Automatidcher Reboot iobroker täglich
es ist wir ein Neustartedes iobroker,. Dh alle Instanzen starten auch neuiob diag:
```bash Script v.2025-08-09 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 12 (bookworm) Static hostname: iobroker20 Icon name: computer Kernel: Linux 6.12.47+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.2 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 21:49:58 up 3 days, 12:49, 2 users, load average: 2.07, 2.17, 1.60 CPU threads: 4 *** LIFE CYCLE STATUS *** Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Thu 2025-12-18 21:49:58 CET Universal time: Thu 2025-12-18 20:49:58 UTC RTC time: n/a Time zone: Europe/Berlin (CET, +0100) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': pi HOME=/home/pi GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne tdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 3.4G 337M 204K 399M 619M Swap: 209M 100M 109M Total: 4.2G 3.5G 446M Active iob-Instances: 38 3795 M total memory 3205 M used memory 1514 M active memory 1705 M inactive memory 321 M free memory 35 M buffer memory 345 M swap cache 199 M total swap 95 M used swap 104 M free swap *** top - Table Of Processes *** top - 21:49:59 up 3 days, 12:49, 2 users, load average: 2.07, 2.17, 1.60 Tasks: 223 total, 1 running, 222 sleeping, 0 stopped, 0 zombie %Cpu(s): 12.5 us, 12.5 sy, 0.0 ni, 62.5 id, 12.5 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3795.9 total, 320.4 free, 3205.8 used, 381.0 buff/cache MiB Swap: 200.0 total, 104.4 free, 95.6 used. 590.1 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 760M 1.2M 759M 1% /run /dev/sda2 ext4 220G 16G 195G 8% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/sda1 vfat 510M 66M 445M 13% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Mon Dec 15 09:00:49 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nv me.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm i=1 snd_bcm2835.enable_hdmi=0 numa=fake=2 system_heap.max_order=0 smsc95xx.maca ddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 con sole=ttyS0,115200 console=tty1 root=PARTUUID=adc78390-02 rootfstype=ext4 fsck.re pair=yes rootwait [Mon Dec 15 09:00:52 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f -a244-318060e7e0ab ro with ordered data mode. Quota mode: none. [Mon Dec 15 09:00:53 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-31 8060e7e0ab r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda2 ext4 rw,noatime,commit=600 `-/boot/firmware /dev/sda1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437 ,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 1.5G /var/ 668M /var/log 667M /var/log/journal/7b7fe4cfb66842c09a3cb98b578c9b66 667M /var/log/journal 416M /var/cache Archived and active journals take up 666.5M in the file system. /opt/iobroker/backups: 3.4M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 7.2G /opt/iobroker/iobroker-data/ 6.8G /opt/iobroker/iobroker-data/history 320M /opt/iobroker/iobroker-data/files 121M /opt/iobroker/iobroker-data/backup-objects 78M /opt/iobroker/iobroker-data/files/icons-open-icon-library-png The five largest files in iobroker-data are: 52M /opt/iobroker/iobroker-data/history/20250306/history.0_userdata.0.Energie_Bezug_Netz.json 52M /opt/iobroker/iobroker-data/history/20250302/history.0_userdata.0.Energie_Bezug_Netz.json 52M /opt/iobroker/iobroker-data/history/20250301/history.0_userdata.0.Energie_Bezug_Netz.json 52M /opt/iobroker/iobroker-data/history/20250210/history.0_userdata.0.Energie_Bezug_Netz.json 45M /opt/iobroker/iobroker-data/history/20250309/history.0_userdata.0.Energie_Bezug_Netz.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0 *** ZigBee Settings *** Your zigbee.0 COM-Port is matching 'by-id'. Very good! Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v22.21.0 /usr/bin/node v22.21.0 /usr/bin/npm 10.9.4 /usr/bin/npx 10.9.4 /usr/bin/corepack 0.34.0 nodejs: Installed: 22.21.0-1nodesource1 Candidate: 22.21.0-1nodesource1 Version table: *** 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 18.20.4+dfsg-1~deb12u1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker20 iobroker20 (version: 7.0.7, hostname: iobroker20 , alive, uptime: 42970) Core adapters versions js-controller: 7.0.7 admin: 7.7.19 javascript: 9.0.11 nodejs modules from github: 3 +-- iobroker.hoymiles-wifi@0.1.1 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#83ba7640e6a73dc4ee4788b055318e1cfc58bc0f) +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#45f4994af57a0f6f06e308d0c6d7961bc49d27a5) +-- iobroker.pv-power-control@0.1.0 (git+ssh://git@github.com/Newan/ioBroker.pv-power-control.git#48203f8ba437503e209138af7f80acac953f7e7c) Adapter State + system.adapter.admin.0 : admin : iobroker20 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker20 - enabled + system.adapter.bmw.0 : bmw : iobroker20 - enabled + system.adapter.broadlink2.0 : broadlink2 : iobroker20 - enabled + system.adapter.cloud.0 : cloud : iobroker20 - enabled system.adapter.daswetter.0 : daswetter : iobroker20 - enabled system.adapter.devices.0 : devices : iobroker20 - disabled + system.adapter.deyeidc.0 : deyeidc : iobroker20 - enabled, port: 8899 + system.adapter.discovery.0 : discovery : iobroker20 - enabled system.adapter.dwd.0 : dwd : iobroker20 - enabled + system.adapter.easee.0 : easee : iobroker20 - enabled + system.adapter.ems-esp.0 : ems-esp : iobroker20 - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker20 - enabled system.adapter.flot.0 : flot : iobroker20 - disabled + system.adapter.harmony.0 : harmony : iobroker20 - enabled + system.adapter.heatingcontrol.0 : heatingcontrol : iobroker20 - enabled + system.adapter.history.0 : history : iobroker20 - enabled + system.adapter.hmip.0 : hmip : iobroker20 - enabled + system.adapter.homeconnect.0 : homeconnect : iobroker20 - enabled system.adapter.hs100.0 : hs100 : iobroker20 - disabled system.adapter.ical.0 : ical : iobroker20 - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker20 - disabled system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker20 - enabled system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker20 - enabled + system.adapter.info.0 : info : iobroker20 - enabled + system.adapter.javascript.0 : javascript : iobroker20 - enabled + system.adapter.meater.0 : meater : iobroker20 - enabled + system.adapter.mercedesme.0 : mercedesme : iobroker20 - enabled system.adapter.midea.0 : midea : iobroker20 - disabled + system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker20 - enabled, port: 54321 + system.adapter.mihome-vacuum.1 : mihome-vacuum : iobroker20 - enabled, port: 54321 + system.adapter.nuki-extended.0 : nuki-extended : iobroker20 - enabled + system.adapter.pushover.0 : pushover : iobroker20 - enabled + system.adapter.rpi2.0 : rpi2 : iobroker20 - enabled + system.adapter.scenes.0 : scenes : iobroker20 - enabled + system.adapter.shelly.0 : shelly : iobroker20 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shuttercontrol.0 : shuttercontrol : iobroker20 - enabled + system.adapter.smartgarden.0 : smartgarden : iobroker20 - enabled + system.adapter.solarlog.0 : solarlog : iobroker20 - enabled, port: 80 + system.adapter.sonoff.0 : sonoff : iobroker20 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.trashschedule.0 : trashschedule : iobroker20 - enabled + system.adapter.tuya.0 : tuya : iobroker20 - enabled system.adapter.vis-icontwo.0 : vis-icontwo : iobroker20 - disabled system.adapter.vis-justgage.0 : vis-justgage : iobroker20 - disabled system.adapter.vis-rgraph.0 : vis-rgraph : iobroker20 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker20 - disabled system.adapter.vis.0 : vis : iobroker20 - enabled + system.adapter.web.1 : web : iobroker20 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.worx.0 : worx : iobroker20 - enabled + system.adapter.yahoo-stock-market.0 : yahoo-stock-market : iobroker20 - enabled + system.adapter.zendure-solarflow.0 : zendure-solarflow : iobroker20 - enabled + system.adapter.zigbee.0 : zigbee : iobroker20 - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker20 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.deyeidc.0 : deyeidc : iobroker20 - enabled, port: 8899 + system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker20 - enabled, port: 54321 + system.adapter.mihome-vacuum.1 : mihome-vacuum : iobroker20 - enabled, port: 54321 + system.adapter.shelly.0 : shelly : iobroker20 - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.solarlog.0 : solarlog : iobroker20 - enabled, port: 80 + system.adapter.sonoff.0 : sonoff : iobroker20 - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.web.1 : web : iobroker20 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker20 - enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0 ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "admin" : 7.7.19 , installed 7.7.19 Adapter "backitup" : 3.3.10 , installed 3.3.10 Adapter "bmw" : 4.3.1 , installed 4.3.1 Adapter "broadlink2" : 2.3.0 , installed 2.3.0 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "daswetter" : 3.2.8 , installed 3.2.8 Adapter "devices" : 1.2.8 , installed 1.2.8 Adapter "deyeidc" : 0.3.1 , installed 0.3.1 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "easee" : 1.0.10 , installed 1.0.10 Adapter "ems-esp" : 6.0.1 , installed 6.0.2 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "energiefluss-erweitert": 0.8.1, installed 0.8.1 Adapter "espresense" : 0.6.3 , installed 0.6.3 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "harmony" : 1.5.0 , installed 1.5.0 Adapter "heatingcontrol": 2.12.19 , installed 2.12.19 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hmip" : 1.27.0 , installed 1.27.0 Adapter "homeconnect" : 1.4.3 , installed 1.4.3 Adapter "hs100" : 3.0.5 , installed 3.0.5 Adapter "ical" : 1.18.1 , installed 1.18.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2 Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1 Adapter "javascript" : 9.0.11 , installed 9.0.11 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "meater" : 1.1.1 , installed 1.1.1 Adapter "midea" : 0.0.7 , installed 0.0.7 Adapter "mihome-vacuum": 5.2.0 , installed 5.3.0 Adapter "nuki-extended": 2.7.0 , installed 2.7.0 Adapter "pushover" : 4.1.0 , installed 4.1.0 Adapter "rpi2" : 2.4.0 , installed 2.4.0 Adapter "scenes" : 3.2.3 , installed 3.2.3 Adapter "shelly" : 10.4.1 , installed 10.4.1 Adapter "shuttercontrol": 2.0.7 , installed 2.0.7 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartgarden" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "solarlog" : 2.4.0 , installed 2.4.0 Adapter "sonoff" : 3.2.1 , installed 3.2.1 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "tuya" : 3.16.0 , installed 3.16.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-icontwo" : 1.18.0 , installed 1.18.0 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "worx" : 3.2.7 , installed 3.2.7 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahoo-stock-market": 0.0.7, installed 0.0.7 Adapter "zendure-solarflow": 3.1.1, installed 3.1.1 Adapter "zigbee" : 3.1.5 , installed 3.1.5 Objects and States Please stand by - This may take a while Objects: 17848 States: 15331 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending Updates: 6 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 5660 721/sshd: /usr/sbin tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 1263208 232904/iobroker.js- tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 1263213 232904/iobroker.js- tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 1265609 233847/io.shelly.