  4. Test Adapter Ford 0.0.x
174 Beiträge 25 Kommentatoren 27.1k Aufrufe 22 Beobachtet
  • T tombox
    @Negalein Vielleicht das ausprobieren
    https://github.com/marq24/ha-fordpass?tab=readme-ov-file#use-of-a-separate-fordpassthe-lincoln-way-account-is-recommended
    vielleicht mit größeren interval
    die logs sehen gut aus?
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #115
    @tombox sagte in Test Adapter Ford 0.0.x:
    Ja, bis zur Sperre alles gut
    2025-12-27 20:08:41.277 - info: host.ioBroker iobroker Update "system.adapter.ford.0"
    2025-12-27 20:11:10.727 - info: host.ioBroker "system.adapter.ford.0" enabled
    2025-12-27 20:11:11.797 - info: host.ioBroker instance system.adapter.ford.0 in version "1.1.0" (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) started with pid 1941486
    2025-12-27 20:11:13.158 - info: ford.0 (1941486) starting. Version 1.1.0 (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) in /opt/iobroker/node_modules/iobroker.ford, node: v20.19.1, js-controller: 7.0.7
    2025-12-27 20:11:13.246 - warn: ford.0 (1941486) ========================================
    2025-12-27 20:11:13.247 - warn: ford.0 (1941486) FORD OAUTH 2.0 LOGIN REQUIRED
    2025-12-27 20:11:13.247 - warn: ford.0 (1941486) ========================================
    2025-12-27 20:11:13.247 - warn: ford.0 (1941486) Please follow these steps:
    2025-12-27 20:11:13.247 - warn: ford.0 (1941486) 1. Open your browser Developer Tools (F12)
    2025-12-27 20:11:13.248 - warn: ford.0 (1941486) 2. Go to the Network tab
    2025-12-27 20:11:13.248 - warn: ford.0 (1941486) 3. Copy and paste this URL into your browser:
    2025-12-27 20:11:13.249 - warn: ford.0 (1941486) https://login.ford.de/4566605f-43a7-400a-946e-89cc9fdb0bd7/B2C_1A_SignInSignUp_de-DE/oauth2/v2.0/authorize?redirect_uri=fordapp%3A%2F%2Fuserauthorized&response_type=code&max_age=3600&code_challenge=zqeXnKibRiFPmdFOYTUqBJz9lJ7ahQjzPncyN8QroVg&code_challenge_method=S256&scope=+09852200-05fd-41f6-8c21-d36d3497dc64+openid&client_id=09852200-05fd-41f6-8c21-d36d3497dc64&ui_locales=de-DE&language_code=de-DE&ford_application_id=667D773E-1BDC-4139-8AD0-2B16474E8DC7&country_code=DEU
    2025-12-27 20:11:13.249 - warn: ford.0 (1941486) 4. Log in with your Ford account
    2025-12-27 20:11:13.249 - warn: ford.0 (1941486) 5. After redirect, browser will show "Cannot open page"
    2025-12-27 20:11:13.249 - warn: ford.0 (1941486) 6. COPY the complete URL from browser address bar (starts with: fordapp://userauthorized/?code=)
    2025-12-27 20:11:13.249 - warn: ford.0 (1941486) 7. Paste it into the "v2 Code URL" field in adapter settings
    2025-12-27 20:11:13.250 - warn: ford.0 (1941486) 8. Save and restart the adapter
    2025-12-27 20:11:13.251 - warn: ford.0 (1941486)
    2025-12-27 20:11:13.252 - warn: ford.0 (1941486) ========================================
    2025-12-27 20:16:34.647 - info: host.ioBroker stopInstance system.adapter.ford.0 (force=false, process=true)
    2025-12-27 20:16:34.652 - info: host.ioBroker stopInstance system.adapter.ford.0 send kill signal
    2025-12-27 20:16:34.652 - info: ford.0 (1941486) Got terminate signal TERMINATE_YOURSELF
    2025-12-27 20:16:34.653 - info: ford.0 (1941486) terminating
    2025-12-27 20:16:34.654 - info: ford.0 (1941486) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-27 20:16:35.155 - info: ford.0 (1941486) terminating
    2025-12-27 20:16:35.292 - info: host.ioBroker instance system.adapter.ford.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-27 20:16:38.709 - info: host.ioBroker instance system.adapter.ford.0 in version "1.1.0" (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) started with pid 1941653
    2025-12-27 20:16:40.912 - info: ford.0 (1941653) starting. Version 1.1.0 (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) in /opt/iobroker/node_modules/iobroker.ford, node: v20.19.1, js-controller: 7.0.7
    2025-12-27 20:16:40.987 - info: ford.0 (1941653) Found v2 Code URL, exchanging for token...
