  4. Test Adapter Unifi Network
    6.3k
173 Beiträge 34 Kommentatoren 26.8k Aufrufe 38 Beobachtet
  • CodierknechtC Codierknecht
    @scrounger sagte in Test Adapter Unifi Network:
    teste mal die v1.1.3
    Die gute Nachricht: Die Instanz wird grün.
    Die schlechte: Ich erhalte keine Daten :-(
    FYI: Es läuft hier nur ein Unifi-AP-Pro. Also ausschließlich WLAN-Clients und kein Unifi-OS.
    unifi-network.0
    	2025-10-05 17:55:09.066	info	[onReady]: WebSocket listener to realtime API successfully started
    unifi-network.0
    	2025-10-05 17:55:09.058	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    unifi-network.0
    	2025-10-05 17:55:09.047	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    unifi-network.0
    	2025-10-05 17:55:09.020	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    unifi-network.0
    	2025-10-05 17:55:08.920	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:55:05.886	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:55:02.841	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:54:59.806	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:54:56.772	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:54:53.740	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:54:50.688	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:54:47.654	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots.
    unifi-network.0
    	2025-10-05 17:54:44.610	info	[login]: WebSocket connection to realtime API successfully established
    unifi-network.0
    	2025-10-05 17:54:44.587	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
    unifi-network.0
    	2025-10-05 17:54:44.263	info	[login]: Logged in successfully to the Unifi-Network controller (host: 192.168.179.13:8443, site: D*****V, isUnifiOs: false)
    unifi-network.0
    	2025-10-05 17:54:44.262	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
    unifi-network.0
    	2025-10-05 17:54:43.974	debug	[NetworkApi.logout] Logging out and clearing credentials.
    unifi-network.0
    	2025-10-05 17:54:43.957	info	starting. Version 1.1.3 (non-npm: Scrounger/ioBroker.unifi-network#fab63502974c2b23b621ebc96844f9d5bc0c61ef) in /opt/iobroker/node_modules/iobroker.unifi-network, node: v22.20.0, js-controller: 7.0.7
    unifi-network.0
    	2025-10-05 17:54:43.896	debug	States connected to redis: 0.0.0.0:9010
    unifi-network.0
    	2025-10-05 17:54:43.846	debug	States create User PubSub Client
    unifi-network.0
    	2025-10-05 17:54:43.846	debug	States create System PubSub Client
    unifi-network.0
    	2025-10-05 17:54:43.841	debug	Redis States: Use Redis connection: 0.0.0.0:9010
    unifi-network.0
    	2025-10-05 17:54:43.829	debug	Objects connected to redis: 0.0.0.0:9011
    unifi-network.0
    	2025-10-05 17:54:43.827	debug	Objects client initialize lua scripts
    unifi-network.0
    	2025-10-05 17:54:43.812	debug	Objects create User PubSub Client
    unifi-network.0
    	2025-10-05 17:54:43.812	debug	Objects create System PubSub Client
    unifi-network.0
    	2025-10-05 17:54:43.811	debug	Objects client ready ... initialize now
    unifi-network.0
    	2025-10-05 17:54:43.798	debug	Redis Objects: Use Redis connection: 0.0.0.0:9011
    host.iobroker
    	2025-10-05 17:54:43.193	info	instance system.adapter.unifi-network.0 in version "1.1.3" (non-npm: Scrounger/ioBroker.unifi-network#fab63502974c2b23b621ebc96844f9d5bc0c61ef) started with pid 3818642
    host.iobroker
    	2025-10-05 17:54:42.900	info	"system.adapter.unifi-network.0" enabled
    Meine Einstellungen:
    Vielleicht korrigierts Du bei Gelegenheit auch den Fauxpas der automatischen Übersetzung 😁
    ScroungerS Offline
    ScroungerS Offline
    Scrounger
    @codierknecht
    also ich hab jetzt extra mal einen self hosted controller in einem proxmox lxc aufgesetzt und auch ne AP dran gehängt.
    Läuft bei mir ohne probleme. Evtl. wird da irgendwas geblockt?
