  4. Automatidcher Reboot iobroker täglich
    6.4k
45 Beiträge 9 Kommentatoren 3.1k Aufrufe 7 Beobachtet
  • K Karacho
    @Thomas-Braun ```
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: iobroker20
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     16:49:19 up 3 days, 18:19,  2 users,  load average: 1.52, 1.22, 0.87
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-12-22 16:49:19 CET
               Universal time: Mon 2025-12-22 15:49:19 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        3.0G        224M        266K        831M        946M
    Swap:           209M         15M        193M
    Total:          4.2G        3.0G        417M
    Active iob-Instances:   30
             3795 M total memory
             2893 M used memory
             1007 M active memory
             2315 M inactive memory
              213 M free memory
               70 M buffer memory
              722 M swap cache
              199 M total swap
               15 M used swap
              184 M free swap
    top - 16:49:20 up 3 days, 18:19,  2 users,  load average: 1.56, 1.23, 0.88
    Tasks: 208 total,   3 running, 205 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 50.0 us, 25.0 sy,  0.0 ni, 25.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.9 total,    211.5 free,   2895.5 used,    792.6 buff/cache
    MiB Swap:    200.0 total,    184.8 free,     15.2 used.    900.4 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/sda2      ext4      220G   16G  195G   8% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Thu Dec 18 22:29:54 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=adc78390-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Dec 18 22:29:56 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
    [Thu Dec 18 22:29:57 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G    /var/
    668M    /var/log
    667M    /var/log/journal/7b7fe4cfb66842c09a3cb98b578c9b66
    416M    /var/cache
    Archived and active journals take up 666.5M in the file system.
    /opt/iobroker/backups:
    3.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    7.2G    /opt/iobroker/iobroker-data/
    6.8G    /opt/iobroker/iobroker-data/history
    319M    /opt/iobroker/iobroker-data/files
    120M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/history/20250306/history.0_userdata.0.Energie_Bezug_Netz.json
    52M     /opt/iobroker/iobroker-data/history/20250302/history.0_userdata.0.Energie_Bezug_Netz.json
    52M     /opt/iobroker/iobroker-data/history/20250301/history.0_userdata.0.Energie_Bezug_Netz.json
    52M     /opt/iobroker/iobroker-data/history/20250210/history.0_userdata.0.Energie_Bezug_Netz.json
    45M     /opt/iobroker/iobroker-data/history/20250309/history.0_userdata.0.Energie_Bezug_Netz.json
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker20          iobroker20 (version: 7.0.7, hostname: iobroker20    , alive, uptime: 66716)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     3
    +-- iobroker.hoymiles-wifi@0.1.1 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#83ba7640e6a73dc4ee4788b055318e1cfc58bc0f)
    +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#45f4994af57a0f6f06e308d0c6d7961bc49d27a5)
    +-- iobroker.pv-power-control@0.1.0 (git+ssh://git@github.com/Newan/ioBroker.pv-power-control.git#48203f8ba437503e209138af7f80acac953f7e7c)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker20                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker20                               -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker20                               -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker20                               -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker20                               -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker20                               -  enabled
      system.adapter.devices.0                : devices               : iobroker20                               - disabled
    + system.adapter.deyeidc.0                : deyeidc               : iobroker20                               -  enabled, port: 8899
      system.adapter.discovery.0              : discovery             : iobroker20                               - disabled
      system.adapter.dwd.0                    : dwd                   : iobroker20                               -  enabled
    + system.adapter.easee.0                  : easee                 : iobroker20                               -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker20                               -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker20                               -  enabled
      system.adapter.flot.0                   : flot                  : iobroker20                               - disabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker20                               -  enabled
    + system.adapter.history.0                : history               : iobroker20                               -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker20                               -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker20                               -  enabled
      system.adapter.hs100.0                  : hs100                 : iobroker20                               - disabled
      system.adapter.ical.0                   : ical                  : iobroker20                               -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker20                               - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker20                               -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker20                               -  enabled
    + system.adapter.info.0                   : info                  : iobroker20                               -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker20                               -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : iobroker20                               -  enabled
      system.adapter.midea.0                  : midea                 : iobroker20                               - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker20                               -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker20                               -  enabled, port: 54321
