  4. instance system.adapter.roborock.0 terminated due to SIGILL
39 Beiträge 10 Kommentatoren 3.7k Aufrufe 7 Beobachtet
  • copystringC copystring
    @holly200289 mcm1957 ist nicht der Entwickler. Bei Problemen immer ein GitHub issue auf machen.
    holly200289H
    holly200289H
    holly200289
    @copystring
    Guten Morgen,
    ich bekomme jetzt den Adapter gar nicht mehr zum laufen, immer wieder die gleiche Fehlermeldung,
    hab nur ich das Problem ?
    Egal bei welcher Version
    roborock.0
    2025-10-23 05:12:59.183 info terminating
    roborock.0
    roborock.0
    2025-10-23 05:12:58.682 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    roborock.0
    2025-10-23 05:12:58.681 info terminating
    roborock.0
    roborock.0
    2025-10-23 05:12:58.679 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
    roborock.0
    2025-10-23 05:12:58.679 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at UDP.onMessage [as onmessage] (node:dgram:990:8)
    roborock.0
    roborock.0
    roborock.0
    2025-10-23 05:12:58.678 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
    roborock.0
    roborock.0
    2025-10-23 05:12:57.776 info MQTT initialized
    roborock.0
    roborock.0
    2025-10-23 05:12:57.054 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
    roborock.0
    roborock.0
    2025-10-23 05:12:57.048 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.21.0, js-controller: 7.0.7
    roborock.0
    roborock.0
    2025-10-23 05:12:56.688 info Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
    roborock.0
    roborock.0
    2025-10-23 05:12:52.925 info terminating
    roborock.0
    roborock.0
    2025-10-23 05:12:52.424 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    roborock.0
    2025-10-23 05:12:52.424 info terminating
    roborock.0
    roborock.0
    roborock.0
    2025-10-23 05:12:52.422 info Got terminate signal TERMINATE_YOURSELF
    roborock.0
    • T
      T
      thomas.flaechsig
      @holly200289 selbes Problem auch bei mir V 0.6.18 - Auch alle früheren Versionen mit gleichem Ergebnis.
      • holly200289H holly200289
        @copystring
        Guten Morgen,
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        roborock.0
        T
        T
        thomas.flaechsig
        @holly200289 jetzt mal über https://github.com/copystring/ioBroker.roborock/tree/dev_ts die 0.6.19 installiert - Läuft vorerst.
        T holly200289H 2 Antworten Letzte Antwort
        • T thomas.flaechsig
          T
          T
          ticaki
          @thomas-flaechsig sagte in instance system.adapter.roborock.0 terminated due to SIGILL:
          die nutze ich auch schon länger.
          Spenden
            holly200289H
            holly200289H
            holly200289
            @thomas-flaechsig
            Vielen dank für die Info, dass kann ich bestätigen momentan läuft es mit der Version.
            • Ro75R
              Ro75R
              Ro75
              Heute kam bei mir auch ein Firmwareupdate an. Nach Neustart gleicher Fehler wie schon hier zuletzt aufgeführt. 0.6.19 installiert (geht aber erst ab nodejs 22.x) läuft der Adapter wieder. Danke für alle Schreiber und Helfer.
              Ro75.
              • Ro75R Ro75
                Ro75.
                holly200289H
                holly200289H
                holly200289
                @ro75 said in instance system.adapter.roborock.0 terminated due to SIGILL:
                Ro75.
                holly200289H 1 Antwort Letzte Antwort
                  Ro75.
                  holly200289H
                  holly200289H
                  holly200289
                  @holly200289
                  Bis jetzt läuft der Adapter sehr gut unter der Nodejs 22.x) und dem Roborock Adapter mit der Version 0.6.19 als Test Adapter.
