  4. Automatidcher Reboot iobroker täglich
    6.4k
45 Beiträge 9 Kommentatoren 3.1k Aufrufe 7 Beobachtet
    Karacho
    es ist wir ein Neustartedes iobroker,. Dh alle Instanzen starten auch neu
    iob diag:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: iobroker20
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:49:58 up 3 days, 12:49,  2 users,  load average: 2.07, 2.17, 1.60
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest        stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-12-18 21:49:58 CET
               Universal time: Thu 2025-12-18 20:49:58 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render ne        tdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.0G        3.4G        337M        204K        399M        619M
    Swap:           209M        100M        109M
    Total:          4.2G        3.5G        446M
    Active iob-Instances:   38
             3795 M total memory
             3205 M used memory
             1514 M active memory
             1705 M inactive memory
              321 M free memory
               35 M buffer memory
              345 M swap cache
              199 M total swap
               95 M used swap
              104 M free swap
    top - 21:49:59 up 3 days, 12:49,  2 users,  load average: 2.07, 2.17, 1.60
    Tasks: 223 total,   1 running, 222 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 12.5 us, 12.5 sy,  0.0 ni, 62.5 id, 12.5 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.9 total,    320.4 free,   3205.8 used,    381.0 buff/cache
    MiB Swap:    200.0 total,    104.4 free,     95.6 used.    590.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     760M  1.2M  759M   1% /run
    /dev/sda2      ext4      220G   16G  195G   8% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Mon Dec 15 09:00:49 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nv        me.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdm        i=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.maca        ddr=DC:A6:32:61:2C:40 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  con        sole=ttyS0,115200 console=tty1 root=PARTUUID=adc78390-02 rootfstype=ext4 fsck.re        pair=yes rootwait
    [Mon Dec 15 09:00:52 2025] EXT4-fs (sda2): mounted filesystem 6835594d-a5f3-459f        -a244-318060e7e0ab ro with ordered data mode. Quota mode: none.
    [Mon Dec 15 09:00:53 2025] EXT4-fs (sda2): re-mounted 6835594d-a5f3-459f-a244-31        8060e7e0ab r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G    /var/
    668M    /var/log
    667M    /var/log/journal/7b7fe4cfb66842c09a3cb98b578c9b66
    416M    /var/cache
    Archived and active journals take up 666.5M in the file system.
    /opt/iobroker/backups:
    3.4M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    7.2G    /opt/iobroker/iobroker-data/
    6.8G    /opt/iobroker/iobroker-data/history
    320M    /opt/iobroker/iobroker-data/files
    121M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    52M     /opt/iobroker/iobroker-data/history/20250306/history.0_userdata.0.Energie_Bezug_Netz.json
    52M     /opt/iobroker/iobroker-data/history/20250302/history.0_userdata.0.Energie_Bezug_Netz.json
    52M     /opt/iobroker/iobroker-data/history/20250301/history.0_userdata.0.Energie_Bezug_Netz.json
    52M     /opt/iobroker/iobroker-data/history/20250210/history.0_userdata.0.Energie_Bezug_Netz.json
    45M     /opt/iobroker/iobroker-data/history/20250309/history.0_userdata.0.Energie_Bezug_Netz.json
    USB-Devices by-id:
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    *** ZigBee Settings ***
    Your zigbee.0 COM-Port is matching 'by-id'. Very good!
