  4. Test Adapter Unifi Network
    6.3k
173 Beiträge 34 Kommentatoren 26.8k Aufrufe 38 Beobachtet
  • R Rushmed
    @Thomas-Braun
    Das Node Update auf 22.21.1 funzt ja irgendwie nicht. Ansonsten glaube ich auf Stand zu sein.
    iob Diag:
    Script v.2025-08-09
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: Smartazamba
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     00:33:25 up 19:31,  2 users,  load average: 2.23, 1.67, 1.86
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-12-21 00:33:25 CET
               Universal time: Sat 2025-12-20 23:33:25 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/pi
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.2G        4.7G        960M        101M        2.7G        3.5G
    Swap:           2.1G        108M        2.0G
    Total:           10G        4.8G        3.0G
    Active iob-Instances:   38
             7819 M total memory
             4494 M used memory
             3790 M active memory
             2673 M inactive memory
              915 M free memory
              110 M buffer memory
             2495 M swap cache
             2047 M total swap
              103 M used swap
             1944 M free swap
    top - 00:33:26 up 19:31,  2 users,  load average: 2.23, 1.67, 1.86
    Tasks: 251 total,   1 running, 250 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  2.1 us,  2.1 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7819.7 total,    913.7 free,   4495.6 used,   2606.3 buff/cache
    MiB Swap:   2048.0 total,   1944.5 free,    103.5 used.   3324.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
    * media-HDD3\x40NAS.mount loaded failed failed /media/HDD3@NAS
    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
            SUB    -> The low-level unit activation state, values depend on unit type.
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    /dev/root      ext4      110G   17G   91G  16% /
    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  140M  1.4G   9% /run
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    tmpfs          tmpfs     3.9G  6.8M  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    /dev/sdc       ext4      5.5T  3.2T  2.0T  62% /media/HDD2
    /dev/sda1      vfat      253M   49M  204M  20% /boot/firmware
    /dev/sdb1      ext4      4.6T  3.2T  1.2T  74% /media/HDD1
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
    tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
    [Sat Dec 20 05:01:51 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sat Dec 20 05:01:54 2025] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
    [Sat Dec 20 05:01:54 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Dec 20 05:01:58 2025] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w.
    [Sat Dec 20 05:01:59 2025] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
    [Sat Dec 20 05:01:59 2025] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    |-/media/HDD2    /dev/sdc  ext4   rw,nosuid,nodev,noexec,relatime
    |-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    `-/media/HDD1    /dev/sdb1 ext4   rw,nosuid,nodev,noexec,relatime
    /var:
    4.7G    /var/
    1.2G    /var/log
    786M    /var/cache
    770M    /var/cache/apt
    637M    /var/cache/apt/archives
    Archived and active journals take up 160.5M in the file system.
    /opt/iobroker/backups:
    1.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    447M    /opt/iobroker/iobroker-data/
    186M    /opt/iobroker/iobroker-data/backup-objects
    181M    /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    65M     /opt/iobroker/iobroker-data/objects.jsonl
    18M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-Rz8ETF2t.js
    15M     /opt/iobroker/iobroker-data/states.jsonl
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
    6.9M    /opt/iobroker/iobroker-data/backup-objects/2025-12-20_23-02_objects.jsonl.gz
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    Smartazamba         Smartazamba (version: 7.0.7, hostname: Smartazamba   , alive, uptime: 70288)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     1
    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
    Adapter State
    + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
      system.adapter.artnet.0                 : artnet                : Smartazamba                              - disabled, port: 6454
    + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
    + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
    + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
      system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
    + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
    + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
      system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
      system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
    + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
    + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
    + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
      system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
    + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
    + system.adapter.matter.0                 : matter                : Smartazamba                              -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
    + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
    + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
    + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
      system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
      system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
      system.adapter.proxmox.0                : proxmox               : Smartazamba                              - disabled, port: 8006
    + system.adapter.reolink.0                : reolink               : Smartazamba                              -  enabled
    + system.adapter.reolink.1                : reolink               : Smartazamba                              -  enabled
    + system.adapter.rest-api.0               : rest-api              : Smartazamba                              -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
    + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
    + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
    + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.unifi-network.0          : unifi-network         : Smartazamba                              -  enabled, port: 8443
    + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
    + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              -  enabled, port: 5000
    + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
    + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
    + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
    Upgrade policy: minor
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "hass"         : 1.4.0    , installed 1.4.0
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "matter"       : 0.5.5    , installed 0.5.6
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
    Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "unifi-network": 1.3.1    , installed 1.3.1
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        19422
    States:         18567
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian trixie InRelease
    Hit:5 https://repos.influxdata.com/debian stable InRelease
    Hit:6 https://apt.grafana.com stable InRelease
    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          3316433    842565/smbd
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          3316434    842565/smbd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9311       923/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       8878       1361/iobroker.js-co
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       7730       1361/iobroker.js-co
    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       4413735    1103371/nc
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       13588      1808/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       13425      1766/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       4262790    1067208/io.sonoff.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7525       1242/exim4
    tcp6       0      0 :::445                  :::*                    LISTEN      0          3316431    842565/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          3316432    842565/smbd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          9321       923/sshd: /usr/sbin
    tcp6       0      0 :::21                   :::*                    LISTEN      0          9266       887/vsftpd
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7526       1242/exim4
    tcp6       0      0 :::3000                 :::*                    LISTEN      109        10314      1360/grafana
    tcp6       0      0 :::8093                 :::*                    LISTEN      1002       14080      2196/io.rest-api.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       14062      2176/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       8974       1459/io.admin.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7578       879/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1002       14010      2147/io.simple-api.
