  4. Automatidcher Reboot iobroker täglich
    6.4k
45 Beiträge 9 Kommentatoren 3.1k Aufrufe 7 Beobachtet
  • K Karacho
    Hier noch einmal top
    login as: pi
    pi@192.168.178.71's password:
    Linux iobroker20 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookw        orm (2025-09-16) aarch64
    permitted by applicable law.
    Last login: Sun Dec 21 23:42:13 2025 from 192.168.178.167
    pi@iobroker20:~ $ top
    top - 15:52:11 up 3 days, 17:22,  1 user,  load average: 0.17, 0.38, 0.75
    Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.4 us,  1.6 sy,  0.0 ni, 85.4 id,  0.0 wa,  0.0 hi,  0.6 si,  0.0 st
    MiB Mem :   3795.9 total,    216.9 free,   2818.7 used,    864.0 buff/cache
    MiB Swap:    200.0 total,    184.8 free,     15.2 used.    977.1 avail Mem
        PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
     224889 iobroker  20   0   11.3g 405168  54368 S  23.8  10.4 234:17.33 iobroker.js-con
     225092 iobroker  20   0   11.2g 273024  53660 S  11.3   7.0  86:38.88 io.javascript.0
     245454 iobroker  20   0   10.9g 133492  54504 S   6.6   3.4   2:55.99 io.zendure-sola
     225406 iobroker  20   0   10.8g 125008  53448 S   5.6   3.2  66:29.22 io.sonoff.0
     225055 iobroker  20   0   11.0g 137472  48032 S   5.0   3.5  47:21.71 io.history.0
     225306 iobroker  20   0   10.8g 110092  47900 S   3.0   2.8   4:41.10 io.ems-esp.0
     225860 iobroker  20   0   11.0g 127960  49316 S   1.3   3.3   2:42.84 io.mercedesme.0
     225015 iobroker  20   0   21.1g 226676  56120 S   0.7   5.8   7:36.41 io.admin.0
         18 root      20   0       0      0      0 I   0.3   0.0   1:04.10 rcu_preempt
         99 root     -51   0       0      0      0 S   0.3   0.0   9:17.27 irq/40-mmc0
     225716 iobroker  20   0   11.0g 138956  54300 S   0.3   3.6   1:23.01 io.zigbee.0
     245558 root      20   0       0      0      0 I   0.3   0.0   0:01.84 kworker/0:1-events
     247029 pi        20   0   11716   5016   2820 R   0.3   0.1   0:00.13 top
          1 root      20   0  168552   7836   5532 S   0.0   0.2   0:38.21 systemd
          2 root      20   0       0      0      0 S   0.0   0.0   0:00.78 kthreadd
          3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
          4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kvfree_rcu_reclaim
          5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_gp
          6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-sync_wq
          7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_flushwq
          8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
         10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
         12 root      20   0       0      0      0 I   0.0   0.0   0:00.01 kworker/u16:0-netns
         13 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_percpu_wq
         14 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
         15 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
         16 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
         17 root      20   0       0      0      0 S   0.0   0.0   0:30.92 ksoftirqd/0
         19 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_exp_par_gp_kthread_worker/0
         20 root      20   0       0      0      0 S   0.0   0.0   0:00.01 rcu_exp_gp_kthread_worker
         21 root      rt   0       0      0      0 S   0.0   0.0   0:00.10 migration/0
         22 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
         23 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
         24 root      rt   0       0      0      0 S   0.0   0.0   0:00.08 migration/1
         25 root      20   0       0      0      0 S   0.0   0.0   0:17.64 ksoftirqd/1
         27 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @Karacho
    top bringt bei so etwas nur bedingt, da es eine augenblicksdarstellung ist
    aufgrund der 24h darstellung sind die ausschläge natürlich nicht so ganz klar.
    woher kommen die daten?
    sind die aus dem iobroker?
    evtl kannst du auch mal noch den gesamt ram verbrauch des kompletten systems tracken.
