  4. Problem mit IO-Broker Reiter Adapter - Fehlermeldung
    5.8k
94 Beiträge 5 Kommentatoren 5.5k Aufrufe 3 Beobachtet
  • F Frank-KNX
    Hier ohne unzählige unnötige KNX-Zeilen:
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Raspbian GNU/Linux 10 (buster)
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 5.10.103-v7l+
          Architecture: arm
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : armv7l
    Userland        : 32 bit
    Systemuptime and Load:
     16:22:07 up 11 days,  8:10,  3 users,  load average: 2.54, 2.16, 1.82
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Unknown release codenamed 'buster'. Please check yourself if the Operating System is actively maintained.
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-12-30 16:22:07 CET
               Universal time: Tue 2025-12-30 15:22:07 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         true
    Display-Manager:        * lightdm.service - Light Display Manager
    Desktop:
    Session:                tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:           7.9G        1.5G        4.2G        158M        2.2G        6.1G
    Swap:           99M          0B         99M
    Total:         8.0G        1.5G        4.3G
    Active iob-Instances:   12
             7898 M total memory
             1495 M used memory
              483 M active memory
             2949 M inactive memory
             4211 M free memory
              153 M buffer memory
             2038 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    top - 16:22:08 up 11 days,  8:10,  3 users,  load average: 2.54, 2.16, 1.82
    Tasks: 191 total,   1 running, 190 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 43.0 us, 11.4 sy,  0.0 ni, 45.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7898.7 total,   4211.1 free,   1496.0 used,   2191.6 buff/cache
    MiB Swap:    100.0 total,    100.0 free,      0.0 used.   6106.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
    * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
    1 loaded units listed. Pass --all to see loaded but inactive units, too.
    To show all installed unit files use 'systemctl list-unit-files'.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      117G   20G   93G  18% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G   47M  3.9G   2% /dev/shm
    tmpfs          tmpfs     3.9G   33M  3.9G   1% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M  4.0K  790M   1% /run/user/1000
    [Fri Dec 19 08:11:39 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=DC:A6:32:D3:7A:A7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=def5eda3-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Fri Dec 19 08:11:40 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Fri Dec 19 08:11:40 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Fri Dec 19 08:11:43 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    Show mounted filesystems:
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime
    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G    /var/
    1.1G    /var/cache/apt/archives
    1.1G    /var/cache/apt
    1.1G    /var/cache
    277M    /var/lib
    Archived and active journals take up 32.0M in the file system.
    /opt/iobroker/backups:
    8.3G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    308M    /opt/iobroker/iobroker-data/
    159M    /opt/iobroker/iobroker-data/files
    105M    /opt/iobroker/iobroker-data/backup-objects
    57M     /opt/iobroker/iobroker-data/files/javascript.admin
    38M     /opt/iobroker/iobroker-data/files/javascript.admin/static
    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    10M     /opt/iobroker/iobroker-data/states.jsonl
    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
    7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.d0c8b930.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.19.0
    /usr/bin/node           v18.19.0
    /usr/bin/npm            10.2.3
    /usr/bin/npx            10.2.3
    /usr/bin/corepack       0.22.0
    nodejs:
      Installed: 18.19.0-1nodesource1
      Candidate: 18.19.0-1nodesource1
      Version table:
     *** 18.19.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
         18.18.2-1nodesource1 1001
         18.18.1-1nodesource1 1001
         18.18.0-1nodesource1 1001
         18.17.1-1nodesource1 1001
         18.17.0-1nodesource1 1001
         18.16.1-1nodesource1 1001
         18.16.0-1nodesource1 1001
         18.15.0-1nodesource1 1001
         18.14.2-1nodesource1 1001
         18.14.1-1nodesource1 1001
         18.14.0-1nodesource1 1001
         18.13.0-1nodesource1 1001
         18.12.0-1nodesource1 1001
         18.11.0-1nodesource1 1001
         18.10.0-1nodesource1 1001
         18.9.1-1nodesource1 1001
         18.9.0-1nodesource1 1001
         18.8.0-1nodesource1 1001
         18.7.0-1nodesource1 1001
         18.6.0-1nodesource1 1001
         18.5.0-1nodesource1 1001
         18.4.0-1nodesource1 1001
         18.3.0-1nodesource1 1001
         18.2.0-1nodesource1 1001
         18.1.0-1nodesource1 1001
         18.0.0-1nodesource1 1001
         10.24.0~dfsg-1~deb10u3 500
    No problems detected
    Errors in npm tree: 0
    npm notice
    npm notice New major version of npm available! 10.2.3 -> 11.7.0
    npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.7.0
    npm notice Run npm install -g npm@11.7.0 to update!
