  4. Test Adapter NSPanel-lovelace-ui v1.x.x
    6.4k
1.3k Beiträge 36 Kommentatoren 306.2k Aufrufe 36 Beobachtet
  • Chris_71C Chris_71
    @apollon77
    Den BLE Adapter hatte ich mal installiert - ist aber schon länger wieder deinstalliert worden
    ilovegymI Offline
    ilovegymI Offline
    ilovegym
    #606
    @chris_71
    zeig doch mal das komplette "iob diag" in code-tags bitte
    Chris_71C 1 Antwort Letzte Antwort
    • ilovegymI ilovegym
      @chris_71
      Chris_71C Offline
      Chris_71C Offline
      Chris_71
      schrieb am zuletzt editiert von Chris_71
      #607
      @ilovegym
      Hier die Ausgabe von iob diag:
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 11 (bullseye)
         Static hostname: ioBroker
               Icon name: computer-vm
                 Chassis: vm
          Virtualization: kvm
                  Kernel: Linux 5.10.0-36-amd64
            Architecture: x86-64
      OS is similar to:
      model name      : Common KVM processor
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       15:43:49 up  3:17,  1 user,  load average: 3.69, 3.21, 2.86
      CPU threads: 8
      *** LIFE CYCLE STATUS ***
      Debian Release codenamed 'bullseye' reached its END OF LIFE and needs to be updated to the latest stable release 'trixie' NOW!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-10-23 15:43:49 CEST
                 Universal time: Thu 2025-10-23 13:43:49 UTC
                       RTC time: Thu 2025-10-23 13:43:50
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      root
      HOME=/xxxx
      GROUPS=xxxx
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev redis bluetooth
      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
      A root login is not required in most Linux Distributions.
      Run 'iobroker fix' or use the system tools to create a user.
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         false
      Unit display-manager.service could not be found.
      Display-Manager:
      Desktop:
      Session:                tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or r                                                un 'iobroker fix'
      *** MEMORY ***
      Mem:             13G        5.9G        6.1G        0.0K        2.0G        7.8G
      Swap:           2.0G          0B        2.0G
      Total:           16G        5.9G        8.2G
      Active iob-Instances:   63
              13980 M total memory
               5897 M used memory
                885 M active memory
               6401 M inactive memory
               6124 M free memory
                201 M buffer memory
               1756 M swap cache
               2046 M total swap
                  0 M used swap
               2046 M free swap
      top - 15:43:50 up  3:17,  1 user,  load average: 3.55, 3.19, 2.85
      Tasks: 172 total,   3 running, 169 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 45.6 us,  7.4 sy,  0.0 ni, 44.1 id,  0.0 wa,  0.0 hi,  2.9 si,  0.0 st
      MiB Mem :  13980.9 total,   6124.7 free,   5897.0 used,   1959.2 buff/cache
      MiB Swap:   2047.0 total,   2047.0 free,      0.0 used.   7760.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  6.9G     0  6.9G   0% /dev
      tmpfs          tmpfs     1.4G  536K  1.4G   1% /run
      /dev/sda1      ext4       20G   13G  5.8G  69% /
      tmpfs          tmpfs     6.9G     0  6.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.4G     0  1.4G   0% /run/user/0
      [Thu Oct 23 12:26:13 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
      [Thu Oct 23 12:26:13 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.5G    /var/
      2.0G    /var/log
      1.9G    /var/log/journal/3f2bf63e5c904f84996f00cc7f0fc49b
      510M    /var/lib
      Archived and active journals take up 1.8G in the file system.