    ansonsten kann ich nur auf den üblichen verdächtigen verweisen:
    den javascript adapter
    da ist vor 23 uhr ein leichter anstieg mit einem heftigeren ausschlag beim admin-adapter und iobroker.
    den admin adapter kann ich mir nicht erklären. evtl weiß noch jemand, was den der admin so operativ den tag durch macht.
    eigentlich ist er ja nur dazu da einstellungen vorzunehmen?
    hattest du einen browser mit der admin ansicht offen?
    wenn sich so ein restart regelmäßig wiederholt ist das meist ein speicherproblem. ein oder mehrere skripte benötigen viel speicher und das betriebssystem entscheidet irgendwann dann mal den prozess neu zu starten. das könntest du dann auch mal im syslog des betriebssystems (bei linux) schauen. schlüsselwörter wären fatal oder error oder warn
    als nächstes müsstest du mal deine skripte durchschauen ob du da ein schedule oder cron drin hast, was zur uhrzeit passt. ggfs auch nochrmale wiederholungen beachten, bei denen sich dann ausgerechnet um 23 uhr mehrere treffen und dann das system in schwierigkeiten bringt.
    auch problematische javascript kann sogenannte memory leaks erzeugen, bei dem speicher geblockt wird aber nicht mehr freigegeben wird (meist bei setInterval/setTimeout, insbesondere dann wenn da was verschachtelt statt findet.)
    ggfs. wirst du skripte auch mal temporär deaktivieren müssen. alternativ können zusätzlich eingefügte logausgaben auch etwas mehr informationen liefern wann da was ausgeführt wird (vergrößert aber dann wieder die last auf das system und ggfs memory)
    Meine Adapter und Widgets
    Links im Profil
      @Karacho sagte in Automatidcher Reboot iobroker täglich:
      up 3 days
      passt nicht zu
      um 23 Uhr war ein Neustart
      oder vor 3 Tagen 23:00?
      Auf jeden Fall ist nach 3 Tagen+
      nicht besorgniserregend
      Karacho
      @Homoran
      Jetzt 15:50Uhr
      PAsst aber zu dem heri:
        @Karacho
        Haste jetzt aufgeräumt? Zeig nochmal die Ausgabe von
        iob diag
        Karacho
        @Thomas-Braun ```
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: iobroker20
               Icon name: computer
                  Kernel: Linux 6.12.47+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         16:49:19 up 3 days, 18:19,  2 users,  load average: 1.52, 1.22, 0.87
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-12-22 16:49:19 CET
                   Universal time: Mon 2025-12-22 15:49:19 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            4.0G        3.0G        224M        266K        831M        946M
        Swap:           209M         15M        193M
        Total:          4.2G        3.0G        417M
        Active iob-Instances:   30
                 3795 M total memory
                 2893 M used memory
                 1007 M active memory
                 2315 M inactive memory
                  213 M free memory
                   70 M buffer memory
                  722 M swap cache
                  199 M total swap
                   15 M used swap
                  184 M free swap
        top - 16:49:20 up 3 days, 18:19,  2 users,  load average: 1.56, 1.23, 0.88
        Tasks: 208 total,   3 running, 205 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 50.0 us, 25.0 sy,  0.0 ni, 25.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.9 total,    211.5 free,   2895.5 used,    792.6 buff/cache
        MiB Swap:    200.0 total,    184.8 free,     15.2 used.    900.4 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     760M  1.2M  759M   1% /run
        /dev/sda2      ext4      220G   16G  195G   8% /
        tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
        /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Thu Dec 18 22:29:54 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=adc78390-02 rootfstype=ext4 fsck.repair=yes rootwait
        [Thu Dec 18 22:29:56 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f-a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
        [Thu Dec 18 22:29:57 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-318060e7e0ab r/w.
        Show mounted filesystems:
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime,commit=600
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.5G    /var/
        668M    /var/log
        667M    /var/log/journal/7b7fe4cfb66842c09a3cb98b578c9b66
        416M    /var/cache
        Archived and active journals take up 666.5M in the file system.