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker20          iobroker20 (version: 7.0.7, hostname: iobroker20    , alive, uptime: 42970)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     3
    +-- iobroker.hoymiles-wifi@0.1.1 (git+ssh://git@github.com/MicHi07i/ioBroker.hoymiles-wifi.git#83ba7640e6a73dc4ee4788b055318e1cfc58bc0f)
    +-- iobroker.nuki-extended@2.7.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.nuki-extended.git#45f4994af57a0f6f06e308d0c6d7961bc49d27a5)
    +-- iobroker.pv-power-control@0.1.0 (git+ssh://git@github.com/Newan/ioBroker.pv-power-control.git#48203f8ba437503e209138af7f80acac953f7e7c)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker20                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker20                               -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker20                               -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : iobroker20                               -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker20                               -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker20                               -  enabled
      system.adapter.devices.0                : devices               : iobroker20                               - disabled
    + system.adapter.deyeidc.0                : deyeidc               : iobroker20                               -  enabled, port: 8899
    + system.adapter.discovery.0              : discovery             : iobroker20                               -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker20                               -  enabled
    + system.adapter.easee.0                  : easee                 : iobroker20                               -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobroker20                               -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker20                               -  enabled
      system.adapter.flot.0                   : flot                  : iobroker20                               - disabled
    + system.adapter.harmony.0                : harmony               : iobroker20                               -  enabled
    + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker20                               -  enabled
    + system.adapter.history.0                : history               : iobroker20                               -  enabled
    + system.adapter.hmip.0                   : hmip                  : iobroker20                               -  enabled
    + system.adapter.homeconnect.0            : homeconnect           : iobroker20                               -  enabled
      system.adapter.hs100.0                  : hs100                 : iobroker20                               - disabled
      system.adapter.ical.0                   : ical                  : iobroker20                               -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker20                               - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker20                               -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker20                               -  enabled
    + system.adapter.info.0                   : info                  : iobroker20                               -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker20                               -  enabled
    + system.adapter.meater.0                 : meater                : iobroker20                               -  enabled
    + system.adapter.mercedesme.0             : mercedesme            : iobroker20                               -  enabled
      system.adapter.midea.0                  : midea                 : iobroker20                               - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker20                               -  enabled, port: 54321
    + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker20                               -  enabled, port: 54321
    + system.adapter.nuki-extended.0          : nuki-extended         : iobroker20                               -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker20                               -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobroker20                               -  enabled
    + system.adapter.scenes.0                 : scenes                : iobroker20                               -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker20                               -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker20                               -  enabled
    + system.adapter.smartgarden.0            : smartgarden           : iobroker20                               -  enabled
    + system.adapter.solarlog.0               : solarlog              : iobroker20                               -  enabled, port: 80
    + system.adapter.sonoff.0                 : sonoff                : iobroker20                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : iobroker20                               -  enabled
    + system.adapter.tuya.0                   : tuya                  : iobroker20                               -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker20                               - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker20                               - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker20                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker20                               - disabled
      system.adapter.vis.0                    : vis                   : iobroker20                               -  enabled
    + system.adapter.web.1                    : web                   : iobroker20                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.worx.0                   : worx                  : iobroker20                               -  enabled