    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1002       15206      2065/io.matter.0
    udp        0      0 0.0.0.0:44195           0.0.0.0:*                           1002       17655      2065/io.matter.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6179       616/dhcpcd: [networ
    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          3321162    843109/nmbd
    udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          3321161    843109/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          3321143    843109/nmbd
    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          3321164    843109/nmbd
    udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          3321163    843109/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          3321144    843109/nmbd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       12481      1725/io.mihome-vacu
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       12483      1744/io.mihome-vacu
    udp        0      0 0.0.0.0:50049           0.0.0.0:*                           108        680        541/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       15212      2065/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       15197      2065/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       16556      2065/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       13014      2184/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        678        541/avahi-daemon: r
    udp6       0      0 :::5540                 :::*                                1002       15205      2065/io.matter.0
    udp6       0      0 :::47178                :::*                                108        681        541/avahi-daemon: r
    udp6       0      0 :::44195                :::*                                1002       17654      2065/io.matter.0
    udp6       0      0 :::546                  :::*                                0          6181       616/dhcpcd: [networ
    udp6       0      0 :::5353                 :::*                                1002       15213      2065/io.matter.0
    udp6       0      0 :::5353                 :::*                                1002       15200      2065/io.matter.0
    udp6       0      0 :::5353                 :::*                                1002       15192      2065/io.matter.0
    udp6       0      0 :::5353                 :::*                                108        679        541/avahi-daemon: r
    2025-12-21 00:22:46.633  - info: host.Smartazamba stopInstance system.adapter.proxmox.0 (force=false, process=true)
    2025-12-21 00:22:46.829  - info: javascript.0 (1518) script.js.Proxmox_Server: Proxmox Server nicht erreichbar, Instanz deaktiviert.
    2025-12-21 00:22:47.131  - info: proxmox.0 (1069537) Got terminate signal TERMINATE_YOURSELF
    2025-12-21 00:22:47.135  - info: proxmox.0 (1069537) terminating
    2025-12-21 00:22:47.137  - info: proxmox.0 (1069537) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-21 00:22:47.152  - info: host.Smartazamba stopInstance system.adapter.proxmox.0 send kill signal
    2025-12-21 00:22:47.640  - info: proxmox.0 (1069537) terminating
    2025-12-21 00:22:48.635  - info: host.Smartazamba stopInstance timeout system.adapter.proxmox.0 killing pid 1069537
    2025-12-21 00:22:49.065  - warn: host.Smartazamba instance system.adapter.proxmox.0 terminated due to SIGKILL
    2025-12-21 00:22:49.066  - info: host.Smartazamba instance system.adapter.proxmox.0 terminated with code null ()
    2025-12-21 00:22:49.332  - warn: javascript.0 (1518) script.js.Proxmox_Server: Proxmox Server wurde ausgeschaltet nach 1 min
    2025-12-21 00:24:52.823  - info: web.0 (2176) ==> Connected system.user.admin from ::ffff:192.168.178.38
    2025-12-21 00:25:30.047  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 1094835
    2025-12-21 00:25:36.017  - info: weatherunderground.0 (1094835) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
    2025-12-21 00:25:42.855  - info: weatherunderground.0 (1094835) Terminated (NO_ERROR): Without reason
    2025-12-21 00:25:43.401  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1094835 terminated with code 0 (NO_ERROR)
    2025-12-21 00:25:57.854  - info: sonoff.0 (1067208) Client [WiFi-Plug12] connection closed: timeout
    2025-12-21 00:26:12.343  - info: sonoff.0 (1067208) Client [WiFi-Plug12] connected with secret 1766273172342_5873
    2025-12-21 00:27:17.547  - info: web.0 (2176) <== Disconnect system.user.admin from ::ffff:192.168.178.38 habpanel.0
    2025-12-21 00:28:48.346  - info: sonoff.0 (1067208) Client [WiFi-Plug12] reconnected. Old secret 1766273172342_5873 ==> New secret 1766273328339_2452
    2025-12-21 00:30:30.042  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 1099380
    2025-12-21 00:30:35.631  - info: weatherunderground.0 (1099380) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
    2025-12-21 00:30:44.423  - info: weatherunderground.0 (1099380) Terminated (NO_ERROR): Without reason
    2025-12-21 00:30:45.003  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1099380 terminated with code 0 (NO_ERROR)
    2025-12-21 00:34:25.154  - info: javascript.0 (1518) script.js.Lampen_Displays._Switch_Status_Synch_: alias.0.Lampe_Bad_switch_State = wahr
    Ich freue mich auf deine Prüfung!