        /opt/iobroker/backups:
        3.4M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        7.2G    /opt/iobroker/iobroker-data/
        6.8G    /opt/iobroker/iobroker-data/history
        319M    /opt/iobroker/iobroker-data/files
        120M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        52M     /opt/iobroker/iobroker-data/history/20250306/history.0_userdata.0.Energie_Bezug_Netz.json
        52M     /opt/iobroker/iobroker-data/history/20250302/history.0_userdata.0.Energie_Bezug_Netz.json
        52M     /opt/iobroker/iobroker-data/history/20250301/history.0_userdata.0.Energie_Bezug_Netz.json
        52M     /opt/iobroker/iobroker-data/history/20250210/history.0_userdata.0.Energie_Bezug_Netz.json
        45M     /opt/iobroker/iobroker-data/history/20250309/history.0_userdata.0.Energie_Bezug_Netz.json
        USB-Devices by-id:
        /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
        *** ZigBee Settings ***
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.21.0
        /usr/bin/node           v22.21.0
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.21.0-1nodesource1
          Candidate: 22.21.0-1nodesource1
          Version table:
         *** 22.21.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main arm64 Packages
                500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker20          iobroker20 (version: 7.0.7, hostname: iobroker20    , alive, uptime: 66716)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.19
        javascript:     9.0.11
        nodejs modules from github:     3
        +-- iobroker.hoymiles-wifi@0.1.1 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#83ba7640e6a73dc4ee4788b055318e1cfc58bc0f)
        +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#45f4994af57a0f6f06e308d0c6d7961bc49d27a5)
        +-- iobroker.pv-power-control@0.1.0 (git+ssh://git@github.com/Newan/ioBroker.pv-power-control.git#48203f8ba437503e209138af7f80acac953f7e7c)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker20                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker20                               -  enabled
        + system.adapter.bmw.0                    : bmw                   : iobroker20                               -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : iobroker20                               -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker20                               -  enabled
          system.adapter.daswetter.0              : daswetter             : iobroker20                               -  enabled
          system.adapter.devices.0                : devices               : iobroker20                               - disabled
        + system.adapter.deyeidc.0                : deyeidc               : iobroker20                               -  enabled, port: 8899
          system.adapter.discovery.0              : discovery             : iobroker20                               - disabled
          system.adapter.dwd.0                    : dwd                   : iobroker20                               -  enabled
        + system.adapter.easee.0                  : easee                 : iobroker20                               -  enabled
        + system.adapter.ems-esp.0                : ems-esp               : iobroker20                               -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker20                               -  enabled
          system.adapter.flot.0                   : flot                  : iobroker20                               - disabled
        + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker20                               -  enabled
        + system.adapter.history.0                : history               : iobroker20                               -  enabled
        + system.adapter.hmip.0                   : hmip                  : iobroker20                               -  enabled
        + system.adapter.homeconnect.0            : homeconnect           : iobroker20                               -  enabled
          system.adapter.hs100.0                  : hs100                 : iobroker20                               - disabled
          system.adapter.ical.0                   : ical                  : iobroker20                               -  enabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker20                               - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker20                               -  enabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker20                               -  enabled
        + system.adapter.info.0                   : info                  : iobroker20                               -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker20                               -  enabled
        + system.adapter.mercedesme.0             : mercedesme            : iobroker20                               -  enabled
          system.adapter.midea.0                  : midea                 : iobroker20                               - disabled
        + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker20                               -  enabled, port: 54321
        + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker20                               -  enabled, port: 54321
        + system.adapter.nuki-extended.0          : nuki-extended         : iobroker20                               -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker20                               -  enabled
          system.adapter.rpi2.0                   : rpi2                  : iobroker20                               - disabled
          system.adapter.scenes.0                 : scenes                : iobroker20                               - disabled
        + system.adapter.shelly.0                 : shelly                : iobroker20                               -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker20                               - disabled
          system.adapter.smartgarden.0            : smartgarden           : iobroker20                               - disabled
        + system.adapter.solarlog.0               : solarlog              : iobroker20                               -  enabled, port: 80
        + system.adapter.sonoff.0                 : sonoff                : iobroker20                               -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.trashschedule.0          : trashschedule         : iobroker20                               -  enabled
        + system.adapter.tuya.0                   : tuya                  : iobroker20                               -  enabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker20                               - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker20                               - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker20                               - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker20                               - disabled
