  4. Adapterinstallation Fehlermeldungen aber Code 0
    6.5k
28 Beiträge 3 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • G Online
    G Online
    guitardoc
    Ich bekomme bei der Adapterinstallation die folgenden Fehlermeldungen, der Adapter scheint aber richtig installiert zu sein:
    $ iobroker url ta2k/ioBroker.vw-connect --host iobroker --debug
    install ta2k/ioBroker.vw-connect
    Installing ta2k/ioBroker.vw-connect... (System call)
    gyp info using node@22.21.0 | linux | x64
    (node:3690) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)
    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
    gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/cpu-features/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]
    Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'
    gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:519:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12)gyp ERR! System Linux 6.17.2-1-pvegyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok
    added 28 packages, and changed 48 packages in 10s263 packages are looking for funding run `npm fund` for details
    upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
    Updating objects from io-package.json for adapter "vw-connect" with version "0.7.15"
    Update "system.adapter.vw-connect.0"
    Process exited with code 0
    Muss ich mir da Gedanken machen?
    • G guitardoc
      @guitardoc sagte in Adapterinstallation Fehlermeldungen aber Code 0:
      Gewöhn dir doch den Mist mit GitHub ab. Das ist KEINE ordentliche Installation. Nimm den Adapter aus einem Repo.
      vw-connect
      github:	0.7.14
      latest:	0.7.13 for 16 days
      stable:	-.-.-
      Liegt also im Beta-Repo bereit.
      Die Installation sieht dann auch anders aus:
      $ iobroker add vw-connect auto --host chet --debug
      Installing iobroker.vw-connect@0.7.13... (System call)
      host.chet install adapter vw-connect
      upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
      upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
      upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
      upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
      Updating objects from io-package.json for adapter "vw-connect" with version "0.7.13"
      host.chet create instance vw-connect
      host.chet object system.adapter.vw-connect.0.alive created
      host.chet object system.adapter.vw-connect.0.connected created
      host.chet object system.adapter.vw-connect.0.compactMode created
      host.chet object system.adapter.vw-connect.0.cpu created
      host.chet object system.adapter.vw-connect.0.cputime created
      host.chet object system.adapter.vw-connect.0.memHeapUsed created
      host.chet object system.adapter.vw-connect.0.memHeapTotal created
      host.chet object system.adapter.vw-connect.0.memRss created
      host.chet object system.adapter.vw-connect.0.uptime created
      host.chet object system.adapter.vw-connect.0.inputCount created
      host.chet object system.adapter.vw-connect.0.outputCount created
      host.chet object system.adapter.vw-connect.0.eventLoopLag created
      host.chet object system.adapter.vw-connect.0.sigKill created
      host.chet object system.adapter.vw-connect.0.logLevel created
      host.chet object vw-connect.0.info created
      host.chet object vw-connect.0.info.connection created
      host.chet Set default value of vw-connect.0.info.connection: false
      host.chet object system.adapter.vw-connect.0 created
      • G Online
        G Online
        guitardoc
        Ich war am Testen der neuen Version, die Version im Beta-Repo lässt kein Login zu (die neuere Version von Github allerdings auch nicht). Sonst installiere ich nicht von Github.
        Thomas BraunT mcm1957M 2 Antworten Letzte Antwort
        • G guitardoc
          @guitardoc
          Joh, siehe:
          https://github.com/TA2k/ioBroker.vw-connect/issues/394
          • G Online
            G Online
            guitardoc
            Ja, es gibt auch einen Thread hier dazu im Forum. Wollte nur testen, ob es meinen Login auch betrifft (leider ja), da der Adapter unterschiedliche Logins unterstützt.
            Aber eine andere Frage - ich habe das Beta-Repo im ioB Admin ausgewählt, aber da komme ich nicht auf die Version 0.7.13? Da ist bei 0.6.0 Schluss.
            Die installierten Versionen anderer Adapter sind seltsamerweise auch alle größer als die Version im Beta-Repo. Und die habe ich alle von stable installiert. Oder hab ich hier falsche Links drin?
