  4. Test Adapter hoymiles-ms v0.2.x
    6.8k
hoymiles-ms mcm1957
100 Beiträge 12 Kommentatoren 7.4k Aufrufe 12 Beobachtet
  • Q Offline
    Q Offline
    quinti
    hier der debug log vom Absturz bei Anmeldung mqtt Explorer:
    host.iobroker	2026-01-11 10:22:40.376	error	instance system.adapter.hoymiles-ms.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    hoymiles-ms.0	2026-01-11 10:22:40.288	info	terminating
    hoymiles-ms.0	2026-01-11 10:22:39.788	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    hoymiles-ms.0	2026-01-11 10:22:39.787	info	terminating
    hoymiles-ms.0	2026-01-11 10:22:39.785	error	Cannot read properties of undefined (reading 'replace')
    hoymiles-ms.0	2026-01-11 10:22:39.784	error	TypeError: Cannot read properties of undefined (reading 'replace') at filterDevId (/opt/iobroker/node_modules/iobroker.hoymiles-ms/build/lib/states.js:1182:18) at initStates (/opt/iobroker/node_modules/iobroker.hoymiles-ms/build/lib/states.js:1185:22) at HoymilesMqtt.onMqttSubscribe (/opt/iobroker/node_modules/iobroker.hoymiles-ms/build/lib/hoymilesMqtt.js:94:39) at HoymilesMsAdapter.mqttEventCallback (/opt/iobroker/node_modules/iobroker.hoymiles-ms/build/main.js:74:61) at /opt/iobroker/node_modules/iobroker.hoymiles-ms/build/lib/mqttServer.js:83:37 at Array.forEach (<anonymous>) at Connection.<anonymous> (/opt/iobroker/node_modules/iobroker.hoymiles-ms/build/lib/mqttServer.js:81:34) at Connection.emit (node:events:507:28) at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8) at Connection.emit (node:events:507:28)
    hoymiles-ms.0	2026-01-11 10:22:39.784	error	unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
    hoymiles-ms.0	2026-01-11 10:22:39.784	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    hoymiles-ms.0	2026-01-11 10:22:39.784	debug	[hoymilesMqtt] process subscription $SYS/#
    hoymiles-ms.0	2026-01-11 10:22:39.784	debug	[MQTT-Server] (mqtt-explorer-5d3f837c) client processing subscription to "$SYS/#"
    hoymiles-ms.0	2026-01-11 10:22:39.784	debug	[MQTT-Server] (mqtt-explorer-5d3f837c) client sending suback id:8291, qos:1"
    hoymiles-ms.0	2026-01-11 10:22:39.784	debug	[MQTT-Server] (mqtt-explorer-5d3f837c) client subscribing to "[{"topic":"$SYS/#","qos":0}]"
    hoymiles-ms.0	2026-01-11 10:22:39.784	debug	[hoymilesMqtt] ignoring invalid topic #
    hoymiles-ms.0	2026-01-11 10:22:39.783	debug	[hoymilesMqtt] process subscription #
    hoymiles-ms.0	2026-01-11 10:22:39.783	debug	[MQTT-Server] (mqtt-explorer-5d3f837c) client processing subscription to "#"
    hoymiles-ms.0	2026-01-11 10:22:39.783	debug	[MQTT-Server] (mqtt-explorer-5d3f837c) client sending suback id:8290, qos:1"
    hoymiles-ms.0	2026-01-11 10:22:39.783	debug	[MQTT-Server] (mqtt-explorer-5d3f837c) client subscribing to "[{"topic":"#","qos":0}]"
    hoymiles-ms.0	2026-01-11 10:22:39.778	info	[hoymilesMQTT] client mqtt-explorer-5d3f837c connected from 192.168.1.111
    • Q quinti
      hibattery funktioniert, hatte vergessen den richtigen port in der App einzustellen, sry!
      mcm1957M Online
      mcm1957M Online
      mcm1957
      @quinti sagte in Test Adapter hoymiles-ms v0.2.x:
      Danke f.d. Info.
      Kannst du mir bitte (gern auch als PN an mcm57 at gmx.at) den Connect senden?
      Ich würd gern wissen wie das
      2026-01-08 20:56:31.020  - info: hoymiles-ms.0 (17617) [hoymilesMQTT] client MSA228002437xxxx connected from 192.168.0.142
      2026-01-08 20:56:31.128  - info: hoymiles-ms.0 (17617) Device MSA-28002437xxxx is initializing states
      2026-01-08 20:56:31.284  - info: hoymiles-ms.0 (17617) Device MSA-28002437xxxx is online
      bei dort aussieht.
