  4. Instabiles Zigbee-Netzwerk
    6.4k
100 Beiträge 11 Kommentatoren 6.6k Aufrufe 13 Beobachtet
    @holly200289
    Setz zuerst mal alle Adapter wieder auf Repos auf.
    Am Beispiel von nuki-extended.
    iob upgrade nuki-extended@2.7.0
    Wenn das alles bereingt ist schaust du nach dem dann noch vorhandenen Rest.
    holly200289H Offline
    holly200289
    #71
    @Thomas-Braun
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.8.12-17-pve
        Architecture: x86-64
    OS is similar to:
    model name      : AMD Ryzen 7 5700G with Radeon Graphics
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     14:55:46 up 58 min,  2 users,  load average: 2.05, 1.26, 1.16
    CPU threads: 8
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2025-12-30 14:55:46 CET
               Universal time: Tue 2025-12-30 13:55:46 UTC
                     RTC time: n/a
    System clock synchronized: no
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    admin
    HOME=/home/admin
    GROUPS=admin adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/admin
    GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             27G        6.5G         20G        3.7M        244M         20G
    Swap:           1.0G          0B        1.0G
    Total:           28G        6.5G         21G
    Active iob-Instances:   83
            26000 M total memory
             6235 M used memory
             6193 M active memory
                0 M inactive memory
            19534 M free memory
                0 M buffer memory
              233 M swap cache
             1000 M total swap
                0 M used swap
             1000 M free swap
    top - 14:55:46 up 58 min,  2 users,  load average: 2.05, 1.26, 1.16
    Tasks: 122 total,  11 running, 111 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 33.8 us,  3.8 sy,  0.0 ni, 61.2 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
    MiB Mem :  26000.0 total,  19528.1 free,   6242.3 used,    233.1 buff/cache
    MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  19757.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    Filesystem              Type   Size  Used Avail Use% Mounted on
    daten/subvol-100-disk-0 zfs    230G   19G  212G   9% /
    none                    tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                   tmpfs   16G     0   16G   0% /dev/shm
    tmpfs                   tmpfs  6.2G  184K  6.2G   1% /run
    tmpfs                   tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                   tmpfs   16G  3.4M   16G   1% /tmp
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
    tmpfs                   tmpfs  3.1G  8.0K  3.1G   1% /run/user/1001
    [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): mounted filesystem 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 ro with ordered data mode. Quota mode: none.
    [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): re-mounted 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE                  FSTYPE OPTIONS
    /      daten/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
    /var:
    3.2G    /var/
    1.9G    /var/lib
    1.8G    /var/lib/containerd
    1.3G    /var/log/journal/9626128f51d4471993ebdff830afe042
    Archived and active journals take up 1.2G in the file system.
    /opt/iobroker/backups:
    7.7G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G    /opt/iobroker/iobroker-data/
    745M    /opt/iobroker/iobroker-data/files
    512M    /opt/iobroker/iobroker-data/history
    266M    /opt/iobroker/iobroker-data/backup-objects
    82M     /opt/iobroker/iobroker-data/files/vis
    21M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
    17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
    17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    HINT:
    Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 600
         22.20.0-1nodesource1 600
         22.19.0-1nodesource1 600
         22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 392)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.17
    nodejs modules from github:     11
    +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
    +-- iobroker.omada@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#0f6a083c8bf8306ffcb248ad6aa80c495cec438e)
    +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#4d519d4e5494569fc898affe0d2946722a646efd)
    +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
    +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
    `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
    Adapter State
    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.admin.2                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 127.0.0.1, run as: admin
    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
    + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.devices.0                : devices               : iobroker                                 - disabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
      system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
    + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
    + system.adapter.history.0                : history               : iobroker                                 -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
      system.adapter.material.0               : material              : iobroker                                 - disabled
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
    + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
    + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
      system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
    + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.places.0                 : places                : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
    + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
    + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
    + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
    + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
    + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
    + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
    + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
    + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
    + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
    + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.187:1020
    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
    + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
    + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: patch
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa-timer-vis": 2.1.2  , installed 2.1.2
