  4. Instabiles Zigbee-Netzwerk
    6.4k
100 Beiträge 11 Kommentatoren 6.6k Aufrufe 13 Beobachtet
  • holly200289H Offline
    holly200289
    zigbee.4
    Zeit
    debug
    Nachricht
    zigbee.4
    2025-12-30 08:30:59.663	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:59.663	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:59.663	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:59.660	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.660	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.511	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:59.511	error	Starting zigbee-herdsman problem : Error while opening socket
    zigbee.4
    2025-12-30 08:30:59.511	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:59.509	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.509	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.509	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:59.509	error	Starting zigbee-herdsman problem : Error while opening socket
    zigbee.4
    2025-12-30 08:30:59.509	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:59.507	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.507	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.507	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:59.507	error	Starting zigbee-herdsman problem : Error while opening socket
    zigbee.4
    2025-12-30 08:30:59.507	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:59.504	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.504	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:59.186	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:59.186	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:59.186	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:59.185	info	Starting Adapter npm ...
    zigbee.4
    2025-12-30 08:30:59.185	info	Try to reconnect.
    zigbee.4
    2025-12-30 08:30:59.184	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:58.322	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:58.322	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:58.321	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:58.320	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:58.320	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:58.319	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:58.319	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:58.319	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:58.317	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:58.317	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:58.317	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:58.317	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:58.317	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:58.315	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:58.314	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:57.220	debug	attempting to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:57.220	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
    zigbee.4
    2025-12-30 08:30:57.220	debug	attempting dns lookup for 192.168.178.240
    zigbee.4
    2025-12-30 08:30:57.220	debug	Test connection for tcp://192.168.178.240:6080
    zigbee.4
    zigbee.4
    zigbee.4
    zigbee.4
    2025-12-30 08:30:57.219	debug	Test connection for tcp://192.168.178.240:6080
    zigbee.4
    2025-12-30 08:30:57.206	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:57.206	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:57.206	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:57.204	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:57.204	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:57.204	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:57.203	info	Starting Adapter npm ...
    zigbee.4
    2025-12-30 08:30:57.203	info	Try to reconnect.
    zigbee.4
    2025-12-30 08:30:57.202	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:57.201	info	Starting Adapter npm ...
    zigbee.4
    2025-12-30 08:30:57.201	info	Try to reconnect.
    zigbee.4
    2025-12-30 08:30:57.200	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:56.779	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:56.779	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:56.779	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:56.776	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:56.776	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:56.655	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:56.655	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:56.655	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:56.652	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:56.652	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:56.096	debug	attempting to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:56.096	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
    zigbee.4
    2025-12-30 08:30:56.096	debug	attempting dns lookup for 192.168.178.240
    zigbee.4
    2025-12-30 08:30:56.095	debug	Test connection for tcp://192.168.178.240:6080
    zigbee.4
    2025-12-30 08:30:55.922	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:55.922	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:55.922	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:55.921	info	Starting Adapter npm ...
    zigbee.4
    2025-12-30 08:30:55.921	info	Try to reconnect.
    zigbee.4
    2025-12-30 08:30:55.920	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:55.248	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:55.248	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:55.248	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:55.246	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:55.246	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:55.246	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:55.246	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:55.246	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:55.244	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:55.244	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:55.244	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:55.244	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:55.244	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:55.241	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:55.241	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:54.200	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:54.200	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:54.200	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:54.198	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:54.197	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:54.197	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:54.196	info	Starting Zigbee-Herdsman
    zigbee.4
    2025-12-30 08:30:54.196	info	configured transmit power :
    zigbee.4
    2025-12-30 08:30:54.195	info	Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.4.2)
    zigbee.4
    2025-12-30 08:30:54.194	info	Starting Adapter npm ...
    zigbee.4
    2025-12-30 08:30:54.194	info	Try to reconnect.
    zigbee.4
    2025-12-30 08:30:54.194	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    zigbee.4
    zigbee.4
    2025-12-30 08:30:54.193	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:54.193	info	Starting Adapter npm ...
    zigbee.4
    2025-12-30 08:30:54.193	info	Try to reconnect.
    zigbee.4
    2025-12-30 08:30:54.192	debug	connected successfully to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:53.708	error	Failed to start Zigbee: no message given
    zigbee.4
    2025-12-30 08:30:53.708	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: Cannot request when znp has not been initialized yet)
    zigbee.4
    2025-12-30 08:30:53.708	warn	unable to stop zigbee-herdsman after failed startup
    zigbee.4
    2025-12-30 08:30:53.706	warn	Network parameters on Coordinator: panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:53.706	warn	Network parameters in Config : panID=8879 channel=15 extendedPanID=08c70133004b1200
    zigbee.4
    2025-12-30 08:30:53.150	debug	attempting to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:53.150	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.150	debug	attempting dns lookup for 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.150	debug	Test connection for tcp://192.168.178.240:6080
    zigbee.4
    2025-12-30 08:30:53.149	debug	attempting to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:53.149	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.149	debug	attempting dns lookup for 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.149	debug	Test connection for tcp://192.168.178.240:6080
    zigbee.4
    2025-12-30 08:30:53.122	debug	attempting to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:53.122	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.122	debug	attempting dns lookup for 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.121	debug	Test connection for tcp://192.168.178.240:6080
    zigbee.4
    2025-12-30 08:30:53.121	debug	attempting to connect to 192.168.178.240 port 6080
    zigbee.4
    2025-12-30 08:30:53.121	debug	dns lookup for tcp://192.168.178.240:6080 produced 192.168.178.240
    zigbee.4
    2025-12-30 08:30:53.121	debug	attempting dns lookup for 192.168.178.240
      holly200289
      Das geht jetzt immer in der Schleife, der Adapter meldet sich jetzt nicht mehr an .
        holly200289
        Die Adapter sind jetzt auch wieder auf Info gestellt
          @holly200289 sagte in Instabiles Zigbee-Netzwerk:
          zigbee-herdsman-converters
          Was liefert
          cd /opt/iobroker/
          npm ls zigbee-herdsman-converters
          holly200289
          #66
          @Thomas-Braun sagte in Instabiles Zigbee-Netzwerk:
          cd /opt/iobroker/
          Das kommt wenn ich den Befehl eingebe ........