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker20                               -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker20                               -  enabled
      system.adapter.rpi2.0                   : rpi2                  : iobroker20                               - disabled
      system.adapter.scenes.0                 : scenes                : iobroker20                               - disabled
    + system.adapter.shelly.0                 : shelly                : iobroker20                               -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker20                               - disabled
      system.adapter.smartgarden.0            : smartgarden           : iobroker20                               - disabled
    + system.adapter.solarlog.0               : solarlog              : iobroker20                               -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : iobroker20                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : iobroker20                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker20                               -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker20                               - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker20                               - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker20                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker20                               - disabled
      system.adapter.vis.0                    : vis                   : iobroker20                               -  enabled
    + system.adapter.web.1                    : web                   : iobroker20                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.worx.0                   : worx                  : iobroker20                               - disabled
    + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : iobroker20                               -  enabled
    + system.adapter.zendure-solarflow.0      : zendure-solarflow     : iobroker20                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker20                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bmw"          : 4.3.1    , installed 4.3.1
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "ems-esp"      : 6.0.1    , installed 6.0.2
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
    Adapter    "heatingcontrol": 2.12.19 , installed 2.12.19
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hs100"        : 3.0.5    , installed 3.0.5
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "solarlog"     : 2.4.0    , installed 2.4.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "worx"         : 3.2.7    , installed 3.2.7
    Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
    Adapter    "zendure-solarflow": 3.1.1, installed 3.1.1
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        16381
    States:         13902
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1265363    225406/io.sonoff.0
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1265653    225786/io.shelly.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1263950    224889/iobroker.js-
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1264641    224889/iobroker.js-
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          733        714/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1287748    228691/io.web.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1264204    225015/io.admin.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       1287108    228669/io.nuki-exte
    tcp6       0      0 :::22                   :::*                    LISTEN      0          735        714/sshd: /usr/sbin
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1266865    225479/io.mihome-va
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       1292546    229348/io.mihome-va
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1267062    225793/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1267063    225793/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1324546    232832/io.broadlink
    udp        0      0 0.0.0.0:60459           0.0.0.0:*                           1001       1324549    232832/io.broadlink
    udp        0      0 0.0.0.0:48344           0.0.0.0:*                           1001       1322960    232832/io.broadlink
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        617        584/avahi-daemon: r
    udp        0      0 0.0.0.0:34184           0.0.0.0:*                           104        619        584/avahi-daemon: r
    udp6       0      0 fe80::93ff:a0e8:a30:546 :::*                                0          5724       627/NetworkManager
    udp6       0      0 :::52435                :::*                                104        620        584/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        618        584/avahi-daemon: r
    2025-12-22 16:45:22.998  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/21.png
    2025-12-22 16:45:23.005  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.windgusts_value with 11 km/h
    2025-12-22 16:45:23.025  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.rain_value with 0 mm
    2025-12-22 16:45:23.031  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.humidity_value with 97
    2025-12-22 16:45:23.036  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.pressure_value with 1028 mb
    2025-12-22 16:45:23.042  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.clouds_value with 0%
    2025-12-22 16:45:23.048  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.snowline_value with 2400 m
    2025-12-22 16:45:23.053  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.uv_index_value with 0
    2025-12-22 16:45:23.059  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.windchill_value with -5 °C
    2025-12-22 16:45:23.065  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.sunshineDuration with 8.58
    2025-12-22 16:45:23.070  - debug: daswetter.0 (247340) hourly forecast done
    2025-12-22 16:45:23.073  - debug: daswetter.0 (247340) exit, all done
    2025-12-22 16:45:23.073  - debug: daswetter.0 (247340) timer killed
    2025-12-22 16:45:23.074  - debug: daswetter.0 (247340) Plugin sentry destroyed
    2025-12-22 16:45:23.075  - info: daswetter.0 (247340) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2025-12-22 16:45:23.590  - info: daswetter.0 (247340) cleaned everything up...
