  4. Thermostat Kompatibilität
36 Beiträge 5 Kommentatoren 3.5k Aufrufe 5 Beobachtet
  • S Stefan341
    @asgothian
    Das müsste der relevante Teil des Logs sein
    2025-09-22 18:09:35.880 - info: zigbee.0 (110710) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"1a043fc8e5a5ed11bc85f1a32981d5c7","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1a043fc8e5a5ed11bc85f1a32981d5c7-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyAMA0"}]
    2025-09-22 18:09:39.245 - info: zigbee.0 (110710) Opening zigbee Network for 60 seconds
    2025-09-22 18:09:48.251 - info: zigbee.0 (110710) Starting interview of '0x44e2f8fffe0f3d69'
    2025-09-22 18:09:48.408 - info: zigbee.0 (110710) Device '0x44e2f8fffe0f3d69' announced itself
    2025-09-22 18:09:58.388 - warn: zigbee.0 (110710) Device 0x44e2f8fffe0f3d69 "undefined" not found.
    2025-09-22 18:10:17.587 - info: zigbee.0 (110710) Device '0x44e2f8fffe0f3d69' announced itself
    2025-09-22 18:10:23.648 - error: zigbee.0 (110710) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-22 18:10:23.649 - error: zigbee.0 (110710) unhandled promise rejection: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    2025-09-22 18:10:23.649 - error: zigbee.0 (110710) Error: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:541:23)
    at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:639:20)
    at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:439:20
    at Queue.execute (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
    at ZStackAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:437:16)
    at Request.send (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:86:20)
    at Endpoint.sendRequest (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:338:20)
    2025-09-22 18:10:23.650 - error: zigbee.0 (110710) Exception-Code: 205: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    2025-09-22 18:10:23.705 - info: zigbee.0 (110710) Halting zigbee adapter. Restart delay is at least 30 seconds.
    2025-09-22 18:10:23.706 - info: zigbee.0 (110710) cleaning everything up...
    2025-09-22 18:10:23.709 - info: zigbee.0 (110710) Saved local configuration data
    2025-09-22 18:10:24.127 - info: zigbee.0 (110710) Closing Zigbee network, 16 seconds remaining
    2025-09-22 18:10:24.708 - warn: zigbee.0 (110710) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-09-22 18:10:25.376 - error: host.ioB-Slave Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-22 18:10:25.377 - error: host.ioB-Slave Caught by controller[2]: Error: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    2025-09-22 18:10:25.377 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:541:23)
    2025-09-22 18:10:25.377 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:639:20)
    2025-09-22 18:10:25.378 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:639:20)
    2025-09-22 18:10:25.378 - error: host.ioB-Slave Caught by controller[2]: at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:439:20
    2025-09-22 18:10:25.378 - error: host.ioB-Slave Caught by controller[2]: at Queue.execute (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
    2025-09-22 18:10:25.378 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:437:16)
    2025-09-22 18:10:25.378 - error: host.ioB-Slave Caught by controller[2]: at Request.send (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:86:20)
    2025-09-22 18:10:25.378 - error: host.ioB-Slave Caught by controller[2]: at Endpoint.sendRequest (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:338:20)
    2025-09-22 18:10:25.378 - error: host.ioB-Slave instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-09-22 18:10:25.379 - info: host.ioB-Slave Restart adapter system.adapter.zigbee.0 because enabled
    2025-09-22 18:10:56.276 - info: host.ioB-Slave instance system.adapter.zigbee.0 in version "3.0.5" started with pid 113951
    2025-09-22 18:10:59.609 - info: zigbee.0 (113951) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
    2025-09-22 18:10:59.657 - info: zigbee.0 (113951) Adapter ready - starting subsystems. Adapter is running in info mode.
    2025-09-22 18:10:59.659 - info: zigbee.0 (113951) init localConfig
    2025-09-22 18:10:59.747 - info: zigbee.0 (113951) delete old Backup files. keep only last 10
    2025-09-22 18:10:59.751 - info: zigbee.0 (113951) --- creating device debug ---
    2025-09-22 18:10:59.752 - info: zigbee.0 (113951) Autostart Zigbee subsystem
    2025-09-22 18:10:59.753 - info: zigbee.0 (113951) Starting Adapter npm ...