    2025-12-27 20:16:40.989 - info: ford.0 (1941653) Exchanging authorization code for access token...
    2025-12-27 20:16:42.160 - info: ford.0 (1941653) OAuth token received, exchanging for FordConnect token...
    2025-12-27 20:16:43.105 - info: ford.0 (1941653) Token exchange successful
    2025-12-27 20:16:43.105 - info: ford.0 (1941653) Token expires in: 30 minutes
    2025-12-27 20:16:43.258 - info: ford.0 (1941653) Code exchanged for token successfully.
    2025-12-27 20:16:44.340 - info: ford.0 (1941653) 1 vehicles found
    2025-12-27 20:16:46.258 - info: ford.0 (1941653) Clearing v2 Code URL and restart Adapter.
    2025-12-27 20:16:46.263 - info: host.ioBroker stopInstance system.adapter.ford.0 (force=false, process=true)
    2025-12-27 20:16:46.265 - info: host.ioBroker stopInstance system.adapter.ford.0 send kill signal
    2025-12-27 20:16:46.265 - info: ford.0 (1941653) Got terminate signal TERMINATE_YOURSELF
    2025-12-27 20:16:46.266 - info: ford.0 (1941653) terminating
    2025-12-27 20:16:46.267 - info: ford.0 (1941653) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-27 20:16:46.767 - info: ford.0 (1941653) terminating
    2025-12-27 20:16:46.774 - error: ford.0 (1941653) Error: Connection is closed.
    2025-12-27 20:16:46.779 - error: ford.0 (1941653) Error: DB closed
    2025-12-27 20:16:46.945 - info: host.ioBroker instance system.adapter.ford.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-27 20:16:50.981 - info: host.ioBroker instance system.adapter.ford.0 in version "1.1.0" (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) started with pid 1941668
    2025-12-27 20:16:53.590 - info: ford.0 (1941668) starting. Version 1.1.0 (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) in /opt/iobroker/node_modules/iobroker.ford, node: v20.19.1, js-controller: 7.0.7
    2025-12-27 20:16:53.671 - info: ford.0 (1941668) Using existing session, refreshing token...
    2025-12-27 20:16:54.257 - info: ford.0 (1941668) Token refresh successful
    2025-12-27 20:16:55.626 - info: ford.0 (1941668) 1 vehicles found
    2025-12-27 20:38:28.112 - info: ford.0 (1941668) Loglevel changed from "info" to "debug"
    2025-12-27 20:38:34.490 - info: host.ioBroker stopInstance system.adapter.ford.0 (force=false, process=true)
    2025-12-27 20:38:34.685 - info: ford.0 (1941668) Got terminate signal TERMINATE_YOURSELF
    2025-12-27 20:38:34.686 - info: ford.0 (1941668) terminating
    2025-12-27 20:38:34.686 - debug: ford.0 (1941668) Plugin sentry destroyed
    2025-12-27 20:38:34.686 - info: ford.0 (1941668) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-27 20:38:34.691 - info: host.ioBroker stopInstance system.adapter.ford.0 send kill signal
    2025-12-27 20:38:35.186 - info: ford.0 (1941668) terminating
    2025-12-27 20:38:35.317 - info: host.ioBroker instance system.adapter.ford.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-27 20:38:38.836 - info: host.ioBroker instance system.adapter.ford.0 in version "1.1.0" (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) started with pid 1942212
    2025-12-27 20:38:40.663 - info: ford.0 (1942212) starting. Version 1.1.0 (non-npm: TA2k/ioBroker.ford#9f6287b70307a773ed54c9b61d8e0adeb21e8616) in /opt/iobroker/node_modules/iobroker.ford, node: v20.19.1, js-controller: 7.0.7
    2025-12-27 20:38:40.695 - info: ford.0 (1942212) Using existing session, refreshing token...
