  4. [gelöst] ioBroker auf PI4 stürzt immer mal wieder ab
    6.4k
58 Beiträge 7 Kommentatoren 3.0k Aufrufe 8 Beobachtet
  • K Kapitaen31
    @Homoran sagte in ioBroker auf PI4 stürzt immer mal wieder ab:
    @Kapitaen31 sagte in ioBroker auf PI4 stürzt immer mal wieder ab:
    habe ich gemacht
    auch alle offenen Updates und die Repos angepasst?
    dann zeig mal ein aktuelles iob diag
    All good habe ich schon gelesen.
    bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: PIArgon
           Icon name: computer
              Kernel: Linux 6.12.62+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     17:01:26 up 15 min,  2 users,  load average: 0.92, 0.75, 0.83
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2026-01-28 17:01:26 CET
               Universal time: Wed 2026-01-28 16:01:26 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    PI
    HOME=/home/PI
    GROUPS=PI adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        2.9G        372M        221K        785M        1.1G
    Swap:           209M        2.6M        207M
    Total:          4.2G        2.9G        579M
    Active iob-Instances:   26
             3789 M total memory
             2761 M used memory
             1816 M active memory
             1445 M inactive memory
              355 M free memory
               82 M buffer memory
              667 M swap cache
              199 M total swap
                2 M used swap
              197 M free swap
    top - 17:01:27 up 15 min,  2 users,  load average: 0.92, 0.75, 0.83
    Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3789.8 total,    354.1 free,   2762.1 used,    749.8 buff/cache
    MiB Swap:    200.0 total,    197.5 free,      2.5 used.   1027.8 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     758M  1.2M  757M   1% /run
    /dev/sda2      ext4      110G   22G   83G  21% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     379M     0  379M   0% /run/user/1000
    [Wed Jan 28 16:45:32 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=1 system_heap.max_order=0 smsc95xx.macaddr=E4:5F:01:FE:0B:37 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=9afaab09-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Wed Jan 28 16:45:36 2026] EXT4-fs (sda2): mounted filesystem 3b614a3f-4a65-4480-876a-8a998e01ac9b ro with ordered data mode. Quota mode: none.
    [Wed Jan 28 16:45:43 2026] EXT4-fs (sda2): re-mounted 3b614a3f-4a65-4480-876a-8a998e01ac9b r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    4.1G    /var/
    1.9G    /var/log/journal/3a228e6261a14b389cf6e2129be3286a
    1.9G    /var/log
    1.2G    /var/lib
    Archived and active journals take up 1.8G in the file system.
    /opt/iobroker/backups:
    9.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    420M    /opt/iobroker/iobroker-data/
    326M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    71M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    6.1M    /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.0
    /usr/bin/node           v22.22.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.22.0-1nodesource1
      Candidate: 22.22.0-1nodesource1
      Version table:
     *** 22.22.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    PIArgon             PIArgon (version: 7.0.7, hostname: PIArgon       , alive, uptime: 936)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.11
    nodejs modules from github:     1
    +-- iobroker.apsystems-ecu@0.2.9 (git+ssh://git@github.com/npeter/iobroker.apsystems-ecu.git#c737ed3ce633041d6adb0494830458a2676c8062)
    Adapter State
    + system.adapter.admin.0                  : admin                 : PIArgon                                  -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : PIArgon                                  - disabled
    + system.adapter.apsystems-ecu.0          : apsystems-ecu         : PIArgon                                  -  enabled
    + system.adapter.backitup.0               : backitup              : PIArgon                                  -  enabled
      system.adapter.daswetter.0              : daswetter             : PIArgon                                  -  enabled
    + system.adapter.discovery.0              : discovery             : PIArgon                                  -  enabled
      system.adapter.dwd.0                    : dwd                   : PIArgon                                  -  enabled
      system.adapter.flot.0                   : flot                  : PIArgon                                  - disabled
    + system.adapter.fritzdect.0              : fritzdect             : PIArgon                                  -  enabled
    + system.adapter.history.0                : history               : PIArgon                                  -  enabled
    + system.adapter.hue.0                    : hue                   : PIArgon                                  -  enabled, port: 443
      system.adapter.icons-icons8.0           : icons-icons8          : PIArgon                                  - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : PIArgon                                  -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: PIArgon                                  - disabled
    + system.adapter.influxdb.0               : influxdb              : PIArgon                                  -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : PIArgon                                  -  enabled
    + system.adapter.lovelace.0               : lovelace              : PIArgon                                  -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : PIArgon                                  -  enabled, port: 1886, bind: 0.0.0.0
    + system.adapter.nina.0                   : nina                  : PIArgon                                  -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : PIArgon                                  -  enabled
    + system.adapter.pushover.0               : pushover              : PIArgon                                  -  enabled
    + system.adapter.pvforecast.0             : pvforecast            : PIArgon                                  -  enabled
    + system.adapter.radar2.0                 : radar2                : PIArgon                                  -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : PIArgon                                  -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : PIArgon                                  -  enabled
    + system.adapter.sonoff.0                 : sonoff                : PIArgon                                  -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.systeminfo.0             : systeminfo            : PIArgon                                  -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : PIArgon                                  -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : PIArgon                                  - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PIArgon                                  - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : PIArgon                                  - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : PIArgon                                  -  enabled
      system.adapter.vis-jsontemplate.0       : vis-jsontemplate      : PIArgon                                  -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : PIArgon                                  -  enabled
      system.adapter.vis-material.0           : vis-material          : PIArgon                                  -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : PIArgon                                  -  enabled
      system.adapter.vis-metro.0              : vis-metro             : PIArgon                                  - disabled
      system.adapter.vis.0                    : vis                   : PIArgon                                  -  enabled
    + system.adapter.web.0                    : web                   : PIArgon                                  -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : PIArgon                                  -  enabled
      system.adapter.yr.0                     : yr                    : PIArgon                                  -  enabled
    + system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : PIArgon                                  -  enabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lovelace"     : 5.0.5    , installed 5.0.5
    Adapter    "nina"         : 0.0.25   , installed 0.0.25
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
    Adapter    "radar2"       : 2.4.0    , installed 2.4.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "rssfeed"      : 3.6.1    , installed 3.6.1
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-jsontemplate": 4.2.0 , installed 4.2.0
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee2mqtt"  : 3.0.10   , installed 3.0.9  [Updatable]
    Objects and States
    Objects:        15413
    States:         14143
    W: GPG error: https://repos.influxdata.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY DA61C26A0585BD3B
    E: The repository 'https://repos.influxdata.com/debian stable InRelease' is not signed.
    W: GPG error: https://apt.grafana.com stable InRelease: The following signatures were invalid: EXPKEYSIG 963FA27710458545 Grafana Labs <engineering@grafana.com>
    E: The repository 'https://apt.grafana.com stable InRelease' is not signed.
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       9270       1038/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       9269       1038/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       7623       1083/io.sonoff.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       6950       841/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       614        841/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6002       694/sshd: /usr/sbin
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7188       764/influxd
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       9712       1315/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       684        883/io.admin.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1001       8891       1421/io.lovelace.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          6004       694/sshd: /usr/sbin
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        6111       840/grafana
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       7759       1154/io.radar2.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        428        566/avahi-daemon: r
    udp        0      0 0.0.0.0:58629           0.0.0.0:*                           104        430        566/avahi-daemon: r
    udp6       0      0 :::59606                :::*                                104        431        566/avahi-daemon: r
    udp6       0      0 fe80::18e0:ffba:1eb:546 :::*                                0          6046       613/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        429        566/avahi-daemon: r
    2026-01-28 16:52:21.071  - warn: sonoff.0 (1083) Old client Luefter2_49E5CD with secret 1769615266109_8169 sends publish. Ignore! Actual secret is 1769615518529_2885
    2026-01-28 16:52:46.872  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:25
    2026-01-28 16:53:16.873  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:30
    2026-01-28 16:53:46.874  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:35
    2026-01-28 16:54:16.874  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:40
    2026-01-28 16:54:46.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:45
    2026-01-28 16:55:16.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:50
    2026-01-28 16:55:38.026  - info: host.PIArgon instance system.adapter.dwd.0 in version "2.8.5" started with pid 1791
    2026-01-28 16:55:42.192  - info: host.PIArgon instance system.adapter.dwd.0 having pid 1791 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-01-28 16:55:46.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:55
    2026-01-28 16:56:16.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:60
    2026-01-28 16:56:46.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:65
    2026-01-28 16:57:16.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:70
    2026-01-28 16:57:46.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:75
    2026-01-28 16:58:16.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:80
    2026-01-28 16:58:46.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:85
    2026-01-28 16:59:16.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:90
    2026-01-28 16:59:46.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:95
    2026-01-28 17:00:16.876  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:100
    2026-01-28 17:00:38.053  - info: host.PIArgon instance system.adapter.dwd.0 in version "2.8.5" started with pid 2078
    2026-01-28 17:00:42.477  - info: host.PIArgon instance system.adapter.dwd.0 having pid 2078 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-01-28 17:00:49.877  - info: javascript.0 (963) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max Einschalt Zyklus abends beendet. Wert: 100
    2026-01-28 17:00:50.025  - info: host.PIArgon instance system.adapter.daswetter.0 in version "3.2.8" started with pid 2094
    2026-01-28 17:00:53.020  - warn: daswetter.0 (2094) The last request was less than 15 minutes ago. You should query the data no more than 4 times per hour to reduce the load on the server. (13.22 min).