    #112
    @Rushmed sagte in Test Adapter Unifi Network:
    Ja, die Version findet sich noch nicht im nodesource-Repo.
    Ansonsten schaut das System (bis auf Kleingkeiten) i.O. aus.
    Die Meldungen haben auch nicht direkt mit dem unifi-network-Adapter zu tun, die kommen vom controller, würde ich sagen. Da weiß ich abber nicht wo und wie man da ansetzen müsste.
    • R Rushmed
      @Thomas-Braun
      Ja, Glückwunsch!
      Bei mir klappt irgendetwas nicht und ich wollte wissen ob mir hier im Forum jemand helfen kann.
      Install Log:
      $ iobroker add unifi-network --host Smartazamba
      NPM version: 10.9.4Installing iobroker.unifi-network@1.3.1... (System call)
      added 5 packages in 12s
      201 packages are looking for funding run `npm fund` for details
      host.Smartazamba install adapter unifi-network
      upload [19] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/clients.jsonConfig.json clients.jsonConfig.json application/json
      upload [18] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/devices.jsonConfig.json devices.jsonConfig.json application/json
      upload [17] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/expert.jsonConfig.json expert.jsonConfig.json application/json
      upload [16] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/firewall.jsonConfig.json firewall.jsonConfig.json application/json
      upload [15] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/general.jsonConfig.json general.jsonConfig.json application/json
      upload [14] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/de.json i18n/de.json application/json
      upload [13] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/en.json i18n/en.json application/json
      upload [12] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/es.json i18n/es.json application/json
      upload [11] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/fr.json i18n/fr.json application/json
      upload [10] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/it.json i18n/it.json application/json
      upload [9] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/nl.json i18n/nl.json application/json
      upload [8] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pl.json i18n/pl.json application/json
      upload [7] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pt.json i18n/pt.json application/json
      upload [6] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/ru.json i18n/ru.json application/json
      upload [5] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/uk.json i18n/uk.json application/json
      upload [4] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
      upload [3] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/jsonConfig.json jsonConfig.json application/json
      upload [2] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/lan.jsonConfig.json lan.jsonConfig.json application/json
      upload [1] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/unifi-network.png unifi-network.png image/png
      upload [0] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/wlan.jsonConfig.json wlan.jsonConfig.json application/json
      host.Smartazamba object system.adapter.unifi-network created/updated
      Updating objects from io-package.json for adapter "unifi-network" with version "1.3.1"
      host.Smartazamba create instance unifi-network
      host.Smartazamba object system.adapter.unifi-network.0.alive created
      host.Smartazamba object system.adapter.unifi-network.0.connected created
      host.Smartazamba object system.adapter.unifi-network.0.compactMode created
      host.Smartazamba object system.adapter.unifi-network.0.cpu created
      host.Smartazamba object system.adapter.unifi-network.0.cputime created
      host.Smartazamba object system.adapter.unifi-network.0.memHeapUsed created
      host.Smartazamba object system.adapter.unifi-network.0.memHeapTotal created
      host.Smartazamba object system.adapter.unifi-network.0.memRss created
      host.Smartazamba object system.adapter.unifi-network.0.uptime created
      host.Smartazamba object system.adapter.unifi-network.0.inputCount created
      host.Smartazamba object system.adapter.unifi-network.0.outputCount created
      host.Smartazamba object system.adapter.unifi-network.0.eventLoopLag created
      host.Smartazamba object system.adapter.unifi-network.0.sigKill created
      host.Smartazamba object system.adapter.unifi-network.0.logLevel created
      host.Smartazamba object unifi-network.0.info created
      host.Smartazamba object unifi-network.0.info.connection created
      host.Smartazamba object unifi-network.0.info.lastRealTimeData created
      host.Smartazamba Set default value of unifi-network.0.info.connection: false
      host.Smartazamba object system.adapter.unifi-network.0 created
      Process exited with code 0
      Hab jetzt nochmal neu installiert.