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.13
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "bshb"         : 0.5.0    , installed 0.5.0
    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "javascript"   : 9.0.11   , installed 9.0.17
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "kisshome-defender": 1.1.13, installed 1.1.13
    Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
    Adapter    "lovelace"     : 5.0.1    , installed 5.0.3
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "matter"       : 0.5.5    , installed 0.5.6
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-cloud" : 0.1.0    , installed 0.2.2
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
    Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "node-red"     : 5.2.1    , installed 6.0.7
    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "parser"       : 2.2.4    , installed 2.2.4
    Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "places"       : 1.3.0    , installed 1.3.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.2
    Adapter    "ring"         : 6.4.0    , installed 6.4.0
    Adapter    "roborock"     : 0.6.18   , installed 0.6.19
    Adapter    "rssfeed"      : 3.6.1    , installed 3.1.0  [Updatable]
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.9
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
    Adapter    "text2command" : 3.0.3    , installed 3.0.3
    Adapter    "tinymqttbroker": 0.1.4   , installed 0.1.4
    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.3
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
    Adapter    "weather-warnings": 0.10.0, installed 0.10.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.9
    Adapter    "webcal"       : 1.4.0    , installed 1.4.0
    Adapter    "webui"        : 1.37.0   , installed 1.38.7
    Adapter    "welcome"      : 1.0.2    , installed 1.0.2
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
    Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
    Adapter    "youtube"      : 6.1.0    , installed 6.1.0
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        56264
    States:         44667
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://security.debian.org trixie-security InRelease
    Hit:2 http://deb.debian.org/debian trixie InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://download.docker.com/linux/debian trixie InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          74300522   1/init
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       74915526   11864/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       74953926   12992/io.mqtt.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       74956901   13090/io.shelly.0
    tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       74955979   13143/io.nuki.0
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74918241   11341/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74918248   11341/iobroker.js-c
    tcp        0      0 127.0.0.1:8089          0.0.0.0:*               LISTEN      1000       74912657   11377/io.admin.2
    tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       74927827   12620/io.sonoff.0
    tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       74974337   13847/io.welcome.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          74289014   316/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          74302536   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          74300523   1/init
    tcp6       0      0 :::1890                 :::*                    LISTEN      1000       74929629   12881/io.espresense
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          74289015   316/master
    tcp6       0      0 :::6824                 :::*                    LISTEN      1000       74922462   12249/io.roborock.0
    tcp6       0      0 :::7999                 :::*                    LISTEN      1000       74930602   12326/io.geofency.0
    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       74975763   13649/io.upnp.0
    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       74961322   13477/io.lovelace.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       74895052   11359/io.admin.1
    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       74971530   13597/io.rtspStream
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       74959152   13272/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       74961186   13279/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       74953472   13335/io.simple-api
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       74922551   12345/io.harmony.0
    udp        0      0 0.0.0.0:42117           0.0.0.0:*                           1000       74968308   13649/io.upnp.0
    udp        0      0 0.0.0.0:58652           0.0.0.0:*                           1000       74975049   14604/io.philips-ai
    udp        0      0 0.0.0.0:42275           0.0.0.0:*                           1000       74975646   14115/io.echarts.0
    udp        0      0 0.0.0.0:42540           0.0.0.0:*                           1000       74912618   11377/io.admin.2
    udp        0      0 0.0.0.0:58952           0.0.0.0:*                           1000       74962081   13335/io.simple-api
    udp        0      0 0.0.0.0:42599           0.0.0.0:*                           1000       74957896   13125/io.cloud.0
    udp        0      0 0.0.0.0:42673           0.0.0.0:*                           1000       74906432   11810/io.node-red.0
    udp        0      0 0.0.0.0:42941           0.0.0.0:*                           1000       74927414   12408/io.places.0
    udp        0      0 0.0.0.0:42949           0.0.0.0:*                           1000       74930163   13195/io.zigbee.3
    udp        0      0 0.0.0.0:59397           0.0.0.0:*                           1000       74922173   11981/io.telegram.0
    udp        0      0 0.0.0.0:59414           0.0.0.0:*                           1000       74968170   13633/io.text2comma
    udp        0      0 0.0.0.0:43196           0.0.0.0:*                           1000       74952939   13090/io.shelly.0
    udp        0      0 0.0.0.0:59656           0.0.0.0:*                           1000       74975617   14078/io.pi-hole2.0
    udp        0      0 0.0.0.0:43355           0.0.0.0:*                           1000       74971678   13950/io.vis-2.0
    udp        0      0 0.0.0.0:59787           0.0.0.0:*                           1000       74979883   14598/io.philips-ai
    udp        0      0 0.0.0.0:59843           0.0.0.0:*                           1000       74952891   13073/io.wifilight.