    + system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : iobroker20                               -  enabled
    + system.adapter.zendure-solarflow.0      : zendure-solarflow     : iobroker20                               -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker20                               -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_e486124e65c8eb11afebc4c3de5b81b4-if00-port0
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "backitup"     : 3.3.10   , installed 3.3.10
    Adapter    "bmw"          : 4.3.1    , installed 4.3.1
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "daswetter"    : 3.2.8    , installed 3.2.8
    Adapter    "devices"      : 1.2.8    , installed 1.2.8
    Adapter    "deyeidc"      : 0.3.1    , installed 0.3.1
    Adapter    "easee"        : 1.0.10   , installed 1.0.10
    Adapter    "ems-esp"      : 6.0.1    , installed 6.0.2
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "espresense"   : 0.6.3    , installed 0.6.3
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "heatingcontrol": 2.12.19 , installed 2.12.19
    Adapter    "hmip"         : 1.27.0   , installed 1.27.0
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "hs100"        : 3.0.5    , installed 3.0.5
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "meater"       : 1.1.1    , installed 1.1.1
    Adapter    "midea"        : 0.0.7    , installed 0.0.7
    Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
    Adapter    "shelly"       : 10.4.1   , installed 10.4.1
    Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "solarlog"     : 2.4.0    , installed 2.4.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "trashschedule": 3.3.0    , installed 3.3.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "worx"         : 3.2.7    , installed 3.2.7
    Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
    Adapter    "zendure-solarflow": 3.1.1, installed 3.1.1
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        17848
    States:         15331
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 6
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5660       721/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1263208    232904/iobroker.js-
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1263213    232904/iobroker.js-
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       1265609    233847/io.shelly.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1267774    233447/io.sonoff.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5662       721/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       1266795    233328/io.harmony.0
    tcp6       0      0 :::51989                :::*                    LISTEN      1001       1290489    237621/io.nuki-exte
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1289952    237606/io.web.1
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1263501    233032/io.admin.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       1266796    233328/io.harmony.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       1264277    233039/io.broadlink
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4711       591/avahi-daemon: r
    udp        0      0 0.0.0.0:56681           0.0.0.0:*                           1001       1294205    233039/io.broadlink
    udp        0      0 0.0.0.0:40424           0.0.0.0:*                           104        4713       591/avahi-daemon: r
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1266304    233472/io.mihome-va
    udp        0      0 0.0.0.0:53422           0.0.0.0:*                           1001       1265517    233517/io.mihome-va
    udp        0      0 0.0.0.0:49383           0.0.0.0:*                           1001       1264283    233039/io.broadlink
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1267457    233854/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1267458    233854/io.tuya.0
    udp6       0      0 fe80::93ff:a0e8:a30:546 :::*                                0          6363       633/NetworkManager
    udp6       0      0 :::33415                :::*                                104        4714       591/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        4712       591/avahi-daemon: r
    2025-12-18 21:48:07.387  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inCurrentT3, value: 14.491000175476074
    2025-12-18 21:48:07.388  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.totalPower, value: 10.25
    2025-12-18 21:48:10.047  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inCurrentT2, value: 2.1989998817443848
    2025-12-18 21:48:10.095  - debug: easee.0 (237946) New SignalR-ID, possible new Value: 73
    2025-12-18 21:48:10.096  - debug: easee.0 (237946) {"mid":"EHAW45A2","dataType":3,"id":73,"timestamp":"2025-12-18T20:48:08Z","value":"15.734999656677246"}
    2025-12-18 21:48:12.123  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inCurrentT3, value: 16.128999710083008
    2025-12-18 21:48:12.123  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.totalPower, value: 10.63599967956543
    2025-12-18 21:48:12.957  - info: bmw.0 (238141) MQTT connection closed
    2025-12-18 21:48:13.039  - debug: easee.0 (237946) New SignalR-ID, possible new Value: 156
    2025-12-18 21:48:13.039  - debug: easee.0 (237946) {"mid":"EH632604","dataType":4,"id":156,"timestamp":"2025-12-18T20:48:11Z","value":"170"}
    2025-12-18 21:48:13.040  - debug: easee.0 (237946) New value over SignalR for: EH632604.status.TempMax, value: 13
    2025-12-18 21:48:30.353  - debug: easee.0 (237946) New value over SignalR for: EH632604.status.inVoltageT2T4, value: 234.8470001220703
    2025-12-18 21:48:30.354  - debug: easee.0 (237946) New value over SignalR for: EH632604.status.inVoltageT2T5, value: 227.80299377441406
    2025-12-18 21:48:30.354  - debug: easee.0 (237946) New value over SignalR for: EH632604.status.inVoltageT2T3, value: 237.26400756835938
    2025-12-18 21:48:42.957  - info: bmw.0 (238141) MQTT reconnecting...