      /opt/iobroker/backups:
      2.4G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      463M    /opt/iobroker/iobroker-data/
      331M    /opt/iobroker/iobroker-data/files
      52M     /opt/iobroker/iobroker-data/files/javascript.admin
      45M     /opt/iobroker/iobroker-data/files/devices.admin/static
      50M     /opt/iobroker/iobroker-data/objects.jsonl
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      28M     /opt/iobroker/iobroker-data/objects.json.migrated
      28M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      HINT:
      Your zigbee.2 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.5
      /usr/bin/node           v20.19.5
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.33.0
      nodejs:
        Installed: 20.19.5-1nodesource1
        Candidate: 20.19.5-1nodesource1
        Version table:
       *** 20.19.5-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.19.4-1nodesource1 1001
           20.19.3-1nodesource1 1001
           20.19.2-1nodesource1 1001
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u7 500
              500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      Hosts:
      ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 6782)
      Core adapters versions
      js-controller:  7.0.7
      admin:          7.7.2
      javascript:     8.9.2
      nodejs modules from github:     2
      +-- iobroker.homepilot20@0.0.72 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#3706cca661f6ac97f7b2d0a77043b9a79eb2847f)
      +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#2f50d0fc1fe0ca6ffac426d01434fd357657723a)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0                                                .0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : ioBroker                                 -  enabled
      + system.adapter.awtrix-light.2           : awtrix-light          : ioBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
        system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
      + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
      + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
        system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
        system.adapter.drops-weather.0          : drops-weather         : ioBroker                                 - disabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
        system.adapter.email.0                  : email                 : ioBroker                                 - disabled
      + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.energiefluss.1           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.energiefluss.2           : energiefluss          : ioBroker                                 -  enabled
      + system.adapter.espresense.0             : espresense            : ioBroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
        system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 - disabled
        system.adapter.heizoel24-mex.0          : heizoel24-mex         : ioBroker                                 -  enabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: xxxx
        system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 - disabled
      + system.adapter.homepilot20.0            : homepilot20           : ioBroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: xxx
        system.adapter.hue.1                    : hue                   : ioBroker                                 - disabled, port: xxx
      + system.adapter.hue.2                    : hue                   : ioBroker                                 -  enabled, port: xxx
      +  system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: xxxx
      + system.adapter.info.0                   : info                  : ioBroker                                 -  enabled
      + system.adapter.innogy-smarthome.0       : innogy-smarthome      : ioBroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
        system.adapter.lovelace.0               : lovelace              : ioBroker                                 - disabled, port: xxxx, bind: 0.0.0.0                                                , run as: admin
        system.adapter.matter.0                 : matter                : ioBroker                                 - disabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.1          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.2          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mihome-vacuum.3          : mihome-vacuum         : ioBroker                                 -  enabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : ioBroker                                 - disabled
      + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0                                                +  system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
      + system.adapter.octoprint.1              : octoprint             : ioBroker                                 -  enabled
        system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
      + system.adapter.owntracks.0              : owntracks             : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0
        system.adapter.places.0                 : places                : ioBroker                                 - disabled
      + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.1               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.2               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.3               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.4               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.5               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.6               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.7               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pushover.8               : pushover              : ioBroker                                 -  enabled
      + system.adapter.pvforecast.0             : pvforecast            : ioBroker                                 -  enabled
      + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
      + system.adapter.renault.0                : renault               : ioBroker                                 -  enabled
      + system.adapter.robonect.0               : robonect              : ioBroker                                 -  enabled
        system.adapter.robonect.1               : robonect              : ioBroker                                 - disabled
      + system.adapter.s7.0                     : s7                    : ioBroker                                 -  enabled
      + system.adapter.s7.1                     : s7                    : ioBroker                                 -  enabled
