  4. instance system.adapter.roborock.0 terminated due to SIGILL
    1.5k
39 Beiträge 10 Kommentatoren 3.7k Aufrufe 7 Beobachtet
  • holly200289H holly200289
    @copystring
    Okay vielen Dank, ich melde mich morgen nochmal
    holly200289H
    holly200289H
    holly200289
    @holly200289
    ich habe jetzt eine neue Email Adresse benutzt, und meinen Router neu gestartet, leider wieder kein Erfolg.
    roborock.0
    2025-10-19 22:12:09.630 info MQTT initialized
    roborock.0
    2025-10-19 22:12:09.267 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
    roborock.0
    2025-10-19 22:12:09.257 info starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
    roborock.0
    2025-10-19 22:11:37.800 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
    roborock.0
    2025-10-19 22:11:37.800 info terminating
    roborock.0
    roborock.0
    roborock.0
    2025-10-19 22:11:37.794 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
    roborock.0
    2025-10-19 22:11:37.794 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
    roborock.0
    roborock.0
    roborock.0
    2025-10-19 22:11:37.793 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
    roborock.0
    roborock.0
    2025-10-19 22:11:34.633 info MQTT initialized
    roborock.0
    roborock.0
    2025-10-19 22:11:34.348 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
    roborock.0
    roborock.0
    2025-10-19 22:11:34.337 info starting. Version 0.6.17 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
    roborock.0
    • copystringC copystring
      @holly200289 dann wurde dein Zugang vorübergehend gesperrt. Versuchs morgen, also in 24 Stunden, nochmal und starte den Router neu, damit du eine neue IP bekommst.
      holly200289H
      holly200289H
      holly200289
      @copystring
      Aktuell funktioniert es leider immer noch nicht, ich bekomme nur Fehlermeldungen
      • Ro75R Ro75
        sicher das es die 0.6.18 ist und nicht die 0.6.19? die 18 geht bei mir. Die Fehler, wie bei dir, kommen in der 19.
        Ro75.
        holly200289H
        holly200289H
        holly200289
        @ro75 said in instance system.adapter.roborock.0 terminated due to SIGILL:
        Ro75.
        ich habe jetzt so einiges versucht, leider ohne Erfolg
        das ist die Fehlermeldung
        roborock.0
        2025-10-20 21:14:46.191 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        2025-10-20 21:14:46.190 info terminating
        roborock.0
        2025-10-20 21:14:46.184 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
        roborock.0
        2025-10-20 21:14:46.184 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
        roborock.0
        2025-10-20 21:14:46.183 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
        roborock.0
        2025-10-20 21:14:42.539 info MQTT initialized
        roborock.0
        2025-10-20 21:14:42.247 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
        roborock.0
        2025-10-20 21:14:42.237 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
        roborock.0
        2025-10-20 21:14:10.889 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        2025-10-20 21:14:10.888 info terminating
        roborock.0
        2025-10-20 21:14:10.882 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
        roborock.0
        2025-10-20 21:14:10.882 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at Socket.emit (node:domain:489:12) at UDP.onMessage (node:dgram:988:8)
        roborock.0
        2025-10-20 21:14:10.881 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
        roborock.0
        2025-10-20 21:14:07.799 info MQTT initialized
        roborock.0
        2025-10-20 21:14:07.463 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
        roborock.0
        2025-10-20 21:14:07.453 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.20.0, js-controller: 7.0.7
        roborock.0
        2025-10-20 21:13:36.070 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
        roborock.0
        2025-10-20 21:13:36.070 info terminating
        • mcm1957M mcm1957
          @fonebone
          Ev. hilft dir ja auch das existierende:
          https://github.com/copystring/ioBroker.roborock/issues/809
          Lies weiter unten was der dev zur dev Release schrribt.
          holly200289H
          holly200289H
          holly200289
          @mcm1957
          Gibt es schon Lösungen für das Problem ?
          copystringC 1 Antwort Letzte Antwort
            @mcm1957
            copystringC
            copystringC
            copystring
            @holly200289 mcm1957 ist nicht der Entwickler. Bei Problemen immer ein GitHub issue auf machen.
            Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
            https://paypal.me/copystring
            holly200289H 2 Antworten Letzte Antwort
              holly200289H
              holly200289H
              holly200289
              @copystring
              ich habe ein neues GitHub issue aufgemacht
                holly200289H
                holly200289H
                holly200289
                @copystring
                Guten Morgen,
                ich bekomme jetzt den Adapter gar nicht mehr zum laufen, immer wieder die gleiche Fehlermeldung,
                hab nur ich das Problem ?