    2026-01-28 17:01:00.732  - info: host.PIArgon instance system.adapter.daswetter.0 having pid 2094 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    Wie mache ich den Grafana und influx Key neu ? Ind der Weboberfläche ? Und muss ich den nur abspeichern und fertig? Oder muß ich diesen Key dann auch in der Konfig vom Adapter angeben?
    https://forum.iobroker.net/post/877759
      Kapitaen31
      schrieb am zuletzt editiert von Kapitaen31
      Vielen lieben Dank für den Link...
      Ich habe eben die Befehle ausgeführt und bei sudo apt update erscheint kein Fehler mehr.
      Danke.
      Raspberry 4 (Trixie) mit 120GB SSD Bookworm
      Grafana, influxDB2, Hue, Zigbee2MQTT, Shelly,usw.
      • K Kapitaen31
        Danke.
        @Kapitaen31
        Dann den
        iob stop
        iob fix
        iob start
        noch. Und dann gerne nochmal den vollständigen Output von
        iob diag
          @Kapitaen31
          Dann den
          iob stop
          iob fix
          iob start
          iob diag
          Kapitaen31
          Jetzt habe ich noch den iob fix durchlaufen lassen.
          Hier die diag Ausgabe:
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
           17:25:14 up 39 min,  2 users,  load average: 4.97, 2.40, 1.43
          CPU threads: 4
          Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
          Current issues:
                         Local time: Wed 2026-01-28 17:25:14 CET
                     Universal time: Wed 2026-01-28 16:25:14 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          PI
          HOME=/home/PI
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:            4.0G        2.6G         90M        245K        1.4G        1.4G
          Swap:           209M        136M         73M
          Total:          4.2G        2.7G        164M
          Active iob-Instances:   4
                   3789 M total memory
                   2453 M used memory
                   2366 M active memory
                    967 M inactive memory
                     86 M free memory
                    119 M buffer memory
                   1206 M swap cache
                    199 M total swap
                    129 M used swap
                     70 M free swap
          top - 17:25:15 up 39 min,  2 users,  load average: 4.97, 2.40, 1.43
          Tasks: 203 total,   6 running, 197 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 66.7 us,  0.0 sy,  0.0 ni, 22.2 id, 11.1 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3789.8 total,     85.8 free,   2453.7 used,   1326.3 buff/cache
          MiB Swap:    200.0 total,     70.0 free,    130.0 used.   1336.1 avail Mem
          *** FILESYSTEM ***
          /var:
          4.1G    /var/
          1.9G    /var/log
          1.2G    /var/lib
          415M    /opt/iobroker/iobroker-data/
          15M     /opt/iobroker/iobroker-data/objects.jsonl
          4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          PIArgon             PIArgon (version: 7.0.7, hostname: PIArgon       , alive, uptime: 112)
          admin:          7.7.22
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        15413
          States:         14163
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://repos.influxdata.com/debian stable InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1001       44526      6946/io.mqtt.0
          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       44525      6946/io.mqtt.0
          tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       41730      7002/io.sonoff.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       44179      6715/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       44184      6715/iobroker.js-co
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       46003      7292/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       42929      6733/io.admin.0
          tcp6       0      0 :::8091                 :::*                    LISTEN      1001       49265      7548/io.lovelace.0
          tcp6       0      0 :::3000                 :::*                    LISTEN      106        35882      5028/grafana
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       47154      7078/io.radar2.0
          2026-01-28 17:26:08.648  - info: lovelace.0 (7548) starting. Version 5.0.5 in /opt/iobroker/node_modules/iobroker.lovelace, node: v22.22.0, js-controller: 7.0.7
          2026-01-28 17:26:08.829  - info: fritzdect.0 (7506) ____________________________________________
          2026-01-28 17:26:08.830  - info: fritzdect.0 (7506) create Main object DECT_ 099950756693 FRITZ!DECT 301 Vorgarten thermo.heat
          2026-01-28 17:26:08.889  - info: lovelace.0 (7548) http server listening on port 8091
          2026-01-28 17:26:15.337  - info: fritzdect.0 (7506) ____________________________________________
          2026-01-28 17:26:15.338  - info: fritzdect.0 (7506) create Main object DECT_ 099950961200 FRITZ!DECT 440 Wohnz thermo
          2026-01-28 17:26:16.368  - info: fritzdect.0 (7506) CREATE groups 1
          2026-01-28 17:26:16.372  - info: fritzdect.0 (7506) ____________________________________________
          2026-01-28 17:26:16.373  - info: fritzdect.0 (7506) create Main object DECT_ grp5C87D9-3C5609803 Wohnzimmer thermo.heat
          2026-01-28 17:26:16.482  - info: rssfeed.0 (7708) starting. Version 3.6.1 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v22.22.0, js-controller: 7.0.7
          2026-01-28 17:26:16.695  - info: pvforecast.0 (7659) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.pvforecast, node: v22.22.0, js-controller: 7.0.7
          2026-01-28 17:26:18.348  - info: fritzdect.0 (7506) finished creating devices/groups (if any)
          2026-01-28 17:26:18.349  - info: fritzdect.0 (7506) templates are used(false)
          2026-01-28 17:26:18.350  - info: fritzdect.0 (7506) start creating templates
          2026-01-28 17:26:18.829  - info: fritzdect.0 (7506) CREATE Templates 2
          2026-01-28 17:26:19.270  - info: fritzdect.0 (7506) finished creating templates (if any)
          2026-01-28 17:26:19.271  - info: fritzdect.0 (7506) routines are used(false)
          2026-01-28 17:26:19.271  - info: fritzdect.0 (7506) start creating routines
          2026-01-28 17:26:19.725  - info: fritzdect.0 (7506) finished creating routines (if any)
          2026-01-28 17:26:19.726  - info: fritzdect.0 (7506) start initial updating devices/groups
          2026-01-28 17:26:23.323  - info: fritzdect.0 (7506) finished initial updating devices/groups
          2026-01-28 17:26:23.324  - info: fritzdect.0 (7506) going over to cyclic polling, messages to poll activity only in debug-mode
          2026-01-28 17:26:26.017  - info: pvforecast.0 (7659) Starting internal update cron (every 15 Minutes) for timezone: Europe/Berlin
          2026-01-28 17:26:39.228  - info: tankerkoenig.0 (7599) Start first request
          2026-01-28 17:26:47.818  - info: host.PIArgon instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          • K Kapitaen31
            Script v.2025-08-09
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            PI
            HOME=/home/PI
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           209M        136M         73M
                     3789 M total memory
                     2453 M used memory
                       86 M free memory
                      119 M buffer memory
                     1206 M swap cache
                      199 M total swap
                      129 M used swap
                       70 M free swap
            *** FILESYSTEM ***
            /var:
            4.1G    /var/
            1.9G    /var/log
            1.2G    /var/lib
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.22
            javascript:     9.0.11
            Adapter State
            + instance is alive
            Objects and States
            Objects:        15413
            States:         14163
            Pending Updates: 0
            @homoran Siehst, JETZT funktioniert auch der Lebenszyklus-Status:
            @kapitaen31 Du solltest also in nächster Zeit (bis diesen Sommer!) also auf die 'Trixie' / Debian 13 umsatteln.
