  4. Frigate Adapter für ioBroker
    6.3k
383 Beiträge 48 Kommentatoren 140.8k Aufrufe 45 Beobachtet
  • B BenjaminCz
    @wendy2702 Ok das ist der Fehler. Habe nun Richtig eingetragen. Danke!
    Aber kommt leider jetzt ein anderer Fehler:
    IOBroker lauft per HTTPS und Frigate auch per HTTPS (port 8971)
    frigate.0
    	2025-03-17 22:08:23.287	error	"<html>\r\n<head><title>401 Authorization Required</title></head>\r\n<body>\r\n<center><h1>401 Authorization Required</h1></center>\r\n<hr><center>nginx/1.25.3</center>\r\n</body>\r\n</html>\r\n"
    frigate.0
    	2025-03-17 22:08:23.286	error	AxiosError: Request failed with status code 401
    frigate.0
    	2025-03-17 22:08:23.286	warn	createCameraDevices error from http://192.168.178.18:8971/api/config
    frigate.0
    	2025-03-17 22:08:23.280	info	Create Device information and fetch Event History
    frigate.0
    	2025-03-17 22:08:21.008	warn	AxiosError: Request failed with status code 401
    frigate.0
    	2025-03-17 22:08:21.007	warn	fetchEventHistory error from http://192.168.178.18:8971/api/events
    frigate.0
    	2025-03-17 22:08:20.998	info	frigate.0 (12721) MQTT client frigate subscribed to topics: frigate/# from broker 003c41bd-eba6-4370-a138-c6d37204433d
    frigate.0
    	2025-03-17 22:08:20.962	info	Filter for message from client: frigate
    frigate.0
    	2025-03-17 22:08:20.961	info	New client: frigate
    frigate.0
    	2025-03-17 22:08:18.177	info	If you don't see a new client connected, please restart frigate and adapter.
    frigate.0
    	2025-03-17 22:08:18.176	info	Please enter host: 'IOBroker' and port: '1883' in frigate config
    frigate.0
    	2025-03-17 22:08:18.176	info	MQTT server started and listening on port 1883
    frigate.0
    	2025-03-17 22:08:18.090	warn	You are using the UI port 8971. Please use the API port 5000
    frigate.0
    	2025-03-17 22:08:18.077	info	starting. Version 1.3.1 (non-npm: iobroker-community-adapters/ioBroker.frigate#877e22a2d453de02d840835ec3e3db025509d22c) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.19.0, js-controller: 7.0.6
    host.IOBroker
    	2025-03-17 22:08:17.298	info	instance system.adapter.frigate.0 in version "1.3.1" (non-npm: iobroker-community-adapters/ioBroker.frigate#877e22a2d453de02d840835ec3e3db025509d22c) started with pid 12721
    host.IOBroker
    	2025-03-17 22:08:13.985	info	instance system.adapter.frigate.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.IOBroker
    	2025-03-17 22:08:13.499	info	stopInstance system.adapter.frigate.0 send kill signal
    frigate.0
    	2025-03-17 22:08:13.446	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    frigate.0
    	2025-03-17 22:08:13.445	info	terminating
    frigate.0
    	2025-03-17 22:08:13.444	info	Got terminate signal TERMINATE_YOURSELF
    host.IOBroker
    	2025-03-17 22:08:13.442	info	stopInstance system.adapter.frigate.0 (force=false, process=true)
    BenjaminCz
    #354
    @benjamincz Ok Adapter geht wohl nicht mit authentifikation sondern nur über port 5000. Ich habe den Port aber deaktiviert muss ich daher wieder aktivieren und Probiere es nocheinmal.
    • B BenjaminCz
      wendy2702W Online
      wendy2702W Online
      #355
      @benjamincz warum braucht man im Heimnetzwerk https und Authenticaton ?