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 1267774 233447/io.sonoff.0 tcp6 0 0 :::22 :::* LISTEN 0 5662 721/sshd: /usr/sbin tcp6 0 0 :::61991 :::* LISTEN 1001 1266795 233328/io.harmony.0 tcp6 0 0 :::51989 :::* LISTEN 1001 1290489 237621/io.nuki-exte tcp6 0 0 :::8082 :::* LISTEN 1001 1289952 237606/io.web.1 tcp6 0 0 :::8081 :::* LISTEN 1001 1263501 233032/io.admin.0 udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 1266796 233328/io.harmony.0 udp 0 0 0.0.0.0:15001 0.0.0.0:* 1001 1264277 233039/io.broadlink udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 4711 591/avahi-daemon: r udp 0 0 0.0.0.0:56681 0.0.0.0:* 1001 1294205 233039/io.broadlink udp 0 0 0.0.0.0:40424 0.0.0.0:* 104 4713 591/avahi-daemon: r udp 0 0 0.0.0.0:53421 0.0.0.0:* 1001 1266304 233472/io.mihome-va udp 0 0 0.0.0.0:53422 0.0.0.0:* 1001 1265517 233517/io.mihome-va udp 0 0 0.0.0.0:49383 0.0.0.0:* 1001 1264283 233039/io.broadlink udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 1267457 233854/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 1267458 233854/io.tuya.0 udp6 0 0 fe80::93ff:a0e8:a30:546 :::* 0 6363 633/NetworkManager udp6 0 0 :::33415 :::* 104 4714 591/avahi-daemon: r udp6 0 0 :::5353 :::* 104 4712 591/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-12-18 21:48:07.387 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inCurrentT3, value: 14.491000175476074 2025-12-18 21:48:07.388 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.totalPower, value: 10.25 2025-12-18 21:48:10.047 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inCurrentT2, value: 2.1989998817443848 2025-12-18 21:48:10.095 - debug: easee.0 (237946) New SignalR-ID, possible new Value: 73 2025-12-18 21:48:10.096 - debug: easee.0 (237946) {"mid":"EHAW45A2","dataType":3,"id":73,"timestamp":"2025-12-18T20:48:08Z","value":"15.734999656677246"} 2025-12-18 21:48:12.123 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inCurrentT3, value: 16.128999710083008 2025-12-18 21:48:12.123 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.totalPower, value: 10.63599967956543 2025-12-18 21:48:12.957 - info: bmw.0 (238141) MQTT connection closed 2025-12-18 21:48:13.039 - debug: easee.0 (237946) New SignalR-ID, possible new Value: 156 2025-12-18 21:48:13.039 - debug: easee.0 (237946) {"mid":"EH632604","dataType":4,"id":156,"timestamp":"2025-12-18T20:48:11Z","value":"170"} 2025-12-18 21:48:13.040 - debug: easee.0 (237946) New value over SignalR for: EH632604.status.TempMax, value: 13 2025-12-18 21:48:30.353 - debug: easee.0 (237946) New value over SignalR for: EH632604.status.inVoltageT2T4, value: 234.8470001220703 2025-12-18 21:48:30.354 - debug: easee.0 (237946) New value over SignalR for: EH632604.status.inVoltageT2T5, value: 227.80299377441406 2025-12-18 21:48:30.354 - debug: easee.0 (237946) New value over SignalR for: EH632604.status.inVoltageT2T3, value: 237.26400756835938 2025-12-18 21:48:42.957 - info: bmw.0 (238141) MQTT reconnecting... 2025-12-18 21:48:43.055 - info: bmw.0 (238141) BMW MQTT stream connected 2025-12-18 21:49:11.161 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inVoltageT2T4, value: 232.67100524902344 2025-12-18 21:49:11.161 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inVoltageT2T5, value: 227.66700744628906 2025-12-18 21:49:11.161 - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inVoltageT2T3, value: 236.23199462890625 2025-12-18 21:50:38.109 - info: host.iobroker20 instance system.adapter.dwd.0 in version "2.8.5" started with pid 261297 2025-12-18 21:50:47.639 - info: dwd.0 (261297) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.21.0, js-controller: 7.0.7 2025-12-18 21:50:53.910 - info: dwd.0 (261297) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-12-18 21:50:56.139 - info: host.iobroker20 instance system.adapter.dwd.0 having pid 261297 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-12-18 21:51:18.171 - debug: easee.0 (237946) New SignalR-ID, possible new Value: 121 2025-12-18 21:51:18.172 - debug: easee.0 (237946) {"mid":"EHAW45A2","dataType":3,"id":121,"timestamp":"2025-12-18T20:51:16Z","value":"14.97032642364502"}@Karacho sagte in Automatidcher Reboot iobroker täglich:
*** MEMORY ***
Mem: 4.0G 3.4G 337M 204K 399M 619MKönnte zu wenig RAM sein. Bei 'Lastspitzen' (Backup usw.) wird der ioBroker gestoppt.