            Da jetzt die Kiste (weitgehend) auf dem aktuellen Stand ist beobachte das Verhalten des Systems mal.
            Mit fällt der Punkt
            CPU threads: 4
            Ins Auge, da musst du mal beobachten wie sich das bei längerer Laufzeit einpendelt.
            Load averages über der Zahl der CPU threads sind dauerhaft zu viel.
              Mit fällt der Punkt
              CPU threads: 4
              Kapitaen31
              @Thomas-Braun sagte in ioBroker auf PI4 stürzt immer mal wieder ab:
              Ich werde auf jeden Fall Trixi installieren, nur gerade jetzt habe ich keine Zeit dazu.
              Auch an dich die Frage: Sollte ich einen größeren PI4 holen (mit 8GB).
              Was meinst Du? Dann ist es doch ein wenig besser mit der Speicherverteilung. Allerdings sind die Kerne trotz dem gut belastet. Dafür bräuchte ich dann eine PI5. Oder doch etwas anderes ?
              Wie siehst Du das ?
              Mit fällt der Punkt
              CPU threads: 4
              • K Kapitaen31
                Wie siehst Du das ?
                Mit fällt der Punkt
                CPU threads: 4
                finde erst mal raus warum.
                Möglicherweise war gerade viel los, ggf. das RAM verbraucht und viel wurde ausgelagert. Wenn's dabei klemmt geht das auch ins load average mit ein
                die Anzahl Kerne sind nur eine Richtschnur um fie load average zu bewerten, die Kerne srlbst müssen dabei gar nicht überladen sein
                • H Offline
                  hoschi2007
                  @kapitaen31 halte auch mal die Belegung des Swap-Speichers im Blick ob der sich langsam füllt. Das siehst du z.b. mit dem Befehl
                  top
                  ganz oben. Beenden kannst du mit der Taste q
                  • RoddiEFR Offline
                    RoddiEFR Offline
                    RoddiEF
                    schrieb am zuletzt editiert von RoddiEF
                    Mal eine Frage zum Lüfter und dem nicht laufen bzw nicht richtig: Die Software dazu ist aber installiert und deinen Wünschen entsprechend Angepasst?
                    Ich habe das Gehäuse mehrfach in Betrieb und die Lüfter sind schon ab und zu mal zu hören, je nachdem was gerade "intensives" ausgeführt wird. Temperaturmäßig liegen meine dadurch so um die 40°C im Höchstfall mal 55°C deshalb meine Frage zu Anfang.
                    Ich bin wie ich bin, was anderes bekommt man nicht !!
                    Thomas BraunT OliverIOO K 3 Antworten Letzte Antwort
                    • RoddiEFR RoddiEF
                      Sollte dann so aussehen:
                      echad@chet:~ $ systemctl status argononed.service
                      ● argononed.service - Argon One Fan and Button Service
                           Loaded: loaded (/usr/lib/systemd/system/argononed.service; enabled; preset: enabled)
                           Active: active (running) since Mon 2026-01-26 13:31:00 CET; 2 days ago
                       Invocation: 9c311fc70eb8486eb0f343920be03b90
                         Main PID: 1153 (python3)
                            Tasks: 2 (limit: 8748)
                              CPU: 3.195s
                           CGroup: /system.slice/argononed.service
                                   └─1153 /usr/bin/python3 /etc/argon/argononed.py SERVICE
                      Jan 26 13:31:00 chet systemd[1]: Started argononed.service - Argon One Fan and Button Service.
                      • RoddiEFR RoddiEF
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @RoddiEF sagte in ioBroker auf PI4 stürzt immer mal wieder ab:
                        Wenn es wegen Überhitzung was gegeben hätte wäre es bei der Diagnose hier aufgeführt
                        Current issues:
                        Meine Adapter und Widgets
                        Links im Profil
                        • RoddiEFR RoddiEF
                          Kapitaen31
                          Moin,
                          ja ich habe die Software installiert. Die Konfig sieht so aus:
                          PI@PIArgon:/etc $ cat argononed.conf
                          # Argon Fan Configuration
                          # Min Temp=Fan Speed
                          50=10
                          55=50
                          60=100
                          Was ich gerade komisch finde das der Befehl
                          sudo systemctl status argononed
                          keine Ausgabe generiert....
                          Ich suche gerade...
                            Kapitaen31
                            Mir ist heute wieder der PI abgestürzt. Ich weiß nicht warum.
                            Der PI ist wohl um 17:02 abgestürzt. Zu der Zeit hören auch meine Aufzeichnungen in der Influx auf.
                            Die letzten Log Einträge sehen so aus:
                            2026-01-30 16:59:47.860 - info: javascript.0 (6831) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:55
                            2026-01-30 17:00:17.860 - info: javascript.0 (6831) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:60
                            2026-01-30 17:00:23.088 - info: host.PIArgon instance system.adapter.daswetter.0 in version "3.2.8" started with pid 117236
                            2026-01-30 17:00:27.115 - info: host.PIArgon instance system.adapter.dwd.0 in version "2.8.5" started with pid 117251
                            2026-01-30 17:00:32.444 - info: host.PIArgon instance system.adapter.dwd.0 having pid 117251 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2026-01-30 17:00:35.947 - info: host.PIArgon instance system.adapter.daswetter.0 having pid 117236 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                            2026-01-30 17:00:47.860 - info: javascript.0 (6831) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:65
                            2026-01-30 17:01:17.860 - info: javascript.0 (6831) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:70
                            2026-01-30 17:01:47.860 - info: javascript.0 (6831) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:75
                            2026-01-30 17:02:17.861 - info: javascript.0 (6831) script.js.common.Lichtsteuerung.Ober_Geschoss.Flur.Hue_Max: Max abends einschalten +5. Wert:80
                            2026-01-30 17:02:24.390 - info: admin.0 (6733) Request actual repository...
                            2026-01-30 17:02:25.462 - info: host.PIArgon Updating repository "Stable (default)" under "http://download.iobroker.net/sources-dist.json"
                            2026-01-30 17:02:31.151 - info: admin.0 (6733) Repository received successfully.
                            2026-01-30 17:24:33.277 - info: host.PIArgon iobroker.js-controller version 7.0.7 js-controller starting
                            2026-01-30 17:24:33.283 - info: host.PIArgon Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
                            2026-01-30 17:24:33.285 - info: host.PIArgon hostname: PIArgon, node: v22.22.0
                            2026-01-30 17:24:33.287 - info: host.PIArgon ip addresses: 192.168.178.36 2001:9e8:e5fb:4a00:be75:7769:1066:ec32 fd95:623b:4cfd:0:bd71:ed85:eae2:ea0 fe80::18e0:ffba:1ebd:844f
                            2026-01-30 17:24:35.609 - info: host.PIArgon connected to Objects and States
                            2026-01-30 17:24:35.638 - info: host.PIArgon added notifications configuration of host
                            2026-01-30 17:24:36.548 - info: host.PIArgon 42 instances found
                            2026-01-30 17:24:36.610 - info: host.PIArgon starting 32 instances
                            2026-01-30 17:24:37.094 - info: host.PIArgon Delete state "system.host.PIArgon.versions.nodeCurrent"
                            2026-01-30 17:24:37.264 - info: host.PIArgon Delete state "system.host.PIArgon.versions.nodeNewest"
                            2026-01-30 17:24:37.277 - info: host.PIArgon Delete state "system.host.PIArgon.versions.nodeNewestNext"
                            2026-01-30 17:24:37.338 - info: host.PIArgon instance system.adapter.admin.0 in version "7.7.22" started with pid 898
                            2026-01-30 17:24:37.346 - info: host.PIArgon Delete state "system.host.PIArgon.versions.npmCurrent"
                            2026-01-30 17:24:37.400 - info: host.PIArgon Delete state "system.host.PIArgon.versions.npmNewest"
                            2026-01-30 17:24:37.452 - info: host.PIArgon Delete state "system.host.PIArgon.versions.npmNewestNext"
                            2026-01-30 17:24:37.503 - info: host.PIArgon Some obsolete host states deleted.
