  4. Test Adapter mytime
    apollon77A
Test Adapter mytime
adaptermytimetestwidget
606 Beiträge 52 Kommentatoren 222.1k Aufrufe 63 Beobachtet
  • T trojanhector
    @trojanhector ich habe von css die root vergessen.
    :root{
    	/*eigene Parameter*/
        --btn-bck-true: hsla(360, 63%, 88%, 1);
        --btn-bck-false: hsla(78, 63%, 79%, 1);
        --btn-bord-color-true: hsla(0, 0%, 0%, 1);
        --btn-bord-hccolor-false: hsla(0, 0%, 100%, 1);
        --btn-txt-true: hsla(0, 0%, 0%, 1);
        --btn-txt-false: hsla(0, 0%, 0%, 1);
        --btn-outershadow-col-true: hsla(34, 77%, 53%, 1);
        --btn-outershadow-col-false: hsla(0, 0%, 100%, 1);
        --page_bar: rgba(25,45,77,1);
        --text_sel: rgba(245,167,8,1);
        --text_col_menue: rgba(255,255,255,1);
        --show_btn_col: rgba(245,167,8,1);
        --backgrd_sel_menue:rgba(148,255,154,1);
        --pastell_blue: #bad6e5;
        --antrazit_1: #424242;
        --black: #000000;
        --bluegrey_1: #607d8b;
        --bluegrey_2: #78909c;
        --bluegrey_3: #90a4ae;
        --bluegrey_4: #b0bec5;
        --bluegrey_5: #cfd8dc;
        --bluegrey_6: #eceff1;
        --dimgray: #696969;
        --gray_1:rgba(60,75,80,1);
        --green_1: #adf701;
        --gold: #ffd700;
        --red_1: #FF5733;
        --thistle: #d8bfd8;
        --violet_1: rgba(55,27,195,1);
        --white: #ffffff;
        --whitesmoke: #f5f5f5;
        --yellow_8:#fbc02d;
        --cbocol: var(--dimgray);
        --cboborderhover: var(--gold);
        --light_sld_l: 40px;
        --light_sld_w: 97px;
        --light_sld_h: 2em;
        --light_sze_l:15px;
        --light_sze_w: 127px;
        --light_sze_h: 44px;
        --light_swl_l: 2px;
        --light_swl_w: 140px;
        --light_swl_h: 2em;
        --light_msw_l:20px;
        --light_sws_l: 107px;
        --light_sws_o: 1px; //oben
        --light_sws_w: 48px;
        --light_sws_h: 2em;
        --light_l_45: 45px;
        --light_w_53: 53px;
        --light_h_2_5: 2.5em;
        --light_o_3_4: 3.4em;
        --light_o_O: 1px;
        --light_o_2_5: 2.5em;
        --light_th: 1.15em;
        --cursor_p: pointer;
        --headerh_1: 2em;
        /*Begin Gradient*/
        --black_3d: linear-gradient(135deg, #7d7e7d 0%,#0e0e0e 100%);
        --yellow_3D: linear-gradient(135deg, #f1e767 0%,#feb645 100%);
        --yellow_3D_2:linear-gradient(135deg, #fff787 0%,#ffcc79 100%);
        --yellow_red_wave: linear-gradient(135deg, #ffa787 0%,#f1e767 72%,#ff7980 100%);
        --gray_horizon_1: linear-gradient(to right, #f6f8f9 0%,#e5ebee 24%,#d7dee3 37%,#e5ebee 78%,#f5f7f9 100%);
        --green_3d_4: linear-gradient(135deg, #f8ffe8 0%,#e3f5ab 33%,#b7df2d 100%);
        --green_gloss_3d: linear-gradient(135deg, #9dd53a 0%,#80c217 60%,#a1d54f 76%,#a1d54f 76%,#7cbc0a 100%);
        --green_flat: linear-gradient(to bottom, #b6e026 0%,#abdc28 100%);
        --blue_gloss_2: linear-gradient(135deg, #b8e1fc 0%,#a9d2f3 10%,#90bae4 25%,#90bcea 37%,#90bff0 50%,#6ba8e5 51%,#a2daf5 83%,#bdf3fd 100%);
        --blue_gloss_1: linear-gradient(135deg, #3b679e 0%,#2b88d9 50%,#207cca 51%,#7db9e8 100%);
        --red_gloss_wave: linear-gradient(135deg, #feccb1 0%,#f17432 26%,#f17432 39%,#ea5507 62%,#fb955e 100%);
        --blue_3d_12 :linear-gradient(135deg, #feffff 0%,#d2ebf9 100%);
        --red_3d_1: linear-gradient(135deg, #fedada 0%,#fec0c0 45%,#ffa3a3 100%);
        /*Ende Gradient*/
        --background_1: var(--gray_1);
        --button_m_l: var(--light_l_45);
        --button_m_w: var(--light_w_53);
        --button_m_h: var(--light_h_2_5);
