  4. Test Adapter Unifi Network
    6.3k
173 Beiträge 34 Kommentatoren 26.8k Aufrufe 38 Beobachtet
  • W Offline
    W Offline
    warp735
    #103
    Da hast leider recht... Die 10er läuft zwar grad unauffällig, aber bei Protect hab ich auch das Gefühl das wird schleichend immer schlechter statt besser
    • R Offline
      Rushmed
      #104
      Bei mir fiegt der Adapter nicht los.
      LOG:
      host.Smartazamba
      2025-12-20 23:16:48.200	info	Rebuild for adapter system.adapter.unifi-network.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
      host.Smartazamba
      2025-12-20 23:16:48.200	error	instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.Smartazamba
      2025-12-20 23:16:48.200	error	Caught by controller[0]: Node.js v22.21.0
      host.Smartazamba
      2025-12-20 23:16:48.200	error	Caught by controller[0]: }
      host.Smartazamba
      2025-12-20 23:16:48.200	error	Caught by controller[0]: url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: code: 'ERR_MODULE_NOT_FOUND',
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at defaultResolve (node:internal/modules/esm/resolve:983:11)
      host.Smartazamba
      2025-12-20 23:16:48.199	error	Caught by controller[0]: at moduleResolve (node:internal/modules/esm/resolve:859:10)
      host.Smartazamba
      2025-12-20 23:16:48.198	error	Caught by controller[0]: at finalizeResolution (node:internal/modules/esm/resolve:274:11)
      host.Smartazamba
      2025-12-20 23:16:48.198	error	Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
      host.Smartazamba
      2025-12-20 23:16:48.198	error	Caught by controller[0]: ^
      host.Smartazamba
      2025-12-20 23:16:48.198	error	Caught by controller[0]: throw new ERR_MODULE_NOT_FOUND(
      host.Smartazamba
      2025-12-20 23:16:48.197	error	Caught by controller[0]: node:internal/modules/esm/resolve:274
      host.Smartazamba
      2025-12-20 23:16:46.389	info	instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1027036
      host.Smartazamba
      2025-12-20 23:16:44.052	info	iobroker npm-rebuild: exit 0
      host.Smartazamba
      2025-12-20 23:16:43.025	info	iobroker npm-rebuild: Rebuilding native modules done
      host.Smartazamba
      2025-12-20 23:16:42.906	info	iobroker npm-rebuild: rebuilt dependencies successfully
      Der ander Unifi Adapter mit den selben Einstellungen läuft!
      Was mach' ich falsch?
      • R Rushmed
        LOG:
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        host.Smartazamba
        #105
        @Rushmed sagte in Test Adapter Unifi Network:
        Installier den Adapter nochmal neu.
        Da wird ein Modul nicht gebaut.
        Und bitte das richtige Log benutzen, nicht das Ding aus dem Admin und dann auch noch in falscher Chronologie.
        • R Offline
          Rushmed
          #106
          Was ist denn bitte das "richtige" LOG?
          Hab den Adapter neu installiert, keine Restarts oder so.
          Es kommt auch:
          host.Smartazamba
          2025-12-20 23:51:10.096	warn	adapter "unifi-network" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
          • R Rushmed
            Es kommt auch:
            host.Smartazamba
            #107
            iob logs --watch
            • R Rushmed
              Es kommt auch:
              host.Smartazamba
              #108
              @Rushmed
              Auf meinem system läuft die Installation einwandfrei durch:
              echad@chet:~ $ iob add unifi-network --debug
              NPM version: 11.6.2
              Installing iobroker.unifi-network@1.3.1... (System call)
              added 6 packages in 11s
              254 packages are looking for funding
                run `npm fund` for details
              host.chet install adapter unifi-network
              upload [19] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/clients.jsonConfig.json clients.jsonConfig.json application/json
              upload [18] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/devices.jsonConfig.json devices.jsonConfig.json application/json
              upload [17] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/expert.jsonConfig.json expert.jsonConfig.json application/json
              upload [16] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/firewall.jsonConfig.json firewall.jsonConfig.json application/json
              upload [15] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/general.jsonConfig.json general.jsonConfig.json application/json
              upload [14] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/de.json i18n/de.json application/json
              upload [13] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/en.json i18n/en.json application/json
              upload [12] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/es.json i18n/es.json application/json
              upload [11] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/fr.json i18n/fr.json application/json
              upload [10] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/it.json i18n/it.json application/json
              upload [9] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/nl.json i18n/nl.json application/json
              upload [8] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pl.json i18n/pl.json application/json
              upload [7] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pt.json i18n/pt.json application/json
              upload [6] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/ru.json i18n/ru.json application/json
              upload [5] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/uk.json i18n/uk.json application/json
              upload [4] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
              upload [3] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/jsonConfig.json jsonConfig.json application/json
              upload [2] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/lan.jsonConfig.json lan.jsonConfig.json application/json
              upload [1] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/unifi-network.png unifi-network.png image/png
              upload [0] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/wlan.jsonConfig.json wlan.jsonConfig.json application/json
              host.chet object system.adapter.unifi-network created/updated
              Updating objects from io-package.json for adapter "unifi-network" with version "1.3.1"
              host.chet create instance unifi-network
              host.chet object system.adapter.unifi-network.0.alive created
              host.chet object system.adapter.unifi-network.0.connected created
              host.chet object system.adapter.unifi-network.0.compactMode created
              host.chet object system.adapter.unifi-network.0.cpu created
              host.chet object system.adapter.unifi-network.0.cputime created
              host.chet object system.adapter.unifi-network.0.memHeapUsed created
              host.chet object system.adapter.unifi-network.0.memHeapTotal created
              host.chet object system.adapter.unifi-network.0.memRss created
              host.chet object system.adapter.unifi-network.0.uptime created
              host.chet object system.adapter.unifi-network.0.inputCount created
              host.chet object system.adapter.unifi-network.0.outputCount created
              host.chet object system.adapter.unifi-network.0.eventLoopLag created
              host.chet object system.adapter.unifi-network.0.sigKill created
              host.chet object system.adapter.unifi-network.0.logLevel created
              host.chet object system.adapter.unifi-network.0.objectsWarnLimit created
              host.chet object unifi-network.0.info created
              host.chet object unifi-network.0.info.connection created
              host.chet object unifi-network.0.info.lastRealTimeData created
              host.chet Set default value of unifi-network.0.info.connection: false
              host.chet object system.adapter.unifi-network.0 created
              echad@chet:~ $
              R 1 Antwort Letzte Antwort
                @Rushmed
                NPM version: 11.6.2
                echad@chet:~ $
                Rushmed
                schrieb am zuletzt editiert von Rushmed
                #109
                @Thomas-Braun
                Ja, Glückwunsch!