    2025-09-22 18:10:59.775 - info: zigbee.0 (113951) Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
    2025-09-22 18:10:59.778 - info: zigbee.0 (113951) configured transmit power : normal
    2025-09-22 18:10:59.780 - info: zigbee.0 (113951) Starting Zigbee-Herdsman
    2025-09-22 18:11:00.326 - info: zigbee.0 (113951) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20210708 (2-1.2.7.1)
    2025-09-22 18:11:00.327 - info: zigbee.0 (113951) Unable to disable LED, unsupported function.
    2025-09-22 18:11:00.388 - info: zigbee.0 (113951) 0x0ceff6fffe3c8598 (addr 46294): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.397 - info: zigbee.0 (113951) 0x0ceff6fffe755a7f (addr 49277): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.401 - info: zigbee.0 (113951) 0x0ceff6fffe7501c8 (addr 7664): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.404 - info: zigbee.0 (113951) 0x842712fffe7dfb91 (addr 35623): SNZB-03P - SONOFF Zigbee PIR sensor (EndDevice)
    2025-09-22 18:11:00.409 - info: zigbee.0 (113951) 0x842712fffe774abf (addr 57506): SNZB-03P - SONOFF Zigbee PIR sensor (EndDevice)
    2025-09-22 18:11:00.412 - info: zigbee.0 (113951) 0x842712fffe7ce735 (addr 1191): SNZB-03P - SONOFF Zigbee PIR sensor (EndDevice)
    2025-09-22 18:11:00.596 - info: zigbee.0 (113951) 0x842e14fffe15cc5b (addr 12785): HG06106C - Lidl Livarno Lux E27 bulb RGB (Router)
    2025-09-22 18:11:00.602 - info: zigbee.0 (113951) 0x588e81fffeb97054 (addr 27716): HG06106C - Lidl Livarno Lux E27 bulb RGB (Router)
    2025-09-22 18:11:00.605 - info: zigbee.0 (113951) 0x08ddebfffef31e0f (addr 44003): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.608 - info: zigbee.0 (113951) 0x0ceff6fffef0fab0 (addr 8324): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.611 - info: zigbee.0 (113951) 0x08ddebfffef34e8b (addr 10209): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.614 - info: zigbee.0 (113951) 0x0ceff6fffe796d31 (addr 36130): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.617 - info: zigbee.0 (113951) 0x08ddebfffef31b25 (addr 64216): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.620 - info: zigbee.0 (113951) 0x0ceff6fffeab2ccf (addr 13515): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.622 - info: zigbee.0 (113951) 0x0ceff6fffeab4874 (addr 20809): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.624 - info: zigbee.0 (113951) 0x0ceff6fffef0e279 (addr 10908): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.627 - info: zigbee.0 (113951) 0x0ceff6fffe7a9bd0 (addr 47572): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.629 - info: zigbee.0 (113951) 0x0ceff6fffe7a8e5d (addr 31454): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.632 - info: zigbee.0 (113951) 0xd44867fffe4c596c (addr 39389): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.634 - info: zigbee.0 (113951) 0xd44867fffe4c2e92 (addr 19118): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.637 - info: zigbee.0 (113951) 0xd44867fffe4c599b (addr 65102): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.639 - info: zigbee.0 (113951) 0xd44867fffe4c5abe (addr 41666): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.641 - info: zigbee.0 (113951) 0x0ceff6fffe782803 (addr 57086): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.643 - info: zigbee.0 (113951) 0xd44867fffe4c5cbb (addr 8990): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
    2025-09-22 18:11:00.644 - info: zigbee.0 (113951) 0x0ceff6fffeab7583 (addr 41118): SNZB-04P - SONOFF Contact sensor (EndDevice)
    2025-09-22 18:11:00.647 - info: zigbee.0 (113951) 0x0ceff6fffe5d918f (addr 15791): SNZB-01P - SONOFF Wireless button (EndDevice)
    2025-09-22 18:11:00.649 - info: zigbee.0 (113951) 0x8c65a3fffed4f850 (addr 63166): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
    2025-09-22 18:11:00.698 - info: zigbee.0 (113951) 0xa4c1383b3d92b80b (addr 54748): A1Z - Nous Smart plug (with power monitoring) (Router)
    2025-09-22 18:11:00.702 - info: zigbee.0 (113951) 0xa4c1387e12b8dd59 (addr 62068): A1Z - Nous Smart plug (with power monitoring) (Router)
    2025-09-22 18:11:00.806 - info: zigbee.0 (113951) 0xa4c13864ccc9a98c (addr 45241): Unsupported (model TS0601)(Router)
    2025-09-22 18:11:00.809 - info: zigbee.0 (113951) 0xa4c138ff1cae6d53 (addr 29372): A1Z - Nous Smart plug (with power monitoring) (Router)
    2025-09-22 18:11:00.817 - info: zigbee.0 (113951) 0xa4c138a331371316 (addr 17723): B1Z - Nous 1 gang switch (Router)
    2025-09-22 18:11:00.819 - info: zigbee.0 (113951) 0xa49e69fffe71c86c (addr 47788): SNZB-01P - SONOFF Wireless button (EndDevice)
    2025-09-22 18:11:00.822 - info: zigbee.0 (113951) 0xc4d8c8fffe03db9f (addr 1809): SNZB-03P - SONOFF Zigbee PIR sensor (EndDevice)