    2025-12-22 16:45:23.614  - info: host.iobroker20 instance system.adapter.daswetter.0 having pid 247340 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-22 16:45:48.029  - info: host.iobroker20 instance system.adapter.dwd.0 in version "2.8.5" started with pid 247358
    2025-12-22 16:45:51.271  - info: dwd.0 (247358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.21.0, js-controller: 7.0.7
    2025-12-22 16:45:52.117  - info: dwd.0 (247358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-22 16:45:52.656  - info: host.iobroker20 instance system.adapter.dwd.0 having pid 247358 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-22 16:49:42.051  - info: admin.0 (225015) ==> Connected system.user.admin from ::ffff:192.168.178.167
    2025-12-22 16:49:51.228  - info: admin.0 (225015) ==> Connected system.user.admin from ::ffff:192.168.178.167
    2025-12-22 16:49:53.247  - info: admin.0 (225015) <== Disconnect system.user.admin from ::ffff:192.168.178.167
    2025-12-22 16:50:15.910  - info: mercedesme.0 (225860) No Data since 120 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 69
    @Karacho
    Setz die LogLevel runter. Oder debuggst du den gerade? Vermutlich nicht.
    • OliverIOO OliverIO
      @Karacho
      top bringt bei so etwas nur bedingt, da es eine augenblicksdarstellung ist
      aufgrund der 24h darstellung sind die ausschläge natürlich nicht so ganz klar.
      woher kommen die daten?
      sind die aus dem iobroker?
      evtl kannst du auch mal noch den gesamt ram verbrauch des kompletten systems tracken.
      ansonsten kann ich nur auf den üblichen verdächtigen verweisen:
      den javascript adapter
      da ist vor 23 uhr ein leichter anstieg mit einem heftigeren ausschlag beim admin-adapter und iobroker.
      den admin adapter kann ich mir nicht erklären. evtl weiß noch jemand, was den der admin so operativ den tag durch macht.
      eigentlich ist er ja nur dazu da einstellungen vorzunehmen?
      hattest du einen browser mit der admin ansicht offen?
      wenn sich so ein restart regelmäßig wiederholt ist das meist ein speicherproblem. ein oder mehrere skripte benötigen viel speicher und das betriebssystem entscheidet irgendwann dann mal den prozess neu zu starten. das könntest du dann auch mal im syslog des betriebssystems (bei linux) schauen. schlüsselwörter wären fatal oder error oder warn
      als nächstes müsstest du mal deine skripte durchschauen ob du da ein schedule oder cron drin hast, was zur uhrzeit passt. ggfs auch nochrmale wiederholungen beachten, bei denen sich dann ausgerechnet um 23 uhr mehrere treffen und dann das system in schwierigkeiten bringt.
      auch problematische javascript kann sogenannte memory leaks erzeugen, bei dem speicher geblockt wird aber nicht mehr freigegeben wird (meist bei setInterval/setTimeout, insbesondere dann wenn da was verschachtelt statt findet.)
      ggfs. wirst du skripte auch mal temporär deaktivieren müssen. alternativ können zusätzlich eingefügte logausgaben auch etwas mehr informationen liefern wann da was ausgeführt wird (vergrößert aber dann wieder die last auf das system und ggfs memory)
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      sagte in Automatidcher Reboot iobroker täglich:
      ich habe mal geschaut, was der admin adapter aktiv im hintergrund den so macht.
      er horcht auf alle objectchanges und auf ein paar wenige stateChange Ereignisse. stateChange betrtifft aber nur Sentry.
      Daher ist der Speicheranstieg des Admin-Adapters nur dadurch erklärbar, das zu diesem Zeitpunkt viele Datenpunktobjekte geändert werden (also nicht States, sondern das eigentliche Objekt)
      Leider gab es noch keine Antwort, ob der Browser mit dem Admin-Adapter offen war. wenn bspw das im Browser geöffnet war und sehr viel passiert, könnte es auch auf den Backend-Anteil des Adapters betreffen. Ist aber eher unwahrscheinlich, da der Frontend-Anteil der Adapter sich direkt vom jscontroller-Prozess informieren lassen.