                Bei mir klappt irgendetwas nicht und ich wollte wissen ob mir hier im Forum jemand helfen kann.
                Install Log:
                $ iobroker add unifi-network --host Smartazamba
                NPM version: 10.9.4Installing iobroker.unifi-network@1.3.1... (System call)
                added 5 packages in 12s
                201 packages are looking for funding run `npm fund` for details
                host.Smartazamba install adapter unifi-network
                host.Smartazamba object system.adapter.unifi-network created/updated
                host.Smartazamba create instance unifi-network
                host.Smartazamba object system.adapter.unifi-network.0.alive created
                host.Smartazamba object system.adapter.unifi-network.0.connected created
                host.Smartazamba object system.adapter.unifi-network.0.compactMode created
                host.Smartazamba object system.adapter.unifi-network.0.cpu created
                host.Smartazamba object system.adapter.unifi-network.0.cputime created
                host.Smartazamba object system.adapter.unifi-network.0.memHeapUsed created
                host.Smartazamba object system.adapter.unifi-network.0.memHeapTotal created
                host.Smartazamba object system.adapter.unifi-network.0.memRss created
                host.Smartazamba object system.adapter.unifi-network.0.uptime created
                host.Smartazamba object system.adapter.unifi-network.0.inputCount created
                host.Smartazamba object system.adapter.unifi-network.0.outputCount created
                host.Smartazamba object system.adapter.unifi-network.0.eventLoopLag created
                host.Smartazamba object system.adapter.unifi-network.0.sigKill created
                host.Smartazamba object system.adapter.unifi-network.0.logLevel created
                host.Smartazamba object unifi-network.0.info created
                host.Smartazamba object unifi-network.0.info.connection created
                host.Smartazamba object unifi-network.0.info.lastRealTimeData created
                host.Smartazamba Set default value of unifi-network.0.info.connection: false
                host.Smartazamba object system.adapter.unifi-network.0 created
                Process exited with code 0
                Hab jetzt nochmal neu installiert.
                LOG:
                2025-12-21 00:11:10.354  - info: host.Smartazamba iobroker 201 packages are looking for funding  run `npm fund` for details
                2025-12-21 00:11:10.412  - info: host.Smartazamba iobroker host.Smartazamba install adapter unifi-network
                2025-12-21 00:11:10.555  - info: host.Smartazamba iobroker upload [19] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/clients.jsonConfig.json clients.jsonConfig.json application/json
                2025-12-21 00:11:10.568  - info: host.Smartazamba iobroker upload [18] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/devices.jsonConfig.json devices.jsonConfig.json application/json
                2025-12-21 00:11:10.580  - info: host.Smartazamba iobroker upload [17] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/expert.jsonConfig.json expert.jsonConfig.json application/json
                2025-12-21 00:11:10.591  - info: host.Smartazamba iobroker upload [16] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/firewall.jsonConfig.json firewall.jsonConfig.json application/json
                2025-12-21 00:11:10.602  - info: host.Smartazamba iobroker upload [15] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/general.jsonConfig.json general.jsonConfig.json application/json
                2025-12-21 00:11:10.613  - info: host.Smartazamba iobroker upload [14] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/de.json i18n/de.json application/json
                2025-12-21 00:11:10.624  - info: host.Smartazamba iobroker upload [13] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/en.json i18n/en.json application/json
                2025-12-21 00:11:10.634  - info: host.Smartazamba iobroker upload [12] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/es.json i18n/es.json application/json
                2025-12-21 00:11:10.648  - info: host.Smartazamba iobroker upload [11] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/fr.json i18n/fr.json application/json
                2025-12-21 00:11:10.707  - info: host.Smartazamba iobroker upload [10] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/it.json i18n/it.json application/json
                2025-12-21 00:11:10.719  - info: host.Smartazamba iobroker upload [9] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/nl.json i18n/nl.json application/json
                2025-12-21 00:11:10.734  - info: host.Smartazamba iobroker upload [8] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pl.json i18n/pl.json application/json
                2025-12-21 00:11:10.742  - info: host.Smartazamba iobroker upload [7] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/pt.json i18n/pt.json application/json
                2025-12-21 00:11:10.752  - info: host.Smartazamba iobroker upload [6] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/ru.json i18n/ru.json application/json
                2025-12-21 00:11:10.761  - info: host.Smartazamba iobroker upload [5] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/uk.json i18n/uk.json application/json
                2025-12-21 00:11:10.778  - info: host.Smartazamba iobroker upload [4] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/i18n/zh-cn.json i18n/zh-cn.json application/json
                2025-12-21 00:11:10.788  - info: host.Smartazamba iobroker upload [3] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/jsonConfig.json jsonConfig.json application/json
                2025-12-21 00:11:10.803  - info: host.Smartazamba iobroker upload [2] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/lan.jsonConfig.json lan.jsonConfig.json application/json
                2025-12-21 00:11:10.820  - info: host.Smartazamba iobroker upload [1] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/unifi-network.png unifi-network.png image/png
                2025-12-21 00:11:10.835  - info: host.Smartazamba iobroker upload [0] unifi-network.admin /opt/iobroker/node_modules/iobroker.unifi-network/admin/wlan.jsonConfig.json wlan.jsonConfig.json application/json
                2025-12-21 00:11:11.060  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network created/updated
                2025-12-21 00:11:11.064  - info: host.Smartazamba iobroker Updating objects from io-package.json for adapter "unifi-network" with version "1.3.1"
                2025-12-21 00:11:11.471  - info: host.Smartazamba iobroker host.Smartazamba create instance unifi-network
                2025-12-21 00:11:11.486  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.alive created
                2025-12-21 00:11:11.567  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.connected created