      Da es immer wieder zu Fakebatterien kommt (wo beim Connect unvollständige Daten gelesen werden) möcht ich gern da checken dass das OK aussieht aber nicht die neuen Akkus gleich mal blockieren :-)
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
      • G Offline
        gs411
        @mcm1957
        Dein Adapter funktioniert mit 3x MS-A2 und 1* HiBattery. Vielen Dank.
        • G gs411
          @mcm1957
          mcm1957M Online
          mcm1957M Online
          mcm1957
          @gs411 sagte in Test Adapter hoymiles-ms v0.2.x:
          @mcm1957
          Danke für die Info.
          Kannst du bitte mal schaun was bei dir im Log steht wenn sich die HiBattery verbindet? #
          Steht da auch MSA-xxxx doer was anderes?
          So sieht das bei mir mit der MS-A2 aus:
          Wie sieht das mit der HiBattery aus? (Seriennummer sicherheitshalber bitte xxen
          • G Offline
            gs411
            schrieb am zuletzt editiert von gs411
            Bei der HiBattery ist der Logeintrag identisch zu MS-A2
            Log-Eintrag der HiBattery
            hoymiles-ms.0
            2026-01-12 15:23:01.510 info [hoymilesMQTT] client MSA2804253xxxxx connected from 10.10.10.115
            • mcm1957M Online
              mcm1957M Online
              mcm1957
              Herzliche DANKESCHÖN
              • andabrahaA Offline
                andabrahaA Offline
                andabraha
                #66
                Habt ihr auch 1x in 24h diese Meldung im iobroker log?
                Ich führe das jetzt nicht auf den Adapter zurück, sondern eher auf den/die Speicher, wollt nur mal wissen ob ihr das auch im Log stehen habt.
                style24S 1 Antwort Letzte Antwort
                • andabrahaA andabraha
                  style24S Offline
                  style24S Offline
                  style24
                  #67
                  @andabraha Hallo bei mir tauchen diese Fehlermeldungen nicht auf
                    Matze2
                    #68
                    Ich sehe diese auch jeden Tag um 01:06 und 01:08 für Master und Slave.
                    • mcm1957M Online
                      mcm1957M Online
                      mcm1957
                      #69
                      Soweit ich es beobachtet habe trennt der Akku nächtens die Verbindung. Warum auch immer.
                      Im Prinzip könnte man die Meldungen unterdrücken - aber dann sieht man sie auch nicht wenn es Probleme gibt.
                      Keine AHnung ob ich da was verbessern kann - zumindest im Moment.
                      @andabraha hast du mehrere MS-A2 oder kommen da immer drei Meldungen von einem Akku ?
                      andabrahaA 1 Antwort Letzte Antwort
                        Matze2
                        #70
                        Also mich stören die Logs nicht.
                        • mcm1957M mcm1957
                          andabrahaA Offline
                          andabrahaA Offline
                          andabraha
                          #71
                          @mcm1957 sagte in Test Adapter hoymiles-ms v0.2.x:
                          Ich habe 3 Akkus der MS-A2 Serie im Haus verteilt
                          Bekannt kommt mir ein Teil der Meldung von anderen MQTT Verbindungen/Sensoren vor also "client error Error: read ECONNRESET"
                          Ob man das nun beheben muss, weiß ich nicht, ein Grund wäre nice2know, aber du hast schon recht, wenns unterdrückt wird, fehlt ggf. im "Ernstfall" etwas.
                          Ich war nur neugierig, ob das bei anderen auch auftaucht.
                          • mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #72
                            ECONNRESET bedeutet dass die TCP Verbindung zurückgesetzt wurde. Das ist ein Netzwerkfehler. An sich sollte bei einer sauberen Trennung kein Error auftreten. Ohne vertiefende Diagnose kann ich allerdings nicht sagen, ob da was im Adapetr verbesserbar wäre oder ob der MS-A2 einfach die Verbindung cancelled ohne dass geeignet mitzuteilen. Liegt mir aber fern einen Fehler uf der anderen Seite zu behaupten ohne dass ich konkretere Hinweise dafür habe. Und die hab ich derzeit nicht.
                            Aber 1 Fehler je Gerät ist an sich erklärbar. Kritischer hätte ich es gesehen wenn da 3 von einem (!) Gerät kurz hintereinader kommen.
                              andabrahaA Offline
                              andabraha
                              #73
                              Wie gesagt, man könnte ja das log-level des Adapters anpassen, kann ja jeder selbst entscheiden
                              Mich stören die Meldungen auch nicht weiter
                                Matze2
                                #74
                                Ich vermute mal eine Art Reset des Speichers, nachdem das immer um 1 Uhr nachts auftritt und auch immer um die selbe Zeit rum.