          system.adapter.vis.0                    : vis                   : iobroker20                               -  enabled
        + system.adapter.web.1                    : web                   : iobroker20                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.worx.0                   : worx                  : iobroker20                               - disabled
        + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : iobroker20                               -  enabled
        + system.adapter.zendure-solarflow.0      : zendure-solarflow     : iobroker20                               -  enabled
        + system.adapter.zigbee.0                 : zigbee                : iobroker20                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
        + instance is alive
        ioBroker-Repositories
        │ (index) │ name               │ url                                                     │ auto upgrade │
        │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
        │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
        Upgrade policy: none
        Installed ioBroker-Adapters
        Adapter    "admin"        : 7.7.19   , installed 7.7.19
        Adapter    "backitup"     : 3.3.10   , installed 3.3.10
        Adapter    "bmw"          : 4.3.1    , installed 4.3.1
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
        Adapter    "devices"      : 1.2.8    , installed 1.2.8
        Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
        Adapter    "easee"        : 1.0.10   , installed 1.0.10
        Adapter    "ems-esp"      : 6.0.1    , installed 6.0.2
        Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
        Adapter    "espresense"   : 0.6.3    , installed 0.6.3
        Adapter    "heatingcontrol": 2.12.19 , installed 2.12.19
        Adapter    "hmip"         : 1.27.0   , installed 1.27.0
        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
        Adapter    "hs100"        : 3.0.5    , installed 3.0.5
        Adapter    "ical"         : 1.18.1   , installed 1.18.1
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
        Adapter    "javascript"   : 9.0.11   , installed 9.0.11
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "midea"        : 0.0.7    , installed 0.0.7
        Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
        Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
        Adapter    "pushover"     : 4.1.0    , installed 4.1.0
        Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "shelly"       : 10.4.1   , installed 10.4.1
        Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
        Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
        Adapter    "solarlog"     : 2.4.0    , installed 2.4.0
        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "worx"         : 3.2.7    , installed 3.2.7
        Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
        Adapter    "zendure-solarflow": 3.1.1, installed 3.1.1
        Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
        Objects and States
        Objects:        16381
        States:         13902
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1265363    225406/io.sonoff.0
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1265653    225786/io.shelly.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1263950    224889/iobroker.js-
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1264641    224889/iobroker.js-
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          733        714/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1287748    228691/io.web.1
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1264204    225015/io.admin.0
        tcp6       0      0 :::51989                :::*                    LISTEN      1001       1287108    228669/io.nuki-exte
        tcp6       0      0 :::22                   :::*                    LISTEN      0          735        714/sshd: /usr/sbin
        udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1266865    225479/io.mihome-va
        udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       1292546    229348/io.mihome-va
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1267062    225793/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1267063    225793/io.tuya.0
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1324546    232832/io.broadlink
        udp        0      0 0.0.0.0:60459           0.0.0.0:*                           1001       1324549    232832/io.broadlink
        udp        0      0 0.0.0.0:48344           0.0.0.0:*                           1001       1322960    232832/io.broadlink
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        617        584/avahi-daemon: r
        udp        0      0 0.0.0.0:34184           0.0.0.0:*                           104        619        584/avahi-daemon: r
        udp6       0      0 fe80::93ff:a0e8:a30:546 :::*                                0          5724       627/NetworkManager
        udp6       0      0 :::52435                :::*                                104        620        584/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        618        584/avahi-daemon: r
        2025-12-22 16:45:22.998  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.windIconURL with /adapter/daswetter/icons/viento-wind/Beaufort-White/21.png
        2025-12-22 16:45:23.005  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.windgusts_value with 11 km/h
        2025-12-22 16:45:23.025  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.rain_value with 0 mm
        2025-12-22 16:45:23.031  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.humidity_value with 97
        2025-12-22 16:45:23.036  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.pressure_value with 1028 mb
        2025-12-22 16:45:23.042  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.clouds_value with 0%
        2025-12-22 16:45:23.048  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.snowline_value with 2400 m
        2025-12-22 16:45:23.053  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.uv_index_value with 0
        2025-12-22 16:45:23.059  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.Hour_8.windchill_value with -5 °C
        2025-12-22 16:45:23.065  - debug: daswetter.0 (247340) insert NextHours.Location_1.Day_5.sunshineDuration with 8.58
        2025-12-22 16:45:23.070  - debug: daswetter.0 (247340) hourly forecast done
        2025-12-22 16:45:23.073  - debug: daswetter.0 (247340) exit, all done
        2025-12-22 16:45:23.073  - debug: daswetter.0 (247340) timer killed
        2025-12-22 16:45:23.074  - debug: daswetter.0 (247340) Plugin sentry destroyed
        2025-12-22 16:45:23.075  - info: daswetter.0 (247340) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
        2025-12-22 16:45:23.590  - info: daswetter.0 (247340) cleaned everything up...