                2025-12-21 00:11:11.691  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.compactMode created
                2025-12-21 00:11:11.814  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.cpu created
                2025-12-21 00:11:12.034  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.cputime created
                2025-12-21 00:11:12.263  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.memHeapUsed created
                2025-12-21 00:11:12.440  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.memHeapTotal created
                2025-12-21 00:11:12.520  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.memRss created
                2025-12-21 00:11:12.691  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.uptime created
                2025-12-21 00:11:12.779  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.inputCount created
                2025-12-21 00:11:12.901  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.outputCount created
                2025-12-21 00:11:13.077  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.eventLoopLag created
                2025-12-21 00:11:13.169  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.sigKill created
                2025-12-21 00:11:13.341  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0.logLevel created
                2025-12-21 00:11:13.562  - info: host.Smartazamba iobroker host.Smartazamba object unifi-network.0.info created
                2025-12-21 00:11:13.622  - info: host.Smartazamba iobroker host.Smartazamba object unifi-network.0.info.connection created
                2025-12-21 00:11:13.649  - info: host.Smartazamba iobroker host.Smartazamba object unifi-network.0.info.lastRealTimeData created
                2025-12-21 00:11:13.672  - info: host.Smartazamba iobroker host.Smartazamba Set default value of unifi-network.0.info.connection: false
                2025-12-21 00:11:13.742  - info: host.Smartazamba iobroker host.Smartazamba object system.adapter.unifi-network.0 created
                2025-12-21 00:11:15.211  - info: host.Smartazamba iobroker exit 0
                2025-12-21 00:11:19.475  - info: host.Smartazamba instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1080585
                2025-12-21 00:11:20.517  - error: host.Smartazamba Caught by controller[0]: node:internal/modules/esm/resolve:274
                2025-12-21 00:11:20.518  - error: host.Smartazamba Caught by controller[0]:     throw new ERR_MODULE_NOT_FOUND(
                2025-12-21 00:11:20.518  - error: host.Smartazamba Caught by controller[0]:           ^
                2025-12-21 00:11:20.518  - error: host.Smartazamba Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
                2025-12-21 00:11:20.519  - error: host.Smartazamba Caught by controller[0]:     at finalizeResolution (node:internal/modules/esm/resolve:274:11)
                2025-12-21 00:11:20.519  - error: host.Smartazamba Caught by controller[0]:     at moduleResolve (node:internal/modules/esm/resolve:859:10)
                2025-12-21 00:11:20.519  - error: host.Smartazamba Caught by controller[0]:     at defaultResolve (node:internal/modules/esm/resolve:983:11)
                2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
                2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
                2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
                2025-12-21 00:11:20.520  - error: host.Smartazamba Caught by controller[0]:     at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
                2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]:     at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
                2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]:   code: 'ERR_MODULE_NOT_FOUND',
                2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]:   url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
                2025-12-21 00:11:20.521  - error: host.Smartazamba Caught by controller[0]: }
                2025-12-21 00:11:20.522  - error: host.Smartazamba Caught by controller[0]: Node.js v22.21.0
                2025-12-21 00:11:20.522  - error: host.Smartazamba instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2025-12-21 00:11:20.522  - info: host.Smartazamba Adapter system.adapter.unifi-network.0 needs rebuild and will be restarted afterwards.
                2025-12-21 00:11:20.523  - info: host.Smartazamba system.adapter.unifi-network.0 will be rebuilt
                2025-12-21 00:11:20.525  - warn: host.Smartazamba adapter "unifi-network" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                2025-12-21 00:11:20.526  - info: host.Smartazamba iobroker rebuild
                2025-12-21 00:11:23.508  - info: host.Smartazamba iobroker npm-rebuild: Rebuilding native modules ...
                2025-12-21 00:12:06.732  - info: sonoff.0 (1067208) Client [WiFi-Plug13] reconnected. Old secret 1766271468696_4722 ==> New secret 1766272326730_9538
                2025-12-21 00:12:22.098  - info: host.Smartazamba iobroker npm-rebuild: rebuilt dependencies successfully
                2025-12-21 00:12:22.178  - info: host.Smartazamba iobroker npm-rebuild: Rebuilding native modules done
                2025-12-21 00:12:23.189  - info: host.Smartazamba iobroker npm-rebuild: exit 0
                2025-12-21 00:12:25.002  - info: host.Smartazamba instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1082402
                2025-12-21 00:12:26.125  - error: host.Smartazamba Caught by controller[0]: node:internal/modules/esm/resolve:274
                2025-12-21 00:12:26.125  - error: host.Smartazamba Caught by controller[0]:     throw new ERR_MODULE_NOT_FOUND(
                2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]:           ^
                2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
                2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]:     at finalizeResolution (node:internal/modules/esm/resolve:274:11)
                2025-12-21 00:12:26.126  - error: host.Smartazamba Caught by controller[0]:     at moduleResolve (node:internal/modules/esm/resolve:859:10)
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at defaultResolve (node:internal/modules/esm/resolve:983:11)
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:     at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:   code: 'ERR_MODULE_NOT_FOUND',
                2025-12-21 00:12:26.127  - error: host.Smartazamba Caught by controller[0]:   url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
                2025-12-21 00:12:26.128  - error: host.Smartazamba Caught by controller[0]: }
                2025-12-21 00:12:26.128  - error: host.Smartazamba Caught by controller[0]: Node.js v22.21.0
                2025-12-21 00:12:26.128  - error: host.Smartazamba instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                2025-12-21 00:12:26.128  - info: host.Smartazamba Adapter system.adapter.unifi-network.0 needs rebuild of undefined and will be restarted afterwards.