                  • Ro75R Ro75
                    Ro75.
                    holly200289H
                    holly200289H
                    holly200289
                    @ro75
                    • T
                      T
                      TheCrusher
                      schrieb am zuletzt editiert von TheCrusher
                      unter Roborock v 0.6.18 und Nodejs 20.x) ging bei mir der Adapter nicht mehr, war nur noch gelb.
                      folgende Fehler schmiss er ins Log
                      	2025-12-06 09:33:15.994	error	Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
                      roborock.0
                      2025-12-06 09:33:15.288	error	Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
                      roborock.0
                      2025-12-06 09:33:15.273	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
                      Nach dem update auf Nodejs 22.21.0 und Roborock v0.6.19, also die Konfiguration die bei Euch wohl läuft, hat sich immer noch nichts gebessert
                      	2025-12-06 13:46:31.042	error	Failed processing onReady on adapter (unknown): Error: Login returned empty userdata. at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/src/lib/httpApi.ts:141:12) at processTicksAndRejections (node:internal/process/task_queues:105:5) at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/src/lib/httpApi.ts:101:3) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/src/main.ts:92:4)
                      roborock.0
                      2025-12-06 13:46:31.012	error	Failed to initialize adapter: Login returned empty userdata.
                      roborock.0
                      2025-12-06 13:46:30.999	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
                      nur die Fehler im Log haben sich ein wenig geändert
                      Hab ich irgendwas überlesen? Jmd. eine Idee, ws ich noch machen kann?
                        @ro75
                        holly200289H
                        holly200289H
                        holly200289
                        Ich habe den Adapter nochmal gelöscht, und den Test Adapter nochmal neu Installiert jetzt ist aber eine
                        2FA Authentifizierung nötig, ich bekomme auch den Code zugeschickt, aber wo soll ich ihn eingeben ?
                        • holly200289H
                          holly200289H
                          holly200289
                          Leider funktoniert es immer noch nicht bei mir ?
                          • holly200289H
                            holly200289H
                            holly200289
                            roborock.0
                            Zeit
                            debug
                            Nachricht
                            roborock.0
                            2025-12-23 18:24:53.735 error ********************************************************************************
                            roborock.0
                            2025-12-23 18:24:53.735 error Please go to the 'Objects' tab in ioBroker, find the state 'roborock.0.loginCode', and enter the 6-digit code into the 'Value' column.
                            roborock.0
                            2025-12-23 18:24:53.735 error An email has been sent to marcushollenbachroborock@gmail.com.
                            roborock.0
                            2025-12-23 18:24:53.735 error ATTENTION: 2FA Code required!
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.734 error ********************************************************************************
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.538 info Starting Direct 2FA Login Flow...
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.538 warn Password login requires 2FA (Code 2031). Falling back to 2FA flow.
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.511 info Starting Password Login Flow...
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.396 info Initializing HTTP API with region: eu (https://euiot.roborock.com)
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.395 info Generated and saved new clientID: 549a4ac0335d4dd4f364ca141372ed21
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.322 info Build Info: Date=16.12.2025, 23:27:20, Commit=0.6.19
                            roborock.0
                            2025-12-23 18:24:53.322 info Starting adapter. This might take a few minutes...
                            roborock.0
                            roborock.0
                            roborock.0
                            2025-12-23 18:24:53.308 info starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#deaeb6dd6ff34c702fe7a91e8a8a7028544ddcbc) in /opt/iobroker/node_modules/iobroker.roborock, node: v22.21.1, js-controller: 7.1.0
                            roborock.0
                            • E
                              E
                              Elsa
                              schrieb am zuletzt editiert von Elsa
                              vermutlich leidet unseren Saros R10 am gleichen Problem, er will sich ums verrecken nicht mit dem Roborock Adapter verbinden.
                              Es funktioniert weder v0.6.18 noch der v0.6.19
                              System Infos:
                              Adapter Version
                              v0.6.18
                              JS-Controller Version
                              7.0.7
                              Node.js Version
                              v22.21.0
                              Operating System
                              linux
                              Firmware version of device
                              V02.50.56
                              Infos zum Problem unter v0.6.18:
                              Debug Log Upload (Adapter v0.6.18)
                              Debuglog - Saros 10R.txt
                              Infos zum Problem unter v0.6.19:
                              Debug Log Upload (Adapter v0.6.19)
                              Debuglog v0.6.19 - Saros 10R.txt
                              Ich hoffe ihr könnt weiterhelfen.
                              vG
                              kurzes Update:
                              nach wiederholter installation der v0.6.19 über den Link aus Post #28 läuft der Adapter jetzt :)