        2025-12-22 16:45:23.614  - info: host.iobroker20 instance system.adapter.daswetter.0 having pid 247340 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-12-22 16:45:48.029  - info: host.iobroker20 instance system.adapter.dwd.0 in version "2.8.5" started with pid 247358
        2025-12-22 16:45:51.271  - info: dwd.0 (247358) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.21.0, js-controller: 7.0.7
        2025-12-22 16:45:52.117  - info: dwd.0 (247358) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-12-22 16:45:52.656  - info: host.iobroker20 instance system.adapter.dwd.0 having pid 247358 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-12-22 16:49:42.051  - info: admin.0 (225015) ==> Connected system.user.admin from ::ffff:192.168.178.167
        2025-12-22 16:49:51.228  - info: admin.0 (225015) ==> Connected system.user.admin from ::ffff:192.168.178.167
        2025-12-22 16:49:53.247  - info: admin.0 (225015) <== Disconnect system.user.admin from ::ffff:192.168.178.167
        2025-12-22 16:50:15.910  - info: mercedesme.0 (225860) No Data since 120 seconds. Lost WebSocket connection. Reconnect WebSocket. Reconnects Today: 69
          Karacho
          Neustarts sind unregelmässig:
          21.12. - 22:19Uhr
          20.12. - 22:17Uhr
          19.12. - 22:15Uhr
          Es staret jedes mal der iobroker neu als wenn ich einen
          iobroker restart
          durchführe
          HomoranH K 2 Antworten Letzte Antwort
          • K Karacho
            @Thomas-Braun ```
            Script v.2025-08-09
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64 bit
            CPU threads: 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Display-Manager:
            Desktop:
            Session:                tty
            *** MEMORY ***
            Swap:           209M         15M        193M
                     3795 M total memory
                     2893 M used memory
                      213 M free memory
                       70 M buffer memory
                      722 M swap cache
                      199 M total swap
                       15 M used swap
                      184 M free swap
            *** FILESYSTEM ***
            /var:
            1.5G    /var/
            668M    /var/log
            416M    /var/cache
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.4
            /usr/bin/npx            10.9.4
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.7.19
            javascript:     9.0.11
            Adapter State
            + instance is alive
            Objects and States
            Objects:        16381
            States:         13902
            Pending Updates: 0
            @Karacho
            Setz die LogLevel runter. Oder debuggst du den gerade? Vermutlich nicht.
            • OliverIOO OliverIO
              @Karacho
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              ich habe mal geschaut, was der admin adapter aktiv im hintergrund den so macht.
              er horcht auf alle objectchanges und auf ein paar wenige stateChange Ereignisse. stateChange betrtifft aber nur Sentry.