        --button_m_o: var(--light_o_O);
        --button_m_c: var(--cursor_p);
        --wl_switch_bg: var(--yellow_3D);
        --wl_switch_o_r_green: var(--green_flat);
        --wl_switch_o_r_red: var(--red_1);
        --wl_switch_o_r_white: var(--whitesmoke);
        --wl_switch_o_r: var(--whitesmoke);
        --wl_switch_width: 47%;
        --wl_switch_hight: 4.7em;
        --wl_switch_bc_on: var(--black);
        --wl_switch_bc_off: var(--black);
        --wl_switch_cc_std: var(--black);
        --wl_border_weather_hc: var(--gold);
        --wl_border_weather_tb: var(--gold);
        --wl_border_weather_tfc: var(--bluegrey_1);
        --wl_border_width_1: 100%;
        --wl_border_top_1: 0px;
        --wl_border_left_1: 0px;
        --rssFeedWidget_Font: var(--whitesmoke);
        --rssFeedWidget_Background: var(--gray_1);
        /*shutterControl begin*/
        /*color*/
        --sc-vis-tbl-caption-bckgrd: var(--yellow_3D);
        --sc-vis-tbl-caption-color: var(--bluegrey_1);
        --sc-vis-tbl-header-bckgrd: var(--red_1);
        --sc-vis-tbl-header-color: var(--smokewhite);
        --sc-vis-tbl-bckgrd: var(--gray);
        --sc-vis-tbl-border-color: var(--white);
        --sc-vis-tbl-color: var(--white);
        --sc-vis-tbl-fcol-bckgrd: var(--thistle);
        --sc-vis-tbl-fcol-color: var(--white);
        --sc-vis-tbl-row-bckgrd: var(--thistle);
        --sc-vis-tbl-row-color: var(--white);
        --sc-vis-tbl-row2-bckgrd: var(--thistle);
        --sc-vis-tbl-row2-color: var(--white);
        /*shutterControl end*/
    OliverIOO
    OliverIOO
    OliverIO
    #519
    @trojanhector sagte in Test Adapter mytime:
    kann man jetzt wunderbar sehen, dass es jeweils oben und links einen Versatz gibt. Lässt sich das neutralisieren
    das mit dem versatz verstehe ich noch nicht ganz.
    meinst du das die schrift nicht ganz exakt am rand oben und unten aufhört?
    grund 1
    du hast die zeile mit 1.25em definiert. ich habe ein zeichen mit 1em höhe definiert.
    grund 2
    die schriftart lato ist vertikal nicht zentriert sondern eher unten orientiert. dadurch ist der doppelpunkt auch nicht so ganz in der mitte
    der abstand nach oben hin ist der größe eines zeichens geschuldet wie es vom font her definiert ist
    hier mal ein screenshot mit em zeilenhöhe
    um jetzt den letzten rand oben auch noch weg zu bekommen, musst du mit einem negative margin arbeiten.
    hier mal ein screenshot mit margin-top: -4px auf dem element cdclock
    .cdclock {
      margin-top: -4px;
    dann passt allerdings die zeilenhöhe nicht mehr, die dann ebenfalls angepasst werden muss, dazu könnte man dann im widget bei heigth
    das eintragen
    calc(1em - 6px)
    Meine Adapter und Widgets
    Links im Profil
    • T trojanhector
      @oliverio Servus,
      ja, das Widget ist jetzt responsive. Gilt für den Editor:
      Das mit der Größe im Editor funktioniert scheinbar erstmal nicht. Aber wenn man die Seite refreshed sieht es passend aus.
      In der Runtime auf dem Handy und auf dem Bildschirm sieht es gut aus.
      Ich habe für alle meine Widgets grundsätzlich im CSS eine Klasse für den Rand definiert. Im Bild, eine Responsive Einstellung mit 2 Spalten, kann man jetzt wunderbar sehen, dass es jeweils oben und links einen Versatz gibt. Lässt sich das neutralisieren?
      Kann man bei Nixie noch die Text Align Eigenschaft mit reinbringen? Jetzt ist es zwar klein, hängt bei einer 100% Width aber am linken Rand. Bei Plain ist es besser.
      Zu 2. Das mit dem falschen Format im plain kann ich heute auch nicht mehr nachvollziehen. Kann am Reboot liegen.
