  4. Instabiles Zigbee-Netzwerk
    6.4k
100 Beiträge 11 Kommentatoren 6.6k Aufrufe 13 Beobachtet
  • holly200289H Offline
    holly200289
    #77
    Das Log von dem Zigbee Adapter habe ich ja geschickt, was braucht ihr noch um es zu analysieren ?
      holly200289
      #78
      Ich habe ja schon einiges entfernt, was ihr angestrichen habt
        holly200289
        #79
        Soll ich mal auf die neuste Zigbee Version Updaten ?
        Und soll ich ein Screenshot von den Geräten mit Fragezeichen Schicken ?
        • holly200289H holly200289
          @Thomas-Braun
          Script v.2025-08-09
          *** BASE SYSTEM ***
          Operating System: Debian GNU/Linux 13 (trixie)
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container ☐
            Virtualization: lxc
                    Kernel: Linux 6.8.12-17-pve
              Architecture: x86-64
          OS is similar to:
          model name      : AMD Ryzen 7 5700G with Radeon Graphics
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           14:55:46 up 58 min,  2 users,  load average: 2.05, 1.26, 1.16
          CPU threads: 8
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'trixie'!
          *** TIME AND TIMEZONES ***
                         Local time: Tue 2025-12-30 14:55:46 CET
                     Universal time: Tue 2025-12-30 13:55:46 UTC
                           RTC time: n/a
          System clock synchronized: no
                        NTP service: inactive
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          admin
          HOME=/home/admin
          GROUPS=admin adm dialout sudo audio video plugdev users iobroker
          iobroker
          HOME=/home/iobroker
          SUDO_HOME=/home/admin
          GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
          *** DISPLAY-SERVER SETUP ***
          Display-Server:         false
          Unit display-manager.service could not be found.
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Mem:             27G        6.5G         20G        3.7M        244M         20G
          Swap:           1.0G          0B        1.0G
          Total:           28G        6.5G         21G
          Active iob-Instances:   83
                  26000 M total memory
                   6235 M used memory
                   6193 M active memory
                      0 M inactive memory
                  19534 M free memory
                      0 M buffer memory
                    233 M swap cache
                   1000 M total swap
                      0 M used swap
                   1000 M free swap
          top - 14:55:46 up 58 min,  2 users,  load average: 2.05, 1.26, 1.16
          Tasks: 122 total,  11 running, 111 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 33.8 us,  3.8 sy,  0.0 ni, 61.2 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
          MiB Mem :  26000.0 total,  19528.1 free,   6242.3 used,    233.1 buff/cache
          MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  19757.7 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          1 CRITICAL ERRORS DETECTED!
          Check 'sudo dmesg --level=emerg,alert,crit -T' for details
          *** FILESYSTEM ***
          Filesystem              Type   Size  Used Avail Use% Mounted on
          daten/subvol-100-disk-0 zfs    230G   19G  212G   9% /
          none                    tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                   tmpfs   16G     0   16G   0% /dev/shm
          tmpfs                   tmpfs  6.2G  184K  6.2G   1% /run
          tmpfs                   tmpfs  5.0M     0  5.0M   0% /run/lock
          tmpfs                   tmpfs   16G  3.4M   16G   1% /tmp
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
          tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
          tmpfs                   tmpfs  3.1G  8.0K  3.1G   1% /run/user/1001
          [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): mounted filesystem 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 ro with ordered data mode. Quota mode: none.