                2025-12-21 00:12:26.128  - info: host.Smartazamba system.adapter.unifi-network.0 will be rebuilt (Args: {"path":"/opt/iobroker/node_modules/@iobroker/adapter-core/build"})
                2025-12-21 00:12:26.129  - warn: host.Smartazamba adapter "unifi-network" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                2025-12-21 00:12:26.130  - info: host.Smartazamba iobroker rebuild undefined@undefined --path /opt/iobroker/node_modules/@iobroker/adapter-core/build
                2025-12-21 00:12:28.076  - info: host.Smartazamba iobroker npm-rebuild: Rebuilding native module "undefined@undefined" in /opt/iobroker/node_modules/@iobroker/adapter-core/build ...
                2025-12-21 00:12:29.352  - error: host.Smartazamba iobroker npm-rebuild: Rebuilding native modules failed
                2025-12-21 00:12:30.369  - info: host.Smartazamba iobroker npm-rebuild: exit 1
                2025-12-21 00:12:31.757  - info: host.Smartazamba instance system.adapter.unifi-network.0 in version "1.3.1" started with pid 1082457
                2025-12-21 00:12:32.680  - error: host.Smartazamba Caught by controller[0]: node:internal/modules/esm/resolve:274
                2025-12-21 00:12:32.680  - error: host.Smartazamba Caught by controller[0]:     throw new ERR_MODULE_NOT_FOUND(
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:           ^
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher' imported from /opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/index.js
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at finalizeResolution (node:internal/modules/esm/resolve:274:11)
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at moduleResolve (node:internal/modules/esm/resolve:859:10)
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at defaultResolve (node:internal/modules/esm/resolve:983:11)
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at #cachedDefaultResolve (node:internal/modules/esm/loader:731:20)
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.resolve (node:internal/modules/esm/loader:708:38)
                2025-12-21 00:12:32.681  - error: host.Smartazamba Caught by controller[0]:     at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:310:38)
                2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:     at ModuleJob._link (node:internal/modules/esm/module_job:182:49)
                2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:     at process.processTicksAndRejections (node:internal/process/task_queues:105:5) {
                2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:   code: 'ERR_MODULE_NOT_FOUND',
                2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]:   url: 'file:///opt/iobroker/node_modules/@iobroker/adapter-core/build/esm/TokenRefresher'
                2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]: }
                2025-12-21 00:12:32.682  - error: host.Smartazamba Caught by controller[0]: Node.js v22.21.0
                2025-12-21 00:12:32.682  - error: host.Smartazamba instance system.adapter.unifi-network.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                Thomas BraunT ScroungerS 2 Antworten Letzte Antwort
                • R Rushmed
                  @Thomas-Braun
                  Ja, Glückwunsch!
                  Install Log:
                  LOG:
                  #110
                  Hattest du kürzlich nodejs upgegraded?
                  Wie sieht das System insgesamt aus?
                  iob diag
                  anschauen.
                    iob diag
                    anschauen.
                    Rushmed
                    #111
                    @Thomas-Braun
                    Das Node Update auf 22.21.1 funzt ja irgendwie nicht. Ansonsten glaube ich auf Stand zu sein.
                    iob Diag:
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                    Operating System: Debian GNU/Linux 13 (trixie)
                     Static hostname: Smartazamba
                           Icon name: computer
                              Kernel: Linux 6.12.47+rpt-rpi-v8
                        Architecture: arm64
                    OS is similar to:
                    Model           : Raspberry Pi 4 Model B Rev 1.4
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     00:33:25 up 19:31,  2 users,  load average: 2.23, 1.67, 1.86
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'trixie'!
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** TIME AND TIMEZONES ***
                                   Local time: Sun 2025-12-21 00:33:25 CET
                               Universal time: Sat 2025-12-20 23:33:25 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    pi
                    HOME=/home/pi
                    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    SUDO_HOME=/home/pi
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server:         false
                    Unit display-manager.service could not be found.
                    Display-Manager:
                    Desktop:
                    Session:                tty
                    *** MEMORY ***
                    Mem:            8.2G        4.7G        960M        101M        2.7G        3.5G
                    Swap:           2.1G        108M        2.0G
                    Total:           10G        4.8G        3.0G
                    Active iob-Instances:   38
                             7819 M total memory
                             4494 M used memory
                             3790 M active memory
                             2673 M inactive memory
                              915 M free memory
                              110 M buffer memory
                             2495 M swap cache
                             2047 M total swap
                              103 M used swap
                             1944 M free swap
                    top - 00:33:26 up 19:31,  2 users,  load average: 2.23, 1.67, 1.86
                    Tasks: 251 total,   1 running, 250 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  2.1 us,  2.1 sy,  0.0 ni, 95.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   7819.7 total,    913.7 free,   4495.6 used,   2606.3 buff/cache
                    MiB Swap:   2048.0 total,   1944.5 free,    103.5 used.   3324.1 avail Mem
                    *** FAILED SERVICES ***
                      UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                    * media-HDD3\x40NAS.mount loaded failed failed /media/HDD3@NAS
                    Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                            ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                            SUB    -> The low-level unit activation state, values depend on unit type.
                    1 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    /dev/root      ext4      110G   17G   91G  16% /
                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     1.6G  140M  1.4G   9% /run
                    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                    tmpfs          tmpfs     3.9G  6.8M  3.9G   1% /tmp
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
                    /dev/sdc       ext4      5.5T  3.2T  2.0T  62% /media/HDD2
                    /dev/sda1      vfat      253M   49M  204M  20% /boot/firmware
                    /dev/sdb1      ext4      4.6T  3.2T  1.2T  74% /media/HDD1
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
                    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyAMA0.service
                    tmpfs          tmpfs     782M  8.0K  782M   1% /run/user/1000
                    [Sat Dec 20 05:01:51 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:E2:C4:A5 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=5bc7cbe7-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Sat Dec 20 05:01:54 2025] EXT4-fs (sda2): mounted filesystem 1943b829-a99b-45b8-9fe5-7136dbea4c4a ro with ordered data mode. Quota mode: none.
