  3. Off Topic
  4. Pflege des Betriebssystems
  5. MQTT Adapter does not start any more after raspi-crash
    6.4k
Geplant Angeheftet Gesperrt Verschoben Ungelöst Pflege des Betriebssystems
43 Beiträge 6 Kommentatoren 1.9k Aufrufe 5 Beobachtet
  • N Offline
    N Offline
    NoPlayBack 0
    • Adaptername: ...MQTT Broker/Client
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 6.1.4
    • js-controller Version: 7.07.
    • Admin Version: 7.7.19
    • Hardwaresystem: Pi5
    • Arbeitsspeicher: 8GB
    • Festplattenart: SSD
    • Betriebssystem: Trixie
    • Nodejs-Version: 22.21.0
    • NPM-Version: 10.9.4
    • Installationsart: Skript
    • Image, Docker genutzt: Nein
    • Ort, Name der Imagedatei: NA
    Linux User bitte hier den Output von iob diag einfügen.
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: raspberrypi01
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     13:08:00 up  1:16,  4 users,  load average: 0.12, 0.08, 0.09
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sat 2026-01-03 13:08:01 CET
               Universal time: Sat 2026-01-03 12:08:01 UTC
                     RTC time: Sat 2026-01-03 12:08:01
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev lpadmin gpio i2c spi render input iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         true
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            8.5G        3.4G        3.4G        152M        1.9G        5.1G
    Swap:           2.1G          0B        2.1G
    Total:           10G        3.4G        5.6G
    Active iob-Instances:   18
             8059 M total memory
             3211 M used memory
             3347 M active memory
              933 M inactive memory
             3251 M free memory
              124 M buffer memory
             1702 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 13:08:01 up  1:16,  4 users,  load average: 0.12, 0.08, 0.09
    Tasks: 301 total,   1 running, 300 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 97.7 id,  2.3 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8059.0 total,   3248.2 free,   3213.8 used,   1828.7 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4845.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     1.6G   20M  1.6G   2% /run
    /dev/nvme0n1p2 ext4      234G   78G  144G  36% /
    tmpfs          tmpfs     4.0G  912K  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     4.0G  9.7M  4.0G   1% /tmp
    /dev/nvme0n1p1 vfat      511M   79M  433M  16% /boot/firmware
    tmpfs          tmpfs     806M  544K  806M   1% /run/user/1000
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA10.service
    [Sat Jan  3 11:51:27 2026] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:9E:6A:69 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=b035d9c0-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sat Jan  3 11:51:29 2026] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
    [Sat Jan  3 11:51:29 2026] EXT4-fs (nvme0n1p2): mounted filesystem 37d2cb52-513e-40e1-b90f-213aa6096cba ro with ordered data mode. Quota mode: none.
    [Sat Jan  3 11:51:30 2026] EXT4-fs (nvme0n1p2): re-mounted 37d2cb52-513e-40e1-b90f-213aa6096cba r/w.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    33G     /var/
    30G     /var/lib
    29G     /var/lib/mysql
    12G     /var/lib/mysql/senec
    10G     /var/lib/mysql/climatecontrol
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    23M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    219M    /opt/iobroker/iobroker-data/
    153M    /opt/iobroker/iobroker-data/files
    52M     /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    8.8M    /opt/iobroker/iobroker-data/objects.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
    5.1M    /opt/iobroker/iobroker-data/states.jsonl
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi01       raspberrypi01 (version: 7.0.7, hostname: raspberrypi01 , alive, uptime: 3361)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     8.9.2
    nodejs modules from github:     2
    +-- iobroker.husqvarna-automower@0.6.0-beta.12 (git+ssh://git@github.com/ice987987/ioBroker.husqvarna-automower.git#d0df35eeb074d8ffb02a30ee0c27b72b03216108)
    +-- iobroker.rpi2@2.4.0 (git+ssh://git@github.com/Grothesk242/ioBroker.rpi2.git#4520729d0399a57717ea36573d39a726b120a048)
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi01                            -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : raspberrypi01                            -  enabled
    + system.adapter.bshb.0                   : bshb                  : raspberrypi01                            -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi01                            -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi01                            -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : raspberrypi01                            -  enabled
    + system.adapter.husqvarna-automower.0    : husqvarna-automower   : raspberrypi01                            -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi01                            -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi01                            -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.nut.0                    : nut                   : raspberrypi01                            -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspberrypi01                            -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi01                            -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi01                            -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sql.0                    : sql                   : raspberrypi01                            -  enabled, port: 3306
    + system.adapter.tibberlink.0             : tibberlink            : raspberrypi01                            -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspberrypi01                            -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi01                            -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi01                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bshb"         : 0.5.0    , installed 0.5.0