          [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): re-mounted 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE                  FSTYPE OPTIONS
          /      daten/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
          /var:
          3.2G    /var/
          1.9G    /var/lib
          1.8G    /var/lib/containerd
          1.3G    /var/log/journal/9626128f51d4471993ebdff830afe042
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          7.7G    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.6G    /opt/iobroker/iobroker-data/
          745M    /opt/iobroker/iobroker-data/files
          512M    /opt/iobroker/iobroker-data/history
          266M    /opt/iobroker/iobroker-data/backup-objects
          82M     /opt/iobroker/iobroker-data/files/vis
          21M     /opt/iobroker/iobroker-data/objects.jsonl
          18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
          17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
          17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
          17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
          USB-Devices by-id:
          No Devices found 'by-id'
          *** ZigBee Settings ***
          HINT:
          Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          HINT:
          Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v22.21.0
          /usr/bin/node           v22.21.0
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          /usr/bin/corepack       0.34.0
          nodejs:
            Installed: 22.21.0-1nodesource1
            Candidate: 22.21.0-1nodesource1
            Version table:
           *** 22.21.0-1nodesource1 600
               22.20.0-1nodesource1 600
               22.19.0-1nodesource1 600
               22.18.0-1nodesource1 600
               22.17.1-1nodesource1 600
               22.17.0-1nodesource1 600
               22.16.0-1nodesource1 600
               22.15.1-1nodesource1 600
               22.15.0-1nodesource1 600
               22.14.0-1nodesource1 600
               22.13.1-1nodesource1 600
               22.13.0-1nodesource1 600
               22.12.0-1nodesource1 600
               22.11.0-1nodesource1 600
               22.10.0-1nodesource1 600
               22.9.0-1nodesource1 600
               22.8.0-1nodesource1 600
               22.7.0-1nodesource1 600
               22.6.0-1nodesource1 600
               22.5.1-1nodesource1 600
               22.5.0-1nodesource1 600
               22.4.1-1nodesource1 600
               22.4.0-1nodesource1 600
               22.3.0-1nodesource1 600
               22.2.0-1nodesource1 600
               22.1.0-1nodesource1 600
               22.0.0-1nodesource1 600
               20.19.2+dfsg-1 500
                  500 http://deb.debian.org/debian trixie/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 392)
          Core adapters versions
          js-controller:  7.0.7
          admin:          7.7.19
          javascript:     9.0.17
          nodejs modules from github:     11
          +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
          +-- iobroker.omada@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#0f6a083c8bf8306ffcb248ad6aa80c495cec438e)
          +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#4d519d4e5494569fc898affe0d2946722a646efd)
          +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
          | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
          +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
          +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
          +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
          `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
          Adapter State
          + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.admin.2                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 127.0.0.1, run as: admin
          + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
          + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
          + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
            system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
            system.adapter.devices.0                : devices               : iobroker                                 - disabled
          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
          + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
          + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
            system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
          + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
          + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
            system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
          + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
          + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
          + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
            system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
            system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
            system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
            system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
            system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
            system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
          + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
          + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
          + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
            system.adapter.material.0               : material              : iobroker                                 - disabled
            system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
            system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
          + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
          + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
          + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
          + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
            system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
          + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
          + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
          + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
          + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
          + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          + system.adapter.places.0                 : places                : iobroker                                 -  enabled
          + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
          + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
          + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
          + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
          + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
          + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
          + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
          + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
          + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
          + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
          + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
          + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
          + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
          + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
          + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
          + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
          + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
          + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
          + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
            system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
            system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
            system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
            system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
            system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
            system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
            system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
            system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
            system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
            system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
            system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
            system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
          + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
          + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
          + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
          + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
          + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
          + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
          + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
          + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
          + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.187:1020
          + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
          + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
          + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: patch
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.7.19   , installed 7.7.19
          Adapter    "alexa-timer-vis": 2.1.2  , installed 2.1.2
          Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "backitup"     : 3.3.10   , installed 3.3.13
          Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
          Adapter    "bshb"         : 0.5.0    , installed 0.5.0
          Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
          Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
          Adapter    "devices"      : 1.2.8    , installed 1.2.8
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "email"        : 2.0.4    , installed 2.0.4
          Adapter    "espresense"   : 0.6.3    , installed 0.6.3
          Adapter    "firetv"       : 2.1.0    , installed 2.1.0
          Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
          Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
          Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
          Adapter    "geofency"     : 1.2.4    , installed 1.2.4
          Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
          Adapter    "ical"         : 1.18.1   , installed 1.18.1
          Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
          Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
          Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
          Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
          Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
          Adapter    "iot"          : 5.0.7    , installed 5.0.7
          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
          Adapter    "javascript"   : 9.0.11   , installed 9.0.17
          Controller "js-controller": 7.0.7    , installed 7.0.7
          Adapter    "kisshome-defender": 1.1.13, installed 1.1.13
          Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
          Adapter    "lovelace"     : 5.0.1    , installed 5.0.3
          Adapter    "material"     : 1.3.1    , installed 1.3.1
          Adapter    "matter"       : 0.5.5    , installed 0.5.6
          Adapter    "mihome"       : 1.4.0    , installed 1.4.0
          Adapter    "mihome-cloud" : 0.1.0    , installed 0.2.2
          Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
          Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
          Adapter    "moma"         : 1.2.9    , installed 1.2.9
          Adapter    "node-red"     : 5.2.1    , installed 6.0.7
          Adapter    "nuki"         : 2.0.0    , installed 2.0.0
          Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
          Adapter    "nut"          : 1.6.0    , installed 1.6.0
          Adapter    "openweathermap": 1.1.2   , installed 1.1.2
          Adapter    "parser"       : 2.2.4    , installed 2.2.4
          Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
          Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
          Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
          Adapter    "ping"         : 1.7.9    , installed 1.7.9
          Adapter    "places"       : 1.3.0    , installed 1.3.0
          Adapter    "proxmox"      : 2.4.0    , installed 2.4.2
          Adapter    "ring"         : 6.4.0    , installed 6.4.0
          Adapter    "roborock"     : 0.6.18   , installed 0.6.19
          Adapter    "rssfeed"      : 3.6.1    , installed 3.1.0  [Updatable]
          Adapter    "samsung"      : 0.6.1    , installed 0.6.1
          Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 10.4.1   , installed 10.4.1
          Adapter    "shuttercontrol": 2.0.7   , installed 2.0.9
          Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
          Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tinymqttbroker": 0.1.4   , installed 0.1.4
          Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "upnp"         : 1.1.0    , installed 1.1.0
          Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
          Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
          Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.3
          Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
          Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
          Adapter    "vis-material" : 0.2.0    , installed 0.2.0
          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
          Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
          Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
          Adapter    "weather-warnings": 0.10.0, installed 0.10.0
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 7.0.9
          Adapter    "webcal"       : 1.4.0    , installed 1.4.0
          Adapter    "webui"        : 1.37.0   , installed 1.38.7
          Adapter    "welcome"      : 1.0.2    , installed 1.0.2
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
          Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
          Adapter    "wled"         : 0.7.2    , installed 0.7.2
          Adapter    "yahka"        : 1.1.5    , installed 1.1.5
          Adapter    "youtube"      : 6.1.0    , installed 6.1.0
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
          Objects and States
          Objects:        56264
          States:         44667
          W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
          Hit:1 http://security.debian.org trixie-security InRelease
          Hit:2 http://deb.debian.org/debian trixie InRelease
          Hit:3 http://deb.debian.org/debian trixie-updates InRelease
          Hit:4 https://download.docker.com/linux/debian trixie InRelease
          Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          74300522   1/init
          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       74915526   11864/node-red
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       74953926   12992/io.mqtt.0
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       74956901   13090/io.shelly.0
          tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       74955979   13143/io.nuki.0
          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74918241   11341/iobroker.js-c
          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74918248   11341/iobroker.js-c
          tcp        0      0 127.0.0.1:8089          0.0.0.0:*               LISTEN      1000       74912657   11377/io.admin.2
          tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       74927827   12620/io.sonoff.0
          tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       74974337   13847/io.welcome.0
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          74289014   316/master
          tcp6       0      0 :::22                   :::*                    LISTEN      0          74302536   1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          74300523   1/init
          tcp6       0      0 :::1890                 :::*                    LISTEN      1000       74929629   12881/io.espresense
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          74289015   316/master
          tcp6       0      0 :::6824                 :::*                    LISTEN      1000       74922462   12249/io.roborock.0
          tcp6       0      0 :::7999                 :::*                    LISTEN      1000       74930602   12326/io.geofency.0
          tcp6       0      0 :::8000                 :::*                    LISTEN      1000       74975763   13649/io.upnp.0
          tcp6       0      0 :::8091                 :::*                    LISTEN      1000       74961322   13477/io.lovelace.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       74895052   11359/io.admin.1
          tcp6       0      0 :::8083                 :::*                    LISTEN      1000       74971530   13597/io.rtspStream
          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       74959152   13272/io.web.0
          tcp6       0      0 :::8084                 :::*                    LISTEN      1000       74961186   13279/io.socketio.0
          tcp6       0      0 :::8087                 :::*                    LISTEN      1000       74953472   13335/io.simple-api
          tcp6       0      0 :::61991                :::*                    LISTEN      1000       74922551   12345/io.harmony.0
          udp        0      0 0.0.0.0:42117           0.0.0.0:*                           1000       74968308   13649/io.upnp.0
          udp        0      0 0.0.0.0:58652           0.0.0.0:*                           1000       74975049   14604/io.philips-ai
          udp        0      0 0.0.0.0:42275           0.0.0.0:*                           1000       74975646   14115/io.echarts.0
          udp        0      0 0.0.0.0:42540           0.0.0.0:*                           1000       74912618   11377/io.admin.2
          udp        0      0 0.0.0.0:58952           0.0.0.0:*                           1000       74962081   13335/io.simple-api
          udp        0      0 0.0.0.0:42599           0.0.0.0:*                           1000       74957896   13125/io.cloud.0
          udp        0      0 0.0.0.0:42673           0.0.0.0:*                           1000       74906432   11810/io.node-red.0
          udp        0      0 0.0.0.0:42941           0.0.0.0:*                           1000       74927414   12408/io.places.0
          udp        0      0 0.0.0.0:42949           0.0.0.0:*                           1000       74930163   13195/io.zigbee.3
          udp        0      0 0.0.0.0:59397           0.0.0.0:*                           1000       74922173   11981/io.telegram.0
          udp        0      0 0.0.0.0:59414           0.0.0.0:*                           1000       74968170   13633/io.text2comma
          udp        0      0 0.0.0.0:43196           0.0.0.0:*                           1000       74952939   13090/io.shelly.0
          udp        0      0 0.0.0.0:59656           0.0.0.0:*                           1000       74975617   14078/io.pi-hole2.0
          udp        0      0 0.0.0.0:43355           0.0.0.0:*                           1000       74971678   13950/io.vis-2.0
          udp        0      0 0.0.0.0:59787           0.0.0.0:*                           1000       74979883   14598/io.philips-ai