Pending Updates: 6
Hau die Updates drauf.
oder Unnötiges/veraltetes deaktivieren/löschen um Ram frei zu machen
Ist das so richtig, dass da zwei Instanzen auf den gleichen Port horchen?+ system.adapter.mihome-vacuum.0 : mihome-vacuum : iobroker20 - enabled, port: 54321 + system.adapter.mihome-vacuum.1 : mihome-vacuum : iobroker20 - enabled, port: 54321 -
Ich hatte die gleichen Probleme mit einem 4GB Raspi 4.
Wenn man einige Adapter installiert hat, reichen die 4GB nur sehr knapp. Kommen dan noch zusätzliche Jobs hinzu wird es eng und IOBroker startet neu.
Also, entweder einige Adapter/Instanzen beenden oder RAM aufrüsten.Ich habe auf einen N150 Mini PC mit 16GB RAM aufgerüstet und IOBroker Läuft Monatelang ohne Probleme.
@Thomas-Braun sagte in Automatidcher Reboot iobroker täglich:
Und das LogLevel gescheit einstellen.
debug: easee.0
Wie stelle ich das ein?
debug: easee.0
Bei der entsprechenden Instanz.
Deutet auf RAM hin....
Natürlich.
debug: easee.0
Siehe hier:
https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge(dort als Beispiel allerdings auf debug umstellen)
Was zeigt denn im laufenden Betrieb die Ausgabe von
topan?@Karacho sagte in Automatidcher Reboot iobroker täglich:
brauchst du die alle?
Das ist natürlich ziemlich happig bei 4GB RAM, aber vielleicht klemmt es da woanders auch nochHast du inzwischen alle Adapter aktuell?
Top:
Tasks: 210 total, 1 running, 209 sleeping, 0 stopped, 0 zombie %Cpu(s): 10.8 us, 1.8 sy, 0.0 ni, 86.8 id, 0.0 wa, 0.0 hi, 0.6 si, 0.0 st MiB Mem : 3795.9 total, 796.5 free, 2509.2 used, 578.3 buff/cache MiB Swap: 200.0 total, 186.2 free, 13.8 used. 1286.6 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 224889 iobroker 20 0 11.3g 362204 54368 S 21.9 9.3 29:52.20 iobroker.js-con 225092 iobroker 20 0 11.0g 242784 53596 S 11.3 6.2 10:33.17 io.javascript.0 229771 iobroker 20 0 10.9g 119148 54436 S 7.6 3.1 0:15.31 io.zendure-sola 225055 iobroker 20 0 10.9g 129244 47972 S 5.0 3.3 5:35.65 io.history.0 225406 iobroker 20 0 10.8g 124184 53388 S 2.6 3.2 5:41.94 io.sonoff.0 225346 iobroker 20 0 11.0g 106136 49228 S 2.0 2.7 0:22.70 io.hmip.0 225015 iobroker 20 0 21.1g 219916 56120 S 1.7 5.7 2:00.03 io.admin.0 627 root 20 0 263044 8108 6272 S 0.3 0.2 2:47.16 NetworkManager 225107 iobroker 20 0 10.8g 96776 49196 S 0.3 2.5 0:09.97 io.pushover.0 225479 iobroker 20 0 10.8g 93604 48016 S 0.3 2.4 0:18.40 io.mihome-vacuu 225949 iobroker 20 0 11.0g 104716 54676 S 0.3 2.7 0:11.53 io.easee.0 229639 root 20 0 0 0 0 D 0.3 0.0 0:00.26 kworker/1:0+events_freezable 229877 pi 20 0 11716 5044 2820 R 0.3 0.1 0:00.26 top -
- habe jetzt alle Adapter aktuell.