            • G guitardoc
              Repo auch aktualisiert?
              Geht per
              iob update
              • G Online
                G Online
                guitardoc
                Ahhh, verflixt!!! Das vergesse ich jedes Mal! Aaaarrrgh…
                • G guitardoc
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  Auch für Testinstallation ist eine Installation von Github nicht notwendig wenn der Maintainer eine saubere Versio n zum Testen bereitstellt. Er bracht dazu nur das releasescript aufrufen und kann gerne auch alpha Versionen (also z.B. 1.2.3-alpha.5) erzeugen. Diese sind unmittelbar nach dem Github basierenden Testes und dem an sich automatisch erfolgenden deploy von npm installierbar. Da alpha Versionen auch nicht ins repo kommen stören sie auch keine normalen latest / stable User. Und die Installation erfolgt mit den ganz normalen Mechanismen ohne irgendwelche Extrawürste...
                  Aber ja - ein geringfügig größerer Aufwand ist es halt für den Maintainer...
                  Support Repositoryverwaltung.
                  LESEN - gute Forenbeitrage
                  • G Online
                    G Online
                    guitardoc
                    Aber auch jetzt bei der Installation vom Beta-Repo kommen diese seltsamen Fehlermeldungen:
                    $ iobroker upgrade vw-connect@0.7.13 --debug
                    Update vw-connect from @0.7.13 to @0.7.13Uninstall npm packet "iobroker.vw-connect" for a clean re-installation
                    260 packages are looking for funding run `npm fund` for details
                    NPM version: 10.9.4Installing iobroker.vw-connect@0.7.13... (System call)
                    > cpu-features@0.0.10 install> node buildcheck.js > buildcheck.gypi && node-gyp rebuildgyp info it worked if it ends with okgyp info using node-gyp@8.4.1gyp info using node@22.21.0 | linux | x64(node:5777) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.(Use `node --trace-deprecation ...` to show where the warning was created)gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"gyp info spawn /usr/bin/python3gyp info spawn args [gyp info spawn args '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',gyp info spawn args 'binding.gyp',gyp info spawn args '-f',gyp info spawn args 'make',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/cpu-features/build/config.gypi',gyp info spawn args '-I',gyp info spawn args '/opt/iobroker/node_modules/node-gyp/addon.gypi',gyp info spawn args '-I',gyp info spawn args '/home/iobroker/.cache/node-gyp/22.21.0/include/node/common.gypi',gyp info spawn args '-Dlibrary=shared_library',gyp info spawn args '-Dvisibility=default',gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.21.0',gyp info spawn args '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.21.0/<(target_arch)/node.lib',gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/cpu-features',gyp info spawn args '-Dnode_engine=v8',gyp info spawn args '--depth=.',gyp info spawn args '--no-parallel',gyp info spawn args '--generator-output',gyp info spawn args 'build',gyp info spawn args '-Goutput_dir=.'gyp info spawn args ]Traceback (most recent call last): File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module> import gyp # noqa: E402 ^^^^^^^^^^ File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module> import gyp.input File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module> from distutils.version import StrictVersionModuleNotFoundError: No module named 'distutils'gyp ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)gyp ERR! stack at ChildProcess.emit (node:events:519:28)gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12)gyp ERR! System Linux 6.17.2-1-pvegyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v22.21.0gyp ERR! node-gyp -v v8.4.1gyp ERR! not ok added 29 packages in 6s263 packages are looking for funding run `npm fund` for detailsUpdating objects from io-package.json for adapter "vw-connect" with version "0.7.13"
                    • G guitardoc
                      Da kann ein Modul nicht gebaut werden, ich vermute
                      cpu-features
                      Das hat mit dem vw-connect aber nichts zu tun, wird aber solange wieder aufgegriffen, bis es da eine Lösung gibt.
                      Deswegen tauchte das auch bei mir nicht auf.
                      Wie schaut das System in Gänze aus?