    2025-12-27 20:38:41.168 - error: ford.0 (1942212) Refresh token failed
    2025-12-27 20:38:41.168 - error: ford.0 (1942212) AxiosError: Request failed with status code 400
    2025-12-27 20:38:41.168 - error: ford.0 (1942212) {"message":"Invalid or Expired Token","timestamp":"2025-12-27T19:38:41.025232880Z","errorCode":"460"}
    2025-12-27 20:38:41.168 - error: ford.0 (1942212) Token refresh failed. Please re-authenticate via adapter settings.
    2025-12-27 20:38:41.168 - warn: ford.0 (1942212) RECOMMENDATION: Delete the authV2 state and re-authenticate with a new login.
    2025-12-27 20:38:41.169 - error: ford.0 (1942212) The adapter will try again in 5 minutes...
    2025-12-27 20:38:42.057 - info: ford.0 (1942212) 1 vehicles found
    2025-12-27 20:40:06.318 - info: host.ioBroker "system.adapter.ford.0" disabled
    2025-12-27 20:40:06.318 - info: host.ioBroker stopInstance system.adapter.ford.0 (force=false, process=true)
    2025-12-27 20:40:06.321 - info: host.ioBroker stopInstance system.adapter.ford.0 send kill signal
    2025-12-27 20:40:06.321 - info: ford.0 (1942212) Got terminate signal TERMINATE_YOURSELF
    2025-12-27 20:40:06.322 - info: ford.0 (1942212) terminating
    2025-12-27 20:40:06.323 - info: ford.0 (1942212) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-27 20:40:06.824 - info: ford.0 (1942212) terminating
    2025-12-27 20:40:07.333 - info: host.ioBroker instance system.adapter.ford.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    schau ich mir an
    ° Fixer ---> iob fix
    Thomas BraunT T 2 Antworten Letzte Antwort
    • NegaleinN Negalein
      schau ich mir an
      #116
      @Negalein sagte in Test Adapter Ford 0.0.x:
      node: v20.19.1
      Und bring es auf nodejs@22
        schau ich mir an
        tombox
        #117
        @Negalein habe in v1.1.2 noch was angepasst aber eher unwahrscheinlich
        vowillV 1 Antwort Letzte Antwort
        • B Online
          B Online
          babl
          schrieb am zuletzt editiert von babl
          #118
          da hatte ich schon was gelesen, vielleicht hängt es damit zusammen,
          Ich gehe davon aus, dass er die Weiterleitung auch im Hintergrund noch benötigt. Ich werde mich da nach den Feiertagen nochmal genauer mit auseinander setzen.
          Nein. Das Problem ist, dass jede Abfrage die schneller als alle 30 Sekunden kommt zu einem 429 führt. Bei "prüfen" und anschließendem "überprüfen & speichern" ist das der Fall. Warte nach dem du auf "prüfen" geklickt hast ca. 30 Sekunden und klicke dann erst auf Speichern, dann sollte es klappen. Ansonsten klicke "trotzdem speichern" an.
          Dann hat evcc den refresh token und so lange der nicht abläuft, brauchst du auch die Weiterleitung wo du den Zugriff bestätigen musst nicht mehr."