    2025-09-22 18:11:00.842 - info: zigbee.0 (113951) 0xa4c13849367c6744 (addr 55396): Unsupported (model TS0601)(Router)
    2025-09-22 18:11:00.862 - info: zigbee.0 (113951) 0x44e2f8fffe0f3d69 (addr 20298): Unsupported (model undefined)(Unknown)
    2025-09-22 18:11:00.863 - info: zigbee.0 (113951) Currently 36 devices are joined:
    2025-09-22 18:11:00.865 - info: zigbee.0 (113951) Zigbee started
    2025-09-22 18:11:02.117 - info: zigbee.0 (113951) debug devices set to ["a4c138f98b74ad84"]
    2025-09-22 18:11:03.456 - warn: zigbee.0 (113951) download icon undefined for undefined Device not available. Check your devices.
    2025-09-22 18:11:03.624 - warn: zigbee.0 (113951) Device 0xa4c13864ccc9a98c "TS0601" not found.
    2025-09-22 18:11:03.627 - warn: zigbee.0 (113951) Device 0xa4c13849367c6744 "TS0601" not found.
    2025-09-22 18:11:07.545 - warn: zigbee.0 (113951) Device 0x44e2f8fffe0f3d69 "undefined" not found.
    2025-09-22 18:11:34.166 - info: zigbee.0 (113951) Opening zigbee Network for 60 seconds
    2025-09-22 18:11:43.235 - info: zigbee.0 (113951) Starting interview of '0x44e2f8fffe0f3d69'
    2025-09-22 18:11:43.391 - info: zigbee.0 (113951) Device '0x44e2f8fffe0f3d69' announced itself
    2025-09-22 18:12:06.961 - info: zigbee.0 (113951) Device '0x44e2f8fffe0f3d69' announced itself
    2025-09-22 18:12:18.739 - error: zigbee.0 (113951) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2025-09-22 18:12:18.740 - error: zigbee.0 (113951) unhandled promise rejection: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    2025-09-22 18:12:18.740 - error: zigbee.0 (113951) Error: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:541:23)
    at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:639:20)
    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:439:20
    at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
    at ZStackAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:437:16)
    at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:86:20)
    at Endpoint.sendRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:338:20)
    2025-09-22 18:12:18.740 - error: zigbee.0 (113951) Exception-Code: 205: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    2025-09-22 18:12:18.772 - info: zigbee.0 (113951) Halting zigbee adapter. Restart delay is at least 30 seconds.
    2025-09-22 18:12:18.772 - info: zigbee.0 (113951) cleaning everything up...
    2025-09-22 18:12:18.774 - info: zigbee.0 (113951) Saved local configuration data
    2025-09-22 18:12:19.039 - info: zigbee.0 (113951) Closing Zigbee network, 16 seconds remaining
    2025-09-22 18:12:19.775 - warn: zigbee.0 (113951) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2025-09-22 18:12:20.451 - error: host.ioB-Slave Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2025-09-22 18:12:20.451 - error: host.ioB-Slave Caught by controller[2]: Error: ZCL command 0x44e2f8fffe0f3d69/1 ssIasZone.enrollRsp({"enrollrspcode":0,"zoneid":23}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
    2025-09-22 18:12:20.452 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:541:23)
    2025-09-22 18:12:20.452 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:639:20)
    2025-09-22 18:12:20.452 - error: host.ioB-Slave Caught by controller[2]: at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:439:20
    2025-09-22 18:12:20.453 - error: host.ioB-Slave Caught by controller[2]: at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
    2025-09-22 18:12:20.453 - error: host.ioB-Slave Caught by controller[2]: at ZStackAdapter.sendZclFrameToEndpoint (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:437:16)
    2025-09-22 18:12:20.453 - error: host.ioB-Slave Caught by controller[2]: at Request.send (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/helpers/request.ts:86:20)
    2025-09-22 18:12:20.453 - error: host.ioB-Slave Caught by controller[2]: at Endpoint.sendRequest (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/model/endpoint.ts:338:20)
    2025-09-22 18:12:20.453 - error: host.ioB-Slave instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2025-09-22 18:12:20.453 - info: host.ioB-Slave Restart adapter system.adapter.zigbee.0 because enabled
    2025-09-22 18:12:51.452 - info: host.ioB-Slave instance system.adapter.zigbee.0 in version "3.0.5" started with pid 113971
    2025-09-22 18:12:54.784 - info: zigbee.0 (113971) starting. Version 3.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v22.19.0, js-controller: 7.0.7
    2025-09-22 18:12:54.827 - info: zigbee.0 (113971) Adapter ready - starting subsystems. Adapter is running in info mode.