      + system.adapter.samsung_tizen.0          : samsung_tizen         : ioBroker                                 - disabled, port: xxxx
      + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0
      + system.adapter.smartgarden.0            : smartgarden           : ioBroker                                 -  enabled
      + system.adapter.solax.0                  : solax                 : ioBroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0                                                + system.adapter.sun2000.0                : sun2000               : ioBroker                                 -  enabled, port: xxxx
      + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.tuya.0                   : tuya                  : ioBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis                   : ioBroker                                 - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
        system.adapter.vis-jqui-mfd.0           : vis                   : ioBroker                                 - disabled
        system.adapter.vis-map.0                : vis-map               : ioBroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis                   : ioBroker                                 - disabled
        system.adapter.vis-metro.0              : vis                   : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0                                                .0, run as: admin
      + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
      + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://x.x.x.x
      + system.adapter.zigbee.1                 : zigbee                : ioBroker                                 -  enabled, port: tcp://x.x.x.x
        system.adapter.zigbee.2                 : zigbee                : ioBroker                                 - disabled, port: tcp://x.x.x.x
      + instance is alive
      + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0                                               , run as: admin
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: xxxx, bind: 0.0.0.0                                                .0, run as: admin
      ioBroker-Repositories
      │ (index) │ name      │ url        │ auto upgrade │
      │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
      │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
      │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
      │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.7.2    , installed 7.7.2
      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
      Adapter    "awtrix-light" : 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.3.5    , installed 3.3.5
      Adapter    "countdown"    : 3.0.0    , installed 3.0.0
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "device-watcher": 2.13.1  , installed 2.13.1
      Adapter    "devices"      : 1.2.8    , installed 1.2.8
      Adapter    "drops-weather": 1.2.7    , installed 1.2.7
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "espresense"   : 0.6.3    , installed 0.6.3
      Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
      Adapter    "heizoel24-mex": 1.5.0    , installed 1.5.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.5.1
      Adapter    "hue"          : 3.16.2   , installed 3.16.2
      Adapter    "ical"         : 1.17.0   , installed 1.17.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.7    , installed 7.0.7
      Adapter    "logparser"    : 2.4.0    , installed 2.4.0
      Adapter    "lovelace"     : 5.0.1    , installed 5.0.1
      Adapter    "matter"       : 0.5.5    , installed 0.5.5
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.3.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "owntracks"    : 1.1.0    , installed 1.1.0
      Adapter    "places"       : 1.3.0    , installed 1.3.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
      Adapter    "radar2"       : 2.4.0    , installed 2.4.0
      Adapter    "robonect"     : 1.4.2    , installed 1.4.2
      Adapter    "s7"           : 1.5.0    , installed 1.5.0
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "shelly"       : 10.2.0   , installed 10.2.0
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "solax"        : 0.9.20   , installed 0.9.20
      Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
      Adapter    "sun2000"      : 2.1.0    , installed 2.3.1
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
      Adapter    "weather-warnings": 0.8.0 , installed 0.8.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wled"         : 0.7.2    , installed 0.7.3
      Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
      Objects and States
      Objects:        38678
      States:         30075
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      2025-10-23 15:41:41.069  - info: host.ioBroker iobroker gyp info using node-gyp@7.1.2gyp info using node@20.19.5 | linux | x64
      2025-10-23 15:41:41.286  - info: host.ioBroker iobroker gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      2025-10-23 15:41:41.611  - info: host.ioBroker iobroker gyp ERR! UNCAUGHT EXCEPTION
      2025-10-23 15:41:41.612  - info: host.ioBroker iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)
      2025-10-23 15:41:41.613  - info: host.ioBroker iobroker gyp ERR! System Linux 5.10.0-36-amd64gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v20.19.5gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      2025-10-23 15:41:41.633  - info: host.ioBroker iobroker > classic-level@3.0.0 install> node-gyp-build
      2025-10-23 15:41:41.775  - info: openweathermap.0 (18438) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.5, js-controller: 7.0.7
      2025-10-23 15:41:42.092  - info: host.ioBroker iobroker gyp info it worked if it ends with ok
      2025-10-23 15:41:42.094  - info: host.ioBroker iobroker gyp info using node-gyp@7.1.2
      2025-10-23 15:41:42.095  - info: host.ioBroker iobroker gyp info using node@20.19.5 | linux | x64
      2025-10-23 15:41:42.254  - info: host.ioBroker iobroker gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
      2025-10-23 15:41:42.647  - info: host.ioBroker iobroker gyp ERR! UNCAUGHT EXCEPTION
      2025-10-23 15:41:42.649  - info: host.ioBroker iobroker gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9
      2025-10-23 15:41:42.650  - info: host.ioBroker iobroker gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)gyp ERR! System Linux 5.10.0-36-amd64gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
      2025-10-23 15:41:42.651  - info: host.ioBroker iobroker gyp ERR! cwd /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui/node_modules/classic-levelgyp ERR! node -v v20.19.5gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.