    2025-12-18 21:48:43.055  - info: bmw.0 (238141) BMW MQTT stream connected
    2025-12-18 21:49:11.161  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inVoltageT2T4, value: 232.67100524902344
    2025-12-18 21:49:11.161  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inVoltageT2T5, value: 227.66700744628906
    2025-12-18 21:49:11.161  - debug: easee.0 (237946) New value over SignalR for: EHAW45A2.status.inVoltageT2T3, value: 236.23199462890625
    2025-12-18 21:50:38.109  - info: host.iobroker20 instance system.adapter.dwd.0 in version "2.8.5" started with pid 261297
    2025-12-18 21:50:47.639  - info: dwd.0 (261297) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v22.21.0, js-controller: 7.0.7
    2025-12-18 21:50:53.910  - info: dwd.0 (261297) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-12-18 21:50:56.139  - info: host.iobroker20 instance system.adapter.dwd.0 having pid 261297 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2025-12-18 21:51:18.171  - debug: easee.0 (237946) New SignalR-ID, possible new Value: 121
    2025-12-18 21:51:18.172  - debug: easee.0 (237946) {"mid":"EHAW45A2","dataType":3,"id":121,"timestamp":"2025-12-18T20:51:16Z","value":"14.97032642364502"}
    Thomas BraunT crunchipC CodierknechtC 3 Antworten Letzte Antwort
      Karacho
      crontab -i bringet: not crontab
      neustart ist auch nicht exakt zur gleichen Zeit..
      • K Karacho
        iob diag:
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 3795 M total memory
                 3205 M used memory
                  321 M free memory
                   35 M buffer memory
                  345 M swap cache
                  199 M total swap
                   95 M used swap
                  104 M free swap
        *** FILESYSTEM ***
        /var:
        1.5G    /var/
        668M    /var/log
        416M    /var/cache
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.19
        javascript:     9.0.11
        Adapter State
        + instance is alive
        Objects and States
        Objects:        17848
        States:         15331
        Pending Updates: 6
        @Karacho sagte in Automatidcher Reboot iobroker täglich:
        *** MEMORY ***
        total used free shared buff/cache available
        Könnte zu wenig RAM sein. Bei 'Lastspitzen' (Backup usw.) wird der ioBroker gestoppt.
        Pending Updates: 6
        Hau die Updates drauf.
        • K Karacho
          iob diag:
          ```bash
          Script v.2025-08-09
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
                   3795 M total memory
                   3205 M used memory
                    321 M free memory
                     35 M buffer memory
                    345 M swap cache
                    199 M total swap
                     95 M used swap
                    104 M free swap
          *** FILESYSTEM ***
          /var:
          1.5G    /var/
          668M    /var/log
          416M    /var/cache
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.9.4
          /usr/bin/npx            10.9.4
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.7.19
          javascript:     9.0.11
          Adapter State
          + instance is alive
          Objects and States
          Objects:        17848
          States:         15331
          Pending Updates: 6
          crunchipC Abwesend
          crunchipC Abwesend
          oder Unnötiges/veraltetes deaktivieren/löschen um Ram frei zu machen
            @crunchip
            Und das LogLevel gescheit einstellen.
            debug: easee.0
            • K Karacho
              iob diag:
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3795 M total memory
                       3205 M used memory
                        321 M free memory
                         35 M buffer memory
                        345 M swap cache
                        199 M total swap
                         95 M used swap
                        104 M free swap
              *** FILESYSTEM ***
              /var:
              1.5G    /var/
              668M    /var/log
              416M    /var/cache
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.19
              javascript:     9.0.11
              Adapter State
              + instance is alive
              Objects and States
              Objects:        17848
              States:         15331
              Pending Updates: 6
              CodierknechtC Offline
              Codierknecht
              @Karacho
              Ist das so richtig, dass da zwei Instanzen auf den gleichen Port horchen?
              HmIP|ZigBee|Tasmota|Unifi
              Zabbix Certified Specialist
              • S Online
                S Online
                Solardach
                @karacho
                Ich hatte die gleichen Probleme mit einem 4GB Raspi 4.