                            2026-01-30 17:24:41.240 - info: host.PIArgon instance system.adapter.history.0 in version "3.0.1" started with pid 909
                            2026-01-30 17:24:42.092 - error: admin.0 (898) admin.0 already running
                            2026-01-30 17:24:42.098 - warn: admin.0 (898) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            2026-01-30 17:24:42.912 - error: host.PIArgon instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            2026-01-30 17:24:42.913 - info: host.PIArgon Restart adapter system.adapter.admin.0 because enabled
                            Ich habe gestern den top Befehl genutzt, um zu sehen, wie sich das System verhält.
                            Am 29.01. habe ich folgende Ausgaben erhalten.
                            top2026 01 30 1740.log
                            Dann habe ich 3 Minuten später nochmal den Befehl ausgeführt:
                            top2026 01 30 1743.log
                            gerade eben habe ich nochmals den Befehl ausgeführt.
                            top2026 01 30 1820.log
                            Irgendwie bin ich ratlos...
                            OliverIOO HomoranH 3 Antworten Letzte Antwort
                            • K Kapitaen31
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @Kapitaen31
                              wenn der rechner auf betriebssystemebene abstürzt musst du auch die logs des betriebssystems prüfen.
                              ein applikationslog (wie hier vom iobroker) wird da uU nix dazu sagen können. bspw weil das betriebssystem entscheidet das eine applikation abgeschossen wird (ggfs wegen oom= out of memory)
                              dann bekommt der iobroker das gar nicht richtig mit
                              Links im Profil
                              • OliverIOO OliverIO
                                @Kapitaen31
                                Kapitaen31
                                @OliverIO sagte in ioBroker auf PI4 stürzt immer mal wieder ab:
                                @Kapitaen31
                                Okay, welche Logs sind da entscheidend?
                                • K Kapitaen31
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  top ist immer nur eine augenblicksansicht
                                  du könntest auch mal über den history adapter dir die RAM-Datenpunkte die sich unterhalb diesem Objekt befinden aufzeichen
                                  system.host.<dein iobroker name>
                                  da würdest du dann zumindest sehen wie sich der freie und benutzte RAM deines Systems sich vor dem nächsten Absturz entwickelt.
                                  Die Daten werden vom History-Adapter auch entsprechend grafisch angezeigt
                                  Links im Profil
                                  • K Kapitaen31
                                    zeig mal das Script
                                      Kapitaen31
                                      Bei meinen Objekte finde ich nur systeminfo.
                                      Kein system.host...
                                      • K Kapitaen31
                                        Kein system.host...
                                        Kein system.host...
                                        als Experte?
                                          zeig mal das Script
                                          Kapitaen31
                                          zeig mal das Script
                                          Hier steuere ich die Hue Lampe und will gerne die Lichtstärke ausgeben. mehr ist das nicht.
                                          Ich habe das Script als blockly geschrieben...
                                          <variables>
                                          <variable id="r)$YD?H+$5:cKC|%W?7V">MAX Wert</variable>
                                          <variable id="hBTrxmvNI[@NJ~V}}Bw">MAX erreichbar</variable> <variable id="5S6~J2p*#psaaaOCs}rm">MAX aufdimmen aktiv</variable> <variable id="fWp(X/d=w3r![SfCJXN~">MAX aufdimmen</variable> <variable id="G4v-2f=[yd{wii!QrdPl">MAX Text</variable> <variable id="nE[tMe{OLLxujut#+%#/">MAX Zyklus beendet</variable> <variable id="bT^aTce)!2nCZJE@WKHE">MAX Farbwert</variable> <variable id="rcxMOv_1MyWP^CnvzTlk">MAX ein/aus</variable> <variable type="cron" id="MaxZeitplan">MaxZeitplan</variable> <variable type="interval" id="MAX aus">MAX aus</variable> <variable type="interval" id="MAX ein">MAX ein</variable> <variable id="ZRtb,5Y0dLX).4;*_Kfq">MAX Helligkeit</variable> <variable type="cron" id="Max abends aus">Max abends aus</variable> <variable type="timeout" id="Wartezeit">Wartezeit</variable> </variables> <block type="procedures_defnoreturn" id="(.oVeh,p@?K$:=m[.W.m" x="738" y="-2387"> <mutation> <arg name="MAX Wert" varid="r)$YD?H+$5:cKC|%W?7V"></arg> <arg name="MAX erreichbar" varid="hBTrxmvNI[@NJ~V}}Bw"></arg>
                                          <arg name="MAX aufdimmen aktiv" varid="5S6~J2p*#psaaaOCs}rm"></arg>
                                          <arg name="MAX aufdimmen" varid="fWp(X/d=w3r![SfCJXN~"></arg>
                                          <arg name="MAX Text" varid="G4v-2f=[yd{wii!QrdPl"></arg>
                                          <arg name="MAX Zyklus beendet" varid="nE[tMe{OLLxujut#+%#/"></arg>
                                          <arg name="MAX Farbwert" varid="bT^aTce)!2nCZJE@WKHE"></arg>
                                          <arg name="MAX ein/aus" varid="rcxMOv_1MyWP^CnvzTlk"></arg>
                                          </mutation>
                                          <field name="NAME">Max dimmen</field>
                                          <comment pinned="false" h="80" w="160">Hue Lampe mit angegebenem Wert langsam einschalten.</comment>
                                          <statement name="STACK">
                                          <block type="controls_if" id="?-MFBCGTKbUEa+;zDqEW">
                                          <value name="IF0">
                                          <block type="logic_compare" id="j[8%TSY1EpNQO|H_M/@f">
                                          <field name="OP">EQ</field>
                                          <value name="A">
                                          <block type="variables_get" id="K+v.fALL0%Vc|SSNF+fn">
                                          <field name="VAR" id="rcxMOv_1MyWP^CnvzTlk">MAX ein/aus</field>
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="text" id="d8PMuciDClI-7TH@$bnN">
                                          <field name="TEXT">ein</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <statement name="DO0">
                                          <block type="comment" id="W$.aN]ZF;P=dZ3l)cj|"> <field name="COMMENT">Max wird aufgeblendet (einschalten)</field> <next> <block type="controls_if" id="8(|H;rxt~?OpcMLqOYJ">
                                          <value name="IF0">
                                          <block type="logic_compare" id="5b}Ft:KR}FG$m?y?hcgV">
                                          <value name="A">
                                          <block type="get_value" id="oM4JXHo#N4{~oQ$SAa.t">
                                          <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field>
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="math_number" id="z4vkLwSH!.36~}uFz$8,">
                                          <field name="NUM">0</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="control" id="$hXbsHJ~DjOvrsTV|I)" disabled-reasons="MANUALLY_DISABLED">
                                          <field name="OID">alias.0.OG.Flur.Licht.EingeschaltetHueMax</field>
                                          <value name="VALUE">
                                          <block type="logic_boolean" id="/~rmnusvM!.hv,4MX/q"> <field name="BOOL">TRUE</field> </block> </value> <next> <block type="control" id="@#Kyw6:zl:8hW;aq%ZT">
                                          <block type="math_number" id="V?l~ufqEz7wh5]@PPLf;">
                                          <field name="NUM">5</field>
                                          </block>
                                          </value>
                                          <next>
                                          <block type="debug" id="{Cl
                                          a.xiz^|r2)~LPL2">
                                          <field name="Severity">warn</field>
                                          <value name="TEXT">
                                          <shadow type="text" id="^jE2Bo%Ym5,Oi@3x}sa">
                                          <field name="TEXT">Max eingeschaltet! </field>
                                          </shadow>
                                          </value>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          <next>