                      Ausgabe von
                      iob diag
                      anschauen.
                      • G Online
                        G Online
                        guitardoc
                        Sieht eigentlich ganz OK aus. Die Fehlermeldungen im Log kommen vom Modus-Adapter und VW-Adapter (beide Fehler sind bekannt).
                        Script v.2025-08-09
                        *** BASE SYSTEM ***
                        Operating System: Debian GNU/Linux 13 (trixie)
                         Static hostname: iobroker
                               Icon name: computer-container
                                 Chassis: container ☐
                          Virtualization: lxc
                                  Kernel: Linux 6.17.2-1-pve
                            Architecture: x86-64
                        OS is similar to:
                        model name	: Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz
                        Docker          : false
                        Virtualization  : lxc
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         18:52:23 up  4:21,  1 user,  load average: 0.93, 0.83, 0.79
                        CPU threads: 2
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Debian stable version codenamed 'trixie'!
                        *** TIME AND TIMEZONES ***
                                       Local time: Wed 2025-11-26 18:52:23 CET
                                   Universal time: Wed 2025-11-26 17:52:23 UTC
                                         RTC time: n/a
                                      NTP service: inactive
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        mn
                        HOME=/home/mn
                        GROUPS=mn adm dialout sudo users iobroker
                        iobroker
                        HOME=/home/iobroker
                        SUDO_HOME=/home/mn
                        GROUPS=iobroker tty dialout audio video plugdev
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: 	false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session: 		tty
                        *** MEMORY ***
                        Mem:             12G        4.0G        7.7G        3.1M        1.3G        8.9G
                        Swap:           536M          0B        536M
                        Total:           13G        4.0G        8.2G
                        Active iob-Instances: 	33
                                12288 M total memory
                                 3768 M used memory
                                 3883 M active memory
                                  899 M inactive memory
                                 7309 M free memory
                                    0 M buffer memory
                                 1212 M swap cache
                                  512 M total swap
                                    0 M used swap
                                  512 M free swap
                        top - 18:52:23 up  4:21,  1 user,  load average: 0.93, 0.83, 0.79
                        Tasks:  65 total,   1 running,  64 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  9.5 us,  4.8 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  12288.0 total,   7308.6 free,   3769.4 used,   1212.8 buff/cache
                        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   8518.6 avail Mem
                        *** FAILED SERVICES ***
                          UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                        * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
                        * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                SUB    -> The low-level unit activation state, values depend on unit type.
                        2 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        dmesg: read kernel buffer failed: Operation not permitted
                        No critical errors detected
                        *** FILESYSTEM ***
                        Filesystem                       Type      Size  Used Avail Use% Mounted on
                        /dev/mapper/pve-vm--100--disk--0 ext4       63G   26G   35G  43% /
                        none                             tmpfs     492K  4.0K  488K   1% /dev
                        /dev/mapper/pve-root             ext4       94G   12G   78G  14% /dev/ttyACM0
                        udev                             devtmpfs   32G     0   32G   0% /dev/tty
                        tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
                        tmpfs                            tmpfs      13G  132K   13G   1% /run
                        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                        tmpfs                            tmpfs      32G  2.9M   32G   1% /tmp
                        tmpfs                            tmpfs     6.3G  8.0K  6.3G   1% /run/user/1001
                        Show mounted filesystems:
                        TARGET         SOURCE                                                 FSTYPE OPTIONS
                        /              /dev/mapper/pve-vm--100--disk--0                       ext4   rw,relatime,stripe=16
                        `-/dev/ttyACM0 /dev/mapper/pve-root[/var/lib/lxc/101/devices/ttyACM0] ext4   rw,relatime,errors=remount-ro
                        /var:
                        8.5G	/var/
                        7.4G	/var/lib
                        7.3G	/var/lib/mysql
                        7.1G	/var/lib/mysql/DBioBroker
                        990M	/var/log
                        Archived and active journals take up 988M in the file system.