    udp        0      0 0.0.0.0:59973           0.0.0.0:*                           1000       74927219   12249/io.roborock.0
    udp        0      0 0.0.0.0:43621           0.0.0.0:*                           1000       74915707   12272/io.backitup.0
    udp        0      0 0.0.0.0:43737           0.0.0.0:*                           1000       74971251   13744/io.vis-invent
    udp        0      0 0.0.0.0:43856           0.0.0.0:*                           1000       74953907   12992/io.mqtt.0
    udp        0      0 0.0.0.0:60275           0.0.0.0:*                           1000       74961454   13597/io.rtspStream
    udp        0      0 0.0.0.0:60442           0.0.0.0:*                           1000       74971550   13898/io.lightcontr
    udp        0      0 0.0.0.0:60496           0.0.0.0:*                           1000       74917842   12146/io.influxdb.0
    udp        0      0 0.0.0.0:60566           0.0.0.0:*                           1000       74924061   11615/io.javascript
    udp        0      0 0.0.0.0:60816           0.0.0.0:*                           1000       74954169   13214/io.zigbee.4
    udp        0      0 0.0.0.0:44492           0.0.0.0:*                           1000       74929862   12962/io.samsung_ti
    udp        0      0 0.0.0.0:44950           0.0.0.0:*                           1000       74958501   13493/io.moma.0
    udp        0      0 0.0.0.0:45052           0.0.0.0:*                           1000       74961539   13616/io.sourceanal
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       74922552   12345/io.harmony.0
    udp        0      0 0.0.0.0:45947           0.0.0.0:*                           1000       74919752   12308/io.broadlink2
    udp        0      0 0.0.0.0:46069           0.0.0.0:*                           1000       74930691   12390/io.ping.0
    udp        0      0 0.0.0.0:46306           0.0.0.0:*                           1000       74918776   11917/io.scenes.0
    udp        0      0 0.0.0.0:46332           0.0.0.0:*                           1000       74929244   12293/io.alexa2.0
    udp        0      0 0.0.0.0:47531           0.0.0.0:*                           1000       74962041   13279/io.socketio.0
    udp        0      0 0.0.0.0:47592           0.0.0.0:*                           1000       74975095   14604/io.philips-ai
    udp        0      0 0.0.0.0:47715           0.0.0.0:*                           1000       74968624   13777/io.rssfeed.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       74926171   12308/io.broadlink2
    udp        0      0 0.0.0.0:47978           0.0.0.0:*                           1000       74922744   12515/io.tr-064.2
    udp        0      0 0.0.0.0:47982           0.0.0.0:*                           1000       74895326   12084/io.whatsapp-c
    udp        0      0 0.0.0.0:48162           0.0.0.0:*                           1000       74918306   11359/io.admin.1
    udp        0      0 0.0.0.0:48367           0.0.0.0:*                           1000       74928424   12326/io.geofency.0
    udp        0      0 0.0.0.0:48543           0.0.0.0:*                           1000       74962279   12308/io.broadlink2
    udp        0      0 0.0.0.0:48635           0.0.0.0:*                           1000       74934484   12445/io.samsung.1
    udp        0      0 0.0.0.0:48715           0.0.0.0:*                           1000       74961773   13762/io.windows-co
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          74296949   1/init
    udp        0      0 0.0.0.0:49366           0.0.0.0:*                           1000       74922493   12308/io.broadlink2
    udp        0      0 0.0.0.0:49390           0.0.0.0:*                           1000       74918229   11341/iobroker.js-c
    udp        0      0 0.0.0.0:33124           0.0.0.0:*                           1000       74958395   13421/io.fullcalend
    udp        0      0 0.0.0.0:50033           0.0.0.0:*                           1000       74895117   11467/io.email.0
    udp        0      0 0.0.0.0:33701           0.0.0.0:*                           1000       74928026   12896/io.daikin-clo
    udp        0      0 0.0.0.0:33839           0.0.0.0:*                           1000       74913662   11515/io.history.0
    udp        0      0 0.0.0.0:34304           0.0.0.0:*                           1000       74971347   13829/io.slideshow.