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "javascript"   : 9.0.11   , installed 8.9.2  [Updatable]
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sql"          : 3.0.1    , installed 3.0.1
    Adapter    "tibberlink"   : 6.0.3    , installed 6.0.3
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Objects and States
    Objects:        3572
    States:         2778
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://deb.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian trixie InRelease
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 4
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          12404      1330/smbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11348      1316/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5263       1/init
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          12403      1330/smbd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          9831       1296/cupsd
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       34357      4622/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33041      4410/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       33036      4410/iobroker.js-co
    tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      111        9561       1146/mariadbd
    tcp        0      0 0.0.0.0:3493            0.0.0.0:*               LISTEN      0          9496       1072/upsd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          12402      1330/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11351      1316/sshd: /usr/sbi
    tcp6       0      0 :::111                  :::*                    LISTEN      0          263        1/init
    tcp6       0      0 :::445                  :::*                    LISTEN      0          12401      1330/smbd
    tcp6       0      0 :::5900                 :::*                    LISTEN      985        9551       1098/wayvnc
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          9830       1296/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      113        13620      1260/grafana
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       34590      4789/io.simple-api.
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       34537      4744/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       33086      4431/io.admin.0
    tcp6       0      0 :::3306                 :::*                    LISTEN      111        9562       1146/mariadbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           101        6532       726/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       34441      4684/io.shelly.0
    udp        0      0 0.0.0.0:39626           0.0.0.0:*                           101        6534       726/avahi-daemon: r
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          4576       1/init
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          8120       1283/nmbd
    udp        0      0 192.168.178.101:137     0.0.0.0:*                           0          8119       1283/nmbd
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          8116       1283/nmbd
    udp        0      0 192.168.178.124:137     0.0.0.0:*                           0          8115       1283/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          8100       1283/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          8122       1283/nmbd
    udp        0      0 192.168.178.101:138     0.0.0.0:*                           0          8121       1283/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          8118       1283/nmbd
    udp        0      0 192.168.178.124:138     0.0.0.0:*                           0          8117       1283/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          8101       1283/nmbd
    udp6       0      0 fe80::3782:de7b:aa2:546 :::*                                0          18298      779/NetworkManager
    udp6       0      0 fe80::e80d:455f:41e:546 :::*                                0          11668      779/NetworkManager
    udp6       0      0 :::5353                 :::*                                101        6533       726/avahi-daemon: r
    udp6       0      0 :::52997                :::*                                101        6535       726/avahi-daemon: r
    udp6       0      0 :::111                  :::*                                0          5264       1/init
        at StatesInMemoryServer.handleSubscribe (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/inMemFileDB.ts:323:59)
        at StatesInMemoryServer._subscribeForClient (file:///opt/iobroker/node_modules/@iobroker/db-states-file/src/lib/states/statesInMemFileDB.js:240:14)
        at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-jsonl/src/lib/states/statesInMemServerRedis.js:380:26)
        at RedisHandler.emit (node:events:519:28)
        at RedisHandler.emit (node:domain:489:12)
        at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37)
        at processImmediate (node:internal/timers:485:21)
    2026-01-03 12:13:12.361  - error: web.0 (4744) Cannot subscribe "http://raspberrypi01:3000/d/BlDiLtmgk/mobilealerts03?orgId=1&refresh=1m&kiosk": Error The pattern "http://raspberrypi01:3000/d/BlDiLtmgk/mobilealerts03?orgId=1&refresh=1m&kiosk" is not a valid ID pattern
    2026-01-03 12:13:15.040  - info: host.raspberrypi01 instance system.adapter.husqvarna-automower.0 in version "0.6.0-beta.12" (non-npm: ice987987/ioBroker.husqvarna-automower#d0df35eeb074d8ffb02a30ee0c27b72b03216108) started with pid 4774
    2026-01-03 12:13:15.775  - info: husqvarna-automower.0 (4774) starting. Version 0.6.0-beta.12 (non-npm: ice987987/ioBroker.husqvarna-automower#d0df35eeb074d8ffb02a30ee0c27b72b03216108) in /opt/iobroker/node_modules/iobroker.husqvarna-automower, node: v22.21.0, js-controller: 7.0.7
    2026-01-03 12:13:15.784  - info: husqvarna-automower.0 (4774) starting adapter "husqvarna-automower"...