                        /opt/iobroker/backups:
                        9.0G	/opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        843M	/opt/iobroker/iobroker-data/
                        497M	/opt/iobroker/iobroker-data/files
                        162M	/opt/iobroker/iobroker-data/backup-objects
                        92M	/opt/iobroker/iobroker-data/files/vis-2
                        67M	/opt/iobroker/iobroker-data/files/echarts.admin
                        150M	/opt/iobroker/iobroker-data/objects.jsonl
                        34M	/opt/iobroker/iobroker-data/states.jsonl
                        30M	/opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
                        26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
                        26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
                        USB-Devices by-id:
                        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2285504-if00
                        *** ZigBee Settings ***
                        HINT:
                        Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                        /dev/ttyACM0
                        zigbee.X
                        Extended Pan ID:
                        *** MASKED ***
                        Pan ID:
                        *** MASKED ***
                        Channel:
                        *** MASKED ***
                        Network Key:
                        *** MASKED ***
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs 	v22.21.0
                        /usr/bin/node 		v22.21.0
                        /usr/bin/npm 		10.9.4
                        /usr/bin/npx 		10.9.4
                        /usr/bin/corepack 	0.34.0
                        nodejs:
                          Installed: 22.21.0-1nodesource1
                          Candidate: 22.21.0-1nodesource1
                          Version table:
                         *** 22.21.0-1nodesource1 1001
                             22.20.0-1nodesource1 1001
                             22.19.0-1nodesource1 1001
                             22.18.0-1nodesource1 1001
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                             20.19.2+dfsg-1 500
                                500 http://deb.debian.org/debian trixie/main amd64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        Hosts:
                        iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 15690)
                        Core adapters versions
                        js-controller: 	7.0.7
                        admin: 		7.7.19
                        javascript: 	9.0.11
                        nodejs modules from github: 	0
                        Adapter State
                          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                        + system.adapter.eusec.0                  : eusec                 : iobroker                                 -  enabled
                          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                        + system.adapter.followthesun.0           : followthesun          : iobroker                                 -  enabled
                        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                        + system.adapter.hydrawise.0              : hydrawise             : iobroker                                 -  enabled
                        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                        + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
                        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                        + system.adapter.nanoleaf-lightpanels.0   : nanoleaf-lightpanels  : iobroker                                 -  enabled, port: 16021
                        + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                        + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                        + system.adapter.shuttercontrol.1         : shuttercontrol        : iobroker                                 -  enabled
                        + system.adapter.shuttercontrol.2         : shuttercontrol        : iobroker                                 -  enabled
                          system.adapter.solaredge.0              : solaredge             : iobroker                                 -  enabled
                        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1888, bind: 0.0.0.0
                        + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                        + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                          system.adapter.uv-protect.0             : uv-protect            : iobroker                                 -  enabled
                        + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
                          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                          system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
                          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                        + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                        + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyACM0
                        + instance is alive
                        ioBroker-Repositories
                        │ (index) │ name          │ url                                                      │ auto upgrade │
                        │ 0       │ 'stable'      │ 'https://download.iobroker.net/sources-dist.json'        │ false        │
                        │ 1       │ 'beta'        │ 'https://download.iobroker.net/sources-dist-latest.json' │ false        │
                        │ 2       │ 'live-stable' │ 'http://iobroker.live/repo/sources-dist.json'            │ false        │
                        │ 3       │ 'live-beta'   │ 'http://iobroker.live/repo/sources-dist-latest.json'     │ false        │
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "admin"        : 7.7.19   , installed 7.7.19
                        Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                        Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                        Adapter    "eusec"        : 2.0.3    , installed 2.0.3
                        Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                        Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                        Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                        Adapter    "hydrawise"    : 1.0.2    , installed 1.0.2
                        Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "logparser"    : 2.4.0    , installed 2.4.0
                        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                        Adapter    "nanoleaf-lightpanels": 1.4.0, installed 1.4.0
                        Adapter    "notification-manager": 1.3.0, installed 1.3.0
                        Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
                        Adapter    "shelly"       : 10.4.0   , installed 10.4.2-alpha.2
                        Adapter    "shuttercontrol": 2.0.7   , installed 2.0.7
                        Adapter    "solaredge"    : 1.4.1    , installed 1.4.1
                        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                        Adapter    "sql"          : 3.0.1    , installed 3.0.1
                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                        Adapter    "uv-protect"   : 0.6.9    , installed 0.6.9
                        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                        Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                        Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
                        Objects and States
                        Objects: 	96170
                        States: 	79976
                        W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
                        Hit:1 http://security.debian.org trixie-security InRelease
                        Hit:2 http://deb.debian.org/debian trixie InRelease
                        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
                        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Reading package lists...