    Test mal die v1.1.4, hab ein paar debug info mit eingebaut, damit man sieht was er da genau macht. Am besten den Adapter davor komplett mal löschen.
    Und bitte info's nach dem test im issue auf github posten!
    @lobomau
    Test mal die v1.1.4, UniFi OS oder self hosted wird jetzt automatusch erkannt. Am besten den Adapter davor komplett mal löschen.
    Wenn noch immer Probleme bestehen, bitte issue auf github erstellen
    lobomauL CodierknechtC 2 Antworten Letzte Antwort
    • ScroungerS Scrounger
      @codierknecht
      @lobomau
      lobomauL Offline
      lobomauL Offline
      lobomau
      schrieb am zuletzt editiert von lobomau
      Edit. ok... zuerst code eintragen und hinterher den Codeknopf drüber. Hab ich sonst andersrum gemacht...
      @scrounger haben die bei Github etwas geändert? Sieht in der Preview nicht nach Code aus:
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      ScroungerS 1 Antwort Letzte Antwort
      • lobomauL lobomau
        ScroungerS Offline
        ScroungerS Offline
        Scrounger
        @lobomau
        https://docs.github.com/en/get-started/writing-on-github/working-with-advanced-formatting/creating-and-highlighting-code-blocks#fenced-code-blocks
          @codierknecht
          @lobomau
          CodierknechtC Offline
          Codierknecht
          unifi-network.0
          2025-10-06 11:25:53.661	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/device?separateUnmanaged=false&includeTrafficUsage=false)
          unifi-network.0
          2025-10-06 11:25:50.633	info	[login]: WebSocket connection to realtime API successfully established
          unifi-network.0
          2025-10-06 11:25:50.630	info	[login]: Logged in successfully to the Unifi-Network controller (host: 192.168.179.13:8443, site: D*****V, isUnifiOs: false)
          unifi-network.0
          2025-10-06 11:25:50.629	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
          unifi-network.0
          2025-10-06 11:25:50.302	debug	[NetworkApi.logout] Logging out and clearing credentials.
          unifi-network.0
          2025-10-06 11:25:50.292	debug	[NetworkApi.logout] Logging out and clearing credentials.
          unifi-network.0
          2025-10-06 11:25:50.292	warn	[aliveChecker]: No connection to the Unifi-Network controller -> restart connection (retries: 0, no data since 55s)
          unifi-network.0
          2025-10-06 11:25:20.281	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi-network.0
          2025-10-06 11:25:20.261	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi-network.0
          2025-10-06 11:25:20.231	debug	Search can't be optimized because wildcard not at the end, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
          unifi-network.0
          2025-10-06 11:25:20.120	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/wlan/enriched-configuration)
          unifi-network.0
          2025-10-06 11:25:17.100	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/wlan/enriched-configuration)
          unifi-network.0
          2025-10-06 11:25:14.060	debug	[createOrUpdateChannel]: creating channel 'wlan'
          unifi-network.0
          2025-10-06 11:25:14.053	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/history?includeUnifiDevices=true&withinHours=0)
          unifi-network.0
          2025-10-06 11:25:11.024	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/history?includeUnifiDevices=true&withinHours=0)
          unifi-network.0
          2025-10-06 11:25:07.992	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/active?includeTrafficUsage=false&includeUnifiDevices=true)
          unifi-network.0
          2025-10-06 11:25:04.964	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/clients/active?includeTrafficUsage=false&includeUnifiDevices=true)
          unifi-network.0
          2025-10-06 11:25:01.941	debug	[createOrUpdateChannel]: creating channel 'clients'
          unifi-network.0
          2025-10-06 11:25:01.939	debug	[createOrUpdateChannel]: creating channel 'clients.vpn'
          unifi-network.0
          2025-10-06 11:25:01.937	debug	[createOrUpdateChannel]: creating channel 'clients.guests'
          unifi-network.0
          2025-10-06 11:25:01.934	debug	[createOrUpdateChannel]: creating channel 'clients.users'
          unifi-network.0
          2025-10-06 11:25:01.929	debug	[createOrUpdateChannel]: creating channel 'devices'
          unifi-network.0
          2025-10-06 11:25:01.927	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/device?separateUnmanaged=false&includeTrafficUsage=false)
          unifi-network.0
          2025-10-06 11:24:58.905	error	[NetworkApi._retrieve] Unable to connect to the Network controller. This is temporary and may occur during device reboots (url: https://192.168.179.13:8443/v2/api/site/D*****V/device?separateUnmanaged=false&includeTrafficUsage=false)
          unifi-network.0
          2025-10-06 11:24:55.850	info	[login]: WebSocket connection to realtime API successfully established
          unifi-network.0
          2025-10-06 11:24:55.836	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
          unifi-network.0
          2025-10-06 11:24:55.565	info	[login]: Logged in successfully to the Unifi-Network controller (host: 192.168.179.13:8443, site: D*****V, isUnifiOs: false)
          unifi-network.0
          2025-10-06 11:24:55.564	debug	[NetworkApi.loginController] login to self hosted UniFi controller successful.