                Egal bei welcher Version
                roborock.0
                2025-10-23 05:12:59.183 info terminating
                roborock.0
                roborock.0
                2025-10-23 05:12:58.682 warn Terminated (UNCAUGHT_EXCEPTION): Without reason
                roborock.0
                roborock.0
                2025-10-23 05:12:58.681 info terminating
                roborock.0
                roborock.0
                2025-10-23 05:12:58.679 error Exception-Code: ERR_OSSL_WRONG_FINAL_BLOCK_LENGTH: error:1C80006B:Provider routines::wrong final block length
                roborock.0
                2025-10-23 05:12:58.679 error Error: error:1C80006B:Provider routines::wrong final block length at Decipheriv.final (node:internal/crypto/cipher:184:29) at localConnector.decryptECB (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:227:25) at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/localConnector.js:190:33) at Socket.emit (node:events:519:28) at UDP.onMessage [as onmessage] (node:dgram:990:8)
                roborock.0
                roborock.0
                roborock.0
                2025-10-23 05:12:58.678 error uncaught exception: error:1C80006B:Provider routines::wrong final block length
                roborock.0
                roborock.0
                2025-10-23 05:12:57.776 info MQTT initialized
                roborock.0
                roborock.0
                2025-10-23 05:12:57.054 info Starting adapter. This might take a few minutes depending on your setup. Please wait.
                roborock.0
                roborock.0
                2025-10-23 05:12:57.048 info starting. Version 0.6.18 in /opt/iobroker/node_modules/iobroker.roborock, node: v22.21.0, js-controller: 7.0.7
                roborock.0
                roborock.0
                2025-10-23 05:12:56.688 info Plugin sentry could not be initialized: ResolvedPlugin is not a constructor
                roborock.0
                roborock.0
                2025-10-23 05:12:52.925 info terminating
                roborock.0
                roborock.0
                2025-10-23 05:12:52.424 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                roborock.0
                2025-10-23 05:12:52.424 info terminating
                roborock.0
                roborock.0
                roborock.0
                2025-10-23 05:12:52.422 info Got terminate signal TERMINATE_YOURSELF
                roborock.0
                • T
                  T
                  thomas.flaechsig
                  @holly200289 selbes Problem auch bei mir V 0.6.18 - Auch alle früheren Versionen mit gleichem Ergebnis.
                    @copystring
                    Guten Morgen,
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    roborock.0
                    T
                    T
                    thomas.flaechsig
                    @holly200289 jetzt mal über https://github.com/copystring/ioBroker.roborock/tree/dev_ts die 0.6.19 installiert - Läuft vorerst.
                    T holly200289H 2 Antworten Letzte Antwort
                    • T thomas.flaechsig
                      T
                      T
                      ticaki
                      @thomas-flaechsig sagte in instance system.adapter.roborock.0 terminated due to SIGILL:
                      die nutze ich auch schon länger.
                      Spenden
                        holly200289H
                        holly200289H
                        holly200289
                        @thomas-flaechsig
                        Vielen dank für die Info, dass kann ich bestätigen momentan läuft es mit der Version.
                        • Ro75R
                          Ro75R
                          Ro75
                          Heute kam bei mir auch ein Firmwareupdate an. Nach Neustart gleicher Fehler wie schon hier zuletzt aufgeführt. 0.6.19 installiert (geht aber erst ab nodejs 22.x) läuft der Adapter wieder. Danke für alle Schreiber und Helfer.
                          Ro75.
                          • Ro75R Ro75
                            Ro75.
                            holly200289H
                            holly200289H
                            holly200289
                            Ro75.
                            holly200289H 1 Antwort Letzte Antwort
                              Ro75.
                              holly200289H
                              holly200289H
                              holly200289
                              @holly200289
                              Bis jetzt läuft der Adapter sehr gut unter der Nodejs 22.x) und dem Roborock Adapter mit der Version 0.6.19 als Test Adapter.
                              • Ro75R Ro75
                                Ro75.
                                holly200289H
                                holly200289H
                                holly200289
                                @ro75
                                • T
                                  T
                                  TheCrusher
                                  schrieb am zuletzt editiert von TheCrusher
                                  unter Roborock v 0.6.18 und Nodejs 20.x) ging bei mir der Adapter nicht mehr, war nur noch gelb.
                                  folgende Fehler schmiss er ins Log
                                  	2025-12-06 09:33:15.994	error	Failed to get home details: Error: loginApi is not initialized. at Roborock.initializeHomeDetails (/opt/iobroker/node_modules/iobroker.roborock/main.js:144:25) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:67:14)
                                  roborock.0
                                  2025-12-06 09:33:15.288	error	Error retrieving or setting clientID: Error: Login returned empty userdata. at Roborock.getUserData (/opt/iobroker/node_modules/iobroker.roborock/main.js:236:11) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Roborock.initializeRoborockApi (/opt/iobroker/node_modules/iobroker.roborock/main.js:103:21) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:65:34)
                                  roborock.0
                                  2025-12-06 09:33:15.273	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects.