                        Pending Updates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:44381         0.0.0.0:*               LISTEN      1000       72879191   1036/io.yahka.0
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          72861883   1/init
                        tcp        0      0 0.0.0.0:1887            0.0.0.0:*               LISTEN      1000       72870727   783/io.mqtt.0
                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1000       72870726   783/io.mqtt.0
                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       72879779   861/io.shelly.1
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       72864848   140/iobroker.js-con
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       72863795   140/iobroker.js-con
                        tcp        0      0 0.0.0.0:1888            0.0.0.0:*               LISTEN      1000       72873925   1125/io.sonoff.0
                        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      105        72863732   232/mariadbd
                        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          72863527   348/master
                        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          72863528   348/master
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       72879343   1173/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       72864231   521/io.admin.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          72861885   1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          72863180   1/init
                        tcp6       0      0 :::1984                 :::*                    LISTEN      1000       72879639   1289/go2rtc
                        tcp6       0      0 :::45397                :::*                    LISTEN      1000       72873856   1036/io.yahka.0
                        tcp6       0      0 :::8555                 :::*                    LISTEN      1000       72880288   1289/go2rtc
                        tcp6       0      0 :::8554                 :::*                    LISTEN      1000       72880286   1289/go2rtc
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       72880018   817/io.shelly.0
                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       72879468   1029/io.tuya.0
                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       72879469   1029/io.tuya.0
                        udp        0      0 0.0.0.0:59799           0.0.0.0:*                           1000       72880277   1140/io.eusec.0
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          72861884   1/init
                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       72880476   1337/io.nanoleaf-li
                        udp        0      0 0.0.0.0:36770           0.0.0.0:*                           1000       72880272   1140/io.eusec.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       72879182   1036/io.yahka.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       72879181   1036/io.yahka.0
                        udp6       0      0 :::8555                 :::*                                1000       72880289   1289/go2rtc
                        udp6       0      0 :::111                  :::*                                0          72861886   1/init
                        2025-11-26 17:57:40.228  - warn: modbus.0 (766) On error: {"errno":-104,"code":"ECONNRESET","syscall":"read"}
                        2025-11-26 17:57:41.229  - info: modbus.0 (766) Disconnected from slave 192.168.188.90
                        2025-11-26 17:58:41.237  - error: modbus.0 (766) Socket Error
                        2025-11-26 17:58:41.237  - error: modbus.0 (766) Client in error state.
                        2025-11-26 17:58:41.237  - warn: modbus.0 (766) On error: {"errno":-111,"code":"ECONNREFUSED","syscall":"connect","address":"192.168.188.90","port":1502}
                        2025-11-26 17:59:42.241  - info: modbus.0 (766) Connected to slave 192.168.188.90
                        2025-11-26 18:00:50.670  - error: vw-connect.0 (4648) Restart adapter
                        2025-11-26 18:01:24.464  - error: vw-connect.0 (5191) Login Failed
                        2025-11-26 18:01:24.464  - error: vw-connect.0 (5191) Restart Adapter in 30min
                        2025-11-26 18:15:38.682  - info: javascript.0 (3276) script.js.common.Beleuchtung.Schalte_Licht_Terrasse_infolge_Insektenschutztür: Terrassenbeleuchtung wird infolge Insektenschutztür eingeschaltet.