                    [Sat Dec 20 05:01:54 2025] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                    [Sat Dec 20 05:01:58 2025] EXT4-fs (sda2): re-mounted 1943b829-a99b-45b8-9fe5-7136dbea4c4a r/w.
                    [Sat Dec 20 05:01:59 2025] EXT4-fs (sdc): mounted filesystem b85c7b90-8154-43e5-bcae-a07f1c446bec r/w with ordered data mode. Quota mode: none.
                    [Sat Dec 20 05:01:59 2025] EXT4-fs (sdb1): mounted filesystem f79cb025-aab2-4bd5-bd49-84de9b0f60b4 r/w with ordered data mode. Quota mode: none.
                    Show mounted filesystems:
                    TARGET           SOURCE    FSTYPE OPTIONS
                    /                /dev/sda2 ext4   rw,noatime
                    |-/media/HDD2    /dev/sdc  ext4   rw,nosuid,nodev,noexec,relatime
                    |-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                    `-/media/HDD1    /dev/sdb1 ext4   rw,nosuid,nodev,noexec,relatime
                    /var:
                    4.7G    /var/
                    1.2G    /var/log
                    786M    /var/cache
                    770M    /var/cache/apt
                    637M    /var/cache/apt/archives
                    Archived and active journals take up 160.5M in the file system.
                    /opt/iobroker/backups:
                    1.8G    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    447M    /opt/iobroker/iobroker-data/
                    186M    /opt/iobroker/iobroker-data/backup-objects
                    181M    /opt/iobroker/iobroker-data/files
                    47M     /opt/iobroker/iobroker-data/files/admin.admin
                    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                    65M     /opt/iobroker/iobroker-data/objects.jsonl
                    18M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-Rz8ETF2t.js
                    15M     /opt/iobroker/iobroker-data/states.jsonl
                    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-C_W7K-9p.js
                    6.9M    /opt/iobroker/iobroker-data/backup-objects/2025-12-20_23-02_objects.jsonl.gz
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0052-if00-port0
                    /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0063-if00-port0
                    *** ZigBee Settings ***
                    HINT:
                    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                    HINT:
                    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
                    tcp
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v22.21.0
                    /usr/bin/node           v22.21.0
                    /usr/bin/npm            10.9.4
                    /usr/bin/npx            10.9.4
                    /usr/bin/corepack       0.34.0
                    nodejs:
                      Installed: 22.21.0-1nodesource1
                      Candidate: 22.21.0-1nodesource1
                      Version table:
                     *** 22.21.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                         22.20.0-1nodesource1 1001
                         22.19.0-1nodesource1 1001
                         22.18.0-1nodesource1 1001
                         22.17.1-1nodesource1 1001
                         22.17.0-1nodesource1 1001
                         22.16.0-1nodesource1 1001
                         22.15.1-1nodesource1 1001
                         22.15.0-1nodesource1 1001
                         22.14.0-1nodesource1 1001
                         22.13.1-1nodesource1 1001
                         22.13.0-1nodesource1 1001
                         22.12.0-1nodesource1 1001
                         22.11.0-1nodesource1 1001
                         22.10.0-1nodesource1 1001
                         22.9.0-1nodesource1 1001
                         22.8.0-1nodesource1 1001
                         22.7.0-1nodesource1 1001
                         22.6.0-1nodesource1 1001
                         22.5.1-1nodesource1 1001
                         22.5.0-1nodesource1 1001
                         22.4.1-1nodesource1 1001
                         22.4.0-1nodesource1 1001
                         22.3.0-1nodesource1 1001
                         22.2.0-1nodesource1 1001
                         22.1.0-1nodesource1 1001
                         22.0.0-1nodesource1 1001
                         20.19.2+dfsg-1 500
                            500 http://deb.debian.org/debian trixie/main arm64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    Smartazamba         Smartazamba (version: 7.0.7, hostname: Smartazamba   , alive, uptime: 70288)
                    Core adapters versions
                    js-controller:  7.0.7
                    admin:          7.7.19
                    javascript:     9.0.11
                    nodejs modules from github:     1
                    | `-- kodi-ws@2.4.4 (git+https://git@github.com/iobroker-community-adapters/kodi-ws.git#ad5a1fdc5cd0a282e6818ff152594b5d32535103)
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : Smartazamba                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.alexa2.0                 : alexa2                : Smartazamba                              -  enabled
                      system.adapter.artnet.0                 : artnet                : Smartazamba                              - disabled, port: 6454
                    + system.adapter.awtrix-light.0           : awtrix-light          : Smartazamba                              -  enabled
                    + system.adapter.awtrix-light.1           : awtrix-light          : Smartazamba                              -  enabled
                    + system.adapter.backitup.0               : backitup              : Smartazamba                              -  enabled
                      system.adapter.denon.0                  : denon                 : Smartazamba                              - disabled
                    + system.adapter.device-watcher.0         : device-watcher        : Smartazamba                              -  enabled
                    + system.adapter.deyeidc.0                : deyeidc               : Smartazamba                              -  enabled, port: 8899
                      system.adapter.habpanel.0               : habpanel              : Smartazamba                              - disabled
                      system.adapter.hass.0                   : hass                  : Smartazamba                              - disabled, port: 8123
                    + system.adapter.hue.0                    : hue                   : Smartazamba                              -  enabled, port: 443
                      system.adapter.ical.0                   : ical                  : Smartazamba                              -  enabled
                    + system.adapter.influxdb.0               : influxdb              : Smartazamba                              -  enabled, port: 8086
                    + system.adapter.iot.0                    : iot                   : Smartazamba                              -  enabled
                    + system.adapter.javascript.0             : javascript            : Smartazamba                              -  enabled
                      system.adapter.kodi.0                   : kodi                  : Smartazamba                              - disabled, port: 9090
                    + system.adapter.logparser.0              : logparser             : Smartazamba                              -  enabled
                    + system.adapter.matter.0                 : matter                : Smartazamba                              -  enabled
                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : Smartazamba                              -  enabled, port: 54321
                    + system.adapter.mqtt.0                   : mqtt                  : Smartazamba                              -  enabled, port: 1883, bind: 0.0.0.0
                    + system.adapter.philips-tv.0             : philips-tv            : Smartazamba                              -  enabled
                    + system.adapter.ping.0                   : ping                  : Smartazamba                              -  enabled
                    + system.adapter.pixelit.0                : pixelit               : Smartazamba                              -  enabled
                      system.adapter.pixelit.1                : pixelit               : Smartazamba                              - disabled
                      system.adapter.pixelit.2                : pixelit               : Smartazamba                              - disabled