      OliverIOO
      OliverIOO
      OliverIO
      #520
      welchen effekt versuchst du da zu erreichen?
      cdclock ist eine flexbox und die display eigenschaft des widgets lässt sich nur begrenz beeinflussen
      wenn du den inhalt zentrieren möchtest, mach am besten eine zusätzliche css klasse
      #w000000 {
        display: flex;
        justify-content: center;
      somit würde alles so aussehen
      klar ist das jetzt eine extreme darstellung und so knapp willst du das nicht haben, aber auf der basis kannst du weitermachen
      werde das mal in die doku aufnehmen
      Links im Profil
      • OliverIOO OliverIO
        #w000000 {
          display: flex;
        T
        T
        trojanhector
        #521
        @oliverio Die Formatierungen waren genau das, was ich brauche.
        Und das mit dem Versatz verstehe ich auch nicht. Du kannst ja auf dem Foto erkennen, dass die Widgets weder oben noch links bündig sind. Aber jetzt nach dem erneuten Aufruf der Seite passt auf einmal alles.
        Nochmal danke für die schnelle Erklärung, und ja, ein Eintrag in die Doku wäre klasse.
        • M
          M
          micklafisch
          #522
          ich habe gerade ein Problem mit den mytime Widgets (2.0.1) in Verbindung mit vis2 (2.13.4).
          Wenn ich den Countdown nur einblenden will wenn er tatsächlich läuft wird er erstmal nicht angezeigt.
          Wenn ich allerdings während der Countdown aktiv ist die Seite neu lade, dann funktioniert die Anzeige. Das ausblenden geht auch im Anschluss wenn der Countdown abgelaufen ist. Wenn ich das 1x gemacht habe wird er auch wieder angezeigt wenn der Countdown erneut gestartet wird. So lange aber die Seite geladen wird während der Countdown nicht aktiv ist, wird das Widget dann nicht angezeigt wenn er startet.
          Blöd zu erklären, aber so ists bei mir. Wenn ich einfache HTML Widgets mit dieser Sichtbarkeitsbedingung einblende funktioniert es immer problemlos.
          OliverIOO 2 Antworten Letzte Antwort
          • M micklafisch
            OliverIOO
            OliverIOO
            OliverIO
            #523
            @micklafisch
            Muss ich mal ausprobieren.
            Fällt mir gerade aber nix ein woran das scheitern sollte.
            Links im Profil
            • M micklafisch
              OliverIOO
              OliverIOO
              OliverIO
              #524
              @micklafisch
              also hier funktioniert das
              280b9ef5-8adb-4c72-9aa9-b47bae458233-20251017-0031-06.7340814.mp4
              getestet mit vis 1.5.6
              Links im Profil
                @micklafisch
                M
                M
                micklafisch
                #525
                @oliverio
                ja, hatte ja die vis2 geschrieben. Unter vis1 habe ich in einem anderen Projekt auch ein Countdown, da läuft das. Mit vis2 gibts scheinbar Probleme.
                • M micklafisch
                  @oliverio
                  OliverIOO
                  OliverIOO
                  OliverIO
                  #526
                  @micklafisch
                  unter vis2 das selbe
                  d57529b9-82db-4072-9c09-3692f03d2519-20251017-1035-58.0979806.mp4
                  Links im Profil
                    @micklafisch
                    M
                    M
                    micklafisch
                    #527
                    @oliverio
                    ich habe insg. 8 Countdowns auf der Seite über die Sichtbarkeit eingebunden und diese werden per Skript gesteuert und nicht per Button. Nichts was irgendwie auf einen Fehler hindeutet. Ich habe jetzt die 8 Countdowns mal auf eine neue leere Seite importiert, aktuell funktioniert alles. Ich beobachte mal weiter, ggf. hängt es mit einem anderen Widget zusammen.
                    • M micklafisch
                      @oliverio
                      OliverIOO
                      OliverIOO
                      OliverIO
                      #528
                      @micklafisch
                      gut. dann schauen wir
                      die visibility funktion ist ja was von vis. unter vis1 und vis2 ist es jeweils der selbe code.
                      allerdings kann es schon sein, das sich in vis2 da irgendwas beißt. meiner Meinung nach ist vis2 auch nicht ganz so stabil wie vis1.
                      Links im Profil
                      O 1 Antwort Letzte Antwort
                        @micklafisch
                        O
                        O
                        Oli
                        schrieb am zuletzt editiert von Oli
                        #529
                        @OliverIO
                        kann ich mir einen immer Wiederkehrenden Countdown anlegen wie z.B. einen Jahrestag, der nach Ablauf automatisch wieder startet?
                        Und wenn ja, wie mache ich das?
                        Oliver
                        • O Oli
                          @OliverIO
                          OliverIOO
                          OliverIOO
                          OliverIO
                          #530
                          @Oli
                          Das geht über den Reiter timeseries.
                          Da kannst du relativ komplexe Zeitreihen aufbauen.
                          Ein Jahrestag ist relativ einfach.