              Daher ist der Speicheranstieg des Admin-Adapters nur dadurch erklärbar, das zu diesem Zeitpunkt viele Datenpunktobjekte geändert werden (also nicht States, sondern das eigentliche Objekt)
              Leider gab es noch keine Antwort, ob der Browser mit dem Admin-Adapter offen war. wenn bspw das im Browser geöffnet war und sehr viel passiert, könnte es auch auf den Backend-Anteil des Adapters betreffen. Ist aber eher unwahrscheinlich, da der Frontend-Anteil der Adapter sich direkt vom jscontroller-Prozess informieren lassen.
              Evtl hilft das bei der Fehlersuche
              Links im Profil
              mcm1957M K 2 Antworten Letzte Antwort
              • K Karacho
                21.12. - 22:19Uhr
                20.12. - 22:17Uhr
                19.12. - 22:15Uhr
                iobroker restart
                durchführe
                so unregelmäßig sind die gar nicht.
                entweder
                • Alle 24h +2min
                  oder ggf.
                • x h:m nach Sonnenuntergang
                @OliverIO sagte in Automatidcher Reboot iobroker täglich:
                klar, aber nach ständigem Volllaufen des RAM über 3 Tage sähe der SWAP anders aus.
                  entweder
                  • Alle 24h +2min
                    oder ggf.
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @Homoran sagte in Automatidcher Reboot iobroker täglich:
                  Wenn der RAM nur temporär vollläuft und die Prozesse dann beendet werden, wird auch der Swap mit der Zeit wieder aufgeräumt bzw freigegeben.
                  Links im Profil
                    mcm1957M Offline
                    mcm1957M Offline
                    mcm1957
                    Admin holt sich auch alle 24h die aktuellen NEWS und legt diese ggF als Notifications ab.
                    Weiters aktualisisert admin im Intervall "config.autoUpdate" Stunden (default 24h) die Repositorydaten.
                    Der Aktivitätspeak kann auch dadurch ausgelöst werden.
                    Admin sollte diese Aktionen mit loglevel DEBUG loggen.
                    Support Repositoryverwaltung.
                    LESEN - gute Forenbeitrage
                    • mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      Und - habs hier vielleicht überlesen - findet überhaupt ein RAM Überlauf statt? Wenn Linux da Prozesse killt, dann sollte das doch in System-Logs zu finden sein.
                      Und steht denn auch gar nichts im ioBroker-Log wenn der js-controller restartet?
                      EDIT:
                      Wäre es bei Speicherknappheit nicht wahrscheinlich dass Linux irgendwelche Prozesse killt - und nicht jedesmal den js-controller aussucht? Wenn Linux da den Adapter xyz zuerst killt würde ja der js-controller mal überleben und das auch im ioBroker log loggen dass der Adapter gecrashed ist.
                      • mcm1957M mcm1957
                        EDIT:
                        @mcm1957 sagte in Automatidcher Reboot iobroker täglich:
                        Wie genau das 'out-of-memory'-Management funktioniert weiß ich gar nicht. Der sollte aber Einträge im journal hinterlassen. Muss man mal reinschauen.
                        • K Karacho
                          21.12. - 22:19Uhr
                          20.12. - 22:17Uhr
                          19.12. - 22:15Uhr
                          iobroker restart
                          durchführe
                          Karacho
                          Von Info auf warn gestellt
                            Karacho
                            @OliverIO
                            Admin Adapter war nicht im Browser offen
                            • mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @karacho
                              hast du hier schon mal das ioBroker Log rund um den js-controlelr neustart gepostet?
                              Also die letzten Minuten VOR und die NACH dem Restart des js-controllers?
                              Wenn nicht könntest du das mal tun.
                              • K Karacho
                                @OliverIO
                                @Karacho
                                Schau dir das jounal an. Am besten nur den entsprechenden Zeitraum +- 15 Minuten.