    udp        0      0 0.0.0.0:34332           0.0.0.0:*                           1000       74906561   12065/io.telegram.1
    udp        0      0 0.0.0.0:50943           0.0.0.0:*                           1000       74953766   12881/io.espresense
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       74958755   13649/io.upnp.0
    udp        0      0 0.0.0.0:51085           0.0.0.0:*                           1000       74971877   14038/io.vw-connect
    udp        0      0 0.0.0.0:34915           0.0.0.0:*                           1000       74926092   12116/io.whatsapp-c
    udp        0      0 0.0.0.0:35545           0.0.0.0:*                           1000       74952670   12859/io.fullybrows
    udp        0      0 0.0.0.0:35565           0.0.0.0:*                           1000       74944440   12667/io.systeminfo
    udp        0      0 0.0.0.0:52773           0.0.0.0:*                           1000       74968947   13880/io.philips-tv
    udp        0      0 0.0.0.0:52834           0.0.0.0:*                           1000       74954738   13649/io.upnp.0
    udp        0      0 0.0.0.0:36505           0.0.0.0:*                           1000       74922479   12308/io.broadlink2
    udp        0      0 0.0.0.0:53179           0.0.0.0:*                           1000       74957483   13579/io.parser.0
    udp        0      0 0.0.0.0:53197           0.0.0.0:*                           1000       74956786   13968/io.wallpanel.
    udp        0      0 0.0.0.0:53255           0.0.0.0:*                           1000       74957855   13055/io.bshb.0
    udp        0      0 0.0.0.0:36984           0.0.0.0:*                           1000       74943301   12598/io.proxmox.0
    udp        0      0 0.0.0.0:37427           0.0.0.0:*                           1000       74959074   13260/io.discovery.
    udp        0      0 0.0.0.0:37490           0.0.0.0:*                           1000       74928400   12308/io.broadlink2
    udp        0      0 0.0.0.0:37536           0.0.0.0:*                           1000       74922549   12345/io.harmony.0
    udp        0      0 0.0.0.0:54122           0.0.0.0:*                           1000       74975459   13986/io.smartthing
    udp        0      0 0.0.0.0:54147           0.0.0.0:*                           1000       74956927   13107/io.webcal.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       74987682   14611/io.ham.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       74972354   13862/io.wled.0
    udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       74937677   12497/io.tr-064.1
    udp        0      0 0.0.0.0:38156           0.0.0.0:*                           1000       74949250   12649/io.homeconnec
    udp        0      0 0.0.0.0:54744           0.0.0.0:*                           1000       74915747   12360/io.nut.0
    udp        0      0 0.0.0.0:38430           0.0.0.0:*                           1000       74953407   13272/io.web.0
    udp        0      0 0.0.0.0:55237           0.0.0.0:*                           1000       74959508   13795/io.webui.0
    udp        0      0 0.0.0.0:39188           0.0.0.0:*                           1000       74928393   12308/io.broadlink2
    udp        0      0 0.0.0.0:55666           0.0.0.0:*                           1000       74915719   12308/io.broadlink2
    udp        0      0 0.0.0.0:39363           0.0.0.0:*                           1000       74928396   12308/io.broadlink2
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       74929929   13037/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       74929930   13037/io.tuya.0
    udp        0      0 0.0.0.0:39500           0.0.0.0:*                           1000       74915716   12308/io.broadlink2
    udp        0      0 0.0.0.0:39664           0.0.0.0:*                           1000       74953318   13246/io.zigbee.1
    udp        0      0 0.0.0.0:39745           0.0.0.0:*                           1000       74971919   14097/io.omada.0
    udp        0      0 0.0.0.0:40220           0.0.0.0:*                           1000       74954488   13456/io.iqontrol.0
    udp        0      0 0.0.0.0:56644           0.0.0.0:*                           1000       74975401   13935/io.alexa-time
    udp        0      0 0.0.0.0:40283           0.0.0.0:*                           1000       74956265   13438/io.iot.0
    udp        0      0 0.0.0.0:40414           0.0.0.0:*                           1000       74961049   13222/io.zigbee.2
    udp        0      0 0.0.0.0:40511           0.0.0.0:*                           1000       74929721   12914/io.spotify-pr
    udp        0      0 0.0.0.0:40519           0.0.0.0:*                           1000       74929894   13037/io.tuya.0
    udp        0      0 0.0.0.0:40538           0.0.0.0:*                           1000       74971387   13847/io.welcome.0
    udp        0      0 0.0.0.0:40579           0.0.0.0:*                           1000       74979900   14598/io.philips-ai