                                          <block type="control" id="WwDM+Wn6F|?W$i8/qGzY">
                                          <field name="OID">alias.0.OG.Flur.Licht.FarbTemperaturHueMax</field>
                                          <block type="variables_get" id="5JWmrbE?p[prXTa)P9ri">
                                          <field name="VAR" id="bT^aTce)!2nCZJE@WKHE">MAX Farbwert</field>
                                          </block>
                                          </value>
                                          <next>
                                          <block type="update" id="8cx-$H]jpMG5!;bFqeFt">
                                          <field name="OID">javascript.0.Datenpunkte.Flur.Licht.Abdimmen_aktiv</field>
                                          <block type="logic_boolean" id="tg,H3EU?IKJ{D:Y)@uj+">
                                          </block>
                                          </value>
                                          <next>
                                          <block type="timeouts_setinterval" id="fKwFr,!MQ9JJz
                                          (sQZD"> <field name="NAME">MAX ein</field> <field name="INTERVAL">30</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="controls_if" id="-v*EhYeIg9/}(t#EQdEJ"> <mutation else="1"></mutation> <value name="IF0"> <block type="logic_operation" id="Fjr0ucdAe|EB+0/T5IY">
                                          <field name="OP">AND</field>
                                          <value name="A">
                                          <block type="logic_compare" id="2}^Y%+3=IJ8;fHl86lVC">
                                          <field name="OP">LT</field>
                                          <value name="A">
                                          <block type="get_value" id="DiDen%J^B?f_}2=f#+q;">
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="variables_get" id="NU,pyt3h.NyZUEb,V@b+">
                                          <field name="VAR" id="r)$YD?H+$5:cKC|%W?7V">MAX Wert</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="logic_compare" id="yJNqJmE%%$@?flk6yOW"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="$%!dx8h;Cnx]rdqZXUd4"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.Erreichbar Hue Max</field> </block> </value> <value name="B"> <block type="variables_get" id="58u^)rVl=8a-0Dd]qq5;"> <field name="VAR" id="hBTrxmvNI[@NJ~V}}Bw">MAX erreichbar</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="control" id="nyA9+pyUaQVC6m{;15S"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="f!(:hyoa2Q+cK))q+dc4"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="zOX(cu-:{WUicw)FqfDY"> <field name="NUM">1</field> </shadow> <block type="get_value" id="/eQWkhgRk{7]G|yTafM">
                                          </block>
                                          </value>
                                          <value name="B">
                                          <shadow type="math_number" id="n?F4LH6yz?S*yZW]R45"> <field name="NUM">1</field> </shadow> <block type="math_number" id="TjH@/4-5DL[.;3B/Y_Km"> <field name="NUM">5</field> </block> </value> </block> </value> <next> <block type="debug" id="aP}FHA[(N/d9xweDq!^p"> <field name="Severity">debug</field> <value name="TEXT"> <shadow type="text" id=":WB,iiHLVHprFT[+t/?-"> <field name="TEXT">MAX morgens einschalten. +5 </field> </shadow> <block type="text_join" id="n~#TrdWiWN.]0+~OLhqk"> <mutation items="2"></mutation> <value name="ADD0"> <block type="variables_get" id="GE3ShNmJn%fr2lFnM.z9"> <field name="VAR" id="G4v-2f=[yd{wii!QrdPl">MAX Text</field> </block> </value> <value name="ADD1"> <block type="get_value" id="uucqFFXsN^K=qZ}9L/zl"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> </block> </value> </block> </value> </block> </next> </block> </statement> <statement name="ELSE"> <block type="timeouts_clearinterval" id="v5{w?:rY4%oWwJhTQhRv"> <field name="NAME">MAX ein</field> <next> <block type="update" id="ZbTWS;R8#,j/T5|Du7Sn"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">javascript.0.Datenpunkte.Flur.Licht.Abdimmen_aktiv</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="variables_get" id="4!nlHp[9kk)%-%zFeGvS"> <field name="VAR" id="5S6~J2p*#psaaaOCs}rm">MAX aufdimmen aktiv</field> </block> </value> <next> <block type="timeouts_settimeout" id="@,_pnkMLL7?bN.IeL_Pz"> <field name="NAME">Wartezeit</field> <field name="DELAY">3000</field> <field name="UNIT">ms</field> <statement name="STATEMENT"> <block type="debug" id="pm%o{%eGw(KC4_;Uk0j#"> <field name="Severity">debug</field> <value name="TEXT"> <shadow type="text" id="cv[@3gvFjb|wnQHO,-J-"> <field name="TEXT">MAX morgens einschalten. +5 </field> </shadow> <block type="text_join" id="(HK{qh%WpiZiczxUa-gg"> <mutation items="2"></mutation> <value name="ADD0"> <block type="variables_get" id="y,*|HlCSc@|HrQ]E]iwB"> <field name="VAR" id="nE[tMe{OLLxujut#+%#/">MAX Zyklus beendet</field> </block> </value> <value name="ADD1"> <block type="get_value" id="z/kv$T2w3vYWnvLu@n"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> </block> </value> </block> </value> </block> </statement> </block> </next> </block> </next> </block> </statement> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </next> </block> </statement> <value name="IF1"> <block type="logic_compare" id="c,^fUdED3)9iw$9sQ,Kb"> <field name="OP">EQ</field> <value name="A"> <block type="variables_get" id="?F]?43#QnaKc$~:,#MK">
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="text" id=")]JlbN1{QL
                                          HZ./Tyq+F">
                                          <field name="TEXT">aus</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <statement name="DO1">
                                          <block type="comment" id="958,(Xj(QU;N{HWAlHiY">
                                          <field name="COMMENT">Max wird abgeblendet (ausgeschalten)</field>
                                          <next>
                                          <block type="controls_if" id="gLYJe|7hwLa[OIi{pEHC">
                                          <value name="IF0">
                                          <block type="get_value" id="iMHc#),MOW!@Tx-l,qdF">
                                          </block>
                                          </value>
                                          <block type="timeouts_clearinterval" id="}378d(zLuy3}:yf#;AW4">
                                          <next>
                                          <block type="timeouts_clearinterval" id="A%cLuw-os0J(qH3tmF$!">
                                          <field name="NAME">MAX aus</field>
                                          <next>
                                          <block type="update" id="Tg]|I;1.X?8rU,}Oi6?">
                                          <block type="variables_get" id="#_]el^U#jQqW=[Rl[4yb">
                                          </block>
                                          </value>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          <next>
                                          <block type="timeouts_setinterval" id="Q*@jZN(1T4FX-!mla2,O">
                                          <block type="controls_if" id="X6;B|d3/mIzw__X4WCZ">
                                          <value name="IF0">
                                          <block type="logic_compare" id="OQ3Gp9E;Pb/bjZ[7je-E">
                                          <value name="A">
                                          <block type="variables_get" id="{YED0{wVOtb2~@WdTPK{">
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="math_number" id="[tXb_adS0#1zdR(bo4:m">
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="controls_if" id="ON12}P7Q9y?!!vP
                                          |q}$">
                                          <value name="IF0">
                                          <block type="logic_operation" id="HE_i?.P4hUB6a+3Ou$V|">
                                          <value name="A">
                                          <block type="logic_compare" id="rL]1!2hJtiTBzO:d^CM">
                                          <field name="OP">GT</field>
                                          <value name="A">
                                          <block type="get_value" id="w;r2ppII1T!7P#7c!}a"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> </block> </value> <value name="B"> <block type="math_number" id="q%*5%Z8kDO@RR(XnW;N-"> <field name="NUM">6</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="wB@p_44=~+c1F_iOLE[">
                                          <value name="A">
                                          <block type="get_value" id="?XMt8Uz$+
                                          ;e{C0qw!~A">
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="math_number" id="YLpg)~%;BcU4I3s6?$(.">
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="variables_set" id="a-L8j5;9[YD;GSDWoc4">
                                          <field name="VAR" id="ZRtb,5Y0dLX).4;