                                Geht so:
                                journalctl --since "2015-06-26 23:15:00" --until "2015-06-26 23:20:00"
                                  Karacho
                                  journalct:
                                  pi@iobroker20:~ $ journalctl --since "2025-12-21 22:04:00" --until "2025-12-21 22:34:00"
                                  Dec 21 22:16:18 iobroker20 bash[128091]: Send diag info: {"uuid":"34fe198a-1e58-0ca4-805f-5ba8bf90f8c2","language":"de","country":"Germany","hosts":[{"version":"7.0.7","platform":"Javascript/Node.js","type":"linux"}]>
                                  Dec 21 22:16:19 iobroker20 sudo[224819]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
                                  Dec 21 22:16:19 iobroker20 sudo[224819]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                  Dec 21 22:16:19 iobroker20 sudo[224819]: pam_unix(sudo:session): session closed for user root
                                  Dec 21 22:16:20 iobroker20 sudo[224824]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                                  Dec 21 22:16:20 iobroker20 sudo[224824]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                  Dec 21 22:16:21 iobroker20 sudo[224824]: pam_unix(sudo:session): session closed for user root
                                  Dec 21 22:16:57 iobroker20 bash[128091]: Send diag info: {"uuid":"34fe198a-1e58-0ca4-805f-5ba8bf90f8c2","language":"de","country":"Germany","hosts":[{"version":"7.0.7","platform":"Javascript/Node.js","type":"linux"}]>
                                  Dec 21 22:17:01 iobroker20 CRON[224858]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
                                  Dec 21 22:17:01 iobroker20 CRON[224859]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
                                  Dec 21 22:17:01 iobroker20 CRON[224858]: pam_unix(cron:session): session closed for user root
                                  Dec 21 22:17:05 iobroker20 sudo[224871]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt -v
                                  Dec 21 22:17:05 iobroker20 sudo[224871]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                  Dec 21 22:17:05 iobroker20 sudo[224871]: pam_unix(sudo:session): session closed for user root
                                  Dec 21 22:17:05 iobroker20 sudo[224876]: iobroker : PWD=/ ; USER=root ; COMMAND=/usr/bin/apt list --upgradeable
                                  Dec 21 22:17:05 iobroker20 sudo[224876]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
                                  Dec 21 22:17:07 iobroker20 sudo[224876]: pam_unix(sudo:session): session closed for user root
                                  Dec 21 22:17:13 iobroker20 kernel: io.hmip.0 invoked oom-killer: gfp_mask=0x140cca(GFP_HIGHUSER_MOVABLE|__GFP_COMP), order=0, oom_score_adj=0
                                  Dec 21 22:17:13 iobroker20 kernel: CPU: 1 UID: 1001 PID: 128556 Comm: io.hmip.0 Tainted: G         C         6.12.47+rpt-rpi-v8 #1  Debian 1:6.12.47-1+rpt1~bookworm
                                  Dec 21 22:17:13 iobroker20 kernel: Tainted: [C]=CRAP
                                  Dec 21 22:17:13 iobroker20 kernel: Hardware name: Raspberry Pi 4 Model B Rev 1.2 (DT)
                                  Dec 21 22:17:13 iobroker20 kernel: Call trace:
                                  Dec 21 22:17:13 iobroker20 kernel:  dump_backtrace+0xa0/0x100
                                  Dec 21 22:17:13 iobroker20 kernel:  show_stack+0x20/0x38
                                  Dec 21 22:17:13 iobroker20 kernel:  dump_stack_lvl+0x78/0x90
                                  Dec 21 22:17:13 iobroker20 kernel:  dump_stack+0x18/0x28
                                  Dec 21 22:17:13 iobroker20 kernel:  dump_header+0x44/0x1a8
                                  Dec 21 22:17:13 iobroker20 kernel:  oom_kill_process+0x140/0x368
                                  Dec 21 22:17:13 iobroker20 kernel:  out_of_memory+0xec/0x588
                                  Dec 21 22:17:13 iobroker20 kernel:  __alloc_pages_noprof+0xaa0/0xdc8
                                  Dec 21 22:17:13 iobroker20 kernel:  alloc_pages_mpol_noprof+0x60/0x158