    2025-09-22 18:12:54.830 - info: zigbee.0 (113971) init localConfig
    2025-09-22 18:12:54.922 - info: zigbee.0 (113971) delete old Backup files. keep only last 10
    2025-09-22 18:12:54.926 - info: zigbee.0 (113971) --- creating device debug ---
    2025-09-22 18:12:54.926 - info: zigbee.0 (113971) Autostart Zigbee subsystem
    2025-09-22 18:12:54.927 - info: zigbee.0 (113971) Starting Adapter npm ...
    2025-09-22 18:12:54.951 - info: zigbee.0 (113971) Installed Version: iobroker.zigbee@3.0.5 (Converters 24.8.0 Herdsman 4.4.1)
    2025-09-22 18:12:54.955 - info: zigbee.0 (113971) configured transmit power : normal
    2025-09-22 18:12:54.956 - info: zigbee.0 (113971) Starting Zigbee-Herdsman
    2025-09-22 18:12:55.520 - info: zigbee.0 (113971) Zigbee-Herdsman started successfully with Coordinator firmware version: ZStack3x0 : 20210708 (2-1.2.7.1)
    2025-09-22 18:12:55.522 - info: zigbee.0 (113971) Unable to disable LED, unsupported function.
    Was ich interessant finde, dass ziemlich weit unten steht, er hätte die Version 24.8.0 installiert.
    In der Package.json war aber die ganze Zeit immernoch 24.14.0 eingetragen. Das musste ich nicht nochmal ändern, nur wie gesagt, npm i neu ausführen.
    Also muss er die Information, dass er die 24.8.0 nehmen soll, vom woanders bekommen haben.
    Das Ganze ist passiert als ich einen Sonoff Wasserlecksensor (https://sonoff.tech/de-de/products/sonoff-zigbee-water-leak-sensor-snzb-05p?srsltid=AfmBOoq7u9MMsclweMGV9GAVErWKMuuqfzP8_fFHTw3iYfjvag5peNWf) neu hinzugefügt habe.
    Danach habe ich testweise noch einen NOUS Stecker (https://www.berrybase.de/nous-a1z-smarte-steckdose-zigbee?srsltid=AfmBOopai3I40lRkPd8k3wEIaWRCqAsdo9DLR5SMw1_F3qQLTzP_keHn) hinzugefügt. Das hat ohne Zwischenfälle geklappt.
    Ich hoffe, ich konnte dir mit den Informationen weiterhelfen :)
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @stefan341 sagte in Thermostat Kompatibilität:
    @asgothian
    Ich fürchte da musst du noch eine Zeile in der package.json ändern. Da steht zigbee-herdsman: 4.x.x Die musst du auf zigbee-herdsman: 5.0.4 anpassen, dann sollten die Abstürze weg sein. (natürlich wieder ein npm i dazwischen
    A.
    • AsgothianA Asgothian
      @asgothian
      A.
      Stefan341
      @asgothian
      removed 3 packages, changed 1 package, and audited 959 packages in 10s
      127 packages are looking for funding
        run `npm fund` for details
      26 vulnerabilities (1 low, 13 moderate, 9 high, 3 critical)
      To address issues that do not require attention, run:
        npm audit fix
      To address all issues possible (including breaking changes), run:
        npm audit fix --force
      Some issues need review, and may require choosing
      a different dependency.
      Run `npm audit` for details.
      ist es sinnvoll npm audit fix --force auszuführen?