          unifi-network.0
          2025-10-06 11:24:55.325	debug	[NetworkApi.logout] Logging out and clearing credentials.
          unifi-network.0
          2025-10-06 11:24:55.325	debug	[NetworkApi.detectUnifiOs] self hosted controller detected
          unifi-network.0
          2025-10-06 11:24:55.325	debug	[NetworkApi.detectUnifiOs] detect self hosted controller repsonse: {"statusCode":302,"headers":{"location":"/manage","content-length":"0","date":"Mon, 06 Oct 2025 09:24:55 GMT","keep-alive":"timeout=30","connection":"keep-alive"},"trailers":{},"opaque":null,"body":{"_events":{},"_readableState":{"highWaterMark":65536,"buffer":[],"bufferIndex":0,"length":0,"pipes":[],"awaitDrainWriters":null}}}
          unifi-network.0
          2025-10-06 11:24:55.282	info	starting. Version 1.1.4 (non-npm: Scrounger/ioBroker.unifi-network) in /opt/iobroker/node_modules/iobroker.unifi-network, node: v22.20.0, js-controller: 7.0.7
          unifi-network.0
          2025-10-06 11:24:55.193	debug	States connected to redis: 0.0.0.0:9010
          unifi-network.0
          2025-10-06 11:24:55.137	debug	States create User PubSub Client
          unifi-network.0
          2025-10-06 11:24:55.136	debug	States create System PubSub Client
          unifi-network.0
          2025-10-06 11:24:55.131	debug	Redis States: Use Redis connection: 0.0.0.0:9010
          unifi-network.0
          2025-10-06 11:24:55.118	debug	Objects connected to redis: 0.0.0.0:9011
          unifi-network.0
          2025-10-06 11:24:55.116	debug	Objects client initialize lua scripts
          unifi-network.0
          2025-10-06 11:24:55.097	debug	Objects create User PubSub Client
          unifi-network.0
          2025-10-06 11:24:55.096	debug	Objects create System PubSub Client
          unifi-network.0
          2025-10-06 11:24:55.095	debug	Objects client ready ... initialize now
          unifi-network.0
          2025-10-06 11:24:55.082	debug	Redis Objects: Use Redis connection: 0.0.0.0:9011
          Geht gleich auch noch an GH
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            unifi-network.0
            Codierknecht
            @Scrounger
            Mit einer Site "default" klappt's dann auch. Issue habe ich geschlossen.
              @Scrounger
              ScroungerS Offline
              ScroungerS Offline
              Scrounger
              @codierknecht
              Hab jetzt noch ne Prüfung eingebaut, die anzeigt welche Sites überhaupt verfügbar sind und bei falscher Eingabe ne Error Meldung wirft
                @codierknecht
                Codierknecht
                @scrounger
                Die automatische Übersetzung hat wieder zugeschlagen 😁
                  @scrounger
                  ScroungerS Offline
                  ScroungerS Offline
                  Scrounger
                  @codierknecht sagte in Test Adapter Unifi Network:
                  @scrounger
                  Tja da gibt's noch nen paar andere so klöpse drin
                  Wenn ihr mithelfen wollt dann erstellt nen PR mit korrigierten Übersetzungen.