          Last login: Mon Dec 29 21:01:27 2025 from 192.168.178.175
          admin@iobroker:~$ cd /opt/iobroker/
          [sudo] password for admin:
          iobroker.inst@3.0.0 /opt/iobroker
          +-- iobroker.zigbee@3.1.5
          | `-- zigbee-herdsman-converters@25.31.0
          `-- zigbee-herdsman-converters@25.96.0 (git+ssh://git@github.com/Koenkk/zigbee-herdsman-converters.git#e9132fc65cc0bcbef60a5793976ba192fcc845ac)
          admin@iobroker:/opt/iobroker$
          • holly200289H holly200289
            cd /opt/iobroker/
            #67
            @holly200289
            Bitte in CodeTags eingebettet posten. Und bitte NICHT aus dem Admin in falscher Chronologie mit zig Leerzeilen. Nimm das Log aus
            iob logs
            Kannst du mir mal sagen, wo du die ganzen GitHub-Klamotten herziehst? Und warum?
            Setz die ganzen Dinger auf reguläre Veröffentlichungen und deinstallier alles, was in der obersten Ebene des npm-Trees nicht mit iobroker. anfängt.
            Beispiel von meinem System:
            echad@chet:/opt/iobroker $ npm ls
            ├── iobroker.admin@7.7.22
            ├── iobroker.alexa2@3.27.4
            ├── iobroker.alias-manager@2.0.0
            ├── iobroker.ankersolix2@2.4.1
            ├── iobroker.awtrix-light@3.0.0
            ├── iobroker.backitup@3.3.13
            ├── iobroker.ble@0.14.1
            ├── iobroker.cloud@5.1.2
            ├── iobroker.devices@1.2.9
            ├── iobroker.echarts@2.0.10 (git+ssh://git@github.com/Grothesk242/ioBroker.echarts.git#7e00a1c9e78e378443ceac4396eeba04f7b7e73f)
            ├── iobroker.firetv@2.1.0
            ├── iobroker.followthesun@0.5.2
            ├── iobroker.govee-app@0.0.10 (git+ssh://git@github.com/TA2k/ioBroker.govee-app.git#d5e7f1703b520238db36cd1552c54cdfa89c6715)
            ├── iobroker.govee-local@0.4.5
            ├── iobroker.history@3.0.1
            ├── iobroker.ical@1.18.1
            ├── iobroker.iceroad@1.2.1
            ├── iobroker.iot@5.0.12
            ├── iobroker.javascript@9.0.17
            ├── iobroker.js-controller@7.1.0
            ├── iobroker.mihome-cloud@0.2.2
            ├── iobroker.mihome-vacuum@5.3.0
            ├── iobroker.mihome@1.4.0
            ├── iobroker.mqtt@6.1.4
            ├── iobroker.nina@0.0.26
            ├── iobroker.notification-manager@1.3.0
            ├── iobroker.nuki-extended@2.7.0
            ├── iobroker.nut@1.7.0
            ├── iobroker.opendtu@3.1.0
            ├── iobroker.openweathermap@1.4.0
            ├── iobroker.parcel@0.2.10 (git+ssh://git@github.com/Grothesk242/ioBroker.parcel.git#8ab31b96827d3612b4a9dc8dd59ad8858456ce82)
            ├── iobroker.playstation@0.0.3
            ├── iobroker.rpi2@3.0.2
            ├── iobroker.sainlogic@1.1.1
            ├── iobroker.samsung_tizen@1.1.0
            ├── iobroker.samsung@0.6.1
            ├── iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/DrozmotiX/ioBroker.switchbot-hub.git#7a05fa59dfc5e3ce8d73018badc4e420996452f8)
            ├── iobroker.tado@0.8.3
            ├── iobroker.tr-064@4.3.0
            ├── iobroker.tradfri@3.1.3
            ├── iobroker.trashschedule@5.2.0
            ├── iobroker.tuya@3.17.0
            ├── iobroker.weather-warnings@0.10.0
            ├── iobroker.web@7.0.9
            ├── iobroker.whatsapp-cmb@0.3.0
            └── iobroker.zigbee@3.3.0
            So sieht ein halbwegs rundes System aus. Die vier GitHub-Installationen erklären sich: 2 sind von mir für nodejs>22 gepatchte Versionen aus meinem eigenen Repo und govee-app undd switchbot-hub sind nie in einem Repo gelandet.
              holly200289
              #68
              Lösche ich die Instanzen ? oder gibt es dafür einen Befehl über SSH ?
                #69
                @holly200289
                Setz zuerst mal alle Adapter wieder auf Repos auf.
                Am Beispiel von nuki-extended.
                iob upgrade nuki-extended@2.7.0
                Wenn das alles bereingt ist schaust du nach dem dann noch vorhandenen Rest.
                holly200289H 1 Antwort Letzte Antwort
                  holly200289
                  #70
                  Ich habe jetzt das ein oder andere deinstalliert, nur alles Funktioniert nicht dann laufen gewisse Prozesse nicht mehr, z.b iobroker.roborock@0.6. 9, iobroker.sourceanalytix@0.4.14, JQuery-Snowfall@1.7.1 sonst Funktionieren ein paar Sachen nicht mehr,
                  der iobroker.rtspStream@0.0.2 lässt sich nicht mehr >deinstallieren, da gab es mal ein Fehler seit den läuft der leider mit, alles andere habe ich versucht.
                    @holly200289
                    holly200289
                    #71
                    @Thomas-Braun
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                    Operating System: Debian GNU/Linux 13 (trixie)
                     Static hostname: iobroker
                           Icon name: computer-container
                             Chassis: container ☐
                      Virtualization: lxc
                              Kernel: Linux 6.8.12-17-pve
                        Architecture: x86-64
                    OS is similar to:
                    model name      : AMD Ryzen 7 5700G with Radeon Graphics
                    Docker          : false
                    Virtualization  : lxc
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     14:55:46 up 58 min,  2 users,  load average: 2.05, 1.26, 1.16
                    CPU threads: 8
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'trixie'!