                                          Kfq">MAX Helligkeit</field>
                                          <block type="logic_boolean" id="sHk},t-)W0R%yxA9bivU">
                                          </block>
                                          </value>
                                          </block>
                                          </statement>
                                          <block type="variables_set" id=")OjVo{g[olOOvXF#,OW"> <field name="VAR" id="ZRtb,5Y0dLX).4;*_Kfq">MAX Helligkeit</field> <value name="VALUE"> <block type="logic_boolean" id="h;Vf,0NehS?1{cQOUiiz"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </statement> <statement name="ELSE"> <block type="controls_if" id="AHx!OQ.^F551s4t+VBG">
                                          <value name="IF0">
                                          <block type="logic_operation" id="vFSVy7r41QsVDt+#M4_"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="}$5NII3N_|Q4m}BJ=M|">
                                          <value name="A">
                                          <block type="get_value" id="9KBp7~~xFP^hj|ai+6{}">
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="variables_get" id=".pi=,ng+FoDq[G45;-bd">
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <value name="B">
                                          <block type="logic_compare" id="5yZ)s~*lg=Nz.xmt?.]i">
                                          <value name="A">
                                          <block type="get_value" id="Wl);mko7c+fmu?=Ut1n"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.Erreichbar Hue Max</field> </block> </value> <value name="B"> <block type="math_number" id="P)o6hxIowSNlPkQV
                                          @X">
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="variables_set" id="XH;CGIm{6LuC2=c-ZT."> <field name="VAR" id="ZRtb,5Y0dLX).4;*_Kfq">MAX Helligkeit</field> <value name="VALUE"> <block type="logic_boolean" id="hsjdq8rIE-qa.6~.$X:A"> <field name="BOOL">TRUE</field> </block> </value> </block> </statement> <statement name="ELSE"> <block type="variables_set" id="BNt@U*}l{Qr(R(_OB8Zd"> <field name="VAR" id="ZRtb,5Y0dLX).4;*_Kfq">MAX Helligkeit</field> <value name="VALUE"> <block type="logic_boolean" id="p+OK5VBCdyF$:@rL=gG7"> <field name="BOOL">FALSE</field> </block> </value> </block> </statement> </block> </statement> <next> <block type="controls_if" id="dkd{Q.M!_@i09jyERTc8"> <mutation else="1"></mutation> <value name="IF0"> <block type="variables_get" id="6]$VTa8Fj/r$hWyes-K8"> <field name="VAR" id="ZRtb,5Y0dLX).4;*_Kfq">MAX Helligkeit</field> </block> </value> <statement name="DO0"> <block type="control" id="/L3?``e9MfOEm#c[;o%/"> <mutation xmlns="http://www.w3.org/1999/xhtml" delay_input="false"></mutation> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="math_arithmetic" id="_XzfJl]KKCRilh,QB-Ny"> <field name="OP">MINUS</field> <value name="A"> <shadow type="math_number" id="Jk)%r3DFhBpQbyso%N1I"> <field name="NUM">1</field> </shadow> <block type="get_value" id="|Y.LfeTc_zrv-wLkoEKf"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> </block> </value> <value name="B"> <shadow type="math_number" id="mmYDnh$QOMo^n~:tS_Wi"> <field name="NUM">1</field> </shadow> <block type="math_number" id="6GqXBkyH7e+$Ya7#|k/e"> <field name="NUM">5</field> </block> </value> </block> </value> <next> <block type="debug" id="tj9HOQ=2?SeU[?27d4f#"> <field name="Severity">debug</field> <value name="TEXT"> <shadow type="text" id="z$7#1w:=!+6f_pXhN_Su"> <field name="TEXT">MAX morgens einschalten. +5 </field> </shadow> <block type="text_join" id="2yp520,J!r=.dVz*dq1]"> <mutation items="2"></mutation> <value name="ADD0"> <block type="variables_get" id="A@$s9(m#0=9D5n@AMsgn"> <field name="VAR" id="G4v-2f=[yd{wii!QrdPl">MAX Text</field> </block> </value> <value name="ADD1"> <block type="get_value" id="VWDhr}v:fpF6/oK$I9[U"> <field name="ATTR">val</field> <field name="OID">alias.0.OG.Flur.Licht.HelligkeitHueMax</field> </block> </value> </block> </value> </block> </next> </block> </statement> <statement name="ELSE"> <block type="timeouts_clearinterval" id="cK}6KBODo;9}z0K=xHC">
                                          <next>
                                          <block type="control" id="2;w:d$~#DCJcA.erYNe">
                                          <block type="logic_boolean" id="5S$G~~Rn-|[cDp4NH?G^">
                                          </block>
                                          </value>
                                          <next>
                                          <block type="debug" id="Xaeg[eZBDM[LQ{u9G()">
                                          <field name="Severity">error</field>
                                          <value name="TEXT">
                                          <shadow type="text" id="tE;V,Q]+W7[W:p/bMn}Q">
                                          <field name="TEXT">Zyklus MAX abblenden morgens gestoppt! </field>
                                          </shadow>
                                          <block type="variables_get" id="(fw/pgGwERg#ggDGc^8d">
                                          </block>
                                          </value>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          </block>
                                          </statement>
                                          </block>
                                          <block type="comment" id="k@#9?8}Gvi3V]3YjA
                                          f," x="87" y="-1738">
                                          <field name="COMMENT">Hue Max automatisch morgens langsam einschalten</field>
                                          <next>
                                          <block type="on_ext" id="~01)iWjnZNH}]UI$b57A">
                                          <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation>
                                          <value name="OID0">
                                          <shadow type="field_oid" id="GEQ;y1SSb59+MzZsY_GN">
                                          <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_Wochentag</field>
                                          </shadow>
                                          </value>
                                          <value name="OID1">
                                          <shadow type="field_oid" id="ncS4R,9mLtjW9;J1(dd"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_Monat</field> </shadow> </value> <value name="OID2"> <shadow type="field_oid" id="v8tK6i}%2s$KDd.B_As">
                                          <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_Datum</field>
                                          </shadow>
                                          </value>
                                          <value name="OID3">
                                          <shadow type="field_oid" id="9)OM,47LXv-ZWe4XU.o"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_Std</field> </shadow> </value> <value name="OID4"> <shadow type="field_oid" id="d2W|;^!|+z$)p0oiA(/r"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_Min</field> </shadow> </value> <statement name="STATEMENT"> <block type="schedule_clear" id="0WZsSo#[BB/zSspbtCKD"> <field name="NAME">MaxZeitplan</field> <next> <block type="schedule_create" id="x}?P^Q$0u}OLJ?PA{myt"> <field name="NAME">MaxZeitplan</field> <value name="SCHEDULE"> <shadow type="field_cron" id="wq]fB8YyaUS?tBPs%B@C"> <field name="CRON">* * * * *</field> </shadow> <block type="cron_builder" id=".;=744~l-D]rat.@IWBI"> <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="false" as_line="false"></mutation> <field name="LINE">FALSE</field> <field name="WITH_SECONDS">FALSE</field> <value name="DOW"> <shadow type="text" id="e96iLJq;_XU-X-ZU#jKD"> <field name="TEXT">*</field> </shadow> <block type="get_value" id=":nhLX2qxF|6]:h~ZKCv6"> <field name="ATTR">val</field> <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_Wochentag</field> </block> </value> <value name="MONTHS"> <shadow type="text" id="!nbRgxx91LZD31R4z*+/"> <field name="TEXT">*</field> </shadow> <block type="get_value" id="#Up:6!Aru{dYwcskc6FO"> <field name="ATTR">val</field> <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_Monat</field> </block> </value> <value name="DAYS"> <shadow type="text" id="]$nvdZmG.[!l:F3gF{n+"> <field name="TEXT">*</field> </shadow> <block type="get_value" id="fAehlarR$[zyt,l_|~=B"> <field name="ATTR">val</field> <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_Datum</field> </block> </value> <value name="HOURS"> <shadow type="text" id="^7ocu$I#MI$o|r.#B^nv"> <field name="TEXT">*</field> </shadow> <block type="get_value" id="J?he8s;YGd2;h-Gaitt">
                                          <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_Std</field>
                                          </block>
                                          </value>
                                          <value name="MINUTES">
