  3. Cloud Dienste
  4. Sammelthread : Cloud (free), Cloud.Pro und Alexa-Abbrüche
318 Beiträge 91 Kommentatoren 91.8k Aufrufe
    The Master
    #256
    Egal welcher Cloud Adapter 2.4.4 -2.4.6
    cloud.0 2018-02-11 00:35:56.294 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:35:55.303 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:35:26.283 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:35:25.288 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:34:56.273 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:34:55.279 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:34:26.268 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:34:25.274 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:33:56.264 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:33:55.270 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:33:26.257 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:33:25.260 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:32:56.254 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:32:55.260 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:32:26.247 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:32:25.253 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:31:56.245 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:31:55.251 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:31:26.239 error Error while connecting to cloud: timeout
    cloud.0 2018-02-11 00:31:25.246 info Trying to connect as system.user.admin
    cloud.0 2018-02-11 00:30:56.236 error Error while connecting to cloud: timeout
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      #257
      Timeout liegt (höchstwahrscheinlich) am Server und nicht am Adapter. Hab ich auch.
      • eric2905E Offline
        eric2905E Offline
        eric2905
        #258
        @The Master:
        Egal welcher Cloud Adapter 2.4.4 -2.4.6 `
        Auch hier : Welche Cloud? Pro oder Free?
        Und Log-Auszüge immer in Code-Tags setzen.
        Gruß,
        Eric
        Von unterwegs getippert
          AlCalzoneA Offline
          AlCalzone
          #259
          Läuft seit ca. 1 Uhr heute Nacht wieder. (free)
          • BBTownB Offline
            BBTownB Offline
            BBTown
            #260
            Jetzt war es mal wieder so weit, dass der cloud-Adapter v.2.4.6. (pro) meinte die Geräte seien nicht erreichbar/bereit.
            Zurück auf die v.2.4.4 und alle ausprobierten Geräte reagierten sofort wieder.
            Ergo: für mich ist erneut d.v.2.4.6 (wie bereits die v.2.4.5) unberechenbar und mal erreichbar, und dann eben wieder nicht. So ein unberechenbares Verhalten kenne ich von der v.2.4.4 bis dato nicht.
            • apollon77A Offline
              #261
              Bitte gehe mal in der 2.4.6 in alexa App, lösche alle Geräte und synce neu. Dann besser?
              • BBTownB Offline
                BBTownB Offline
                BBTown
                #262
                @apollon77:
                Bitte gehe mal in der 2.4.6 in alexa App, lösche alle Geräte und synce neu. Dann besser? ` genau das habe ich gestern nach der Installation von 2.4.6 gemacht und zunächst lief der Adapter und Alexa.
                Aber es ist unberechenbar wie lange und wann ja und wann nein.
                AlCalzone hatte bereits den Tip mit dem Löschen und Neu-Sync gegeben, daher gab ich der 2.4.6 eine neue Chance.
                Aber lange vorgehalten hat das ganze nicht.
                Besonders ärgerlich ist, dass alle Gruppen anschließend auch wieder manuell in der Alexa-App eingerichtet werden müssen
                [EDIT] anbei noch ein Auszug von Logs während die v.2.4.6 nicht reagierte
                  AlCalzoneA Offline
                  AlCalzone
                  #263
                  Das wundert mich jetzt, hat WolfspiritM nicht irgendwo geschrieben, dass jetzt nur noch SmartNames als appliance-id verwendet werden und nicht die State-IDs? Für mich sieht das schwer nach der State-ID aus.
                  • Z Offline
                    Z Offline
                    Zippolighter
                    #264
                    Keine neuen Smart Geräte einrichtbar
                    Hallo, weiß jetzt gar nicht ob ich hier noch richtig bin oder ob es einen anderen Thread hierzu gibt oder ob ich einen neuen aufmachen soll.
                    Cloud Adapter 2.4.6, Cloud free
                    Versuche jetzt schon die ganze Zeit ein Javascript Objekt dem Cloud Adapter hinzuzufügen. Aber es passiert gar nichts. Auch nach wechseln der Karteireiter.
                    Ein Neustart vom Cloud Adapter sowie downgrade auf 2.4.4 helfen auch nicht.
                    Hoffe Ihr habt eine Idee
                    Gruß Zippolighter
                    Edit:
                    Habe dann nochmal ein bischen geforscht
                    Der Javascript Eintrag sah bei mir so aus
                    Ein funktionierender sah bei mir so aus
                    Ich habe ihn dann den nicht funktionierenden gelöscht und neu eingerichtet
                    Nachdem ich manuel dann in den RAW Settings den SmartName eingetragen habe,
                    war der Eintrag auch sofort in der Cloud vorhanden.
                    Nach Sync mit Amazon Alexa Skill ioBroker Neue Geräte hinzufügen funktionierte der Eintrag sofort
                    • BBTownB Offline
                      BBTownB Offline
                      BBTown
                      #265
                      Bei mir ist die Kombination Admin v.3.2 in Verbindung mit dem cloud-Adapter v.2.4.6 nach wie vor absolut unzuverlässig.
