  3. Off Topic
  4. Homematic RPC liefert keine Statusänderungen
    5.9k
23 Beiträge 5 Kommentatoren 1.7k Aufrufe 3 Beobachtet
  • haselchenH haselchen
    @heldchen
    Mehr Infos liefern.
    Zuerst mal in Codetags die Ausgabe von
    iob diag
    Sollte es nicht auf Anhieb funktionieren
    iob fix
    vorher.
    heldchen
    schrieb am zuletzt editiert von heldchen
    @haselchen
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: PM-iObroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.14.11-4-pve
        Architecture: x86-64
    OS is similar to:
    model name      : 13th Gen Intel(R) Core(TM) i9-13900H
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     01:33:36 up 4 min,  2 users,  load average: 1.02, 1.35, 1.28
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-10-26 01:33:36 CEST
               Universal time: Sat 2025-10-25 23:33:36 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    admin
    HOME=/home/admin
    GROUPS=admin adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            2.1G        1.5G        103M        118K        578M        682M
    Swap:           2.1G          0B        2.1G
    Total:          4.3G        1.5G        2.3G
    Active iob-Instances:   22
             2048 M total memory
             1398 M used memory
             1456 M active memory
              335 M inactive memory
               97 M free memory
                0 M buffer memory
              552 M swap cache
             2048 M total swap
                0 M used swap
             2048 M free swap
    top - 01:33:37 up 4 min,  2 users,  load average: 0.94, 1.33, 1.27
    Tasks:  48 total,   1 running,  47 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   2048.0 total,     95.9 free,   1399.9 used,    552.3 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.    648.1 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--405--disk--0 ext4       20G  4.6G   14G  25% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   32G     0   32G   0% /dev/tty
    tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
    tmpfs                            tmpfs      13G  112K   13G   1% /run
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--405--disk--0 ext4   rw,relatime,stripe=16
    /var:
    635M    /var/
    335M    /var/cache
    331M    /var/cache/apt
    255M    /var/cache/apt/archives
    152M    /var/log/journal/c643c63321f8461eb5173bd401c846d2
    Archived and active journals take up 151.5M in the file system.
    /opt/iobroker/backups:
    500M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    499M    /opt/iobroker/iobroker-data/
    374M    /opt/iobroker/iobroker-data/files
    104M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    48M     /opt/iobroker/iobroker-data/files/iot.admin
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    25M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js.map
    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
    18M     /opt/iobroker/iobroker-data/objects.jsonl
    11M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.5
    /usr/bin/node           v20.19.5
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.33.0
    nodejs:
      Installed: 20.19.5-1nodesource1
      Candidate: 20.19.5-1nodesource1
      Version table:
     *** 20.19.5-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.4-1nodesource1 1001
         20.19.3-1nodesource1 1001
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main amd64 Packages
            500 http://security.debian.org bookworm-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    PM-iObroker         PM-iObroker (version: 7.0.7, hostname: PM-iObroker   , alive, uptime: 226)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     1
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    Adapter State
    + system.adapter.admin.0                  : admin                 : PM-iObroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                 : alexa2                : PM-iObroker                              - disabled
    + system.adapter.backitup.0               : backitup              : PM-iObroker                              -  enabled
    + system.adapter.discovery.0              : discovery             : PM-iObroker                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : PM-iObroker                              -  enabled
    + system.adapter.hm-rega.1                : hm-rega               : PM-iObroker                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.3                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.4                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
    + system.adapter.hm-rpc.5                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : PM-iObroker                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : PM-iObroker                              -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : PM-iObroker                              - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : PM-iObroker                              - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : PM-iObroker                              - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: PM-iObroker                              - disabled
      system.adapter.influxdb.1               : influxdb              : PM-iObroker                              - disabled, port: 8086
    + system.adapter.info.0                   : info                  : PM-iObroker                              -  enabled
    + system.adapter.iot.0                    : iot                   : PM-iObroker                              -  enabled
    + system.adapter.javascript.0             : javascript            : PM-iObroker                              -  enabled
    + system.adapter.lg-ess-home.0            : lg-ess-home           : PM-iObroker                              -  enabled
      system.adapter.mielecloudservice.0      : mielecloudservice     : PM-iObroker                              -  enabled
    + system.adapter.myenergi.1               : myenergi              : PM-iObroker                              -  enabled
    + system.adapter.myvbus.0                 : myvbus                : PM-iObroker                              -  enabled
    + system.adapter.shelly.0                 : shelly                : PM-iObroker                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.viessmannapi.0           : viessmannapi          : PM-iObroker                              -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : PM-iObroker                              - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : PM-iObroker                              - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : PM-iObroker                              - disabled