    2026-01-03 12:13:15.944  - info: husqvarna-automower.0 (4774) "Husqvarna Authentication API Access token" received.
    2026-01-03 12:13:16.221  - info: husqvarna-automower.0 (4774) Mowerdata initially saved.
    2026-01-03 12:13:16.275  - info: husqvarna-automower.0 (4774) State value to set for "husqvarna-automower.0.65aee08a-aca4-4d4b-bef4-96ef3ebb40d6.stayOutZones.zones" has to be stringified but received type "object"
    2026-01-03 12:13:16.431  - info: husqvarna-automower.0 (4774) Connection to "Husqvarna WebSocket" established. Ready to get data...
    2026-01-03 12:13:19.038  - info: host.raspberrypi01 instance system.adapter.simple-api.0 in version "2.8.0" started with pid 4789
    2026-01-03 12:13:19.952  - info: simple-api.0 (4789) starting. Version 2.8.0 in /opt/iobroker/node_modules/iobroker.simple-api, node: v22.21.0, js-controller: 7.0.7
    2026-01-03 12:13:19.963  - info: simple-api.0 (4789) simpleAPI server listening on port 8087
    2026-01-03 12:13:19.963  - info: simple-api.0 (4789) Allow states only when user is owner: false
    2026-01-03 12:13:19.970  - info: simple-api.0 (4789) http server listening on port 8087
    2026-01-03 12:44:04.927  - warn: tibberlink.0 (4699) Error (Unknown Status) occurred during: -pull of prices tomorrow- : Request timeout for https://api.tibber.com/v1-beta/gql
    2026-01-03 12:56:09.790  - info: shelly.0 (4684) [CoAP] Device 192.168.178.6 (shellyflood / shellyflood-441793220A77 / SHWT-1#441793220A77#1) connected! Polltime set to 3600 sec.
    2026-01-03 12:57:42.034  - info: daikin-cloud.0 (4607) Daikin-Cloud tokens updated ...
    2026-01-03 12:57:42.035  - info: daikin-cloud.0 (4607) Daikin token updated in adapter configuration ...
    2026-01-03 13:00:45.685  - info: shelly.0 (4684) [CoAP] Device 192.168.178.5 (shellyflood / shellyflood-4C7525062C2F / SHWT-1#4C7525062C2F#1) connected! Polltime set to 3600 sec.
    iob diag has finished.
    Have set up a new raspi 5 with Trixie, with iobroker and MQTT.
    Yesterday i did unplug an external SSD from my old raspi which is near by the new one... which ended up in both, the old and new raspi, to get stuck and they did not respond any more.
    After reboot everything looks fine, except the MQTT Adapter.
    When starting it gets stuck with a yellow warning sign in the list of instdances, with 2 greens and one red behind.
    I cannot see any strange thing in the protocol.