          udp        0      0 0.0.0.0:59843           0.0.0.0:*                           1000       74952891   13073/io.wifilight.
          udp        0      0 0.0.0.0:59973           0.0.0.0:*                           1000       74927219   12249/io.roborock.0
          udp        0      0 0.0.0.0:43621           0.0.0.0:*                           1000       74915707   12272/io.backitup.0
          udp        0      0 0.0.0.0:43737           0.0.0.0:*                           1000       74971251   13744/io.vis-invent
          udp        0      0 0.0.0.0:43856           0.0.0.0:*                           1000       74953907   12992/io.mqtt.0
          udp        0      0 0.0.0.0:60275           0.0.0.0:*                           1000       74961454   13597/io.rtspStream
          udp        0      0 0.0.0.0:60442           0.0.0.0:*                           1000       74971550   13898/io.lightcontr
          udp        0      0 0.0.0.0:60496           0.0.0.0:*                           1000       74917842   12146/io.influxdb.0
          udp        0      0 0.0.0.0:60566           0.0.0.0:*                           1000       74924061   11615/io.javascript
          udp        0      0 0.0.0.0:60816           0.0.0.0:*                           1000       74954169   13214/io.zigbee.4
          udp        0      0 0.0.0.0:44492           0.0.0.0:*                           1000       74929862   12962/io.samsung_ti
          udp        0      0 0.0.0.0:44950           0.0.0.0:*                           1000       74958501   13493/io.moma.0
          udp        0      0 0.0.0.0:45052           0.0.0.0:*                           1000       74961539   13616/io.sourceanal
          udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       74922552   12345/io.harmony.0
          udp        0      0 0.0.0.0:45947           0.0.0.0:*                           1000       74919752   12308/io.broadlink2
          udp        0      0 0.0.0.0:46069           0.0.0.0:*                           1000       74930691   12390/io.ping.0
          udp        0      0 0.0.0.0:46306           0.0.0.0:*                           1000       74918776   11917/io.scenes.0
          udp        0      0 0.0.0.0:46332           0.0.0.0:*                           1000       74929244   12293/io.alexa2.0
          udp        0      0 0.0.0.0:47531           0.0.0.0:*                           1000       74962041   13279/io.socketio.0
          udp        0      0 0.0.0.0:47592           0.0.0.0:*                           1000       74975095   14604/io.philips-ai
          udp        0      0 0.0.0.0:47715           0.0.0.0:*                           1000       74968624   13777/io.rssfeed.0
          udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       74926171   12308/io.broadlink2
          udp        0      0 0.0.0.0:47978           0.0.0.0:*                           1000       74922744   12515/io.tr-064.2
          udp        0      0 0.0.0.0:47982           0.0.0.0:*                           1000       74895326   12084/io.whatsapp-c
          udp        0      0 0.0.0.0:48162           0.0.0.0:*                           1000       74918306   11359/io.admin.1
          udp        0      0 0.0.0.0:48367           0.0.0.0:*                           1000       74928424   12326/io.geofency.0
          udp        0      0 0.0.0.0:48543           0.0.0.0:*                           1000       74962279   12308/io.broadlink2
          udp        0      0 0.0.0.0:48635           0.0.0.0:*                           1000       74934484   12445/io.samsung.1
          udp        0      0 0.0.0.0:48715           0.0.0.0:*                           1000       74961773   13762/io.windows-co
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          74296949   1/init
          udp        0      0 0.0.0.0:49366           0.0.0.0:*                           1000       74922493   12308/io.broadlink2
          udp        0      0 0.0.0.0:49390           0.0.0.0:*                           1000       74918229   11341/iobroker.js-c
          udp        0      0 0.0.0.0:33124           0.0.0.0:*                           1000       74958395   13421/io.fullcalend
          udp        0      0 0.0.0.0:50033           0.0.0.0:*                           1000       74895117   11467/io.email.0
          udp        0      0 0.0.0.0:33701           0.0.0.0:*                           1000       74928026   12896/io.daikin-clo
          udp        0      0 0.0.0.0:33839           0.0.0.0:*                           1000       74913662   11515/io.history.0
          udp        0      0 0.0.0.0:34304           0.0.0.0:*                           1000       74971347   13829/io.slideshow.
          udp        0      0 0.0.0.0:34332           0.0.0.0:*                           1000       74906561   12065/io.telegram.1
          udp        0      0 0.0.0.0:50943           0.0.0.0:*                           1000       74953766   12881/io.espresense
          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       74958755   13649/io.upnp.0
          udp        0      0 0.0.0.0:51085           0.0.0.0:*                           1000       74971877   14038/io.vw-connect
          udp        0      0 0.0.0.0:34915           0.0.0.0:*                           1000       74926092   12116/io.whatsapp-c
          udp        0      0 0.0.0.0:35545           0.0.0.0:*                           1000       74952670   12859/io.fullybrows
          udp        0      0 0.0.0.0:35565           0.0.0.0:*                           1000       74944440   12667/io.systeminfo
          udp        0      0 0.0.0.0:52773           0.0.0.0:*                           1000       74968947   13880/io.philips-tv
          udp        0      0 0.0.0.0:52834           0.0.0.0:*                           1000       74954738   13649/io.upnp.0
          udp        0      0 0.0.0.0:36505           0.0.0.0:*                           1000       74922479   12308/io.broadlink2
          udp        0      0 0.0.0.0:53179           0.0.0.0:*                           1000       74957483   13579/io.parser.0
          udp        0      0 0.0.0.0:53197           0.0.0.0:*                           1000       74956786   13968/io.wallpanel.
          udp        0      0 0.0.0.0:53255           0.0.0.0:*                           1000       74957855   13055/io.bshb.0
          udp        0      0 0.0.0.0:36984           0.0.0.0:*                           1000       74943301   12598/io.proxmox.0
          udp        0      0 0.0.0.0:37427           0.0.0.0:*                           1000       74959074   13260/io.discovery.