- nur die easee Adapter waren im debug Modus
- habe einige Instanzen dekativiert
- hier mal eine Auswertung (keine ahnug, ob das aussagekräftig)
War da den jetzt ein Neustart dabei?
Ich sehe da gar nix.
Die einzige kleine Auffälligkeit ist ca 23 Uhr. -
Hier noch einmal
toplogin as: pi pi@192.168.178.71's password: Linux iobroker20 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookw orm (2025-09-16) aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Dec 21 23:42:13 2025 from 192.168.178.167 pi@iobroker20:~ $ top top - 15:52:11 up 3 days, 17:22, 1 user, load average: 0.17, 0.38, 0.75 Tasks: 199 total, 1 running, 198 sleeping, 0 stopped, 0 zombie %Cpu(s): 12.4 us, 1.6 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.6 si, 0.0 st MiB Mem : 3795.9 total, 216.9 free, 2818.7 used, 864.0 buff/cache MiB Swap: 200.0 total, 184.8 free, 15.2 used. 977.1 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 224889 iobroker 20 0 11.3g 405168 54368 S 23.8 10.4 234:17.33 iobroker.js-con 225092 iobroker 20 0 11.2g 273024 53660 S 11.3 7.0 86:38.88 io.javascript.0 245454 iobroker 20 0 10.9g 133492 54504 S 6.6 3.4 2:55.99 io.zendure-sola 225406 iobroker 20 0 10.8g 125008 53448 S 5.6 3.2 66:29.22 io.sonoff.0 225055 iobroker 20 0 11.0g 137472 48032 S 5.0 3.5 47:21.71 io.history.0 225306 iobroker 20 0 10.8g 110092 47900 S 3.0 2.8 4:41.10 io.ems-esp.0 225860 iobroker 20 0 11.0g 127960 49316 S 1.3 3.3 2:42.84 io.mercedesme.0 225015 iobroker 20 0 21.1g 226676 56120 S 0.7 5.8 7:36.41 io.admin.0 18 root 20 0 0 0 0 I 0.3 0.0 1:04.10 rcu_preempt 99 root -51 0 0 0 0 S 0.3 0.0 9:17.27 irq/40-mmc0 225716 iobroker 20 0 11.0g 138956 54300 S 0.3 3.6 1:23.01 io.zigbee.0 245558 root 20 0 0 0 0 I 0.3 0.0 0:01.84 kworker/0:1-events 247029 pi 20 0 11716 5016 2820 R 0.3 0.1 0:00.13 top 1 root 20 0 168552 7836 5532 S 0.0 0.2 0:38.21 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.78 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-kvfree_rcu_reclaim 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_gp 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-sync_wq 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_flushwq 8 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns 10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri 12 root 20 0 0 0 0 I 0.0 0.0 0:00.01 kworker/u16:0-netns 13 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_percpu_wq 14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread 15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread 16 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread 17 root 20 0 0 0 0 S 0.0 0.0 0:30.92 ksoftirqd/0 19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_exp_par_gp_kthread_worker/0 20 root 20 0 0 0 0 S 0.0 0.0 0:00.01 rcu_exp_gp_kthread_worker 21 root rt 0 0 0 0 S 0.0 0.0 0:00.10 migration/0 22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 24 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/1 25 root 20 0 0 0 0 S 0.0 0.0 0:17.64 ksoftirqd/1 27 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpri -
Hier noch einmal
toplogin as: pi pi@192.168.178.71's password: Linux iobroker20 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookw orm (2025-09-16) aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Dec 21 23:42:13 2025 from 192.168.178.167 pi@iobroker20:~ $ top top - 15:52:11 up 3 days, 17:22, 1 user, load average: 0.17, 0.38, 0.75 Tasks: 199 total, 1 running, 198 sleeping, 0 stopped, 0 zombie %Cpu(s): 12.4 us, 1.6 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.6 si, 0.0 st MiB Mem : 3795.9 total, 216.9 free, 2818.7 used, 864.0 buff/cache MiB Swap: 