    udp        0      0 0.0.0.0:40607           0.0.0.0:*                           1000       74937360   12461/io.shuttercon
    udp        0      0 0.0.0.0:57073           0.0.0.0:*                           1000       74922482   12308/io.broadlink2
    udp        0      0 0.0.0.0:57653           0.0.0.0:*                           1000       74928531   12426/io.samsung.0
    udp        0      0 0.0.0.0:41345           0.0.0.0:*                           1000       74928405   12308/io.broadlink2
    udp        0      0 0.0.0.0:57764           0.0.0.0:*                           1000       74930858   12620/io.sonoff.0
    udp        0      0 0.0.0.0:57830           0.0.0.0:*                           1000       74961320   13477/io.lovelace.0
    udp        0      0 0.0.0.0:57871           0.0.0.0:*                           1000       74928390   12308/io.broadlink2
    udp        0      0 0.0.0.0:41593           0.0.0.0:*                           1000       74972359   13862/io.wled.0
    udp        0      0 0.0.0.0:41762           0.0.0.0:*                           1000       74955912   13143/io.nuki.0
    udp6       0      0 :::111                  :::*                                0          74296950   1/init
    2025-12-30 14:56:00.831  - info: shelly.0 (13090) [authEnabled] 192.168.178.96 (shellyplus2pm / shellyplus2pm-2cbcbb3cd65c / shellyplus2pm#2cbcbb3cd65c#1): This device is not protected via restricted login (see adapter documentation for details)
    2025-12-30 14:56:01.329  - info: shelly.0 (13090) [authEnabled] 192.168.178.41 (shellyplus1 / shellyplus1-78ee4cd60b9c / shellyplus1#78ee4cd60b9c#1): This device is not protected via restricted login (see adapter documentation for details)
    2025-12-30 14:56:01.602  - info: shelly.0 (13090) [authEnabled] 192.168.178.122 (shellyplus2pm / shellyplus2pm-a0dd6c2af678 / shellyplus2pm#a0dd6c2af678#1): This device is not protected via restricted login (see adapter documentation for details)
    2025-12-30 14:56:02.747  - info: host.iobroker instance system.adapter.philips-air.1 in version "1.2.0" started with pid 14598
    2025-12-30 14:56:02.761  - info: host.iobroker instance system.adapter.philips-air.0 in version "1.2.0" started with pid 14604
    2025-12-30 14:56:02.772  - info: host.iobroker instance system.adapter.ham.0 in version "5.3.1" started with pid 14611
    2025-12-30 14:56:03.118  - info: philips-air.1 (14598) Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
    2025-12-30 14:56:03.169  - info: philips-air.0 (14604) Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
    2025-12-30 14:56:04.105  - info: philips-air.0 (14604) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.philips-air, node: v22.21.0, js-controller: 7.0.7
    2025-12-30 14:56:04.102  - info: philips-air.1 (14598) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.philips-air, node: v22.21.0, js-controller: 7.0.7
    2025-12-30 14:56:07.603  - info: shelly.0 (13090) [authEnabled] 192.168.178.110 (shellyplus2pm / shellyplus2pm-30c922740d78 / shellyplus2pm#30c922740d78#1): This device is not protected via restricted login (see adapter documentation for details)
    2025-12-30 14:56:08.272  - silly: broadlink2.0 (12308) States user redis pmessage broadlink2.0.*/broadlink2.0.RM:Broadlink-RMMINI-8e-eb-24.Temperature:{"val":13,"ack":true,"ts":1767102968271,"q":0,"from":"system.adapter.broadlink2.0","user":"system.user.admin","lc":1767102968271}
    2025-12-30 14:56:08.273  - info: broadlink2.0 (12308) debug: ChangeState ack:true of RM:Broadlink-RMMINI-8e-eb-24.Temperature = 13
    code_text
    holly200289H Thomas BraunT 3 Antworten Letzte Antwort
    • holly200289H holly200289
      @Thomas-Braun
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 8
                       RTC time: n/a
                RTC in local TZ: no
      admin
      HOME=/home/admin
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           1.0G          0B        1.0G
      Total:           28G        6.5G         21G
               6235 M used memory
                  0 M inactive memory
              19534 M free memory
                  0 M buffer memory
                233 M swap cache
               1000 M total swap
                  0 M used swap
               1000 M free swap
      *** FILESYSTEM ***
      /var:
      3.2G    /var/
      1.9G    /var/lib
      USB-Devices by-id:
      HINT:
      tcp
      HINT:
      tcp
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
           20.19.2+dfsg-1 500
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     9.0.17
      Adapter State
      + instance is alive
      Objects and States
      Objects:        56264
      States:         44667
      Pending Updates: 0
      code_text
      holly200289
      #72
      admin@iobroker:~$ iob logs
      Uncaught Rejection: Error: Cannot create a string longer than 0x1fffffe8 characters
          at Object.slice (node:buffer:636:37)
          at Buffer.toString (node:buffer:864:14)