                                  Nach dem update auf Nodejs 22.21.0 und Roborock v0.6.19, also die Konfiguration die bei Euch wohl läuft, hat sich immer noch nichts gebessert
                                  	2025-12-06 13:46:31.042	error	Failed processing onReady on adapter (unknown): Error: Login returned empty userdata. at http_api.initializeRealApi (/opt/iobroker/node_modules/iobroker.roborock/src/lib/httpApi.ts:141:12) at processTicksAndRejections (node:internal/process/task_queues:105:5) at http_api.init (/opt/iobroker/node_modules/iobroker.roborock/src/lib/httpApi.ts:101:3) at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/src/main.ts:92:4)
                                  roborock.0
                                  2025-12-06 13:46:31.012	error	Failed to initialize adapter: Login returned empty userdata.
                                  roborock.0
                                  2025-12-06 13:46:30.999	error	Error in getUserData: Login returned empty userdata.. This is most likely due to too many reconnects. Emptying UserData & HomeData
                                  nur die Fehler im Log haben sich ein wenig geändert
                                  Hab ich irgendwas überlesen? Jmd. eine Idee, ws ich noch machen kann?
                                    @ro75
                                    holly200289H
                                    holly200289H
                                    holly200289
                                    Ich habe den Adapter nochmal gelöscht, und den Test Adapter nochmal neu Installiert jetzt ist aber eine
                                    2FA Authentifizierung nötig, ich bekomme auch den Code zugeschickt, aber wo soll ich ihn eingeben ?
                                    • holly200289H
                                      holly200289H
                                      holly200289
                                      Leider funktoniert es immer noch nicht bei mir ?
                                      • holly200289H
                                        holly200289H
                                        holly200289
                                        roborock.0
                                        Zeit
                                        debug
                                        Nachricht
                                        roborock.0
                                        2025-12-23 18:24:53.735 error ********************************************************************************
                                        roborock.0
                                        2025-12-23 18:24:53.735 error Please go to the 'Objects' tab in ioBroker, find the state 'roborock.0.loginCode', and enter the 6-digit code into the 'Value' column.
                                        roborock.0
                                        2025-12-23 18:24:53.735 error An email has been sent to marcushollenbachroborock@gmail.com.
                                        roborock.0
                                        2025-12-23 18:24:53.735 error ATTENTION: 2FA Code required!
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.734 error ********************************************************************************
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.538 info Starting Direct 2FA Login Flow...
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.538 warn Password login requires 2FA (Code 2031). Falling back to 2FA flow.
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.511 info Starting Password Login Flow...
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.396 info Initializing HTTP API with region: eu (https://euiot.roborock.com)
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.395 info Generated and saved new clientID: 549a4ac0335d4dd4f364ca141372ed21
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.322 info Build Info: Date=16.12.2025, 23:27:20, Commit=0.6.19
                                        roborock.0
                                        2025-12-23 18:24:53.322 info Starting adapter. This might take a few minutes...
                                        roborock.0
                                        roborock.0
                                        roborock.0
                                        2025-12-23 18:24:53.308 info starting. Version 0.6.19 (non-npm: copystring/ioBroker.roborock#deaeb6dd6ff34c702fe7a91e8a8a7028544ddcbc) in /opt/iobroker/node_modules/iobroker.roborock, node: v22.21.1, js-controller: 7.1.0
                                        roborock.0
                                        • E
                                          E
                                          Elsa
                                          schrieb am zuletzt editiert von Elsa
                                          vermutlich leidet unseren Saros R10 am gleichen Problem, er will sich ums verrecken nicht mit dem Roborock Adapter verbinden.
                                          Es funktioniert weder v0.6.18 noch der v0.6.19
                                          System Infos:
                                          Adapter Version
                                          v0.6.18
                                          JS-Controller Version
                                          7.0.7
                                          Node.js Version
                                          v22.21.0
                                          Operating System
                                          linux
                                          Firmware version of device
                                          V02.50.56
                                          Infos zum Problem unter v0.6.18:
                                          Debug Log Upload (Adapter v0.6.18)
                                          Debuglog - Saros 10R.txt
                                          Infos zum Problem unter v0.6.19:
                                          Debug Log Upload (Adapter v0.6.19)
                                          Debuglog v0.6.19 - Saros 10R.txt
                                          Ich hoffe ihr könnt weiterhelfen.
                                          vG
                                          kurzes Update:
                                          nach wiederholter installation der v0.6.19 über den Link aus Post #28 läuft der Adapter jetzt :)
