  4. Shelly Adapter - genereller Support
    6.8k
mcm1957shelly
525 Beiträge 72 Kommentatoren 73.8k Aufrufe 53 Beobachtet
    @Peter-c sagte in Shelly Adapter - genereller Support:
    Incorrect username (expected "shelly_Plugs"
    ...und nicht shelly_PlugS
    Peter c
    schrieb am zuletzt editiert von Peter c
    #291
    @Homoran Oh ja stimmt. Shame on me.....
    Es ist immer der user
    • P Peter c
      @mcm1957 Habe nun das PW im Adapter geprüft und beim shelly 1mini gen3 erneut eingegeben, neu gebootet. Dann die Shelly Instanz neu gestartet. Und dass ist dann protokolliert worden.
      2025-12-02 13:53:50.335 - error: shelly.0 (28807) [MQTT] Wrong MQTT authentication of client "shelly1minig3-e4b32328d3c8": Incorrect username (expected "shelly_Plugs")
      2025-12-02 13:53:50.357 - info: shelly.0 (28807) [MQTT] Client Close: (shelly1minig3 / shelly1minig3-e4b32328d3c8 / shelly1minig3#e4b32328d3c8#1) (false)
      2025-12-02 13:54:15.176 - info: host.iobroker stopInstance system.adapter.shelly.0 (force=false, process=true)
      2025-12-02 13:54:15.186 - info: shelly.0 (28807) Got terminate signal TERMINATE_YOURSELF
      2025-12-02 13:54:15.193 - info: shelly.0 (28807) terminating
      2025-12-02 13:54:15.195 - info: shelly.0 (28807) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-12-02 13:54:15.236 - info: host.iobroker stopInstance system.adapter.shelly.0 send kill signal
      2025-12-02 13:54:15.697 - info: shelly.0 (28807) terminating
      2025-12-02 13:54:15.796 - info: host.iobroker instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-12-02 13:54:19.382 - info: host.iobroker instance system.adapter.shelly.0 in version "10.4.1" started with pid 29166
      2025-12-02 13:54:23.291 - info: shelly.0 (29166) starting. Version 10.4.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.19.1, js-controller: 7.0.7
      2025-12-02 13:54:23.889 - info: shelly.0 (29166) [firmwareUpdate] Auto-Update enabled - devices will be updated automatically
      2025-12-02 13:54:23.890 - info: shelly.0 (29166) Starting in MQTT mode. Listening on 0.0.0.0:1882 (QoS 0)
      2025-12-02 13:54:29.587 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-80646fe770c4" connected from 192.168.178.126!
      2025-12-02 13:54:29.598 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-a0a3b3e84258" connected from 192.168.178.199!
      2025-12-02 13:54:29.603 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-d4d4da7c3fdc" connected from 192.168.178.98!
      2025-12-02 13:54:29.968 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-d48afc56889c" connected from 192.168.178.105!
      2025-12-02 13:54:30.194 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-a0a3b3e82c7c" connected from 192.168.178.106!
      2025-12-02 13:54:30.524 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-e465b843483c" connected from 192.168.178.130!
      2025-12-02 13:54:32.182 - info: shelly.0 (29166) [MQTT] Device with client id "shellyplusplugs-d48afc560ac0" connected from 192.168.178.116!
      2025-12-02 13:54:45.190 - error: shelly.0 (29166) [MQTT] Wrong MQTT authentication of client "shelly1minig3-e4b32328d3c8": Incorrect username (expected "shelly_Plugs")
      2025-12-02 13:54:45.219 - info: shelly.0 (29166) [MQTT] Client Close: (shelly1minig3 / shelly1minig3-e4b32328d3c8 / shelly1minig3#e4b32328d3c8#1) (false)
      mcm1957M Online
      mcm1957M Online
      mcm1957
      #292
      2025-12-02 13:53:50.335 - error: shelly.0 (28807) [MQTT] Wrong MQTT authentication of client "shelly1minig3-e4b32328d3c8": **Incorrect username** (expected "shelly_Plugs")
      Auch wenns schon gelöst ist - als Info für die Zukunft:
      Die Fehlermeldung sagt EINDEUTIG dass der Username nicht passt. Bei falschem Passwort würde die Meldung anders lauten und auf das falsche Kennwort hindeuten. Allerdinsg wird weder das falsche noch das erwartetet Passwort in diesem Fall gelogged :-)
      Support Repositoryverwaltung.