    What i did so far:
    iob fix
    setting log to debug and checking log when stopping and starting the adapter
    deinstall and reinstall the mqtt-adapter
    No change in behaviour.... the adapter simply does not start.
    debug-log attached.... the 5 mqtt clients which are listed at end of the start of the adapter are exactly the 5 which i want to track....
    Any help here ?
    • N NoPlayBack 0
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      SUDO_HOME=/home/pi
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           2.1G          0B        2.1G
               8059 M total memory
               3211 M used memory
               3251 M free memory
                124 M buffer memory
               1702 M swap cache
               2047 M total swap
                  0 M used swap
               2047 M free swap
      *** FILESYSTEM ***
      /var:
      33G     /var/
      30G     /var/lib
      29G     /var/lib/mysql
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        3572
      States:         2778
      Pending Updates: 4
      What i did so far:
      iob fix
      Any help here ?
      @NoPlayBack-0 sagte in MQTT Adapter does not start any more after raspi-crash:
      Any help here
      warum auf Englisch im deutschen Teil des Forums?
      • Samson71S Samson71 verschob dieses Thema von Error/Bug am
        Any help here
        Samson71S Offline
        Samson71S Offline
        Samson71
        @Homoran
        Hab' ich jetzt verschoben. Keine Lust mehr drauf. Im anderen Thread werden Bemerkungen ja scheinbar auch ignoriert.
        Markus
        Bitte beachten:
        • N NoPlayBack 0
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          SUDO_HOME=/home/pi
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           2.1G          0B        2.1G
                   8059 M total memory
                   3211 M used memory
                   3251 M free memory
                    124 M buffer memory
                   1702 M swap cache
                   2047 M total swap
                      0 M used swap
                   2047 M free swap
          *** FILESYSTEM ***
          /var:
          33G     /var/
          30G     /var/lib
          29G     /var/lib/mysql
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
               20.19.2+dfsg-1 500
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        3572
          States:         2778
          Pending Updates: 4
          What i did so far:
          iob fix
          Any help here ?
          das ist weder ein englischer, noch ein deutscher Bug von ioBroker!
          • N Offline
            N Offline
            NoPlayBack 0
            Nein sie werden nicht ignoriert. Es hat sich überschlagen.
            Mea culpa.
            Aber wieso steht oben auf der Seite bei mir
            • N NoPlayBack 0
              Mea culpa.
              Samson71S Offline
              Samson71S Offline
              Samson71
              @NoPlayBack-0
              Weil es dorthin verschoben wurde. Englischer Post -> englische Sektion. Soll das wieder nach Deutsch?
              Markus
              Bitte beachten:
              • N Offline
                N Offline
                NoPlayBack 0
                uiuiui, ja wenn möglich, ich gelobe Besserung und entschuldige mich.
                Meine nächste oder letzte Frage hier wäre nämlich... lässt sich so ein Fehler beheben, kann man einfach die Platte reparieren, oder nehme ich lieber das Backup was ich kurz vorher gemacht habe (das war nämlich der Grund für die SSD am alten Raspi)...
                • Samson71S Samson71 verschob dieses Thema von ioBroker general am
                • N NoPlayBack 0
                  Samson71S Offline
                  Samson71S Offline
                  Samson71
                  @NoPlayBack-0
                  Ist wieder im Deutschen Bereich, allerdings bei "Pflege des Betriebssystems". Du hast nen Schuss im Dateisystem. @homoran hat Dir das im Beitrag #4 aufgezeigt. Ich würde wohl zum Backup greifen denke ich, sofern das vor den Problemen entstanden ist.
                  Markus
                  Bitte beachten:
                  • N Offline
                    N Offline
                    NoPlayBack 0
                    Sodelle.... raspiBackup zurückgespielt, Fehler immer noch da.