      2025-10-23 15:41:43.158  - info: host.ioBroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui/node_modules/classic-levelnpm error command failednpm error command sh -c node-gyp-build
      2025-10-23 15:41:43.166  - info: host.ioBroker iobroker npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-23T13_41_29_823Z-debug-0.log
      2025-10-23 15:41:43.214  - error: host.ioBroker iobroker npm warn deprecated npmlog@4.1.2: This package is no longer supported.npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.npm warn deprecated gauge@2.7.4: This package is no longer supported.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@20.19.5 | linux | x64gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)gyp ERR! System Linux 5.10.0-36-amd64gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/raw-socketgyp ERR! node -v v20.19.5gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@20.19.5 | linux | x64gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)gyp ERR! System Linux 5.10.0-36-amd64gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/usocketgyp ERR! node -v v20.19.5gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.gyp info it worked if it ends with okgyp info using node-gyp@7.1.2gyp info using node@20.19.5 | linux | x64gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"gyp ERR! UNCAUGHT EXCEPTION gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:188:23)gyp ERR! System Linux 5.10.0-36-amd64gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui/node_modules/classic-levelgyp ERR! node -v v20.19.5gyp ERR! node-gyp -v v7.1.2gyp ERR! Node-gyp failed to build your package.gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error code 7npm error path /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui/node_modules/classic-levelnpm error command failednpm error command sh -c node-gyp-buildnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-23T13_41_29_823Z-debug-0.log
      2025-10-23 15:41:43.216  - error: host.ioBroker iobroker host.ioBroker Cannot install iobroker.nspanel-lovelace-ui@latest: 7
      2025-10-23 15:41:44.240  - info: host.ioBroker iobroker exit 25
      2025-10-23 15:42:09.382  - info: owntracks.0 (9177) Client [S24Chris] closed
      2025-10-23 15:42:15.150  - info: openweathermap.0 (18438) Terminated (NO_ERROR): Without reason
      2025-10-23 15:42:15.675  - info: host.ioBroker instance system.adapter.openweathermap.0 having pid 18438 terminated with code 0 (NO_ERROR)
      2025-10-23 15:42:39.582  - info: owntracks.0 (9177) Client [S24Chris] connected
      2025-10-23 15:44:05.014  - info: javascript.0 (10111) script.js.E-Auto.Dacia_Spring.GPS_Test_Openstreetmap: null
      iob diag has finished.
        @ilovegym
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
                   Chassis: vm
            Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
        CPU threads: 8
                      NTP service: active
                  RTC in local TZ: no
        root
        HOME=/xxxx
        GROUPS=xxxx
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Swap:           2.0G          0B        2.0G
                 5897 M used memory
                  885 M active memory
                 6124 M free memory
                  201 M buffer memory
                 1756 M swap cache
                 2046 M total swap
                    0 M used swap
                 2046 M free swap
        *** FILESYSTEM ***
        /var:
        2.5G    /var/
        2.0G    /var/log
        510M    /var/lib
        USB-Devices by-id:
        HINT:
        tcp
        HINT:
        tcp
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        Hosts:
        admin:          7.7.2
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        38678
        States:         30075
        Pending Updates: 0
        #608
        @chris_71
        Bring das auf Debian 13
        Log dich NIE als root ein.
        Setz das BootTarget auf 'multi-user'.
        Verwende nodejs@22
        Veränder die Ausgabe nicht.
        Räum die ioBroker-Repositories auf.
        Vermutlich wegen zu alter python-Version.
          @chris_71
          Verwende nodejs@22
          Chris_71C Offline
          Chris_71C Offline
          Chris_71
          #609
          Nach der Deinstallation von 2 alten NPM Modulen (vom Radar2 Adapter V1.x) konnte der Adapter ohne Fehlermeldung installiert werden.
          Thomas BraunT ilovegymI 2 Antworten Letzte Antwort
            #610
            @chris_71
            Der Rest der Analyse bleibt aber dennoch gültig.
              ticaki
              #611
              Da ist ein Fehler drin, der verhindert das man neue Panels anlernt - sry wird behoben.
              Spenden
                ticaki
                #612
                0.6.8 (2025-10-24)
                • (ticaki) Error during conversion to fetch prevented adding of panels. Fixed.
                Spenden
                  ilovegymI Offline
                  ilovegymI Offline
                  ilovegym
                  #613
                  @chris_71 sagte in Betatest NSPanel-lovelace-ui v0.6.x:
                  Tu dir aber selbst n gefallen, und mach n Backup, setz das System am besten gleich mit dem aktuellen Trixie neu auf, damit du wieder uptodate bist. So schleppst du dir nur den Murks mit rum.. wird ja nicht besser und irgendwann geht dann gar nix mehr..