                    *** TIME AND TIMEZONES ***
                                   Local time: Tue 2025-12-30 14:55:46 CET
                               Universal time: Tue 2025-12-30 13:55:46 UTC
                                     RTC time: n/a
                    System clock synchronized: no
                                  NTP service: inactive
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    admin
                    HOME=/home/admin
                    GROUPS=admin adm dialout sudo audio video plugdev users iobroker
                    iobroker
                    HOME=/home/iobroker
                    SUDO_HOME=/home/admin
                    GROUPS=iobroker tty dialout audio video plugdev bluetooth docker
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:             27G        6.5G         20G        3.7M        244M         20G
                    Swap:           1.0G          0B        1.0G
                    Total:           28G        6.5G         21G
                    Active iob-Instances:   83
                            26000 M total memory
                             6235 M used memory
                             6193 M active memory
                                0 M inactive memory
                            19534 M free memory
                                0 M buffer memory
                              233 M swap cache
                             1000 M total swap
                                0 M used swap
                             1000 M free swap
                    top - 14:55:46 up 58 min,  2 users,  load average: 2.05, 1.26, 1.16
                    Tasks: 122 total,  11 running, 111 sleeping,   0 stopped,   0 zombie
                    %Cpu(s): 33.8 us,  3.8 sy,  0.0 ni, 61.2 id,  0.0 wa,  0.0 hi,  1.2 si,  0.0 st
                    MiB Mem :  26000.0 total,  19528.1 free,   6242.3 used,    233.1 buff/cache
                    MiB Swap:   1000.0 total,   1000.0 free,      0.0 used.  19757.7 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    1 CRITICAL ERRORS DETECTED!
                    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                    *** FILESYSTEM ***
                    Filesystem              Type   Size  Used Avail Use% Mounted on
                    daten/subvol-100-disk-0 zfs    230G   19G  212G   9% /
                    none                    tmpfs  492K  4.0K  488K   1% /dev
                    tmpfs                   tmpfs   16G     0   16G   0% /dev/shm
                    tmpfs                   tmpfs  6.2G  184K  6.2G   1% /run
                    tmpfs                   tmpfs  5.0M     0  5.0M   0% /run/lock
                    tmpfs                   tmpfs   16G  3.4M   16G   1% /tmp
                    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
                    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
                    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/console-getty.service
                    tmpfs                   tmpfs  1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
                    tmpfs                   tmpfs  3.1G  8.0K  3.1G   1% /run/user/1001
                    [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): mounted filesystem 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 ro with ordered data mode. Quota mode: none.
                    [Mon Dec 29 12:46:49 2025] EXT4-fs (dm-1): re-mounted 8454bac7-7b31-4e6e-a8ae-07a4b96134b1 r/w. Quota mode: none.
                    Show mounted filesystems:
                    TARGET SOURCE                  FSTYPE OPTIONS
                    /      daten/subvol-100-disk-0 zfs    rw,relatime,xattr,posixacl,casesensitive
                    /var:
                    3.2G    /var/
                    1.9G    /var/lib
                    1.8G    /var/lib/containerd
                    1.3G    /var/log/journal/9626128f51d4471993ebdff830afe042
                    Archived and active journals take up 1.2G in the file system.
                    /opt/iobroker/backups:
                    7.7G    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    1.6G    /opt/iobroker/iobroker-data/
                    745M    /opt/iobroker/iobroker-data/files
                    512M    /opt/iobroker/iobroker-data/history
                    266M    /opt/iobroker/iobroker-data/backup-objects
                    82M     /opt/iobroker/iobroker-data/files/vis
                    21M     /opt/iobroker/iobroker-data/objects.jsonl
                    18M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                    17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
                    17M     /opt/iobroker/iobroker-data/history/20241203/history.pi-hole.0.overTimeData10mins.ads_over_time.data-table.json
                    17M     /opt/iobroker/iobroker-data/history/20241202/history.pi-hole.0.overTimeData10mins.domains_over_time.data-table.json
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    *** ZigBee Settings ***
                    HINT:
                    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    HINT:
                    Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    HINT:
                    Your zigbee.3 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v22.21.0
                    /usr/bin/node           v22.21.0
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    /usr/bin/corepack       0.34.0
                    nodejs:
                      Installed: 22.21.0-1nodesource1
                      Candidate: 22.21.0-1nodesource1
                      Version table:
                     *** 22.21.0-1nodesource1 600
                         22.20.0-1nodesource1 600
                         22.19.0-1nodesource1 600
                         22.18.0-1nodesource1 600
                         22.17.1-1nodesource1 600
                         22.17.0-1nodesource1 600
                         22.16.0-1nodesource1 600
                         22.15.1-1nodesource1 600
                         22.15.0-1nodesource1 600
                         22.14.0-1nodesource1 600
                         22.13.1-1nodesource1 600
                         22.13.0-1nodesource1 600
                         22.12.0-1nodesource1 600
                         22.11.0-1nodesource1 600
                         22.10.0-1nodesource1 600
                         22.9.0-1nodesource1 600
                         22.8.0-1nodesource1 600
                         22.7.0-1nodesource1 600
                         22.6.0-1nodesource1 600
                         22.5.1-1nodesource1 600
                         22.5.0-1nodesource1 600
                         22.4.1-1nodesource1 600
                         22.4.0-1nodesource1 600
                         22.3.0-1nodesource1 600
                         22.2.0-1nodesource1 600
                         22.1.0-1nodesource1 600
                         22.0.0-1nodesource1 600
                         20.19.2+dfsg-1 500
                            500 http://deb.debian.org/debian trixie/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 392)
                    Core adapters versions
                    js-controller:  7.0.7
                    admin:          7.7.19
                    javascript:     9.0.17
                    nodejs modules from github:     11
                    +-- @iobroker/plugin-sentry@2.0.4 (git+ssh://git@github.com/ioBroker/plugin-sentry.git#31c593552c25cd0f10e2946589fbc88ad30cc480)
                    +-- iobroker.omada@0.0.7 (git+ssh://git@github.com/TA2k/ioBroker.omada.git#0f6a083c8bf8306ffcb248ad6aa80c495cec438e)
                    +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#4d519d4e5494569fc898affe0d2946722a646efd)
                    +-- iobroker.rtspStream@0.0.2 (git+ssh://git@github.com/dbweb-ch/ioBroker.rtspStream.git#3891a8545b5566946b89b6f4dbfeac1e2a6527a5)
                    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
                    +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#b055221990231cf4c8b7fbfd6bee94ff59b0fd75)
                    +-- iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#9c4635239c7b9321601dcf0fcdd8677a55a8b13f)
                    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                    +-- JQuery-Snowfall@1.7.1 (git+ssh://git@github.com/loktar00/JQuery-Snowfall.git#d22ba78f76804e21404bc000142c019d6c10973d)
                    +-- magic-snowflakes@7.0.1 (git+ssh://git@github.com/hcodes/snowflakes.git#718a2b06c3d590ea89081700d96cfa014074dd4a)
                    Adapter State
                    + system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                    + system.adapter.admin.2                  : admin                 : iobroker                                 -  enabled, port: 8089, bind: 127.0.0.1, run as: admin
                    + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                    + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
                    + system.adapter.bshb.0                   : bshb                  : iobroker                                 -  enabled
