  4. Wir empfehlen: Node.js 22.x
    6.8k
370 Beiträge 53 Kommentatoren 92.7k Aufrufe 53 Beobachtet
  • bergjetB Offline
    bergjetB Offline
    bergjet
    #256
    Habe den Fixer laufen lassen, jetzt passt es.
    homee, ioBroker, iMac, iPhone, Sonos, Alaxa
    • bergjetB bergjet
      #257
      @bergjet sagte in Wir empfehlen: Node.js 22.x:
      :-D Der macht nur genau gar nichts (direkt) an den Paketquellen.
      Zeig mal per
      iob diag
      wie du da genau unterwegs bist.
      bergjetB 1 Antwort Letzte Antwort
        Zeig mal per
        iob diag
        bergjetB Offline
        bergjetB Offline
        bergjet
        #258
        @Thomas-Braun ```
        Script v.2025-08-09
        *** BASE SYSTEM ***
        Operating System: Raspbian GNU/Linux 11 (bullseye)
           Static hostname: pi4
                 Icon name: computer
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to: debian
        Model		: Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 32 bit
        Systemuptime and Load:
         19:33:52 up  8:39,  1 user,  load average: 0.36, 0.50, 0.47
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Thu 2026-01-15 19:33:52 CET
                   Universal time: Thu 2026-01-15 18:33:52 UTC
                         RTC time: n/a
                        Time zone: Europe/Vienna (CET, +0100)
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server: 	false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session: 		tty
        *** MEMORY ***
        Mem:            7.8G         81M        7.1G        1.0M        601M        7.6G
        Swap:            99M          0B         99M
        Total:          7.9G         81M        7.2G
        Active iob-Instances: 	1
                 7812 M total memory
                   81 M used memory
                  184 M active memory
                  378 M inactive memory
                 7129 M free memory
                  116 M buffer memory
                  485 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 19:33:53 up  8:39,  1 user,  load average: 0.36, 0.50, 0.47
        Tasks: 146 total,   1 running, 145 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  1.5 us,  1.5 sy,  0.0 ni, 97.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7812.3 total,   7128.5 free,     82.0 used,    601.8 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   7607.4 avail Mem
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       29G   11G   18G  38% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.1M  1.6G   1% /run
        /dev/mmcblk0p1 vfat      255M   52M  204M  21% /boot
        tmpfs          tmpfs     782M     0  782M   0% /run/user/1000
        [Thu Jan 15 10:54:43 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:6F:15:63 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=0167a20d-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Thu Jan 15 10:54:44 2026] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Thu Jan 15 10:54:44 2026] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Thu Jan 15 10:54:47 2026] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.7G	/var/
        1.3G	/var/log/journal/cc5e24afcfff49949c0835065fe598da
        1.3G	/var/log
        1.3G	/var/cache/apt
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        144M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        684M	/opt/iobroker/iobroker-data/
        384M	/opt/iobroker/iobroker-data/files
        139M	/opt/iobroker/iobroker-data/node-red
        138M	/opt/iobroker/iobroker-data/node-red/node_modules
        111M	/opt/iobroker/iobroker-data/backup-objects
        41M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
        32M	/opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
        31M	/opt/iobroker/iobroker-data/objects.jsonl
        19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
        9.9M	/opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
        USB-Devices by-id:
        No Devices found 'by-id'
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v22.15.0
        /usr/bin/node 		v22.15.0
        /usr/bin/npm 		10.9.2
        /usr/bin/npx 		10.9.2
        /usr/bin/corepack 	0.32.0
        nodejs:
          Installed: 22.15.0-1nodesource1
          Candidate: 22.15.0-1nodesource1
          Version table:
         *** 22.15.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main armhf Packages
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u7 500
        No problems detected
        Errors in npm tree: 0
        The current Node.js version (v22.15.0) is vulnerable to the following CVEs:
        CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
        Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
        CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
        This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
        Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
        CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
        CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
        CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
        server.on('secureConnection', socket => {
        socket.on('error', err => {
        console.log(err)
        CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when `async_hooks.createHook()` is enabled. Instead of reaching `process.on('uncaughtException')`, the process terminates, making the crash unrecoverable. Applications that rely on `AsyncLocalStorage` (v22, v20) or `async_hooks.createHook()` (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
        CVE-2026-21637(medium): A flaw in Node.js TLS error handling allows remote attackers to crash or exhaust resources of a TLS server when `pskCallback` or `ALPNCallback` are in use. Synchronous exceptions thrown during these callbacks bypass standard TLS error handling paths (tlsClientError and error), causing either immediate process termination or silent file descriptor leaks that eventually lead to denial of service. Because these callbacks process attacker-controlled input during the TLS handshake, a remote client can repeatedly trigger the issue. This vulnerability affects TLS servers using PSK or ALPN callbacks across Node.js versions where these callbacks throw without being safely wrapped.