      • S Stefan341
        @asgothian
          npm audit fix
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @stefan341 nein
        S 2 Antworten Letzte Antwort
          @stefan341 nein
          Stefan341
          @asgothian
          Ok, ich werde berichten falls mir noch was auffällt :)
          Danke nochmal
            @stefan341 nein
            Stefan341
            @asgothian
            Irgendwie werden meine Thermostate wieder nicht erkannt. Ich habe es gelöscht und versucht neu zu paaren. Leider auch ohne Erfolg
            New device: 'XXXX' does not have a known model. please provide an external converter for 'TS0601'.
            Interview successful: {"friendly_name":"XXXX","supported":false}
            Pairing time left: 40
            New device joined 'XXXX' model TS0601
            Device 'XXXX' announced itself
            Interview started: XXXXX
            • S Stefan341
              @asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              @asgothian
              • welche adapter version nutzt du ?
              • warum nutzt du nicht die version aus dem latest ?
              A.
                @asgothian
                A.
                Stefan341
                @asgothian
                Ich benutze 3.0.5 Mir wird keine neuere Version bzw. kein Update angezeigt. Kann ich die Suche manuell „anstoßen“?
                • S Stefan341
                  @asgothian
                  @stefan341
                  Du hast das Stable-Repo aktiv.
                  github:	3.1.5
                  latest:	3.1.5 for 1 days
                  stable:	3.0.5 for 38 days
                  Die Beta-Version kann man so installieren:
                    @asgothian
                    A.
                    Stefan341
                    @asgothian said in Thermostat Kompatibilität:
                    weil du weiter oben geschrieben hast, dass dies zu unerwünschten Effekten führen kann
                    • S Stefan341
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      Das war am Anfang mal. Inzwischen ist die Version aus dem Latest fast stable würdig. Die kannst du also nehmen. Ansonsten weiss ich nicht was bei Dir passiert ist - wahrscheinlich wurde wieder ein alter Herdsman aktiv. Du stehst also wieder da wo wir Mitte September waren. Ich hatte ja gesagt das es nur eine Zwischenlösung ist. Also entweder das wiederholen oder aus dem Latest installieren.
                      A.
                      nachtrag: oder bis zum kommenden Wochenende warten - dann wird der aktuelle wohl in den Stable hoch rutschen. Es gibt noch einen kleinen Bug - der ist auf meinem Teststand schon behoben- der Fix geht morgen ins Latest. Der wird dich aber kaum betreffen.
                        A.
                        Stefan341
                        schrieb am zuletzt editiert von Stefan341
                        @Thomas-Braun
                        Danke für die Anleitung :)
                        @asgothian
                        Ich habe jetzt die 3.1.5 installiert.
                        Soweit scheint das super zu laufen. Meine Thermostate werden wieder alle erkannt.
                        Ich habe jetzt nur zwei Coordinatoren
                        Dann habe ich in den Logs noch ein paar Fehlermeldungen gefunden...
                        zigbee.0
                        2025-10-05 23:39:44.219	warn	Object zigbee.0.a4c13849367c6744.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
                        zigbee.0
                        2025-10-05 23:39:44.113	warn	Object a4c13849367c6744.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
                        zigbee.0
                        2025-10-05 22:36:56.461	error	Send command to 0xa4c1389742c05838 failed with no error code (Timeout - 2266 - 1 - 191 - 6 - 11 after 10000ms)
                        zigbee.0
                        2025-10-05 18:46:09.636	error	unable to read /opt/iobroker/iobroker-data/zigbee_0 : EISDIR: illegal operation on a directory, read
                        • S Stefan341
                          @Thomas-Braun
                          @asgothian
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          zigbee.0
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          zigbee.0  2025-10-05 23:39:44.219	warn	Object zigbee.0.a4c13849367c6744.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
                          zigbee.0  2025-10-05 23:39:44.113	warn	Object a4c13849367c6744.mode is invalid: obj.common.states has an invalid type! Expected "object", received "string" This will throw an error up from js-controller version 7.0.0!
                          zigbee.0  2025-10-05 22:36:56.461	error	Send command to 0xa4c1389742c05838 failed with no error code (Timeout - 2266 - 1 - 191 - 6 - 11 after 10000ms)
                          zigbee.0  2025-10-05 18:46:09.636	error	unable to read /opt/iobroker/iobroker-data/zigbee_0 : EISDIR: illegal operation on a directory, read
                          Die Log-Meldungen musst du mir schon vollständig posten. Und es stellt sich die Frage was fuer ein Device das a4c13849367c6744 ist.
                          A.
                          Nachtrag: Bitte folgendes machen:
                          • Upload des zigbee Adapters
                          • Reload am Browser mit leeren des Cache.
                          Du bist der einzige mit dem 2. Tile