                  • M Online
                    M Online
                    Max_yeah
                    #614
                    Ich bekomme mein panel einfach nicht zum laufen. Ich hab schon mehrmals alles raus gelöscht (Objecte, Scripte, In der instanz) und neu angelegt. (v0.6.8)
                    Beim Neustart der Instanz bekomme ich aktuell diese Meldungen:
                    nspanel-lovelace-ui.0
                    2025-10-24 21:13:35.627	info	[NSPanel_Badezimmer] Setting panel to offline until first message!
                    mqtt.0
                    2025-10-24 21:13:35.626	info	Client [iobroker_a350717b-2ee5-45f8-8f61-d6db59dcf564] subscribes on "SmartHome/NSPanel_Badezimmer/stat/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_Badezimmer\.stat\..*/
                    mqtt.0
                    2025-10-24 21:13:35.625	info	Client [iobroker_a350717b-2ee5-45f8-8f61-d6db59dcf564] subscribes on "SmartHome/NSPanel_Badezimmer/stat/#" with regex /^SmartHome\.NSPanel_Badezimmer\.stat\..*/
                    mqtt.0
                    2025-10-24 21:13:35.618	info	Client [iobroker_a350717b-2ee5-45f8-8f61-d6db59dcf564] subscribes on "SmartHome/NSPanel_Badezimmer/tele/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_Badezimmer\.tele\..*/
                    mqtt.0
                    2025-10-24 21:13:35.617	info	Client [iobroker_a350717b-2ee5-45f8-8f61-d6db59dcf564] subscribes on "SmartHome/NSPanel_Badezimmer/tele/#" with regex /^SmartHome\.NSPanel_Badezimmer\.tele\..*/
                    mqtt.0
                    2025-10-24 21:13:35.613	info	Client [iobroker_a350717b-2ee5-45f8-8f61-d6db59dcf564] subscribes on "mqtt.0.SmartHome.NSPanel_Badezimmer.stat.RESULT"
                    mqtt.0
                    2025-10-24 21:13:09.829	info	Client [NSPanel_Badezimmer] publishOnSubscribe send all known states
                    mqtt.0
                    2025-10-24 21:13:09.629	info	Client [NSPanel_Badezimmer] subscribes on "SmartHome/NSPanel_Badezimmer/cmnd/#" with regex /^mqtt\.0\.SmartHome\.NSPanel_Badezimmer\.cmnd\..*/
                    mqtt.0
                    2025-10-24 21:13:09.628	info	Client [NSPanel_Badezimmer] subscribes on "SmartHome/NSPanel_Badezimmer/cmnd/#" with regex /^SmartHome\.NSPanel_Badezimmer\.cmnd\..*/
                    mqtt.0
                    2025-10-24 21:13:09.578	info	Client [NSPanel_Badezimmer] connected with secret 1761333189577_4195
                    mqtt.0
                    2025-10-24 21:13:04.494	info	Client [NSPanel_Badezimmer] connection closed: closed
                    mqtt.0
                    2025-10-24 21:13:03.531	info	Client [iobroker_a350717b-2ee5-45f8-8f61-d6db59dcf564] connected with secret 1761333183530_4548
                    2025-10-24 21:13:02.095	info	Detailed configuration checks are suppressed here. Full validation output is only shown when the configuration script is sent to the adapter.
                    2025-10-24 21:13:02.094	info	Found 1 script configs for topics: SmartHome/NSPanel_Badezimmer
                    2025-10-24 21:13:02.094	info	Configured panels: name#topic -> [NSPanel_Badezimmer#SmartHome/NSPanel_Badezimmer]
                    2025-10-24 21:13:02.022	info	starting. Version 0.6.8 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.2, js-controller: 7.0.6
                    In der Instanz wird wird das panel als offline angezeigt:
                    • M Max_yeah
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      mqtt.0
                      muuulle
                      #615
                      @max_yeah
                      Drück einmal eine Taste auf dem Panel. Das hilf bei mir in der selben Situation 😀
                      • M muuulle
                        @max_yeah
                        M Online
                        M Online
                        Max_yeah
                        #616
                        @muuulle Danke, nur leider tut sich da nix.