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        pi4                 pi4 (version: 7.0.7, hostname: pi4           , alive, uptime: 30993)
        Core adapters versions
        js-controller: 	7.0.7
        admin: 		7.7.19
        javascript: 	8.9.2
        nodejs modules from github: 	6
        +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.bambulab.git#10f9040fecd5044ccb9825bfb7b1f452deae16d4)
        +-- iobroker.husqvarna-automower@0.4.0 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#79e34f134df5a479f40dff73e833a55620cd72c6)
        +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#0921ba9cef4d6b62375f339126457f3429d0448f)
        +-- iobroker.trashschedule@4.0.0 (git+ssh://git@github.com/klein0r/ioBroker.trashschedule.git#d640860880666638c94546ca1c4961eca3834347)
        +-- iobroker.vis-materialdesign@0.5.76 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#43f3a07d7b48f367612c19ef678935709f718aae)
        +-- iobroker.web@7.0.9 (git+ssh://git@github.com/ioBroker/ioBroker.web.git#fdc0ef642f146a592a108deffc53297d0bf16dcb)
        Adapter State
          system.adapter.admin.0                  : admin                 : pi4                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : pi4                                      -  enabled
          system.adapter.backitup.0               : backitup              : pi4                                      -  enabled
          system.adapter.bambulab.0               : bambulab              : pi4                                      - disabled, port: 8883
          system.adapter.coronavirus-statistics.0 : coronavirus-statistics: pi4                                      - disabled
          system.adapter.daswetter.0              : daswetter             : pi4                                      -  enabled
          system.adapter.discovery.0              : discovery             : pi4                                      -  enabled
          system.adapter.email.0                  : email                 : pi4                                      - disabled
          system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: pi4                                      -  enabled
          system.adapter.fakeroku.0               : fakeroku              : pi4                                      -  enabled
          system.adapter.flot.0                   : flot                  : pi4                                      -  enabled
          system.adapter.fritzbox.0               : fritzbox              : pi4                                      -  enabled
          system.adapter.fronius-solarweb.0       : fronius-solarweb      : pi4                                      - disabled
          system.adapter.fronius.0                : fronius               : pi4                                      -  enabled
          system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : pi4                                      -  enabled
          system.adapter.geofency.0               : geofency              : pi4                                      -  enabled, port: 7999, bind: 0.0.0.0
          system.adapter.harmony.0                : harmony               : pi4                                      -  enabled
          system.adapter.history.0                : history               : pi4                                      -  enabled
          system.adapter.homee.0                  : homee                 : pi4                                      -  enabled
          system.adapter.hue-extended.0           : hue-extended          : pi4                                      -  enabled
          system.adapter.hue.0                    : hue                   : pi4                                      -  enabled, port: 443
          system.adapter.husqvarna-automower.0    : husqvarna-automower   : pi4                                      -  enabled
          system.adapter.ical.0                   : ical                  : pi4                                      -  enabled
          system.adapter.ical.1                   : ical                  : pi4                                      -  enabled
          system.adapter.ical.2                   : ical                  : pi4                                      -  enabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : pi4                                      -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi4                                      -  enabled
          system.adapter.iot.0                    : iot                   : pi4                                      -  enabled
          system.adapter.javascript.0             : javascript            : pi4                                      -  enabled
          system.adapter.lgtv.0                   : lgtv                  : pi4                                      - disabled
          system.adapter.material.0               : material              : pi4                                      -  enabled
          system.adapter.meross.0                 : meross                : pi4                                      -  enabled
          system.adapter.mobile.0                 : mobile                : pi4                                      -  enabled
          system.adapter.mqtt.0                   : mqtt                  : pi4                                      -  enabled, port: 1883, bind: 0.0.0.0
          system.adapter.mytime.0                 : mytime                : pi4                                      - disabled
          system.adapter.netatmo.0                : netatmo               : pi4                                      -  enabled
          system.adapter.node-red.0               : node-red              : pi4                                      -  enabled, port: 1880, bind: 0.0.0.0
          system.adapter.nuki.0                   : nuki                  : pi4                                      -  enabled
          system.adapter.openweathermap.0         : openweathermap        : pi4                                      - disabled
          system.adapter.ping.0                   : ping                  : pi4                                      -  enabled
          system.adapter.pushover.0               : pushover              : pi4                                      -  enabled
          system.adapter.rpi2.0                   : rpi2                  : pi4                                      -  enabled
          system.adapter.sayit.0                  : sayit                 : pi4                                      -  enabled
          system.adapter.shelly.0                 : shelly                : pi4                                      - disabled, port: 1882, bind: 0.0.0.0
          system.adapter.simple-api.0             : simple-api            : pi4                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartthings.0            : smartthings           : pi4                                      - disabled
          system.adapter.sonos.0                  : sonos                 : pi4                                      -  enabled
          system.adapter.telegram.0               : telegram              : pi4                                      -  enabled, port: 8443, bind: 0.0.0.0
          system.adapter.text2command.0           : text2command          : pi4                                      -  enabled