                Wenn man einige Adapter installiert hat, reichen die 4GB nur sehr knapp. Kommen dan noch zusätzliche Jobs hinzu wird es eng und IOBroker startet neu.
                Also, entweder einige Adapter/Instanzen beenden oder RAM aufrüsten.
                Ich habe auf einen N150 Mini PC mit 16GB RAM aufgerüstet und IOBroker Läuft Monatelang ohne Probleme.
                  @crunchip
                  debug: easee.0
                  Karacho
                  @Thomas-Braun
                  @Thomas-Braun sagte in Automatidcher Reboot iobroker täglich:
                  @crunchip
                  debug: easee.0
                  Wie stelle ich das ein?
                    Karacho
                    Also, der iobroker stürzt inzwischen unregelmäßog ab und startet neu.
                    Besonders, wenn ich nebenbei in der Vis und Flot Änderungen mache. Deutet auf RAM hin....
                    • K Karacho
                      @Thomas-Braun
                      @crunchip
                      debug: easee.0
                      Bei der entsprechenden Instanz.
                      Natürlich.
                      • K Karacho
                        @Thomas-Braun
                        @crunchip
                        debug: easee.0
                        Siehe hier:
                        (dort als Beispiel allerdings auf debug umstellen)
                        Was zeigt denn im laufenden Betrieb die Ausgabe von top an?
                        brauchst du die alle?
                        Das ist natürlich ziemlich happig bei 4GB RAM, aber vielleicht klemmt es da woanders auch noch
                        Hast du inzwischen alle Adapter aktuell?
                          Karacho
                          • habe jetzt alle Adapter aktuell.
                          • nur die easee Adapter waren im debug Modus
                          • habe einige Instanzen dekativiert
                          • hier mal eine Auswertung (keine ahnug, ob das aussagekräftig)
                            Karacho
                            Top:
                            Tasks: 210 total,   1 running, 209 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 10.8 us,  1.8 sy,  0.0 ni, 86.8 id,  0.0 wa,  0.0 hi,  0.6 si,  0.0 st
                            MiB Mem :   3795.9 total,    796.5 free,   2509.2 used,    578.3 buff/cache
                            MiB Swap:    200.0 total,    186.2 free,     13.8 used.   1286.6 avail Mem
                                PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                             224889 iobroker  20   0   11.3g 362204  54368 S  21.9   9.3  29:52.20 iobroker.js-con
                             225092 iobroker  20   0   11.0g 242784  53596 S  11.3   6.2  10:33.17 io.javascript.0
                             229771 iobroker  20   0   10.9g 119148  54436 S   7.6   3.1   0:15.31 io.zendure-sola
                             225055 iobroker  20   0   10.9g 129244  47972 S   5.0   3.3   5:35.65 io.history.0
                             225406 iobroker  20   0   10.8g 124184  53388 S   2.6   3.2   5:41.94 io.sonoff.0
                             225346 iobroker  20   0   11.0g 106136  49228 S   2.0   2.7   0:22.70 io.hmip.0
                             225015 iobroker  20   0   21.1g 219916  56120 S   1.7   5.7   2:00.03 io.admin.0
                                627 root      20   0  263044   8108   6272 S   0.3   0.2   2:47.16 NetworkManager
                             225107 iobroker  20   0   10.8g  96776  49196 S   0.3   2.5   0:09.97 io.pushover.0
                             225479 iobroker  20   0   10.8g  93604  48016 S   0.3   2.4   0:18.40 io.mihome-vacuu
                             225949 iobroker  20   0   11.0g 104716  54676 S   0.3   2.7   0:11.53 io.easee.0
                             229639 root      20   0       0      0      0 D   0.3   0.0   0:00.26 kworker/1:0+events_freezable
                             229877 pi        20   0   11716   5044   2820 R   0.3   0.1   0:00.26 top
                            • K Karacho
                              OliverIOO Offline
                              OliverIOO Offline
                              OliverIO
                              @Karacho
                              War da den jetzt ein Neustart dabei?