          udp        0      0 0.0.0.0:37490           0.0.0.0:*                           1000       74928400   12308/io.broadlink2
          udp        0      0 0.0.0.0:37536           0.0.0.0:*                           1000       74922549   12345/io.harmony.0
          udp        0      0 0.0.0.0:54122           0.0.0.0:*                           1000       74975459   13986/io.smartthing
          udp        0      0 0.0.0.0:54147           0.0.0.0:*                           1000       74956927   13107/io.webcal.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       74987682   14611/io.ham.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       74972354   13862/io.wled.0
          udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       74937677   12497/io.tr-064.1
          udp        0      0 0.0.0.0:38156           0.0.0.0:*                           1000       74949250   12649/io.homeconnec
          udp        0      0 0.0.0.0:54744           0.0.0.0:*                           1000       74915747   12360/io.nut.0
          udp        0      0 0.0.0.0:38430           0.0.0.0:*                           1000       74953407   13272/io.web.0
          udp        0      0 0.0.0.0:55237           0.0.0.0:*                           1000       74959508   13795/io.webui.0
          udp        0      0 0.0.0.0:39188           0.0.0.0:*                           1000       74928393   12308/io.broadlink2
          udp        0      0 0.0.0.0:55666           0.0.0.0:*                           1000       74915719   12308/io.broadlink2
          udp        0      0 0.0.0.0:39363           0.0.0.0:*                           1000       74928396   12308/io.broadlink2
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       74929929   13037/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       74929930   13037/io.tuya.0
          udp        0      0 0.0.0.0:39500           0.0.0.0:*                           1000       74915716   12308/io.broadlink2
          udp        0      0 0.0.0.0:39664           0.0.0.0:*                           1000       74953318   13246/io.zigbee.1
          udp        0      0 0.0.0.0:39745           0.0.0.0:*                           1000       74971919   14097/io.omada.0
          udp        0      0 0.0.0.0:40220           0.0.0.0:*                           1000       74954488   13456/io.iqontrol.0
          udp        0      0 0.0.0.0:56644           0.0.0.0:*                           1000       74975401   13935/io.alexa-time
          udp        0      0 0.0.0.0:40283           0.0.0.0:*                           1000       74956265   13438/io.iot.0
          udp        0      0 0.0.0.0:40414           0.0.0.0:*                           1000       74961049   13222/io.zigbee.2
          udp        0      0 0.0.0.0:40511           0.0.0.0:*                           1000       74929721   12914/io.spotify-pr
          udp        0      0 0.0.0.0:40519           0.0.0.0:*                           1000       74929894   13037/io.tuya.0
          udp        0      0 0.0.0.0:40538           0.0.0.0:*                           1000       74971387   13847/io.welcome.0
          udp        0      0 0.0.0.0:40579           0.0.0.0:*                           1000       74979900   14598/io.philips-ai
          udp        0      0 0.0.0.0:40607           0.0.0.0:*                           1000       74937360   12461/io.shuttercon
          udp        0      0 0.0.0.0:57073           0.0.0.0:*                           1000       74922482   12308/io.broadlink2
          udp        0      0 0.0.0.0:57653           0.0.0.0:*                           1000       74928531   12426/io.samsung.0
          udp        0      0 0.0.0.0:41345           0.0.0.0:*                           1000       74928405   12308/io.broadlink2
          udp        0      0 0.0.0.0:57764           0.0.0.0:*                           1000       74930858   12620/io.sonoff.0
          udp        0      0 0.0.0.0:57830           0.0.0.0:*                           1000       74961320   13477/io.lovelace.0
          udp        0      0 0.0.0.0:57871           0.0.0.0:*                           1000       74928390   12308/io.broadlink2