          at CLILogs.execute (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/cli/cliLogs.js:36:51)
          at processCommand (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js:1012:25)
          at Module.execute (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js:2661:5)
          at file:///opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:55
      admin@iobroker:~$
        @Thomas-Braun
        Script v.2025-08-09
        *** BASE SYSTEM ***
          Virtualization: lxc
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
                         RTC time: n/a
                  RTC in local TZ: no
        admin
        HOME=/home/admin
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           1.0G          0B        1.0G
        Total:           28G        6.5G         21G
                 6235 M used memory
                    0 M inactive memory
                19534 M free memory
                    0 M buffer memory
                  233 M swap cache
                 1000 M total swap
                    0 M used swap
                 1000 M free swap
        *** FILESYSTEM ***
        /var:
        3.2G    /var/
        1.9G    /var/lib
        USB-Devices by-id:
        HINT:
        tcp
        HINT:
        tcp
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
             20.19.2+dfsg-1 500
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.19
        javascript:     9.0.17
        Adapter State
        + instance is alive
        Objects and States
        Objects:        56264
        States:         44667
        Pending Updates: 0
        code_text
        #73
        @holly200289
        Du hast da viel zu viel Kappes laufen. Wozu denn bitte ein
        JQuery-Snowfall, was seit 10 Jahren nicht mehr gepflegt wird? Sowas SCHREIT geradezu nach Problemen.
        • holly200289H Offline
          holly200289
          #74
          Zurück zu dem Zigbee Problem, das ist ja nicht der Auslöser oder ?
          Ich soll das alles Clean machen aber dann funktionieren einige Sachen nicht mehr, und ich finde das schön, wenn es scheint, jetzt meine Frage sind das Auslöser warum Zigbee nicht läuft ?
            holly200289
            #75
            Ich dachte wir suchen das Problem warum die Zigbee Adapter nicht funktionieren ?
              #76
              @holly200289 sagte in Instabiles Zigbee-Netzwerk:
              Keine Ahnung, eher nicht. Aber deine Kiste ist so strubbelig, da fällt es schwer Ursachen zu finden.
                holly200289
                #77
                Das Log von dem Zigbee Adapter habe ich ja geschickt, was braucht ihr noch um es zu analysieren ?
                  holly200289
                  #78
                  Ich habe ja schon einiges entfernt, was ihr angestrichen habt
                    holly200289
                    #79
                    Soll ich mal auf die neuste Zigbee Version Updaten ?
                    Und soll ich ein Screenshot von den Geräten mit Fragezeichen Schicken ?
                      @Thomas-Braun
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 8
                                       RTC time: n/a
                                RTC in local TZ: no
                      admin
                      HOME=/home/admin
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           1.0G          0B        1.0G
                      Total:           28G        6.5G         21G
                               6235 M used memory
                                  0 M inactive memory
                              19534 M free memory
                                  0 M buffer memory
                                233 M swap cache
                               1000 M total swap
                                  0 M used swap
                               1000 M free swap
                      *** FILESYSTEM ***
                      /var:
                      3.2G    /var/
                      1.9G    /var/lib
                      USB-Devices by-id:
                      HINT:
                      tcp
                      HINT:
                      tcp
                      HINT:
                      tcp
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.19
                      javascript:     9.0.17
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        56264
                      States:         44667
                      Pending Updates: 0
                      code_text
                      #80
                      Gehört nicht in die erste Ebene.
                      iobroker.omada
                      Ist wohl nie ordentlich veröffentlicht worden.
                      iobroker.roborock
                      Kann sein, dass es da Probleme mit dem Login gab, die in einem GitHub-Commit behoben sind.
                      iobroker.rtspStream
                      smartthings
                      Zur Zeit nur als Beta über das entsprechende Repo zu installieren.
                      sourceanalytix
                      Ewiger Beta-Status...
