  4. RPI2 Adapter kann nicht installiert werden
    6.4k
167 Beiträge 11 Kommentatoren 13.2k Aufrufe 10 Beobachtet
  • G Gonzokalle
    @crunchip
    In das Verzeichnis komme ich erst gar nicht.
    Ich denke mal das PW vom iobroker ist gemeint.
    martin@RaspberryPi-Iobroker:~ $ su - iobroker && cd /opt/iobroker
    Passwort:
    su: Fehler bei Authentifizierung
    Passwort:
    Passwort:
    crunchipC Offline
    crunchipC Offline
    #129
    @Gonzokalle habs oben korrigiert
    • G Gonzokalle
      @crunchip
      Passwort:
      Passwort:
      Passwort:
      #130
      @Gonzokalle
      Dann schau jetzt mal ob du den Adapter installiert bekommst.
      iobroker url iobroker.rpi2@latest  --debug
      G 1 Antwort Letzte Antwort
        @Gonzokalle
        Gonzokalle
        #131
        @Thomas-Braun
        martin@RaspberryPi-Iobroker:~ $ iobroker url iobroker.rpi2@latest  --debug
        install iobroker.rpi2@latest
        NPM version: 11.6.2
        Installing iobroker.rpi2@latest... (System call)
        npm warn deprecated npmlog@4.1.2: This package is no longer supported.
        npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
        npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
        npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
        npm warn deprecated gauge@2.7.4: This package is no longer supported.
        > iobroker.rpi2@3.0.2 preinstall
        > bash ./preinstall-check.sh
        Checking package: libgpiod-dev >= 2.2
        libgpiod-dev version OK: 2.2.1-2+deb13u1
        > @stoprocent/bluetooth-hci-socket@1.5.2 install
        > node-gyp-build
        > @stoprocent/noble@1.19.1 install
        > node-gyp-build
        gyp info it worked if it ends with ok
        gyp info using node-gyp@7.1.2
        gyp info using node@24.12.0 | linux | arm64
        (node:98580) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
        (Use `node --trace-deprecation ...` to show where the warning was created)
        gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
        gyp ERR! Completion callback never invoked!
        gyp ERR! System Linux 6.12.47+rpt-rpi-2712
        gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
        gyp ERR! node -v v24.12.0
        gyp ERR! node-gyp -v v7.1.2
        gyp ERR! Node-gyp failed to build your package.
        gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
        > cpu-features@0.0.10 install
        > node buildcheck.js > buildcheck.gypi && node-gyp rebuild
        (node:98614) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
        gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/cpu-features
        > diskusage@1.2.0 install
        > node-gyp rebuild
        (node:98629) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
        gyp ERR! cwd /opt/iobroker/node_modules/diskusage
        > node-dht-sensor@0.4.5 install
        > node-gyp configure
        (node:98643) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
        gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
        gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
        > opengpio@2.0.2 install
        > node-gyp rebuild
        (node:98657) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
        gyp ERR! cwd /opt/iobroker/node_modules/opengpio
        npm error code 6
        npm error path /opt/iobroker/node_modules/opengpio
        npm error command failed
        npm error command sh -c node-gyp rebuild
        npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-29T17_42_20_656Z-debug-0.log
        npm error code 6
        host.RaspberryPi-Iobroker Cannot install iobroker.rpi2@latest: 6
        • G Gonzokalle
          @Thomas-Braun
          NPM version: 11.6.2
          > node-gyp-build
          > node-gyp-build
          > node-gyp rebuild
          > node-gyp configure
          > node-gyp rebuild
          npm error code 6
          npm error code 6
          #132
          @Gonzokalle sagte in RPI2 Adapter kann nicht installiert werden:
          Zieht sich immer noch irgendwoher die veraltete Version.
          Bei dir wird vermutlich dies der Fall sein:
          Lokale Installation im Projekt
          Viele Projekte installieren node-gyp als lokale Abhängigkeit (in node_modules/.bin).
          Wenn du npm install ausführst, wird oft die in der package.json oder package-lock.json festgelegte Version verwendet – und die kann veraltet sein.
          Lösung: Prüfe die package.json und package-lock.json auf die Version von node-gyp und aktualisiere sie ggf. mit:
          npm update node-gyp
          Also wird in einer deiner package.json oder package-lock.json die alte node-gyp drin stehen.
          Schau mal per
          cd /opt/iobroker/
          grep -R --include \*package* '"node-gyp":'
          danach.
          G HomoranH 2 Antworten Letzte Antwort
            npm update node-gyp
            Schau mal per
            cd /opt/iobroker/
            danach.