          udp        0      0 0.0.0.0:41593           0.0.0.0:*                           1000       74972359   13862/io.wled.0
          udp        0      0 0.0.0.0:41762           0.0.0.0:*                           1000       74955912   13143/io.nuki.0
          udp6       0      0 :::111                  :::*                                0          74296950   1/init
          2025-12-30 14:56:00.831  - info: shelly.0 (13090) [authEnabled] 192.168.178.96 (shellyplus2pm / shellyplus2pm-2cbcbb3cd65c / shellyplus2pm#2cbcbb3cd65c#1): This device is not protected via restricted login (see adapter documentation for details)
          2025-12-30 14:56:01.329  - info: shelly.0 (13090) [authEnabled] 192.168.178.41 (shellyplus1 / shellyplus1-78ee4cd60b9c / shellyplus1#78ee4cd60b9c#1): This device is not protected via restricted login (see adapter documentation for details)
          2025-12-30 14:56:01.602  - info: shelly.0 (13090) [authEnabled] 192.168.178.122 (shellyplus2pm / shellyplus2pm-a0dd6c2af678 / shellyplus2pm#a0dd6c2af678#1): This device is not protected via restricted login (see adapter documentation for details)
          2025-12-30 14:56:02.747  - info: host.iobroker instance system.adapter.philips-air.1 in version "1.2.0" started with pid 14598
          2025-12-30 14:56:02.761  - info: host.iobroker instance system.adapter.philips-air.0 in version "1.2.0" started with pid 14604
          2025-12-30 14:56:02.772  - info: host.iobroker instance system.adapter.ham.0 in version "5.3.1" started with pid 14611
          2025-12-30 14:56:03.118  - info: philips-air.1 (14598) Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
          2025-12-30 14:56:03.169  - info: philips-air.0 (14604) Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
          2025-12-30 14:56:04.105  - info: philips-air.0 (14604) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.philips-air, node: v22.21.0, js-controller: 7.0.7
          2025-12-30 14:56:04.102  - info: philips-air.1 (14598) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.philips-air, node: v22.21.0, js-controller: 7.0.7
          2025-12-30 14:56:07.603  - info: shelly.0 (13090) [authEnabled] 192.168.178.110 (shellyplus2pm / shellyplus2pm-30c922740d78 / shellyplus2pm#30c922740d78#1): This device is not protected via restricted login (see adapter documentation for details)
          2025-12-30 14:56:08.272  - silly: broadlink2.0 (12308) States user redis pmessage broadlink2.0.*/broadlink2.0.RM:Broadlink-RMMINI-8e-eb-24.Temperature:{"val":13,"ack":true,"ts":1767102968271,"q":0,"from":"system.adapter.broadlink2.0","user":"system.user.admin","lc":1767102968271}
          2025-12-30 14:56:08.273  - info: broadlink2.0 (12308) debug: ChangeState ack:true of RM:Broadlink-RMMINI-8e-eb-24.Temperature = 13
          code_text
          #80
          @holly200289 sagte in Instabiles Zigbee-Netzwerk:
          Gehört nicht in die erste Ebene.
          iobroker.omada
          Ist wohl nie ordentlich veröffentlicht worden.
          iobroker.roborock
          Kann sein, dass es da Probleme mit dem Login gab, die in einem GitHub-Commit behoben sind.
          iobroker.rtspStream
          smartthings
          Zur Zeit nur als Beta über das entsprechende Repo zu installieren.
          sourceanalytix
          Ewiger Beta-Status...
          JQuery-Snowfall
          Wird wohl nicht mehr gepflegt, letztes Release im November 2013. Komplett entbehrlich, wenn man ein stabiles System haben möchte.
          magic-snowflakes
          Siehe zuvor.
          Hat in der ersten Ebene nix verloren. zigbee-herdsman-converters ist eine Dependency des zigbee-Adapters und hängt drunter.
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            #81
            Update auf die aktuelle 'latest' version kann helfen
            bringt nix.
            Ich stimme dem was @thomas-braun geschrieben hat zu - dein System ist komisch.
            Das der Adapter manchmal nicht startet liegt daran das er die Verbindung zu den Koordinatoren verliert. Beim Neustart antworten diese nicht (Insbesondere die Netzwerk Koordinatoren), weswegen die Instanz 4 auch nicht startet. Da solltest du den Koordinator mal vom strom nehmen, 30 s warten und dann wieder anklemmen. Danach die Instanz neu starten und sie sollte hoch kommen.