      LOG:
      2025-12-21 00:11:10.354  - info: host.Smartazamba iobroker 201 packages are looking for funding  run `npm fund` for details
      2025-12-21 00:11:10.412  - info: host.Smartazamba iobroker host.Smartazamba install adapter unifi-network
      2025-12-21 00:11:10.555  - info: host.Smartazamba iobroker upload [19] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/clients.jsonConfig.json clients.jsonConfig.json application/json
      2025-12-21 00:11:10.568  - info: host.Smartazamba iobroker upload [18] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/devices.jsonConfig.json devices.jsonConfig.json application/json
      2025-12-21 00:11:10.580  - info: host.Smartazamba iobroker upload [17] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/expert.jsonConfig.json expert.jsonConfig.json application/json
      2025-12-21 00:11:10.591  - info: host.Smartazamba iobroker upload [16] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/firewall.jsonConfig.json firewall.jsonConfig.json application/json
      2025-12-21 00:11:10.602  - info: host.Smartazamba iobroker upload [15] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/general.jsonConfig.json general.jsonConfig.json application/json
      2025-12-21 00:11:10.613  - info: host.Smartazamba iobroker upload [14] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/de.json i18n/de.json application/json
      2025-12-21 00:11:10.624  - info: host.Smartazamba iobroker upload [13] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/en.json i18n/en.json application/json
      2025-12-21 00:11:10.634  - info: host.Smartazamba iobroker upload [12] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/es.json i18n/es.json application/json
      2025-12-21 00:11:10.648  - info: host.Smartazamba iobroker upload [11] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/fr.json i18n/fr.json application/json
      2025-12-21 00:11:10.707  - info: host.Smartazamba iobroker upload [10] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/it.json i18n/it.json application/json
      2025-12-21 00:11:10.719  - info: host.Smartazamba iobroker upload [9] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/nl.json i18n/nl.json application/json
      2025-12-21 00:11:10.734  - info: host.Smartazamba iobroker upload [8] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pl.json i18n/pl.json application/json
      2025-12-21 00:11:10.742  - info: host.Smartazamba iobroker upload [7] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pt.json i18n/pt.json application/json
      2025-12-21 00:11:10.752  - info: host.Smartazamba iobroker upload [6] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/ru.json i18n/ru.json application/json
      2025-12-21 00:11:10.761  - info: host.Smartazamba iobroker upload [5] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/uk.json i18n/uk.json application/json
      2025-12-21 00:11:10.778  - info: host.Smartazamba iobroker upload [4] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
      2025-12-21 00:11:10.788  - info: host.Smartazamba iobroker upload [3] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/jsonConfig.json jsonConfig.json application/json
      2025-12-21 00:11:10.803  - info: host.Smartazamba iobroker upload [2] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/lan.jsonConfig.json lan.jsonConfig.json application/json
      2025-12-21 00:11:10.820  - info: host.Smartazamba iobroker upload [1] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/unifi-network.png unifi-network.png image/png
      2025-12-21 00:11:10.835  - info: host.Smartazamba iobroker upload [0] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/wlan.jsonConfig.json wlan.jsonConfig.json application/json
      2025-12-21 00:11:11.060  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network created/updated
      2025-12-21 00:11:11.064  - info: host.Smartazamba iobroker Updating objects from io-package.json for adapter "unifi-network" with version "1.3.1"
      2025-12-21 00:11:11.471  - info: host.Smartazamba iobroker host.Smartazamba create instance unifi-network
      2025-12-21 00:11:11.486  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.alive created
      2025-12-21 00:11:11.567  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.connected created
      2025-12-21 00:11:11.691  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.compactMode created
      2025-12-21 00:11:11.814  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.cpu created
      2025-12-21 00:11:12.034  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.cputime created
      2025-12-21 00:11:12.263  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.memHeapUsed created
      2025-12-21 00:11:12.440  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.memHeapTotal created
      2025-12-21 00:11:12.520  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.memRss created
      2025-12-21 00:11:12.691  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.uptime created
      2025-12-21 00:11:12.779  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.inputCount created
      2025-12-21 00:11:12.901  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.outputCount created
      2025-12-21 00:11:13.077  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.eventLoopLag created
      2025-12-21 00:11:13.169  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.sigKill created
      2025-12-21 00:11:13.341  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.logLevel created
      2025-12-21 00:11:13.562  - info: host.Smartazamba iobroker host.Smartazamba object unifi-network.0.info created
      2025-12-21 00:11:13.622  - info: host.Smartazamba iobroker host.Smartazamba object unifi-network.0.info.connection created
      2025-12-21 00:11:13.649  - info: host.Smartazamba iobroker host.Smartazamba object unifi-network.0.info.lastRealTimeData created
      2025-12-21 00:11:13.672  - info: host.Smartazamba iobroker host.Smartazamba Set default value of unifi-network.0.info.connection: false
      2025-12-21 00:11:13.742  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0 created
      2025-12-21 00:11:15.211  - info: host.Smartazamba iobroker exit 0
      2025-12-21 00:11:19.475  - info: host.Smartazamba instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1080585
      2025-12-21 00:11:20.517  - error: host.Smartazamba Caught by controller[0]: node:internal/modules/esm/resolve:274
      2025-12-21 00:11:20.518  - error: host.Smartazamba Caught by controller[0]:     throw new ERR_MODULE_NOT_FOUND(
      2025-12-21 00:11:20.518  - error: host.Smartazamba Caught by controller[0]:           ^
      2025-12-21 00:11:20.518  - error: host.Smartazamba Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
      2025-12-21 00:11:20.519  - error: host.Smartazamba Caught by controller[0]:     at finalizeResolution (node:internal/modules/esm/resolve:274:11)
      2025-12-21 00:11:20.519  - error: host.Smartazamba Caught by controller[0]:     at moduleResolve (node:internal/modules/esm/resolve:859:10)
      2025-12-21 00:11:20.519  - error: host.Smartazamba Caught by controller[0]:     at defaultResolve (node:internal/modules/esm/resolve:983:11)
      2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
      2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
      2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
      2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
      2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]:     at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
      2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]:   code: 'ERR_MODULE_NOT_FOUND',
      2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]:   url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
      2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]: }
      2025-12-21 00:11:20.522  - error: host.Smartazamba Caught by controller[0]: Node.js v22.21.0
      2025-12-21 00:11:20.522  - error: host.Smartazamba instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-12-21 00:11:20.522  - info: host.Smartazamba Adapter system.adapter.unifi-network.0 needs rebuild and will be restarted afterwards.