                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    + system.adapter.daikin-cloud.0           : daikin-cloud          : iobroker                                 -  enabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                      system.adapter.devices.0                : devices               : iobroker                                 - disabled
                    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                    + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                    + system.adapter.espresense.0             : espresense            : iobroker                                 -  enabled
                      system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
                    + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                    + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
                      system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                    + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
                    + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                    + system.adapter.history.0                : history               : iobroker                                 -  enabled
                    + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                      system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                      system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                      system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
                      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                    + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    + system.adapter.lightcontrol.0           : lightcontrol          : iobroker                                 -  enabled
                    + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
                      system.adapter.material.0               : material              : iobroker                                 - disabled
                      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
                      system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
                    + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                    + system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
                    + system.adapter.omada.0                  : omada                 : iobroker                                 -  enabled, port: 8043
                      system.adapter.openweathermap.1         : openweathermap        : iobroker                                 -  enabled
                    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                    + system.adapter.philips-air.0            : philips-air           : iobroker                                 -  enabled
                    + system.adapter.philips-air.1            : philips-air           : iobroker                                 -  enabled
                    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
                    + system.adapter.pi-hole2.0               : pi-hole2              : iobroker                                 -  enabled, port: 80
                    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                    + system.adapter.places.0                 : places                : iobroker                                 -  enabled
                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                    + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
                    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
                    + system.adapter.rtspStream.0             : rtspStream            : iobroker                                 -  enabled, port: 8083
                    + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
                    + system.adapter.samsung.1                : samsung               : iobroker                                 -  enabled
                    + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
                    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.slideshow.0              : slideshow             : iobroker                                 -  enabled
                    + system.adapter.smartthings.0            : smartthings           : iobroker                                 -  enabled
                    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 192.168.178.250
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                    + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
                    + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5001
                    + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                    + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.tr-064.2                 : tr-064                : iobroker                                 -  enabled
                    + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                    + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                      system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
                      system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                      system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                    + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                    + system.adapter.wallpanel.0              : wallpanel             : iobroker                                 -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                    + system.adapter.webcal.0                 : webcal                : iobroker                                 -  enabled
                    + system.adapter.webui.0                  : webui                 : iobroker                                 -  enabled
                    + system.adapter.welcome.0                : welcome               : iobroker                                 -  enabled, port: 8080, bind: 192.168.178.250 (SSL), run as: admin
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled
                    + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled
                    + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
                    + system.adapter.windows-control.0        : windows-control       : iobroker                                 -  enabled
                    + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                      system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                    + system.adapter.zigbee.1                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.187:1020
                    + system.adapter.zigbee.2                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.38:2030
                    + system.adapter.zigbee.3                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.230:4060
                    + system.adapter.zigbee.4                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.178.240:6080
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Upgrade policy: patch
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.7.19   , installed 7.7.19
                    Adapter    "alexa-timer-vis": 2.1.2  , installed 2.1.2
                    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                    Adapter    "backitup"     : 3.3.10   , installed 3.3.13
                    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                    Adapter    "bshb"         : 0.5.0    , installed 0.5.0
                    Adapter    "daikin-cloud" : 0.4.12   , installed 0.4.12
                    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
                    Adapter    "devices"      : 1.2.8    , installed 1.2.8
                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                    Adapter    "email"        : 2.0.4    , installed 2.0.4
                    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
                    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
                    Adapter    "flexcharts"   : 0.6.1    , installed 0.6.1
                    Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                    Adapter    "geofency"     : 1.2.4    , installed 1.2.4
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "ham"          : 5.3.1    , installed 5.3.1
                    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
                    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                    Adapter    "ical"         : 1.18.1   , installed 1.18.1
                    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
                    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
                    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
                    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
                    Adapter    "iot"          : 5.0.7    , installed 5.0.7
                    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                    Adapter    "javascript"   : 9.0.11   , installed 9.0.17