      system.adapter.vis-history.0            : vis-history           : PM-iObroker                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PM-iObroker                              - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : PM-iObroker                              - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : PM-iObroker                              - disabled
      system.adapter.vis-metro.0              : vis-metro             : PM-iObroker                              - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : PM-iObroker                              - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : PM-iObroker                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : PM-iObroker                              - disabled
      system.adapter.vis-weather.0            : vis-weather           : PM-iObroker                              - disabled
      system.adapter.vis.0                    : vis                   : PM-iObroker                              -  enabled
    + system.adapter.web.0                    : web                   : PM-iObroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zehnder-cloud.0          : zehnder-cloud         : PM-iObroker                              - disabled
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.2    , installed 7.7.2
    Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.17.0   , installed 1.17.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "iot"          : 3.3.0    , installed 3.3.0
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lg-ess-home"  : 0.4.1    , installed 0.4.1
    Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
    Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
    Adapter    "myvbus"       : 0.6.0    , installed 0.6.0
    Adapter    "shelly"       : 10.2.0   , installed 10.2.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
    Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wireless-settings": 1.0.2, installed 1.0.2
    Adapter    "zehnder-cloud": 0.0.7    , installed 0.0.7
    Objects and States
    Objects:        11176
    States:         9748
    Hit:2 http://security.debian.org bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       99568770   1672/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       99568765   1672/iobroker.js-co
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          99557635   314/master
    tcp        0      0 192.168.1.248:2000      0.0.0.0:*               LISTEN      1000       99568364   1818/io.hm-rpc.1
    tcp        0      0 192.168.1.248:2001      0.0.0.0:*               LISTEN      1000       99569238   1803/io.hm-rpc.0
    tcp        0      0 192.168.1.248:2002      0.0.0.0:*               LISTEN      1000       99569420   1848/io.hm-rpc.3
    tcp        0      0 192.168.1.248:2003      0.0.0.0:*               LISTEN      1000       99569479   1863/io.hm-rpc.4
    tcp        0      0 192.168.1.248:2010      0.0.0.0:*               LISTEN      1000       99569379   1833/io.hm-rpc.2
    tcp        0      0 192.168.1.248:2011      0.0.0.0:*               LISTEN      1000       99568484   1878/io.hm-rpc.5
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       99570725   1953/io.shelly.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          99530558   1/init
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          99557636   314/master
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       99572886   2836/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       99568850   1690/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          99540970   1/init
    tcp6       0      0 :::111                  :::*                    LISTEN      0          99530560   1/init
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          99557450   95/dhclient
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          99530559   1/init
    udp6       0      0 :::111                  :::*                                0          99530561   1/init
    2025-10-26 01:31:18.694  - info: vis.0 (2659) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.19.5, js-controller: 7.0.7
    2025-10-26 01:31:19.401  - info: vis.0 (2659) Terminated (NO_ERROR): Without reason
    2025-10-26 01:31:19.929  - info: host.PM-iObroker instance system.adapter.vis.0 terminated while should be started once
    2025-10-26 01:31:22.120  - info: host.PM-iObroker instance system.adapter.web.0 in version "7.0.8" started with pid 2836
    2025-10-26 01:31:22.740  - info: web.0 (2836) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v20.19.5, js-controller: 7.0.7
    2025-10-26 01:31:22.815  - info: web.0 (2836) http server listening on port 8082
    2025-10-26 01:31:22.856  - info: web.0 (2836) socket.io server listening on port 8082
    2025-10-26 01:31:26.149  - info: host.PM-iObroker instance system.adapter.myenergi.1 in version "0.0.3" started with pid 2905
    2025-10-26 01:31:26.719  - info: myenergi.1 (2905) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.myenergi, node: v20.19.5, js-controller: 7.0.7
    2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: eddi - 0
    2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: harvi - 0
    2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: libbi - 0
    2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: zappi - 1
    2025-10-26 01:31:27.079  - info: myenergi.1 (2905) skipping asn
    2025-10-26 01:31:32.985  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-543204663b80" connected from 192.168.1.134!
    2025-10-26 01:31:34.303  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplug-s-6E9299" connected from 192.168.1.130!
    2025-10-26 01:31:34.453  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-5432046797c4" connected from 192.168.1.132!
    2025-10-26 01:31:35.364  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplusplugs-d4d4daeb85e0" connected from 192.168.1.136!
    2025-10-26 01:31:35.575  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-84fce63656c4" connected from 192.168.1.131!
    2025-10-26 01:31:36.295  - info: shelly.0 (1953) [MQTT] Device with client id "shellypro3em-34987a449758" connected from 192.168.1.251!
    2025-10-26 01:31:36.598  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-54320465e730" connected from 192.168.1.133!
    2025-10-26 01:31:37.572  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplug-s-0DA223" connected from 192.168.1.135!
    2025-10-26 01:31:37.776  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplusplugs-d4d4daeb55bc" connected from 192.168.1.119!
    2025-10-26 01:31:45.052  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplusplugs-d4d4daedbbb8" connected from 192.168.1.238!
    2025-10-26 01:31:48.190  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-543204664428" connected from 192.168.1.139!