      LESEN - gute Forenbeitrage
        doubleyou
        #293
        ich habe ein problem mit einem shelly Dimmer2 gen1 der im adapter nicht auftaucht. iobroker auf raspi alle adapter und js aktuell.
        Das Problem: ich habe den iobroker in netzwerk1 . shelly1/GEN1 Shelly Dimmer2/Gen1 in netzwerk2 Verbindung der Netzwerke über VPN. Shellys in Netzwerk2 coap/http aktiviert und in shelly cloud aktiviert.
        Der shelly1 taucht im Netzwerk1 im Adapter auf der Dimmer nicht. beide Shellys von Netzwerk 1 über ip erreichbar. Wie kann ich den Adapter überreden den Dimmer anzunehmen? Alles mehrfach neu gestartet.
        Ich hoffe ich habe mich einigermaßen verständlich ausgedrückt.
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          #294
          Shelly cloud spielt mal nicht mit. Der Adapter benutzt die Cloud nicht.
          Sofern die beiden Netzte via vpn OHNE NAT verbunden sind sollte es prinzipiell gehen.
          Hast du beim Dimmer COAP UNICAST eingestellt? Siehe Doku https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-coap.md
          Falls eine Firmware-Version größer als 1.9.4 verwendet wird, musst ein CoIoT-Server auf den Shelly-Geräten konfiguriert werden (unicast).
            doubleyou
            #295
            Das war es. Vielen Dank für die Hilfe.
              musicnrw
              #296
              ich habe einen Shelly H&T G3 in iobroker mittels MQTT eingebunden. Das funktioniert auch soweit, das entsprechende Objekt wird unter "Shelly" aufgelistet. Nur sehe ich das Problem, dass das Gerät, um Energie zu sparen, ja immer nur kurz sendet und dann wieder in den Deep-sleep-mode fällt. Entsprechend dieses Verhaltens sehe ich in dem entsprechenden Shelly-Objekt im iobroker auch, dass eben keine Verbindung zum Gerät in diesen deep-sleep-Phasen existiert. Das wäre ja nicht tragisch, jedoch sehe ich auch nach längerem Zeitraum, in der das Gerät jetzt im iobroker existiert, keine entsprechenden sich ändernden Messwerte im Verlaufsdiagramm z.b. der Temperatur. Kriegt iobroker die kurzen "Wachphasen" einfach nicht mit?
              Hat einer einen Lösungsvorschlag?
              FabioF mcm1957M 2 Antworten Letzte Antwort
              • mcm1957M Online
                mcm1957M Online
                mcm1957
                #297
                Sobald der H&T sendet bekommt das ioBroker mit.
                Welche Adapterversion verwendest du?
                Was steht im Log? Schalt ggF das DEBUG Log ein . dann solltest du sehen ob bzw. was der H&T sendet.
                In den Stateattributen siehst du auch wann sie zuletzt aktualisisiert wurden.
                Sieht eigentlich eher so aus als würde der H&T gar keine Verbindung mit ioBroker aufnehmen. Check mal die MQTT Einstellung, insbesondere ob die IP Addressen des Hosts passen und ob die MQTT Optionen alle angehakt sind. (Sihe Dokumentation)
                • M musicnrw
                  FabioF Offline
                  FabioF Offline
                  Fabio
                  schrieb am zuletzt editiert von Fabio
                  #298
                  @musicnrw sagte in Shelly Adapter - genereller Support:
                  ...ja, das bekommt er mit und funktioniert einwandfrei. Ich habe über zehn der HT eingebunden.