                  • O Offline
                    O Offline
                    oxident
                    Tolle Idee mit dem Adapter ... und danke, dass Du das öffentlich verfügbar machst.
                    Leider ist bei mir wohl ein Rebuild bei der Installation nötig ... und der schlägt mit NodeJS 22.20.0 fehl da das Modul "TokenRefresher" nicht gefunden werden kann. Habe ein Issue unter https://github.com/Scrounger/ioBroker.unifi-network/issues/33 aufgemacht.
                      Dragon
                      Kann die Zugangsdaten nicht speichern. Er gibt jedes mal einen Json error und die Daten sind wieder leer.
                      • D Dragon
                        ScroungerS Offline
                        ScroungerS Offline
                        Scrounger
                        @dragon
                        Logs und genauere Beschreibung was du gemacht hast?
                        • JackDanielJ Offline
                          JackDanielJ Offline
                          JackDaniel
                          schrieb am zuletzt editiert von JackDaniel
                          wäre es möglich das der adapter den db last_seen bei den clients gleich von einem unix zeitstempel in ein "lesbares" datum/uhrzeit format umwandelt,oder ist es doch besser das über einen alias zu konvertieren?
                          Carpe diem
                          • JackDanielJ JackDaniel
                            Codierknecht
                            @jackdaniel
                            Nee des ist bewusst so weil ich immer mit timestamps arbeitet. Wenn man mit der Maus drüber fährt zeigt es ja das Datum und Zeit an.
                            Alternativ kannst du ja nen alias erstellen
                            • mcm1957M Online
                              mcm1957M Online
                              mcm1957
                              @dragon said in Test Adapter Unifi Network:
                              @Scrounger
                              Hab heute dieses Issue mitbekommen:
                              https://github.com/ioBroker/ioBroker.admin/issues/3257
                              Nur als Info falls da was in Admin faul ist das sich nur bei gewissen Konstellationen auswirkt. Issue bei unifi-network hab ich nicht gefunden um das dort ggF zu verlinken
                              Support Repositoryverwaltung.
                              LESEN - gute Forenbeitrage
                                @dragon
                                Dragon
                                @scrounger Log kann ich heut Abend oder morgen vormittag anhängen. Habe den Adapter über die Katze installiert und nach dem Anlegen der Instanz fragt er nach IP und Zugangsdaten. Die kann ich eintippen und dann klicke ich auf speichern. Dann zeigt er den weiter unten noch einmal erwähnten json Fehler an und wenn ich dann noch einmal die Konfiguration aufmache ist sie leer. Das passiert jedes mal beim Druck auf speichern
                                • D Dragon
                                  ScroungerS Offline
                                  ScroungerS Offline
                                  Scrounger
                                  schrieb am zuletzt editiert von Scrounger
                                  @dragon
                                  OK aber lösch den Adapter erstmal und installier die Version aus'm stable rep!
                                  Und alle Infos in ein issue bei GitHub packen.
                                    @dragon
                                    Dragon
                                    @scrounger im stable gibt es den adapter nicht. da gibt es die vorgängerversion mit 0.0.7 oder soetwas.
                                    • D Dragon
                                      mcm1957M Online
                                      mcm1957M Online
                                      mcm1957
                                      Im Stable gibts die 1.1.6. Im Latest die 1.1.7:
                                      Ein 0. irgendwas war nie im Stable. Bist beim richtigen Adapter unterwegs?
                                      Und
                                      Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                                      Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                                      • mcm1957M mcm1957
                                        Und
                                        Codierknecht
                                        @mcm1957 sagte in Test Adapter Unifi Network:
                                        Das ist der bislang vorhandene "Original" Adapter für Unifi.
                                        Hat mit diesem hier eigentlich nix zu tun.
                                          Dragon
                                          schrieb am zuletzt editiert von Dragon
                                          @codierknecht das ist aber auch der einzige den ich im stable finde. Den hier gibt es da garnicht.
                                          Hatte es von unterwegs über die Cloud versucht. Da könnte ich ihn nicht finden. Nun im LAN habe ich ihn finden können.