    npm notice
    v18.19.0 is end-of-life. There are high chances of being vulnerable. Please upgrade it.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspberrypi         raspberrypi (version: 5.0.17, hostname: raspberrypi   , alive, uptime: 979833)
    Core adapters versions
    js-controller:  5.0.17
    admin:          6.13.16
    javascript:     7.8.0
    nodejs modules from github:     0
    Adapter State
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
    + system.adapter.knx.0                    : knx                   : raspberrypi                              -  enabled, bind: 192.168.2.98
    + system.adapter.linux-control.0          : linux-control         : raspberrypi                              -  enabled
    + system.adapter.node-red.0               : node-red              : raspberrypi                              -  enabled, port: 1880, bind: 192.168.2.98
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
    + system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.19   , installed 6.13.16 [Updatable]
    Adapter    "backitup"     : 3.3.10   , installed 2.9.8  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 4.2.0  [Updatable]
    Adapter    "ical"         : 1.18.1   , installed 1.13.3 [Updatable]
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "javascript"   : 9.0.11   , installed 7.8.0  [Updatable]
    Controller "js-controller": 7.0.7    , installed 5.0.17 [Updatable]
    Adapter    "knx"          : 2.0.30   , installed 2.0.24 [Updatable]
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "node-red"     : 5.2.1    , installed 5.1.0  [Updatable]
    Adapter    "simple-api"   : 2.8.0    , installed 2.7.2  [Updatable]
    Adapter    "socketio"     : 6.7.1    , installed 6.6.0  [Updatable]
    Adapter    "statistics"   : 2.4.0    , installed 2.4.0
    Adapter    "tr-064"       : 4.3.0    , installed 4.2.18 [Updatable]
    Adapter    "trashschedule": 3.3.0    , installed 2.3.0  [Updatable]
    Adapter    "upnp"         : 1.1.0    , installed 1.0.21 [Updatable]
    Adapter    "vis"          : 1.5.6    , installed 1.5.4  [Updatable]
    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.4.0  [Updatable]
    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
    Adapter    "web"          : 7.0.8    , installed 6.2.3  [Updatable]
    Adapter    "ws"           : 2.6.2    , installed 2.5.10 [Updatable]
    Objects and States
    Objects:        3116
    States:         2245
    E: The repository 'http://raspbian.raspberrypi.org/raspbian buster Release' no longer has a Release file.
    Pending Updates: 2
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18565      578/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          2302861    13020/cupsd
    tcp        0      0 192.168.2.98:1880       0.0.0.0:*               LISTEN      1001       24175      1258/node-red
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        19847      465/influxd
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19225      809/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19218      809/iobroker.js-con
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       18195      934/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       23704      1212/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        17827      465/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          18567      578/sshd
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          2302860    13020/cupsd
    udp        0      0 192.168.2.98:49040      0.0.0.0:*                           1001       2400381    1060/io.knx.0
    @Frank-KNX sagte in Problem mit IO-Broker Reiter Adapter - Fehlermeldung:
    Tot, da muss ein lebendes Release installiert werden.
    Kannste schon mal komplett NEU installieren. Diesmal dann ohne Desktop-Geraffel, also in der 64Bit-Lite-Version.
    Zuvor würde ich versuchen ein Backup ziehen, das allerdings von einer aktuellen Codebasis aus.
    Ich weiß nur gerade nicht, ob auf einem Buster noch nodejs>18 ans laufen zu bringen ist.
    Versuch mal ein
    iob nodejs-update 20
    • F Offline
      Frank-KNX
      Hallo Thomas Braun,
      vielen Dank. Ich soll also eine neuere Linux-Version installieren ?