                        2025-11-26 18:15:38.684  - info: javascript.0 (3276) script.js.common.Fenster.Kombinationen_der_Kontaktsensoren: Kombination der Kontaktsensoren Wohnzimmer Tür zur Terrasse: true, Auslöser: offen geschlossen/angekippt
                        2025-11-26 18:15:49.577  - info: javascript.0 (3276) script.js.common.Fenster.Kombinationen_der_Kontaktsensoren: Kombination der Kontaktsensoren Wohnzimmer Tür zur Terrasse: false, Auslöser: offen geschlossen/angekippt
                        2025-11-26 18:16:38.682  - info: javascript.0 (3276) script.js.common.Beleuchtung.Schalte_Licht_Terrasse_infolge_Insektenschutztür: Terrassenbeleuchtung infolge Insektenschutztür wird ausgeschaltet.
                        2025-11-26 18:31:24.464  - error: vw-connect.0 (5191) Restart adapter
                        2025-11-26 18:32:04.356  - error: vw-connect.0 (5541) Login Failed
                        2025-11-26 18:32:04.357  - error: vw-connect.0 (5541) Restart Adapter in 30min
                        2025-11-26 18:36:02.406  - error: vw-connect.0 (5658) No Login Form found for type: Id
                        2025-11-26 18:36:02.407  - error: vw-connect.0 (5658) Login Failed
                        2025-11-26 18:36:02.407  - error: vw-connect.0 (5658) Restart Adapter in 30min
                        2025-11-26 18:38:08.210  - info: homeconnect.0 (1114) DISCONNECTED: 011070386308002348
                        2025-11-26 18:38:09.632  - info: homeconnect.0 (1114) 011070386308002348/programs/active/options: HomeAppliance is offline.
                        2025-11-26 18:38:24.450  - info: uv-protect.0 (5808) starting. Version 0.6.9 in /opt/iobroker/node_modules/iobroker.uv-protect, node: v22.21.0, js-controller: 7.0.7
                        2025-11-26 18:38:31.197  - info: uv-protect.0 (5808) Terminated (NO_ERROR): Without reason
                        2025-11-26 18:39:47.205  - info: homeconnect.0 (1114) CONNECTED: 011070386308002348
                        2025-11-26 18:39:48.114  - info: homeconnect.0 (1114) 011070386308002348/programs/active: There is no program active.
                        • G guitardoc
                          Script v.2025-08-09
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                          CPU threads: 2
                                           RTC time: n/a
                                    RTC in local TZ: no
                          mn
                          HOME=/home/mn
                          iobroker
                          HOME=/home/iobroker
                          SUDO_HOME=/home/mn
                          Display-Manager:
                          Desktop:
                          Session: 		tty
                          *** MEMORY ***
                          Swap:           536M          0B        536M
                                   3768 M used memory
                                   7309 M free memory
                                      0 M buffer memory
                                   1212 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          *** FILESYSTEM ***
                          /var:
                          8.5G	/var/
                          7.4G	/var/lib
                          7.3G	/var/lib/mysql
                          990M	/var/log
                          USB-Devices by-id:
                          HINT:
                          /dev/ttyACM0
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm 		10.9.4
                          /usr/bin/npx 		10.9.4
                          nodejs:
                            Version table:
                               20.19.2+dfsg-1 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          admin: 		7.7.19
                          javascript: 	9.0.11
                          Adapter State
                          + instance is alive
                          Objects and States
                          Objects: 	96170
                          States: 	79976
                          Pending Updates: 0
                          @guitardoc
                          Okay, schau dir den tree an.