                  Da könnte bei dir evtl. was falsch eingestellt sein.
                  Fabio
                  Iobroker:
                  • Matter over Thread Hilfe
                  • M musicnrw
                    mcm1957M Online
                    mcm1957M Online
                    mcm1957
                    #299
                    Check das mal (https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/de/protocol-mqtt.md)
                    Vor allem die RPC Einstellungen und die IP incl. Port
                    • mcm1957M mcm1957
                      musicnrw
                      #300
                      @mcm1957, genau die Einstellungen habe ich umgesetzt. Wenn ich am Shelly den Knopf (Reset-Button) kurz drücke, dmit er aufwacht, sehe ich das Gerät mit aktivem WLAN im iobroker. Aber das bleibt eben nur für die kurze Zeit, bis er wieder in den deep-sleep-Modus geht. Es kommen in der "wachen" Zeit leider auch keine Messwerte rein.
                      fuzzy1955F FabioF mcm1957M 3 Antworten Letzte Antwort
                      • M musicnrw
                        fuzzy1955F Online
                        fuzzy1955F Online
                        fuzzy1955
                        #301
                        Hi, @mcm1957
                        dasselbe Problem habe ich mit dem batteriebetriebenen Shelly Smoke auch. Gibt es da eine Lösung?
                        Gruß,
                        Fuzzy
                        Smart-Home-Automation unter IOB auf RASPI5, 16GB RAM, 50GB SSD, MariaSQL, VIS-2.
                        Anfang 2025 war ich Newbie in Sachen RaspBerry, Linux und IOB.
                        Jetzt läuft alles konstant gut und ich gebe gern meine Erfahrungen und mein Wissen an die Forums-User/Innen weiter.
                        Großes Danke an alle tatkräftigen Helfer im Forum!
                        • M musicnrw
                          FabioF Offline
                          FabioF Offline
                          Fabio
                          #302
                          es kommen nur Messwerte rein wenn sie sich auch geändert haben ansonsten nicht auch wenn du ihn aufweckst falls der Wert sich nicht verändert hat wirst du auch nichts im Iobroker sehen. So ist das jedefalls bei mir.
                          du kannst ihn an ein Netzteil hängen dann kommen Daten öfters rein.
                          Bitte lesen https://kb.shelly.cloud/knowledge-base/shelly-h-t-gen3
                          letzte Änderung war um 7.07 jetzt haben wir fast 9.00 Uhr.
                          Iobroker:
                          • fuzzy1955F fuzzy1955
                            Hi, @mcm1957
                            Gruß,
                            Fuzzy
                            mcm1957M Online
                            mcm1957M Online
                            mcm1957
                            #303
                            @fuzzy1955 sagte in Shelly Adapter - genereller Support:
                            Hi, @mcm1957
                            Gruß,
                            Fuzzy
                            Welches Problem hast du auch?
                            Die batteriebetriebenen Geräte wachen nur kurzzeitig auf und gehen dann wieder in den seep sleep. Im deep-sleep Zustand trennen die Shellies die WLAN Verbindung um Energie zu sparen. Dies ist von Shelly so implementiert und aus Gründen der Batterielebensdauer auch so sinnvoll. Diese Trennung der WLAN Verbindung ist kein Problem sondern "per Design" so vorgesehen.
                            fuzzy1955F 1 Antwort Letzte Antwort
                            • M musicnrw
                              mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              #304
                              Also der shelly sollte wie folgt lt. Doku senden:
                              Measuring and reporting
                              On batteries
                              When running on batteries the Device behaves as follows:
                              Wakes up every minute to do a measurement. If there is a 0.2 °C temperature or 3% humidity difference the screen updates. The default threshold for reporting is a change of 0.5 °C or 5%. If the change is less there will be no report sent.
                              If for two hours there is no report based on threshold values, the Device unconditionally (disregarding threshold values) reports its status to Shelly Cloud and other connected channels.
                              Due to self-heating a cool down period of 5 minutes is imposed. During this period the Device would not wake up at all.