          system.adapter.tr-064.0                 : tr-064                : pi4                                      -  enabled
          system.adapter.trashschedule.0          : trashschedule         : pi4                                      -  enabled
          system.adapter.vis-bars.0               : vis-bars              : pi4                                      -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : pi4                                      -  enabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : pi4                                      -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : pi4                                      -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi4                                      -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : pi4                                      -  enabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : pi4                                      -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi4                                      -  enabled
          system.adapter.vis-justgage.0           : vis-justgage          : pi4                                      -  enabled
          system.adapter.vis-map.0                : vis-map               : pi4                                      -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi4                                      -  enabled
          system.adapter.vis-metro.0              : vis-metro             : pi4                                      -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi4                                      -  enabled
          system.adapter.vis.0                    : vis                   : pi4                                      -  enabled
          system.adapter.weather-warnings.0       : weather-warnings      : pi4                                      -  enabled
          system.adapter.web.0                    : web                   : pi4                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yeelight-2.0             : yeelight-2            : pi4                                      -  enabled
          system.adapter.zwave2.0                 : zwave2                : pi4                                      - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.7.19   , installed 7.7.19
        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
        Adapter    "backitup"     : 3.3.13   , installed 3.3.13
        Adapter    "coronavirus-statistics": 0.9.0, installed 0.9.0
        Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
        Adapter    "email"        : 2.0.4    , installed 2.0.4
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
        Adapter    "fakeroku"     : 0.3.0    , installed 0.3.0
        Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
        Adapter    "fronius"      : 2.1.1    , installed 2.1.1
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
        Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "harmony"      : 1.5.0    , installed 1.5.0
        Adapter    "homee"        : 1.2.0    , installed 1.2.0
        Adapter    "hue"          : 3.16.2   , installed 3.16.2
        Adapter    "ical"         : 1.18.1   , installed 1.18.1
        Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
        Adapter    "iot"          : 5.0.7    , installed 5.0.7
        Adapter    "javascript"   : 9.0.11   , installed 8.9.2  [Updatable]
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
        Adapter    "material"     : 1.3.1    , installed 1.3.1
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "mytime"       : 2.3.0    , installed 2.3.0
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "nuki"         : 2.0.0    , installed 2.0.0
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "ping"         : 1.7.9    , installed 1.7.9
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
        Adapter    "sayit"        : 5.0.0    , installed 5.0.0
        Adapter    "shelly"       : 10.4.1   , installed 10.4.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "text2command" : 4.0.0    , installed 3.0.3  [Updatable]
        Adapter    "trashschedule": 3.3.0    , installed 4.0.0
        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.76
        Adapter    "weather-warnings": 0.10.0, installed 0.10.0
        Adapter    "web"          : 7.0.8    , installed 7.0.9
        Adapter    "yeelight-2"   : 1.5.2    , installed 1.5.2
        Adapter    "zwave2"       : 3.1.0    , installed 3.1.0
        Objects and States
        Objects: 	27219
        States: 	23420
        Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
        Hit:3 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14979      510/sshd: /usr/sbin
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14981      510/sshd: /usr/sbin
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12692      377/avahi-daemon: r
        udp        0      0 0.0.0.0:60348           0.0.0.0:*                           108        12694      377/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15100      680/dhcpcd
        udp6       0      0 :::37373                :::*                                108        12695      377/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        12693      377/avahi-daemon: r
        2026-01-15 19:31:49.286  - info: host.pi4 instance system.adapter.discovery.0 terminated with code null ()
        2026-01-15 19:31:49.286  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.352  - warn: host.pi4 instance system.adapter.web.0 terminated due to SIGKILL
        2026-01-15 19:31:49.353  - info: host.pi4 instance system.adapter.web.0 terminated with code null ()
        2026-01-15 19:31:49.353  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.430  - warn: host.pi4 instance system.adapter.husqvarna-automower.0 terminated due to SIGKILL
        2026-01-15 19:31:49.430  - info: host.pi4 instance system.adapter.husqvarna-automower.0 terminated with code null ()
        2026-01-15 19:31:49.430  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.487  - warn: host.pi4 instance system.adapter.iot.0 terminated due to SIGKILL
        2026-01-15 19:31:49.487  - info: host.pi4 instance system.adapter.iot.0 terminated with code null ()
        2026-01-15 19:31:49.488  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.548  - warn: host.pi4 instance system.adapter.text2command.0 terminated due to SIGKILL
        2026-01-15 19:31:49.548  - info: host.pi4 instance system.adapter.text2command.0 terminated with code null ()
        2026-01-15 19:31:49.549  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.607  - warn: host.pi4 instance system.adapter.weather-warnings.0 terminated due to SIGKILL
        2026-01-15 19:31:49.608  - info: host.pi4 instance system.adapter.weather-warnings.0 terminated with code null ()
        2026-01-15 19:31:49.608  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.665  - warn: host.pi4 instance system.adapter.javascript.0 terminated due to SIGKILL
        2026-01-15 19:31:49.665  - info: host.pi4 instance system.adapter.javascript.0 terminated with code null ()
        2026-01-15 19:31:49.666  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.829  - warn: host.pi4 Cannot get view: Connection is closed.