      2025-12-21 00:11:20.523  - info: host.Smartazamba system.adapter.unifi-network.0 will be rebuilt
      2025-12-21 00:11:20.525  - warn: host.Smartazamba adapter "unifi-network" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      2025-12-21 00:11:20.526  - info: host.Smartazamba iobroker rebuild
      2025-12-21 00:11:23.508  - info: host.Smartazamba iobroker npm-rebuild: Rebuilding native modules ...
      2025-12-21 00:12:06.732  - info: sonoff.0 (1067208) Client [WiFi-Plug13] reconnected. Old secret 1766271468696_4722 ==> New secret 1766272326730_9538
      2025-12-21 00:12:22.098  - info: host.Smartazamba iobroker npm-rebuild: rebuilt dependencies successfully
      2025-12-21 00:12:22.178  - info: host.Smartazamba iobroker npm-rebuild: Rebuilding native modules done
      2025-12-21 00:12:23.189  - info: host.Smartazamba iobroker npm-rebuild: exit 0
      2025-12-21 00:12:25.002  - info: host.Smartazamba instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1082402
      2025-12-21 00:12:26.125  - error: host.Smartazamba Caught by controller[0]: node:internal/modules/esm/resolve:274
      2025-12-21 00:12:26.125  - error: host.Smartazamba Caught by controller[0]:     throw new ERR_MODULE_NOT_FOUND(
      2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]:           ^
      2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
      2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]:     at finalizeResolution (node:internal/modules/esm/resolve:274:11)
      2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]:     at moduleResolve (node:internal/modules/esm/resolve:859:10)
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at defaultResolve (node:internal/modules/esm/resolve:983:11)
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:   code: 'ERR_MODULE_NOT_FOUND',
      2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:   url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
      2025-12-21 00:12:26.128  - error: host.Smartazamba Caught by controller[0]: }
      2025-12-21 00:12:26.128  - error: host.Smartazamba Caught by controller[0]: Node.js v22.21.0
      2025-12-21 00:12:26.128  - error: host.Smartazamba instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2025-12-21 00:12:26.128  - info: host.Smartazamba Adapter system.adapter.unifi-network.0 needs rebuild of undefined and will be restarted afterwards.
      2025-12-21 00:12:26.128  - info: host.Smartazamba system.adapter.unifi-network.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules/@iobroker/adapter-core/build"})
      2025-12-21 00:12:26.129  - warn: host.Smartazamba adapter "unifi-network" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
      2025-12-21 00:12:26.130  - info: host.Smartazamba iobroker rebuild undefined@undefined --path /opt/iobroker/node_modules/@iobroker/adapter-core/build
      2025-12-21 00:12:28.076  - info: host.Smartazamba iobroker npm-rebuild: Rebuilding native module "undefined@undefined" in /opt/iobroker/node_modules/@iobroker/adapter-core/build ...
      2025-12-21 00:12:29.352  - error: host.Smartazamba iobroker npm-rebuild: Rebuilding native modules failed
      2025-12-21 00:12:30.369  - info: host.Smartazamba iobroker npm-rebuild: exit 1
      2025-12-21 00:12:31.757  - info: host.Smartazamba instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1082457
      2025-12-21 00:12:32.680  - error: host.Smartazamba Caught by controller[0]: node:internal/modules/esm/resolve:274
      2025-12-21 00:12:32.680  - error: host.Smartazamba Caught by controller[0]:     throw new ERR_MODULE_NOT_FOUND(
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:           ^
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at finalizeResolution (node:internal/modules/esm/resolve:274:11)
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at moduleResolve (node:internal/modules/esm/resolve:859:10)
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at defaultResolve (node:internal/modules/esm/resolve:983:11)
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
      2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
      2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:     at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
      2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:     at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
      2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:   code: 'ERR_MODULE_NOT_FOUND',
      2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:   url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
      2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]: }
      2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]: Node.js v22.21.0
      2025-12-21 00:12:32.682  - error: host.Smartazamba instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      ScroungerS Offline
      ScroungerS Offline
      Scrounger
      #113
      Das hatten wir schon mal:
      https://github.com/Scrounger/ioBroker.unifi-network/issues/33
      • R Offline
        Rushmed
        #114
        @scrounger Vielen Dank.
