  4. [Aufruf] Dringender Test sql 1.6.4
203 Beiträge 15 Kommentatoren 65.4k Aufrufe
  • BBTownB Offline
    BBTownB Offline
    BBTown
    #116
    ich habe auch gerade gesehen … das Format der Spalte "val" in der "ts_bool"ist in der MariaDB vom Typ "tinyint", das sollte die 0 und 1 Darstellung von true und false erklären.
    • sissiwupS Offline
      sissiwupS Offline
      sissiwup
      #117
      1.6.8: (nach nächtlichen Neustart)
      ost.zotac	2018-02-07 05:30:45.029	error	instance system.adapter.sql.0 terminated with code 0 (OK)
      Caught	2018-02-07 05:30:45.029	error	by controller[3]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      Caught	2018-02-07 05:30:45.029	error	by controller[3]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      Caught	2018-02-07 05:30:45.028	error	by controller[3]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      Caught	2018-02-07 05:30:45.028	error	by controller[3]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2018-02-07 05:30:45.028	error	by controller[3]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      Caught	2018-02-07 05:30:45.028	error	by controller[3]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2018-02-07 05:30:45.028	error	by controller[3]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2018-02-07 05:30:45.027	error	by controller[3]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      Caught	2018-02-07 05:30:45.027	error	by controller[3]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2018-02-07 05:30:45.027	error	by controller[3]: at Socket. (/opt/iobroker/node_modules/iobroker.sql/main.js:939:40)
      Caught	2018-02-07 05:30:45.027	error	by controller[3]: 2018-02-07 05:30:44.454 - sql.0 ReferenceError: task is not defined
      Caught	2018-02-07 05:30:45.027	error	by controller[2]: 2018-02-07 05:30:44.453 - sql.0 uncaught exception: task is not defined
      Caught	2018-02-07 05:30:45.026	error	by controller[1]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      Caught	2018-02-07 05:30:45.026	error	by controller[1]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      Caught	2018-02-07 05:30:45.026	error	by controller[1]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      Caught	2018-02-07 05:30:45.026	error	by controller[1]: at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2018-02-07 05:30:45.025	error	by controller[1]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      Caught	2018-02-07 05:30:45.025	error	by controller[1]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      Caught	2018-02-07 05:30:45.025	error	by controller[1]: at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      Caught	2018-02-07 05:30:45.024	error	by controller[1]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      Caught	2018-02-07 05:30:45.024	error	by controller[1]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      Caught	2018-02-07 05:30:45.024	error	by controller[1]: at Socket. (/opt/iobroker/node_modules/iobroker.sql/main.js:939:40)
      Caught	2018-02-07 05:30:45.024	error	by controller[1]: ReferenceError: task is not defined
      Caught	2018-02-07 05:30:45.023	error	by controller[0]: Cannot find module 'pg-native'
      sql.0	2018-02-07 05:30:44.995	info	terminating
      sql.0	2018-02-07 05:30:44.485	warn	Exception: ReferenceError: task is not defined
      Zurück auf 1.6.7 -> Fehler weg.
      MfG
      Sissi
      1 CCU3 1 CCU2-Gateway 1 LanGateway 1 Pi-Gateway 1 I7 für ioBroker/MySQL
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        #118
        @sissiwup:
        Zurück auf 1.6.7 -> Fehler weg. `
        Von 1.6.8 gab es sehr kurzfristig ein paar Überarbeitungen. Hattest Du den letzten Stand noch einmal drüber installiert?
        Ich hatten den Fehler mit einem Zwischenstand der 1.6.8 auch. Dann gab es ganz schnell einen Fix un der Fehler war weg.
        • apollon77A Offline
          #119
          Jupp scheinbar hatte sissiwup die zwischenversion drauf. Please retry ;-)
            #120
            Ich glaube wir sind auf der Zielgeraden. Ich habe noch eine Kleinigkeit geändert was das Start-Logging angeht - da wurde teilweise der geloggte "letze existierende Wert" verzögert geloggt zusammen mit der nächsten Änderung, was durchaus komisch aussah.
            Also die 1.6.8 die jetzt auf Github ist wäre aus meiner Sicht ok … erste Tests bestätigen es.
            Also wenn Ihr könnt bitte JETZT (also nach 10:15 heute) nochmal neu installieren.
            @sissiwup: Vor allem Du bitte :-)
            Und bitte nach update starten, Log checken nach Fehlern. Falls welche da sind bitte nochmal stoppen und nochmal starten. Sind die Fehler dann immer noch da? Bei ruhr70 hat das initiale "verbogene Typen glattziehen" zu ein paar Warnungen geführt, die beim zweiten Start aber weg waren ...
            Wenn Fehler waren bitte trotzdem mir schicken/posten.
            Wenn das alles passt suche ich als nächstes User mit 1.5.6 (Stable) die mal ein Update versuchen ... bin gespannt was dann noch so passiert ...
            In jedem Fall Mega Danke an Eure Unterstützung!!!
            • ruhr70R Offline
              ruhr70R Offline
              ruhr70
              #121
              Mehs Dank für Deine Arbeit!
              • R Offline
                rudiraz
                #122
                Also ich komme von sql 1.5.6 und habe es gewagt, nun die aktuelle von github 1.6.8 zu installieren.