                      system.adapter.proxmox.0                : proxmox               : Smartazamba                              - disabled, port: 8006
                    + system.adapter.reolink.0                : reolink               : Smartazamba                              -  enabled
                    + system.adapter.reolink.1                : reolink               : Smartazamba                              -  enabled
                    + system.adapter.rest-api.0               : rest-api              : Smartazamba                              -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                    + system.adapter.shelly.0                 : shelly                : Smartazamba                              -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shuttercontrol.0         : shuttercontrol        : Smartazamba                              -  enabled
                    + system.adapter.simple-api.0             : simple-api            : Smartazamba                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    + system.adapter.smartmeter.0             : smartmeter            : Smartazamba                              -  enabled
                    + system.adapter.smartmeter.1             : smartmeter            : Smartazamba                              -  enabled
                    + system.adapter.sonoff.0                 : sonoff                : Smartazamba                              -  enabled, port: 1884, bind: 0.0.0.0
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : Smartazamba                              -  enabled
                    + system.adapter.telegram.0               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.telegram.1               : telegram              : Smartazamba                              -  enabled, port: 8443, bind: 0.0.0.0
                      system.adapter.unifi-network.0          : unifi-network         : Smartazamba                              -  enabled, port: 8443
                    + system.adapter.unifi.0                  : unifi                 : Smartazamba                              -  enabled
                      system.adapter.weatherunderground.0     : weatherunderground    : Smartazamba                              -  enabled
                    + system.adapter.web.0                    : web                   : Smartazamba                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    + system.adapter.wiobrowser.0             : wiobrowser            : Smartazamba                              -  enabled, port: 5000
                    + system.adapter.wled.0                   : wled                  : Smartazamba                              -  enabled
                    + system.adapter.zigbee.0                 : zigbee                : Smartazamba                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_b875aef9f419ec118e7074e5f01c6278-if00-port0
                    + system.adapter.zigbee.1                 : zigbee                : Smartazamba                              -  enabled, port: tcp://192.168.178.42:6638
                    + instance is alive
                    ioBroker-Repositories
                    │ (index) │ name               │ url                                                     │ auto upgrade │
                    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                    │ 2       │ 'latest live'      │ 'http://iobroker.live/repo/sources-dist-latest.json'    │ false        │
                    Upgrade policy: minor
                    Installed ioBroker-Adapters
                    Adapter    "admin"        : 7.7.19   , installed 7.7.19
                    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                    Adapter    "artnet"       : 1.2.2    , installed 1.2.2
                    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
                    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                    Adapter    "denon"        : 1.15.12  , installed 1.15.12
                    Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "hass"         : 1.4.0    , installed 1.4.0
                    Adapter    "hue"          : 3.16.2   , installed 3.16.2
                    Adapter    "ical"         : 1.18.1   , installed 1.18.1
                    Adapter    "iot"          : 5.0.7    , installed 5.0.7
                    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                    Controller "js-controller": 7.0.7    , installed 7.0.7
                    Adapter    "kodi"         : 3.1.0    , installed 3.1.0
                    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                    Adapter    "matter"       : 0.5.5    , installed 0.5.6
                    Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
                    Adapter    "ping"         : 1.7.9    , installed 1.7.9
                    Adapter    "pixelit"      : 1.1.4    , installed 1.1.4
                    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                    Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                    Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
                    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
                    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                    Adapter    "unifi-network": 1.3.1    , installed 1.3.1
                    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                    Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
                    Adapter    "wled"         : 0.7.2    , installed 0.7.2
                    Adapter    "ws"           : 2.6.2    , installed 3.0.19
                    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                    Objects and States
                    Objects:        19422
                    States:         18567
                    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                    Hit:1 http://deb.debian.org/debian trixie InRelease
                    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
                    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
                    Hit:4 http://archive.raspberrypi.org/debian trixie InRelease
                    Hit:5 https://repos.influxdata.com/debian stable InRelease
                    Hit:6 https://apt.grafana.com stable InRelease
                    Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          3316433    842565/smbd
                    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          3316434    842565/smbd
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9311       923/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1002       8878       1361/iobroker.js-co
                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1002       7730       1361/iobroker.js-co
                    tcp        0      0 0.0.0.0:9999            0.0.0.0:*               LISTEN      1000       4413735    1103371/nc
                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1002       13588      1808/io.shelly.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1002       13425      1766/io.mqtt.0
                    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1002       4262790    1067208/io.sonoff.0
                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          7525       1242/exim4
                    tcp6       0      0 :::445                  :::*                    LISTEN      0          3316431    842565/smbd
                    tcp6       0      0 :::139                  :::*                    LISTEN      0          3316432    842565/smbd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          9321       923/sshd: /usr/sbin
                    tcp6       0      0 :::21                   :::*                    LISTEN      0          9266       887/vsftpd
                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          7526       1242/exim4
                    tcp6       0      0 :::3000                 :::*                    LISTEN      109        10314      1360/grafana
                    tcp6       0      0 :::8093                 :::*                    LISTEN      1002       14080      2196/io.rest-api.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1002       14062      2176/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1002       8974       1459/io.admin.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        7578       879/influxd
                    tcp6       0      0 :::8087                 :::*                    LISTEN      1002       14010      2147/io.simple-api.