                                  Dec 21 22:17:13 iobroker20 kernel:  alloc_pages_noprof+0x58/0x98
                                  Dec 21 22:17:13 iobroker20 kernel:  folio_alloc_noprof+0x1c/0x38
                                  Dec 21 22:17:13 iobroker20 kernel:  filemap_alloc_folio_noprof+0x13c/0x158
                                  Dec 21 22:17:13 iobroker20 kernel:  __filemap_get_folio+0x140/0x310
                                  Dec 21 22:17:13 iobroker20 kernel:  filemap_fault+0x534/0x970
                                  Dec 21 22:17:13 iobroker20 kernel:  __do_fault+0x44/0x148
                                  Dec 21 22:17:13 iobroker20 kernel:  __handle_mm_fault+0x628/0xc58
                                  Dec 21 22:17:13 iobroker20 kernel:  handle_mm_fault+0x188/0x2a0
                                  Dec 21 22:17:13 iobroker20 kernel:  do_page_fault+0x104/0x548
                                  Dec 21 22:17:13 iobroker20 kernel:  do_translation_fault+0xa4/0xc8
                                  Dec 21 22:17:13 iobroker20 kernel:  do_mem_abort+0x4c/0xa8
                                  Dec 21 22:17:13 iobroker20 kernel:  el0_ia+0x50/0xe8
                                  Dec 21 22:17:13 iobroker20 kernel:  el0t_64_sync_handler+0xd0/0x130
                                  Dec 21 22:17:13 iobroker20 kernel:  el0t_64_sync+0x190/0x198
                                  Dec 21 22:17:13 iobroker20 kernel: Mem-Info:
                                  Dec 21 22:17:13 iobroker20 kernel: active_anon:234589 inactive_anon:679128 isolated_anon:0
        active_file:51 inactive_file:142 isolated_file:0
        unevictable:0 dirty:114 writeback:0
        slab_reclaimable:22441 slab_unreclaimable:9482
        mapped:793 shmem:26 pagetables:5124
        sec_pagetables:0 bounce:0
        kernel_misc_reclaimable:0
        free:4724 free_pcp:1189 free_cma:512
                                  Dec 21 22:17:13 iobroker20 kernel: Node 0 active_anon:390732kB inactive_anon:1378928kB active_file:0kB inactive_file:460kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1568kB dirty:216kB writeback:0kB>
                                  Dec 21 22:17:13 iobroker20 kernel: Node 1 active_anon:452660kB inactive_anon:1432548kB active_file:0kB inactive_file:308kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:1604kB dirty:240kB writeback:0kB>
                                  lines 1-56
                                  • K Karacho
                                    journalct:
                                    lines 1-56
                                    @Karacho
                                    Da läuft die Ermittlung der Updates und die Übermittlung der Telemetrie an ioBroker.
                                    Das ganze löst dann den oom-killer aus:
                                      Karacho
                                      Also definitiv RAM Problem?
                                      Falls ja, wie kann ich weiter "runterschrauben"?
                                      • K Karacho
                                        Eher schwierig. Du hast da jetzt 30 Instanzen laufen, über den Daumen gepeilt benötigt jede Instanz um die 100MB RAM. Kommt noch das Basissystem hinzu und dann bist du im normalen Betrieb 'unter der Decke'. Kommen dann solche Dinge wie gerade gesehen hinzu muss ein aus Sicht des OS entbehrlicher Prozess über die Klinge springen.
                                        Edit: Du kannst natürlich die Übermittlung der ioBroker-Statistik mal untersagen. Wo man die OS-Updates abstellt weiß ich aber gerade nicht.
                                        • mcm1957M Offline
                                          mcm1957M Offline
                                          mcm1957
                                          Du könntest überlegen den compact mode zu aktivieren. Spart memory kann aber dazu führen dass ein Fehler in einem Adapter nicht nur dirsen crashen lässt. Obvdrr Adapter xx im compact mode stabil läuft musst du testen.
                                          Technisch läuft normalerweise jede Adapterinstanz inbeinem eigenen Prozess. Im compact Mode laufen alle oder einige Instanzenbgemeindamnin einem Prozess.
                                          Generell würd ich dir aber zu einem grösseren System raten