    • H heldchen
      @haselchen
      Script v.2025-08-09
      *** BASE SYSTEM ***
        Virtualization: lxc
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 2
                       RTC time: n/a
                RTC in local TZ: no
      admin
      HOME=/home/admin
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Swap:           2.1G          0B        2.1G
               2048 M total memory
               1398 M used memory
                 97 M free memory
                  0 M buffer memory
                552 M swap cache
               2048 M total swap
                  0 M used swap
               2048 M free swap
      *** FILESYSTEM ***
      /var:
      635M    /var/
      335M    /var/cache
      331M    /var/cache/apt
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        11176
      States:         9748
      Pending Updates: 0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @heldchen
      Rein interessehalber, wozu brauchst Du 2 HM-Rega und 6 HM-RPC Instanzen?
      Edit:
      Nebenschauplatz: Node auf Stand bringen. Und eventuell kurz das Repo auf Beta stellen, die V3.0.1 vom HM-RPC installieren und wieder zurück auf Stable schalten.
      Dann wäre man soweit erstmal aktuell.
      H 2 Antworten Letzte Antwort
        @heldchen
        Edit:
        heldchen
        @haselchen Habe 2 Homematiczentralen, 2 Wohnungen getrennt. Da jeweils Wired, ip-wired und normale sowie ip Komponenten.
        • H heldchen
          @heldchen hab kein ipw, aber braucht das auch ne eigene Instanz?
          ich hab alleine 3 Instanzen bei hm, hmip und hmw
          H 1 Antwort Letzte Antwort
            heldchen
            @homoran Jeweils eine für rfd, 485(also HMW) und HMIP. Das ganze mal 2 bei mir. HMIPW braucht wohl keine eigene.
              @heldchen
              Edit:
              heldchen
              @haselchen Updates haben im Übrigen nichts verbessert in der Richtung
              • H heldchen
                haselchenH Offline
                haselchenH Offline
                haselchen
                @heldchen
                Naja, gibt jetzt x Möglichkeiten.
                CCU neu starten .
                Einstellungen von den besagten Instanzen posten (HM Rega /HM RPC)
                Firewall Einstellungen der CCU.
                • H heldchen
                  ich schalte mein Licht über Homematic wired(nicht ip) über direkte Verknüpfung eines io 7/12er Moduls. Das klappt super. Auch das Schalten über den IObroker (Objekt switch) klappt super. Was aber nicht klappt, ist die Aktualisierung des States im iobroker wenn ich per Hardware Schalter oder über die WebUI der Homematic den Schalter drücke. Polling habe ich schon auf 5 Sekunden gestellt. Was kann ich evtl noch tun?
                  vowillV Offline
                  vowillV Offline
                  vowill
                  schrieb am zuletzt editiert von vowill
                  @heldchen Von Zeit zu Zeit (und zufällig auch gestern) habe ich dieses Problem auch. Was dann hilft ist ein Aufruf der Instanz hm-rpc.x in der ioBroker-Oberfläche, Klick auf den Schraubenschlüssel und dann das Häkchen setzen bei "Geräte neu einlesen (einmalig)".
                  Leider habe ich noch keine Option gefunden, dieses einmalige Neu-Einlesen über ein Skript zu starten ...
                  ioBroker im lxc auf NUC / Aktive Instanzen: 38
                  • vowillV vowill
                    heldchen
                    @vowill Danke für den Hinweis, das werde ich nachher direkt mal versuchen! Ich hoffe das Ganze hat dann keine Effekte für die eingebundenen Datenpunkte in VIS und Skripten?
                    vowillV 1 Antwort Letzte Antwort
                    • H heldchen
                      vowillV Offline
                      vowillV Offline
                      vowill
                      @heldchen Nein, das ist tatsächlich nur eine erneute Synchronisation (und kann beliebig oft wiederholt werden).
                      • vowillV vowill
                        heldchen
                        @vowill Hat leider alles nix gebracht. Habe eine neue RPC Instanz angelegt, nun scheint es erstmal zu funktionieren.
                        • H heldchen
                          @heldchen das sieht dann aber nach Fehlkonfiguration aus.
                          @haselchen sagte in Homematic RPC liefert keine Statusänderungen:
                          hast du leider nicht gemacht
                            heldchen
                            RPC habe ich 1:1 so eingestellt wie den alten, und in Rega nur 485 von RPC4 auf RPC6 geändert und gespeichert.
                            • black.falcon87B Offline
                              black.falcon87
                              Hast du in den Einstellungen der Instanz etwas bei Callback Adresse eingetragen? Ich glaube da muss bei Verwendung von Containern bzw. Docker die Adresse vom ioBroker Host rein.
                              https://github.com/ioBroker/ioBroker.hm-rpc?tab=readme-ov-file#adapter-callback-address
                              • black.falcon87B black.falcon87
                                heldchen
                                alles genau wie beim alten RPC
                                • H heldchen
                                  @heldchen das steht im zweiten Reiter
                                    heldchen
                                    • H heldchen
                                      @heldchen da muss die IP des hosts eingetragen werden, sonst hast du das Problem bald wieder
                                        heldchen
                                        @homoran Ahh ok. Warum kommt das dann erst nach einer Zeit??
                                        • H heldchen
                                          @heldchen keine Ahnung!
                                          müsste eigentlich von Anfang an Probleme geben.
                                          Ich kenne mich mit Containern nicht aus.
                                          Vielleicht hat der die Route anfangs noch von der Installation.