200.0 total, 184.8 free, 15.2 used. 977.1 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 224889 iobroker 20 0 11.3g 405168 54368 S 23.8 10.4 234:17.33 iobroker.js-con 225092 iobroker 20 0 11.2g 273024 53660 S 11.3 7.0 86:38.88 io.javascript.0 245454 iobroker 20 0 10.9g 133492 54504 S 6.6 3.4 2:55.99 io.zendure-sola 225406 iobroker 20 0 10.8g 125008 53448 S 5.6 3.2 66:29.22 io.sonoff.0 225055 iobroker 20 0 11.0g 137472 48032 S 5.0 3.5 47:21.71 io.history.0 225306 iobroker 20 0 10.8g 110092 47900 S 3.0 2.8 4:41.10 io.ems-esp.0 225860 iobroker 20 0 11.0g 127960 49316 S 1.3 3.3 2:42.84 io.mercedesme.0 225015 iobroker 20 0 21.1g 226676 56120 S 0.7 5.8 7:36.41 io.admin.0 18 root 20 0 0 0 0 I 0.3 0.0 1:04.10 rcu_preempt 99 root -51 0 0 0 0 S 0.3 0.0 9:17.27 irq/40-mmc0 225716 iobroker 20 0 11.0g 138956 54300 S 0.3 3.6 1:23.01 io.zigbee.0 245558 root 20 0 0 0 0 I 0.3 0.0 0:01.84 kworker/0:1-events 247029 pi 20 0 11716 5016 2820 R 0.3 0.1 0:00.13 top 1 root 20 0 168552 7836 5532 S 0.0 0.2 0:38.21 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.78 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-kvfree_rcu_reclaim 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_gp 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-sync_wq 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_flushwq 8 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns 10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri 12 root 20 0 0 0 0 I 0.0 0.0 0:00.01 kworker/u16:0-netns 13 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_percpu_wq 14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread 15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread 16 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread 17 root 20 0 0 0 0 S 0.0 0.0 0:30.92 ksoftirqd/0 19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_exp_par_gp_kthread_worker/0 20 root 20 0 0 0 0 S 0.0 0.0 0:00.01 rcu_exp_gp_kthread_worker 21 root rt 0 0 0 0 S 0.0 0.0 0:00.10 migration/0 22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 24 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/1 25 root 20 0 0 0 0 S 0.0 0.0 0:17.64 ksoftirqd/1 27 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpri@Karacho sagte in Automatidcher Reboot iobroker täglich:
up 3 days
passt nicht zu
um 23 Uhr war ein Neustart
oder vor 3 Tagen 23:00?
Auf jeden Fall ist nach 3 Tagen+
nicht besorgniserregend
Hier noch einmal
Hier noch einmal
toplogin as: pi pi@192.168.178.71's password: Linux iobroker20 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookw orm (2025-09-16) aarch64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Sun Dec 21 23:42:13 2025 from 192.168.178.167 pi@iobroker20:~ $ top top - 15:52:11 up 3 days, 17:22, 1 user, load average: 0.17, 0.38, 0.75 Tasks: 199 total, 1 running, 198 sleeping, 0 stopped, 0 zombie %Cpu(s): 12.4 us, 1.6 sy, 0.0 ni, 85.4 id, 0.0 wa, 0.0 hi, 0.6 si, 0.0 st MiB Mem : 3795.9 total, 216.9 free, 2818.7 used, 864.0 buff/cache MiB Swap: 200.0 total, 184.8 free, 15.2 used. 977.1 avail Mem PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 224889 iobroker 20 0 11.3g 405168 54368 S 23.8 10.4 234:17.33 iobroker.js-con 225092 iobroker 20 0 11.2g 273024 53660 S 11.3 7.0 86:38.88 io.javascript.0 245454 iobroker 20 0 10.9g 133492 54504 S 6.6 3.4 2:55.99 io.zendure-sola 225406 iobroker 20 0 10.8g 125008 53448 S 5.6 3.2 66:29.22 io.sonoff.0 225055 iobroker 20 0 11.0g 137472 48032 S 5.0 3.5 47:21.71 io.history.0 225306 iobroker 20 0 10.8g 110092 47900 S 3.0 2.8 4:41.10 io.ems-esp.0 225860 iobroker 20 0 11.0g 127960 49316 S 1.3 3.3 2:42.84 io.mercedesme.0 