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "kisshome-defender": 1.1.13, installed 1.1.13
                    Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
                    Adapter    "lovelace"     : 5.0.1    , installed 5.0.3
                    Adapter    "material"     : 1.3.1    , installed 1.3.1
                    Adapter    "matter"       : 0.5.5    , installed 0.5.6
                    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
                    Adapter    "mihome-cloud" : 0.1.0    , installed 0.2.2
                    Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
                    Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
                    Adapter    "moma"         : 1.2.9    , installed 1.2.9
                    Adapter    "node-red"     : 5.2.1    , installed 6.0.7
                    Adapter    "nuki"         : 2.0.0    , installed 2.0.0
                    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
                    Adapter    "nut"          : 1.6.0    , installed 1.6.0
                    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                    Adapter    "parser"       : 2.2.4    , installed 2.2.4
                    Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
                    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
                    Adapter    "pi-hole2"     : 1.1.1    , installed 1.1.1
                    Adapter    "ping"         : 1.7.9    , installed 1.7.9
                    Adapter    "places"       : 1.3.0    , installed 1.3.0
                    Adapter    "proxmox"      : 2.4.0    , installed 2.4.2
                    Adapter    "ring"         : 6.4.0    , installed 6.4.0
                    Adapter    "roborock"     : 0.6.18   , installed 0.6.19
                    Adapter    "rssfeed"      : 3.6.1    , installed 3.1.0  [Updatable]
                    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                    Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.9
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
                    Adapter    "synology"     : 3.1.0    , installed 3.1.0
                    Adapter    "systeminfo"   : 1.3.0    , installed 1.3.0
                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                    Adapter    "tinymqttbroker": 0.1.4   , installed 0.1.4
                    Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.3
                    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                    Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
                    Adapter    "weather-warnings": 0.10.0, installed 0.10.0
                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                    Adapter    "web"          : 7.0.8    , installed 7.0.9
                    Adapter    "webcal"       : 1.4.0    , installed 1.4.0
                    Adapter    "webui"        : 1.37.0   , installed 1.38.7
                    Adapter    "welcome"      : 1.0.2    , installed 1.0.2
                    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                    Adapter    "wifilight"    : 2.0.3    , installed 2.0.3
                    Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
                    Adapter    "wled"         : 0.7.2    , installed 0.7.2
                    Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                    Adapter    "youtube"      : 6.1.0    , installed 6.1.0
                    Adapter    "yr"           : 5.3.0    , installed 5.3.0
                    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                    Objects and States
                    Objects:        56264
                    States:         44667
                    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                    Hit:1 http://security.debian.org trixie-security InRelease
                    Hit:2 http://deb.debian.org/debian trixie InRelease
                    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                    Hit:4 https://download.docker.com/linux/debian trixie InRelease
                    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          74300522   1/init
                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       74915526   11864/node-red
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       74953926   12992/io.mqtt.0
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       74956901   13090/io.shelly.0
                    tcp        0      0 192.168.178.250:9092    0.0.0.0:*               LISTEN      1000       74955979   13143/io.nuki.0
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       74918241   11341/iobroker.js-c
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       74918248   11341/iobroker.js-c
                    tcp        0      0 127.0.0.1:8089          0.0.0.0:*               LISTEN      1000       74912657   11377/io.admin.2
                    tcp        0      0 192.168.178.250:1886    0.0.0.0:*               LISTEN      1000       74927827   12620/io.sonoff.0
                    tcp        0      0 192.168.178.250:8080    0.0.0.0:*               LISTEN      1000       74974337   13847/io.welcome.0
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          74289014   316/master
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          74302536   1/init
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          74300523   1/init
                    tcp6       0      0 :::1890                 :::*                    LISTEN      1000       74929629   12881/io.espresense
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          74289015   316/master
                    tcp6       0      0 :::6824                 :::*                    LISTEN      1000       74922462   12249/io.roborock.0
                    tcp6       0      0 :::7999                 :::*                    LISTEN      1000       74930602   12326/io.geofency.0
                    tcp6       0      0 :::8000                 :::*                    LISTEN      1000       74975763   13649/io.upnp.0
                    tcp6       0      0 :::8091                 :::*                    LISTEN      1000       74961322   13477/io.lovelace.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       74895052   11359/io.admin.1
                    tcp6       0      0 :::8083                 :::*                    LISTEN      1000       74971530   13597/io.rtspStream
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       74959152   13272/io.web.0
                    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       74961186   13279/io.socketio.0
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       74953472   13335/io.simple-api
                    tcp6       0      0 :::61991                :::*                    LISTEN      1000       74922551   12345/io.harmony.0
                    udp        0      0 0.0.0.0:42117           0.0.0.0:*                           1000       74968308   13649/io.upnp.0
                    udp        0      0 0.0.0.0:58652           0.0.0.0:*                           1000       74975049   14604/io.philips-ai
                    udp        0      0 0.0.0.0:42275           0.0.0.0:*                           1000       74975646   14115/io.echarts.0
                    udp        0      0 0.0.0.0:42540           0.0.0.0:*                           1000       74912618   11377/io.admin.2
                    udp        0      0 0.0.0.0:58952           0.0.0.0:*                           1000       74962081   13335/io.simple-api
                    udp        0      0 0.0.0.0:42599           0.0.0.0:*                           1000       74957896   13125/io.cloud.0
                    udp        0      0 0.0.0.0:42673           0.0.0.0:*                           1000       74906432   11810/io.node-red.0
                    udp        0      0 0.0.0.0:42941           0.0.0.0:*                           1000       74927414   12408/io.places.0
                    udp        0      0 0.0.0.0:42949           0.0.0.0:*                           1000       74930163   13195/io.zigbee.3
                    udp        0      0 0.0.0.0:59397           0.0.0.0:*                           1000       74922173   11981/io.telegram.0
                    udp        0      0 0.0.0.0:59414           0.0.0.0:*                           1000       74968170   13633/io.text2comma
                    udp        0      0 0.0.0.0:43196           0.0.0.0:*                           1000       74952939   13090/io.shelly.0
                    udp        0      0 0.0.0.0:59656           0.0.0.0:*                           1000       74975617   14078/io.pi-hole2.0
                    udp        0      0 0.0.0.0:43355           0.0.0.0:*                           1000       74971678   13950/io.vis-2.0
                    udp        0      0 0.0.0.0:59787           0.0.0.0:*                           1000       74979883   14598/io.philips-ai
                    udp        0      0 0.0.0.0:59843           0.0.0.0:*                           1000       74952891   13073/io.wifilight.