                                          <shadow type="text" id="O}~evu;@fAxCdM,s(:R-">
                                          <field name="TEXT">
                                          </field>
                                          </shadow>
                                          <block type="get_value" id="{:-=QHd136HTyl(4%wC">
                                          <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_Min</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="debug" id="0|dwAii]#UTH4?,I)F)7">
                                          <value name="TEXT">
                                          <shadow type="text" id="sOT$]pdGx8#%$cSW}6RQ">
                                          <field name="TEXT">Neuer Zeitplan wurde für morgens einschalten angelegt. </field>
                                          </shadow>
                                          </value>
                                          <next>
                                          <block type="controls_if" id="j4yvD3%mWg~z
                                          EdN~,fM">
                                          <value name="IF0">
                                          <block type="time_compare_ex" id="1z_dMF(m-f$q90Kvc;qU">
                                          <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false" actual_time="true"></mutation>
                                          <field name="USE_ACTUAL_TIME">TRUE</field>
                                          <field name="OPTION"><</field>
                                          <value name="START_TIME">
                                          <shadow type="text" id=":6F%-{bzG)iSSfeza6L=">
                                          <field name="TEXT">12:00</field>
                                          </shadow>
                                          <block type="time_astro" id="fys@6x3M}^7!~u;O.@7l">
                                          <field name="TYPE">dawn</field>
                                          <field name="OFFSET">18</field>
                                          </block>
                                          </value>
                                          </block>
                                          </value>
                                          <block type="debug" id="egfh_^MD7u6}UKyXqziN">
                                          <value name="TEXT">
                                          <shadow type="text" id="?m)fS~Oxt,RJ^uF.l3CV">
                                          </shadow>
                                          <block type="text_join" id="IXqr+fUq[VYslHF3,~y"> <mutation items="3"></mutation> <value name="ADD0"> <block type="time_get" id="ds6}/C4?i#x6:q$2zDq-"> <mutation xmlns="http://www.w3.org/1999/xhtml" format="false" language="false"></mutation> <field name="OPTION">object</field> </block> </value> <value name="ADD1"> <block type="text" id="jt;XRhng.h$J2;2)P28["> <field name="TEXT"> ; </field> </block> </value> <value name="ADD2"> <block type="time_astro" id="4tiRND)hpOlyrnH^uOe-"> <field name="TYPE">dawn</field> <field name="OFFSET">18</field> </block> </value> </block> </value> <next> <block type="timeouts_clearinterval" id="(/}pgJ}TaR6_:^b|oF">
                                          <next>
                                          <block type="timeouts_clearinterval" id="}9tVFt^}:^IsmLkm@Dcv">
                                          <next>
                                          <block type="procedures_callnoreturn" id="xH+jxQD/]|RihK?VB]zz">
                                          <mutation name="Max dimmen">
                                          <arg name="MAX Wert"></arg>
                                          <arg name="MAX erreichbar"></arg>
                                          <arg name="MAX aufdimmen aktiv"></arg>
                                          <arg name="MAX aufdimmen"></arg>
                                          <arg name="MAX Text"></arg>
                                          <arg name="MAX Zyklus beendet"></arg>
                                          <arg name="MAX Farbwert"></arg>
                                          <arg name="MAX ein/aus"></arg>
                                          </mutation>
                                          <value name="ARG0">
                                          <block type="math_number" id="AXpIj-h79GlbTY(HyEbW">
                                          <field name="NUM">30</field>
                                          </block>
                                          </value>
                                          <value name="ARG1">
                                          <block type="logic_boolean" id="L+)^13zWe}/O%s8W|B/%">
                                          </block>
                                          </value>
                                          <value name="ARG2">
                                          <block type="logic_boolean" id="LA.t!a_7vhj~6w,Q;v#I">
                                          </block>
                                          </value>
                                          <value name="ARG3">
                                          <block type="logic_boolean" id="ug]7l8Aoy}a|9bz8b?J_">
                                          </block>
                                          </value>
                                          <value name="ARG4">
                                          <block type="text" id="J,XWj$3y@bJvH/=g~Y#Y">
                                          <field name="TEXT">Max morgens einschalten +5. Wert:</field>
                                          </block>
                                          </value>
                                          <value name="ARG5">
                                          <block type="text" id="fUX5znvA6|4gRfkOgbU"> <field name="TEXT">Max Einschalt Zyklus morgens beendet. Wert: </field> </block> </value> <value name="ARG6"> <block type="math_number" id="u{pe]c04~mS.P/M;b6wJ"> <field name="NUM">2730</field> </block> </value> <value name="ARG7"> <block type="text" id="|8^}i++FoQws5;MV~ZNB"> <field name="TEXT">ein</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </next> </block> </statement> <next> <block type="comment" id="Hh[T7Rk(HB|R2g1t^HL">
                                          <field name="COMMENT">Hue Max automatisch abends langsam einschalten</field>
                                          <next>
                                          <block type="astro" id="LqO=N$:{p/W+W:*WVnO"> <field name="TYPE">sunset</field> <field name="OFFSET">0</field> <statement name="STATEMENT"> <block type="debug" id="4b=o_7(IoBZH{s;!8tLQ"> <field name="Severity">warn</field> <value name="TEXT"> <shadow type="text" id="d,bRF,=z,1pBm~GC$OIV"> <field name="TEXT">Sonnenuntergang. </field> </shadow> </value> <next> <block type="controls_if" id="66%7$~O^^@5l[RsbVRo+"> <value name="IF0"> <block type="time_compare" id="-A8j2A{eDa@#]Wo%H-}l"> <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="false"></mutation> <field name="OPTION">&lt;</field> <field name="START_TIME">21:36</field> </block> </value> <statement name="DO0"> <block type="timeouts_clearinterval" id="LLRdxs*I-UZE@GW{.rbY"> <field name="NAME">MAX ein</field> <next> <block type="timeouts_clearinterval" id="27]Oj$$Y#n]e{6@rAybN"> <field name="NAME">MAX aus</field> <next> <block type="procedures_callnoreturn" id="%(KZO%N6)BAn~#UR44qy"> <mutation name="Max dimmen"> <arg name="MAX Wert"></arg> <arg name="MAX erreichbar"></arg> <arg name="MAX aufdimmen aktiv"></arg> <arg name="MAX aufdimmen"></arg> <arg name="MAX Text"></arg> <arg name="MAX Zyklus beendet"></arg> <arg name="MAX Farbwert"></arg> <arg name="MAX ein/aus"></arg> </mutation> <value name="ARG0"> <block type="math_number" id="wfuhN(nGHljuumadguXu"> <field name="NUM">100</field> </block> </value> <value name="ARG1"> <block type="math_number" id="rDLgu:vFO98Fk529s]hb"> <field name="NUM">1</field> </block> </value> <value name="ARG2"> <block type="logic_boolean" id="v/xfJWP$L,d4TQ@l9v}4"> <field name="BOOL">FALSE</field> </block> </value> <value name="ARG3"> <block type="logic_boolean" id="]fbUlWD9GFRusx75eE7Q"> <field name="BOOL">TRUE</field> </block> </value> <value name="ARG4"> <block type="text" id="B{y[qRb$:k#K5*Gie@sj"> <field name="TEXT">Max abends einschalten +5. Wert:</field> </block> </value> <value name="ARG5"> <block type="text" id="p-)cpZjz9l]iv4,!LN/">
                                          <field name="TEXT">Max Einschalt Zyklus abends beendet. Wert: </field>
                                          </block>
                                          </value>
                                          <value name="ARG6">
                                          <block type="math_number" id="IFNm_0vp1^YZk6DmjB0B">
                                          </block>
                                          </value>
                                          <value name="ARG7">