                Es funktioniert alles tadellos ohne Fehlermeldungen beim Starten des Adapters
                • sissiwupS Offline
                  sissiwupS Offline
                  sissiwup
                  #123
                  habe neuen Fehler:
                  sql.0	2018-02-07 21:53:13.478	error	Error: ER_NO_SUCH_TABLE: Table 'iobroker.undefined' doesn't exist
                  sql.0	2018-02-07 21:53:13.443	error	Please wait till next data record is logged and reload.
                  sql.0	2018-02-07 21:53:13.443	warn	For getHistory for id hm-rpc.0.HEQ0113689.1.VALVE_STATE: Type empty. Need to write data first. Index = 410
                  web.0	2018-02-07 21:53:13.317	info	2018-02-07T20:53:13.317Z Connected system.user.admin
                  web.0	2018-02-07 21:53:12.429	info	2018-02-07T20:53:12.429Z Connected system.user.admin
                  host.zotac	2018-02-07 21:53:03.443	info	Update repository "online" under "https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json"
                  iobroker	2018-02-07 21:53:03.166	info	exit 0
                  Das ist ein Uralter Datenpunkt von einem VD-Regler (also die alten Heizungsregler).
                  Wenn ich im Objekt mir die Tabelle der Werte Anzeige, sind die alle sauber geloggt.
                  Float-Grafik bringt obige Fehlermeldung. (PS: neuste Version vom GIT, grade vor 5 min. installiert).
                  MfG
                  Sissi
                  • BBTownB Offline
                    BBTownB Offline
                    BBTown
                    #124
                    @apollon77:
                    In jedem Fall Mega Danke an Eure Unterstützung!!! ` fühlt sich nach "verkehrter Welt" an.
                    Der Dank geht natürlich an dich!
                      Kueppert
                      #125
                      Hab mich auch nochmal getraut, das Update anzuklicken. Wie immer ist der pi3 dabei eingefroren. Kaltstart und Upgrade SQL und schon hab ich dir 1.6.8 drauf. Werde mir den Verlauf anschauen und berichten.
                      PS: bei kleinste Änderung im zu loggenden Objekt, muss man da mit Punkt oder Komma Arbeiten? 0.01 oder 0,01?
                      Danke und viele Grüße, Thorsten
                      Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk
                        #126
                        @sissiwup:
                        Float-Grafik bringt obige Fehlermeldung. (PS: neuste Version vom GIT, grade vor 5 min. installiert). `
                        Schau dir mal genau die Meldung an. Bei der neuen Version kann es vorkommen das noch nicht die Typinfo initialisiert ist und damit die getHistory-Abfrage ins leere läuft.
                        Wartemal bis der ein bissl läuft und ein Wert geloggt wurde Geht Flot dann?
                        Ansonsten habe ich die letzte 1.6.8 jetzt als 1.6.9 veröffentlicht. Ist dann morgen im latest. Nur so um sicher zu gehen das auch jeder die aktuelle Version bekommt :-)
                          #127
                          @Kueppert:
                          PS: bei kleinste Änderung im zu loggenden Objekt, muss man da mit Punkt oder Komma Arbeiten? 0.01 oder 0,01? `
                          geht beides.
                          • BBTownB Offline
                            BBTownB Offline
                            BBTown
                            #128
                            @apollon77:
                            Ansonsten habe ich die letzte 1.6.8 jetzt als 1.6.9 veröffentlicht. Ist dann morgen im latest. Nur so um sicher zu gehen das auch jeder die aktuelle Version bekommt :-) ` beim Update auf die v.1.6.9 hat sich dieses mal mein raspberry aufgehangen
                              #129
                              Echt interessant … das kann nur am sqlite Kompiliervorgang liegen ... komisch
                              • R Offline
                                rudiraz
                                #130
                                Das denke ich ebenfalls (als Laie).
                                Auf meinem Tinkerboard dauert die Installation extrem lange; mit dem Unterschied, dass es sich nicht aufhängt.
                                Obwohl ich das öfters gedacht habe…
                                  Kueppert
                                  #131
                                  Kann man nicht sqlite evtl separat updaten? Würde gern testen ob mein pi3 deshalb beim Update vom SQL Adapter immer aufgibt…
                                  • 0 Offline
                                    0 Offline
                                    0018
                                    #132
                                    @BBTown:
                                    @apollon77:
                                    Ansonsten habe ich die letzte 1.6.8 jetzt als 1.6.9 veröffentlicht. Ist dann morgen im latest. Nur so um sicher zu gehen das auch jeder die aktuelle Version bekommt :-) beim Update auf die v.1.6.9 hat sich dieses mal mein raspberry aufgehangen
                                    meiner auch…. Load auf über 40, keine Reaktion mehr.
                                    Mfg
                                    0018
                                      #133
                                      Load 40? Kann es damit ein Speicherproblem sein? Swappt er ? Welcher Prozess? Kann das mal einer mit top verfolgen parallel?!
                                        Kueppert
                                        #134
                                        @apollon77:
                                        Load 40? Kann es damit ein Speicherproblem sein? Swappt er ? Welcher Prozess? Kann das mal einer mit top verfolgen parallel?! ` Gern… Aber ich kenne "top" leider nicht. Ist das ein Befehl in der Konsole???
                                          #135
                                          Ja. Zeigt Prozesse mit ihren cpu Auslastungen, Speicher und sowas an.