                    udp        0      0 0.0.0.0:59973           0.0.0.0:*                           1000       74927219   12249/io.roborock.0
                    udp        0      0 0.0.0.0:43621           0.0.0.0:*                           1000       74915707   12272/io.backitup.0
                    udp        0      0 0.0.0.0:43737           0.0.0.0:*                           1000       74971251   13744/io.vis-invent
                    udp        0      0 0.0.0.0:43856           0.0.0.0:*                           1000       74953907   12992/io.mqtt.0
                    udp        0      0 0.0.0.0:60275           0.0.0.0:*                           1000       74961454   13597/io.rtspStream
                    udp        0      0 0.0.0.0:60442           0.0.0.0:*                           1000       74971550   13898/io.lightcontr
                    udp        0      0 0.0.0.0:60496           0.0.0.0:*                           1000       74917842   12146/io.influxdb.0
                    udp        0      0 0.0.0.0:60566           0.0.0.0:*                           1000       74924061   11615/io.javascript
                    udp        0      0 0.0.0.0:60816           0.0.0.0:*                           1000       74954169   13214/io.zigbee.4
                    udp        0      0 0.0.0.0:44492           0.0.0.0:*                           1000       74929862   12962/io.samsung_ti
                    udp        0      0 0.0.0.0:44950           0.0.0.0:*                           1000       74958501   13493/io.moma.0
                    udp        0      0 0.0.0.0:45052           0.0.0.0:*                           1000       74961539   13616/io.sourceanal
                    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       74922552   12345/io.harmony.0
                    udp        0      0 0.0.0.0:45947           0.0.0.0:*                           1000       74919752   12308/io.broadlink2
                    udp        0      0 0.0.0.0:46069           0.0.0.0:*                           1000       74930691   12390/io.ping.0
                    udp        0      0 0.0.0.0:46306           0.0.0.0:*                           1000       74918776   11917/io.scenes.0
                    udp        0      0 0.0.0.0:46332           0.0.0.0:*                           1000       74929244   12293/io.alexa2.0
                    udp        0      0 0.0.0.0:47531           0.0.0.0:*                           1000       74962041   13279/io.socketio.0
                    udp        0      0 0.0.0.0:47592           0.0.0.0:*                           1000       74975095   14604/io.philips-ai
                    udp        0      0 0.0.0.0:47715           0.0.0.0:*                           1000       74968624   13777/io.rssfeed.0
                    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       74926171   12308/io.broadlink2
                    udp        0      0 0.0.0.0:47978           0.0.0.0:*                           1000       74922744   12515/io.tr-064.2
                    udp        0      0 0.0.0.0:47982           0.0.0.0:*                           1000       74895326   12084/io.whatsapp-c
                    udp        0      0 0.0.0.0:48162           0.0.0.0:*                           1000       74918306   11359/io.admin.1
                    udp        0      0 0.0.0.0:48367           0.0.0.0:*                           1000       74928424   12326/io.geofency.0
                    udp        0      0 0.0.0.0:48543           0.0.0.0:*                           1000       74962279   12308/io.broadlink2
                    udp        0      0 0.0.0.0:48635           0.0.0.0:*                           1000       74934484   12445/io.samsung.1
                    udp        0      0 0.0.0.0:48715           0.0.0.0:*                           1000       74961773   13762/io.windows-co
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          74296949   1/init
                    udp        0      0 0.0.0.0:49366           0.0.0.0:*                           1000       74922493   12308/io.broadlink2
                    udp        0      0 0.0.0.0:49390           0.0.0.0:*                           1000       74918229   11341/iobroker.js-c
                    udp        0      0 0.0.0.0:33124           0.0.0.0:*                           1000       74958395   13421/io.fullcalend
                    udp        0      0 0.0.0.0:50033           0.0.0.0:*                           1000       74895117   11467/io.email.0
                    udp        0      0 0.0.0.0:33701           0.0.0.0:*                           1000       74928026   12896/io.daikin-clo
                    udp        0      0 0.0.0.0:33839           0.0.0.0:*                           1000       74913662   11515/io.history.0
                    udp        0      0 0.0.0.0:34304           0.0.0.0:*                           1000       74971347   13829/io.slideshow.
                    udp        0      0 0.0.0.0:34332           0.0.0.0:*                           1000       74906561   12065/io.telegram.1
                    udp        0      0 0.0.0.0:50943           0.0.0.0:*                           1000       74953766   12881/io.espresense
                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       74958755   13649/io.upnp.0
                    udp        0      0 0.0.0.0:51085           0.0.0.0:*                           1000       74971877   14038/io.vw-connect
                    udp        0      0 0.0.0.0:34915           0.0.0.0:*                           1000       74926092   12116/io.whatsapp-c
                    udp        0      0 0.0.0.0:35545           0.0.0.0:*                           1000       74952670   12859/io.fullybrows
                    udp        0      0 0.0.0.0:35565           0.0.0.0:*                           1000       74944440   12667/io.systeminfo
                    udp        0      0 0.0.0.0:52773           0.0.0.0:*                           1000       74968947   13880/io.philips-tv
                    udp        0      0 0.0.0.0:52834           0.0.0.0:*                           1000       74954738   13649/io.upnp.0
                    udp        0      0 0.0.0.0:36505           0.0.0.0:*                           1000       74922479   12308/io.broadlink2
                    udp        0      0 0.0.0.0:53179           0.0.0.0:*                           1000       74957483   13579/io.parser.0
                    udp        0      0 0.0.0.0:53197           0.0.0.0:*                           1000       74956786   13968/io.wallpanel.
                    udp        0      0 0.0.0.0:53255           0.0.0.0:*                           1000       74957855   13055/io.bshb.0
                    udp        0      0 0.0.0.0:36984           0.0.0.0:*                           1000       74943301   12598/io.proxmox.0
                    udp        0      0 0.0.0.0:37427           0.0.0.0:*                           1000       74959074   13260/io.discovery.