                              On USB power supply
                              If powered via its USB port the Device will wake up every 5 minutes, perform a measurement, update its screen, unconditionally report to all connected channels, and sleep for 5 minutes.
                              User initiated report
                              If the user presses the Reset button (behind the cover) the Device will wake up, perform a measurement, update its screen, unconditionally report to all connected channels, and sleep for 5 minutes.
                              Wenn du auch beim Drücken des Reset Buttons keine geänderten Werte siehst dann stimmt was nicht - wobei du beachten musst dass die 5 Minuten jeden Update in der Zeit blockt. Sinnvoller Weise würde ich daher die Teperatur vor dem Drücken merkbar ändern (kurz warm anblasen od in den Kühlschrank legen).
                              Wenn da nichst kommt bitte
                              • gib mal die Adpater Version an die du benutzt
                              • aktiveiere das Log mit LEVEL DEBUG
                              Im Log muss der Connect des Shellies auftauchen. Weiters wird gelogged was er sendet. Prüf mal ob das ankommt oder ob der Shelly den ioBroker Host gar nicht erreicht. Und NEIN das Online Symbol sagt nichts darüber aus ob die MQTT Verbindung richtig eingestellt ist. Online / offline wird via ping / http geprüft. Also schau sicherheitshalber nochmal die IP und vor allem den Port den du im Shelly eingetragen hast genau an.
                              • mcm1957M mcm1957
                                Hi, @mcm1957
                                Gruß,
                                Fuzzy
                                fuzzy1955F Online
                                fuzzy1955F Online
                                fuzzy1955
                                #305
                                @mcm1957 sagte in Shelly Adapter - genereller Support:
                                Ja, das ist mir klar. Das Problem ist: Ich bringe den batteriebetriebenen Shelly Smoke bei Rauchalarm nicht zum Reagieren.
                                  FabioF Offline
                                  FabioF Offline
                                  Fabio
                                  #306
                                  ... was heißt das denn genau. Gibt er von sich aus keinen Alarm bei Rauch?
                                  Iobroker:
                                    mcm1957M Online
                                    mcm1957M Online
                                    mcm1957
                                    #307
                                    Damit wir alle vom selben Gerät reden:
                                    Geht es um einen Shelly Smoke (GEN1) oder einen Shelly Smoke Plus (GEN2) ?
                                    An sich sollten beide supported sein.
                                    Beim Gen 2 gilt dasseleb wie eben erst geschrieben - also bitte nochmals explizit die MQTT Daten prüfen.
                                    Beim Gen 1 hängts davon ab ob du COAP oder MQTT benutzt. Bei COAP bitte sicherstellen dass unicast ausgewählt ist.
                                    Wenn da Daten nicht ankommen gilt auch hier:
                                    Bitte ein DEBUG LOG erstellen und den Shelly aktivieren - ich weiß leider nicht wie man beim Smoke einen Testalarm auslösen kann (abgesehen von anrauchen oder Testspray).
                                    • HomoranH Homoran hat dieses Thema am aufgespalten
                                    • mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      #308
                                      Die nachfolgende Diskussion zum Thema "Welche Rauchmelderalternative zu Shelly" wurde abgespaltet und findet sich nun hier:
                                      https://forum.iobroker.net/topic/83226/welchen-rauchmelder
                                        musicnrw
                                        #309
                                        Jetzt nochmal zum Shelly H&T G3, also dem Ursprungspost:
                                        Als ich MQTT im Shelly eingerichtet und aktiviert habe, sind ja initial Messwerte für Temperatur und Luftfeuchte übertragen worden. Von daher muss die Kommunikation ja funktioniert haben mit iobroker. Aber eben nur 1x!