                    In iob diag ist immer noch die Zeile zu sehen:
                    [Sat Jan 3 16:46:16 2026] EXT4-fs (nvme0n1p2): orphan cleanup on readonly fs
                    Also war der Fehler wohl schon beim Backup vorhanden, muss aber sehr sehr kurz vorher entstanden sein weil der MQTT-Adapter bis wenige Minuten vorher noch Daten empfangen hat und die in der db gespeichert wurden.
                    Das einzige was ich vorher gemacht hatte in dem Zeitraum (wegen dem anderen Problem hier: https://forum.iobroker.net/topic/83446/meldung-auth-could-not-identify-password-for-iobroker) war der Versuch, iob diag laufen zu lassen was wegen Rechteprobleme nicht ging. Ich hatte versucht den User pi zur Gruppe iobroker hinzuzufügen mit "sudo usermod -a -G iobroker pi" was aber auch nicht geholfen hatte.
                    Dann hatte ich vorsichtshalber ein Backup gemacht und danach erst mit iob fix das Rechteproblem gelöst. Obwohl dort keine Abfrage nach einem User und Passwort kam konnte ich nacher als pi den Befehl iob diag laufen lassen.
                    Wieso läuft alles, nur dieser MQTT bleibt auf gelb hängen ?????
                    Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                    • N Offline
                      N Offline
                      NoPlayBack 0
                      Ich hätte hier noch ein Backup aus dem gleichen Moment... ich mache auch immer ein Image mit SDCard-Kopier.... aber das kann ja nichts anderes machen?
                      Oder wäre das ein Versuch wert ???
                      • N NoPlayBack 0
                        Bei einem 'ordentlichen Setup' (bei dem der user pi (bzw. ein anderer Standarduser) verwendet wird) ist der user immer auch in der Gruppe 'iobroker' enthalten.
                        Der 'iob fix' löst kein Rechte-'Problem', weil es da nie 'Probleme' gibt, lediglich nicht korrekt gesetzte Rechte. Der Fixer greift dem Admin des Systems nur etwas unter die Arme und richtet die Rechte für ihn ein.
                        • N NoPlayBack 0
                          nöö, die Platte scheint massive Probleme zu haben, und/oder die Einschläge sind in Dateien vom OS, node.js...ä
                          • N Offline
                            N Offline
                            NoPlayBack 0
                            so und jetzt wird es richtig komisch... habe gerade nachgeguckt, der MQTT-Adapter auf dem alten Raspi (den hatte ich deaktivert) zeigt jetzt das gleiche Verhalten, wird nicht grün.
                            Der MQTT-Adapter auf einem dritten Raspi ebenfalls, bleibt auf gelb.
                            Ich bin ratlos ...
                            • N NoPlayBack 0
                              Was heißt immer noch? Das ist ein neuer Eintrag. Es wurden also bei diesem Boot weitere/neue verwaiste Einträge gelöscht.
                              Spricht für einen wurmstichigen Datenträger, wenn der Neustart ordentlich durchgeführt wurde jedenfalls.
                              • mcm1957M Offline
                                mcm1957M Offline
                                mcm1957
                                Link zum gleichlautenden Issue: https://github.com/ioBroker/ioBroker.mqtt/issues/582
                                Support Repositoryverwaltung.
                                LESEN - gute Forenbeitrage
                                • N NoPlayBack 0
                                  Ich bin ratlos ...
                                  mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  @NoPlayBack-0
                                  Betriebst du den mqtt Adapter als client oder als server?
                                  Wenn der Adapter als Server / Broker läuft:
                                  Hast du ggF die IP Addressen bei den clients angepasst? Ein neuer Rechner hat ja mit einer gewissen Wahrscheinlichkeit eine neue IP. Ohne Anpassen der clients werden die den nicht finden.
                                  • N Offline
                                    N Offline
                                    NoPlayBack 0
                                    schrieb am zuletzt editiert von NoPlayBack 0
                                    Jupp... habe ich, bzw. die nutzen keine IP sondern DNS, aber ja, die IPs habe ich tatsächlich bei den Raspis manuell und fix vergeben. Der Adapter läuft als Server/Broker.