                    udp        0      0 0.0.0.0:37490           0.0.0.0:*                           1000       74928400   12308/io.broadlink2
                    udp        0      0 0.0.0.0:37536           0.0.0.0:*                           1000       74922549   12345/io.harmony.0
                    udp        0      0 0.0.0.0:54122           0.0.0.0:*                           1000       74975459   13986/io.smartthing
                    udp        0      0 0.0.0.0:54147           0.0.0.0:*                           1000       74956927   13107/io.webcal.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       74987682   14611/io.ham.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       74972354   13862/io.wled.0
                    udp        0      0 192.168.178.250:5353    0.0.0.0:*                           1000       74937677   12497/io.tr-064.1
                    udp        0      0 0.0.0.0:38156           0.0.0.0:*                           1000       74949250   12649/io.homeconnec
                    udp        0      0 0.0.0.0:54744           0.0.0.0:*                           1000       74915747   12360/io.nut.0
                    udp        0      0 0.0.0.0:38430           0.0.0.0:*                           1000       74953407   13272/io.web.0
                    udp        0      0 0.0.0.0:55237           0.0.0.0:*                           1000       74959508   13795/io.webui.0
                    udp        0      0 0.0.0.0:39188           0.0.0.0:*                           1000       74928393   12308/io.broadlink2
                    udp        0      0 0.0.0.0:55666           0.0.0.0:*                           1000       74915719   12308/io.broadlink2
                    udp        0      0 0.0.0.0:39363           0.0.0.0:*                           1000       74928396   12308/io.broadlink2
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       74929929   13037/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       74929930   13037/io.tuya.0
                    udp        0      0 0.0.0.0:39500           0.0.0.0:*                           1000       74915716   12308/io.broadlink2
                    udp        0      0 0.0.0.0:39664           0.0.0.0:*                           1000       74953318   13246/io.zigbee.1
                    udp        0      0 0.0.0.0:39745           0.0.0.0:*                           1000       74971919   14097/io.omada.0
                    udp        0      0 0.0.0.0:40220           0.0.0.0:*                           1000       74954488   13456/io.iqontrol.0
                    udp        0      0 0.0.0.0:56644           0.0.0.0:*                           1000       74975401   13935/io.alexa-time
                    udp        0      0 0.0.0.0:40283           0.0.0.0:*                           1000       74956265   13438/io.iot.0
                    udp        0      0 0.0.0.0:40414           0.0.0.0:*                           1000       74961049   13222/io.zigbee.2
                    udp        0      0 0.0.0.0:40511           0.0.0.0:*                           1000       74929721   12914/io.spotify-pr
                    udp        0      0 0.0.0.0:40519           0.0.0.0:*                           1000       74929894   13037/io.tuya.0
                    udp        0      0 0.0.0.0:40538           0.0.0.0:*                           1000       74971387   13847/io.welcome.0
                    udp        0      0 0.0.0.0:40579           0.0.0.0:*                           1000       74979900   14598/io.philips-ai
                    udp        0      0 0.0.0.0:40607           0.0.0.0:*                           1000       74937360   12461/io.shuttercon
                    udp        0      0 0.0.0.0:57073           0.0.0.0:*                           1000       74922482   12308/io.broadlink2
                    udp        0      0 0.0.0.0:57653           0.0.0.0:*                           1000       74928531   12426/io.samsung.0
                    udp        0      0 0.0.0.0:41345           0.0.0.0:*                           1000       74928405   12308/io.broadlink2
                    udp        0      0 0.0.0.0:57764           0.0.0.0:*                           1000       74930858   12620/io.sonoff.0
                    udp        0      0 0.0.0.0:57830           0.0.0.0:*                           1000       74961320   13477/io.lovelace.0
                    udp        0      0 0.0.0.0:57871           0.0.0.0:*                           1000       74928390   12308/io.broadlink2
                    udp        0      0 0.0.0.0:41593           0.0.0.0:*                           1000       74972359   13862/io.wled.0
                    udp        0      0 0.0.0.0:41762           0.0.0.0:*                           1000       74955912   13143/io.nuki.0
                    udp6       0      0 :::111                  :::*                                0          74296950   1/init
                    2025-12-30 14:56:00.831  - info: shelly.0 (13090) [authEnabled] 192.168.178.96 (shellyplus2pm / shellyplus2pm-2cbcbb3cd65c / shellyplus2pm#2cbcbb3cd65c#1): This device is not protected via restricted login (see adapter documentation for details)
                    2025-12-30 14:56:01.329  - info: shelly.0 (13090) [authEnabled] 192.168.178.41 (shellyplus1 / shellyplus1-78ee4cd60b9c / shellyplus1#78ee4cd60b9c#1): This device is not protected via restricted login (see adapter documentation for details)
                    2025-12-30 14:56:01.602  - info: shelly.0 (13090) [authEnabled] 192.168.178.122 (shellyplus2pm / shellyplus2pm-a0dd6c2af678 / shellyplus2pm#a0dd6c2af678#1): This device is not protected via restricted login (see adapter documentation for details)
                    2025-12-30 14:56:02.747  - info: host.iobroker instance system.adapter.philips-air.1 in version "1.2.0" started with pid 14598
                    2025-12-30 14:56:02.761  - info: host.iobroker instance system.adapter.philips-air.0 in version "1.2.0" started with pid 14604
                    2025-12-30 14:56:02.772  - info: host.iobroker instance system.adapter.ham.0 in version "5.3.1" started with pid 14611
                    2025-12-30 14:56:03.118  - info: philips-air.1 (14598) Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
                    2025-12-30 14:56:03.169  - info: philips-air.0 (14604) Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
                    2025-12-30 14:56:04.105  - info: philips-air.0 (14604) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.philips-air, node: v22.21.0, js-controller: 7.0.7
                    2025-12-30 14:56:04.102  - info: philips-air.1 (14598) starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.philips-air, node: v22.21.0, js-controller: 7.0.7
                    2025-12-30 14:56:07.603  - info: shelly.0 (13090) [authEnabled] 192.168.178.110 (shellyplus2pm / shellyplus2pm-30c922740d78 / shellyplus2pm#30c922740d78#1): This device is not protected via restricted login (see adapter documentation for details)
                    2025-12-30 14:56:08.272  - silly: broadlink2.0 (12308) States user redis pmessage broadlink2.0.*/broadlink2.0.RM:Broadlink-RMMINI-8e-eb-24.Temperature:{"val":13,"ack":true,"ts":1767102968271,"q":0,"from":"system.adapter.broadlink2.0","user":"system.user.admin","lc":1767102968271}
                    2025-12-30 14:56:08.273  - info: broadlink2.0 (12308) debug: ChangeState ack:true of RM:Broadlink-RMMINI-8e-eb-24.Temperature = 13
                    code_text
                    holly200289H Thomas BraunT 3 Antworten Letzte Antwort
                      @Thomas-Braun
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                        Virtualization: lxc
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                      CPU threads: 8
                                       RTC time: n/a
                                RTC in local TZ: no
                      admin
                      HOME=/home/admin
                      iobroker
                      HOME=/home/iobroker
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                      Swap:           1.0G          0B        1.0G
                      Total:           28G        6.5G         21G
                               6235 M used memory
                                  0 M inactive memory
                              19534 M free memory
                                  0 M buffer memory
                                233 M swap cache
                               1000 M total swap
                                  0 M used swap
                               1000 M free swap
                      *** FILESYSTEM ***
                      /var:
                      3.2G    /var/
                      1.9G    /var/lib
                      USB-Devices by-id:
                      HINT:
                      tcp
                      HINT:
                      tcp
                      HINT:
                      tcp
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.19
                      javascript:     9.0.17
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        56264
                      States:         44667
                      Pending Updates: 0
                      code_text
                      holly200289
                      #72
                      admin@iobroker:~$ iob logs
                      Uncaught Rejection: Error: Cannot create a string longer than 0x1fffffe8 characters
                          at Object.slice (node:buffer:636:37)
                          at Buffer.toString (node:buffer:864:14)