        2026-01-15 19:31:49.831  - warn: host.pi4 instance system.adapter.meross.0 terminated due to SIGKILL
        2026-01-15 19:31:49.831  - info: host.pi4 instance system.adapter.meross.0 terminated with code null ()
        2026-01-15 19:31:49.831  - info: host.pi4 All instances are stopped.
        2026-01-15 19:31:49.886  - info: host.pi4 terminated
        iob diag has finished.
        pi@pi4:~ $
        • bergjetB Offline
          bergjetB Offline
          bergjet
          #259
          Jetzt zeigt es mir wieder die Version 22.15.0 an
          • bergjetB bergjet
            #260
            mit dem längst EOL
            in Verbindung mit
            Userland : 32 bit
            wird es wohl nichts höheres geben.
            Neuinstallation mit Debian 13 (Trixie) in 64Bit ist angesagt
              mit dem längst EOL
              in Verbindung mit
              Userland : 32 bit
              #261
              @Homoran sagte in Wir empfehlen: Node.js 22.x:
              Exakt...
              • bergjetB Offline
                bergjetB Offline
                bergjet
                schrieb am zuletzt editiert von bergjet
                #262
                Was ich auch versuche, beim Zugriff mit SSH kommt die Meldung "Permission denied (publickey)".
                Installiert hätte ich mit dem Raspberry PI Imager das 64 Bit Lite Debian Trixi.
                Alles schon x mal versucht auf einem iMac.
                • bergjetB bergjet
                  #263
                  SSH aktiviert?
                  ansonsten passt möglicherweise
                  (publickey)
                  zu
                  iMac
                  da hab ich keinen Schimmer von
                  • bergjetB bergjet
                    #264
                    @bergjet
                    Du wirst auf dem Mac einen alten key haben. Lösch den (wo auch immer der dort abgelegt wird), dann müsste beim neuen Einloggen ein neuer publickey ausgehandelt werden.
                      @bergjet
                      TT-Tom
                      #265
                      @Thomas-Braun sagte in Wir empfehlen: Node.js 22.x:
                      @bergjet
                      Sollte unter username/.ssh/… liegen
                      Gruß Tom
                      Public Transport
                      NSPanel Adapter Wiki
                      • bergjetB Offline
                        bergjetB Offline
                        bergjet
                        #266
                        Danke, ja war ein alter key. Und ja, er liegt unter unter username/.ssh/
                        • CyberraphC Online
                          CyberraphC Online
                          Cyberraph
                          #267
                          Hallo Zusammen!
                          Ein Großer Dank an @thomas-braun und generell alle schlauen Leute hier.
                          Konnte zuerst sauber von bookworm auf nun trixie updaten (RPI5).
                          Und hiermit auch sauber nun auf die aktuellste NodeJS Version.
                          Vielen vielen Dank auch hier und weiter mit der guten Arbeit. :-)
                          Beste Grüße!
                          io-Broker Neuling 2024 :-)
                          Bislang jedoch einiges an Beiträgen und Grundlagen eingeflößt, um etwas besser empor zu irren.
                          • I Offline
                            I Offline
                            ivo-int
                            #268
                            Hallo zusammen
                            Ich habe mein System ebenfalls auf "trixie" hochgezogen.