                      JQuery-Snowfall
                      Wird wohl nicht mehr gepflegt, letztes Release im November 2013. Komplett entbehrlich, wenn man ein stabiles System haben möchte.
                      magic-snowflakes
                      Siehe zuvor.
                      Hat in der ersten Ebene nix verloren. zigbee-herdsman-converters ist eine Dependency des zigbee-Adapters und hängt drunter.
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #81
                        Update auf die aktuelle 'latest' version kann helfen
                        bringt nix.
                        Ich stimme dem was @thomas-braun geschrieben hat zu - dein System ist komisch.
                        Das der Adapter manchmal nicht startet liegt daran das er die Verbindung zu den Koordinatoren verliert. Beim Neustart antworten diese nicht (Insbesondere die Netzwerk Koordinatoren), weswegen die Instanz 4 auch nicht startet. Da solltest du den Koordinator mal vom strom nehmen, 30 s warten und dann wieder anklemmen. Danach die Instanz neu starten und sie sollte hoch kommen.
                        Was die generelle Frage zur Instabilität angeht - es fehlen immer noch die Aussagen was passiert wenn die Instanzen instabil werden. Dazu habe ich kein Log gesehen. Ohne ist das alles nur 'allgemeines stochern im Nebel'. und Nebel gibt es auf dem System deutlich zu viel.
                        A.
                          holly200289
                          #82
                          Das stimmt nicht ganz, punkt #63 habe ich den Verlauf vom Stick gepostet
                            holly200289
                            #83
                            Zu allen anderen Sachen Stimme ich zu, ich versuche natürlich das System so stabil wie möglich zubekommen,
                            nur bei den ein oder anderen wäre Unterstützung von euch nett, ihr seht ja wo der Schuhe drückt.
                            soll der entfernt werden ?
                              holly200289
                              #84
                              sourceanalytix ; also gibt es das auch nicht über die Katze ?
                                #85
                                Ich würde den im Interesse eine 'KISS'-Systems aus den Füßen haben wollen.
                                Je weniger Kokolores installiert ist, desto besser kann man Fehler finden und desto stabiler läuft so ein System auch.
                                Nicht umsonst fährt man Server eigentlich auch ohne graphische Desktopumgebung. Was nicht läuft kann nicht abstürzen, kann nicht attackiert werden und frisst keine Systemressourcen weg.
                                  holly200289
                                  #86
                                  KISS'-Systems habe ich jetzt Deinstalliert
                                    #87
                                    @holly200289
                                    Ich meinte zwar damit ein
                                    K eep
                                    I t
                                    S imple and
                                    S tupid
                                    Setup, aber du hast Recht, der Adapter ist auch ein Streichkandidat. Deren erster Adapter hat z. B. mächtig auf die Netzwerkperformance gedrückt. Keine Ahnung, ob sich das aktuelle Ding da besser verhält.
                                    Der ist wegen der negativen Erfahrungen gar nicht erst auf meiner Kiste gelandet.
                                      holly200289
                                      #88
                                      Ich schicke euch jetzt die Geräte, die bei Zigbee 3.3.0 ein Fragezeichen haben
                                      holly200289H 1 Antwort Letzte Antwort
                                        holly200289
                                        #89
                                        model:MS-105Z
                                        type:Router
                                        description:Smart Dimmer module
                                        hasLegacyDef:false
                                        vendor:Moes
                                        hasOnEvent:false
                                        hasConfigure:true
                                        icon:img/MS-105Z.png
                                        modelZigbee:TS0601
                                        type:Router
                                        ieee:0x4c5bb3fffe2eaac6
                                        nwk:15437
                                        manuf name:_TZE200_la2c2uo9
                                        manufacturer:Moes
                                        power:Mains (single phase)
                                        app version:68
                                        hard version:1
                                        zcl version:3
                                        date code:
                                        interviewstate:SUCCESSFUL
                                        BindSource:true
                                        isGroupable:true
                                        configured:true
                                          holly200289
                                          #90
                                          Also es ist nur das eine Gerät was mit dem neuen Converter nicht klar kommt : model:MS-105Z