      • wendy2702W wendy2702
        BenjaminCz
        #356
        @wendy2702 Ok danke jetzt Funktioniert alles ohne fehler. Da habe ich mir selbst ein bein gestellt. Eine frage hätte ich noch kann ich nun über blockly direkt die Snapshots abgreifen und weiterverarbeiten bzw. per mail oder Gotify senden oder bedarf es einer umkonvertierung des Snapshots ? Kurzum will einfach bei Bewegung das Snapshot z.b per Mail oder Gotify weiter senden.
        • B BenjaminCz
          wendy2702W Online
          wendy2702W Online
          #357
          @benjamincz ich versende direkt per Adapter und Telegramm.
          Noch nicht mit beschäftigt das mit etwas anderem zu versenden
            BenjaminCz
            #358
            Hallo Unter events History werden immer die letzten 10 events Angezeigt Richtig es werden nicht mehr ? Dann gibts es unten noch die json datei. Wird hier immer das letzte event hinterlegt oder wozu dient diese datei ? Evtl kann ich von dort das letzte event abgreifen von der letzen Kamera und muss nicht dann die 10 events anlegen.
            Vieleicht hat ja einer ein Blockly wo die events weiterverarbeitet werden. Gotify habe ich soweit fertig es werden auch Bilder angezeigt und der Link mit dem Video wird auch versendet. Es geht also nur um die Zwischenverarbeitung Frigate Adapter>Blockly>Gotify/Email ect.
            Vielen Dank!
              kuumaur
              #359
              Moin,
              ist es möglich die Notification via Blockly zu aktivieren oder zu deaktivieren?
              Ich benötige nicht immer die Notifications. Eigentlich nur, wenn ich nicht zu hause bin.
              Proxmox | IoBroker LXC Container | Zigbee | Rhasspy Voice | SqueezeBox | Frigate CCTV | Jarvis Vis |
              • crunchipC Abwesend
                crunchipC Abwesend
                #360
                @Wal @tombox
                hab mal ein Anliegen,
                Adapter v1.3.2
                genutzt wurde Frigate 0.15.1 und hab gestern auf 0.16.0 aktualisiert. Jedoch ist mir aufgefallen ( auch schon mit der v0.15 ) das zig Unterordner in den History Ordnern angelegt wurden, ergo hatte ich über 32000 Objekte. Hab mal den kompletten Baum gelöscht und bin nun schon wieder bei über 16000.
                siehe
                und das gleich nochmal bei jeder cam
                bei 3 cams
                WalW 1 Antwort Letzte Antwort
                  @Wal @tombox
                  Adapter v1.3.2
                  siehe
                  bei 3 cams
                  WalW Offline
                  WalW Offline
                  Wal
                  schrieb am zuletzt editiert von Wal
                  #361
                  @crunchip ,
                  habe mit dem neuen Adapter nichts mehr zu tun. 👼
                  edit: Du nutzt bestimmt den Mosquitto ?
                  Walter
                  DoorIO-Adapter
                  • WalW Wal
                    @crunchip ,
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #362
                    @wal das hatte ich dann auch gesehen, aber schon auf absenden gedrückt
                    naja, den frigatte integrierten auf port 1983
                    anderweitig hab ich nen externen mqtt auf port 1883
                      was habe ich denn vermutlich falsch konfiguriert wenn ich das im Log bekomme:
                      2024-11-05 12:23:00.705  - info: frigate.0 (89599) Notification sending active but no image available for type person state Event After
                      2024-11-05 12:23:00.709  - info: frigate.0 (89599) Clip sending active but no clip available
                      2024-11-05 12:23:42.424  - info: frigate.0 (89599) Notification sending active but no image available for type person state Event After
                      2024-11-05 12:23:42.424  - info: frigate.0 (89599) Clip sending active but no clip available
                      Laut iob um z.B. 12:34 ein Bild gespeichert wird
                      Und ebenfalls das im Log kommt:
                      2024-11-05 12:34:18.724  - info: frigate.0 (236155) Notification sending active but no image available for type person state Event After
                      V Offline
                      V Offline
                      virFortis
                      schrieb am zuletzt editiert von virFortis
                      #363
                      @wendy2702 Hi, hast du das Problem in den Griff bekommen?