                          at CLILogs.execute (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/cli/cliLogs.js:36:51)
                          at processCommand (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js:1012:25)
                          at Module.execute (file:///opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup.js:2661:5)
                          at file:///opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:55
                      admin@iobroker:~$
                        @Thomas-Braun
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                          Virtualization: lxc
                        OS is similar to:
                        Docker          : false
                        Kernel          : x86_64
                        Userland        : 64 bit
                        CPU threads: 8
                                         RTC time: n/a
                                  RTC in local TZ: no
                        admin
                        HOME=/home/admin
                        iobroker
                        HOME=/home/iobroker
                        Display-Manager:
                        Desktop:
                        Session:                tty
                        *** MEMORY ***
                        Swap:           1.0G          0B        1.0G
                        Total:           28G        6.5G         21G
                                 6235 M used memory
                                    0 M inactive memory
                                19534 M free memory
                                    0 M buffer memory
                                  233 M swap cache
                                 1000 M total swap
                                    0 M used swap
                                 1000 M free swap
                        *** FILESYSTEM ***
                        /var:
                        3.2G    /var/
                        1.9G    /var/lib
                        USB-Devices by-id:
                        HINT:
                        tcp
                        HINT:
                        tcp
                        HINT:
                        tcp
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        /usr/bin/npm            10.9.4
                        /usr/bin/npx            10.9.4
                        nodejs:
                          Version table:
                             20.19.2+dfsg-1 500
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        admin:          7.7.19
                        javascript:     9.0.17
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        56264
                        States:         44667
                        Pending Updates: 0
                        code_text
                        #73
                        @holly200289
                        Du hast da viel zu viel Kappes laufen. Wozu denn bitte ein
                        JQuery-Snowfall, was seit 10 Jahren nicht mehr gepflegt wird? Sowas SCHREIT geradezu nach Problemen.
                          holly200289
                          #74
                          Zurück zu dem Zigbee Problem, das ist ja nicht der Auslöser oder ?
                          Ich soll das alles Clean machen aber dann funktionieren einige Sachen nicht mehr, und ich finde das schön, wenn es scheint, jetzt meine Frage sind das Auslöser warum Zigbee nicht läuft ?
                            holly200289
                            #75
                            Ich dachte wir suchen das Problem warum die Zigbee Adapter nicht funktionieren ?
                              #76
                              Keine Ahnung, eher nicht. Aber deine Kiste ist so strubbelig, da fällt es schwer Ursachen zu finden.
                                holly200289
                                #77
                                Das Log von dem Zigbee Adapter habe ich ja geschickt, was braucht ihr noch um es zu analysieren ?
                                  holly200289
                                  #78
                                  Ich habe ja schon einiges entfernt, was ihr angestrichen habt
                                    holly200289
                                    #79
                                    Soll ich mal auf die neuste Zigbee Version Updaten ?
                                    Und soll ich ein Screenshot von den Geräten mit Fragezeichen Schicken ?
                                      @Thomas-Braun
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                        Virtualization: lxc
                                      OS is similar to:
                                      Docker          : false
                                      Kernel          : x86_64
                                      Userland        : 64 bit
                                      CPU threads: 8
                                                       RTC time: n/a
                                                RTC in local TZ: no
                                      admin
                                      HOME=/home/admin
                                      iobroker
                                      HOME=/home/iobroker
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Swap:           1.0G          0B        1.0G
                                      Total:           28G        6.5G         21G
                                               6235 M used memory
                                                  0 M inactive memory
                                              19534 M free memory
                                                  0 M buffer memory
                                                233 M swap cache
                                               1000 M total swap
                                                  0 M used swap
                                               1000 M free swap
                                      *** FILESYSTEM ***
                                      /var:
                                      3.2G    /var/
                                      1.9G    /var/lib
                                      USB-Devices by-id:
                                      HINT:
                                      tcp
                                      HINT:
                                      tcp
                                      HINT:
                                      tcp
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/npm            10.9.4
                                      /usr/bin/npx            10.9.4
                                      nodejs:
                                        Version table:
                                           20.19.2+dfsg-1 500
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      admin:          7.7.19
                                      javascript:     9.0.17
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        56264
                                      States:         44667
                                      Pending Updates: 0
                                      code_text
                                      #80
                                      Gehört nicht in die erste Ebene.
                                      iobroker.omada
                                      Ist wohl nie ordentlich veröffentlicht worden.
                                      iobroker.roborock
                                      Kann sein, dass es da Probleme mit dem Login gab, die in einem GitHub-Commit behoben sind.
                                      iobroker.rtspStream
                                      smartthings
                                      Zur Zeit nur als Beta über das entsprechende Repo zu installieren.
                                      sourceanalytix
                                      Ewiger Beta-Status...
                                      JQuery-Snowfall
                                      Wird wohl nicht mehr gepflegt, letztes Release im November 2013. Komplett entbehrlich, wenn man ein stabiles System haben möchte.
                                      magic-snowflakes
                                      Siehe zuvor.
                                      Hat in der ersten Ebene nix verloren. zigbee-herdsman-converters ist eine Dependency des zigbee-Adapters und hängt drunter.
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #81
                                        Update auf die aktuelle 'latest' version kann helfen
                                        bringt nix.
                                        Ich stimme dem was @thomas-braun geschrieben hat zu - dein System ist komisch.
                                        Das der Adapter manchmal nicht startet liegt daran das er die Verbindung zu den Koordinatoren verliert. Beim Neustart antworten diese nicht (Insbesondere die Netzwerk Koordinatoren), weswegen die Instanz 4 auch nicht startet. Da solltest du den Koordinator mal vom strom nehmen, 30 s warten und dann wieder anklemmen. Danach die Instanz neu starten und sie sollte hoch kommen.
                                        Was die generelle Frage zur Instabilität angeht - es fehlen immer noch die Aussagen was passiert wenn die Instanzen instabil werden. Dazu habe ich kein Log gesehen. Ohne ist das alles nur 'allgemeines stochern im Nebel'. und Nebel gibt es auf dem System deutlich zu viel.
                                        A.
                                          holly200289
                                          #82
                                          Das stimmt nicht ganz, punkt #63 habe ich den Verlauf vom Stick gepostet