                              Ich sehe da gar nix.
                              Die einzige kleine Auffälligkeit ist ca 23 Uhr.
                              Meine Adapter und Widgets
                              Links im Profil
                              HomoranH K 2 Antworten Letzte Antwort
                              • OliverIOO OliverIO
                                @Karacho
                                @OliverIO sagte in Automatidcher Reboot iobroker täglich:
                                @karacho
                                Ja, die oberste Zeile fehlt leider.
                                ausser das der SWAP etwas gebraucht wurde sehe ich auch nichts
                                  @Karacho
                                  Karacho
                                  @OliverIO
                                  Ja, um 23 Uhr war ein Neustart
                                    Karacho
                                    Hier noch einmal top
                                    login as: pi
                                    pi@192.168.178.71's password:
                                    Linux iobroker20 6.12.47+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookw        orm (2025-09-16) aarch64
                                    permitted by applicable law.
                                    Last login: Sun Dec 21 23:42:13 2025 from 192.168.178.167
                                    pi@iobroker20:~ $ top
                                    top - 15:52:11 up 3 days, 17:22,  1 user,  load average: 0.17, 0.38, 0.75
                                    Tasks: 199 total,   1 running, 198 sleeping,   0 stopped,   0 zombie
                                    %Cpu(s): 12.4 us,  1.6 sy,  0.0 ni, 85.4 id,  0.0 wa,  0.0 hi,  0.6 si,  0.0 st
                                    MiB Mem :   3795.9 total,    216.9 free,   2818.7 used,    864.0 buff/cache
                                    MiB Swap:    200.0 total,    184.8 free,     15.2 used.    977.1 avail Mem
                                     224889 iobroker  20   0   11.3g 405168  54368 S  23.8  10.4 234:17.33 iobroker.js-con
                                     225092 iobroker  20   0   11.2g 273024  53660 S  11.3   7.0  86:38.88 io.javascript.0
                                     245454 iobroker  20   0   10.9g 133492  54504 S   6.6   3.4   2:55.99 io.zendure-sola
                                     225406 iobroker  20   0   10.8g 125008  53448 S   5.6   3.2  66:29.22 io.sonoff.0
                                     225055 iobroker  20   0   11.0g 137472  48032 S   5.0   3.5  47:21.71 io.history.0
                                     225306 iobroker  20   0   10.8g 110092  47900 S   3.0   2.8   4:41.10 io.ems-esp.0
                                     225860 iobroker  20   0   11.0g 127960  49316 S   1.3   3.3   2:42.84 io.mercedesme.0
                                     225015 iobroker  20   0   21.1g 226676  56120 S   0.7   5.8   7:36.41 io.admin.0
                                         18 root      20   0       0      0      0 I   0.3   0.0   1:04.10 rcu_preempt
                                         99 root     -51   0       0      0      0 S   0.3   0.0   9:17.27 irq/40-mmc0
                                     225716 iobroker  20   0   11.0g 138956  54300 S   0.3   3.6   1:23.01 io.zigbee.0
                                     245558 root      20   0       0      0      0 I   0.3   0.0   0:01.84 kworker/0:1-events
                                     247029 pi        20   0   11716   5016   2820 R   0.3   0.1   0:00.13 top
                                          1 root      20   0  168552   7836   5532 S   0.0   0.2   0:38.21 systemd
                                          2 root      20   0       0      0      0 S   0.0   0.0   0:00.78 kthreadd
                                          3 root      20   0       0      0      0 S   0.0   0.0   0:00.00 pool_workqueue_release
                                          4 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-kvfree_rcu_reclaim
                                          5 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-rcu_gp
                                          6 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-sync_wq
                                          7 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-slub_flushwq
                                          8 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-netns
                                         10 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/0:0H-events_highpri
                                         12 root      20   0       0      0      0 I   0.0   0.0   0:00.01 kworker/u16:0-netns
                                         13 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/R-mm_percpu_wq
