08:01:18.861	warn	ELEVATED:I02.1a (712c) converter 1 : Cluster customClusterEwelink
      Nachtrag 2:
      Anstatt diese Meldungen aus dem normalen ioBroker protokoll zu holen kann man die (sauber fürs Forum aufbereitet, incl. code tags) über das Debug Interface des Adapters beziehen - Doku dazu siehe hier: https://github.com/ioBroker/ioBroker.zigbee/wiki/Device-messaging-debug
      • nograxN Online
        nograxN Online
        nograx
        @asgothian Sorry das war das erste Mal das ich hier dazu ein Log poste. Ich gelobe Besserung.
        Tatsächlich hat das Reconfigure bzw. löschen und neu hinzufügen nichts gebracht. Würde es helfen wenn ich dir noch entsprechende Logs zur Verfügung stelle? Wenn ja wie?
        WinniW AsgothianA 2 Antworten Letzte Antwort
        • nograxN nograx
          WinniW Offline
          WinniW Offline
          Winni
          @nograx sagte in Zigbee Adapter zeigt bei Sonoff Plug keine Energiewerte:
          Ich hatte das gleiche Problem bei einer von zwei dieser Dosen. Was bei mir geholfen hat war folgendes: Die Dose vom Strom nehmen, den Ein/Ausschaltknopf gedrückt halten, dann einstecken und warten bis die LED blinkt. Dann mit dem Adapter suchen lassen. Anschließend waren alle Werte da.
          nograxN 1 Antwort Letzte Antwort
          • WinniW Winni
            nograxN Online
            nograxN Online
            nograx
            schrieb am zuletzt editiert von nograx
            @Winni Die kumulierten Werte sind da, nur die momentane Leistung steht auf 0 obwohl das angeschlossene Gerät eingeschaltet ist und definitiv Strom verbraucht.
            Habe den Adapter schon neugestartet, den Plug entfernt, neu hinzugefügt. O.g. Methode brachte ebenfalls keine Änderung.
            • WinniW Offline
              WinniW Offline
              Winni
              Tut mir leid, dass es bei dir nicht funktioniert hat. Bei mir wird es normal angezeigt.
              • nograxN Online
                nograxN Online
                nograx
                Also wenn ich das richtige sehe kommen ja Werte an, werden nur nicht verarbeitet.
                Ich nehme an das die 72879 -> 72W sind...
                • nograxN nograx
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  Aktuell leider nein.
                  Das Log zeigt:
                  • die Steckdose meldet Werte (data: {"acCurrentPowerValue":72879}
                  • von den 8 Convertern die diese Werte für den Zigbee Adapter aufbereiten konvertiert auch einer diese Werte (candidates: [{},{},{"power":0},{},{},{},{},{}] => payload {"power":0})
                  • Der Adapter wählt auch korrekterweise den aus der einen gültigen Payload (mit Inhalt) liefert.
                  Diese Umwandlung findet in einer externen Bibliothek statt (Zigbee-Herdsman-Converters). Um heraus zu finden was da schief geht müsste ich mit einem Debugger durch gehen und so eine Meldung bekommen - das ist ohne Gerät nicht trivial.
                  A.
                  • nograxN Online
                    nograxN Online
                    nograx
                    Interessant ist es ja das es bei @Winni offensichtlich funktioniert.
                    • nograxN nograx
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      Da stellt sich die Frage (n):
                      • welche Adapter Version setzt @Winni ein ?
                      • welche ZHC Version ist da mit dabei (steht auf der Kachel des Koordinators) ?
                      • Was melden seine Steckdosen ?
                      • Sind es wirklich die gleichen (Gleiche Firmware, etc.)
                      A.
                      WinniW 1 Antwort Letzte Antwort
                      • nograxN Online
                        nograxN Online
                        nograx
                        Bei mir:
                        Adapter:3.3.4
                        Installed:iobroker.zigbee@3.3.4
                        Herdsman:8.1.0
                        Converters:25.112.0
                        Plug:
                        model:S60ZBTPF
                        Firmware:
                        -> date code:20250411
                        -> build:1.0.2
                        AsgothianA HomoranH 2 Antworten Letzte Antwort
                        • nograxN nograx
                          Bei mir:
                          Adapter:3.3.4
                          Herdsman:8.1.0
                          Converters:25.112.0
                          Plug:
                          model:S60ZBTPF
                          Firmware:
                          -> build:1.0.2
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          Firmware?
                          Steht auf der Info-Seite der Steckdose (meistens)
                          • nograxN nograx
                            Bei mir:
                            Adapter:3.3.4
                            Herdsman:8.1.0
                            Converters:25.112.0
                            Plug:
                            model:S60ZBTPF
                            Firmware:
                            -> build:1.0.2
                            Firmware?
                            steht nix auf der Rückseite der Kachel?
                            • nograxN Online
                              nograxN Online
                              nograx
                              nwk:25461 (0x6375) <- Ist das die Firmware?
                              Auf der Hauptseite steht noch:
                              date code:20250411
                              build:1.0.2
                              • nograxN nograx
                                date code:20250411
                                build:1.0.2
                                date code:20250411
                                build:1.0.2
                                das ist es
                                • nograxN Online
                                  nograxN Online
                                  nograx
                                  So wie ich das sehe gibt es das Problem auch bei HA und zigbee2mqtt:
                                  https://github.com/Koenkk/zigbee2mqtt/issues/29564
                                  https://github.com/home-assistant/core/issues/158061
                                  • nograxN nograx
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    Das deckt sich mit meiner Aussage das der Konverter die ursache des problems ist.
                                    ZHA und zigbee2mqtt nutzen auch die ZHC Bibliothek.
                                    A.
                                    • AsgothianA Asgothian
                                      A.
                                      WinniW Offline
                                      WinniW Offline
                                      Winni
                                      @Asgothian Hallo, das ist die Kachel von meinem Koordinator
                                      • nograxN Online
                                        nograxN Online
                                        nograx
                                        @Winni @Asgothian Habe mir mal gerade die 3.1.5 installiert, dann werden mir die Leistungswerte auch angezeigt:
                                          basty2
                                          Hallo, leider habe ich das gleiche Problem. Bei mir wird Power nicht richtig umgewandelt. ELEVATED:I02.2b (bdb9) data: {"acCurrentPowerValue":4924} options: {} meta:{"deviceIEEE":"xyz","logger":"StatesController","state":{"state":""}} result:{"power":0}