225015 iobroker 20 0 21.1g 226676 56120 S 0.7 5.8 7:36.41 io.admin.0 18 root 20 0 0 0 0 I 0.3 0.0 1:04.10 rcu_preempt 99 root -51 0 0 0 0 S 0.3 0.0 9:17.27 irq/40-mmc0 225716 iobroker 20 0 11.0g 138956 54300 S 0.3 3.6 1:23.01 io.zigbee.0 245558 root 20 0 0 0 0 I 0.3 0.0 0:01.84 kworker/0:1-events 247029 pi 20 0 11716 5016 2820 R 0.3 0.1 0:00.13 top 1 root 20 0 168552 7836 5532 S 0.0 0.2 0:38.21 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.78 kthreadd 3 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pool_workqueue_release 4 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-kvfree_rcu_reclaim 5 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-rcu_gp 6 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-sync_wq 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-slub_flushwq 8 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-netns 10 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/0:0H-events_highpri 12 root 20 0 0 0 0 I 0.0 0.0 0:00.01 kworker/u16:0-netns 13 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/R-mm_percpu_wq 14 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_kthread 15 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_rude_kthread 16 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_tasks_trace_kthread 17 root 20 0 0 0 0 S 0.0 0.0 0:30.92 ksoftirqd/0 19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_exp_par_gp_kthread_worker/0 20 root 20 0 0 0 0 S 0.0 0.0 0:00.01 rcu_exp_gp_kthread_worker 21 root rt 0 0 0 0 S 0.0 0.0 0:00.10 migration/0 22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 24 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/1 25 root 20 0 0 0 0 S 0.0 0.0 0:17.64 ksoftirqd/1 27 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:0H-events_highpritop bringt bei so etwas nur bedingt, da es eine augenblicksdarstellung ist
aufgrund der 24h darstellung sind die ausschläge natürlich nicht so ganz klar.
woher kommen die daten?
sind die aus dem iobroker?
evtl kannst du auch mal noch den gesamt ram verbrauch des kompletten systems tracken.ansonsten kann ich nur auf den üblichen verdächtigen verweisen:
den javascript adapter
da ist vor 23 uhr ein leichter anstieg mit einem heftigeren ausschlag beim admin-adapter und iobroker.
den admin adapter kann ich mir nicht erklären. evtl weiß noch jemand, was den der admin so operativ den tag durch macht.
eigentlich ist er ja nur dazu da einstellungen vorzunehmen?
hattest du einen browser mit der admin ansicht offen?wenn sich so ein restart regelmäßig wiederholt ist das meist ein speicherproblem. ein oder mehrere skripte benötigen viel speicher und das betriebssystem entscheidet irgendwann dann mal den prozess neu zu starten. das könntest du dann auch mal im syslog des betriebssystems (bei linux) schauen. schlüsselwörter wären fatal oder error oder warn
als nächstes müsstest du mal deine skripte durchschauen ob du da ein schedule oder cron drin hast, was zur uhrzeit passt. ggfs auch nochrmale wiederholungen beachten, bei denen sich dann ausgerechnet um 23 uhr mehrere treffen und dann das system in schwierigkeiten bringt.
auch problematische javascript kann sogenannte memory leaks erzeugen, bei dem speicher geblockt wird aber nicht mehr freigegeben wird (meist bei setInterval/setTimeout, insbesondere dann wenn da was verschachtelt statt findet.)
ggfs. wirst du skripte auch mal temporär deaktivieren müssen. alternativ können zusätzlich eingefügte logausgaben auch etwas mehr informationen liefern wann da was ausgeführt wird (vergrößert aber dann wieder die last auf das system und ggfs memory)
up 3 days
passt nicht zu