        Eine Lösung dafür konnte ich aber weder auf Github noch hier
        https://forum.iobroker.net/topic/82486/adapter-core-unterschiedlich-3-3-1-3-3-2/18
        finden.
        • ScroungerS Offline
          ScroungerS Offline
          Scrounger
          #115
          Kann sein hab das nicht im Detail verfolgt, da es kein Problem vom Adapter ist. Ggf. Das fehlerhafte Paket halt manuell installieren.
          • Q Offline
            Q Offline
            Qlink
            schrieb am zuletzt editiert von Qlink
            #116
            Hat hier jemand ein Blockly Beispiel für mich, zwecks Anwesenheitserkennung mit dem neuen Adapter hier ? Wie verarbeitet ihr den "last seen" Datenpunkt ? Was sagt der Wert genau aus ? Sind das Sekunden? Im alten Adapter hatte ich genau das Datum + Uhrzeit was selbst erklärend ist...
            Danke und beste Grüße
            lobomauL CodierknechtC 2 Antworten Letzte Antwort
            • Q Qlink
              lobomauL Offline
              lobomauL Offline
              lobomau
              schrieb am zuletzt editiert von lobomau
              #117
              @Qlink musst einstellen, dass "isOnline" verfügbar ist. Ist boolean true/false:
              Host: NUC8i3 mit Proxmox:
              • Slave: Pi4
              • ScroungerS Scrounger
                mcm1957M Offline
                mcm1957M Offline
                mcm1957
                #118
                @Scrounger sagte in Test Adapter Unifi Network:
                Fehlende npm Pakete sollten eigentlich nie manuel installiert werden. Es ist eigentlich Aufgabe des Adapters der diese benötigt sicherzustellen dass diese Pakete installiert werden. Als NOT-Lösung mag es in Einzelfällen notwendig sein.
                Wenn dieses Problem mit der zu alten adapter-core Version zusammenhängt, dann sollte js-controller 7.1.0 (derzeit im Beta) das Problem beheben, da diese Release adapeter-core 3.2.2 (aktuelle Version) installiert. Damit diese js-controlelr Version jedenfalls installiert ist sollte der Adapter (in Zukunft) seine Requirements anpassen wenn er Module oder Funktionen benötigt die erst mit adapter-core 3.2.2 verfügabr sind. (Nur damiots nicht falsch rüberkommt: Das ist KEINE Kritik an der Adapterentwicklung, zur Zeit der Erstellung des Adapters war die js-controlelr Version 7.1.0 noch nicht mal existent und das Problem ist auch erst durch diesen Adapetr aufgefallen.)
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                ScroungerS 1 Antwort Letzte Antwort
                • mcm1957M mcm1957
                  ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  #119
                  @mcm1957
                  Mir war nicht bewusst das die 3.2.2. wohl nicht mit dem aktuellen js-controller kompatibel sein soll. Warum wird die dann den Entwicklern per bot überhaupt vorgeschlagen?
                  Und warum haben manche Probleme - bis jetzt sind mir 2 bekannt - und andere nicht?
                  Ich betreue 7 Systemen mit aktuellem stable js-controller und bei keinem tritt das Problem auf.
                  Was muss man denn implementieren das die Installation der 3.2.2. garantiert wird, dachte das läuft automatisch?
                  • R Offline
                    Rushmed
                    #120
                    @mcm1957 Danke mit js-controller 7.1.0 bekomm ich den Adapter gestartet.
                    • Q Qlink
                      CodierknechtC Offline
                      Codierknecht
                      #121
                      @Qlink sagte in Test Adapter Unifi Network:
                      Du benötigst dazu eine passende Aufzählung (Kategorie), in die Du alle relevanten isOnline Datenpunkte packst.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • mcm1957M Offline
                        mcm1957M Offline
                        mcm1957
                        #122
                        Super - danke fürs Feedback.
                        Ev. ergänze deine Erfahrungen im Issue https://github.com/Scrounger/ioBroker.unifi-network/issues/56 damit scrounger dort Feedback bekommt ob bzw. dass ein Update der Dependency Requirement sinnvoll ist.
                        Und ja - js-controller 7.1.0 ist noch im BETA Channel. Da dieser die Basis für ioBroker ist geht der nicht zwischen Tür und Angel ins STABLE. Bisher kenne ich allerdings keine (neuen) Probleme mit js-controller 7.1.0
                          @mcm1957
                          mcm1957M Offline
                          mcm1957M Offline
                          mcm1957
                          #123
                          @mcm1957
                          Völlig klar dass dir das nicht bewusst war.
                          Die Antwort ist ein wenig länger :-).
                          Als reiner User kann das Nachfolgende gerne übersprungen werden - ist aber kein Geheimnis.