      Sind dadurch nicht alle Daten (zum Beispiel VIS) verloren ?
      Bitte hilf mir auf die Sprünge:
      Altes reparieren und dann lauffähige Sicherung machen, um danach alles Upzudaten geht nicht ?
      Welche Reihenfolge schlägst du vor und mit welchen SSH-Befehlen führe ich dies erfolgreich aus ?
      • F Frank-KNX
        Hallo Thomas Braun,
        Dafür hast du ein Backup.
        • F Offline
          Frank-KNX
          Dein Befehl hat leider nicht funktioniert...
          pi@raspberrypi:~ $ iob nodejs-update 20
          Valid major version
          Debian 10 'Buster' has reached End of Life and is not supported anymore.
          Recent versions of nodejs won't run.
          Please install the current Debian Stable
          pi@raspberrypi:~ $
          • F Offline
            Frank-KNX
            Mit Backup meinst du eine 1 zu 1 Kopie der SD-Karte im PI oder einen Kopiervorgang der PI-Daten auf meinen PC per Software-Befehl ?
            Ich habe kein wissentliches Backup... lediglich vor 2 Jahren mal eine 1 zu 1 Kopie der SD-Karte geklont.
            • F Frank-KNX
              Hallo Thomas Braun,
              @Frank-KNX
              Nein, es gibt keinen Upgrade-Pfad von einem 32Bit-Buster auf ein 64Bit-Trixie.
              Deswegen muss das zwingend neuinstalliert werden.
              Der hat schon funktioniert. Nur dein System ist unrettbar abgesoffen. Tot durch 'unterlassen' könnte man sagen.
              Weder noch. Ich meine ein Backup vom ioBroker mittels Backitup-Adapter.
              Klone sind kein Backup. .
              Jetzt ist nur das Versionsdelta so groß geworden, das geht nicht mehr so einfach aus deinem versumpften System.
              • F Offline
                Frank-KNX
                OK, Verstanden.
                Ich habe den Backitup-Adapter zumindest schon auf meinem System (denn sonst könnte ich den jetzt auch nicht mehr installieren).
                Allerdings bringt dieser direkt beim Start die Meldung, dass derzeit die Sicherungen im gleichen System erfolgen und bei einem Problem damit auch das lokale Backup gelöscht ist.. Ich besitze aber weder NAS noch Google-Drive..
                Daher die Frage, wie ich im ersten Schritt ein erfolgreiches Backup auf ein anderes Speichermedium schaffe ? (zum Beispiel auf meinen Laptop, von dem ich per SSH auf den PI zugreife.
                • F Frank-KNX
                  OK, Verstanden.
                  @Frank-KNX
                  Mittels scp.
                  Aber keine Ahnung, ob und wie das unter Windows funktioniert.
                  • F Frank-KNX
                    OK, Verstanden.
                    Da Backups überlebenswichtig sind ist backitup seit Jahren Bestandteil der Grundinstallation.
                    Was eigentlich dessen Nutzung implizieren sollte.
                    im ersten Schritt höchstens mit mounting eines USB Sticks an deinen RasPi.
                    Empfehlenswert wäre jetzt quick & dirty lokal zu sichern und Anschließend Die Backupdatei per WIN-SCP oder Filezilla auf den Pc zu kopieren
                    • F Offline
                      Frank-KNX
                      Ich versuche gerade google dive.
                      Ich habe mich dort erfolgreich registriert und kämpfe jetzt noch mit dem Token für die Zugriffsrechte. Hier kommt noch eine Fehlermeldung im Backitup adapter unter Einstellungen.
                      • F Offline
                        Frank-KNX
                        Hallo Homoran,
                        danke für den Hinweis. das ich mit Google keinen Erfolg und nur Fehlermeldungen hatte, bleibt wohl nur der von dir vorgeschlagene Weg.
                        Ich habe ein Lokales Backup mit Backitup gemacht und nun die Software WinSCP installiert.
                        Welchen Port muss ich einstellen und welches Protokoll ? Ich bin mit default Port 22 nicht auf den PI gekommen.