      Evtl hilft das bei der Fehlersuche
      Meine Adapter und Widgets
      Links im Profil
      mcm1957M K 2 Antworten Letzte Antwort
      • K Karacho
        Neustarts sind unregelmässig:
        21.12. - 22:19Uhr
        20.12. - 22:17Uhr
        19.12. - 22:15Uhr
        Es staret jedes mal der iobroker neu als wenn ich einen
        iobroker restart
        durchführe
        @Karacho sagte in Automatidcher Reboot iobroker täglich:
        so unregelmäßig sind die gar nicht.
        entweder
        • Alle 24h +2min
          oder ggf.
        • x h:m nach Sonnenuntergang
        @OliverIO sagte in Automatidcher Reboot iobroker täglich:
        klar, aber nach ständigem Volllaufen des RAM über 3 Tage sähe der SWAP anders aus.
          entweder
          • Alle 24h +2min
            oder ggf.
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @Homoran sagte in Automatidcher Reboot iobroker täglich:
          Wenn der RAM nur temporär vollläuft und die Prozesse dann beendet werden, wird auch der Swap mit der Zeit wieder aufgeräumt bzw freigegeben.
          Links im Profil
            mcm1957M Offline
            mcm1957M Offline
            mcm1957
            Admin holt sich auch alle 24h die aktuellen NEWS und legt diese ggF als Notifications ab.
            Weiters aktualisisert admin im Intervall "config.autoUpdate" Stunden (default 24h) die Repositorydaten.
            Der Aktivitätspeak kann auch dadurch ausgelöst werden.
            Admin sollte diese Aktionen mit loglevel DEBUG loggen.
            Support Repositoryverwaltung.
            LESEN - gute Forenbeitrage
            • mcm1957M Offline
              mcm1957M Offline
              mcm1957
              Und - habs hier vielleicht überlesen - findet überhaupt ein RAM Überlauf statt? Wenn Linux da Prozesse killt, dann sollte das doch in System-Logs zu finden sein.
              Und steht denn auch gar nichts im ioBroker-Log wenn der js-controller restartet?
              EDIT:
              Wäre es bei Speicherknappheit nicht wahrscheinlich dass Linux irgendwelche Prozesse killt - und nicht jedesmal den js-controller aussucht? Wenn Linux da den Adapter xyz zuerst killt würde ja der js-controller mal überleben und das auch im ioBroker log loggen dass der Adapter gecrashed ist.
              • mcm1957M mcm1957
                EDIT:
                @mcm1957 sagte in Automatidcher Reboot iobroker täglich:
                Wie genau das 'out-of-memory'-Management funktioniert weiß ich gar nicht. Der sollte aber Einträge im journal hinterlassen. Muss man mal reinschauen.
                • K Karacho
                  21.12. - 22:19Uhr
                  20.12. - 22:17Uhr
                  19.12. - 22:15Uhr
                  iobroker restart
                  durchführe
                  Karacho
                  Von Info auf warn gestellt
                    Karacho
                    @OliverIO
                    Admin Adapter war nicht im Browser offen
                    • mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      @karacho
                      hast du hier schon mal das ioBroker Log rund um den js-controlelr neustart gepostet?
                      Also die letzten Minuten VOR und die NACH dem Restart des js-controllers?
                      Wenn nicht könntest du das mal tun.
                      • K Karacho
                        @OliverIO
                        @Karacho
                        Schau dir das jounal an. Am besten nur den entsprechenden Zeitraum +- 15 Minuten.