                          cd /opt/iobroker
                          npm ls
                          npm ls cpu-features
                          • G Online
                            G Online
                            guitardoc
                            mn@iobroker:~$ cd /opt/iobroker
                            mn@iobroker:/opt/iobroker$ npm ls
                            iobroker.inst@3.0.0 /opt/iobroker
                            +-- iobroker.admin@7.7.19
                            +-- iobroker.alias-manager@2.0.0
                            +-- iobroker.backitup@3.3.10
                            +-- iobroker.cloud@5.0.1
                            +-- iobroker.discovery@5.0.0
                            +-- iobroker.echarts@1.9.2
                            +-- iobroker.eusec@2.0.3
                            +-- iobroker.feiertage@1.2.1
                            +-- iobroker.followthesun@0.5.2
                            +-- iobroker.homeconnect@1.4.3
                            +-- iobroker.hydrawise@1.0.2
                            +-- iobroker.javascript@9.0.11
                            +-- iobroker.js-controller@7.0.7
                            +-- iobroker.logparser@2.4.0
                            +-- iobroker.modbus@6.3.2
                            +-- iobroker.mqtt@6.1.4
                            +-- iobroker.nanoleaf-lightpanels@1.4.0
                            +-- iobroker.notification-manager@1.3.0
                            +-- iobroker.pvforecast@5.0.0
                            +-- iobroker.shelly@10.4.2-alpha.2
                            +-- iobroker.shuttercontrol@2.0.7
                            +-- iobroker.simple-api@2.8.0
                            +-- iobroker.socketio@6.7.1
                            +-- iobroker.solaredge@1.4.1
                            +-- iobroker.sonoff@3.2.1
                            +-- iobroker.sql@3.0.1
                            +-- iobroker.telegram@4.1.0
                            +-- iobroker.tuya@3.16.0
                            +-- iobroker.uv-protect@0.6.9
                            +-- iobroker.viessmannapi@2.4.3
                            +-- iobroker.vis-2-widgets-material@1.4.10
                            +-- iobroker.vis-2@2.13.4
                            +-- iobroker.vis-map@1.1.2
                            +-- iobroker.vis-materialdesign@0.5.9
                            +-- iobroker.vis@1.5.6
                            +-- iobroker.vw-connect@0.7.13
                            +-- iobroker.weatherunderground@3.7.0
                            +-- iobroker.web@7.0.8
                            +-- iobroker.ws@2.6.2
                            +-- iobroker.yahka@1.1.5
                            `-- iobroker.zigbee@3.1.5
                            mn@iobroker:/opt/iobroker$ npm ls cpu-features
                            `-- (empty)
                            • G guitardoc
                              `-- (empty)
                              @guitardoc
                              Bei mir liegt das unterhalb vom admin@7.7.20:
                              echad@chet:/opt/iobroker $ npm ls cpu-features
                              └─┬ iobroker.admin@7.7.20
                                └─┬ @iobroker/plugin-docker@0.1.6
                                  └─┬ dockerode@4.0.9
                                    └─┬ docker-modem@5.0.6
                                      └─┬ ssh2@1.17.0
                                        └── cpu-features@0.0.10
                              • G Online
                                G Online
                                guitardoc
                                Hmm, das ist wohl irgendwann was schief gelaufen. Ich bin auf Trixie, liegt es daran?
                                Ansonsten - wie kann ich das beheben?
                                • G guitardoc
                                  Nein.
                                  iob upgrade admin@7.7.19 --host iobroker --debug
                                  • Thomas BraunT Online
                                    Gerade nochmal auf meinem Test-System geschaut:
                                    [thomas@daleth iobroker]$ npm ls cpu-features
                                    └─┬ iobroker.admin@7.7.19
                                        └─┬ dockerode@4.0.9
                                            └─┬ ssh2@1.17.0
                                    Auch bei admin@7.7.19 war das schon eine Abhängigkeit vom plugin-docker
                                    • G Online
                                      G Online
                                      guitardoc
                                      Bei mir läuft kein Docker, das System liegt auf einem Proxmox LXC und läuft auf einem headless Debian Trixie.
                                      • G guitardoc
                                        Hier läuft auch kein Docker.
                                        • G Online
                                          G Online
                                          guitardoc
                                          Ahh, ich dachte, weil da oben was von Docker stand.
                                          Hmm, was kann ich denn nun machen?