                        T T 2 Antworten Letzte Antwort
                        • M Max_yeah
                          TT-Tom
                          #617
                          @max_yeah
                          gehe mal bitte in die Tasmota Konsole, starte das panel neu und zeige mal das Log
                          zeige mal die MQTT Einstellungen vom Adapter
                          Gruß Tom
                          Public Transport
                          NSPanel Adapter Wiki
                          • M Max_yeah
                            ticaki
                            #618
                            @max_yeah
                            Das löschen von allem sollte NIE nötig sein - und danach läufts i.d.R. erstmal garnicht mehr, das deinstallieren und reinstallieren vom Adapter nur wenn was extrem daneben läuft. Ich hab den noch nie reinstalliert(also löschen vom Adapter und wieder installieren) oder große Zweige an States gelöscht und teste fast jedes Update erst bei mir.
                            Um zu helfen fehlen mir da ein paar grundsätzliche Dinge - da das mqtt.0 schon mal danach aussieht als wenn du nicht den Adapter eigenen Mqtt-Server benutzt wäre ein Bild der mqtt Konfig(vom Server und von diesem Adapter) und ein Bild der NSPanel-Einstellungen hilfreich.
                            Spenden
                            M 2 Antworten Letzte Antwort
                            • T TT-Tom
                              @max_yeah
                              M Online
                              M Online
                              Max_yeah
                              #619
                              @tt-tom sorry, ich glaub ich hab das panel jetzt endgültig gecrashed 🤦
                              Werde es noch mal komplett neu flashen müssen. Kann nicht mal mehr die MQTT Einstellungen öffnen. Und startet die ganze zeit in den SaveBoot. Ich melde mich wieder wenn ich es wieder zum laufen gebracht hab.
                              Vielleicht schmeis ich auch gleich den adapter noch mal runter und starte das ganze mit einem cleanen Adapter von vorne.
                              Sorry für die Störung.
                              • M Max_yeah
                                ticaki
                                #620
                                @max_yeah
                                Bitte keine Panik - safeboot kommt wenn du tasmota updates - wenn du 15.1 drauf hast, wird das mit dem Adapter nix werden - 15.0.1 und alles ist gut. Falls der Tasmota nach 5 Minuten noch immer im Safeboot ist, update neu starten und dann FINGER WEG 🤣
                                EDIT: Wir helfen gerne - daher lass uns auch helfen - empfehle aber das du den Adapter internen MQTT Server benutzt. Das macht die wenigsten Probleme.
                                Spenden
                                • T ticaki
                                  @max_yeah
                                  M Online
                                  M Online
                                  Max_yeah
                                  #621
                                  @ticaki Hey danke, werd ich machen sobald ich es neu aufgestzt hab. Ja ich dachte da ich noch 3 andere Panels mit dem "Alten" system betreibe kann ich den mqtt weiter verwenden.
                                  • T ticaki
                                    @max_yeah
                                    TT-Tom
                                    #622
                                    @ticaki
                                    laut screenshot 15.0.1.
                                    Gruß Tom
                                    Public Transport
                                    • M Max_yeah
                                      ticaki
                                      #623
                                      @max_yeah sagte in Betatest NSPanel-lovelace-ui v0.6.x:
                                      Das Problem mit dem alten System ist - das 95% der Anwender keinen Plan haben was die Einstellungen bedeuten - der interne verwendet das was funktioniert und da kann man nix "falsch" einstellen. Kannst ja beide betreiben - mqtt-server verbraucht jetzt nicht sonderlich viel ressourcen.
                                      Spenden
                                      • M Online
                                        M Online
                                        Max_yeah
                                        #624
                                        Mein Panel gibt mir das zurück...
                                        File Not Found
                                        URI: /cn
                                        Method: GET
                                        Arguments: 0
                                        • M Max_yeah
                                          File Not Found
                                          URI: /cn
                                          Method: GET
                                          Arguments: 0
                                          ticaki
                                          #625
                                          File Not Found
                                          URI: /cn
                                          Method: GET
                                          Arguments: 0
                                          wenn du was machst? Und wo gibt es das zurück
                                          Spenden