                          Das funktioniert bspw wie eine terminierte in Outlook
                          Links im Profil
                            @Oli
                            O
                            O
                            Oli
                            #531
                            @OliverIO
                            Anscheinend stelle ich mich wieder etwas an und bekomme es leider nicht hin.
                            Hast du vielleicht irgendwo ein Beispiel?
                            Oliver
                            • O Oli
                              @OliverIO
                              OliverIOO
                              OliverIOO
                              OliverIO
                              #532
                              @Oli
                              Als erstes denReiter Timeseries auswählen und neue Timeserie anlegen
                              name vergeben, und neue hinzufügende zeitregel anlegen
                              dann auch der zeitregel einen namen geben,
                              jährlich und ein starttermin angeben
                              voreingestellt sind 10 ereignisse, also nach 10 jahren wäre schluss. alternativ auch die anderen möglichkeiten prüfen.
                              im rechten bereich werden die nächsten berechneten termine angezeigt.
                              über die weiteren Reiter Ext1/Ext2 können noch viel komplexere Regeln erstellt werden (beliebt ist bspw immer letzter Tag im Monat um eine bestimmte Uhrzeit)
                              nach dem speichern wird der erstellte datenpunkt zum gegebenen zeitpunkt dann getriggert, was du dann mit einem skript entsprechend auswerten und weitere aktionen starten kannst.
                              Links im Profil
                                @Oli
                                O
                                O
                                Oli
                                #533
                                @OliverIO
                                Ok, danke für die Anleitung, jetzt weiß ich auch wo mein Denkfehler lag, bzw, wo ich mich wahrscheinlich falsch ausgedrückt habe.
                                Neuer Versuch, ich hoffe jetzt verständlicher.
                                Ich möchte mir einen Countdown von jetzt bis zum nächsten Jahrestag in der VIS anzeigen lassen,
                                der jede Minute weniger wird und nach erreichen des Jahrestages wieder von vorne beginnt.
                                Oliver
                                • O Oli
                                  @OliverIO
                                  OliverIOO
                                  OliverIOO
                                  OliverIO
                                  #534
                                  @Oli
                                  eigentlich könnte man das mit einem Skript machen, der immer wenn ein Countdown abgelaufen ist den wieder neu startet.
                                  ich bin gerade an einer Erweiterung des Adapters, bei dem das als zusätzlicher Modus eingebaut ist, so das der sich selber verlängert.
                                  Links im Profil
                                    @Oli
                                    O
                                    O
                                    Oli
                                    #535
                                    @OliverIO
                                    Ohja, dass wäre cool, könntest du dann deine Widgets für die Anzeige von Monaten erweitern?
                                    Oliver
                                    • O Oli
                                      @OliverIO
                                      OliverIOO
                                      OliverIOO
                                      OliverIO
                                      #536
                                      @Oli
                                      ![Bild Text](Bild Link)
                                      Ich muss mir das mal nochmal anschauen.
                                      Aufgrund der ungleichen Anzahl von Tagen im Monat und im Jahr habe ich damals entschieden das wegzulassen. Weiter erfordert das eine Menge Zusatzlogik, die nicht so einfach war.
                                      Ich muss auch mal schauen, ob ich dafür eine Bibliothek verwenden kann, die damit auch besser umgehen kann.
                                      Damals konnte sie es noch nicht.
                                      https://github.com/moment/moment/pull/571
                                      https://momentjs.com/docs/#/displaying/difference/
                                      Links im Profil
                                        @Oli
                                        OliverIOO
                                        OliverIOO
                                        OliverIO
                                        #537
                                        Neue Version 2.1.0
                                        • das build system wurde auf vite umgestellt. da das eine tiefer eingreifende änderung war, bitte auf entsprechende probleme achten.
                                        • für countdown timer wurde die stopbeahviour option rerun eingeführt. ein abgelaufener timer wird automatisch neu gestartet. die neue startzeit wird auf die endezeit des abgelaufenen timers eingestellt. falls der adapter oder iobroker gestoppt war und die letzte timerzeit entsprechend so lange abgelaufen ist wie der time lang ist, wird die neue startzeit auf die aktuelle zeit eingestellt
                                        Die Prüfung auf Anzeige Monate und Jahre in den widgets war jetzt noch nicht enthalten. Das kommt dann als nächstes, andernfalls berichte ich hier über das Ergebnis
                                        Links im Profil
                                        • S
                                          S
                                          Shadowhunter23
                                          schrieb am zuletzt editiert von Shadowhunter23
                                          #538
                                          Bei Zeitreihen kommt bei mir:
                                          Cannot import from custom/customComponents.js: TypeError: Failed to fetch dynamically imported module: http://192.168.0.222:8081/adapter/mytime/custom/customComponents.js
                                          Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                                          ioBroker Backup Analyzer
                                          84.0k