                        Geht so:
                        journalctl --since "2015-06-26 23:15:00" --until "2015-06-26 23:20:00"
                          Karacho
                          journalct:
                          pi@iobroker20:~ $ journalctl --since "2025-12-21 22:04:00" --until "2025-12-21 22:34:00"
                          Dec 21 22:16:18 iobroker20 bash[128091]: Send diag info: {"uuid":"34fe198a-1e58-0ca4-805f-5ba8bf90f8c2","language":"de","country":"Germany","hosts":[{"version":"7.0.7","platform":"Javascript/Node.js","type":"linux"}]>
                          Dec 21 22:16:19 iobroker20 sudo[224819]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
                          Dec 21 22:16:19 iobroker20 sudo[224819]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                          Dec 21 22:16:19 iobroker20 sudo[224819]: pam_unix(sudo:session): session closed for user root
                          Dec 21 22:16:20 iobroker20 sudo[224824]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                          Dec 21 22:16:20 iobroker20 sudo[224824]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                          Dec 21 22:16:21 iobroker20 sudo[224824]: pam_unix(sudo:session): session closed for user root
                          Dec 21 22:16:57 iobroker20 bash[128091]: Send diag info: {"uuid":"34fe198a-1e58-0ca4-805f-5ba8bf90f8c2","language":"de","country":"Germany","hosts":[{"version":"7.0.7","platform":"Javascript/Node.js","type":"linux"}]>
                          Dec 21 22:17:01 iobroker20 CRON[224858]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
                          Dec 21 22:17:01 iobroker20 CRON[224859]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
                          Dec 21 22:17:01 iobroker20 CRON[224858]: pam_unix(cron:session): session closed for user root
                          Dec 21 22:17:05 iobroker20 sudo[224871]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
                          Dec 21 22:17:05 iobroker20 sudo[224871]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                          Dec 21 22:17:05 iobroker20 sudo[224871]: pam_unix(sudo:session): session closed for user root
                          Dec 21 22:17:05 iobroker20 sudo[224876]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                          Dec 21 22:17:05 iobroker20 sudo[224876]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                          Dec 21 22:17:07 iobroker20 sudo[224876]: pam_unix(sudo:session): session closed for user root
                          Dec 21 22:17:13 iobroker20 kernel: io.hmip.0 invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
                          Dec 21 22:17:13 iobroker20 kernel: CPU: 1 UID: 1001 PID: 128556 Comm: io.hmip.0 Tainted: G         C         6.12.47+rpt-rpi-v8 #1  Debian 1:6.12.47-1+rpt1~bookworm
                          Dec 21 22:17:13 iobroker20 kernel: Tainted: [C]=CRAP
                          Dec 21 22:17:13 iobroker20 kernel: Hardware name: Raspberry Pi 4 Model B Rev 1.2 (DT)
                          Dec 21 22:17:13 iobroker20 kernel: Call trace:
                          Dec 21 22:17:13 iobroker20 kernel:  dump_backtrace+0xa0/0x100
                          Dec 21 22:17:13 iobroker20 kernel:  show_stack+0x20/0x38
                          Dec 21 22:17:13 iobroker20 kernel:  dump_stack_lvl+0x78/0x90
                          Dec 21 22:17:13 iobroker20 kernel:  dump_stack+0x18/0x28
                          Dec 21 22:17:13 iobroker20 kernel:  dump_header+0x44/0x1a8
                          Dec 21 22:17:13 iobroker20 kernel:  oom_kill_process+0x140/0x368
                          Dec 21 22:17:13 iobroker20 kernel:  out_of_memory+0xec/0x588
                          Dec 21 22:17:13 iobroker20 kernel:  __alloc_pages_noprof+0xaa0/0xdc8
                          Dec 21 22:17:13 iobroker20 kernel:  alloc_pages_mpol_noprof+0x60/0x158
                          Dec 21 22:17:13 iobroker20 kernel:  alloc_pages_noprof+0x58/0x98
                          Dec 21 22:17:13 iobroker20 kernel:  folio_alloc_noprof+0x1c/0x38
                          Dec 21 22:17:13 iobroker20 kernel:  filemap_alloc_folio_noprof+0x13c/0x158
                          Dec 21 22:17:13 iobroker20 kernel:  __filemap_get_folio+0x140/0x310
                          Dec 21 22:17:13 iobroker20 kernel:  filemap_fault+0x534/0x970