          Hier der Link dazu, ganz unten:
          Link Text
          • T tombox
            vowillV Offline
            vowillV Offline
            vowill
            #119
            @tombox Habe eben mit v1.1.3 meinen Ford Explorer electric getestet - läuft super, 460 (!= Datenpunkte sind angekommen
            ioBroker im lxc auf NUC / Aktive Instanzen: 38
            • vowillV vowill
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #120
              @vowill sagte in Test Adapter Ford 0.0.x:
              mit Zweitaccount wie hier beschrieben?
                vowillV Offline
                vowillV Offline
                vowill
                #121
                @Negalein Ja.
                • vowillV vowill
                  @Negalein Ja.
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #122
                  Ja
                  perfekt
                  wie sind deine Adapter-Settings?
                  • vowillV Offline
                    vowillV Offline
                    vowill
                    #123
                    Habe Aktualisierungsintervall in Minuten: 30; und alle Häkchen gesetzt.
                    Eben kam eine Fehlermeldung: "Token refresh failed. Please re-authenticate via adapter settings."
                    Hm.
                    • vowillV Offline
                      vowillV Offline
                      vowill
                      #124
                      @tombox Offenbar läuft das generierte Token nach einer gewissen Zeit ab: Bei meiner Einstellung auf "30 min" kommen bereits beim zweiten Zugriff (also nach den 30 min) die Meldungen:
                      • Refresh token failed
                      • 2025-12-29 10:53:02.472 - error: ford.0 (66176) AxiosError: Request failed with status code 400
                      • 2025-12-29 10:53:02.473 - error: ford.0 (66176) {"message":"Invalid or Expired Token","timestamp":"2025-12-29T09:53:02.401278166Z","errorCode":"460"}
                      • 2025-12-29 10:53:02.473 - error: ford.0 (66176) Token refresh failed. Please re-authenticate via adapter settings.
                      • 2025-12-29 10:53:02.473 - warn: ford.0 (66176) RECOMMENDATION: Delete the authV2 state and re-authenticate with a new login.
                        Das wiederholt sich dann alle 5 min durch die automatischen Retrys des Adapters.
                        Nach der erneuten Prozedur über OAuth URL und dem Eintragen einer neuen URL "fordapp://userauthorized..." geht es wieder.
                      • vowillV Offline
                        vowillV Offline
                        vowill
                        #125
                        Update:
                        Nach dem erneuten Anlegen des Accounts scheint der Adapter jetzt durchzulaufen. Allerdings kommt nach jeder Meldung
                        2025-12-29 16:17:37.083 - info: ford.0 (68025) Token refresh successful
                        ca. 3 min später diese Fehlerangabe:
                        2025-12-29 16:20:38.187 - error: ford.0 (68025) Failed to force update
                        2025-12-29 16:20:38.187 - error: ford.0 (68025) AxiosError: Request failed with status code 404
                        2025-12-29 16:20:38.187 - error: ford.0 (68025) {"code":404,"error":"not found","message":"No supported devices for command: statusRefresh","messageTemplate":"No supported devices for command: {commandType}","messageParams":{"commandType":"statusRefresh"},"timestamp":"2025- 12-29T15:20:38.092902Z","referenceId":"e8b00098777842b742416adcc0c4eb31"}
                        Die Datenpunkte werden zur gleichen Zeit dennoch aktualisiert. Vermutlich ist aus dem Adapter nur eine Message fehlerhaft?
                        • vowillV vowill
                          Update:
                          tombox
                          #126
                          @vowill v1.1.4 testen
                          • T tombox
                            vowillV Offline
                            vowillV Offline
                            vowill
                            #127
                            @tombox v1.1.4 läuftsuper und ohne Probleme! (Zeitintervall 29 min).
                            VIELEN DANK!!!