                                        Ich habe das Log mal angehängt, vielleicht findet jemand etwas verdächtiges:
                                          "deviceInfo": {
                                            "name": null,
                                            "id": "shellyhtg3-e4b3233c89bc",
                                            "mac": "E4B3233C89BC",
                                            "slot": 0,
                                            "key": "eyJhbGciOiJFUzM4NCIsInR5cCI6IkpXVCJ9.eyJpYXQiOjE3MzI3OTI0MDUsIm1hYyI6IkU0QjMyMzNDODlCQyIsIm0iOiJTM1NOLTBVMTJBIiwiYiI6IjIzNTAtQnJvYWR3ZWxsIiwiZnAiOiIwNzYzZGRhMiJ9.mvoIO2SxrWZfARG8MhlNwBPwP_RymUFGHaryVsE5TOg1mtCrb-LG9DRclbh50AVNk7B9gd6Vn9z-gIj9XBoIBF68qvu3--uJfQaPXmJc3u-cGpmaRbZEBD3R52OX0Aai",
                                            "batch": "2350-Broadwell",
                                            "fw_sbits": "04",
                                            "model": "S3SN-0U12A",
                                            "gen": 3,
                                            "fw_id": "20251211-072409/1.7.4-beta1-gfd54ba5",
                                            "ver": "1.7.4-beta1",
                                            "app": "HTG3",
                                            "auth_en": false,
                                            "auth_domain": null
                                          "logs": [
                                              "data": "Connected.",
                                              "ts": 1765778710.47,
                                              "level": 2,
                                              "fd": 1
                                              "seq": 140,
                                              "ts": 1765778711.095,
                                              "level": 2,
                                              "data": "shelly_debug.cpp:236    Streaming logs to 192.168.178.20:42339",
                                              "fd": 2
                                              "seq": 141,
                                              "ts": 1765778712.01,
                                              "level": 2,
                                              "data": "shos_lwip.cpp:196       ws(0x3fcc2328): IPv6 addrs: fe80::e6b3:23ff:fe3c:89bc,P 2003:c5:e730:f300:e6b3:23ff:fe3c:89bc,P fd1a:d087:cadd:0:e6b3:23ff:fe3c:89bc,t1",
                                              "fd": 2
                                              "seq": 142,
                                              "ts": 1765778712.014,
                                              "level": 2,
                                              "data": "shos_lwip.cpp:196       ws(0x3fcc2328): IPv6 addrs: fe80::e6b3:23ff:fe3c:89bc,P 2003:c5:e730:f300:e6b3:23ff:fe3c:89bc,P fd1a:d087:cadd:0:e6b3:23ff:fe3c:89bc,P",
                                              "fd": 2
                                              "seq": 143,
                                              "ts": 1765778714.653,
                                              "level": 2,
                                              "data": "shos_dns_sd_respond:236 ws(0x3fcc2328): Announced ShellyHTG3-E4B3233C89BC any@any (fe80::e6b3:23ff:fe3c:89bc,2003:c5:e730:f300:e6b3:23ff:fe3c:89bc,fd1a:d087:cadd:0:e6b3:23ff:fe3c:89bc)",
                                              "fd": 2
                                              "seq": 144,
                                              "ts": 1765778715.463,
                                              "level": 2,
                                              "data": "shelly_update.cpp:355   Checking for updates (1.7.4-beta1 20251211-072409/1.7.4-beta1-gfd54ba5 {\"bl\":16777983,\"t\":1765778715.460,\"ut\":10463234,\"hf\":109540,\"hmf\":100208,\"fs\":1048576,\"fsf\":712704,\"pkw\":0})",
                                              "fd": 2
                                              "seq": 145,
                                              "ts": 1765778715.465,
                                              "level": 2,
                                              "data": "shos_http_client.cp:316 0x3fcc6360: HTTPS GET https://updates.shelly.cloud/update/HTG3?src=auto1 (CA shelly_cloud.pem,ca.pem)",
                                              "fd": 2
                                              "seq": 146,
                                              "ts": 1765778715.653,
                                              "level": 2,
                                              "data": "shos_init.c:103         New min heap free: 94784",
                                              "fd": 2
                                              "seq": 147,
                                              "ts": 1765778715.885,
                                              "level": 2,
                                              "data": "shos_http_client.cp:656 0x3fcc6360: Finished; bytes 411, code 200, redir 0/3, auth 0, status OK",
                                              "fd": 2
                                              "seq": 148,
                                              "ts": 1765778715.894,
                                              "level": 2,