                                    Und... die liefen nach der ganzen Umstellung ja auch bis gestern abend....
                                    • N Offline
                                      N Offline
                                      NoPlayBack 0
                                      Neee nä ?
                                      Meine Gedanken gingen in die gleiche Richtung daher war ich gerade dabei und habe einen Client umprogrammiert auf die fixe Adresse.... und zack, der Adapter wird grün.
                                      In meiner FritzBox gibt es gerade im Netzwerk 2 Geräte mit unterschiedlichen IPs, aber sie haben den gleichen Netzwerknamen !?!?!?!?!?
                                      Nachtrag: Eins ist das WLAN das andere kabelgebunden.....
                                      Nachtrag2: .... und damit zu früh gefreut... WLAN abgeschaltet (wie ich es bei den anderen Raspis auch hatte), wieder versucht den Server/Broker mit Netzwerknamen anzusprechen, es kommt kein Connect, die Clients können sich nicht verbinden...
                                      Morgen ist auch noch ein Tag.
                                      • N Offline
                                        N Offline
                                        NoPlayBack 0
                                        so, neuer Tag neues Glück:
                                        Erst einmal vielen Dank an die super Unterstützung hier, ich weiß jetzt wo die Ursache ist, beheben konnte ich sie noch nicht.
                                        Ich hatte beim Umbau von alt auf neu ein paar mal IPs und Namen der Netzwerkgeräte gewechselt, mit dem Ziel, dem Haupt-Raspi die gleiche IP und den gleichen Namen zu geben wie vorher.
                                        In der Fritzbox ist nun bei den Geräteinformationen zwar der richtige Name eingetragen, aber es gibt dort auch einen Eintrag "Erstverbindung ins Heimnetz als:" und dort steht der Name-02 drinne... ich vermute das ist der Name den ich beim ersten Start von Trixie vergeben hatte.
                                        Wenn ich heute mit tracert IP in einem Windows-Terminal nachschaue dann kommt dort die Rückmeldung, dass unter der IP das Gerät Name-02 ist.
                                        Wenn ich tracert Name teste kommt das gleiche Ergebnis, mit tracert Name-02 gibt es "Name konnte nicht aufgelöst werden".
                                        Ein ping klappt mit beiden Namen.
                                        Wenn ich einen MQTT-Client programmiere mit dem Namen, kann keine Verbindung aufgebaut werden.
                                        Wenn ich einen MQTT-Client programmiere mit dem Namen-02, dann wird eine Verbindung aufgebaut.
                                        Mit IP natürlich auch.
                                        Ich vermute dass beim crash gar nix passiert ist... außer dass der neue raspi halt neu gestartet werden musste und er ab dem Zeitpunkt dann mit dieser Situation nicht mehr klarkommt... bzw. der Adapter.
                                        Langer Rede kurzer Sinn: Ich würde mich freuen Hilfe zu bekommen die Ursache zu finden und auch zu beheben, aber das ist ja jetzt eigentlich ein anderes Thema. Ich möchte nicht einfach nur in den Clients jetzt die IPs eintragen, ich würde gerne beim Namen bleiben, daher muss ich mal herausfinden wie ich das löse.
                                        Eine viel wichtigere Frage die hier vielleicht noch hinpasst:
                                        Ihr habt mir ja jetzt gezeigt dass meine Platte offensichtlich Kummer hat. Wo kann ich da mehr lesen bzgl. SSD-Test, SSD-Health, Ursachen-Analyse?
                                        An der Stelle noch ein kleiner Hinweis: Ich habe in der config.txt das pciex1_gen=3 gesetzt um die Geschwindigkeit höher zu zwingen... in einem anderen Forum wurde mir gesagt dass das alle machen und bis jetzt noch keine Schwierigkeiten bekannt sind...oder gibt es hier eine andere Meinung ?
                                        • N NoPlayBack 0
                                          Dann lösch die Doublette dort raus.