                                iobroker.2026-01-08.log.gz:2026-01-08 01:06:01.824  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-08.log.gz:2026-01-08 01:08:24.687  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                iobroker.2026-01-09.log.gz:2026-01-09 01:06:01.738  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-09.log.gz:2026-01-09 01:08:04.284  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                iobroker.2026-01-10.log.gz:2026-01-10 01:06:21.896  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-10.log.gz:2026-01-10 01:08:23.996  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                iobroker.2026-01-11.log.gz:2026-01-11 01:06:21.664  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-11.log.gz:2026-01-11 01:08:03.598  - error: hoymiles-ms.0 (499) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                iobroker.2026-01-12.log.gz:2026-01-12 01:06:21.291  - error: hoymiles-ms.0 (768926) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-12.log.gz:2026-01-12 01:08:02.916  - error: hoymiles-ms.0 (768926) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                iobroker.2026-01-13.log.gz:2026-01-13 01:06:01.078  - error: hoymiles-ms.0 (768926) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-13.log.gz:2026-01-13 01:08:02.335  - error: hoymiles-ms.0 (768926) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                iobroker.2026-01-14.log.gz:2026-01-14 01:06:20.518  - error: hoymiles-ms.0 (768926) [MQTT-Server] (MSAMASTER) client error Error: read ECONNRESET
                                iobroker.2026-01-14.log.gz:2026-01-14 01:08:02.295  - error: hoymiles-ms.0 (768926) [MQTT-Server] (MSASLAVE) client error Error: read ECONNRESET
                                • W Offline
                                  W Offline
                                  WurstDLX
                                  schrieb am zuletzt editiert von WurstDLX
                                  #75
                                  Habe heute meinen Hoymiles HiBattery AC erhalten und eingesteckt. Da ich kein Smartmeter, sondern nur ein IR Hichi habe, kann ich die Steuerung noch nicht plugnplay umsetzen. Der Adapter hat die Batterie erkannt und es werden alle Werte angezeigt. Da ich neu im BKW-Speicher Bereich bin, muss ich die Begriffe erst einmal verstehen lernen. Aktuell suche ich, mit welchem mqtt command ich den Akku zum Laden/Entladen zwingen kann. Aktuell lädt der seine Kapazität ins Netz, obwohl unnötig.
                                  • mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #76
                                    Wenn du einen MA-A2 via Adapter betreiben willst, braiuchts du keine mqtt Befehle.
                                    Einfach
                                    Paramater ems_mode.control auf 'mqtt_ctrl' stellen
                                    Parameter power_ctrl.set auf den gewünschten Lade- / Entladeleistungswert setzen. Negative Werte Laden Akku.
                                    Beim HiBattery AC sollte eigentlich ident gehen. Kann nur sein, dass du da die aktuellste Firmware brauchst. EDIT: Da der Speicher seine Werte eh liefert sollte die FW ok sein.
                                    Wenn was nicht geht, bitte ein Issue eröffnen und ein Log mit Level DEBUG anhängen. (Seriennummer im Log invalidieren.) Alternativ Issue + Log bitte per PM (mcm57 at gmx.at)
                                    W 1 Antwort Letzte Antwort
                                    • mcm1957M mcm1957
                                      Einfach
                                      W Offline
                                      W Offline
                                      WurstDLX
                                      #77
                                      @mcm1957 Okay den Mode konnte ich unter
                                      setzen. Mal schauen ob er das akzeptiert. Wie gesagt, ich muss mich mit der grundsätzlichen Logik mal reinfuchsen. Mein Ziel ist es, dass ich eine eigene Lade Logik per js schreiben "muss" und dafür ja die states setzen möchte mit einer gewissen Hysterese. Ich denke nämlich nicht, dass es den Speicher gut tut alle 20s umzuschalten, wenn mal Wolken etc auftreten.
                                      edit: unter
                                      hat er den Befehl noch nicht akzeptiert. Werde gleich mal das Log anschmeißen.
                                      edit2:
                                      Sehe im Log, dass er meldet:
                                      cannot access state MSA-XXXX.power_ctrl.set
                                      • mcm1957M Online
                                        mcm1957M Online
                                        mcm1957
                                        #78
                                        Die Leistung 'andauernd' umzustellen sollte eher egal sein. Wenn man ihn in der Nulleinspeisungseinstellung mit einem Shelly beobachtet ändert er seine Lade-/Entladewerte ununterbrochen.
                                        • W WurstDLX
                                          edit: unter
                                          edit2:
                                          mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #79
                                          @WurstDLX sagte in Test Adapter hoymiles-ms v0.2.x:
                                          edit2:
                                          Bitte mehr log context.
                                          Versteh nicht ganz wer da nicht auf den State zugreifen darf ...
                                          Schreibt das der Adapter ? Oder ein Script ? Oder ...