                                              "data": "shelly_notification:164 Status change of sys: {\"available_updates\":{\"stable\":{\"version\":\"1.7.1\"}}}",
                                              "fd": 2
                                              "seq": 149,
                                              "ts": 1765778720.142,
                                              "level": 2,
                                              "data": "shos_rpc_inst.c:243     shelly.checkforupdate [6@02a3bf84-02ca-41dc-bc8a-b77a444d1c7a] via WS_in 192.168.178.20:57487",
                                              "fd": 2
                                              "seq": 150,
                                              "ts": 1765778720.143,
                                              "level": 2,
                                              "data": "shelly_update.cpp:355   Checking for updates (1.7.4-beta1 20251211-072409/1.7.4-beta1-gfd54ba5 {\"bl\":16777983,\"t\":1765778720.137,\"ut\":15140900,\"hf\":107776,\"hmf\":94784,\"fs\":1048576,\"fsf\":712704,\"pkw\":0})",
                                              "fd": 2
                                              "seq": 151,
                                              "ts": 1765778720.144,
                                              "level": 2,
                                              "data": "shos_http_client.cp:316 0x3fcc6404: HTTPS GET https://updates.shelly.cloud/update/HTG3?src=auto_ui (CA shelly_cloud.pem,ca.pem)",
                                              "fd": 2
                                              "seq": 152,
                                              "ts": 1765778720.491,
                                              "level": 2,
                                              "data": "shos_init.c:103         New min heap free: 93616",
                                              "fd": 2
                                              "seq": 153,
                                              "ts": 1765778720.567,
                                              "level": 2,
                                              "data": "shos_http_client.cp:656 0x3fcc6404: Finished; bytes 411, code 200, redir 0/3, auth 0, status OK",
                                              "fd": 2
                                              "seq": 154,
                                              "ts": 1765778728.771,
                                              "level": 2,
                                              "data": "shos_mqtt_conn.c:674    MQTT0: Connecting to 192.168.178.50:1882 (192.168.178.50:1882)",
                                              "fd": 2
                                              "seq": 155,
                                              "ts": 1765778728.781,
                                              "level": 0,
                                              "data": "shos_mqtt_conn.c:506    MQTT0: Connect status 4",
                                              "fd": 2
                                              "seq": 156,
                                              "ts": 1765778728.782,
                                              "level": 2,
                                              "data": "shos_mqtt_conn.c:911    MQTT0: Connecting after 34986 ms",
                                              "fd": 2
                                              "seq": 157,
                                              "ts": 1765778728.785,
                                              "level": 2,
                                              "data": "shos_mqtt_conn.c:911    MQTT0: Connecting after 55273 ms",
                                              "fd": 2
                                        FabioF 1 Antwort Letzte Antwort
                                        • mcm1957M Online
                                          mcm1957M Online
                                          mcm1957
                                          #310
                                                "seq": 154,
                                                "level": 2,
                                                "fd": 2
                                                "seq": 155,
                                                "level": 0,
                                                "fd": 2
                                                "seq": 156,
                                                "level": 2,
                                                "fd": 2
                                                "seq": 157,
                                                "level": 2,
                                                "fd": 2
                                          Sieht für mich eher nach mqtt connect Problemen denn nach Datenaustausch aus. Nur ich kann das Shell Log nur oberflächslich interpretieren.
                                          Bitte häng ein Log des Shelly ADAPTERs mit level DEBUG an. Wichtig wäre der Zeitraum wo sich der H&T mit dem Adapter verbindet (das sollte eigentlich bei Tastendruck passieren). Gibt es sonst Meldungen im ioBroker Log (vom Shelly Adapter)? Welche Version des Shelly Adapters läuft bei dir?