                            • B Online
                              B Online
                              babl
                              #128
                              auch im test mit der 1.1.4 zeitintervall 30min, das einzige was mir auffällt, kannst du bei der instanz vielleicht die 3 sachen anders anordnen, da ich die leider nicht sehe Screenshot 2026-01-01 094703.png Danke.
                              • B babl
                                tombox
                                #129
                                @babl ist behoben
                                • L Offline
                                  Linustrispoke
                                  schrieb am zuletzt editiert von Linustrispoke
                                  #130
                                  @tombox @vowill @babl
                                  Moin zusammen und ein gutes neues Jahr .....
                                  Habe gerade auf 1.1.5 aktualisiert, und 30 Sekunden später die eMail mit der Aufforderung zur Zurücksetzung meines Passwortes erhalten, Anmeldedaten sind deaktiviert.
                                  Bin ich der Einzige mit dem Problem?
                                  • L Offline
                                    Linustrispoke
                                    #131
                                    @tombox
                                    Habe gerade noch festgestellt, dass die Checkboxen (Kartenupdate, etc.) zwar angeklickt werden können und die das Konfig-Fenster auch "Speichern und Schließen" aktiviert, aber kein Häckchen gesetzt wird, ich sehe nicht was momentan also angeklickt ist.
                                    • L Linustrispoke
                                      vowillV Offline
                                      vowillV Offline
                                      vowill
                                      #132
                                      @Linustrispoke sagte in Test Adapter Ford 0.0.x:
                                      Ich denke das muss 1.1.4 heißen?
                                      L 1 Antwort Letzte Antwort
                                      • vowillV Offline
                                        vowillV Offline
                                        vowill
                                        #133
                                        @tombox In den letzten Tagen erhielt ich täglich von Ford die Aufforderung, das Passwort zurückzusetzen. Ebenfalls täglich kam dann im Log:
                                        2026-01-01 16:37:06.146 - error: ford.0 (89249) Refresh token failed
                                        2026-01-01 16:37:06.146 - error: ford.0 (89249) AxiosError: Request failed with status code 400
                                        2026-01-01 16:37:06.146 - error: ford.0 (89249) {"message":"Invalid or Expired Token","timestamp":"2026-01-01T15:37:06.073626486Z","errorCode":"460"}
                                        2026-01-01 16:37:06.146 - error: ford.0 (89249) Token refresh failed. Please re-authenticate via adapter settings.
                                        2026-01-01 16:37:06.146 - warn: ford.0 (89249) RECOMMENDATION: Delete the authV2 state and re-authenticate with a new login.
                                        Das passierte auch heute (siehe das vorstehende Log). Zusätzlich kam heute die Mail von Ford:
                                        Ihr konto wurde deaktiviert
                                        Sehr geehrte Damen und Herren,
                                        wir haben Ihr FordPass Konto gesperrt, da wir über verdächtige Aktivitäten in Bezug auf Ihr Konto informiert wurden.
                                        Für ein optimales Erlebnis empfehlen wir, FordPass nicht mit Apps von Drittanbietern zu verwenden. Dies kann zu Problemen bei der Fahrzeugqualität führen, wie z. B. zu einer erhöhten Batterieentladung sowie zu anderen potenziellen Sicherheitsproblemen.
                                        Wir arbeiten weiterhin daran, sorgfältig ausgewählte Apps von Drittanbietern einzusetzen, um Ihnen neue Funktionen und Produkte anzubieten.
                                        Um Ihr Konto wieder zu aktivieren, wenden Sie sich bitte an unseren FordPass Kundendienst unter 0221 90-39770.
                                        Ihr Konto bleibt so lange gesperrt, bis weitere Maßnahmen erfolgen.
                                        Damit bin ich jetzt erst mal leider raus.
                                        Ich rufe Morgen an und schau mal, was der Kundendienst meint ...
                                        T vowillV 2 Antworten Letzte Antwort
                                        • vowillV vowill
                                          Linustrispoke
                                          #134
                                          Hi, heißt 1.1.15