            Gonzokalle
            #133
            @Thomas-Braun
            cd /opt/iobroker/
            node_modules/nan/package.json:    "node-gyp": "~v10.3.1",
            node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "9.4.0",
            node_modules/iobroker.zigbee/node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "11.0.0",
            node_modules/zigbee-herdsman/node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "11.0.0",
            grep: node_modules/.bin/patch-package: Datei oder Verzeichnis nicht gefunden
            node_modules/zigbee-herdsman-converters/node_modules/@serialport/bindings-cpp/package.json:    "node-gyp": "11.0.0",
            package-lock.json:        "node-gyp": "bin/node-gyp.js"
            package-lock.json:        "node-gyp": "^7.1.2"
            martin@RaspberryPi-Iobroker:/opt/iobroker $
              npm update node-gyp
              Schau mal per
              cd /opt/iobroker/
              danach.
              HomoranH Offline
              HomoranH Offline
              #134
              @Thomas-Braun sagte in RPI2 Adapter kann nicht installiert werden:
              du hast ja editiert 😉
              ich wollte dich gestern schon fragen ob es Sinn ergäbe die package-lock.json zu löschen.
              aber da steht ja ^ 7.1.2 drin
              • G Gonzokalle
                @Thomas-Braun
                cd /opt/iobroker/
                #135
                @Gonzokalle
                iob stop
                rm /opt/iobroker/package-lock.json
                cd /opt/iobroker/
                npm i
                iob start
                  #136
                  @Homoran sagte in RPI2 Adapter kann nicht installiert werden:
                  Das verhindert, das höhere Versionen als node-gyp 7.x.y verwendet werden können.
                    HomoranH Offline
                    HomoranH Offline
                    #137
                    nicht mindestens 7.1.2??
                      #138
                      Ja, aber auch maximal 7.x.y.
                        Gonzokalle
                        #139
                        @Thomas-Braun
                        Ich mache einfach was du sagst..
                        martin@RaspberryPi-Iobroker:/opt/iobroker $ iob stop
                        martin@RaspberryPi-Iobroker:/opt/iobroker $ rm /opt/iobroker/package-lock.json
                        martin@RaspberryPi-Iobroker:/opt/iobroker $ cd /opt/iobroker/
                        martin@RaspberryPi-Iobroker:/opt/iobroker $ npm i
                        changed 1 package in 25s
                        206 packages are looking for funding
                          run `npm fund` for details
                        martin@RaspberryPi-Iobroker:/opt/iobroker $ iob start
                          HomoranH Offline
                          HomoranH Offline
                          #140
                          aahh, dann ist das in der json-lock anders herum als in den Dependencys!
                          ergäbe Sinn
                            ergäbe Sinn
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #141
                            ergäbe Sinn
                            Nicht anders herum.
                            ^7.1.2 fordert das eine 7. Version genommen wird die neuer ist als 7.1.2.
                            7.1.0 - nein
                            7.2.4 - ja
                            8.0.0 - nein
                            A.
                            • G Gonzokalle
                              @Thomas-Braun
                              #142
                              @Gonzokalle
                              Dann versuch jetzt nochmal
                                @Gonzokalle
                                Gonzokalle
                                #143
                                @Thomas-Braun
                                martin@RaspberryPi-Iobroker:/opt/iobroker $ iobroker url iobroker.rpi2@latest  --debug
                                NPM version: 11.6.2
                                > node-gyp-build
                                > node-gyp-build
                                (node:149664) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                (node:149699) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                > node-gyp rebuild
                                (node:149713) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                > node-gyp configure
                                (node:149727) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                > node-gyp rebuild
                                (node:149741) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                                npm error code 6
                                npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-12-30T10_03_38_431Z-debug-0.log
                                npm error code 6
                                • G Gonzokalle
                                  @Thomas-Braun
                                  NPM version: 11.6.2
                                  > node-gyp-build
                                  > node-gyp-build
                                  > node-gyp rebuild
                                  > node-gyp configure
                                  > node-gyp rebuild
                                  npm error code 6
                                  npm error code 6
                                  #144
                                  Da isser wieder.
                                  Keine Ahnung wo das immer herkommt.
                                    Da isser wieder.
                                    crunchipC Offline
                                    crunchipC Offline
                                    #145
                                    kann es möglicherweise an fehlenden Schreibrechten liegen bei user martin?
                                    nen test mit
                                    cd /opt/iobroker
                                    echo "=== BEFORE rm ===" && ls -la node_modules/node-gyp* 2>/dev/null || echo "NO node-gyp"
                                    rm -v node_modules/node-gyp* 2>/dev/null && echo "rm VERBOSE OK" || echo "**EACCES!**"
                                    echo "=== AFTER rm ===" && ls -la node_modules/node-gyp* 2>/dev/null || echo "GONE!"