                                          <block type="text" id="lwy(#lFN_S$wUs]b~tKX">
                                          </block>
                                          </value>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          <next>
                                          <block type="comment" id="ljK8%!=}D47{xXM[+qyu">
                                          <field name="COMMENT">Hue Max automatisch abends langsam ausschalten</field>
                                          <next>
                                          <block type="on_ext" id="0~zi1
                                          d)oO;M4dnFnfp"> <mutation xmlns="http://www.w3.org/1999/xhtml" items="5"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="$9J$dj@K6?R@?Hr/ufCp"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_datum_abends</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id=")?YQ@;EDzlB^+w2KvL/v"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_min_abends</field> </shadow> </value> <value name="OID2"> <shadow type="field_oid" id="?H:k_f,3PM}8^uS,G{PB"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_monat_abends</field> </shadow> </value> <value name="OID3"> <shadow type="field_oid" id=".e(Dj[W^0mlG*dUfIG(Z"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_std_abends</field> </shadow> </value> <value name="OID4"> <shadow type="field_oid" id="jDRQWS(~-)2ZhsuS_d${"> <field name="oid">javascript.0.Datenpunkte.Flur.Licht.CRON_wochentag_abends</field> </shadow> </value> <statement name="STATEMENT"> <block type="debug" id="pV-u7{?VTd%Edor];nqk"> <field name="Severity">warn</field> <value name="TEXT"> <shadow type="text" id="YDcl+!ItLt3Z7:u(Kp46"> <field name="TEXT">Zeitplan MAX abends ausschalten wurde neu angelegt: </field> </shadow> </value> <next> <block type="schedule_clear" id="CH+#N{r0(cu#FC;Z6IKm"> <field name="NAME">Max abends aus</field> <next> <block type="schedule_create" id="O63Nidu+jYM0|D;ur(pd"> <field name="NAME">Max abends aus</field> <value name="SCHEDULE"> <shadow type="field_cron" id="-dqiyQ(ND$C)Tj~OyWgT"> <field name="CRON">* * * * *</field> </shadow> <block type="cron_builder" id="V@Q66gY%GK0g]xm,9ze">
                                          <value name="DOW">
                                          <shadow type="text" id=",%T7x18:a$.CT7St|3Fb">
                                          <field name="TEXT"></field>
                                          </shadow>
                                          <block type="get_value" id="9z
                                          .DbnZw=}hYq/W9(|">
                                          <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_wochentag_abends</field>
                                          </block>
                                          </value>
                                          <shadow type="text" id=",kV/K;ZS2k-uiGfs*#/C">
                                          </shadow>
                                          <block type="get_value" id="|Czncw8JtBEUed9{-c}]">
                                          <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_monat_abends</field>
                                          </block>
                                          </value>
                                          <value name="DAYS">
                                          <shadow type="text" id="%7WON19x,lk;7QC}!QL"> <field name="TEXT">*</field> </shadow> <block type="get_value" id="j*.m_HK+*jbSW:L-Sg)">
                                          <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_datum_abends</field>
                                          </block>
                                          </value>
                                          <shadow type="text" id="LUALVt@uT:K3Z}Nb5hO"> <field name="TEXT">*</field> </shadow> <block type="get_value" id="/=dcbV^$;o$c[a5LQX"> <field name="ATTR">val</field> <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_std_abends</field> </block> </value> <value name="MINUTES"> <shadow type="text" id="ASXoyMTds9QyM_CND/_c"> <field name="TEXT">*</field> </shadow> <block type="get_value" id="cEGG^+:}?^PaEhG#Pf^l"> <field name="ATTR">val</field> <field name="OID">javascript.0.Datenpunkte.Flur.Licht.CRON_min_abends</field> </block> </value> </block> </value> <statement name="STATEMENT"> <block type="debug" id="1VGsD:SShZ(YPo1?:aW1"> <field name="Severity">warn</field> <value name="TEXT"> <shadow type="text" id="wLMVRQov~.7Hwr(tt09v"> <field name="TEXT">Zeitplan MAX abends ausschalten gestartet: </field> </shadow> </value> <next> <block type="timeouts_clearinterval" id="dr_kpJ7jjo2b.JJCpOpi"> <field name="NAME">MAX aus</field> <next> <block type="timeouts_clearinterval" id="zo0;BvCl3ljqmCe@lhUD"> <field name="NAME">MAX ein</field> <next> <block type="procedures_callnoreturn" id="2E!l$Sbr?^2=L~v==Kom"> <mutation name="Max dimmen"> <arg name="MAX Wert"></arg> <arg name="MAX erreichbar"></arg> <arg name="MAX aufdimmen aktiv"></arg> <arg name="MAX aufdimmen"></arg> <arg name="MAX Text"></arg> <arg name="MAX Zyklus beendet"></arg> <arg name="MAX Farbwert"></arg> <arg name="MAX ein/aus"></arg> </mutation> <value name="ARG0"> <block type="math_number" id=")!J=OCNEISl$+7S1RLsM"> <field name="NUM">0</field> </block> </value> <value name="ARG1"> <block type="math_number" id="mVq0}k6*dk8g(|tr:~+h"> <field name="NUM">1</field> </block> </value> <value name="ARG2"> <block type="logic_boolean" id="NqyCS;7.:!Fx.iNFa6Ci"> <field name="BOOL">FALSE</field> </block> </value> <value name="ARG3"> <block type="logic_boolean" id="9iBsCu2f{zTBfo--pW,#"> <field name="BOOL">FALSE</field> </block> </value> <value name="ARG4"> <block type="text" id="~{Ti()gN^IFEv*[[Z8^">
                                          <field name="TEXT">Max abends ausschalten -5. Wert: </field>
                                          </block>
                                          </value>
                                          <value name="ARG5">
                                          <block type="text" id="*oQCa[ugwu@tve.i//f"> <field name="TEXT">Zyklus MAX ausschalten abends beendet! Wert: </field> </block> </value> <value name="ARG6"> <block type="math_number" id="T$voOMW{*r1z_6Isb;A2"> <field name="NUM">2730</field> </block> </value> <value name="ARG7"> <block type="text" id="776Wd]9@@}u@@Ik~Z{-N"> <field name="TEXT">aus</field> </block> </value> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </statement> <next> <block type="comment" id="y[bm=SQ8KmXT}!$S5E=J"> <field name="COMMENT">Hue Max automatisch morgens langsam ausschalten</field> <next> <block type="astro" id="VE!zP+,ZHk7o8P6f$5_!"> <field name="TYPE">dawn</field> <field name="OFFSET">20</field> <statement name="STATEMENT"> <block type="debug" id="9F6/6n2FwB;tX]e:0Z%c"> <field name="Severity">warn</field> <value name="TEXT"> <shadow type="text" id=":KpTCwK6a5o=HJeKe~Jw"> <field name="TEXT">Sonnenaufgang 20min später.</field> </shadow> </value> <next> <block type="timeouts_clearinterval" id="iF#*AK@6($?,9pB$sISG"> <field name="NAME">MAX aus</field> <next> <block type="timeouts_clearinterval" id="@w+R1Osl8H5/?^Ipgm$^"> <field name="NAME">MAX ein</field> <next> <block type="procedures_callnoreturn" id="AMBjnh5Eoo,SU!n-w?bc"> <mutation name="Max dimmen"> <arg name="MAX Wert"></arg> <arg name="MAX erreichbar"></arg> <arg name="MAX aufdimmen aktiv"></arg> <arg name="MAX aufdimmen"></arg> <arg name="MAX Text"></arg> <arg name="MAX Zyklus beendet"></arg> <arg name="MAX Farbwert"></arg> <arg name="MAX ein/aus"></arg> </mutation> <value name="ARG0"> <block type="math_number" id="*%]wK0y-ig:K9{%%W%R("> <field name="NUM">0</field> </block> </value> <value name="ARG1"> <block type="math_number" id="yV/@3n2A7/Us.ElZ_iev"> <field name="NUM">1</field> </block> </value> <value name="ARG2"> <block type="logic_boolean" id="_A*M37z6=!*!dHQRH6VN"> <field name="BOOL">FALSE</field> </block> </value> <value name="ARG3"> <block type="logic_boolean" id="%psd|BmgaQJnX|1jqV6x"> <field name="BOOL">FALSE</field> </block> </value> <value name="ARG4"> <block type="text" id="(Rm7:NZtgd2OdWOR1szK"> <field name="TEXT">Max morgens ausschalten -5. Wert: </field> </block> </value> <value name="ARG5"> <block type="text" id="t0.ECvW;(OYjYf+yVWhc"> <field name="TEXT">Zyklus MAX ausschalten morgens beendet! Wert: </field> </block> </value> <value name="ARG6"> <block type="math_number" id="w$@IQeFmq,b!k{!{T(gj"> <field name="NUM">2730</field> </block> </value> <value name="ARG7"> <block type="text" id="Cym~$UbeCt.9xM@kGC
                                          </block>
                                          </value>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </statement>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </next>
                                          </block>
                                          </xml>
                                          habe den Blockly exportiert und als txt Datei hier eingestellt.
                                          Hue_Max.txt