                        • F Frank-KNX
                          Hallo Homoran,
                          mit welcher Meldung?
                          als welcher user?
                          ssh mit putty o.ä. funktioniert?
                          • F Offline
                            Frank-KNX
                            Ja, jetzt funktioniert es auch mit WinSCP.
                            ich finde auf der rechten Seite die Datenstruktur auf dem PI.
                            Kann aber auf Anhieb die Backup-Dateien nicht finden...
                            Hätte ich mit Sicherung auf meinen PC dann alle wichtigen Daten zum IO-Brocker (inkl. der VIS-Inhalte.. ich nutze natürlich noch VIS1) gesichert und kann mit eurer Hilfe das Updaten des PI in Angriff nehmen ?
                            • F Frank-KNX
                              du bist ja auch fernab von relevanten Strukturen.
                              die Backups befinden sich in /opt/iobroker/ backups/
                              • F Offline
                                Frank-KNX
                                Vielen Dank.
                                ich habe nun erfolgreich das letzte Backup von IO-Broker mit einer Größe von ca. 12MB auf meinen PC übertragen.
                                Eine zweite Backupdatei "sqlite..." konnte seit Anfang an offenbar nicht erstellt werden und diese Dateien haben alle die Dabei-Größe "0". Ich nutze aber bisher keine SQL-Datenbanken für eine VIS und daher hoffe ich, dass diese zweite Datei auch nicht für ein Backup notwendig ist.
                                • F Frank-KNX
                                  Vielen Dank.
                                  SQL-Datenbanken werden in ioBroker zum historisieren von Werten genutzt.
                                  Hat mit vis direkt nichts zu tun.
                                  bitte immer alles zeigen.
                                  wenn du SQL nicht nutzst, warum hast du das denn in backitup konfiguriert?
                                  • F Offline
                                    Frank-KNX
                                    Hier noch der Nachtrag der auf meinem Laptop gesicherten Backup-Datei:
                                    Auf der linken Seite markiert.
                                    die andern Dateien sind Screenshots der IO-Broker-Instanzen mit deren IP-Einstellungen für den Fall eines Totalschadens beim PI.
                                    Vielen Dank für die Hilfe eines erfolgreichen Backups
                                    • F Offline
                                      Frank-KNX
                                      Nun aber die Fragen an euch Fachleute:
                                      In welcher Reihenfolge und mit welchen einfachen Befehlen (über SSH) aktualisiere ich mein veraltetes System um bestenfalls am Ende mit dem Backup Großteile meiner VIS wieder herzustellen und am Ende wieder die stabile VIS auf dem Monitor erscheint.
                                      Im Nachfragen und Missverständnisse zu vermeiden, bitte möglichst einfach erklären. Ich kann (leider) keine Linux-Befehle (oder Grundlagen) und habe mich seit langer Zeit nicht mehr mit diesem Thema beschäftigt.
                                      Vielen Dank im Voraus für eure Hilfe bezüglich Reihenfolge und Masterplan.
                                      • F Frank-KNX
                                        Wenn du damit dein Betriebssystem meinst: Gar nicht. Der Zug ist abgefahren.
                                        Installier es neu:
                                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                        Und dann musst du hoffen, das dein Backup auf der neuen Installation einzuspielen ist.
                                        Du kannst aber auch mal versuchen zuvor die ioBroker-Adapter soweit wie das noch möglich ist auf einen aktuelleren Stand zu hieven:
                                        iob update
                                        iob upgrade
                                        • F Offline
                                          Frank-KNX
                                          Vielen Dank,
                                          ich habe mir gerade überlegt, da der PI auch schon etwas älter ist, einfach einen neues PI-Modell zu kaufen und dort alles neu zu machen. Dann kann ich bis das neue System vollständig läuft, einfach das bisherige weiter nutzen und die VIS mit allen Funktionen steht zur Verfügung und ich mache mir keinen Zeitstress bis auf dem neuen System alles läuft.
                                          @ Thomas Braun: was hälst du davon ? sollte ich dann sicher den ganz aktuellen PI kaufen, um auch mit der Hardware besser für die Zukunft gerüstet zu sein.