                          Es gibt im js-controller einen override für adapter-core der bis 7.0.x mindesten adapter-core 3.1.x verlangt. Dieser wurde mit js-controller 6 eingeführt da es zahlreiche schlecht gewartete Adapter gab (und noch immer einige gibt) die nur adapter-core 2.x.x verlangen und mit js-controller 6 schlagartig nicht mehr funktioniert hätten. Leider blockiert der Override auch die aktuelleren Angaben in Adaptern. Dieser Effekt war bis vor Kurzem nicht bekannt. Dadurch wurde und wird auch bei Angabe von adapter-core 3.2.2 kein Update des cores installiert. Mit js-controller 7.1.0 wird nun der core auf mindestens 3.2.2 gehoben. Mit js-controller 8 ist es wahrscheinlich, dass der override ganz entfällt und die dann noch nicht komptiblen Adapter je nach "Gesamtzustand" deprecated werden oder per override eine Aktualisiserung bekommen. Das ist aber ein Thema für das core-Team und js-controller 8.
                          adapter-core 3.2.2 is voll kompatibel mit js-controller 6 und 7. Probleme gibt es nur, wenn ein Adapter Funktionalität verwendet die erst mit adapter-core 3.2.x implementiert wurde und in älteren Versionen nicht verfügbar ist. Das ist nur bei ganz wenigen Adaptern der Fall. Kann es sein, dass der unifi irgendwas im Bereich oauth verwendet? Der Bot reklamiert eine aktuelle adapter-core Version auch aus dem Grund weiterhin da diese Dependency mit Wegfall des Overrides wieder wichtig wird.
                          Hoffe ich ich konnte mehr erklären denn verwirren.
                          mcm1957
                            @michmein sagte in Test Adapter Unifi Network:
                            Ich hätte da allerdings ne Frage zu den Einstellungen der Firewall, ich denke es so konfiguriert zu haben das alle Infos aus meinem UCG-max ausgelesen werden sollten. Ich kann in den Objekten aber nur zwei Gruppen sehen und keine einzelnen Regeln. Habe ich etwas falsch gemacht oder ist es gar nicht implementiert?
                            Das ist gar nicht implementiert. Sorry hatte damit mal angefangen, aber da ich es dann doch nicht gebraucht habe, hab ich es nicht zu Ende implementiert.
                            Wenn du es brauchst, erstell bitte nen Feature Request auf GitHub.
                            Zusätzlich habe ich auch ein Unifi UNAS in meiner Sammlung, weisst du ob es die Möglichkeit gibt dies ebenfalls unter "devices" aufzuführen? Im Webinterface des UCG wird es auch unter Devices ausfgelistet.
                            Es werden nur die Network relevanten Devices angezeigt. Devices von anderen Unifi Applications wie Protect, Talk, Drive, etc. werden nicht angezeigt. Ich weiß auch gar nicht ob die API das mitliefert.
                            Mach hierzu am besten auch mal ein Feature Request auf GitHub auf. Brauch ggf. dann unterstützung von Dir weil ich keine NAS / Unifi Drive habe.
                            Die bessere Lösung wäre, wenn es einen eigenen Adapter für Unifi Drive geben würde ;-)
                            Rushmed
                            #124
                            Scrounger Offline
                            Scrounger
                            schrieb am 15. Nov. 2025, 19:01
                            zuletzt editiert von Scrounger
                            Ich hatte die naive Hoffnung mit dem Adapter Zugriff auf meine Firewall regeln zu bekommen.
                            Bei den beiden Optinonen von "Firewall - Rule enabled" bleibt das Pulldown mit Ladekreiseln hängen und ich kann nichts auswählen.
                            Ist das nicht implementiert?
                            • mcm1957M mcm1957
                              @mcm1957
                              mcm1957
                              ScroungerS Offline
                              ScroungerS Offline
                              Scrounger
                              #125
                              @mcm1957 sagte in Test Adapter Unifi Network:
                              Nö der verwendet nix spezielles, läuft auch mit 3.2.1, hab das nur aktualisiert weil der bot es angemerkt hat.
                              Ist noch nicht implemnetiert:
                              https://github.com/Scrounger/ioBroker.unifi-network/issues/44
                              • Q Offline
                                Q Offline
                                Qlink
                                #126
                                @scrounger
                                Hab gerade folgende warning im log erhalten:
                                [onNetworkEvent]: not implemented event (key: EVT_DM_Connected) -
                                Please report this to the developer and creating an issue on github!