                    udp        0      0 0.0.0.0:5540            0.0.0.0:*                           1002       15206      2065/io.matter.0
                    udp        0      0 0.0.0.0:44195           0.0.0.0:*                           1002       17655      2065/io.matter.0
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6179       616/dhcpcd: [networ
                    udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          3321162    843109/nmbd
                    udp        0      0 192.168.178.20:137      0.0.0.0:*                           0          3321161    843109/nmbd
                    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          3321143    843109/nmbd
                    udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          3321164    843109/nmbd
                    udp        0      0 192.168.178.20:138      0.0.0.0:*                           0          3321163    843109/nmbd
                    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          3321144    843109/nmbd
                    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1002       12481      1725/io.mihome-vacu
                    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1002       12483      1744/io.mihome-vacu
                    udp        0      0 0.0.0.0:50049           0.0.0.0:*                           108        680        541/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       15212      2065/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       15197      2065/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       16556      2065/io.matter.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1002       13014      2184/io.wled.0
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        678        541/avahi-daemon: r
                    udp6       0      0 :::5540                 :::*                                1002       15205      2065/io.matter.0
                    udp6       0      0 :::47178                :::*                                108        681        541/avahi-daemon: r
                    udp6       0      0 :::44195                :::*                                1002       17654      2065/io.matter.0
                    udp6       0      0 :::546                  :::*                                0          6181       616/dhcpcd: [networ
                    udp6       0      0 :::5353                 :::*                                1002       15213      2065/io.matter.0
                    udp6       0      0 :::5353                 :::*                                1002       15200      2065/io.matter.0
                    udp6       0      0 :::5353                 :::*                                1002       15192      2065/io.matter.0
                    udp6       0      0 :::5353                 :::*                                108        679        541/avahi-daemon: r
                    2025-12-21 00:22:46.633  - info: host.Smartazamba stopInstance system.adapter.proxmox.0 (force=false, process=true)
                    2025-12-21 00:22:46.829  - info: javascript.0 (1518) script.js.Proxmox_Server: Proxmox Server nicht erreichbar, Instanz deaktiviert.
                    2025-12-21 00:22:47.131  - info: proxmox.0 (1069537) Got terminate signal TERMINATE_YOURSELF
                    2025-12-21 00:22:47.135  - info: proxmox.0 (1069537) terminating
                    2025-12-21 00:22:47.137  - info: proxmox.0 (1069537) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-12-21 00:22:47.152  - info: host.Smartazamba stopInstance system.adapter.proxmox.0 send kill signal
                    2025-12-21 00:22:47.640  - info: proxmox.0 (1069537) terminating
                    2025-12-21 00:22:48.635  - info: host.Smartazamba stopInstance timeout system.adapter.proxmox.0 killing pid 1069537
                    2025-12-21 00:22:49.065  - warn: host.Smartazamba instance system.adapter.proxmox.0 terminated due to SIGKILL
                    2025-12-21 00:22:49.066  - info: host.Smartazamba instance system.adapter.proxmox.0 terminated with code null ()
                    2025-12-21 00:22:49.332  - warn: javascript.0 (1518) script.js.Proxmox_Server: Proxmox Server wurde ausgeschaltet nach 1 min
                    2025-12-21 00:24:52.823  - info: web.0 (2176) ==> Connected system.user.admin from ::ffff:192.168.178.38
                    2025-12-21 00:25:30.047  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 1094835
                    2025-12-21 00:25:36.017  - info: weatherunderground.0 (1094835) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
                    2025-12-21 00:25:42.855  - info: weatherunderground.0 (1094835) Terminated (NO_ERROR): Without reason
                    2025-12-21 00:25:43.401  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1094835 terminated with code 0 (NO_ERROR)
                    2025-12-21 00:25:57.854  - info: sonoff.0 (1067208) Client [WiFi-Plug12] connection closed: timeout
                    2025-12-21 00:26:12.343  - info: sonoff.0 (1067208) Client [WiFi-Plug12] connected with secret 1766273172342_5873
                    2025-12-21 00:27:17.547  - info: web.0 (2176) <== Disconnect system.user.admin from ::ffff:192.168.178.38 habpanel.0
                    2025-12-21 00:28:48.346  - info: sonoff.0 (1067208) Client [WiFi-Plug12] reconnected. Old secret 1766273172342_5873 ==> New secret 1766273328339_2452
                    2025-12-21 00:30:30.042  - info: host.Smartazamba instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 1099380
                    2025-12-21 00:30:35.631  - info: weatherunderground.0 (1099380) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v22.21.0, js-controller: 7.0.7
                    2025-12-21 00:30:44.423  - info: weatherunderground.0 (1099380) Terminated (NO_ERROR): Without reason
                    2025-12-21 00:30:45.003  - info: host.Smartazamba instance system.adapter.weatherunderground.0 having pid 1099380 terminated with code 0 (NO_ERROR)
                    2025-12-21 00:34:25.154  - info: javascript.0 (1518) script.js.Lampen_Displays._Switch_Status_Synch_: alias.0.Lampe_Bad_switch_State = wahr
                    Ich freue mich auf deine Prüfung!
                    • R Rushmed
                      @Thomas-Braun
                      iob Diag:
                      Script v.2025-08-09
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm64
                      OS is similar to:
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : 64 bit
                      CPU threads: 4
                      Current issues:
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      pi
                      HOME=/home/pi
                      iobroker
                      HOME=/home/iobroker
                      SUDO_HOME=/home/pi
                      Display-Manager:
                      Desktop:
                      Session:                tty
                      *** MEMORY ***
                               7819 M total memory
                               4494 M used memory
                                915 M free memory
                                110 M buffer memory
                               2495 M swap cache
                               2047 M total swap
                                103 M used swap
                               1944 M free swap
                      *** FILESYSTEM ***
                      /var:
                      4.7G    /var/
                      1.2G    /var/log
                      786M    /var/cache
                      770M    /var/cache/apt
                      USB-Devices by-id:
                      HINT:
                      HINT:
                      tcp
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.9.4
                      /usr/bin/npx            10.9.4
                      nodejs:
                        Version table:
                           20.19.2+dfsg-1 500
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      admin:          7.7.19
                      javascript:     9.0.11
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        19422
                      States:         18567
                      Pending Updates: 0
                      #112
                      Ja, die Version findet sich noch nicht im nodesource-Repo.