                                         14 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_kthread
                                         15 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_rude_kthread
                                         16 root      20   0       0      0      0 I   0.0   0.0   0:00.00 rcu_tasks_trace_kthread
                                         17 root      20   0       0      0      0 S   0.0   0.0   0:30.92 ksoftirqd/0
                                         19 root      20   0       0      0      0 S   0.0   0.0   0:00.00 rcu_exp_par_gp_kthread_worker/0
                                         20 root      20   0       0      0      0 S   0.0   0.0   0:00.01 rcu_exp_gp_kthread_worker
                                         21 root      rt   0       0      0      0 S   0.0   0.0   0:00.10 migration/0
                                         22 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/0
                                         23 root      20   0       0      0      0 S   0.0   0.0   0:00.00 cpuhp/1
                                         24 root      rt   0       0      0      0 S   0.0   0.0   0:00.08 migration/1
                                         25 root      20   0       0      0      0 S   0.0   0.0   0:17.64 ksoftirqd/1
                                         27 root       0 -20       0      0      0 I   0.0   0.0   0:00.00 kworker/1:0H-events_highpri
                                    HomoranH Thomas BraunT OliverIOO 3 Antworten Letzte Antwort
                                    • K Karacho
                                      login as: pi
                                      up 3 days
                                      passt nicht zu
                                      oder vor 3 Tagen 23:00?
                                      Auf jeden Fall ist nach 3 Tagen+
                                      nicht besorgniserregend
                                      • K Karacho
                                        login as: pi
                                        @Karacho
                                        Haste jetzt aufgeräumt? Zeig nochmal die Ausgabe von
                                        iob diag
                                        • K Karacho
                                          login as: pi
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          @Karacho
                                          top bringt bei so etwas nur bedingt, da es eine augenblicksdarstellung ist
                                          aufgrund der 24h darstellung sind die ausschläge natürlich nicht so ganz klar.
                                          woher kommen die daten?
                                          sind die aus dem iobroker?
                                          evtl kannst du auch mal noch den gesamt ram verbrauch des kompletten systems tracken.
                                          ansonsten kann ich nur auf den üblichen verdächtigen verweisen:
                                          den javascript adapter
                                          da ist vor 23 uhr ein leichter anstieg mit einem heftigeren ausschlag beim admin-adapter und iobroker.
                                          den admin adapter kann ich mir nicht erklären. evtl weiß noch jemand, was den der admin so operativ den tag durch macht.
                                          eigentlich ist er ja nur dazu da einstellungen vorzunehmen?
                                          hattest du einen browser mit der admin ansicht offen?
                                          wenn sich so ein restart regelmäßig wiederholt ist das meist ein speicherproblem. ein oder mehrere skripte benötigen viel speicher und das betriebssystem entscheidet irgendwann dann mal den prozess neu zu starten. das könntest du dann auch mal im syslog des betriebssystems (bei linux) schauen. schlüsselwörter wären fatal oder error oder warn
                                          als nächstes müsstest du mal deine skripte durchschauen ob du da ein schedule oder cron drin hast, was zur uhrzeit passt. ggfs auch nochrmale wiederholungen beachten, bei denen sich dann ausgerechnet um 23 uhr mehrere treffen und dann das system in schwierigkeiten bringt.
                                          auch problematische javascript kann sogenannte memory leaks erzeugen, bei dem speicher geblockt wird aber nicht mehr freigegeben wird (meist bei setInterval/setTimeout, insbesondere dann wenn da was verschachtelt statt findet.)
                                          ggfs. wirst du skripte auch mal temporär deaktivieren müssen. alternativ können zusätzlich eingefügte logausgaben auch etwas mehr informationen liefern wann da was ausgeführt wird (vergrößert aber dann wieder die last auf das system und ggfs memory)
                                          Links im Profil