                            ```bash
                            Script v.2025-08-09
                            *** BASE SYSTEM ***
                            Operating System: Debian GNU/Linux 13 (trixie)
                             Static hostname: RaspberryPi4-IOBroker
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Model           : Raspberry Pi 4 Model B Rev 1.2
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 32 bit
                            Welches ist nun die aktuellste Node.js Version?
                            Bei mir ist immer noch V22.15.0 und NPM 10.9.2 aktuell. Ich kann die neuere Version mit "iob nodejs-update" nicht installieren.
                            Mache ich hier etwas falsch?
                            Gruss Ivo
                            • H Offline
                              hanand
                              #269
                              Hallo an alle,
                              ich hoffe ich bin hier richtig um vielleicht andere vor ähnlichen Problemen zu bewahren bzw. evt. zu helfen.
                              Im Zusammenhang mit dem empfohlenen Update auf node.js 22.x traten bei mir folgende Probleme auf, welche ich letztendlich nur mit einem Downgrade auf node.js 20.x beheben konnte:
                              1. im MBus Adapter war die Schnittstelle weg und lies sich auch nicht mehr einstellen. Hier war der Workaround (wie im Forum zu lesen) Adapter löschen und neu anlegen.
                              2. Zigbee2mqtt lief sehr instabil. Ich hatte das erst gar nicht so mitbekommen, da die Werte grundsätzlich da waren. Aber die Verbindung vom zigbee2mqtt Dienst zum Zigbee-Coordinator würde ständig ab- und wieder aufgebaut. Das Thema liegt also nicht auf der Seite vom iobroker sondern an seiner Peripherie. Ich weiß nicht ob jemand dafür eine Lösung hat?
                                Ansonsten bin ich hochgradig begeistert was hier so geleistet wird. Vielen Dank von mir und bis bald
                              • H hanand
                                Hallo an alle,
                                mcm1957M Online
                                mcm1957M Online
                                mcm1957
                                #270
                                @hanand sagte in Wir empfehlen: Node.js 22.x:
                                Hallo an alle,
                                Ich hoffe du hast deine Probleme bei den entsprechenden Adaptern eingemeldet und dort Issues erstellt. Von einem Downgrade auf node.js 20 wird jedenfalls abgeraten - das ist maximal die allerletzte Notmassnahme.
                                Node.js 20 erreicht im April 2026 EOL, wird nicht mehr gewartet und wird ab diesem Zeitpunkt mit hoher Wahrscheinlichkeit von immer mehr Adaptern nicht mehr unterstützt werden. Du benutzt also im Moment zwar ein noch nicht totes Pferd aber eins dass bereits in der Pallativabteilung liegt.
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • I ivo-int
                                  Hallo zusammen
                                  ```bash
                                  Script v.2025-08-09
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 32 bit
                                  Gruss Ivo
                                  #271
                                  @ivo-int sagte in Wir empfehlen: Node.js 22.x:
                                  Für 32Bit wird nichts aktuelleres angeboten.
                                  Installier da NEU die 64 Bit Lite Version von Raspberry OS.
                                  Darüber hinaus wird auch der falsche Kernel geladen.
                                  • I Offline
                                    I Offline
                                    ivo-int
                                    #272
                                    Ich habe mit "Buster" auf 64Bit umgestellt. Dies habe ich mit dieser Anleitungvorgenommen.
                                    Ist die falsche Linux Version installiert?
                                    Mit der "Bookworm" Version hat es immer funktioniert. An Weihnachten habe ich das Upgrade auf "Trxie" vorgenommen.
                                    • I ivo-int
                                      #273
                                      @ivo-int
                                      NEIN, du hast NICHT auf 64Bit umgestellt:
                                      Kernel : aarch64
                                      Userland : 32 bit
                                      Dein 'userland' ist weiterhin 32bittig.
                                      Das kannstu du nur per kompletter NEUINSTALLATION auf 64Bit 'umstellen'.
                                      Steht auch so in der Anleitung drin.
                                      Und 'inline upgrades' von buster auf booworm haben auch noch nie für RaspberryOS funktioniert. Auch da hätte eine Neuinstallation vorgenommen werden müssen.
                                      I 1 Antwort Letzte Antwort
                                        @ivo-int
                                        Kernel : aarch64
                                        Userland : 32 bit
                                        I Offline
                                        I Offline
                                        ivo-int
                                        #274
                                        Danke für die Rückmeldung.
                                        Ich habe jetzt das System neu installiert. Das funktioniert mit Backitup problemlos, zum Glück.
                                        Somit ist mein Problem gelöst.
                                        Danke nochmals
                                        Gruss Ivo
                                        • I ivo-int
                                          Danke nochmals
                                          Gruss Ivo
                                          #275
                                          Das war ja auch die einzige Option.