                      Ansonsten schaut das System (bis auf Kleingkeiten) i.O. aus.
                      Die Meldungen haben auch nicht direkt mit dem unifi-network-Adapter zu tun, die kommen vom controller, würde ich sagen. Da weiß ich abber nicht wo und wie man da ansetzen müsste.
                      • R Rushmed
                        @Thomas-Braun
                        Ja, Glückwunsch!
                        Install Log:
                        LOG:
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        #113
                        Das hatten wir schon mal:
                        https://github.com/Scrounger/ioBroker.unifi-network/issues/33
                        • R Offline
                          Rushmed
                          #114
                          @scrounger Vielen Dank.
                          Eine Lösung dafür konnte ich aber weder auf Github noch hier
                          https://forum.iobroker.net/topic/82486/adapter-core-unterschiedlich-3-3-1-3-3-2/18
                          finden.
                          • ScroungerS Offline
                            ScroungerS Offline
                            Scrounger
                            #115
                            Kann sein hab das nicht im Detail verfolgt, da es kein Problem vom Adapter ist. Ggf. Das fehlerhafte Paket halt manuell installieren.
                            • Q Offline
                              Q Offline
                              Qlink
                              schrieb am zuletzt editiert von Qlink
                              #116
                              Hat hier jemand ein Blockly Beispiel für mich, zwecks Anwesenheitserkennung mit dem neuen Adapter hier ? Wie verarbeitet ihr den "last seen" Datenpunkt ? Was sagt der Wert genau aus ? Sind das Sekunden? Im alten Adapter hatte ich genau das Datum + Uhrzeit was selbst erklärend ist...
                              Danke und beste Grüße
                              lobomauL CodierknechtC 2 Antworten Letzte Antwort
                              • Q Qlink
                                lobomauL Offline
                                lobomauL Offline
                                lobomau
                                schrieb am zuletzt editiert von lobomau
                                #117
                                @Qlink musst einstellen, dass "isOnline" verfügbar ist. Ist boolean true/false:
                                Host: NUC8i3 mit Proxmox:
                                • Slave: Pi4
                                • ScroungerS Scrounger
                                  mcm1957M Online
                                  mcm1957M Online
                                  mcm1957
                                  #118
                                  @Scrounger sagte in Test Adapter Unifi Network:
                                  Fehlende npm Pakete sollten eigentlich nie manuel installiert werden. Es ist eigentlich Aufgabe des Adapters der diese benötigt sicherzustellen dass diese Pakete installiert werden. Als NOT-Lösung mag es in Einzelfällen notwendig sein.
                                  Wenn dieses Problem mit der zu alten adapter-core Version zusammenhängt, dann sollte js-controller 7.1.0 (derzeit im Beta) das Problem beheben, da diese Release adapeter-core 3.2.2 (aktuelle Version) installiert. Damit diese js-controlelr Version jedenfalls installiert ist sollte der Adapter (in Zukunft) seine Requirements anpassen wenn er Module oder Funktionen benötigt die erst mit adapter-core 3.2.2 verfügabr sind. (Nur damiots nicht falsch rüberkommt: Das ist KEINE Kritik an der Adapterentwicklung, zur Zeit der Erstellung des Adapters war die js-controlelr Version 7.1.0 noch nicht mal existent und das Problem ist auch erst durch diesen Adapetr aufgefallen.)
                                  Support Repositoryverwaltung.
                                  LESEN - gute Forenbeitrage
                                  ScroungerS 1 Antwort Letzte Antwort
                                  • mcm1957M mcm1957
                                    ScroungerS Offline
                                    ScroungerS Offline
                                    Scrounger
                                    #119
                                    @mcm1957
                                    Mir war nicht bewusst das die 3.2.2. wohl nicht mit dem aktuellen js-controller kompatibel sein soll. Warum wird die dann den Entwicklern per bot überhaupt vorgeschlagen?
                                    Und warum haben manche Probleme - bis jetzt sind mir 2 bekannt - und andere nicht?
                                    Ich betreue 7 Systemen mit aktuellem stable js-controller und bei keinem tritt das Problem auf.
                                    Was muss man denn implementieren das die Installation der 3.2.2. garantiert wird, dachte das läuft automatisch?
                                    • R Offline
                                      Rushmed
                                      #120
                                      @mcm1957 Danke mit js-controller 7.1.0 bekomm ich den Adapter gestartet.
                                      • Q Qlink
                                        CodierknechtC Offline
                                        Codierknecht
                                        #121
                                        @Qlink sagte in Test Adapter Unifi Network:
                                        Du benötigst dazu eine passende Aufzählung (Kategorie), in die Du alle relevanten isOnline Datenpunkte packst.
                                        HmIP|ZigBee|Tasmota|Unifi
                                        Zabbix Certified Specialist
                                        • mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #122
                                          Super - danke fürs Feedback.
                                          Ev. ergänze deine Erfahrungen im Issue https://github.com/Scrounger/ioBroker.unifi-network/issues/56 damit scrounger dort Feedback bekommt ob bzw. dass ein Update der Dependency Requirement sinnvoll ist.
                                          Und ja - js-controller 7.1.0 ist noch im BETA Channel. Da dieser die Basis für ioBroker ist geht der nicht zwischen Tür und Angel ins STABLE. Bisher kenne ich allerdings keine (neuen) Probleme mit js-controller 7.1.0