                      Ständig kommt lediglich die Rückmeldung "Das Geräte reagiert nicht / ist nicht verfügbar"
                      2 Dinge fallen mit dabei auf:
                      In der Alexa App auf meinem Smartphone kann ich die Smart Geräte direkt schalten, ohne Probleme
                      Wenn ich per Sprachkommando nach "Geräten suchen" lasse, reagiert Alexa auf das Sprachkommando, welches zuvor als "Gerät reagiert nicht" erfolglos blieb.
                        AlCalzoneA Offline
                        AlCalzone
                        #266
                        @Zippolighter:
                        Versuche jetzt schon die ganze Zeit ein Javascript Objekt dem Cloud Adapter hinzuzufügen. Aber es passiert gar nichts. Auch nach wechseln der Karteireiter. `
                        Gib dem Objekt mal eine common.role="switch" und probier es dann. Die neueren Versionen versuchen anhand dieser, schlaue Entscheidungen zum Schalten zu treffen.
                        • F Offline
                          FoxMulder
                          #267
                          Bei mir seid heute :
                          Gesendet von meinem SM-G950F mit Tapatalk
                            maxeddy
                            #268
                            Seit Stunden ist keine Anmeldung beim Cloud-Adapter (free) möglich. Habe alle o.g. Probleme/Fälle (alles neu einrichten usw.) auch erlebt.
                            Ich würde die "pro-Version" ja auch kaufen. Befürchte nur , wenn es viele machen, läuft die auch nicht mehr stabil und "geschenkt" bekommt man sie auch nicht gerade.
                            1-2 Tage kann man gut Alexa nutzen und dann gibt es zig Stunden wieder keine Verbindung zum cloud-Adapter.
                            cloud.0 2018-02-15 18:08:36.190 error Error while connecting to cloud: timeout
                            cloud.0 2018-02-15 18:08:35.234 info Trying to connect as system.user.admin
                            Version 2.4.6
                            • W Online
                              W Online
                              Wildbill
                              #269
                              Weil es so schön passt und ich vermute, dass der eine oder andere die Cloud nur verwendet um ioBroker mit Alexa zu steuern. Das geht auch ohne die Cloud mittels node-red: http://forum.iobroker.net/viewtopic.php?f=37&t=11302
                              Wer die Cloud nicht für den Zugriff von unterwegs braucht, der kann den Adapter dann beenden oder gar löschen und Alexa macht trotzdem brav mit. Das könnte den Cloud-Server ja vielleicht mit entlasten, wenn hier der eine oder andere umsteigt…
                              Gruss, Jürgen
                              • TJJochenT Offline
                                TJJochenT Offline
                                TJJochen
                                #270
                                Was ist denn los? Warum ist der Cloudserver mal wieder futsch?
                                • eric2905E Offline
                                  eric2905E Offline
                                  eric2905
                                  #271
                                  Sieht wohl so aus ….
                                  Warum? Mal meine Glaskugel suchen ...
                                  Habe gerade was dazu gepostet.
                                  • eric2905E Offline
                                    eric2905E Offline
                                    eric2905
                                    #272
                                    Siehe hier:
                                    http://forum.iobroker.net/viewtopic.php?f=8&t=11841
                                    Gruß,
                                    Eric
                                      AlCalzoneA Offline
                                      AlCalzone
                                      #273
                                      @maxeddy:
                                      Ich würde die "pro-Version" ja auch kaufen. Befürchte nur , wenn es viele machen, läuft die auch nicht mehr stabil und "geschenkt" bekommt man sie auch nicht gerade. `
                                      Wenn es viele machen, hat Bluefox genug Einnahmen, um den Server hochzuskalieren und dabei nicht aus eigener Tasche drauf zu legen ;)
                                      So herum solltest du es mal sehen ;)
                                        maxeddy
                                        #274
                                        Hallo Jürgen. Danke für den Tipp (Das geht auch ohne die Cloud mittels node-red: viewtopic.php?f=37&t=11302)
                                        Genau das habe ich schon gesucht. Läuft prima. Geräte und Schalter (FS20-Steckdosen, angesteuert über Broadlink) können schnell eingerichtet werden. Bei Szenen und Scripten suche ich noch den richtigen Weg. Nochmals Danke. Für mich hat sich der "cloud-Adapter" erledigt.
                                        Auf "Geschäftemacherei" mit unsicherem Ausgang (s. pro-Version) stehe ich nicht.
                                        • eric2905E Offline
                                          eric2905E Offline
                                          eric2905
                                          #275
                                          @maxeddy:
                                          Auf "Geschäftemacherei" mit unsicherem Ausgang (s. pro-Version) …. `
                                          Könntest Du diese Aussage bitte etwas spezifizieren?