            Was die generelle Frage zur Instabilität angeht - es fehlen immer noch die Aussagen was passiert wenn die Instanzen instabil werden. Dazu habe ich kein Log gesehen. Ohne ist das alles nur 'allgemeines stochern im Nebel'. und Nebel gibt es auf dem System deutlich zu viel.
            A.
              holly200289
              #82
              Das stimmt nicht ganz, punkt #63 habe ich den Verlauf vom Stick gepostet
                holly200289
                #83
                Zu allen anderen Sachen Stimme ich zu, ich versuche natürlich das System so stabil wie möglich zubekommen,
                nur bei den ein oder anderen wäre Unterstützung von euch nett, ihr seht ja wo der Schuhe drückt.
                soll der entfernt werden ?
                  holly200289
                  #84
                  sourceanalytix ; also gibt es das auch nicht über die Katze ?
                    #85
                    Ich würde den im Interesse eine 'KISS'-Systems aus den Füßen haben wollen.
                    Je weniger Kokolores installiert ist, desto besser kann man Fehler finden und desto stabiler läuft so ein System auch.
                    Nicht umsonst fährt man Server eigentlich auch ohne graphische Desktopumgebung. Was nicht läuft kann nicht abstürzen, kann nicht attackiert werden und frisst keine Systemressourcen weg.
                      holly200289
                      #86
                      KISS'-Systems habe ich jetzt Deinstalliert
                        #87
                        @holly200289
                        Ich meinte zwar damit ein
                        K eep
                        I t
                        S imple and
                        S tupid
                        Setup, aber du hast Recht, der Adapter ist auch ein Streichkandidat. Deren erster Adapter hat z. B. mächtig auf die Netzwerkperformance gedrückt. Keine Ahnung, ob sich das aktuelle Ding da besser verhält.
                        Der ist wegen der negativen Erfahrungen gar nicht erst auf meiner Kiste gelandet.
                          holly200289
                          #88
                          Ich schicke euch jetzt die Geräte, die bei Zigbee 3.3.0 ein Fragezeichen haben
                          holly200289H 1 Antwort Letzte Antwort
                            holly200289
                            #89
                            model:MS-105Z
                            type:Router
                            description:Smart Dimmer module
                            hasLegacyDef:false
                            vendor:Moes
                            hasOnEvent:false
                            hasConfigure:true
                            icon:img/MS-105Z.png
                            modelZigbee:TS0601
                            type:Router
                            ieee:0x4c5bb3fffe2eaac6
                            nwk:15437
                            manuf name:_TZE200_la2c2uo9
                            manufacturer:Moes
                            power:Mains (single phase)
                            app version:68
                            hard version:1
                            zcl version:3
                            date code:
                            interviewstate:SUCCESSFUL
                            BindSource:true
                            isGroupable:true
                            configured:true
                              holly200289
                              #90
                              Also es ist nur das eine Gerät was mit dem neuen Converter nicht klar kommt : model:MS-105Z
                                holly200289
                                #91
                                Soll ich den js-Cotroller auch Updaten, oder soll ich ihn auf 7.0.7 lassen.
                                  holly200289
                                  #92
                                  Also mein System hat eigentlich schon Power, das bringt aber nur bedingt was, wenn der Traffic hoch ist, und die Software wie ein Sack Nüsse läuft.
                                  wichtig ist das es Stabil Läuft.
                                  Ich habe mir alles selbst beigebracht, da ist natürlich auch einiges schief gelaufen, siehe jetzt, aber ich bin ja lernfähig.
                                    #93
                                    Das hängt aber auch gar nicht mit dem schrägen Setup des 'Power-Systems' zusammen... :-D
                                      #94
                                      heisst was?
                                      ioBroker läuft bei 60.000 Usern "like a charm"
                                        holly200289
                                        #95
                                        Also die Adapter stürzen immer noch ab, also genau der gleich Eintrag wie oben schon erwähnt #63
                                          holly200289
                                          #96
                                          Auch bei der Version 3.3.0