                      Ich habe jetzt dem Umstieg von Raspberry auf Windows hinter mir. Iobroker läuft auf einem Windows Tablet und Frigate auf dem Raspberry weiter.
                      Vorher hat mir Frigate dann die Bilder weiter an Telegram geschickt, jetzt mit der neuen Config bekomme ich die Meldung:
                      "Notification sending active but no image available for type person state Event After" - wie bei dir. Unter Objekten ist das Bild aber auch gespeichert und sichtbar.
                      • V virFortis
                        wendy2702W Online
                        wendy2702W Online
                        #364
                        @virfortis Ich nutze Frigate nicht mehr.
                        H V 2 Antworten Letzte Antwort
                          H Nicht stören
                          H Nicht stören
                          Hansi1234
                          #365
                          @wendy2702 said in Frigate Adapter für ioBroker:
                          Was benutzt du nun?
                            V Offline
                            V Offline
                            virFortis
                            #366
                            @wendy2702 danke für die Antwort. Ich habe es doch hinbekommen..ich habe den snapshots in der config vom iobroker noch zusätzlich aktiviert und siehe jetzt kommen auch die Bilder an.
                            • H Hansi1234
                              Was benutzt du nun?
                              wendy2702W Online
                              wendy2702W Online
                              #367
                              @hansi1234 sagte in Frigate Adapter für ioBroker:
                              Was benutzt du nun?
                              Objekt Erkennung der Reolink Kameras Haupt-sächlich weil ich die Anzahl der VMs/CTs reduzieren möchte und mir die Erkennung der Kameras reicht.
                              • F Offline
                                fiddle
                                #368
                                Moin, gerade gesehen, dass der Frigate-Adapter hier ca. 2GB (!) RAM verschlingt, alle anderen Adapter die hier laufen sind <<500MB unterwegs. Woran liegt das, und kann ich das "bändigen"? Der Server hat zwar gut phys. Ram und die IObroker VM darf aktuell 8GB, da sind wir aber bald schon dank Frigate. Mutt datt so?
                                • F fiddle
                                  crunchipC Abwesend
                                  crunchipC Abwesend
                                  #369
                                  @fiddle said in Frigate Adapter für ioBroker:
                                  Falsche config in frigate, schau dir mal das log in Frigate an.
                                  Andernfalls mal die issue dazu auf github
                                  F 1 Antwort Letzte Antwort
                                    fiddle
                                    #370
                                    @crunchip Danke, ja, Frigate hatte sich irgendwie aufgehängt und sich das Log vollgeschmissen - verstanden habe ich's nicht. Frigate container neu gestartet, läuft nun seit Tagen wieder wie gehabt und der Adapter nimmt wieder so um die 150MB. Wie immer gilt: "Iiiiichhh hab nix gemacht!!" :) Danke und weitermachen (am Besten mit "nix machen")!
                                    • F Offline
                                      flispy
                                      #371
                                      ist es möglich nur Benachrichtigungen zu bekommen, wenn Objekte oder Bewegungen in bestimmten Zonen stattfindet? Aktuell bekomme ich Benachrichtigungen bei jedem Event. Wenn ich das Feld "Zonen von der Benachrichtigung ausschließen" nutze, habe ich das Gefühl, dass es nicht genutzt wird und die Benachrichtigungen trotzdem kommen
                                      T E 2 Antworten Letzte Antwort
                                      • F flispy
                                        tombox
                                        #372
                                        @flispy probier mal Keine Benachrichtigung senden, wenn die Zonenliste des Events für diese Kameras leer ist " manchmal ist die zone am Anfang noch leer
                                        • F flispy
                                          ewc
                                          #373
                                          @flispy Moin... ich nutze ausschließlich nur bestimmte Zonen für Benachrichtigungen. Mit einem Script schiebe ich die Nachricht mit Bild über pushsafer raus