                          Dec 21 22:17:13 iobroker20 kernel:  __do_fault+0x44/0x148
                          Dec 21 22:17:13 iobroker20 kernel:  __handle_mm_fault+0x628/0xc58
                          Dec 21 22:17:13 iobroker20 kernel:  handle_mm_fault+0x188/0x2a0
                          Dec 21 22:17:13 iobroker20 kernel:  do_page_fault+0x104/0x548
                          Dec 21 22:17:13 iobroker20 kernel:  do_translation_fault+0xa4/0xc8
                          Dec 21 22:17:13 iobroker20 kernel:  do_mem_abort+0x4c/0xa8
                          Dec 21 22:17:13 iobroker20 kernel:  el0_ia+0x50/0xe8
                          Dec 21 22:17:13 iobroker20 kernel:  el0t_64_sync_handler+0xd0/0x130
                          Dec 21 22:17:13 iobroker20 kernel:  el0t_64_sync+0x190/0x198
                          Dec 21 22:17:13 iobroker20 kernel: Mem-Info:
                          Dec 21 22:17:13 iobroker20 kernel: active_anon:234589 inactive_anon:679128 isolated_anon:0
                                                              active_file:51 inactive_file:142 isolated_file:0
                                                              unevictable:0 dirty:114 writeback:0
                                                              slab_reclaimable:22441 slab_unreclaimable:9482
                                                              mapped:793 shmem:26 pagetables:5124
                                                              sec_pagetables:0 bounce:0
                                                              kernel_misc_reclaimable:0
                                                              free:4724 free_pcp:1189 free_cma:512
                          Dec 21 22:17:13 iobroker20 kernel: Node 0 active_anon:390732kB inactive_anon:1378928kB active_file:0kB inactive_file:460kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1568kB dirty:216kB writeback:0kB>
                          Dec 21 22:17:13 iobroker20 kernel: Node 1 active_anon:452660kB inactive_anon:1432548kB active_file:0kB inactive_file:308kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1604kB dirty:240kB writeback:0kB>
                          lines 1-56
                          • K Karacho
                            journalct:
                            lines 1-56
                            @Karacho
                            Da läuft die Ermittlung der Updates und die Übermittlung der Telemetrie an ioBroker.
                            Das ganze löst dann den oom-killer aus:
                              Karacho
                              Also definitiv RAM Problem?
                              Falls ja, wie kann ich weiter "runterschrauben"?
                              • K Karacho
                                Eher schwierig. Du hast da jetzt 30 Instanzen laufen, über den Daumen gepeilt benötigt jede Instanz um die 100MB RAM. Kommt noch das Basissystem hinzu und dann bist du im normalen Betrieb 'unter der Decke'. Kommen dann solche Dinge wie gerade gesehen hinzu muss ein aus Sicht des OS entbehrlicher Prozess über die Klinge springen.
                                Edit: Du kannst natürlich die Übermittlung der ioBroker-Statistik mal untersagen. Wo man die OS-Updates abstellt weiß ich aber gerade nicht.
                                • mcm1957M Offline
                                  mcm1957M Offline
                                  mcm1957
                                  Du könntest überlegen den compact mode zu aktivieren. Spart memory kann aber dazu führen dass ein Fehler in einem Adapter nicht nur dirsen crashen lässt. Obvdrr Adapter xx im compact mode stabil läuft musst du testen.
                                  Technisch läuft normalerweise jede Adapterinstanz inbeinem eigenen Prozess. Im compact Mode laufen alle oder einige Instanzenbgemeindamnin einem Prozess.
                                  Generell würd ich dir aber zu einem grösseren System raten
                                  • K Karacho
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    debug: daswetter
                                    debug ausschalten war gemeint
                                    • system.adapter.info.0
                                    der ist doch eh "abgekündigt", wofür genau benötigst du den noch bzw was fehlt dir, was iobroker nicht schon von Haus aus bietet?
                                    oder ggf wenn zufällig noch was brauchbares rumliegt, einen slave aufsetzen