                                      nen test mit
                                      cd /opt/iobroker
                                      Gonzokalle
                                      #146
                                      @crunchip
                                      martin@RaspberryPi-Iobroker:~ $ cd /opt/iobroker
                                      === BEFORE rm ===
                                      insgesamt 80
                                      drwxrwxr-x+   2 iobroker iobroker  4096 27. Dez 10:39 .
                                      drwxrwxr-x+ 765 iobroker iobroker 32768 30. Dez 12:09 ..
                                      -rwxrwxr-x+   1 iobroker iobroker  2094 27. Dez 10:39 bin.js
                                      -rwxrwxr-x+   1 iobroker iobroker   398 27. Dez 10:39 build-test.js
                                      -rw-rw-r--+   1 iobroker iobroker   390 27. Dez 10:39 index.js
                                      -rw-rw-r--+   1 iobroker iobroker  1079 27. Dez 10:39 LICENSE
                                      -rw-rw-r--+   1 iobroker iobroker  6078 27. Dez 10:39 node-gyp-build.js
                                      -rwxrwxr-x+   1 iobroker iobroker   143 27. Dez 10:39 optional.js
                                      -rw-rw-r--+   1 iobroker iobroker  1004 27. Dez 10:39 package.json
                                      -rw-rw-r--+   1 iobroker iobroker  2485 27. Dez 10:39 README.md
                                      -rw-rw-r--+   1 iobroker iobroker   193 27. Dez 10:39 SECURITY.md
                                      rm -v node_modules/node-gyp* 2>/dev/null && echo "rm VERBOSE OK" || echo "**EACCES"=== BEFORE rm ===" && ls -la node_modules/node-gyp* 2> /dev/null || echo "NO node-gyp"*"
                                      **EACCES=== BEFORE rm === && ls -la node_modules/node-gyp* 2> /dev/null || echo NO node-gyp*
                                      === AFTER rm ===
                                      insgesamt 80
                                      • G Gonzokalle
                                        @crunchip
                                        === BEFORE rm ===
                                        insgesamt 80
                                        === AFTER rm ===
                                        insgesamt 80
                                        crunchipC Offline
                                        crunchipC Offline
                                        #147
                                        @Gonzokalle zeig mal die Ausgabe von
                                        cd /opt/iobroker
                                        echo '=== VERSIONS ==='
                                        node -v && npm -v
                                        echo '=== PATH & GLOBAL ==='
                                        which node-gyp && node-gyp -v 2>/dev/null || echo 'NO GLOBAL!'
                                        echo '=== NPM INTERNAL ==='
                                        npm exec node-gyp -v 2>/dev/null || echo 'NO npm internal!'
                                        echo '=== NPM CONFIG ==='
                                        npm config get node_gyp || echo 'NO npm config!'
                                        echo '=== .BIN SYMLINKS ==='
                                        ls -la node_modules/.bin/node-gyp* 2>/dev/null || echo 'NO .bin!'
                                        echo '=== DEPENDENCY TREE ==='
                                        npm ls node-gyp --depth=0 2>/dev/null || echo 'NO LOCAL deps!'
                                        echo '=== NPX CACHE ==='
                                        npm config get cache
                                        ls -la ~/.npm/_npx/node-gyp* 2>/dev/null || echo 'NO npx cache!'
                                          cd /opt/iobroker
                                          node -v && npm -v
                                          Gonzokalle
                                          #148
                                          @crunchip
                                          node -v && npm -v
                                          === VERSIONS ===
                                          v24.12.0
                                          11.6.2
                                          NO GLOBAL!
                                          11.6.2
                                          === NPM CONFIG ===
                                          undefined
                                          lrwxrwxrwx 1 iobroker iobroker 24 27. Dez 10:40 node_modules/.bin/node-gyp-build -> ../node-gyp-build/bin.js
                                          lrwxrwxrwx 1 iobroker iobroker 29 27. Dez 10:40 node_modules/.bin/node-gyp-build-optional -> ../node-gyp-build/optional.js
                                          lrwxrwxrwx 1 iobroker iobroker 31 27. Dez 10:40 node_modules/.bin/node-gyp-build-test -> ../node-gyp-build/build-test.js
                                          iobroker.inst@3.0.0 /opt/iobroker
                                          └── (empty)
                                          NO LOCAL deps!
                                          === NPX CACHE ===
                                          /home/iobroker/.npm
                                          NO npx cache!