                                (meta: {"rc":"ok","message":"events"}, data: {"key":"EVT_DM_Connected","dm":"0c:ea:14:8a:5f:2f","gw":"0c:ea:14:8a:5f:2f","dm_name":"MMB UCG Max","dm_model":"UCGMAX","dm_displayName":"MMB UCG Max","gw_displayName":"MMB UCG Max","subsystem":"lan","is_negative":false,"site_id":"61ebfad7c4598a55bd60c03c","time":1767040236649,"datetime":"2025-12-29T20:30:36Z","msg":"0c:ea:14:8a:5f:2f was connected"})
                                R 1 Antwort Letzte Antwort
                                • Q Qlink
                                  @scrounger
                                  reutli
                                  #127
                                  @scrounger
                                  Dann mach doch, was da steht:
                                  --> https://github.com/Scrounger/ioBroker.unifi-network/issues
                                  iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
                                  *Wer freundlich ist, dem wird freundlich geholfen *
                                    megamacy
                                    #128
                                    Besteht die Möglichkeit Log Einträge zu reconnects von Geräten einzuschränken? Ich hab einen Switchbot HUB der bewusst vom Internet geblockt wurde. Laut deren Support ist in dem Fall ein frequentes WiFi reconnect "gewollt", was mich schon im Unify Log nervt. Mit dem neuen iobroker Adapter (Der echt super ist bisher) zieht das nun 1:1 ins iobroker Log. Ich dachte zuerst wenn ich einen debounce einstelle, löst das auch die Log Problematik, was leider nicht so ist.
                                    * unifi-network.0	30.12.2025 18:22	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:22	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:25	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:25	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:27	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:27	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:29	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:29	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:32	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:32	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:39	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:39	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:46	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:46	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:48	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:49	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:50	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:51	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:53	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:53	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:55	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:56	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    * unifi-network.0	30.12.2025 18:57	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' disconnected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) from 'iot' on 'U6+ EG Wohnzimmer' -> debounce disconnection for 180s (client specific)
                                    * unifi-network.0	30.12.2025 18:58	info	[eventHandler.client.connected]: client 'SwitchBot-HubMiniMatter' connected (mac: 9c:9e:6e:xx:xx:xx, ip: 192.168.1.66) to 'iot' on 'U6+ EG Wohnzimmer'
                                    • M megamacy
                                      ScroungerS Offline
                                      ScroungerS Offline
                                      Scrounger
                                      #129
                                      @megamacy
                                      Feature request auf GitHub bitte erstellen, dann Bau ich das in eine der nächsten Versionen ein, das man die Meldungen auf debug stellen kann.
                                        schweiger2
                                        #130
                                        Hallo @scrounger ,
                                        mit dem neuen Adapter iobroker.unifi-network ist eine Verbindung zum UnifiOS Server nicht möglich.
                                        Nach dem Starten des Adapters bleibt dieser lange gelb und wird dann rot.
                                        Das Log sagt dazu
                                        2026-01-12 21:14:21.657 - info: host.iobroker instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 5321
                                        2026-01-12 21:14:22.471 - info: unifi-network.0 (5321) starting. Version 1.3.1 in /opt/iobroker/node_modules/iobroker.unifi-network, node: v22.21.0, js-controller: 7.1.0
                                        2026-01-12 21:14:25.520 - error: unifi-network.0 (5321) [NetworkApi.detectUnifiOs] Unable to detect UniFi OS or self hosted controller!
                                        2026-01-12 21:14:25.521 - error: unifi-network.0 (5321) [login]: Login to the Unifi-Network controller API failed! (host: https://X.X.X.X:11443, site: xxxx)
                                        2026-01-12 21:14:25.526 - info: unifi-network.0 (5321) [onReady]: Listening to WebSocket realtime API events started
                                        2026-01-12 21:14:55.526 - warn: unifi-network.0 (5321) [aliveChecker]: No connection to the Unifi-Network controller -> restart connection (retries: 0, no data since 33s)
                                        2026-01-12 21:14:58.545 - error: unifi-network.0 (5321) [NetworkApi.detectUnifiOs] Unable to detect UniFi OS or self hosted controller!
                                        2026-01-12 21:14:58.546 - error: unifi-network.0 (5321) [login]: Login to the Unifi-Network controller API failed! (host: https://X.X.X.X:11443, site: xxxx)
                                        Entsprechend der Konfigurations-Hinweise zum neuen Adapter auf Github wurde natürlich der zusätzliche Admin mit den dort angegebenen Rechten in UnifiOS Server angelegt.
                                        Alle Ports wurden durchgetestet:
                                        curl -k https://X.X.X.X:443
                                        curl -k https://X.X.X.X:8443
                                        curl -k https://X.X.X.X:11443
                                        curl -k http://X.X.X.X:80
                                        Nur auf Port 11443 gibt es eine Antwort.
                                        Wenn ich mit dem alten Unifi-Adapter die genau gleichen Credentials benutze, gelingt die Verbindung problemlos, der Adapter wird grün und transportiert Werte.
                                        Welche weiteren Infos werden benötigt?
                                        Vielen Dank
                                        • S schweiger2
                                          Hallo @scrounger ,
                                          Das Log sagt dazu
                                          Vielen Dank
                                          reutli
                                          #131
                                          @schweiger2 sagte in Test Adapter Unifi Network:
                                          Vielleicht gibst Du mal die vollständigen EInstellungen im Adapter preis und welche IP Adresse Dein (welchem) UnifiOS mit welcher Ausprägung hat.
                                          PS: Deine private IP-Adresse musst Du nicht "aus-Xen" kann ohnehin niemand was mit anfangen...
